    4. Harmony Adapter versagt seinen Dienst !
      Springreiter @Homoran last edited by
      @homoran garnichts!
      • DJMarc75
        DJMarc75 @Springreiter last edited by
        @springreiter sagte in Harmony Adapter versagt seinen Dienst !:
        garnichts!
        Adapter neu starten und dann muss sogar beim LOG-Level Info einiges im LOG stehen.
        bei mir z.B.
        harmony.0
        	2024-02-18 11:13:48.888	debug	current activity: MagentaTV
        harmony.0
        	2024-02-18 11:13:48.849	info	[PROCESS] Synced hub config for ML Multimedia (192.168.178.176)
        harmony.0
        	2024-02-18 11:13:48.849	debug	[PROCESS] Deleting devices
        harmony.0
        	2024-02-18 11:13:48.849	debug	[PROCESS] Deleting activities
        harmony.0
        	2024-02-18 11:13:48.849	debug	[PROCESS] Creating devices
        harmony.0
        	2024-02-18 11:13:48.849	debug	creating activities
        harmony.0
        	2024-02-18 11:13:48.848	debug	[PROCESS] Creating hub device
        harmony.0
        	2024-02-18 11:13:48.848	debug	[PROCESS] Creating activities and devices
        harmony.0
        	2024-02-18 11:13:48.082	info	[CONNECT] Connected to ML Multimedia (192.168.178.176)
        harmony.0
        	2024-02-18 11:13:46.951	info	[CONNECT] Connecting to ML Multimedia (192.168.178.176)
        harmony.0
        	2024-02-18 11:13:46.926	debug	hub initialized
        harmony.0
        	2024-02-18 11:13:46.898	info	[DISCOVER] Discovered ML Multimedia (192.168.178.176) and will try to connect
        harmony.0
        	2024-02-18 11:13:36.647	info	[DISCOVER] Searching for Harmony Hubs on 255.255.255.255
        harmony.0
        	2024-02-18 11:13:36.640	debug	[START] Subnet: 255.255.255.255, Discovery interval: 10000
        harmony.0
        	2024-02-18 11:13:36.632	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.19
        harmony.0
        	2024-02-18 11:13:36.555	debug	States connected to redis: 127.0.0.1:9000
        harmony.0
        	2024-02-18 11:13:36.488	debug	States create User PubSub Client
        harmony.0
        	2024-02-18 11:13:36.488	debug	States create System PubSub Client
        harmony.0
        	2024-02-18 11:13:36.473	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        harmony.0
        	2024-02-18 11:13:36.446	debug	Objects connected to redis: 127.0.0.1:9001
        harmony.0
        	2024-02-18 11:13:36.443	debug	Objects client initialize lua scripts
        harmony.0
        	2024-02-18 11:13:36.393	debug	Objects create User PubSub Client
        harmony.0
        	2024-02-18 11:13:36.392	debug	Objects create System PubSub Client
        harmony.0
        	2024-02-18 11:13:36.391	debug	Objects client ready ... initialize now
        harmony.0
        	2024-02-18 11:13:36.366	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        S Homoran 2 Replies Last reply Reply Quote 1
          Springreiter @DJMarc75 last edited by
            Homoran Global Moderator Administrators @Springreiter last edited by
            @springreiter bitte als Text in code-tags posten.
              Springreiter @Homoran last edited by Homoran
              2024-02-18 11:38:26.857 - info: host.iobroker stopInstance system.adapter.harmony.0 (force=false, process=true)
              2024-02-18 11:38:26.859 - info: harmony.0 (4155269) Got terminate signal TERMINATE_YOURSELF
              2024-02-18 11:38:26.861 - info: host.iobroker stopInstance system.adapter.harmony.0 send kill signal
              2024-02-18 11:38:26.860 - info: harmony.0 (4155269) [END] Terminating
              2024-02-18 11:38:26.861 - info: harmony.0 (4155269) terminating
              2024-02-18 11:38:26.861 - info: harmony.0 (4155269) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-02-18 11:38:27.362 - info: harmony.0 (4155269) terminating
              2024-02-18 11:38:27.455 - info: host.iobroker instance system.adapter.harmony.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-02-18 11:38:29.952 - info: host.iobroker instance system.adapter.harmony.0 started with pid 4156085
              2024-02-18 11:38:30.942 - debug: harmony.0 (4156085) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2024-02-18 11:38:30.973 - debug: harmony.0 (4156085) Objects client ready ... initialize now
              2024-02-18 11:38:30.974 - debug: harmony.0 (4156085) Objects create System PubSub Client
              2024-02-18 11:38:30.974 - debug: harmony.0 (4156085) Objects create User PubSub Client
              2024-02-18 11:38:31.025 - debug: harmony.0 (4156085) Objects client initialize lua scripts
              2024-02-18 11:38:31.029 - debug: harmony.0 (4156085) Objects connected to redis: 127.0.0.1:9001
              2024-02-18 11:38:31.077 - debug: harmony.0 (4156085) Redis States: Use Redis connection: 127.0.0.1:6379
              2024-02-18 11:38:31.081 - debug: harmony.0 (4156085) States create System PubSub Client
              2024-02-18 11:38:31.082 - debug: harmony.0 (4156085) States create User PubSub Client
              2024-02-18 11:38:31.091 - debug: harmony.0 (4156085) States connected to redis: 127.0.0.1:6379
              2024-02-18 11:38:31.228 - info: harmony.0 (4156085) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.17
              2024-02-18 11:38:31.249 - debug: harmony.0 (4156085) [START] Subnet: 255.255.255.255, Discovery interval: 10000
              2024-02-18 11:38:31.287 - info: harmony.0 (4156085) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
                und 10 Sekunden später kommt nichts?
                  @homoran nein- nichts
                    Homoran Global Moderator Administrators @Springreiter last edited by Homoran
                    demnach soll er alle 10000msec suchen
                      @homoran wenn der nicht über Jahre problemlos funktioniert hätte. Aber nach dem Searching for Harmony Hubs kommt nichts mehr. Da wurde nichts verändert- über Fernbedienung funktioniert er auch???
                      • DJMarc75
                        Sicherlich wird es mit irgendeinen Update zusammen hängen
                        ioBroker läuft bei Dir im Docker?
                          @djmarc75 Proxmos VM mit Debian
                          • DJMarc75
                            @springreiter
                            dann zeig mal bitte die Langfassung von:
                            iob diag
                            bitte in CodeTags
                              Leider darf der Benutzer dw »/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh« als iobroker auf iobroker nicht ausführen.
                              kannte ich auch nicht
                                oha!
                                Rechte verbogen mit irgendwelchen "Tools"?
                                bitte
                                iob stop
                                iob fix
                                iob start
                                ausführen ... warten
                                dann iob diag nochmal versuchen.
                                und immer jede Ein- und Ausgabe der Konsole vollständig in code-tags zeigen!
                                  @homoran darf ich immer noch nicht😞
                                    Thomas Braun Most Active @Springreiter last edited by
                                    @springreiter
                                    Du darfst keine vollständigen Dinge posten?
                                    Wer hat denn das untersagt?
                                      Springreiter @Thomas Braun last edited by
                                      @thomas-braun Leider darf der Benutzer dw »/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh« als iobroker auf iobroker nicht ausführen.
                                        @springreiter
                                        Vollständige Ein- wie Ausgaben inkl. des LoginPrompt, keine Nacherzählung.
                                          Springreiter @Thomas Braun last edited by Homoran
                                          login as: dw
                                          dw@192.168.178.59's password:
                                          Linux iobroker 5.10.0-18-amd64 #1 SMP Debian 5.10.140-1 (2022-09-02) x86_64
                                          The programs included with the Debian GNU/Linux system are free software;
                                          the exact distribution terms for each program are described in the
                                          individual files in /usr/share/doc/*/copyright.
                                          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                          permitted by applicable law.
                                          Last login: Sun Feb 18 12:32:09 2024 from 192.168.178.47
                                          dw@iobroker:~$ iob diag
                                          [sudo] Passwort für dw:
                                          dw@iobroker:~$
                                            Thomas Braun Most Active @Springreiter last edited by Thomas Braun
                                            @springreiter
                                            In CodeTags wäre noch fein...
                                            groups
                                            sagt?
                                            5541
