    4. Node-Red
    5. Node Red Tasmota und Switsch
      JosefThal last edited by
      benötige noch mal euer hilfe
      es geht soweit ,die batterie über 91 % voll schaltet er eine wenn er unter 71 % ist schaltet er aus.
      wenn ich den taster Starten ( Manuel ) geht es aber wenn die Batterie runter geht ( z.b. 50 % auf 49 % ) schaltet der Timer aus obwohl die zeit nicht abgelaufen ist
      hab schon versucht eine undglied einzusetzt geht nicht
             "id": "e4aa7e9b9fb405d9",
             "type": "tab",
             "label": "Tasmota Test1",
             "disabled": false,
             "info": "",
             "env": []
             "id": "74f2d76bc3ce958f",
             "type": "junction",
             "z": "e4aa7e9b9fb405d9",
             "x": 1060,
             "y": 480,
             "wires": [
             "id": "e5c4d789e94d350e",
             "type": "debug",
             "name": "debug 81",
             "active": false,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "false",
             "statusVal": "",
             "statusType": "auto",
             "x": 1040,
             "y": 160,
             "wires": []
             "id": "7cf3622b17046eee",
             "type": "change",
             "name": "Spannung",
             "rules": [
                     "t": "move",
                     "p": "payload.ENERGY.Voltage",
                     "pt": "msg",
                     "to": "payload",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 580,
             "y": 160,
             "wires": [
                     "e5c4d789e94d350e",
                     "a10b8a367682404e"
             "id": "a10b8a367682404e",
             "type": "ui_gauge",
             "name": "",
             "group": "04d5298db5344c1e",
             "order": 1,
             "width": 0,
             "height": 0,
             "gtype": "gage",
             "title": "volt Test 1",
             "label": "units",
             "format": "{{value}}",
             "min": 0,
             "max": "240",
             "colors": [
                 "#ff0000",
                 "#ffff00",
                 "#008000"
             "seg1": "200",
             "seg2": "220",
             "x": 760,
             "y": 160,
             "wires": []
             "id": "77456c5a3405fff3",
             "type": "debug",
             "name": "debug 82",
             "active": false,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 440,
             "y": 100,
             "wires": []
             "id": "89e9cf65394790da",
             "type": "change",
             "name": "Strom Filter",
             "rules": [
                     "t": "move",
                     "p": "payload.ENERGY.Current[1]",
                     "pt": "msg",
                     "to": "payload",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 570,
             "y": 200,
             "wires": [
                     "e60c46e0c106e4dc"
             "id": "318a5c613a88c769",
             "type": "debug",
             "name": "debug 83",
             "active": false,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1040,
             "y": 200,
             "wires": []
             "id": "401d1fdd51ecce14",
             "type": "victron-input-battery",
             "service": "com.victronenergy.battery.socketcan_can1",
             "path": "/Soc",
             "serviceObj": {
                 "name": "Pylontech battery"
             "pathObj": {
                 "path": "/Soc",
                 "type": "float",
                 "name": "State of charge (%)"
             "initial": "",
             "name": "",
             "onlyChanges": false,
             "x": 190,
             "y": 340,
             "wires": [
                     "6ddde74da4bb9545"
             "id": "5369f8cb591ac34d",
             "type": "switch",
             "name": "",
             "property": "payload",
             "propertyType": "msg",
             "rules": [
                     "t": "gt",
                     "v": "91",
                     "vt": "num"
                     "t": "lt",
                     "v": "70",
                     "vt": "num"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 210,
             "y": 500,
             "wires": [
                     "e5fea5b934a2efc7",
                     "b9ed6599cf70de74"
                     "5012c46291e78a77",
                     "cbe9c595bb01b81e"
             "id": "f237aa09ab50cbd7",
             "type": "debug",
             "name": "debug 84",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "payload",
             "targetType": "msg",
             "statusVal": "",
             "x": 720,
             "y": 1020,
             "wires": []
             "id": "5d01b124055bea37",
             "type": "debug",
             "name": "State Of Charge",
             "active": false,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1100,
             "y": 360,
             "wires": []
             "id": "6ddde74da4bb9545",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "StateOfCharge",
                     "pt": "global",
                     "to": "payload",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 560,
             "y": 340,
             "wires": [
                     "5d01b124055bea37",
                     "52e26a73c3b27f6e",
                     "50eb11e95ce1c4f3"
             "id": "bd97fddd9dcd4646",
             "type": "ui_slider",
             "name": "",
             "label": "0 bis 100  test 1eingang",
             "tooltip": "",
             "order": 3,
             "width": 0,
             "height": 0,
             "passthru": true,
             "outs": "all",
             "topic": "topic",
             "topicType": "msg",
             "min": 0,
             "max": "100",
             "step": 1,
             "x": 120,
             "y": 760,
             "wires": [
                     "1b2e513f58f2960b",
                     "5369f8cb591ac34d"
             "id": "1b2e513f58f2960b",
             "type": "ui_gauge",
             "name": "",
             "order": 4,
             "width": 0,
             "height": 0,
             "gtype": "gage",
             "title": "0 bis 100   test 1 Ausgang",
             "label": "Batterie",
             "min": 0,
             "max": "100",
             "colors": [
                 "#ff0000",
                 "#e6e600",
                 "#00ff00"
             "seg1": "",
             "seg2": "",
             "x": 490,
             "y": 760,
             "wires": []
             "id": "0d5525e74b9b0109",
             "type": "debug",
             "name": "debug 86",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 680,
             "y": 580,
             "wires": []
             "id": "73f440c9fc6e840c",
             "type": "debug",
             "name": "debug 87",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1060,
             "y": 280,
             "wires": []
             "id": "6ebf1c2b99b260a0",
             "type": "debug",
             "name": "debug 88",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 920,
             "y": 880,
             "wires": []
             "id": "99db0d2dae9eefe5",
             "type": "change",
             "name": "Strom power",
             "rules": [
                     "t": "move",
                     "p": "payload.Switch1",
                     "pt": "msg",
                     "to": "payload",
                     "tot": "msg"
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "on",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 570,
             "y": 280,
             "wires": [
                     "ec8f88403a3d804a"
             "id": "d6f7d9277bab1b46",
             "type": "ui_chart",
             "name": "",
             "group": "a9d0f0d6dc0f0a7e",
             "order": 1,
             "width": 0,
             "height": 0,
             "label": "1Strom Test1",
             "chartType": "bar",
             "legend": "true",
             "xformat": "HH:mm:ss",
             "interpolate": "linear",
             "nodata": "",
             "dot": false,
             "ymin": "",
             "ymax": "",
             "removeOlder": 1,
             "removeOlderPoints": "",
             "removeOlderUnit": "3600",
             "cutout": 0,
             "useOneColor": false,
             "useUTC": false,
             "colors": [
                 "#1f77b4",
                 "#aec7e8",
                 "#ff7f0e",
                 "#2ca02c",
                 "#98df8a",
                 "#d62728",
                 "#ff9896",
                 "#9467bd",
                 "#c5b0d5"
             "outputs": 1,
             "useDifferentColor": false,
             "x": 770,
             "y": 240,
             "wires": [
                     "eba281a8c7d862c3"
             "id": "eba281a8c7d862c3",
             "type": "debug",
             "name": "debug 89",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1060,
             "y": 240,
             "wires": []
             "id": "f5252ff2d2f5e5c1",
             "type": "change",
             "rules": [
                     "t": "move",
                     "p": "payload.ENERGY.Current[0]",
                     "pt": "msg",
                     "to": "payload",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 570,
             "y": 240,
             "wires": [
                     "d6f7d9277bab1b46"
             "id": "e60c46e0c106e4dc",
             "type": "ui_chart",
             "name": "",
             "order": 5,
             "width": 0,
             "height": 0,
             "label": "Strom Test1",
             "chartType": "bar",
             "legend": "false",
             "nodata": "",
             "dot": false,
             "ymin": "",
             "ymax": "",
             "removeOlder": 1,
             "cutout": 0,
             "useUTC": false,
             "colors": [
                 "#1f77b4",
                 "#aec7e8",
                 "#ff7f0e",
                 "#2ca02c",
                 "#98df8a",
                 "#d62728",
                 "#ff9896",
                 "#9467bd",
                 "#c5b0d5"
             "outputs": 1,
             "x": 770,
             "y": 200,
             "wires": [
                     "318a5c613a88c769"
             "id": "e5fea5b934a2efc7",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "ON",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 630,
             "y": 480,
             "wires": [
                     "a3ff7d845272b908",
                     "d00e1f649acb16f3"
             "id": "7dd91967b9ae0e11",
             "type": "Tasmota Sensor",
             "broker": "7a7b311bf649aa87",
             "device": "Tasmota_test1",
             "name": "",
             "outputs": 1,
             "uidisabler": false,
             "fullTopic": "",
             "cmndPrefix": "",
             "statPrefix": "",
             "telePrefix": "",
             "qos": 1,
             "retain": false,
             "rules": [],
             "outputTopic": "",
             "x": 240,
             "y": 140,
             "wires": [
                     "99db0d2dae9eefe5",
                     "f5252ff2d2f5e5c1",
                     "89e9cf65394790da",
                     "7cf3622b17046eee",
                     "77456c5a3405fff3"
             "id": "ec8f88403a3d804a",
             "type": "ui_chart",
             "name": "",
             "order": 6,
             "width": 0,
             "height": 0,
             "label": "Pauer Test1",
             "chartType": "bar",
             "legend": "true",
             "nodata": "",
             "dot": false,
             "ymin": "",
             "ymax": "",
             "removeOlder": 1,
             "cutout": 0,
             "useUTC": false,
             "colors": [
                 "#1f77b4",
                 "#aec7e8",
                 "#ff7f0e",
                 "#2ca02c",
                 "#98df8a",
                 "#d62728",
                 "#ff9896",
                 "#9467bd",
                 "#c5b0d5"
             "outputs": 1,
             "x": 770,
             "y": 280,
             "wires": [
                     "73f440c9fc6e840c"
             "id": "d00e1f649acb16f3",
             "type": "mqtt out",
             "name": "",
             "topic": "cmnd/Tasmota_test1/POWER1",
             "qos": "",
             "retain": "",
             "respTopic": "",
             "contentType": "",
             "userProps": "",
             "correl": "",
             "expiry": "",
             "broker": "b84a725bf6dd8e6b",
             "x": 1530,
             "y": 500,
             "wires": []
             "id": "d9062f21b1c4fdaf",
             "type": "switch",
             "name": "",
             "property": "payload.Switch1",
             "rules": [
                     "t": "eq",
                     "v": "ON",
                     "vt": "str"
             "checkall": "true",
             "repair": false,
             "outputs": 1,
             "x": 470,
             "y": 1020,
             "wires": [
                     "b22e13f626cd98a3",
                     "f237aa09ab50cbd7"
             "id": "56a67d7f80182ecc",
             "type": "mqtt in",
             "name": "",
             "topic": "tele/Tasmota_test1/SENSOR",
             "qos": "0",
             "datatype": "json",
             "nl": false,
             "rap": true,
             "rh": 0,
             "inputs": 0,
             "x": 190,
             "y": 980,
             "wires": [
                     "d9062f21b1c4fdaf",
                     "a79580173aa2a19f"
             "id": "b22e13f626cd98a3",
             "type": "trigger",
             "name": "",
             "op1": "ON",
             "op2": "OFF",
             "op1type": "str",
             "op2type": "str",
             "duration": "12",
             "extend": false,
             "overrideDelay": true,
             "units": "s",
             "reset": "",
             "bytopic": "all",
             "topic": "topic",
             "outputs": 1,
             "x": 630,
             "y": 880,
             "wires": [
                     "6ebf1c2b99b260a0",
                     "d00e1f649acb16f3"
             "id": "a3ff7d845272b908",
             "type": "debug",
             "name": "debug 98",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 620,
             "y": 420,
             "wires": []
             "id": "a79580173aa2a19f",
             "type": "debug",
             "name": "debug 100",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 430,
             "y": 900,
             "wires": []
             "id": "52e26a73c3b27f6e",
             "type": "ui_text",
             "group": "71e172fc8641b4f7",
             "order": 6,
             "width": 6,
             "height": 1,
             "name": "",
             "label": "Batterie test 1",
             "format": "{{msg.payload}}",
             "layout": "row-spread",
             "x": 830,
             "y": 380,
             "wires": []
             "id": "50eb11e95ce1c4f3",
             "type": "ui_gauge",
             "name": "",
             "order": 2,
             "width": 0,
             "height": 0,
             "gtype": "gage",
             "title": "Batterie Test 1",
             "label": "units",
             "min": 0,
             "max": "100",
             "colors": [
                 "#ff0000",
                 "#ffff00",
                 "#008000"
             "seg1": "30",
             "seg2": "75",
             "x": 840,
             "y": 420,
             "wires": []
             "id": "5012c46291e78a77",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "OFF",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 630,
             "y": 520,
             "wires": [
                     "0d5525e74b9b0109",
                     "d00e1f649acb16f3"
             "id": "b9ed6599cf70de74",
             "type": "debug",
             "name": "debug 101",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 390,
             "y": 440,
             "wires": []
             "id": "cbe9c595bb01b81e",
             "type": "debug",
             "name": "debug 102",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 370,
             "y": 600,
             "wires": []
             "id": "934a40174dc661ef",
             "type": "function",
             "name": "function 1",
             "func": "\nreturn msg;",
             "outputs": 1,
             "noerr": 0,
             "initialize": "",
             "finalize": "",
             "libs": [],
             "x": 1340,
             "y": 240,
             "wires": [
             "id": "04d5298db5344c1e",
             "type": "ui_group",
             "name": "Group 4",
             "tab": "12a65f5c2118623e",
             "order": 3,
             "disp": true,
             "width": 6
             "id": "a9d0f0d6dc0f0a7e",
             "type": "ui_group",
             "name": "Default",
             "order": 4,
             "disp": true,
             "width": 6,
             "collapse": false
             "id": "7a7b311bf649aa87",
             "type": "tasmota-mqtt-broker",
             "name": "",
             "broker": "localhost",
             "port": "1883",
             "clientid": "",
             "usetls": false,
             "keepalive": "60",
             "cleansession": true
             "id": "b84a725bf6dd8e6b",
             "type": "mqtt-broker",
             "name": "CerboGX",
             "broker": "192.168.178.35",
             "port": "1883",
             "clientid": "",
             "autoConnect": true,
             "usetls": false,
             "protocolVersion": "4",
             "keepalive": "60",
             "cleansession": true,
             "birthTopic": "",
             "birthQos": "0",
             "birthPayload": "",
             "birthMsg": {},
             "closeTopic": "",
             "closeQos": "0",
             "closePayload": "",
             "closeMsg": {},
             "willTopic": "",
             "willQos": "0",
             "willPayload": "",
             "willMsg": {},
             "userProps": "",
             "sessionExpiry": ""
             "id": "71e172fc8641b4f7",
             "type": "ui_group",
             "name": "Stapler ",
             "order": 1,
             "disp": true,
             "width": "6",
             "collapse": false
             "id": "12a65f5c2118623e",
             "type": "ui_tab",
             "name": "Home",
             "icon": "dashboard",
             "order": 2,
             "disabled": false,
             "hidden": false
      • mickym
        mickym Most Active @JosefThal last edited by
        @josefthal Verstehe zwar nicht wie das gehen Soll, ausser der Tasmota Sensor gibt längere Zeit kein ON Signal.
        Du hast doch nur EINE externe Quelle in Deinem Flow - der selbstständig schalten kann? (ROT markiert).
        Bist Du Dir denn sicher, dass das Ganze was mit dem NodeRedFlow zu tun hat?
          JosefThal @mickym last edited by
          @mickym wichtig s.url
            • mickym
              @josefthal Wie ich sagte - der Flow kann nur von dem unterne Kasten automatisch schalten, das siehst Du doch an der debug Node 55
              • mickym
                Grundsätzlich ist es jedoch so, um Dir allgemein zu helfen. Du brauchste keine UND Node oder so einen Schmarn. Wenn Du willst das ein Flow an einer Stelle unterbrochen wird, machst Du eine SwitchNode rein und prüfst dort auf den Zustand einer Flowvariablen.
                Diese Flowvariable kannst Du an anderer Stelle setzen - egal durch was.
                  @mickym [
                  "id": "c38eca0b6d0feb3e",
                  "type": "tab",
                  "label": "Flow 2",
                  "disabled": false,
                  "info": "",
                  "env": []
                  "id": "1e1408fe355f5f7c",
                  "type": "mqtt in",
                  "z": "c38eca0b6d0feb3e",
                  "name": "",
                  "qos": "0",
                  "datatype": "json",
                  "nl": false,
                  "rap": true,
                  "rh": 0,
                  "inputs": 0,
                  "x": 240,
                  "y": 260,
                  "wires": [
                  "99a27f412cc4724b"
                  "id": "99a27f412cc4724b",
                  "type": "change",
                  "rules": [
                  "t": "move",
                  "pt": "msg",
                  "to": "payload",
                  "tot": "msg"
                  "t": "set",
                  "p": "payload",
                  "pt": "msg",
                  "to": "on",
                  "tot": "str"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 530,
                  "y": 260,
                  "wires": [
                  "e4734f30a2286602"
                  "id": "e4734f30a2286602",
                  "type": "debug",
                  "name": "debug 113",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 760,
                  "y": 260,
                  "wires": []
                  "name": "CerboGX",
                  "port": "1883",
                  "clientid": "",
                  "usetls": false,
                  "keepalive": "60",
                  "birthTopic": "",
                  "birthQos": "0",
                  "birthPayload": "",
                  "birthMsg": {},
                  "closeTopic": "",
                  "closeQos": "0",
                  "closePayload": "",
                  "closeMsg": {},
                  "willTopic": "",
                  "willQos": "0",
                  "willPayload": "",
                  "willMsg": {},
                  "userProps": "",
                  "sessionExpiry": ""
                    JosefThal @JosefThal last edited by
                      da habe ich noch einen Fehler aber komme nicht drauf wie ich es hin bekommen
                      das signal mus erst einmal für 2 sekunden anlegen das es durchgeschaltet wird wenn es unter 2 Sekunden anlegt soll nicht pasieren
                      • mickym
                        1. Einen Flow hier einzustellen ohne ihn in Code-Tags zu packen, ist total sinnlos.
                        2. Der Tele Ast übermittelt keine Zustandsänderungen, wenn sie auftreten sondern in zeitlich definierten Abständen und ist deshalb ungeeignet
                        3. wenn ein Zustand für eine bestimmte Zeit anhalten soll, dann musst du ja auch analysieren wenn der Zustand nicht mehr vorliegt. Also benötigt man einen Switch.
                        4. Realisieren tut man es mit einer Trigger Node, die zurückgesetzt wird, wenn der zu überprüfende Zustand nicht mehr vorliegt.
                          @mickym ```
                          "type": "tab",
                          "disabled": false,
                          "info": "",
                          "env": []
                          "type": "debug",
                          "name": "debug 81",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 1040,
                          "y": 160,
                          "wires": []
                          "type": "change",
                          "name": "Spannung",
                          "rules": [
                          "t": "move",
                          "pt": "msg",
                          "to": "payload",
                          "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 580,
                          "y": 160,
                          "wires": [
                          "e5c4d789e94d350e",
                          "a10b8a367682404e"
                          "type": "ui_gauge",
                          "name": "",
                          "order": 2,
                          "width": 0,
                          "height": 0,
                          "gtype": "gage",
                          "label": "units",
                          "min": 0,
                          "max": "240",
                          "colors": [
                          "#ff0000",
                          "#ffff00",
                          "#008000"
                          "seg1": "200",
                          "seg2": "220",
                          "x": 760,
                          "y": 160,
                          "wires": []
                          "type": "debug",
                          "name": "debug 82",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 440,
                          "y": 100,
                          "wires": []
                          "type": "change",
                          "rules": [
                          "t": "move",
                          "pt": "msg",
                          "to": "payload",
                          "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 570,
                          "y": 200,
                          "wires": [
                          "e60c46e0c106e4dc"
                          "type": "debug",
                          "name": "debug 83",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 1040,
                          "y": 200,
                          "wires": []
                          "path": "/Soc",
                          "serviceObj": {
                          "pathObj": {
                          "path": "/Soc",
                          "type": "float",
                          "initial": "",
                          "name": "",
                          "x": 180,
                          "y": 520,
                          "wires": [
                          "6ddde74da4bb9545"
                          "type": "switch",
                          "name": "",
                          "rules": [
                          "t": "gt",
                          "v": "101",
                          "vt": "num"
                          "t": "lt",
                          "v": "70",
                          "vt": "num"
                          "checkall": "false",
                          "repair": false,
                          "outputs": 2,
                          "x": 390,
                          "y": 1000,
                          "wires": [
                          "e5fea5b934a2efc7",
                          "b9ed6599cf70de74"
                          "5012c46291e78a77",
                          "cbe9c595bb01b81e"
                          "type": "debug",
                          "name": "debug 84",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 660,
                          "y": 380,
                          "wires": []
                          "type": "debug",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 800,
                          "y": 580,
                          "wires": []
                          "type": "change",
                          "name": "",
                          "rules": [
                          "t": "set",
                          "pt": "global",
                          "to": "payload",
                          "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 520,
                          "y": 520,
                          "wires": [
                          "5d01b124055bea37",
                          "52e26a73c3b27f6e",
                          "50eb11e95ce1c4f3"
                          "name": "",
                          "tooltip": "",
                          "order": 4,
                          "width": 0,
                          "height": 0,
                          "passthru": true,
                          "outs": "all",
                          "topic": "topic",
                          "topicType": "msg",
                          "min": 0,
                          "max": "100",
                          "step": 1,
                          "x": 160,
                          "y": 600,
                          "wires": [
                          "1b2e513f58f2960b",
                          "236cb5a6278abac6",
                          "5ba74f68268192ec",
                          "e5c7f72323657170",
                          "dbc6348bafca49a8"
                          "type": "ui_gauge",
                          "name": "",
                          "order": 5,
                          "width": 0,
                          "height": 0,
                          "gtype": "gage",
                          "min": 0,
                          "max": "100",
                          "colors": [
                          "#ff0000",
                          "#e6e600",
                          "#00ff00"
                          "seg1": "",
                          "seg2": "",
                          "x": 590,
                          "y": 600,
                          "wires": []
                          "type": "debug",
                          "name": "debug 86",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 880,
                          "y": 1120,
                          "wires": []
                          "type": "debug",
                          "name": "debug 87",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 1060,
                          "y": 280,
                          "wires": []
                          "type": "debug",
                          "name": "debug 88",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": true,
                          "statusVal": "payload",
                          "x": 940,
                          "y": 760,
                          "wires": []
                          "type": "change",
                          "rules": [
                          "t": "move",
                          "pt": "msg",
                          "to": "payload",
                          "tot": "msg"
                          "t": "set",
                          "p": "payload",
                          "pt": "msg",
                          "to": "on",
                          "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 570,
                          "y": 280,
                          "wires": [
                          "ec8f88403a3d804a"
                          "type": "ui_chart",
                          "name": "",
                          "order": 11,
                          "width": 0,
                          "height": 0,
                          "chartType": "bar",
                          "legend": "true",
                          "nodata": "",
                          "dot": false,
                          "ymin": "",
                          "ymax": "",
                          "removeOlder": 1,
                          "cutout": 0,
                          "useUTC": false,
                          "colors": [
                          "#1f77b4",
                          "#aec7e8",
                          "#ff7f0e",
                          "#2ca02c",
                          "#98df8a",
                          "#d62728",
                          "#ff9896",
                          "#9467bd",
                          "#c5b0d5"
                          "outputs": 1,
                          "x": 770,
                          "y": 240,
                          "wires": [
                          "eba281a8c7d862c3"
                          "type": "debug",
                          "name": "debug 89",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 1060,
                          "y": 240,
                          "wires": []
                          "type": "change",
                          "rules": [
                          "t": "move",
                          "pt": "msg",
                          "to": "payload",
                          "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 570,
                          "y": 240,
                          "wires": [
                          "d6f7d9277bab1b46"
                          "type": "ui_chart",
                          "name": "",
                          "order": 6,
                          "width": 0,
                          "height": 0,
                          "chartType": "bar",
                          "legend": "false",
                          "nodata": "",
                          "dot": false,
                          "ymin": "",
                          "ymax": "",
                          "removeOlder": 1,
                          "cutout": 0,
                          "useUTC": false,
                          "colors": [
                          "#1f77b4",
                          "#aec7e8",
                          "#ff7f0e",
                          "#2ca02c",
                          "#98df8a",
                          "#d62728",
                          "#ff9896",
                          "#9467bd",
                          "#c5b0d5"
                          "outputs": 1,
                          "x": 770,
                          "y": 200,
                          "wires": [
                          "318a5c613a88c769"
                          "type": "change",
                          "name": "",
                          "rules": [
                          "t": "set",
                          "p": "payload",
                          "pt": "msg",
                          "to": "ON",
                          "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 630,
                          "y": 1020,
                          "wires": [
                          "a3ff7d845272b908",
                          "d00e1f649acb16f3"
                          "name": "",
                          "outputs": 1,
                          "fullTopic": "",
                          "cmndPrefix": "",
                          "statPrefix": "",
                          "telePrefix": "",
                          "qos": 1,
                          "retain": false,
                          "rules": [],
                          "outputTopic": "",
                          "x": 240,
                          "y": 140,
                          "wires": [
                          "99db0d2dae9eefe5",
                          "f5252ff2d2f5e5c1",
                          "89e9cf65394790da",
                          "7cf3622b17046eee",
                          "77456c5a3405fff3"
                          "type": "ui_chart",
                          "name": "",
                          "order": 7,
                          "width": 0,
                          "height": 0,
                          "chartType": "bar",
                          "legend": "true",
                          "nodata": "",
                          "dot": false,
                          "ymin": "",
                          "ymax": "",
                          "removeOlder": 1,
                          "cutout": 0,
                          "useUTC": false,
                          "colors": [
                          "#1f77b4",
                          "#aec7e8",
                          "#ff7f0e",
                          "#2ca02c",
                          "#98df8a",
                          "#d62728",
                          "#ff9896",
                          "#9467bd",
                          "#c5b0d5"
                          "outputs": 1,
                          "x": 770,
                          "y": 280,
                          "wires": [
                          "73f440c9fc6e840c"
                          "type": "mqtt out",
                          "name": "",
                          "qos": "",
                          "retain": "",
                          "respTopic": "",
                          "contentType": "",
                          "userProps": "",
                          "correl": "",
                          "expiry": "",
                          "x": 1010,
                          "y": 1020,
                          "wires": []
                          "type": "mqtt in",
                          "name": "",
                          "qos": "0",
                          "datatype": "json",
                          "nl": false,
                          "rap": true,
                          "rh": 0,
                          "inputs": 0,
                          "x": 140,
                          "y": 320,
                          "wires": [
                          "a79580173aa2a19f",
                          "0ae9a66a06af1dd3"
                          "type": "debug",
                          "name": "debug 98",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 980,
                          "y": 980,
                          "wires": []
                          "type": "debug",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 660,
                          "y": 320,
                          "wires": []
                          "type": "ui_text",
                          "order": 6,
                          "width": 6,
                          "height": 1,
                          "name": "",
                          "x": 1090,
                          "y": 560,
                          "wires": []
                          "type": "ui_gauge",
                          "name": "",
                          "order": 3,
                          "width": 0,
                          "height": 0,
                          "gtype": "gage",
                          "label": "units",
                          "min": 0,
                          "max": "100",
                          "colors": [
                          "#ff0000",
                          "#ffff00",
                          "#008000"
                          "seg1": "30",
                          "seg2": "75",
                          "x": 1100,
                          "y": 520,
                          "wires": []
                          "type": "change",
                          "name": "",
                          "rules": [
                          "t": "set",
                          "p": "payload",
                          "pt": "msg",
                          "to": "OFF",
                          "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 630,
                          "y": 1060,
                          "wires": [
                          "0d5525e74b9b0109",
                          "d00e1f649acb16f3"
                          "type": "debug",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": true,
                          "x": 720,
                          "y": 940,
                          "wires": []
                          "type": "debug",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 640,
                          "y": 1120,
                          "wires": []
                          "type": "function",
                          "outputs": 1,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 1340,
                          "y": 240,
                          "wires": [
                          "id": "7b549e85395e6e3a",
                          "type": "function",
                          "name": "Zähler 1",
                          "func": "var f_zaehler1 = flow.get(f_zaehler1) || 0;\nf_zaehler1 = 100;\nflow.set('f_zaehler1', f_zaehler1);\nmsg.payload = f_zaehler1;\nreturn msg;",
                          "outputs": 1,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 860,
                          "y": 440,
                          "wires": [
                          "091cad702c61cd45"
                          "id": "091cad702c61cd45",
                          "type": "debug",
                          "name": "debug 104",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": true,
                          "x": 1020,
                          "y": 400,
                          "wires": []
                          "id": "89f93330dc0e65fa",
                          "type": "debug",
                          "name": "debug 105",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": true,
                          "x": 920,
                          "y": 700,
                          "wires": []
                          "id": "e14d12f8a327f7d2",
                          "type": "debug",
                          "name": "debug 106",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 120,
                          "y": 920,
                          "wires": []
                          "id": "7f4199879ec3aeda",
                          "type": "debug",
                          "name": "debug 107",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": true,
                          "x": 1020,
                          "y": 480,
                          "wires": []
                          "id": "5ba74f68268192ec",
                          "type": "switch",
                          "name": "",
                          "rules": [
                          "t": "gt",
                          "v": "1",
                          "vt": "num"
                          "t": "lt",
                          "v": "0",
                          "vt": "num"
                          "repair": false,
                          "outputs": 2,
                          "x": 150,
                          "y": 720,
                          "wires": [
                          "id": "dbc6348bafca49a8",
                          "type": "function",
                          "name": "Zähler 2",
                          "func": "var f_zaehler2 = flow.get(f_zaehler2) || 0;\nflow.set('f_zaehler2',msg.payload);\nreturn msg;",
                          "outputs": 1,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 660,
                          "y": 700,
                          "wires": [
                          "89f93330dc0e65fa"
                          "id": "0ae9a66a06af1dd3",
                          "type": "change",
                          "rules": [
                          "t": "move",
                          "pt": "msg",
                          "to": "payload",
                          "tot": "msg"
                          "t": "set",
                          "p": "payload",
                          "pt": "msg",
                          "to": "on",
                          "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 350,
                          "y": 380,
                          "wires": [
                          "f237aa09ab50cbd7",
                          "799b36b1217126ae"
                          "id": "799b36b1217126ae",
                          "type": "trigger",
                          "name": "",
                          "op1": "ON",
                          "op2": "ON",
                          "op1type": "str",
                          "op2type": "str",
                          "duration": "18",
                          "extend": false,
                          "overrideDelay": false,
                          "units": "s",
                          "reset": "",
                          "bytopic": "all",
                          "topic": "topic",
                          "outputs": 2,
                          "x": 670,
                          "y": 460,
                          "wires": [
                          "7b549e85395e6e3a"
                          "65753d1d393ce5f9"
                          "id": "65753d1d393ce5f9",
                          "type": "function",
                          "name": "Zähler 1",
                          "func": "var f_zaehler1 = flow.get(f_zaehler1) || 0;\nf_zaehler1 = 0;\nflow.set('f_zaehler1', f_zaehler1);\nmsg.payload = f_zaehler1;\nreturn msg;",
                          "outputs": 1,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 860,
                          "y": 480,
                          "wires": [
                          "7f4199879ec3aeda"
                          "id": "3ce3731fa2de008c",
                          "type": "function",
                          "name": "Zähler 4",
                          "func": "var f_zaehler1 = flow.get(f_zaehler1) || 0;\nvar f_zaehler2 = flow.get(f_zaehler2) || 0;\nvar f_zaehler4 = flow.get(f_zaehler4) || 0;\nf_zaehler4 = f_zaehler1 + f_zaehler2;\nflow.set('f_zaehler4', f_zaehler4);\nmsg.payload = f_zaehler4;\nreturn msg;",
                          "outputs": 1,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 720,
                          "y": 760,
                          "wires": [
                          "6ebf1c2b99b260a0"
                          "id": "236cb5a6278abac6",
                          "type": "switch",
                          "name": "",
                          "rules": [
                          "t": "gt",
                          "v": "1",
                          "vt": "num"
                          "repair": false,
                          "outputs": 1,
                          "x": 150,
                          "y": 800,
                          "wires": [
                          "e14d12f8a327f7d2",
                          "1d22878d092191cd"
                          "id": "f18bedcfdbd9660f",
                          "type": "debug",
                          "name": "debug 109",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": true,
                          "x": 960,
                          "y": 880,
                          "wires": []
                          "id": "e5c7f72323657170",
                          "type": "switch",
                          "name": "",
                          "rules": [
                          "t": "gt",
                          "v": "1",
                          "vt": "num"
                          "repair": false,
                          "outputs": 1,
                          "x": 150,
                          "y": 760,
                          "wires": [
                          "5317e2e4064ae269"
                          "id": "241a3883ea624c8d",
                          "type": "debug",
                          "name": "debug 110",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": true,
                          "x": 960,
                          "y": 820,
                          "wires": []
                          "id": "aaf5f791f630a6a3",
                          "type": "function",
                          "name": "Zähler 3",
                          "func": "var f_zaehler4 = flow.get(f_zaehler4) || 0;\nvar f_zaehler3 = flow.get(f_zaehler3) || 0;\nf_zaehler3 = f_zaehler4;\nflow.set('f_zaehler3', f_zaehler3);\nmsg.payload = f_zaehler3;\nreturn msg;",
                          "outputs": 1,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 720,
                          "y": 820,
                          "wires": [
                          "241a3883ea624c8d",
                          "5369f8cb591ac34d"
                          "id": "47b0ef4a8fb9242e",
                          "type": "debug",
                          "name": "debug 111",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": true,
                          "x": 180,
                          "y": 1060,
                          "wires": []
                          "id": "f30c68af18f7aef1",
                          "type": "ui_button",
                          "name": "",
                          "order": 1,
                          "width": 0,
                          "height": 0,
                          "passthru": false,
                          "label": "button",
                          "tooltip": "",
                          "color": "",
                          "bgcolor": "",
                          "icon": "",
                          "payload": "",
                          "payloadType": "str",
                          "topic": "topic",
                          "topicType": "msg",
                          "x": 150,
                          "y": 460,
                          "wires": [
                          "799b36b1217126ae"
                          "id": "474cddab788eb28b",
                          "type": "function",
                          "name": "Zähler 2",
                          "func": "var f_zaehler2 = flow.get(f_zaehler2) || 0;\n\nif (msg.topic === "modbus/1/holdingRegisters/30/2600_L1_Power") context.set("L1",msg.payload);\nif (msg.topic === "modbus/1/holdingRegisters/30/2601_L2_Power") context.set("L2",msg.payload);\nif (msg.topic === "modbus/1/holdingRegisters/30/2602_L3_Power") context.set("L3",msg.payload);\n\nvar L1 = context.get("L1") || 0;\nvar L2 = context.get("L2") || 0;\nvar L3 = context.get("L3") || 0;\n\nmsg.payload = L1 + L2 + L3;\n\n\n\n\n\nflow.set('f_zaehler2',msg.payload);\nreturn msg;",
                          "outputs": 1,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 220,
                          "y": 980,
                          "wires": [
                          "id": "1d22878d092191cd",
                          "type": "trigger",
                          "name": "",
                          "op1": "ON",
                          "op2": "Taster OFF",
                          "op1type": "str",
                          "op2type": "str",
                          "duration": "-2",
                          "extend": false,
                          "units": "s",
                          "reset": "",
                          "bytopic": "all",
                          "topic": "topic",
                          "outputs": 1,
                          "x": 500,
                          "y": 820,
                          "wires": [
                          "aaf5f791f630a6a3"
                          "id": "5317e2e4064ae269",
                          "type": "trigger",
                          "name": "",
                          "op1": "ON",
                          "op1type": "str",
                          "op2type": "str",
                          "duration": "-2",
                          "extend": false,
                          "units": "s",
                          "reset": "",
                          "bytopic": "all",
                          "topic": "topic",
                          "outputs": 1,
                          "x": 480,
                          "y": 760,
                          "wires": [
                          "3ce3731fa2de008c"
                          "type": "ui_group",
                          "name": "Test 1",
                          "order": 3,
                          "disp": true,
                          "width": "6",
                          "collapse": false
                          "type": "ui_group",
                          "name": "Default",
                          "order": 4,
                          "disp": true,
                          "width": 6,
                          "collapse": false
                          "name": "",
                          "port": "1883",
                          "clientid": "",
                          "usetls": false,
                          "keepalive": "60",
                          "name": "CerboGX",
                          "port": "1883",
                          "clientid": "",
                          "usetls": false,
                          "keepalive": "60",
                          "birthTopic": "",
                          "birthQos": "0",
                          "birthPayload": "",
                          "birthMsg": {},
                          "closeTopic": "",
                          "closeQos": "0",
                          "closePayload": "",
                          "closeMsg": {},
                          "willTopic": "",
                          "willQos": "0",
                          "willPayload": "",
                          "willMsg": {},
                          "userProps": "",
                          "sessionExpiry": ""
                          "type": "ui_group",
                          "name": "Stapler ",
                          "order": 1,
                          "disp": true,
                          "width": "6",
                          "collapse": false
                          "type": "ui_tab",
                          "name": "Home",
                          "order": 2,
                          "disabled": false,
                          "hidden": false
                                    "type": "tab",
                                    "disabled": false,
                                    "info": "",
                                    "env": []
                                    "type": "debug",
                                    "name": "debug 81",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 1040,
                                    "y": 160,
                                    "wires": []
                                    "type": "change",
                                    "name": "Spannung",
                                    "rules": [
                                            "t": "move",
                                            "pt": "msg",
                                            "to": "payload",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 580,
                                    "y": 160,
                                    "wires": [
                                            "e5c4d789e94d350e",
                                            "a10b8a367682404e"
                                    "type": "ui_gauge",
                                    "name": "",
                                    "order": 2,
                                    "width": 0,
                                    "height": 0,
                                    "gtype": "gage",
                                    "label": "units",
                                    "min": 0,
                                    "max": "240",
                                    "colors": [
                                        "#ff0000",
                                        "#ffff00",
                                        "#008000"
                                    "seg1": "200",
                                    "seg2": "220",
                                    "x": 760,
                                    "y": 160,
                                    "wires": []
                                    "type": "debug",
                                    "name": "debug 82",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 440,
                                    "y": 100,
                                    "wires": []
                                    "type": "change",
                                    "rules": [
                                            "t": "move",
                                            "pt": "msg",
                                            "to": "payload",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 570,
                                    "y": 200,
                                    "wires": [
                                            "e60c46e0c106e4dc"
                                    "type": "debug",
                                    "name": "debug 83",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 1040,
                                    "y": 200,
                                    "wires": []
                                    "path": "/Soc",
                                    "serviceObj": {
                                    "pathObj": {
                                        "path": "/Soc",
                                        "type": "float",
                                    "initial": "",
                                    "name": "",
                                    "x": 180,
                                    "y": 520,
                                    "wires": [
                                            "6ddde74da4bb9545"
                                    "type": "switch",
                                    "name": "",
                                    "rules": [
                                            "t": "gt",
                                            "v": "101",
                                            "vt": "num"
                                            "t": "lt",
                                            "v": "70",
                                            "vt": "num"
                                    "repair": false,
                                    "outputs": 2,
                                    "x": 390,
                                    "y": 1000,
                                    "wires": [
                                            "e5fea5b934a2efc7",
                                            "b9ed6599cf70de74"
                                            "5012c46291e78a77",
                                            "cbe9c595bb01b81e"
                                    "type": "debug",
                                    "name": "debug 84",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 660,
                                    "y": 380,
                                    "wires": []
                                    "type": "debug",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 800,
                                    "y": 580,
                                    "wires": []
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "pt": "global",
                                            "to": "payload",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 520,
                                    "y": 520,
                                    "wires": [
                                            "5d01b124055bea37",
                                            "52e26a73c3b27f6e",
                                            "50eb11e95ce1c4f3"
                                    "name": "",
                                    "tooltip": "",
                                    "order": 4,
                                    "width": 0,
                                    "height": 0,
                                    "passthru": true,
                                    "outs": "all",
                                    "topic": "topic",
                                    "topicType": "msg",
                                    "min": 0,
                                    "max": "100",
                                    "step": 1,
                                    "x": 160,
                                    "y": 600,
                                    "wires": [
                                            "1b2e513f58f2960b",
                                            "236cb5a6278abac6",
                                            "5ba74f68268192ec",
                                            "e5c7f72323657170",
                                            "dbc6348bafca49a8"
                                    "type": "ui_gauge",
                                    "name": "",
                                    "order": 5,
                                    "width": 0,
                                    "height": 0,
                                    "gtype": "gage",
                                    "min": 0,
                                    "max": "100",
                                    "colors": [
                                        "#ff0000",
                                        "#e6e600",
                                        "#00ff00"
                                    "seg1": "",
                                    "seg2": "",
                                    "x": 590,
                                    "y": 600,
                                    "wires": []
                                    "type": "debug",
                                    "name": "debug 86",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 880,
                                    "y": 1120,
                                    "wires": []
                                    "type": "debug",
                                    "name": "debug 87",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 1060,
                                    "y": 280,
                                    "wires": []
                                    "type": "debug",
                                    "name": "debug 88",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": true,
                                    "x": 940,
                                    "y": 760,
                                    "wires": []
                                    "type": "change",
                                    "rules": [
                                            "t": "move",
                                            "pt": "msg",
                                            "to": "payload",
                                            "tot": "msg"
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "on",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 570,
                                    "y": 280,
                                    "wires": [
                                            "ec8f88403a3d804a"
                                    "type": "ui_chart",
                                    "name": "",
                                    "order": 11,
                                    "width": 0,
                                    "height": 0,
                                    "chartType": "bar",
                                    "legend": "true",
                                    "nodata": "",
                                    "dot": false,
                                    "ymin": "",
                                    "ymax": "",
                                    "removeOlder": 1,
                                    "cutout": 0,
                                    "useUTC": false,
                                    "colors": [
                                        "#1f77b4",
                                        "#aec7e8",
                                        "#ff7f0e",
                                        "#2ca02c",
                                        "#98df8a",
                                        "#d62728",
                                        "#ff9896",
                                        "#9467bd",
                                        "#c5b0d5"
                                    "outputs": 1,
                                    "x": 770,
                                    "y": 240,
                                    "wires": [
                                            "eba281a8c7d862c3"
                                    "type": "debug",
                                    "name": "debug 89",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 1060,
                                    "y": 240,
                                    "wires": []
                                    "type": "change",
                                    "rules": [
                                            "t": "move",
                                            "pt": "msg",
                                            "to": "payload",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 570,
                                    "y": 240,
                                    "wires": [
                                            "d6f7d9277bab1b46"
                                    "type": "ui_chart",
                                    "name": "",
                                    "order": 6,
                                    "width": 0,
                                    "height": 0,
                                    "chartType": "bar",
                                    "legend": "false",
                                    "nodata": "",
                                    "dot": false,
                                    "ymin": "",
                                    "ymax": "",
                                    "removeOlder": 1,
                                    "cutout": 0,
                                    "useUTC": false,
                                    "colors": [
                                        "#1f77b4",
                                        "#aec7e8",
                                        "#ff7f0e",
                                        "#2ca02c",
                                        "#98df8a",
                                        "#d62728",
                                        "#ff9896",
                                        "#9467bd",
                                        "#c5b0d5"
                                    "outputs": 1,
                                    "x": 770,
                                    "y": 200,
                                    "wires": [
                                            "318a5c613a88c769"
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "ON",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 630,
                                    "y": 1020,
                                    "wires": [
                                            "a3ff7d845272b908",
                                            "d00e1f649acb16f3"
                                    "name": "",
                                    "outputs": 1,
                                    "fullTopic": "",
                                    "cmndPrefix": "",
                                    "statPrefix": "",
                                    "telePrefix": "",
                                    "qos": 1,
                                    "retain": false,
                                    "rules": [],
                                    "outputTopic": "",
                                    "x": 240,
                                    "y": 140,
                                    "wires": [
                                            "99db0d2dae9eefe5",
                                            "f5252ff2d2f5e5c1",
                                            "89e9cf65394790da",
                                            "7cf3622b17046eee",
                                            "77456c5a3405fff3"
                                    "type": "ui_chart",
                                    "name": "",
                                    "order": 7,
                                    "width": 0,
                                    "height": 0,
                                    "chartType": "bar",
                                    "legend": "true",
                                    "nodata": "",
                                    "dot": false,
                                    "ymin": "",
                                    "ymax": "",
                                    "removeOlder": 1,
                                    "cutout": 0,
                                    "useUTC": false,
                                    "colors": [
                                        "#1f77b4",
                                        "#aec7e8",
                                        "#ff7f0e",
                                        "#2ca02c",
                                        "#98df8a",
                                        "#d62728",
                                        "#ff9896",
                                        "#9467bd",
                                        "#c5b0d5"
                                    "outputs": 1,
                                    "x": 770,
                                    "y": 280,
                                    "wires": [
                                            "73f440c9fc6e840c"
                                    "type": "mqtt out",
                                    "name": "",
                                    "qos": "",
                                    "retain": "",
                                    "respTopic": "",
                                    "contentType": "",
                                    "userProps": "",
                                    "correl": "",
                                    "expiry": "",
                                    "x": 1010,
                                    "y": 1020,
                                    "wires": []
                                    "type": "mqtt in",
                                    "name": "",
                                    "qos": "0",
                                    "datatype": "json",
                                    "nl": false,
                                    "rap": true,
                                    "rh": 0,
                                    "inputs": 0,
                                    "x": 140,
                                    "y": 320,
                                    "wires": [
                                            "a79580173aa2a19f",
                                            "0ae9a66a06af1dd3"
                                    "type": "debug",
                                    "name": "debug 98",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 980,
                                    "y": 980,
                                    "wires": []
                                    "type": "debug",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 660,
                                    "y": 320,
                                    "wires": []
                                    "type": "ui_text",
                                    "order": 6,
                                    "width": 6,
                                    "height": 1,
                                    "name": "",
                                    "x": 1090,
                                    "y": 560,
                                    "wires": []
                                    "type": "ui_gauge",
                                    "name": "",
                                    "order": 3,
                                    "width": 0,
                                    "height": 0,
                                    "gtype": "gage",
                                    "label": "units",
                                    "min": 0,
                                    "max": "100",
                                    "colors": [
                                        "#ff0000",
                                        "#ffff00",
                                        "#008000"
                                    "seg1": "30",
                                    "seg2": "75",
                                    "x": 1100,
                                    "y": 520,
                                    "wires": []
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "OFF",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 630,
                                    "y": 1060,
                                    "wires": [
                                            "0d5525e74b9b0109",
                                            "d00e1f649acb16f3"
                                    "type": "debug",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": true,
                                    "x": 720,
                                    "y": 940,
                                    "wires": []
                                    "type": "debug",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 640,
                                    "y": 1120,
                                    "wires": []
                                    "type": "function",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 1340,
                                    "y": 240,
                                    "wires": [
                                    "type": "function",
                                    "name": "Zähler 1",
                                    "func": "var f_zaehler1 = flow.get(`f_zaehler1`) || 0;\nf_zaehler1 = 100;\nflow.set('f_zaehler1', f_zaehler1);\nmsg.payload = f_zaehler1;\nreturn msg;",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 860,
                                    "y": 440,
                                    "wires": [
                                            "091cad702c61cd45"
                                    "type": "debug",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": true,
                                    "x": 1020,
                                    "y": 400,
                                    "wires": []
                                    "type": "debug",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": true,
                                    "x": 920,
                                    "y": 700,
                                    "wires": []
                                    "type": "debug",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 120,
                                    "y": 920,
                                    "wires": []
                                    "type": "debug",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": true,
                                    "x": 1020,
                                    "y": 480,
                                    "wires": []
                                    "type": "switch",
                                    "name": "",
                                    "rules": [
                                            "t": "gt",
                                            "v": "1",
                                            "vt": "num"
                                            "t": "lt",
                                            "v": "0",
                                            "vt": "num"
                                    "repair": false,
                                    "outputs": 2,
                                    "x": 150,
                                    "y": 720,
                                    "wires": [
                                    "type": "function",
                                    "name": "Zähler 2",
                                    "func": "var f_zaehler2 = flow.get(`f_zaehler2`) || 0;\nflow.set('f_zaehler2',msg.payload);\nreturn msg;",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 660,
                                    "y": 700,
                                    "wires": [
                                            "89f93330dc0e65fa"
                                    "type": "change",
                                    "rules": [
                                            "t": "move",
                                            "pt": "msg",
                                            "to": "payload",
                                            "tot": "msg"
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "on",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 350,
                                    "y": 380,
                                    "wires": [
                                            "f237aa09ab50cbd7",
                                            "799b36b1217126ae"
                                    "type": "trigger",
                                    "name": "",
                                    "op1": "ON",
                                    "op2": "ON",
                                    "op1type": "str",
                                    "op2type": "str",
                                    "duration": "18",
                                    "extend": false,
                                    "units": "s",
                                    "reset": "",
                                    "bytopic": "all",
                                    "topic": "topic",
                                    "outputs": 2,
                                    "x": 670,
                                    "y": 460,
                                    "wires": [
                                            "7b549e85395e6e3a"
                                            "65753d1d393ce5f9"
                                    "type": "function",
                                    "name": "Zähler 1",
                                    "func": "var f_zaehler1 = flow.get(`f_zaehler1`) || 0;\nf_zaehler1 = 0;\nflow.set('f_zaehler1', f_zaehler1);\nmsg.payload = f_zaehler1;\nreturn msg;",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 860,
                                    "y": 480,
                                    "wires": [
                                            "7f4199879ec3aeda"
                                    "type": "function",
                                    "name": "Zähler 4",
                                    "func": "var f_zaehler1 = flow.get(`f_zaehler1`) || 0;\nvar f_zaehler2 = flow.get(`f_zaehler2`) || 0;\nvar f_zaehler4 = flow.get(`f_zaehler4`) || 0;\nf_zaehler4 = f_zaehler1 + f_zaehler2;\nflow.set('f_zaehler4', f_zaehler4);\nmsg.payload = f_zaehler4;\nreturn msg;",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 720,
                                    "y": 760,
                                    "wires": [
                                            "6ebf1c2b99b260a0"
                                    "type": "switch",
                                    "name": "",
                                    "rules": [
                                            "t": "gt",
                                            "v": "1",
                                            "vt": "num"
                                    "repair": false,
                                    "outputs": 1,
                                    "x": 150,
                                    "y": 800,
                                    "wires": [
                                            "e14d12f8a327f7d2",
                                            "1d22878d092191cd"
                                    "type": "debug",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": true,
                                    "x": 960,
                                    "y": 880,
                                    "wires": []
                                    "type": "switch",
                                    "name": "",
                                    "rules": [
                                            "t": "gt",
                                            "v": "1",
                                            "vt": "num"
                                    "repair": false,
                                    "outputs": 1,
                                    "x": 150,
                                    "y": 760,
                                    "wires": [
                                            "5317e2e4064ae269"
                                    "type": "debug",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": true,
                                    "x": 960,
                                    "y": 820,
                                    "wires": []
                                    "type": "function",
                                    "name": "Zähler 3",
                                    "func": "var f_zaehler4 = flow.get(`f_zaehler4`) || 0;\nvar f_zaehler3 = flow.get(`f_zaehler3`) || 0;\nf_zaehler3 = f_zaehler4;\nflow.set('f_zaehler3', f_zaehler3);\nmsg.payload = f_zaehler3;\nreturn msg;",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 720,
                                    "y": 820,
                                    "wires": [
                                            "241a3883ea624c8d",
                                            "5369f8cb591ac34d"
                                    "type": "debug",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": true,
                                    "x": 180,
                                    "y": 1060,
                                    "wires": []
                                    "name": "",
                                    "order": 1,
                                    "width": 0,
                                    "height": 0,
                                    "passthru": false,
                                    "label": "button",
                                    "tooltip": "",
                                    "color": "",
                                    "bgcolor": "",
                                    "icon": "",
                                    "payload": "",
                                    "topic": "topic",
                                    "topicType": "msg",
                                    "x": 150,
                                    "y": 460,
                                    "wires": [
                                            "799b36b1217126ae"
                                    "type": "function",
                                    "name": "Zähler 2",
                                    "func": "var f_zaehler2 = flow.get(`f_zaehler2`) || 0;\n\nif (msg.topic === \"modbus/1/holdingRegisters/30/2600_L1_Power\") context.set(\"L1\",msg.payload);\nif (msg.topic === \"modbus/1/holdingRegisters/30/2601_L2_Power\") context.set(\"L2\",msg.payload);\nif (msg.topic === \"modbus/1/holdingRegisters/30/2602_L3_Power\") context.set(\"L3\",msg.payload);\n\nvar L1 = context.get(\"L1\") || 0;\nvar L2 = context.get(\"L2\") || 0;\nvar L3 = context.get(\"L3\") || 0;\n\nmsg.payload = L1 + L2 + L3;\n\n\n\n\n\nflow.set('f_zaehler2',msg.payload);\nreturn msg;",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 220,
                                    "y": 980,
                                    "wires": [
                                    "type": "trigger",
                                    "name": "",
                                    "op1": "ON",
                                    "op1type": "str",
                                    "op2type": "str",
                                    "duration": "-2",
                                    "extend": false,
                                    "units": "s",
                                    "reset": "",
                                    "bytopic": "all",
                                    "topic": "topic",
                                    "outputs": 1,
                                    "x": 500,
                                    "y": 820,
                                    "wires": [
                                            "aaf5f791f630a6a3"
                                    "type": "trigger",
                                    "name": "",
                                    "op1": "ON",
                                    "op1type": "str",
                                    "op2type": "str",
                                    "duration": "-2",
                                    "extend": false,
                                    "units": "s",
                                    "reset": "",
                                    "bytopic": "all",
                                    "topic": "topic",
                                    "outputs": 1,
                                    "x": 480,
                                    "y": 760,
                                    "wires": [
                                            "3ce3731fa2de008c"
                                    "type": "ui_group",
                                    "name": "Test 1",
                                    "order": 3,
                                    "disp": true,
                                    "width": "6",
                                    "collapse": false
                                    "type": "ui_group",
                                    "name": "Default",
                                    "order": 4,
                                    "disp": true,
                                    "width": 6,
                                    "collapse": false
                                    "name": "",
                                    "port": "1883",
                                    "clientid": "",
                                    "usetls": false,
                                    "keepalive": "60",
                                    "name": "CerboGX",
                                    "port": "1883",
                                    "clientid": "",
                                    "usetls": false,
                                    "keepalive": "60",
                                    "birthTopic": "",
                                    "birthQos": "0",
                                    "birthPayload": "",
                                    "birthMsg": {},
                                    "closeTopic": "",
                                    "closeQos": "0",
                                    "closePayload": "",
                                    "closeMsg": {},
                                    "willTopic": "",
                                    "willQos": "0",
                                    "willPayload": "",
                                    "willMsg": {},
                                    "userProps": "",
                                    "sessionExpiry": ""
                                    "type": "ui_group",
                                    "name": "Stapler ",
                                    "order": 1,
                                    "disp": true,
                                    "width": "6",
                                    "collapse": false
                                    "type": "ui_tab",
                                    "name": "Home",
                                    "order": 2,
                                    "disabled": false,
                                    "hidden": false
                              @josefthal ```
                              "type": "tab",
                              "disabled": false,
                              "info": "",
                              "env": []
                              "type": "debug",
                              "name": "debug 81",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 1040,
                              "y": 160,
                              "wires": []
                              "type": "change",
                              "name": "Spannung",
                              "rules": [
                              "t": "move",
                              "pt": "msg",
                              "to": "payload",
                              "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 580,
                              "y": 160,
                              "wires": [
                              "e5c4d789e94d350e",
                              "a10b8a367682404e"
                              "type": "ui_gauge",
                              "name": "",
                              "order": 2,
                              "width": 0,
                              "height": 0,
                              "gtype": "gage",
                              "label": "units",
                              "min": 0,
                              "max": "240",
                              "colors": [
                              "#ff0000",
                              "#ffff00",
                              "#008000"
                              "seg1": "200",
                              "seg2": "220",
                              "x": 760,
                              "y": 160,
                              "wires": []
                              "type": "debug",
                              "name": "debug 82",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 440,
                              "y": 100,
                              "wires": []
                              "type": "change",
                              "rules": [
                              "t": "move",
                              "pt": "msg",
                              "to": "payload",
                              "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 570,
                              "y": 200,
                              "wires": [
                              "e60c46e0c106e4dc"
                              "type": "debug",
                              "name": "debug 83",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 1040,
                              "y": 200,
                              "wires": []
                              "path": "/Soc",
                              "serviceObj": {
                              "pathObj": {
                              "path": "/Soc",
                              "type": "float",
                              "initial": "",
                              "name": "",
                              "x": 180,
                              "y": 520,
                              "wires": [
                              "6ddde74da4bb9545"
                              "type": "switch",
                              "name": "",
                              "rules": [
                              "t": "gt",
                              "v": "101",
                              "vt": "num"
                              "t": "lt",
                              "v": "70",
                              "vt": "num"
                              "repair": false,
                              "outputs": 2,
                              "x": 390,
                              "y": 1000,
                              "wires": [
                              "e5fea5b934a2efc7",
                              "b9ed6599cf70de74"
                              "5012c46291e78a77",
                              "cbe9c595bb01b81e"
                              "type": "debug",
                              "name": "debug 84",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 660,
                              "y": 380,
                              "wires": []
                              "type": "debug",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 800,
                              "y": 580,
                              "wires": []
                              "type": "change",
                              "name": "",
                              "rules": [
                              "t": "set",
                              "pt": "global",
                              "to": "payload",
                              "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 520,
                              "y": 520,
                              "wires": [
                              "5d01b124055bea37",
                              "52e26a73c3b27f6e",
                              "50eb11e95ce1c4f3"
                              "name": "",
                              "tooltip": "",
                              "order": 4,
                              "width": 0,
                              "height": 0,
                              "passthru": true,
                              "outs": "all",
                              "topic": "topic",
                              "topicType": "msg",
                              "min": 0,
                              "max": "100",
                              "step": 1,
                              "x": 160,
                              "y": 600,
                              "wires": [
                              "1b2e513f58f2960b",
                              "236cb5a6278abac6",
                              "5ba74f68268192ec",
                              "e5c7f72323657170",
                              "dbc6348bafca49a8"
                              "type": "ui_gauge",
                              "name": "",
                              "order": 5,
                              "width": 0,
                              "height": 0,
                              "gtype": "gage",
                              "min": 0,
                              "max": "100",
                              "colors": [
                              "#ff0000",
                              "#e6e600",
                              "#00ff00"
                              "seg1": "",
                              "seg2": "",
                              "x": 590,
                              "y": 600,
                              "wires": []
                              "type": "debug",
                              "name": "debug 86",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 880,
                              "y": 1120,
                              "wires": []
                              "type": "debug",
                              "name": "debug 87",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 1060,
                              "y": 280,
                              "wires": []
                              "type": "debug",
                              "name": "debug 88",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": true,
                              "x": 940,
                              "y": 760,
                              "wires": []
                              "type": "change",
                              "rules": [
                              "t": "move",
                              "pt": "msg",
                              "to": "payload",
                              "tot": "msg"
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "on",
                              "tot": "str"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 570,
                              "y": 280,
                              "wires": [
                              "ec8f88403a3d804a"
                              "type": "ui_chart",
                              "name": "",
                              "order": 11,
                              "width": 0,
                              "height": 0,
                              "chartType": "bar",
                              "legend": "true",
                              "nodata": "",
                              "dot": false,
                              "ymin": "",
                              "ymax": "",
                              "removeOlder": 1,
                              "cutout": 0,
                              "useUTC": false,
                              "colors": [
                              "#1f77b4",
                              "#aec7e8",
                              "#ff7f0e",
                              "#2ca02c",
                              "#98df8a",
                              "#d62728",
                              "#ff9896",
                              "#9467bd",
                              "#c5b0d5"
                              "outputs": 1,
                              "x": 770,
                              "y": 240,
                              "wires": [
                              "eba281a8c7d862c3"
                              "type": "debug",
                              "name": "debug 89",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 1060,
                              "y": 240,
                              "wires": []
                              "type": "change",
                              "rules": [
                              "t": "move",
                              "pt": "msg",
                              "to": "payload",
                              "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 570,
                              "y": 240,
                              "wires": [
                              "d6f7d9277bab1b46"
                              "type": "ui_chart",
                              "name": "",
                              "order": 6,
                              "width": 0,
                              "height": 0,
                              "chartType": "bar",
                              "legend": "false",
                              "nodata": "",
                              "dot": false,
                              "ymin": "",
                              "ymax": "",
                              "removeOlder": 1,
                              "cutout": 0,
                              "useUTC": false,
                              "colors": [
                              "#1f77b4",
                              "#aec7e8",
                              "#ff7f0e",
                              "#2ca02c",
                              "#98df8a",
                              "#d62728",
                              "#ff9896",
                              "#9467bd",
                              "#c5b0d5"
                              "outputs": 1,
                              "x": 770,
                              "y": 200,
                              "wires": [
                              "318a5c613a88c769"
                              "type": "change",
                              "name": "",
                              "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "ON",
                              "tot": "str"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 630,
                              "y": 1020,
                              "wires": [
                              "a3ff7d845272b908",
                              "d00e1f649acb16f3"
                              "name": "",
                              "outputs": 1,
                              "fullTopic": "",
                              "cmndPrefix": "",
                              "statPrefix": "",
                              "telePrefix": "",
                              "qos": 1,
                              "retain": false,
                              "rules": [],
                              "outputTopic": "",
                              "x": 240,
                              "y": 140,
                              "wires": [
                              "99db0d2dae9eefe5",
                              "f5252ff2d2f5e5c1",
                              "89e9cf65394790da",
                              "7cf3622b17046eee",
                              "77456c5a3405fff3"
                              "type": "ui_chart",
                              "name": "",
                              "order": 7,
                              "width": 0,
                              "height": 0,
                              "chartType": "bar",
                              "legend": "true",
                              "nodata": "",
                              "dot": false,
                              "ymin": "",
                              "ymax": "",
                              "removeOlder": 1,
                              "cutout": 0,
                              "useUTC": false,
                              "colors": [
                              "#1f77b4",
                              "#aec7e8",
                              "#ff7f0e",
                              "#2ca02c",
                              "#98df8a",
                              "#d62728",
                              "#ff9896",
                              "#9467bd",
                              "#c5b0d5"
                              "outputs": 1,
                              "x": 770,
                              "y": 280,
                              "wires": [
                              "73f440c9fc6e840c"
                              "type": "mqtt out",
                              "name": "",
                              "qos": "",
                              "retain": "",
                              "respTopic": "",
                              "contentType": "",
                              "userProps": "",
                              "correl": "",
                              "expiry": "",
                              "x": 1010,
                              "y": 1020,
                              "wires": []
                              "type": "mqtt in",
                              "name": "",
                              "qos": "0",
                              "datatype": "json",
                              "nl": false,
                              "rap": true,
                              "rh": 0,
                              "inputs": 0,
                              "x": 140,
                              "y": 320,
                              "wires": [
                              "a79580173aa2a19f",
                              "0ae9a66a06af1dd3"
                              "type": "debug",
                              "name": "debug 98",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 980,
                              "y": 980,
                              "wires": []
                              "type": "debug",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 660,
                              "y": 320,
                              "wires": []
                              "type": "ui_text",
                              "order": 6,
                              "width": 6,
                              "height": 1,
                              "name": "",
                              "x": 1090,
                              "y": 560,
                              "wires": []
                              "type": "ui_gauge",
                              "name": "",
                              "order": 3,
                              "width": 0,
                              "height": 0,
                              "gtype": "gage",
                              "label": "units",
                              "min": 0,
                              "max": "100",
                              "colors": [
                              "#ff0000",
                              "#ffff00",
                              "#008000"
                              "seg1": "30",
                              "seg2": "75",
                              "x": 1100,
                              "y": 520,
                              "wires": []
                              "type": "change",
                              "name": "",
                              "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "OFF",
                              "tot": "str"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 630,
                              "y": 1060,
                              "wires": [
                              "0d5525e74b9b0109",
                              "d00e1f649acb16f3"
                              "type": "debug",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": true,
                              "x": 720,
                              "y": 940,
                              "wires": []
                              "type": "debug",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 640,
                              "y": 1120,
                              "wires": []
                              "type": "function",
                              "outputs": 1,
                              "noerr": 0,
                              "initialize": "",
                              "finalize": "",
                              "libs": [],
                              "x": 1340,
                              "y": 240,
                              "wires": [
                              "type": "function",
                              "name": "Zähler 1",
                              "outputs": 1,
                              "noerr": 0,
                              "initialize": "",
                              "finalize": "",
                              "libs": [],
                              "x": 860,
                              "y": 440,
                              "wires": [
                              "091cad702c61cd45"
                              "type": "debug",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": true,
                              "x": 1020,
                              "y": 400,
                              "wires": []
                              "type": "debug",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": true,
                              "x": 920,
                              "y": 700,
                              "wires": []
                              "type": "debug",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 120,
                              "y": 920,
                              "wires": []
                              "type": "debug",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": true,
                              "x": 1020,
                              "y": 480,
                              "wires": []
                              "type": "switch",
                              "name": "",
                              "rules": [
                              "t": "gt",
                              "v": "1",
                              "vt": "num"
                              "t": "lt",
                              "v": "0",
                              "vt": "num"
                              "repair": false,
                              "outputs": 2,
                              "x": 150,
                              "y": 720,
                              "wires": [
                              "type": "function",
                              "name": "Zähler 2",
                              "outputs": 1,
                              "noerr": 0,
                              "initialize": "",
                              "finalize": "",
                              "libs": [],
                              "x": 660,
                              "y": 700,
                              "wires": [
                              "89f93330dc0e65fa"
                              "type": "change",
                              "rules": [
                              "t": "move",
                              "pt": "msg",
                              "to": "payload",
                              "tot": "msg"
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "on",
                              "tot": "str"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 350,
                              "y": 380,
                              "wires": [
                              "f237aa09ab50cbd7",
                              "799b36b1217126ae"
                              "type": "trigger",
                              "name": "",
                              "op1": "ON",
                              "op2": "ON",
                              "op1type": "str",
                              "op2type": "str",
                              "duration": "18",
                              "extend": false,
                              "units": "s",
                              "reset": "",
                              "bytopic": "all",
                              "topic": "topic",
                              "outputs": 2,
                              "x": 670,
                              "y": 460,
                              "wires": [
                              "7b549e85395e6e3a"
                              "65753d1d393ce5f9"
                              "type": "function",
                              "name": "Zähler 1",
                              "outputs": 1,
                              "noerr": 0,
                              "initialize": "",
                              "finalize": "",
                              "libs": [],
                              "x": 860,
                              "y": 480,
                              "wires": [
                              "7f4199879ec3aeda"
                              "type": "function",
                              "name": "Zähler 4",
                              "outputs": 1,
                              "noerr": 0,
                              "initialize": "",
                              "finalize": "",
                              "libs": [],
                              "x": 720,
                              "y": 760,
                              "wires": [
                              "6ebf1c2b99b260a0"
                              "type": "switch",
                              "name": "",
                              "rules": [
                              "t": "gt",
                              "v": "1",
                              "vt": "num"
                              "repair": false,
                              "outputs": 1,
                              "x": 150,
                              "y": 800,
                              "wires": [
                              "e14d12f8a327f7d2",
                              "1d22878d092191cd"
                              "type": "debug",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": true,
                              "x": 960,
                              "y": 880,
                              "wires": []
                              "type": "switch",
                              "name": "",
                              "rules": [
                              "t": "gt",
                              "v": "1",
                              "vt": "num"
                              "repair": false,
                              "outputs": 1,
                              "x": 150,
                              "y": 760,
                              "wires": [
                              "5317e2e4064ae269"
                              "type": "debug",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": true,
                              "x": 960,
                              "y": 820,
                              "wires": []
                              "type": "function",
                              "name": "Zähler 3",
                              "outputs": 1,
                              "noerr": 0,
                              "initialize": "",
                              "finalize": "",
                              "libs": [],
                              "x": 720,
                              "y": 820,
                              "wires": [
                              "241a3883ea624c8d",
                              "5369f8cb591ac34d"
                              "type": "debug",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": true,
                              "x": 180,
                              "y": 1060,
                              "wires": []
                              "name": "",
                              "order": 1,
                              "width": 0,
                              "height": 0,
                              "passthru": false,
                              "label": "button",
                              "tooltip": "",
                              "color": "",
                              "bgcolor": "",
                              "icon": "",
                              "payload": "",
                              "topic": "topic",
                              "topicType": "msg",
                              "x": 150,
                              "y": 460,
                              "wires": [
                              "799b36b1217126ae"
                              "type": "function",
                              "name": "Zähler 2",
                              "outputs": 1,
                              "noerr": 0,
                              "initialize": "",
                              "finalize": "",
                              "libs": [],
                              "x": 220,
                              "y": 980,
                              "wires": [
                              "type": "trigger",
                              "name": "",
                              "op1": "ON",
                              "op1type": "str",
                              "op2type": "str",
                              "duration": "-2",
                              "extend": false,
                              "units": "s",
                              "reset": "",
                              "bytopic": "all",
                              "topic": "topic",
                              "outputs": 1,
                              "x": 500,
                              "y": 820,
                              "wires": [
                              "aaf5f791f630a6a3"
                              "type": "trigger",
                              "name": "",
                              "op1": "ON",
                              "op1type": "str",
                              "op2type": "str",
                              "duration": "-2",
                              "extend": false,
                              "units": "s",
                              "reset": "",
                              "bytopic": "all",
                              "topic": "topic",
                              "outputs": 1,
                              "x": 480,
                              "y": 760,
                              "wires": [
                              "3ce3731fa2de008c"
                              "type": "ui_group",
                              "name": "Test 1",
                              "order": 3,
                              "disp": true,
                              "width": "6",
                              "collapse": false
                              "type": "ui_group",
                              "name": "Default",
                              "order": 4,
                              "disp": true,
                              "width": 6,
                              "collapse": false
                              "name": "",
                              "port": "1883",
                              "clientid": "",
                              "usetls": false,
                              "keepalive": "60",
                              "name": "CerboGX",
                              "port": "1883",
                              "clientid": "",
                              "usetls": false,
                              "keepalive": "60",
                              "birthTopic": "",
                              "birthQos": "0",
                              "birthPayload": "",
                              "birthMsg": {},
                              "closeTopic": "",
                              "closeQos": "0",
                              "closePayload": "",
                              "closeMsg": {},
                              "willTopic": "",
                              "willQos": "0",
                              "willPayload": "",
                              "willMsg": {},
                              "userProps": "",
                              "sessionExpiry": ""
                              "type": "ui_group",
                              "name": "Stapler ",
                              "order": 1,
                              "disp": true,
                              "width": "6",
                              "collapse": false
                              "type": "ui_tab",
                              "name": "Home",
                              "order": 2,
                              "disabled": false,
                              "hidden": false
                              2127
