    4. ZigBee neue Version 1.9.x
    • Latzi
      Latzi @dimaiv last edited by
      @dimaiv
      gesagt, getan - hat leider nichts geändert.
      Log schaut unauffällig aus:
      zigbee.0
      2024-02-18 16:19:07.420	info	DeviceConfigure successful 0x54ef441000258d08 lumi.switch.n0agl1
      zigbee.0
      2024-02-18 16:19:07.242	info	-> Configuring 0x54ef441000258d08 lumi.switch.n0agl1
        dimaiv @Latzi last edited by
        @latzi
        Firmware auf dem Switch kannst du auch noch aktualisieren...
        Latzi 1 Reply Last reply Reply Quote 0
        • Latzi
          @dimaiv
          hab ich vor dem ersten Posting schon gemacht, Firmware ist aktuell.
            arteck Developer Most Active @Latzi last edited by arteck
            erstmal
            log vom adapter Start zeigen..
            • Latzi
              Latzi @arteck last edited by
              @arteck sagte in ZigBee neue Version 1.9.x:
              bitte sehr ...
              2024-02-19 07:11:30.383 - info: host.ioBroker instance system.adapter.zigbee.0 started with pid 3191297
              2024-02-19 07:11:32.489 - info: zigbee.0 (3191297) starting. Version 1.10.2 (non-npm: ioBroker/ioBroker.zigbee#679c62d826fdf73f37da83761ffaef07d9e1de12) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.1, js-controller: 5.0.19
              2024-02-19 07:11:32.528 - info: zigbee.0 (3191297) delete old Backup files. keep only last 10
              2024-02-19 07:11:32.529 - info: zigbee.0 (3191297) Starting Zigbee npm ...
              2024-02-19 07:11:32.646 - info: zigbee.0 (3191297) Installed Version: ioBroker/ioBroker.zigbee#679c62d826fdf73f37da83761ffaef07d9e1de12
              2024-02-19 07:11:33.026 - info: zigbee.0 (3191297) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20190523}}
              2024-02-19 07:11:33.052 - info: zigbee.0 (3191297) Unable to disable LED, unsupported function.
              2024-02-19 07:11:33.057 - info: zigbee.0 (3191297) --> transmitPower : high
              2024-02-19 07:11:33.070 - info: zigbee.0 (3191297) Currently 50 devices are joined:
              2024-02-19 07:11:33.111 - info: zigbee.0 (3191297) 0x00158d00042cbc41 (addr 32904): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
              2024-02-19 07:11:33.113 - info: zigbee.0 (3191297) 0x00158d000578cacb (addr 39762): WXKG01LM - Xiaomi Mi wireless switch (EndDevice)
              2024-02-19 07:11:33.113 - info: zigbee.0 (3191297) 0xbc33acfffed3751d (addr 18125): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
              2024-02-19 07:11:33.114 - info: zigbee.0 (3191297) 0x7cb03eaa0a058b13 (addr 25701): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
              2024-02-19 07:11:33.114 - info: zigbee.0 (3191297) 0x00158d000423c2b3 (addr 1047): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
              2024-02-19 07:11:33.114 - info: zigbee.0 (3191297) 0x00158d000359b3ac (addr 39307): WXKG01LM - Xiaomi Mi wireless switch (EndDevice)
              2024-02-19 07:11:33.115 - info: zigbee.0 (3191297) 0x00158d000359b468 (addr 51855): WXKG01LM - Xiaomi Mi wireless switch (EndDevice)
              2024-02-19 07:11:33.115 - info: zigbee.0 (3191297) 0x00158d0003fb04e0 (addr 29417): RTCGQ11LM - Aqara Motion sensor (EndDevice)
              2024-02-19 07:11:33.116 - info: zigbee.0 (3191297) 0x00158d0003a5b42f (addr 21249): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
              2024-02-19 07:11:33.116 - info: zigbee.0 (3191297) 0x00158d000423cca0 (addr 20171): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
              2024-02-19 07:11:33.117 - info: zigbee.0 (3191297) 0x00158d0003cbc49f (addr 46812): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
              2024-02-19 07:11:33.117 - info: zigbee.0 (3191297) 0x00158d0003a5b46e (addr 7607): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
              2024-02-19 07:11:33.118 - info: zigbee.0 (3191297) 0x00158d000451c08a (addr 18096): RTCGQ11LM - Aqara Motion sensor (EndDevice)
              2024-02-19 07:11:33.118 - info: zigbee.0 (3191297) 0x00158d000451a4cd (addr 43756): RTCGQ11LM - Aqara Motion sensor (EndDevice)
              2024-02-19 07:11:33.118 - info: zigbee.0 (3191297) 0x00158d00041dff50 (addr 42699): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
              2024-02-19 07:11:33.119 - info: zigbee.0 (3191297) 0x3425b4fffe97529d (addr 4159): E2112 - IKEA Vindstyrka air quality and humidity sensor (Router)
              2024-02-19 07:11:33.119 - info: zigbee.0 (3191297) 0x00158d000444a895 (addr 32464): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
              2024-02-19 07:11:33.120 - info: zigbee.0 (3191297) 0x00158d00041842da (addr 52234): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
              2024-02-19 07:11:33.120 - info: zigbee.0 (3191297) 0x00158d0004185cf3 (addr 62939): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
              2024-02-19 07:11:33.121 - info: zigbee.0 (3191297) 0x00158d00041890c8 (addr 32172): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
              2024-02-19 07:11:33.121 - info: zigbee.0 (3191297) 0x00158d000423b0e5 (addr 64349): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
              2024-02-19 07:11:33.121 - info: zigbee.0 (3191297) 0x00158d000445006d (addr 24968): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
              2024-02-19 07:11:33.122 - info: zigbee.0 (3191297) 0x7cb03eaa0a04459b (addr 49243): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
              2024-02-19 07:11:33.122 - info: zigbee.0 (3191297) 0x60a423fffee55619 (addr 49893): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
              2024-02-19 07:11:33.123 - info: zigbee.0 (3191297) 0x60a423fffeeedaf3 (addr 1789): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
              2024-02-19 07:11:33.123 - info: zigbee.0 (3191297) 0x001788010bcfad1a (addr 4746): 9290030675 - Philips Hue motion sensor (EndDevice)
              2024-02-19 07:11:33.124 - info: zigbee.0 (3191297) 0xbc33acfffea231b7 (addr 39370): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
              2024-02-19 07:11:33.125 - info: zigbee.0 (3191297) 0x60a423fffef481d4 (addr 9667): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
              2024-02-19 07:11:33.125 - info: zigbee.0 (3191297) 0xbc33acfffe2b5348 (addr 51918): LED1903C5/LED1835C6 - IKEA TRADFRI bulb E12/E14/E17 WS 450/470/440 lumen, dimmable, white spectrum, opal white (Router)
              2024-02-19 07:11:33.126 - info: zigbee.0 (3191297) 0x04cf8cdf3c8e2db4 (addr 45614): ZNCZ04LM - Xiaomi Mi smart plug EU (Router)
              2024-02-19 07:11:33.127 - info: zigbee.0 (3191297) 0xa4c138611008805f (addr 27489): ZY-M100-S_2 - TuYa Mini human breathe sensor (Router)
              2024-02-19 07:11:33.130 - info: zigbee.0 (3191297) 0x04cf8cdf3c867556 (addr 48621): ZNCZ04LM - Xiaomi Mi smart plug EU (Router)
              2024-02-19 07:11:33.130 - info: zigbee.0 (3191297) 0x04cf8cdf3c8a23ab (addr 51696): ZNCZ04LM - Xiaomi Mi smart plug EU (Router)
              2024-02-19 07:11:33.131 - info: zigbee.0 (3191297) 0x04cf8cdf3c8a26a5 (addr 24281): ZNCZ04LM - Xiaomi Mi smart plug EU (Router)
              2024-02-19 07:11:33.131 - info: zigbee.0 (3191297) 0x04cf8cdf3c8a28b4 (addr 59251): ZNCZ04LM - Xiaomi Mi smart plug EU (Router)
              2024-02-19 07:11:33.132 - info: zigbee.0 (3191297) 0x04cf8cdf3c8a2816 (addr 7676): ZNCZ04LM - Xiaomi Mi smart plug EU (Router)
              2024-02-19 07:11:33.132 - info: zigbee.0 (3191297) 0x04cf8cdf3c86766f (addr 31479): ZNCZ04LM - Xiaomi Mi smart plug EU (Router)
              2024-02-19 07:11:33.132 - info: zigbee.0 (3191297) 0x00158d000578d0a3 (addr 43507): WXKG01LM - Xiaomi Mi wireless switch (EndDevice)
              2024-02-19 07:11:33.133 - info: zigbee.0 (3191297) 0x54ef441000258d08 (addr 21943): SSM-U01 - Aqara Single switch module T1 (with neutral) (Router)
              2024-02-19 07:11:33.134 - info: zigbee.0 (3191297) 0xa4c1384d2dd219fb (addr 58682): A1Z - Nous Smart plug (with power monitoring) (Router)
              2024-02-19 07:11:33.135 - info: zigbee.0 (3191297) 0xa4c138881bae4f17 (addr 61921): A1Z - Nous Smart plug (with power monitoring) (Router)
              2024-02-19 07:11:33.136 - info: zigbee.0 (3191297) 0xa4c1388c55d55499 (addr 28397): ZY-M100-S_2 - TuYa Mini human breathe sensor (Router)
              2024-02-19 07:11:33.136 - info: zigbee.0 (3191297) 0xe0798dfffec98052 (addr 57772): ZBMINI - SONOFF Zigbee two way smart switch (Router)
              2024-02-19 07:11:33.138 - info: zigbee.0 (3191297) 0xa4c138528cff8d70 (addr 58500): ZY-M100-S_1 - TuYa Mini human breathe sensor (Router)
              2024-02-19 07:11:33.139 - info: zigbee.0 (3191297) 0x00158d0009ce28d9 (addr 20575): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
              2024-02-19 07:11:33.139 - info: zigbee.0 (3191297) 0x70b3d52b600151d7 (addr 15180): SM-0306E-2W - UseeLink 4 gang switch, with USB (Router)
              2024-02-19 07:11:33.140 - info: zigbee.0 (3191297) 0xa4c138421ad10f21 (addr 794): ZSS-HM-SSD01 - Moes Smoke sensor (EndDevice)
              2024-02-19 07:11:33.141 - info: zigbee.0 (3191297) 0xa4c138b86190bc77 (addr 30730): ZY-M100-24G - TuYa 24G MmWave radar human presence motion sensor (Router)
              2024-02-19 07:11:33.141 - info: zigbee.0 (3191297) 0x70ac08fffe5b0952 (addr 42729): HS1SA - HEIMAN Smoke detector (EndDevice)
              2024-02-19 07:11:33.142 - info: zigbee.0 (3191297) 0x60a423fffeed6f44 (addr 842): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
              2024-02-19 07:11:33.142 - info: zigbee.0 (3191297) Zigbee started
              2024-02-19 07:11:33.221 - info: zigbee.0 (3191297) debug devices set to []
                @latzi siht gut aus.. dann lern das ding nochmal an.. lösche es aber davor
                Latzi 2 Replies Last reply Reply Quote 0
                • Latzi
                  @arteck
                  puuuh, wir etwas dauern, hab´s schon in der Wand verbaut und sicherheitshalber einen Schrank davor gestellt 😉
                  Neuschwansteini 1 Reply Last reply Reply Quote 0
                  • Neuschwansteini
                    Neuschwansteini @Latzi last edited by Neuschwansteini
                    @latzi sagte in ZigBee neue Version 1.9.x:
                    @arteck
                    Bei mir bleiben neue Devices erstmal auf dem Schreibtisch liegen, bis se funktionieren, 2-4 Tage.
                    Dann gehts an den Ort, wo se installiert werden, provisorisch, ca mindestens ne Woche.
                    Treten dann immer noch keine Fehler auf, kann das Teil dann dahin eingebaut werden, aber so, dass man immer wieder dran kommt.
                    Und da ist es egal, ob das Zigbee, Wifi oder Ethernet ist, selbst bei letzteren zeigt die Erfahrung, dass nicht jeder Switch alle Vlan's haben muss oder das in Wirklichkeit so ist, wie es in der Config oder auf dem Plan aussieht... 🙂
                    • JackDaniel
                      JackDaniel last edited by JackDaniel
                      mal eine frage ob das bei mir nur so ist (adapter version 1.10.2)
                      lt. dem adapeter sind ota updates verfügbar, nur sehe ich nichts bei den kacheln wo ich das update starten könnte
                      current Firmware for 0x680ae2fffe419dac is 587761201 new is 604241939
                      Latzi P JackDaniel 3 Replies Last reply Reply Quote 0
                      • Latzi
                        Latzi @JackDaniel last edited by Latzi
                        @jackdaniel
                        hier drücken:
                        drück mal auf "Rollo Badezimmer", dann sollte die Kachel drehen und dann erscheint unten ein grüner Pfeil
                        JackDaniel 2 Replies Last reply Reply Quote 0
                        • JackDaniel
                          JackDaniel @Latzi last edited by
                          @jackdaniel
                          das ist der screenshot von der gedrehten kachel
                          • Latzi
                            @jackdaniel
                            stimmt, hab´s zu spät gesehen, hast du oben vorher auf den Button gedrückt (hab´s oben im Posting geändert)?
                            • JackDaniel
                              @jackdaniel
                              hier drücken:
                              hab ich doch auch schon gemacht, woher kommt wohl das hier -> current Firmware for 0x680ae2fffe419dac is 587761201 new is 604241939 😉
                              • Latzi
                                @jackdaniel
                                hmm, bin ratlos
                                  picky @JackDaniel last edited by picky
                                  Wenn es update gibt, dann ist das Symbol grün mit dem Pfeil, da dann drauf klicken 😉
                                  Wenn es kein update gibt sieht es ja so aus.2024-02-19 12.25.46 192.168.178.27 80f2bc0c873b.png
                                  • Latzi
                                    gelöscht und angelernt - leider gleicher Zustand 😞
                                    Hab beim suchen dieses issue gefunden, könnte es mit der Firmware des Sticks zusammenhängen?
                                    Mein CC2538+CC2592 ist ja nicht gerade der Frischeste 😉
                                      locito09 @Latzi last edited by locito09
                                      @latzi
                                      Stick updaten
                                      Bei mir läuft aktuell die 20230922 sehr zuverlässig
                                      • Latzi
                                        Latzi @locito09 last edited by
                                        @locito09
                                        Dazu fehlt mir die Kenntnis und das J-Link Equipment 😢
                                          @latzi die oben erwähnte Firmware ist nicht für deinen Stick. Poste mal Fotos von deinem Stick (Platine)
                                          • Latzi
                                            @dimaiv sagte in ZigBee neue Version 1.9.x:
                                            hier die Fotos von beiden Seiten, sollte dir bekannt vorkommen - hab ich Ende 2019 von dir bekommen 😉
                                            31.7k
                                            79.8k
                                            1.9 converter zhc zigbee
                                            28
                                            120
                                            14199
