    4. Backitup Probleme mit mount NAS
      Snopy_16 last edited by
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       17:08:52 up  1:55,  3 users,  load average: 0.89, 0.98, 1.10
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sat 2024-02-17 17:08:52 CET
                 Universal time: Sat 2024-02-17 16:08:52 UTC
                       RTC time: n/a
                      Time zone: Europe/Vienna (CET, +0100)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.8G        3.1G        2.3G         34M        2.3G        4.5G
      Swap:            99M          0B         99M
      Total:          7.9G        3.1G        2.4G
               7811 M total memory
               3146 M used memory
               4170 M active memory
                962 M inactive memory
               2330 M free memory
                156 M buffer memory
               2178 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                          Type      Size  Used Avail Use% Mounted on
      /dev/root                           ext4      110G   14G   90G  14% /
      devtmpfs                            devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs                               tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                               tmpfs     1.6G  9.3M  1.6G   1% /run
      tmpfs                               tmpfs     5.0M  4.0K  5.0M   1% /run/lock
      /dev/sda1                           vfat      253M   31M  222M  13% /boot
      tmpfs                               tmpfs     782M   20K  782M   1% /run/user/1000
      //192.168.178.10/Sicherung/iobroker cifs      1.9T  509G  1.4T  28% /opt/iobroker/backups
      [Sat Feb 17 15:13:07 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:59:9B:B3 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=96bb02d6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sat Feb 17 15:13:09 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Feb 17 15:13:09 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sat Feb 17 15:13:11 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET                  SOURCE                              FSTYPE OPTIONS
      /                       /dev/sda2                           ext4   rw,noatime,stripe=8191
      |-/boot                 /dev/sda1                           vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      `-/opt/iobroker/backups //192.168.178.10/Sicherung/iobroker cifs   rw,relatime,vers=2.1,cache=strict,username=admin,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.10,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
      /var:
      2.8G    /var/
      1.5G    /var/lib
      987M    /var/cache
      975M    /var/cache/apt
      873M    /var/cache/apt/archives
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      402M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.0G    /opt/iobroker/iobroker-data/
      1.5G    /opt/iobroker/iobroker-data/history
      406M    /opt/iobroker/iobroker-data/files
      100M    /opt/iobroker/iobroker-data/backup-objects
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      21M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.605c1bc5.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b4cc327b0745ec11aff094fd6f14af06-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.1
      /usr/bin/node           v18.19.1
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.1-1nodesource1
        Candidate: 18.19.1-1nodesource1
        Version table:
       *** 18.19.1-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   2
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
      + system.adapter.eventlist.0              : eventlist             : raspberrypi                              -  enabled
      + system.adapter.eventlist.1              : eventlist             : raspberrypi                              -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
      + system.adapter.fronius.0                : fronius               : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
      + system.adapter.pushsafer.0              : pushsafer             : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
      + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 9090, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
      + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b4cc327b0745ec11aff094fd6f14af06-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.9.6   , installed 2.9.6
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "email"        : 1.2.2    , installed 1.2.2
      Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
      Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
      Adapter    "fb-checkpresence": 1.2.3 , installed 1.2.2  [Updatable]
      Adapter    "fronius"      : 2.0.2    , installed 2.0.2
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
      Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "snmp"         : 3.1.0    , installed 3.1.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Objects and States
      Objects:        10824
      States:         9011
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://giteduberger.fr rpimonitor/ InRelease
      Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:6 https://repos.influxdata.com/debian stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:8 https://repos.influxdata.com/debian bullseye InRelease
      Hit:9 https://packages.grafana.com/oss/deb stable InRelease
      Hit:10 https://dl.ui.com/unifi/debian unifi-7.4 InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15011      565/cupsd
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15723      700/vncserver-x11-c
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        15498      611/mosquitto
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       101899     19950/io.sonoff.0
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       101382     19641/iobroker.js-c
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       101389     19641/iobroker.js-c
      tcp        0      0 127.0.0.1:27117         0.0.0.0:*               LISTEN      118        22670      2799/bin/mongod
      tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      117        15111      584/mongod
      tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          16779      1252/perl
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13052      705/sshd: /usr/sbin
      tcp6       0      0 :::8086                 :::*                    LISTEN      119        15991      591/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       99627      19665/io.admin.0
      tcp6       0      0 :::8080                 :::*                    LISTEN      118        19310      676/java
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       104961     21178/io.web.0
      tcp6       0      0 :::3000                 :::*                    LISTEN      120        16282      1410/grafana
      tcp6       0      0 :::6789                 :::*                    LISTEN      118        22157      676/java
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15010      565/cupsd
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          15722      700/vncserver-x11-c
      tcp6       0      0 :::1883                 :::*                    LISTEN      116        15499      611/mosquitto
      tcp6       0      0 :::9090                 :::*                    LISTEN      1001       100345     20566/io.socketio.0
      tcp6       0      0 :::8843                 :::*                    LISTEN      118        21228      676/java
      tcp6       0      0 :::8880                 :::*                    LISTEN      118        19311      676/java
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13054      705/sshd: /usr/sbin
      tcp6       0      0 :::8443                 :::*                    LISTEN      118        20002      676/java
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       99103      19977/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       99104      19977/io.tuya.0
      udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          14808      -
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16403      521/dhcpcd
      udp        0      0 0.0.0.0:53424           0.0.0.0:*                           1001       104855     21114/io.upnp.0
      udp        0      0 0.0.0.0:37188           0.0.0.0:*                           1001       104854     21114/io.upnp.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15080      1004/cups-browsed
      udp        0      0 0.0.0.0:41761           0.0.0.0:*                           108        11245      409/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11243      409/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       99938      19930/io.shelly.0
      udp        0      0 0.0.0.0:55061           0.0.0.0:*                           1001       104611     20543/io.snmp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       105001     21114/io.upnp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       105000     21114/io.upnp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       104999     21114/io.upnp.0
      udp        0      0 0.0.0.0:38900           0.0.0.0:*                           1001       104612     20543/io.snmp.0
      udp        0      0 0.0.0.0:55616           0.0.0.0:*                           1001       104856     21114/io.upnp.0
      udp6       0      0 :::51820                :::*                                0          14809      -
      udp6       0      0 :::51853                :::*                                108        11246      409/avahi-daemon: r
      udp6       0      0 10.110.114.1:56456      :::*                                118        22225      676/java
      udp6       0      0 192.168.178.11:56694    :::*                                118        22233      676/java
      udp6       0      0 192.168.178.211:60810   :::*                                118        22232      676/java
      udp6       0      0 :::3478                 :::*                                118        23068      676/java
      udp6       0      0 :::546                  :::*                                0          13152      521/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        11244      409/avahi-daemon: r
      udp6       0      0 :::5514                 :::*                                118        22221      676/java
      udp6       0      0 :::10001                :::*                                118        22234      676/java
      2024-02-17 17:02:00.276  - info: javascript.0 (19740) script.js.Mein_Ordner.Fronius0: Solarweb Token erstellt
      2024-02-17 17:09:53.317  - info: admin.0 (19665) ==> Connected system.user.admin from ::ffff:192.168.178.33
      2024-02-17 17:09:53.422  - info: admin.0 (19665) ==> Connected system.user.admin from ::ffff:192.168.178.33
        Thomas Braun Most Active last edited by
        @snopy_16
        könnte da etwas im Argen liegen?
        Ja, da ist irgendwas bei der Rechteverwaltung krumm. Der User 'iobroker' kann nicht mehr via sudo Dinge ausführen. Keine Ahnung wo es genau klemmt.
        Oder hat etwa das update node.js von v18.19.0 auf v18.19.1 damit etwas zu tun?
        Nein.
          Snopy_16 @Thomas Braun last edited by
          @thomas-braun sagte in Backitup Probleme mit mount NAS:
          😧 Das ist schlimm, da ich jetzt absolut nicht mehr weiter weiss.
          Kann man dem iobroker nicht mehr die Rechte geben?
          Gibt es eine Möglichkeit, das wieder zurecht zurücken? (OHNE Neuinstallation)
            Thomas Braun Most Active @Snopy_16 last edited by
            @snopy_16
            ls -lah /home/pi/temp_sudo_file
            getfacl /home/pi/temp_sudo_file
            sagt?
              pi@raspberrypi:~ $ ls -lah /home/pi/temp_sudo_file
              ls: Zugriff auf '/home/pi/temp_sudo_file' nicht möglich: Datei oder Verzeichnis nicht gefunden
              pi@raspberrypi:~ $ getfacl /home/pi/temp_sudo_file
              getfacl: /home/pi/temp_sudo_file: Datei oder Verzeichnis nicht gefunden
              Die Datei gibts nicht
                Snopy_16 @Snopy_16 last edited by
                @Thomas-Braun @Homoran
                Noch wer eine Idee?
                  @snopy_16
                  Installier da neu ein RaspberryOS 12.
                  Dist-upgrade von 11 auf 12 funktioniert eh nicht.
                    Das will ich vermeiden. (Hab ja einiges drauf auf dem derzeitigen Raspberry 4)
                    Zumindest bis ich vielleicht mal umsteige auf einen Raspi 5.
                    Bookworm erscheint mir noch etwas suspect (Einrichten einer statischen IP,...)
                    Weiss auch nicht, ob dann alles in Ordnung ist, wenn ich ein Backup von iobroker einspiele.
                      Thomas Braun Most Active @Snopy_16 last edited by Thomas Braun
                      @snopy_16 sagte in Backitup Probleme mit mount NAS:
                      Kannst du eh nicht vermeiden.
                      Was soll da sein? Wird halt jetzt ggfls. anders gemacht, das ist aber auch schon alles.
                        Nun, ich bin der Sache etwas näher gekommen.
                        Ich habe eine 1:1 Kopie der SSD-Platte vom 12.2.24.
                        Mit der habe ich das system gestartet und gleich mal ein Backup mit dem Backitup Adapter gemacht. Funktionierte wie gewohnt.
                        Anschließend machte ich ein
                        iob fix
                        was war die Folge?
                            Checking ioBroker user and directory permissions (2/5)
                        main: Zeile 702: /home/pi/temp_sudo_file: Keine Berechtigung
                        Fixing directory permissions...
                        This system does not support setting default permissions.
                        Do not use npm to manually install adapters unless you know what you are doing!
                        Dann machte ich nochmal ein Backup machen und sofort kam die ursprüngliche Meldung wie auf Post #1 beschrieben und das NAS wurde nicht gemountet.
                        Also liegt das ganze an IOB FIX.
                        Mit dem sollte eigentlich was repariert werden und nicht ein Problem erzeugt.
                        Was steht da im Code auf Seite 702?
                        Ein IOB FIX kann ich wohl nicht mehr rückgängig machen.
                        Ich weiss leider nicht, wer in dieser Sache den nötigen Einblick hat, aber es muss doch einen Grund dafür geben.
                          Homoran Global Moderator Administrators @Snopy_16 last edited by Homoran
                          wieso???
                          wenn du
                          dabei einen vorhandenen Fehler klonst, an dem iob fix sich die Zähne ausbeisst, weil du z.b. vorher mit der Verwendung von root Rechte so verbogen hattest, dass selbst der Fixer das nicht mehr richten kann, dann ist der Fixer nicht der Täter sonden das Opfer!
                          Deswegen klont man keine ganzen Platten sondern installiert neu.
                            Nix. Das fix-Skript hat nur 480 Zeilen.
                            https://github.com/ioBroker/ioBroker/blob/master/fix_installation.sh
                            Ich hab jetzt gerade mal spaßeshalber 2x hintereinander den iob fix auf meinem System durchgeführt. Kein Fehler bei mir.
                              Snopy_16 @Homoran last edited by
                              Also doch sehr komplex, ich versteh einfach nicht:
                              Wieso sucht der Fixer in Zeile 702 nach "/home/pi/temp_sudo_file", das nicht vorhanden ist und schreibt dann "keine Berechtigung".
                              Kann man diese file nicht nachinstallieren?
                              Thomas Braun Homoran 4 Replies Last reply Reply Quote 0
                                Nein, das ist nur ein temporäres File, das wird vom fixer wieder gelöscht.
                                  @snopy_16
                                  groups
                                  als der user, der auch den fixer aufruft sagt? Wohl der 'pi' bei dir.
                                    mal halblang. Diese Meldung ist nicht normal!
                                    und der Rest anscheinend fehlinterpretiert. ich bin kein Entwickler und Programmierer, aber wie kommst fu darauf, dass
                                    da steht
                                    Keine Berechtigung
                                    heisst: selbst der Fixer hat nicht das Recht, die verbogenen Rechte wieder herzustellen!
                                    irgendwas an dem Grundsystem wurde so verstellt, dass
                                      @snopy_16
                                      sudo cat /etc/sudoers.d/iobroker
                                        Ich meinte das nicht so, ist einfach für MICH zu komplex.
                                        Wusste auch nicht das die Datei nur temporär angelegt wird und wieder gelöscht wird, darum hab ich sie auch nicht gefunden.
                                        Ich will halt alles verstehen und mache mir dazu Gedanken, wenn auch oftmals falsche.
                                        bin aber sehr froh, dass ich bei Euch Hilfe finde.
                                          Snopy_16 @Thomas Braun last edited by Snopy_16
                                          pi@raspberrypi:~ $ sudo cat /etc/sudoers.d/iobroker
                                          cat: /etc/sudoers.d/iobroker: Datei oder Verzeichnis nicht gefunden
                                          Habe dann auf meinem Ersatzsystem ein
                                          sudo iob fix
                                          gemacht, dabei wurde dann die datei angelegt
                                          Created /etc/sudoers.d/iobroker
                                          Seitdem funktioniert auch wieder das Backup auf das NAS 👍
                                          auch nach einem reboot.
                                          Hier nun die Ausgabe vom angelegtem
                                          iobroker ALL=(ALL) ALL
                                          iobroker ALL=(ALL) NOPASSWD: /usr/sbin/shutdown
                                          iobroker ALL=(ALL) NOPASSWD: /usr/sbin/halt
                                          iobroker ALL=(ALL) NOPASSWD: /usr/sbin/poweroff
                                          iobroker ALL=(ALL) NOPASSWD: /usr/sbin/reboot
                                          iobroker ALL=(ALL) NOPASSWD: /usr/bin/systemctl start
                                          iobroker ALL=(ALL) NOPASSWD: /usr/bin/systemctl stop
                                          iobroker ALL=(ALL) NOPASSWD: /usr/bin/mount
                                          iobroker ALL=(ALL) NOPASSWD: /usr/bin/umount
                                          iobroker ALL=(ALL) NOPASSWD: /usr/bin/systemd-run
                                          iobroker ALL=(ALL) NOPASSWD: /usr/bin/apt-get
                                          iobroker ALL=(ALL) NOPASSWD: /usr/bin/dpkg
                                          iobroker ALL=(ALL) NOPASSWD: /usr/bin/make
                                          iobroker ALL=(ALL) NOPASSWD: /usr/bin/ping
                                          iobroker ALL=(ALL) NOPASSWD: /usr/sbin/setcap
                                          iobroker ALL=(ALL) NOPASSWD: /usr/bin/vcgencmd
                                          iobroker ALL=(ALL) NOPASSWD: /usr/bin/cat
                                          iobroker ALL=(ALL) NOPASSWD: /usr/bin/df
                                          iobroker ALL=(ALL) NOPASSWD: /usr/sbin/ldconfig
                                          ALL ALL=NOPASSWD: /usr/bin/systemctl start iobroker
                                          ALL ALL=NOPASSWD: /usr/bin/systemctl stop iobroker
                                          ALL ALL=NOPASSWD: /usr/bin/systemctl restart iobroker
                                          ALL ALL=(iobroker) NOPASSWD: /usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js *
                                          Ich weiss zwar nicht ob das jetzt in Ordnung ist, aber es funktioniert
                                          Mit einem erneutem IOB-FIX ohne sudo kamen wieder die selben Probleme.
                                            sudo iob fix
                                            gemacht,
                                            niemals nie nicht iobroker Befehle mit sudo einleiten!!!
                                            das führt zu genau so etwas
                                            1279
