    4. Harmony Adapter versagt seinen Dienst !
      Homoran Global Moderator Administrators @Springreiter last edited by
      @springreiter bitte als Text in code-tags posten.
        Springreiter @Homoran last edited by Homoran
        2024-02-18 11:38:26.857 - info: host.iobroker stopInstance system.adapter.harmony.0 (force=false, process=true)
        2024-02-18 11:38:26.859 - info: harmony.0 (4155269) Got terminate signal TERMINATE_YOURSELF
        2024-02-18 11:38:26.861 - info: host.iobroker stopInstance system.adapter.harmony.0 send kill signal
        2024-02-18 11:38:26.860 - info: harmony.0 (4155269) [END] Terminating
        2024-02-18 11:38:26.861 - info: harmony.0 (4155269) terminating
        2024-02-18 11:38:26.861 - info: harmony.0 (4155269) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-02-18 11:38:27.362 - info: harmony.0 (4155269) terminating
        2024-02-18 11:38:27.455 - info: host.iobroker instance system.adapter.harmony.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-02-18 11:38:29.952 - info: host.iobroker instance system.adapter.harmony.0 started with pid 4156085
        2024-02-18 11:38:30.942 - debug: harmony.0 (4156085) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2024-02-18 11:38:30.973 - debug: harmony.0 (4156085) Objects client ready ... initialize now
        2024-02-18 11:38:30.974 - debug: harmony.0 (4156085) Objects create System PubSub Client
        2024-02-18 11:38:30.974 - debug: harmony.0 (4156085) Objects create User PubSub Client
        2024-02-18 11:38:31.025 - debug: harmony.0 (4156085) Objects client initialize lua scripts
        2024-02-18 11:38:31.029 - debug: harmony.0 (4156085) Objects connected to redis: 127.0.0.1:9001
        2024-02-18 11:38:31.077 - debug: harmony.0 (4156085) Redis States: Use Redis connection: 127.0.0.1:6379
        2024-02-18 11:38:31.081 - debug: harmony.0 (4156085) States create System PubSub Client
        2024-02-18 11:38:31.082 - debug: harmony.0 (4156085) States create User PubSub Client
        2024-02-18 11:38:31.091 - debug: harmony.0 (4156085) States connected to redis: 127.0.0.1:6379
        2024-02-18 11:38:31.228 - info: harmony.0 (4156085) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.17
        2024-02-18 11:38:31.249 - debug: harmony.0 (4156085) [START] Subnet: 255.255.255.255, Discovery interval: 10000
        2024-02-18 11:38:31.287 - info: harmony.0 (4156085) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
          @springreiter sagte in Harmony Adapter versagt seinen Dienst !:
          und 10 Sekunden später kommt nichts?
            @homoran nein- nichts
              Homoran Global Moderator Administrators @Springreiter last edited by Homoran
              demnach soll er alle 10000msec suchen
                @homoran wenn der nicht über Jahre problemlos funktioniert hätte. Aber nach dem Searching for Harmony Hubs kommt nichts mehr. Da wurde nichts verändert- über Fernbedienung funktioniert er auch???
                • DJMarc75
                  DJMarc75 @Springreiter last edited by
                  Sicherlich wird es mit irgendeinen Update zusammen hängen
                  ioBroker läuft bei Dir im Docker?
                    Springreiter @DJMarc75 last edited by
                    @djmarc75 Proxmos VM mit Debian
                    • DJMarc75
                      @springreiter
                      dann zeig mal bitte die Langfassung von:
                      iob diag
                      bitte in CodeTags
                        Leider darf der Benutzer dw »/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh« als iobroker auf iobroker nicht ausführen.
                        kannte ich auch nicht
                          oha!
                          Rechte verbogen mit irgendwelchen "Tools"?
                          bitte
                          iob stop
                          iob fix
                          iob start
                          ausführen ... warten
                          dann iob diag nochmal versuchen.
                          und immer jede Ein- und Ausgabe der Konsole vollständig in code-tags zeigen!
                            @homoran darf ich immer noch nicht😞
                              Thomas Braun Most Active @Springreiter last edited by
                              @springreiter
                              Du darfst keine vollständigen Dinge posten?
                              Wer hat denn das untersagt?
                                Springreiter @Thomas Braun last edited by
                                @thomas-braun Leider darf der Benutzer dw »/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh« als iobroker auf iobroker nicht ausführen.
                                  @springreiter
                                  Vollständige Ein- wie Ausgaben inkl. des LoginPrompt, keine Nacherzählung.
                                    Springreiter @Thomas Braun last edited by Homoran
                                    login as: dw
                                    dw@192.168.178.59's password:
                                    Linux iobroker 5.10.0-18-amd64 #1 SMP Debian 5.10.140-1 (2022-09-02) x86_64
                                    The programs included with the Debian GNU/Linux system are free software;
                                    the exact distribution terms for each program are described in the
                                    individual files in /usr/share/doc/*/copyright.
                                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                    permitted by applicable law.
                                    Last login: Sun Feb 18 12:32:09 2024 from 192.168.178.47
                                    dw@iobroker:~$ iob diag
                                    [sudo] Passwort für dw:
                                    dw@iobroker:~$
                                      Thomas Braun Most Active @Springreiter last edited by Thomas Braun
                                      @springreiter
                                      In CodeTags wäre noch fein...
                                      groups
                                      sagt?
                                        @thomas-braun jetzt setzt du zuviel bei mir vorraus- was ist das
                                        Codierknecht Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                                        • Codierknecht
                                          Codierknecht Developer Most Active @Springreiter last edited by
                                          @springreiter
                                          Das da:
                                            @springreiter
                                            Den Befehl
                                            groups
                                            in dein Terminal hacken, vollständige Ein- wie Ausgaben hier wieder rein kopieren, in CodeTags eingebettet.
                                            5543
