    4. Harmony Adapter versagt seinen Dienst !
      Springreiter @wendy2702 last edited by
      @wendy2702 Hub hatte ich schon mehrmals neu gestartet
        Springreiter @wendy2702 last edited by wendy2702
        @wendy2702
        2024-02-18 19:13:01.891 - info: host.iobroker instance system.adapter.harmony.0 started with pid 510833
        2024-02-18 19:13:02.739 - debug: harmony.0 (510833) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2024-02-18 19:13:02.772 - debug: harmony.0 (510833) Objects client ready ... initialize now
        2024-02-18 19:13:02.777 - debug: harmony.0 (510833) Objects create System PubSub Client
        2024-02-18 19:13:02.778 - debug: harmony.0 (510833) Objects create User PubSub Client
        2024-02-18 19:13:02.836 - debug: harmony.0 (510833) Objects client initialize lua scripts
        2024-02-18 19:13:02.840 - debug: harmony.0 (510833) Objects connected to redis: 127.0.0.1:9001
        2024-02-18 19:13:02.872 - debug: harmony.0 (510833) Redis States: Use Redis connection: 127.0.0.1:6379
        2024-02-18 19:13:02.877 - debug: harmony.0 (510833) States create System PubSub Client
        2024-02-18 19:13:02.877 - debug: harmony.0 (510833) States create User PubSub Client
        2024-02-18 19:13:02.882 - debug: harmony.0 (510833) States connected to redis: 127.0.0.1:6379
        2024-02-18 19:13:03.001 - info: harmony.0 (510833) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.17
        2024-02-18 19:13:03.015 - debug: harmony.0 (510833) [START] Subnet: 255.255.255.255, Discovery interval: 10000
        2024-02-18 19:13:03.026 - info: harmony.0 (510833) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
        MOD EDIT: CODE TAGS Korrigiert
        wendy2702 FredF 2 Replies Last reply Reply Quote 0
        • Codierknecht
          Codierknecht Developer Most Active @Springreiter last edited by
          @springreiter
          Die 3 Backticks für die Code-Tags müssen jeweils in eigenen Zeilen stehen.
          • wendy2702
            wendy2702 @Springreiter last edited by
            @springreiter sagte in Harmony Adapter versagt seinen Dienst !:
            Was kommt nach den 10000msec im log ?
            S Homoran 2 Replies Last reply Reply Quote 0
              @wendy2702 nichts mehr
                Homoran Global Moderator Administrators @wendy2702 last edited by
                @wendy2702 sagte in Harmony Adapter versagt seinen Dienst !:
                @homoran nein- nichts
                • O
                  oFbEQnpoLKKl6mbY5e13 @Springreiter last edited by oFbEQnpoLKKl6mbY5e13
                  @springreiter
                  Hast du die IP deines Hubs mal in der Instanz hinzugefügt?
                  Edit:
                  Konfiguration Harmony Instanz
                    Springreiter @oFbEQnpoLKKl6mbY5e13 last edited by
                    @ofbeqnpolkkl6mby5e13 hatte ich schon mal versucht, ohne Erfolg. Ich versuche es noch einmal, nach den ganzen Ergänzungen
                      @ofbeqnpolkkl6mby5e13 nochmal versucht, keine Änderung
                      • O
                        @springreiter
                        Und du bist sicher, dass die IP korrekt ist?
                          wendy2702 O 2 Replies Last reply Reply Quote 1
                          • wendy2702
                            wendy2702 @Springreiter last edited by wendy2702
                            @springreiter Was kommt jetzt im log und welche Updates hast du denn gemacht?
                            Du hast auch geschrieben du hast Adapter gelöscht und neu Installiert, wirklich den Adapter oder nur die Instanz gelöscht?
                            Gerade mal bei mir geschaut, log sieht so aus wenn ich den HUB z.B. vom Strom nehme.
                            • O
                              @springreiter
                              Kannst du die IP-Adresse von deinem iobroker aus erreichen?
                                @wendy2702
                                @wendy2702 said in Harmony Adapter versagt seinen Dienst !:
                                Instanz gelöscht, Adapter gelöscht- Adapter und Instanz installiert- keine Veränderungen
                                • wendy2702
                                  @springreiter Ich würde ehrlich gesagt immer noch vermuten das der HUB nicht erreichbar ist.
                                  Wenn du den mal vom Netz nimmst, verschwindet er denn auch in der FB als aktives device?
                                    @ofbeqnpolkkl6mby5e13 der ping adapter sagt
                                    • wendy2702
                                      Wurde der IOB Server mal neu gestartet?
                                      Homoran S 2 Replies Last reply Reply Quote 0
                                        oder die Fritte?
                                        geht das Ganze nicht über UDP? Gab es da nicht irgendwelche Einschränkungen bezüglich Switche auf dem Weg?
                                          @wendy2702 Stecker gezogen
                                            Springreiter @Homoran last edited by
                                            @homoran dann hätte ich ja irgendetwas geändert haben müssen- definitiv nicht
                                            5530
