Unifi Controller HTTP Status 404 – Not Found
@snopy_16 sagte in Unifi Controller HTTP Status 404 – Not Found:
Illegal reflective access by org.apache.catalina.loader.WebappClassLoaderBase (file:/usr/lib/unifi/lib/tomcat-embed-core-9.0.65.jar) to field
Wenn man danach sucht findet man einiges.
Auf welchem Stand ist denn dein 'immer mal' upgedatetes System?iob diagsagt dir das.
@thomas-braun sagte in Unifi Controller HTTP Status 404 – Not Found:
Ja, aber leider ist mein englisch fast nicht zu verwenden
iob diag
*** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Kernel : aarch64 Userland : arm64 Systemuptime and Load: 12:50:22 up 1:20, 3 users, load average: 0.60, 0.86, 1.13 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Tue 2024-02-20 12:50:22 CET Universal time: Tue 2024-02-20 11:50:22 UTC RTC time: n/a Time zone: Europe/Vienna (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker *** X-Server-Setup *** X-Server: true Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 7.8G 3.0G 3.5G 29M 1.3G 4.6G Swap: 99M 0B 99M Total: 7.9G 3.0G 3.6G 7812 M total memory 3023 M used memory 3414 M active memory 708 M inactive memory 3495 M free memory 87 M buffer memory 1206 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 13G 14G 49% / devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 1.6G 9.3M 1.6G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 253M 31M 222M 13% /boot tmpfs tmpfs 782M 20K 782M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Tue Feb 20 11:29:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=D8:3A:DD:59:9B:B3 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=96bb02d6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [Tue Feb 20 11:29:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none. [Tue Feb 20 11:29:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Tue Feb 20 11:29:36 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 2.9G /var/ 1.5G /var/lib 1.1G /var/cache/apt 1.1G /var/cache 936M /var/cache/apt/archives Archived and active journals take up 8.0M in the file system. /opt/iobroker/backups: 124M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.8G /opt/iobroker/iobroker-data/ 1.3G /opt/iobroker/iobroker-data/history 397M /opt/iobroker/iobroker-data/files 99M /opt/iobroker/iobroker-data/backup-objects 89M /opt/iobroker/iobroker-data/files/echarts.admin The five largest files in iobroker-data are: 24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map 24M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map 23M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map 22M /opt/iobroker/iobroker-data/objects.jsonl 22M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b4cc327b0745ec11aff094fd6f14af06-if00-port0 *** NodeJS-Installation *** /usr/bin/nodejs v18.19.1 /usr/bin/node v18.19.1 /usr/bin/npm 10.2.4 /usr/bin/npx 10.2.4 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.1-1nodesource1 Candidate: 18.19.1-1nodesource1 Version table: *** 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 12.22.12~dfsg-1~deb11u4 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages 500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.17 admin: 6.13.16 javascript: 7.8.0 Adapters from github: 2 Adapter State + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : raspberrypi - enabled + system.adapter.device-reminder.0 : device-reminder : raspberrypi - enabled + system.adapter.device-watcher.0 : device-watcher : raspberrypi - enabled + system.adapter.echarts.0 : echarts : raspberrypi - enabled + system.adapter.email.0 : email : raspberrypi - enabled + system.adapter.energiefluss.0 : energiefluss : raspberrypi - enabled + system.adapter.eventlist.0 : eventlist : raspberrypi - enabled + system.adapter.eventlist.1 : eventlist : raspberrypi - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : raspberrypi - enabled system.adapter.flot.0 : flot : raspberrypi - disabled + system.adapter.fronius.0 : fronius : raspberrypi - enabled + system.adapter.history.0 : history : raspberrypi - enabled system.adapter.ical.0 : ical : raspberrypi - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspberrypi - disabled + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.info.0 : info : raspberrypi - enabled + system.adapter.iqontrol.0 : iqontrol : raspberrypi - enabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled + system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.octoprint.0 : octoprint : raspberrypi - enabled + system.adapter.pushsafer.0 : pushsafer : raspberrypi - enabled + system.adapter.rpi2.0 : rpi2 : raspberrypi - enabled + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.snmp.0 : snmp : raspberrypi - enabled system.adapter.socketio.0 : socketio : raspberrypi - disabled, port: 9090, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : raspberrypi - enabled + system.adapter.statistics.0 : statistics : raspberrypi - enabled + system.adapter.trashschedule.0 : trashschedule : raspberrypi - enabled + system.adapter.tuya.0 : tuya : raspberrypi - enabled + system.adapter.upnp.0 : upnp : raspberrypi - enabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : raspberrypi - disabled system.adapter.vis-history.0 : vis-history : raspberrypi - disabled system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled system.adapter.vis-map.0 : vis-map : raspberrypi - disabled system.adapter.vis-rgraph.0 : vis-rgraph : raspberrypi - disabled system.adapter.vis.0 : vis : raspberrypi - enabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : raspberrypi - enabled + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b4cc327b0745ec11aff094fd6f14af06-if00-port0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b4cc327b0745ec11aff094fd6f14af06-if00-port0 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.13.16 , installed 6.13.16 Adapter "backitup" : 2.9.8 , installed 2.9.8 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.9.6 , installed 2.9.6 Adapter "echarts" : 1.7.2 , installed 1.7.2 Adapter "email" : 1.2.2 , installed 1.2.2 Adapter "energiefluss" : 3.6.0 , installed 3.6.0 Adapter "eventlist" : 2.0.0 , installed 2.0.0 Adapter "fb-checkpresence": 1.2.3 , installed 1.2.2 [Updatable] Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fronius" : 2.0.2 , installed 2.0.2 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iqontrol" : 2.3.0 , installed 2.3.0 Adapter "javascript" : 7.8.0 , installed 7.8.0 Controller "js-controller": 5.0.17 , installed 5.0.17 Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "octoprint" : 5.1.0 , installed 5.1.0 Adapter "pushsafer" : 1.0.3 , installed 1.0.3 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "shelly" : 6.6.1 , installed 6.6.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "snmp" : 3.1.0 , installed 3.1.0 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "statistics" : 2.4.0 , installed 2.4.0 Adapter "trashschedule": 2.3.0 , installed 2.3.0 Adapter "tuya" : 3.15.0 , installed 3.15.0 Adapter "upnp" : 1.0.21 , installed 1.0.21 Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-icontwo" : 1.3.0 , installed 1.3.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-map" : 1.0.4 , installed 1.0.4 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "web" : 6.2.3 , installed 6.2.3 Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3 Adapter "ws" : 2.5.10 , installed 2.5.10 Adapter "zigbee" : 1.10.1 , installed 1.10.1 Objects and States Please stand by - This may take a while Objects: 10959 States: 9320 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security bullseye-security InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 http://deb.debian.org/debian bullseye InRelease Hit:4 http://deb.debian.org/debian bullseye-updates InRelease Hit:5 http://giteduberger.fr rpimonitor/ InRelease Hit:6 https://packages.grafana.com/oss/deb stable InRelease Hit:7 https://repos.influxdata.com/debian stable InRelease Hit:8 https://repos.influxdata.com/debian bullseye InRelease Hit:9 https://deb.nodesource.com/node_18.x nodistro InRelease Hit:10 https://dl.ui.com/unifi/debian unifi-7.4 InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:27017 0.0.0.0:* LISTEN 117 16549 577/mongod tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12970 681/sshd: /usr/sbin tcp 0 0 0.0.0.0:8888 0.0.0.0:* LISTEN 0 13102 802/perl tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 17401 1557/iobroker.js-co tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 18360 1557/iobroker.js-co tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 16414 567/cupsd tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 116 2044 631/mosquitto tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 21342 2899/io.sonoff.0 tcp 0 0 0.0.0.0:5900 0.0.0.0:* LISTEN 0 15571 630/vncserver-x11-c tcp6 0 0 :::3000 :::* LISTEN 120 17172 1553/grafana tcp6 0 0 :::8000 :::* LISTEN 1001 446767 3550/io.upnp.0 tcp6 0 0 :::8086 :::* LISTEN 119 16973 597/influxd tcp6 0 0 :::8081 :::* LISTEN 1001 19281 2573/io.admin.0 tcp6 0 0 :::8080 :::* LISTEN 118 480432 26071/java tcp6 0 0 :::8082 :::* LISTEN 1001 31658 3636/io.web.0 tcp6 0 0 :::22 :::* LISTEN 0 12973 681/sshd: /usr/sbin tcp6 0 0 :::8443 :::* LISTEN 118 480443 26071/java tcp6 0 0 :::8843 :::* LISTEN 118 478174 26071/java tcp6 0 0 :::8880 :::* LISTEN 118 480433 26071/java tcp6 0 0 ::1:631 :::* LISTEN 0 16413 567/cupsd tcp6 0 0 :::1883 :::* LISTEN 116 2045 631/mosquitto tcp6 0 0 :::5900 :::* LISTEN 0 15570 630/vncserver-x11-c udp 0 0 0.0.0.0:51820 0.0.0.0:* 0 13008 - udp 0 0 0.0.0.0:48878 0.0.0.0:* 1001 31344 3425/io.snmp.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 14904 526/dhcpcd udp 0 0 0.0.0.0:49453 0.0.0.0:* 1001 32178 3550/io.upnp.0 udp 0 0 0.0.0.0:41326 0.0.0.0:* 1001 31343 3425/io.snmp.0 udp 0 0 0.0.0.0:631 0.0.0.0:* 0 14890 770/cups-browsed udp 0 0 0.0.0.0:54019 0.0.0.0:* 1001 32179 3550/io.upnp.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 1855 424/avahi-daemon: r udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 21320 2823/io.shelly.0 udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 32466 3550/io.upnp.0 udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 32465 3550/io.upnp.0 udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 32464 3550/io.upnp.0 udp 0 0 0.0.0.0:47126 0.0.0.0:* 108 1857 424/avahi-daemon: r udp 0 0 0.0.0.0:59784 0.0.0.0:* 1001 32177 3550/io.upnp.0 udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 21404 2924/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 21405 2924/io.tuya.0 udp6 0 0 :::51820 :::* 0 13009 - udp6 0 0 :::546 :::* 0 16538 526/dhcpcd udp6 0 0 :::46104 :::* 108 1858 424/avahi-daemon: r udp6 0 0 :::5353 :::* 108 1856 424/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-02-20 11:33:07.070 - info: tuya.0 (2924) 67334207807d3a73076a: Error on Reconnect (7): connect ECONNREFUSED 192.168.178.24:6668 2024-02-20 11:33:15.889 - info: tuya.0 (2924) bfce629f8925be1b3avd8x: Error on Reconnect (7): connect ECONNREFUSED 192.168.178.21:6668 2024-02-20 11:33:21.815 - info: tuya.0 (2924) bf2a002143d1aaa3d6pxdo: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.80:6668 2024-02-20 11:33:22.681 - info: tuya.0 (2924) bf6cb789979a05727fivhw: Error on Reconnect (7): connect ECONNREFUSED 192.168.178.51:6668 2024-02-20 11:33:24.375 - info: tuya.0 (2924) 703548358cce4ecf54fb: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.78:6668 2024-02-20 11:33:28.695 - info: tuya.0 (2924) bfd24a3dcc000234f1fdsz: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.50:6668 2024-02-20 11:33:30.423 - info: tuya.0 (2924) 10801581f4cfa202a51c: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.45:6668 2024-02-20 11:33:32.119 - info: tuya.0 (2924) 10801581f4cfa202a6a2: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.78:6668 2024-02-20 11:33:33.495 - info: tuya.0 (2924) 27051506b4e62d57b7e7: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.60:6668 2024-02-20 11:33:36.471 - info: tuya.0 (2924) 70354835e09806164458: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.79:6668 2024-02-20 11:33:38.040 - info: tuya.0 (2924) 703384143c6105ebb2c8: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.55:6668 2024-02-20 11:49:34.513 - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36 2024-02-20 11:49:50.081 - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36 2024-02-20 11:49:53.101 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json" 2024-02-20 12:02:00.240 - info: javascript.0 (2693) script.js.Mein_Ordner.Fronius0: Solarweb Token erstellt 2024-02-20 12:03:00.162 - warn: zigbee.0 (2958) DeviceAvailability:Stopping to ping 0xa4c1387a9c41346d TS011F after 4 ping attempts 2024-02-20 12:03:00.710 - warn: zigbee.0 (2958) DeviceAvailability:Stopping to ping 0xa4c1382e5d9115bd TS011F after 4 ping attempts 2024-02-20 12:21:33.640 - info: admin.0 (2573) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin 2024-02-20 12:21:33.653 - info: admin.0 (2573) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin 2024-02-20 12:21:33.656 - info: admin.0 (2573) <== Disconnect system.user.admin from ::ffff:192.168.178.36 2024-02-20 12:30:01.890 - info: sourceanalytix.0 (3464) Device reset detected for mqtt.0.EASY-ESP32-02.Heizöl_MW.Liter_MW, feature disabled processing normally) 2024-02-20 12:34:21.995 - info: sourceanalytix.0 (3464) Device reset detected for mqtt.0.EASY-ESP32-02.Heizöl.Liter, feature disabled processing normally) 2024-02-20 12:34:22.134 - info: sourceanalytix.0 (3464) Device reset detected for mqtt.0.EASY-ESP32-02.Heizöl_MW.Liter_MW, feature disabled processing normally) 2024-02-20 12:49:09.157 - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36 2024-02-20 12:49:09.173 - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36 -
630/vncserver-x11-c
Schalt den Desktop-Mumpitz und damit auch den vnc-Mist aus.
Zum Problem: Könnte sein, dass die verwendete Datenbank zu alt ist.
Ich hab aber keine Ahnung, ob eine Neuinstallation von Raspberry OS 'Bookworm' da aktuelleres mit bringt.Und die Quelle
würde ich auch rauskicken, wenn du nicht weißt warum die drin ist.
influxdb hast du doppelt drin. -
wie kann ich das rauskicken und kann ich auch die 2. influx kicken (Welche?) -
sudo systemctl set-default multi-user.target
pi@raspberrypi:~ $ sudo systemctl set-default multi-user.target Removed /etc/systemd/system/default.target. Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.pi@raspberrypi:~ $ ls -lAh /etc/apt/sources.list.d/ insgesamt 28K -rw-r--r-- 1 root root 137 22. Sep 17:19 100-ubnt-unifi.list -rw-r--r-- 1 root root 53 29. Okt 17:30 grafana.list -rw-r--r-- 1 root root 117 24. Okt 17:24 influxdata.list -rw-r--r-- 1 root root 56 24. Okt 17:07 influxdb.list -rw-r--r-- 1 root root 100 24. Okt 15:37 nodesource.list -rw-r--r-- 1 root root 191 3. Mai 2023 raspi.list -rw-r--r-- 1 root root 73 24. Okt 10:47 rpimonitor.list -
sudo rm /etc/apt/sources.list.d/rpimonitor.list sudo rm /etc/apt/sources.list.d/influxdb.list sudo apt update -
so ok ?pi@raspberrypi:~ $ ls -lAh /etc/apt/sources.list.d/ insgesamt 20K -rw-r--r-- 1 root root 137 22. Sep 17:19 100-ubnt-unifi.list -rw-r--r-- 1 root root 53 29. Okt 17:30 grafana.list -rw-r--r-- 1 root root 117 24. Okt 17:24 influxdata.list -rw-r--r-- 1 root root 100 24. Okt 15:37 nodesource.list -rw-r--r-- 1 root root 191 3. Mai 2023 raspi.listUnifi - Problem hab ich noch nicht gelöst
sudo apt update
pi@raspberrypi:~ $ sudo apt update OK:1 http://security.debian.org/debian-security bullseye-security InRelease OK:2 http://deb.debian.org/debian bullseye InRelease OK:3 http://deb.debian.org/debian bullseye-updates InRelease OK:4 https://repos.influxdata.com/debian stable InRelease OK:5 https://packages.grafana.com/oss/deb stable InRelease OK:6 https://deb.nodesource.com/node_18.x nodistro InRelease OK:7 https://dl.ui.com/unifi/debian unifi-7.4 InRelease OK:8 http://archive.raspberrypi.org/debian bullseye InRelease Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Alle Pakete sind aktuell.Ich glaub das ist so in Ordnung?
Ja, passt.
@thomas-braun Danke
Hier wirst du doch bestimmt fündig für die Fälle des Installierens und Update.
