    4. Hosts update 5.0.19 Problem
    • Krisiun
      Krisiun @Thomas Braun last edited by
      @thomas-braun sagte in Hosts update 5.0.19 Problem:
      @krisiun sagte in Hosts update 5.0.19 Problem:
      Wenn ich wieder probleme bekommen sollte dann mache ich das mal.
      Mach es JETZT und verwende ein Linux so wie es vorgesehen ist: Mit einem user und NICHT per root.
      Und wie mache ich das bitte schön ?
      • Krisiun
        Wenn ich versuche einen Backup zu machen kommt das
        Started iobroker ...
        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Krisiun,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.128/Synology 215j-6TB/IOBroker-Backup /opt/iobroker/backups"
        [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Krisiun,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.128/Synology 215j-6TB/IOBroker-Backup /opt/iobroker/backups"
        [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Krisiun,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.128/Synology 215j-6TB/IOBroker-Backup /opt/iobroker/backups
        mount: bad usage
        Try 'mount --help' for more information.
        [DEBUG] [mount] - Error: Command failed: sudo mount -t cifs -o username=Krisiun,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.128/Synology 215j-6TB/IOBroker-Backup /opt/iobroker/backups
        mount: bad usage
        [DEBUG] [iobroker] - host.Marek2 5739 states saved
        [DEBUG] [iobroker] - host.Marek2 6619 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2024_02_20-20_38_58_backupiobroker.tar.gz
        [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
        [DEBUG] [iobroker] - done
        [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
        [DEBUG] [javascripts] - found Script: Finde_Kato
        [DEBUG] [javascripts] - found Script: Saugereinstellungen
        [DEBUG] [javascripts] - found Script: Saugersteuerung_mit_Alexa
        [DEBUG] [javascripts] - found Script: Waschmaschiene
        [DEBUG] [javascripts] - found Script: Staubsauger
        [DEBUG] [javascripts] - found Script: VU+Uno_4K_SE
        [DEBUG] [javascripts] - found Script: Fenseher
        [DEBUG] [javascripts] - found Script: TV_Box
        [DEBUG] [javascripts] - found Script: Lampe
        [DEBUG] [javascripts] - found Script: Skript_1_Saugersteuerung_mit_Alexa
        [DEBUG] [javascripts] - found Script: Skript_2_Saugereinstellungen
        [DEBUG] [javascripts] - found Script: Waschmaschine
        [DEBUG] [javascripts] - found Script: Fensterkontakt_Balkon
        [DEBUG] [javascripts] - found Script: Fensterkontakt_Schlafzimmer
        [DEBUG] [javascripts] - found Script: Fensterkontakt_Badezimmer
        [DEBUG] [javascripts] - found Script: Fensterkontakt_Kleineszimmer
        [DEBUG] [javascripts] - found Script: Fensterstatus1
        [DEBUG] [javascripts] - found Script: Abfrage_Fensterstatus
        [DEBUG] [javascripts] - found Script: Fenster_Alias
        [DEBUG] [javascripts] - found Script: Fensterscript_für_faule_leute_die_nicht_lernen_wollen
        [DEBUG] [javascripts] - found Script: Festnetz
        [DEBUG] [javascripts] - found Script: Fensterkontakt_Küche
        [DEBUG] [javascripts] - found Script: Fernseher
        [DEBUG] [javascripts] - found Script: Saugroboter
        [DEBUG] [javascripts] - found Script: Waschmaschine_Alexa
        [DEBUG] [javascripts] - found Script: TV_BOX_NEU_
        [DEBUG] [javascripts] - found Script: VU+Fernseher
        [DEBUG] [javascripts] - found Script: VU+Test_Neu
        [DEBUG] [javascripts] - found Script: Abwesenheit_Marek
        [DEBUG] [javascripts] - found Script: Abwesenheit_Johanna
        [DEBUG] [javascripts] - found Script: Adapter_Updates_2
        [DEBUG] [javascripts] - found Script: Geofency
        [DEBUG] [javascripts] - found Script: Geofency_Marek
        [DEBUG] [javascripts] - found Script: Geofency_Johanna
        [DEBUG] [javascripts] - found Script: Fenster_Schlafzimmer-Telegram
        [DEBUG] [javascripts] - found Script: Fenster_Küche-Telegram
        [DEBUG] [javascripts] - found Script: Fenster_Kleineszimmer-Telegram
        [DEBUG] [javascripts] - found Script: Fenster_Bad-Telegram
        [DEBUG] [javascripts] - found Script: Fenster_Baklon-Telegram
        [DEBUG] [javascripts] - found Script: FernseherNeu
        [DEBUG] [javascripts] - found Script: arminTest
        [DEBUG] [javascripts] - found Script: Spritpreis
        [DEBUG] [javascripts] - found Script: AlleTankstellenPreiseDiesel
        [DEBUG] [javascripts] - found Script: AlleTankstellenPreiseBenzin
        [DEBUG] [javascripts] - found Script: Benzin
        [DEBUG] [javascripts] - found Script: Diesel
        [DEBUG] [javascripts] - found Script: Briefkasten
        [DEBUG] [javascripts] - found Script: Festnetztelefon
        [DEBUG] [javascripts] - found Script: Johanna_Abwesenheit
        [DEBUG] [javascripts] - found Script: Mareks_Abwesenheit
        [DEBUG] [javascripts] - found Script: Stumm_Schaltung
        [DEBUG] [javascripts] - found Script: TV_Stummschallten
        [DEBUG] [javascripts] - found Script: Tel_TV_Stumm
        [DEBUG] [javascripts] - found Script: Batterie_Status
        [DEBUG] [javascripts] - found Script: Batteriestatus_Abfrage
        [DEBUG] [javascripts] - found Script: Schlafzimmertemperatur
        [DEBUG] [javascripts] - found Script: Benzinpreis
        [DEBUG] [javascripts] - found Script: Dieselpreis
        [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
        [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
        [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2024_02_20-20_39_06_backupiobroker.tar.gz
        [DEBUG] [javascripts] - done
        [DEBUG] [cifs] - used copy path: /Synology 215j-6TB/IOBroker-Backup
        [DEBUG] [cifs] - done
        [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
        [DEBUG] [clean] - done
        [DEBUG] [telegram] - done
        [DEBUG] [historyHTML] - new history html values created
        [DEBUG] [historyHTML] - done
        [DEBUG] [historyJSON] - new history json values created
        [DEBUG] [historyJSON] - done
        Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Krisiun last edited by Thomas Braun
          @krisiun
          Viel lesen:
          https://wiki.ubuntuusers.de/Startseite/
          https://wiki.ubuntuusers.de/Erste_Schritte/
          Krisiun 1 Reply Last reply Reply Quote 0
          • Krisiun
            Stimmt, da ist echt viel zum Lesen 🙂
              @krisiun
              Dann solltest du das tun.
              Krisiun 2 Replies Last reply Reply Quote 0
              • Krisiun
                Mache ich auch. Nur das ist nicht in 10 min getan.
                Da braucht man Zeit.
                Vielen Dank für die Infos
                  Das ist korrekt. Die Zeit für die Grundlagen/Erste Schritte muss man sich schon nehmen. Sonst rennst du immer wieder vor die Wand.
                  • Krisiun
                    Ich verstehe aber trotzdem nicht warum das Backup nicht klappt.
                    Habe alles so eingestellt wie auf meiner RP installation wo das Backup tatenlos funktioniert.
                      Leerzeichen in Verzeichnisnamen sind auch 'verboten'. Führen nämlich zu dem Verhalten da bei dir.
                      Krisiun Homoran 2 Replies Last reply Reply Quote 0
                      • Krisiun
                        Ich habe das leerzeichen weggenommen aber leider das gleiche Problem
                          ich fürchte das ist kein Dateiname, sonder der falsch angegebene Share
                            @krisiun
                            Und du hampelst da weiter als root herum? Dann bin ich nämlich eh raus.
                            Lies dir an, wie man user anlegt und mit denen agiert.
                            • Krisiun
                              Krisiun @Homoran last edited by
                              Ich habe da alles so angegeben wie auch bei meiner funktionierende Backup aktion
                              • Krisiun
                                Das haben wir doch bei meinem letzten Problem schon behoben. Keine Ahnung warum sich da was geändert hat.
                                Wie mache ich das schnell wieder in Ordnung? Bitte
                                  Was?
                                  • Krisiun
                                    Wie man schnell der root los werden kann
                                      @krisiun
                                      Ich werde dir jetzt nicht das Wiki vorlesen...
                                      Link haste, setzt dich hin und lies.
                                      Krisiun 2 Replies Last reply Reply Quote 1
                                      • Krisiun
                                        OK. Hast du recht.
                                        Viele Dank
                                        • Krisiun
                                          @krisiun
                                          Hi ich bin jetzt den root los aber backup geht trotzdem nicht.
                                          Immer der gleiche Fehler.
                                          [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Krisiun,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.2/homes/iobroker-ubuntu-backup /opt/iobroker/backups
                                          mount error: cifs filesystem not supported by the system
                                          mount error(19): No such device
                                          Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                          [DEBUG] [mount] - Error: Command failed: sudo mount -t cifs -o username=Krisiun,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.2/homes/iobroker-ubuntu-backup /opt/iobroker/backups
                                            @krisiun
                                            Du hast da wohl was falsch eingestellt. Zeig mal die Einstellungen aus dem Backitup-Adapter.
                                            2764
