    4. Harmony Adapter versagt seinen Dienst !
      Springreiter @wendy2702 last edited by wendy2702
      @wendy2702
      armony.0
      2024-02-18 19:13:03.026	info	[DISCOVER] Searching for Harmony Hubs on 255.255.255.255
      harmony.0
      2024-02-18 19:13:03.015	debug	[START] Subnet: 255.255.255.255, Discovery interval: 10000
      harmony.0
      2024-02-18 19:13:03.001	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.17
      harmony.0
      2024-02-18 19:13:02.882	debug	States connected to redis: 127.0.0.1:6379
      harmony.0
      2024-02-18 19:13:02.877	debug	States create User PubSub Client
      harmony.0
      2024-02-18 19:13:02.877	debug	States create System PubSub Client
      harmony.0
      2024-02-18 19:13:02.872	debug	Redis States: Use Redis connection: 127.0.0.1:6379
      harmony.0
      2024-02-18 19:13:02.840	debug	Objects connected to redis: 127.0.0.1:9001
      harmony.0
      2024-02-18 19:13:02.836	debug	Objects client initialize lua scripts
      harmony.0
      2024-02-18 19:13:02.778	debug	Objects create User PubSub Client
      harmony.0
      2024-02-18 19:13:02.777	debug	Objects create System PubSub Client
      harmony.0
      2024-02-18 19:13:02.772	debug	Objects client ready ... initialize now
      harmony.0
      2024-02-18 19:13:02.739	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      harmony.0
      2024-02-18 19:12:59.322	info	terminating
      harmony.0
      2024-02-18 19:12:58.820	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      harmony.0
      2024-02-18 19:12:58.820	info	terminating
        @wendy2702 Hub hatte ich schon mehrmals neu gestartet
          @wendy2702
          2024-02-18 19:13:01.891 - info: host.iobroker instance system.adapter.harmony.0 started with pid 510833
          2024-02-18 19:13:02.739 - debug: harmony.0 (510833) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2024-02-18 19:13:02.772 - debug: harmony.0 (510833) Objects client ready ... initialize now
          2024-02-18 19:13:02.777 - debug: harmony.0 (510833) Objects create System PubSub Client
          2024-02-18 19:13:02.778 - debug: harmony.0 (510833) Objects create User PubSub Client
          2024-02-18 19:13:02.836 - debug: harmony.0 (510833) Objects client initialize lua scripts
          2024-02-18 19:13:02.840 - debug: harmony.0 (510833) Objects connected to redis: 127.0.0.1:9001
          2024-02-18 19:13:02.872 - debug: harmony.0 (510833) Redis States: Use Redis connection: 127.0.0.1:6379
          2024-02-18 19:13:02.877 - debug: harmony.0 (510833) States create System PubSub Client
          2024-02-18 19:13:02.877 - debug: harmony.0 (510833) States create User PubSub Client
          2024-02-18 19:13:02.882 - debug: harmony.0 (510833) States connected to redis: 127.0.0.1:6379
          2024-02-18 19:13:03.001 - info: harmony.0 (510833) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.17
          2024-02-18 19:13:03.015 - debug: harmony.0 (510833) [START] Subnet: 255.255.255.255, Discovery interval: 10000
          2024-02-18 19:13:03.026 - info: harmony.0 (510833) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
          MOD EDIT: CODE TAGS Korrigiert
          wendy2702 FredF 2 Replies Last reply Reply Quote 0
          • Codierknecht
            Codierknecht Developer Most Active @Springreiter last edited by
            @springreiter
            Die 3 Backticks für die Code-Tags müssen jeweils in eigenen Zeilen stehen.
            • wendy2702
              wendy2702 @Springreiter last edited by
              @springreiter sagte in Harmony Adapter versagt seinen Dienst !:
              Was kommt nach den 10000msec im log ?
              S Homoran 2 Replies Last reply Reply Quote 0
                @wendy2702 nichts mehr
                  Homoran Global Moderator Administrators @wendy2702 last edited by
                  @wendy2702 sagte in Harmony Adapter versagt seinen Dienst !:
                  @homoran nein- nichts
                  • O
                    oFbEQnpoLKKl6mbY5e13 @Springreiter last edited by oFbEQnpoLKKl6mbY5e13
                    @springreiter
                    Hast du die IP deines Hubs mal in der Instanz hinzugefügt?
                    Edit:
                    Konfiguration Harmony Instanz
                      Springreiter @oFbEQnpoLKKl6mbY5e13 last edited by
                      @ofbeqnpolkkl6mby5e13 hatte ich schon mal versucht, ohne Erfolg. Ich versuche es noch einmal, nach den ganzen Ergänzungen
                        @ofbeqnpolkkl6mby5e13 nochmal versucht, keine Änderung
                        • O
                          @springreiter
                          Und du bist sicher, dass die IP korrekt ist?
                            wendy2702 O 2 Replies Last reply Reply Quote 1
                            • wendy2702
                              wendy2702 @Springreiter last edited by wendy2702
                              @springreiter Was kommt jetzt im log und welche Updates hast du denn gemacht?
                              Du hast auch geschrieben du hast Adapter gelöscht und neu Installiert, wirklich den Adapter oder nur die Instanz gelöscht?
                              Gerade mal bei mir geschaut, log sieht so aus wenn ich den HUB z.B. vom Strom nehme.
                              • O
                                @springreiter
                                Kannst du die IP-Adresse von deinem iobroker aus erreichen?
                                  @wendy2702
                                  @wendy2702 said in Harmony Adapter versagt seinen Dienst !:
                                  Instanz gelöscht, Adapter gelöscht- Adapter und Instanz installiert- keine Veränderungen
                                  • wendy2702
                                    @springreiter Ich würde ehrlich gesagt immer noch vermuten das der HUB nicht erreichbar ist.
                                    Wenn du den mal vom Netz nimmst, verschwindet er denn auch in der FB als aktives device?
                                      @ofbeqnpolkkl6mby5e13 der ping adapter sagt
                                      • wendy2702
                                        Wurde der IOB Server mal neu gestartet?
                                        Homoran S 2 Replies Last reply Reply Quote 0
                                          oder die Fritte?
                                          geht das Ganze nicht über UDP? Gab es da nicht irgendwelche Einschränkungen bezüglich Switche auf dem Weg?
                                            @wendy2702 Stecker gezogen
                                            5663
