    4. Teilweise über 200% CPU Auslastung im Docker
    • DJMarc75
      DJMarc75 @Dr.Pie last edited by
      @dr-pie sagte in Teilweise über 200% CPU Auslastung im Docker:
      iob diag läuft schon
      und die Ausgabe in Codetags wäre interessant zu sehen 😉
      Dr.Pie 1 Reply Last reply Reply Quote 0
      • Dr.Pie
        Dr.Pie @DJMarc75 last edited by
        @djmarc75 ```
        Copy text starting here:
                                v.2023-10-10
        model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v8.0.1
        Installation:           Docker
        Kernel:                 x86_64
        Userland:               amd64
        Timezone:               Etc/UTC
        User-ID:                0
        X-Server:               false
        Pending OS-Updates:     28
        /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                throw e;
        Error: Connection is closed.
            at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
            at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
            at Object.onceWrapper (node:events:629:26)
            at Socket.emit (node:events:514:28)
            at TCP.<anonymous> (node:net:323:12)
        Emitted 'error' event on ScanStream instance at:
            at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
            at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
            at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
            at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        Node.js v18.17.1
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                /usr/bin/node           v18.17.1
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
                                /usr/bin/corepack       0.18.0
        Recommended versions are nodejs 18.19.1 and npm 10.2.4
        MEMORY:
        Mem:            7.8G        5.4G        539M        119M        1.9G        2.0G
        Swap:           6.7G         34M        6.7G
        Total:           14G        5.4G        7.2G
        Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
            at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:493:23)
        Active iob-Instances:   0
         Unable to subscribe to meta namespace "meta." changes: Connection is closed.
        ioBroker Core:          js-controller           5.0.17
                                admin                   6.13.16
        ioBroker Status:         Connection is closed.
         Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
        Objects:                0
        States:                 0
        Size of iob-Database:
        26M     /opt/iobroker/iobroker-data/objects.jsonl
        4.5M    /opt/iobroker/iobroker-data/states.jsonl
        Die lange Version ginge natürlich auch ... hab ich aber verpasst 😊
        • DJMarc75
          und die wäre schön zu sehen 😉
          Mach halt nochmal - und am Ende keine Taste drücken
          • OliverIO
            OliverIO @Dr.Pie last edited by
            @dr-pie
            Du kannst top auch auf der console aufrufen.
            Also dort wo du auch iob diag eingegeben hast
            • Dr.Pie
              Dr.Pie @OliverIO last edited by
              @oliverio sagte in Teilweise über 200% CPU Auslastung im Docker:
              @dr-pie
              top - 15:47:27 up 20:46,  0 users,  load average: 2,47, 2,94, 2,96
              Tasks:  25 total,   2 running,  23 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 51,3 us,  5,0 sy,  0,0 ni, 42,9 id,  0,0 wa,  0,0 hi,  0,8 si,  0,0 st
              MiB Mem :   7802,0 total,    408,3 free,   5502,6 used,   1891,1 buff/cache
              MiB Swap:   6731,9 total,   6697,0 free,     34,9 used.   1883,2 avail Mem
                PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                174 iobroker  20   0   11,6g 804244  46096 R  96,3  10,1   1261:46 iobroker.js-con
                679 iobroker  20   0 1944184   1,1g  40092 S  94,0  14,8 717:46.89 io.device-watch
                450 iobroker  20   0 1718048 887868  39948 S   9,3  11,1 156:07.51 io.shelly.1
                366 iobroker  20   0 1002892 147496  39836 S   8,0   1,8  52:05.24 io.shelly.0
                224 iobroker  20   0 1184844 346172  45832 S   3,7   4,3  53:28.79 io.javascript.0
                262 iobroker  20   0  967956 113200  39712 S   1,7   1,4  21:30.92 io.influxdb.0
                196 iobroker  20   0 1089088 215252  46868 S   0,7   2,7  10:16.87 iobroker.js-con
              29287 iobroker  20   0  948668  85048  45784 S   0,7   1,1   0:05.22 io.fullybrowser
                243 iobroker  20   0  991452 104484  38776 S   0,3   1,3   4:07.28 io.sql.0
                492 iobroker  20   0   20,9g 104416  46372 S   0,3   1,3   0:37.12 io.backitup.0
                565 iobroker  20   0  955132  89356  39968 S   0,3   1,1   2:52.76 io.denon.0
                610 iobroker  20   0   10,9g 108868  39816 S   0,3   1,4   6:46.13 io.heos.0
                668 iobroker  20   0   10,9g 122508  40756 S   0,3   1,5   9:36.75 io.fb-checkpres
                  1 root      20   0    7364   3120   3120 S   0,0   0,0   0:00.04 bash
                381 iobroker  20   0   10,9g 103092  40088 S   0,0   1,3   1:24.17 io.synology.1
                392 iobroker  20   0   10,9g 102880  40320 S   0,0   1,3   1:26.84 io.synology.2
                407 iobroker  20   0  831736 103904  45672 S   0,0   1,3   7:35.23 io.tr-064.0
                435 iobroker  20   0  832248 106664  45752 S   0,0   1,3  19:54.27 io.tr-064.1
                465 iobroker  20   0  821636  82804  39872 S   0,0   1,0   0:34.42 io.discovery.0
                507 iobroker  20   0 1024264 164200  40988 S   0,0   2,1   8:10.61 io.web.0
                595 iobroker  20   0  960016  84900  39880 S   0,0   1,1   0:51.34 io.harmony.0
                634 iobroker  20   0 1088292 235916  40952 S   0,0   3,0   1:17.81 io.tankerkoenig
                653 iobroker  20   0  971976 116388  45876 S   0,0   1,5   1:43.31 io.wled.0
              32314 root      20   0    7496   3840   3408 S   0,0   0,0   0:00.00 bash
              32329 root      20   0   10296   3584   3112 R   0,0   0,0   0:00.03 top
              • Dr.Pie
                @djmarc75 sagte in Teilweise über 200% CPU Auslastung im Docker:
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                Hardware Vendor : Synology
                Kernel          : x86_64
                Userland        : amd64
                Docker          : v8.0.1
                Virtualization  : Docker
                Kernel          : x86_64
                Userland        : amd64
                Systemuptime and Load:
                 15:50:36 up 20:49,  0 users,  load average: 3.28, 3.01, 2.98
                CPU threads: 4
                *** Time and Time Zones ***
                Thu Feb 22 14:50:36 UTC 2024
                Thu Feb 22 15:50:36 CET 2024
                CET +0100
                Etc/UTC
                *** User and Groups ***
                root
                /root
                root
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:            7.8G        5.3G        590M        120M        1.9G        2.1G
                Swap:           6.7G         34M        6.7G
                Total:           14G        5.4G        7.3G
                         7802 M total memory
                         5319 M used memory
                         4777 M active memory
                         1528 M inactive memory
                          590 M free memory
                           38 M buffer memory
                         1854 M swap cache
                         6731 M total swap
                           34 M used swap
                         6697 M free swap
                *** FILESYSTEM ***
                Filesystem             Type   Size  Used Avail Use% Mounted on
                /dev/mapper/cachedev_4 btrfs  3.5T  2.0T  1.6T  56% /
                tmpfs                  tmpfs   64M     0   64M   0% /dev
                tmpfs                  tmpfs  3.9G     0  3.9G   0% /sys/fs/cgroup
                shm                    tmpfs   64M     0   64M   0% /dev/shm
                /dev/mapper/cachedev_4 btrfs  3.5T  2.0T  1.6T  56% /opt/iobroker
                /dev/mapper/cachedev_4 btrfs  3.5T  2.0T  1.6T  56% /etc/hosts
                tmpfs                  tmpfs  3.9G     0  3.9G   0% /proc/acpi
                tmpfs                  tmpfs  3.9G     0  3.9G   0% /proc/scsi
                tmpfs                  tmpfs  3.9G     0  3.9G   0% /sys/firmware
                sudo: unable to resolve host iobroker: Name or service not known
                [Wed Feb 21 19:01:19 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
                [Wed Feb 21 19:01:19 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
                [Wed Feb 21 19:01:19 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
                [Wed Feb 21 19:01:25 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
                [Wed Feb 21 19:01:25 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
                [Wed Feb 21 19:01:25 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
                TARGET             SOURCE        FSTYPE OPTIONS
                /                  /dev/mapper/cachedev_4[/@syno/@docker/btrfs/subvolumes/2082bc39f93f33f788e3c7fa290317a1b738ac8cf85a4217a83d22a38aceec36]       btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=724572,subvol=/@syno/@docker/btrfs/subvolumes/2082bc39f93f33f788e3c7fa290317a1b738ac8cf85a4217a83d22a38aceec36
                |-/opt/iobroker    /dev/mapper/cachedev_4[/@syno/docker/iobroker]        btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=724400,subvol=/@syno/docker
                |-/etc/resolv.conf /dev/mapper/cachedev_4[/@syno/@docker/containers/0450185fc3ce5afab5101aa2eabbba0a1f80981592975fc06d13c4fc7271dbd6/resolv.conf] btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
                |-/etc/hostname    /dev/mapper/cachedev_4[/@syno/@docker/containers/0450185fc3ce5afab5101aa2eabbba0a1f80981592975fc06d13c4fc7271dbd6/hostname]    btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
                `-/etc/hosts       /dev/mapper/cachedev_4[/@syno/@docker/containers/0450185fc3ce5afab5101aa2eabbba0a1f80981592975fc06d13c4fc7271dbd6/hosts]       btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
                /var:
                33M     /var/
                31M     /var/lib
                18M     /var/lib/apt/lists
                18M     /var/lib/apt
                13M     /var/lib/dpkg
                /opt/iobroker/backups:
                3.2G    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                498M    /opt/iobroker/iobroker-data/
                363M    /opt/iobroker/iobroker-data/files
                137M    /opt/iobroker/iobroker-data/files/vis-2
                94M     /opt/iobroker/iobroker-data/backup-objects
                78M     /opt/iobroker/iobroker-data/files/vis-2/static
                22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                18M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e642d05b.js.map
                18M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.2b7aff38.js.map
                18M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
                USB-Devices by-id:
                *** NodeJS-Installation ***
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                nodejs:
                  Installed: 18.17.1-deb-1nodesource1
                  Candidate: 18.17.1-deb-1nodesource1
                  Version table:
                 *** 18.17.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                        100 /var/lib/dpkg/status
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://deb.debian.org/debian bullseye/main amd64 Packages
                        500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                 Cannot determine Lua scripts strategy: Connection is closed. ["cfg.o.system.host.iobroker"]
                No connection to databases possible ...
                Core adapters versions
                js-controller:  5.0.17
                admin:          6.13.16
                javascript:     7.8.0
                Adapters from github:   3
                Adapter State
                        throw e;
                Node.js v18.17.1
                ioBroker-Repositories
                        throw e;
                Node.js v18.17.1
                Installed ioBroker-Instances
                Objects and States
                Objects:        3
                States:         3
                Hit:1 http://deb.debian.org/debian bullseye InRelease
                Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                Reading package lists...
                Pending Updates: 28
                *** Listening Ports ***
                tcp        0      0 192.168.178.203:8081    0.0.0.0:*               LISTEN      1000       134867     -
                tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      297536     82661      -
                tcp        0      0 192.168.178.203:8082    0.0.0.0:*               LISTEN      1000       145247     -
                tcp        0      0 172.17.0.1:53           0.0.0.0:*               LISTEN      115492     103340     -
                tcp        0      0 172.17.0.1:53           0.0.0.0:*               LISTEN      115492     103339     -
                tcp        0      0 172.17.0.1:53           0.0.0.0:*               LISTEN      115492     103338     -
                tcp        0      0 172.17.0.1:53           0.0.0.0:*               LISTEN      115492     103337     -
                tcp        0      0 169.254.241.18:53       0.0.0.0:*               LISTEN      115492     76525      -
                tcp        0      0 169.254.241.18:53       0.0.0.0:*               LISTEN      115492     76524      -
                tcp        0      0 169.254.241.18:53       0.0.0.0:*               LISTEN      115492     76523      -
                tcp        0      0 169.254.241.18:53       0.0.0.0:*               LISTEN      115492     76522      -
                tcp        0      0 192.168.178.203:53      0.0.0.0:*               LISTEN      115492     76517      -
                tcp        0      0 192.168.178.203:53      0.0.0.0:*               LISTEN      115492     76516      -
                tcp        0      0 192.168.178.203:53      0.0.0.0:*               LISTEN      115492     76515      -
                tcp        0      0 192.168.178.203:53      0.0.0.0:*               LISTEN      115492     76514      -
                tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      115492     78686      -
                tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      115492     78688      -
                tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      115492     78687      -
                tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      115492     78685      -
                tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      0          54769      -
                tcp        0      0 0.0.0.0:662             0.0.0.0:*               LISTEN      0          36461      -
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          31027      -
                tcp        0      0 127.0.0.1:40247         0.0.0.0:*               LISTEN      297536     97536      -
                tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN      0          59416      -
                tcp        0      0 127.0.0.1:38008         0.0.0.0:*               LISTEN      0          110742     -
                tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      297536     98173      -
                tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         71637      -
                tcp        0      0 127.0.0.1:33304         0.0.0.0:*               LISTEN      0          34158      -
                tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      115492     78695      -
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       145106     -
                tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          47395      -
                tcp        0      0 0.0.0.0:892             0.0.0.0:*               LISTEN      0          36195      -
                tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          53837      -
                tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          114413     -
                tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          55954      -
                tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0          45472      -
                tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN      0          106312     -
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       135803     -
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       131823     -
                tcp        0      0 0.0.0.0:873             0.0.0.0:*               LISTEN      0          54571      -
                tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          47391      -
                tcp        0      0 127.0.0.1:38443         0.0.0.0:*               LISTEN      0          110744     -
                tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          53838      -
                tcp        0      0 0.0.0.0:5003            0.0.0.0:*               LISTEN      0          47389      -
                tcp        0      0 0.0.0.0:4045            0.0.0.0:*               LISTEN      0          55976      -
                tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          49341      -
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          22207      -
                tcp        0      0 0.0.0.0:32400           0.0.0.0:*               LISTEN      297536     82659      -
                tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          47393      -
                tcp6       0      0 2a02:8109:2740:2e30::53 :::*                    LISTEN      115492     172337     -
                tcp6       0      0 2a02:8109:2740:2e30::53 :::*                    LISTEN      115492     172336     -
                tcp6       0      0 2a02:8109:2740:2e30::53 :::*                    LISTEN      115492     172335     -
                tcp6       0      0 2a02:8109:2740:2e30::53 :::*                    LISTEN      115492     172334     -
                tcp6       0      0 fe80::211:32ff:fe9b::53 :::*                    LISTEN      115492     78692      -
                tcp6       0      0 fe80::211:32ff:fe9b::53 :::*                    LISTEN      115492     78691      -
                tcp6       0      0 fe80::211:32ff:fe9b::53 :::*                    LISTEN      115492     78690      -
                tcp6       0      0 fe80::211:32ff:fe9b::53 :::*                    LISTEN      115492     78689      -
                tcp6       0      0 ::1:53                  :::*                    LISTEN      115492     76533      -
                tcp6       0      0 ::1:53                  :::*                    LISTEN      115492     76532      -
                tcp6       0      0 ::1:53                  :::*                    LISTEN      115492     76531      -
                tcp6       0      0 ::1:53                  :::*                    LISTEN      115492     76530      -
                tcp6       0      0 :::21                   :::*                    LISTEN      0          54770      -
                tcp6       0      0 :::8086                 :::*                    LISTEN      1000       130412     -
                tcp6       0      0 :::662                  :::*                    LISTEN      0          36466      -
                tcp6       0      0 :::22                   :::*                    LISTEN      0          31034      -
                tcp6       0      0 :::631                  :::*                    LISTEN      0          59417      -
                tcp6       0      0 :::3000                 :::*                    LISTEN      472        124181     -
                tcp6       0      0 ::1:38008               :::*                    LISTEN      0          110743     -
                tcp6       0      0 :::443                  :::*                    LISTEN      0          47396      -
                tcp6       0      0 :::892                  :::*                    LISTEN      0          36199      -
                tcp6       0      0 :::445                  :::*                    LISTEN      0          53835      -
                tcp6       0      0 :::3261                 :::*                    LISTEN      0          48771      -
                tcp6       0      0 :::5566                 :::*                    LISTEN      0          77124      -
                tcp6       0      0 :::3263                 :::*                    LISTEN      0          49871      -
                tcp6       0      0 :::3264                 :::*                    LISTEN      0          49873      -
                tcp6       0      0 :::2049                 :::*                    LISTEN      0          55966      -
                tcp6       0      0 :::3265                 :::*                    LISTEN      0          51895      -
                tcp6       0      0 :::6690                 :::*                    LISTEN      0          106313     -
                tcp6       0      0 :::515                  :::*                    LISTEN      0          58487      -
                tcp6       0      0 :::61991                :::*                    LISTEN      1000       148897     -
                tcp6       0      0 :::6281                 :::*                    LISTEN      0          90992      -
                tcp6       0      0 :::873                  :::*                    LISTEN      0          54572      -
                tcp6       0      0 :::5001                 :::*                    LISTEN      0          47392      -
                tcp6       0      0 ::1:38443               :::*                    LISTEN      0          110745     -
                tcp6       0      0 :::139                  :::*                    LISTEN      0          53836      -
                tcp6       0      0 :::5003                 :::*                    LISTEN      0          47390      -
                tcp6       0      0 :::4045                 :::*                    LISTEN      0          55978      -
                tcp6       0      0 :::5357                 :::*                    LISTEN      0          49342      -
                tcp6       0      0 :::111                  :::*                    LISTEN      0          22210      -
                tcp6       0      0 :::80                   :::*                    LISTEN      0          47394      -
                udp        0      0 0.0.0.0:55696           0.0.0.0:*                           1000       151886     -
                udp        0      0 127.0.0.1:55957         0.0.0.0:*                           297536     96010      -
                udp        0      0 0.0.0.0:56016           0.0.0.0:*                           1000       142224     -
                udp        0      0 0.0.0.0:56346           0.0.0.0:*                           0          22206      -
                udp        0      0 0.0.0.0:44094           0.0.0.0:*                           1000       141012     -
                udp        0      0 0.0.0.0:56769           0.0.0.0:*                           1000       136498     -
                udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         36872      -
                udp        0      0 0.0.0.0:32410           0.0.0.0:*                           297536     96004      -
                udp        0      0 0.0.0.0:32412           0.0.0.0:*                           297536     96005      -
                udp        0      0 0.0.0.0:32413           0.0.0.0:*                           297536     96006      -
                udp        0      0 0.0.0.0:32414           0.0.0.0:*                           297536     96003      -
                udp        0      0 0.0.0.0:44880           0.0.0.0:*                           1000       138310     -
                udp        0      0 0.0.0.0:53169           0.0.0.0:*                           0          35295      -
                udp        0      0 0.0.0.0:4045            0.0.0.0:*                           0          55975      -
                udp        0      0 0.0.0.0:49146           0.0.0.0:*                           1000       135059     -
                udp        0      0 172.17.0.1:53           0.0.0.0:*                           115492     103335     -
                udp        0      0 172.17.0.1:53           0.0.0.0:*                           115492     103336     -
                udp        0      0 172.17.0.1:53           0.0.0.0:*                           115492     103334     -
                udp        0      0 172.17.0.1:53           0.0.0.0:*                           115492     103333     -
                udp        0      0 169.254.241.18:53       0.0.0.0:*                           115492     76521      -
                udp        0      0 169.254.241.18:53       0.0.0.0:*                           115492     76520      -
                udp        0      0 169.254.241.18:53       0.0.0.0:*                           115492     76519      -
                udp        0      0 169.254.241.18:53       0.0.0.0:*                           115492     76518      -
                udp        0      0 192.168.178.203:53      0.0.0.0:*                           115492     76513      -
                udp        0      0 192.168.178.203:53      0.0.0.0:*                           115492     76512      -
                udp        0      0 192.168.178.203:53      0.0.0.0:*                           115492     76511      -
                udp        0      0 192.168.178.203:53      0.0.0.0:*                           115492     76510      -
                udp        0      0 127.0.0.1:53            0.0.0.0:*                           115492     78684      -
                udp        0      0 127.0.0.1:53            0.0.0.0:*                           115492     78683      -
                udp        0      0 127.0.0.1:53            0.0.0.0:*                           115492     78682      -
                udp        0      0 127.0.0.1:53            0.0.0.0:*                           115492     78681      -
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          29720      -
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          22205      -
                udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          36521      -
                udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          170893     -
                udp        0      0 192.168.178.203:137     0.0.0.0:*                           0          170892     -
                udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          171950     -
                udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          170895     -
                udp        0      0 192.168.178.203:138     0.0.0.0:*                           0          170894     -
                udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          171951     -
                udp        0      0 127.0.0.1:161           0.0.0.0:*                           0          45471      -
                udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          36519      -
                udp        0      0 192.168.178.203:49483   0.0.0.0:*                           297536     96008      -
                udp        0      0 0.0.0.0:41316           0.0.0.0:*                           1000       145040     -
                udp        0      0 0.0.0.0:49618           0.0.0.0:*                           1000       145934     -
                udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       148908     -
                udp        0      0 169.254.241.18:49723    0.0.0.0:*                           297536     96015      -
                udp        0      0 127.0.0.1:619           0.0.0.0:*                           0          36388      -
                udp        0      0 0.0.0.0:41620           0.0.0.0:*                           1000       149081     -
                udp        0      0 0.0.0.0:662             0.0.0.0:*                           0          36457      -
                udp        0      0 0.0.0.0:892             0.0.0.0:*                           0          36193      -
                udp        0      0 169.254.241.18:37759    0.0.0.0:*                           297536     96009      -
                udp        0      0 192.168.178.203:33717   0.0.0.0:*                           297536     96014      -
                udp        0      0 0.0.0.0:41941           0.0.0.0:*                           1000       149120     -
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       151729     -
                udp        0      0 192.168.178.203:5353    0.0.0.0:*                           1000       143158     -
                udp        0      0 192.168.178.203:5353    0.0.0.0:*                           1000       143641     -
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          35293      -
                udp        0      0 127.0.0.1:54514         0.0.0.0:*                           297536     96007      -
                udp        0      0 0.0.0.0:58694           0.0.0.0:*                           1000       146404     -
                udp        0      0 0.0.0.0:38214           0.0.0.0:*                           1000       135736     -
                udp        0      0 0.0.0.0:42386           0.0.0.0:*                           1000       131903     -
                udp        0      0 0.0.0.0:42458           0.0.0.0:*                           1000       147997     -
                udp        0      0 0.0.0.0:54762           0.0.0.0:*                           1000       144365     -
                udp        0      0 0.0.0.0:42518           0.0.0.0:*                           1000       139000     -
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       141042     -
                udp        0      0 0.0.0.0:54877           0.0.0.0:*                           1000       150072     -
                udp        0      0 0.0.0.0:34406           0.0.0.0:*                           1000       134738     -
                udp        0      0 0.0.0.0:34425           0.0.0.0:*                           1000       151824     -
                udp        0      0 0.0.0.0:38577           0.0.0.0:*                           1000       148893     -
                udp        0      0 0.0.0.0:34528           0.0.0.0:*                           1000       6247571    -
                udp        0      0 192.168.178.203:46830   0.0.0.0:*                           297536     96011      -
                udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          29938      -
                udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          29937      -
                udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          29936      -
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          49219      -
                udp        0      0 0.0.0.0:1901            0.0.0.0:*                           297536     96013      -
                udp        0      0 0.0.0.0:51087           0.0.0.0:*                           1000       139389     -
                udp        0      0 169.254.241.18:42991    0.0.0.0:*                           297536     96012      -
                udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          55965      -
                udp        0      0 0.0.0.0:51385           0.0.0.0:*                           1000       141194     -
                udp        0      0 0.0.0.0:55516           0.0.0.0:*                           1000       154626     -
                udp        0      0 0.0.0.0:43312           0.0.0.0:*                           1000       142990     -
                udp6       0      0 :::3702                 :::*                                99         36874      -
                udp6       0      0 :::4045                 :::*                                0          55977      -
                udp6       0      0 2a02:8109:2740:2e30::53 :::*                                115492     172333     -
                udp6       0      0 2a02:8109:2740:2e30::53 :::*                                115492     172332     -
                udp6       0      0 2a02:8109:2740:2e30::53 :::*                                115492     172331     -
                udp6       0      0 2a02:8109:2740:2e30::53 :::*                                115492     172330     -
                udp6       0      0 fe80::211:32ff:fe9b::53 :::*                                115492     76537      -
                udp6       0      0 fe80::211:32ff:fe9b::53 :::*                                115492     76536      -
                udp6       0      0 fe80::211:32ff:fe9b::53 :::*                                115492     76535      -
                udp6       0      0 fe80::211:32ff:fe9b::53 :::*                                115492     76534      -
                udp6       0      0 ::1:53                  :::*                                115492     76529      -
                udp6       0      0 ::1:53                  :::*                                115492     76528      -
                udp6       0      0 ::1:53                  :::*                                115492     76527      -
                udp6       0      0 ::1:53                  :::*                                115492     76526      -
                udp6       0      0 :::111                  :::*                                0          22208      -
                udp6       0      0 :::123                  :::*                                0          36522      -
                udp6       0      0 ::1:323                 :::*                                0          36520      -
                udp6       0      0 :::37315                :::*                                0          35296      -
                udp6       0      0 :::662                  :::*                                0          36464      -
                udp6       0      0 :::892                  :::*                                0          36197      -
                udp6       0      0 :::5353                 :::*                                0          35294      -
                udp6       0      0 :::58682                :::*                                0          22209      -
                udp6       0      0 :::2049                 :::*                                0          55967      -
                2024-02-22 15:53:42.856  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef62c9c" connected!
                2024-02-22 15:53:47.028  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef5afd0" connected!
                2024-02-22 15:53:49.586  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-4855199c1ee8 / shellyplus1pm#4855199c1ee8#1) (false)
                2024-02-22 15:53:52.654  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-0cdc7ef6696c / shellyplus1pm#0cdc7ef6696c#1) (false)
                2024-02-22 15:53:52.679  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-4855199d205c" connected!
                2024-02-22 15:53:52.854  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-0cdc7ef62c9c / shellyplus1pm#0cdc7ef62c9c#1) (false)
                2024-02-22 15:53:54.229  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-4855199d1ee8" connected!
                2024-02-22 15:53:56.551  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef62910" connected!
                2024-02-22 15:53:57.025  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-0cdc7ef5afd0 / shellyplus1pm#0cdc7ef5afd0#1) (false)
                2024-02-22 15:53:57.950  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef5a954" connected!
                2024-02-22 15:54:01.850  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef62cbc" connected!
                2024-02-22 15:54:02.131  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-4855199cfa60" connected!
                2024-02-22 15:54:02.670  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-4855199d205c / shellyplus1pm#4855199d205c#1) (false)
                • OliverIO
                  @dr-pie
                  Ich tippe mal ein Problem mit dem device watcher.
                  Lese mal hier.
                  https://github.com/ciddi89/ioBroker.device-watcher/issues/283
                  Stoppe mal den Adapter ob sich dann die Auslastung normalisiert.
                  Roellen created this issue in ciddi89/ioBroker.device-watcher
                  closed Device Watcher makes 100% CPU load of js-controller #283
                  Dr.Pie 2 Replies Last reply Reply Quote 0
                  • Dr.Pie
                    @dr-pie
                    Lese mal hier.
                    Ich komme ja nicht auf die iob-Oberfläche.
                    Der Editor funktioniert nach ca. 15 Minuten. Auch die Vis ist verfügbar.Jeder klick in der Vis bedeutet aber waaaaarten
                    • Dr.Pie
                      @dr-pie
                      In einer Millisekunde konnte ich auf den iob kommen.
                      Habe dann den "device watcher" angehalten ... und siehe da ...die CPU Auslastung normalisierte sich wieder.
                      • OliverIO
                        @dr-pie
                        Man kann Adapter auch über console Befehle starten und stoppen
                        • Dr.Pie
                          @dr-pie
                          Hab ich gerade raus gefunden. 👍 👍 👍
                          • Glasfaser
                            Glasfaser last edited by
                            Docker : v8.0.1
                            /usr/bin/npm 9.6.7
                            /usr/bin/npx 9.6.7
                            nodejs:
                            Docker Image ist alt und du bleibst auf der nodejs Version stehen .
                            • Dr.Pie
                              Dr.Pie @Glasfaser last edited by
                              @glasfaser sagte in Teilweise über 200% CPU Auslastung im Docker:
                              Docker : v8.0.1
                              /usr/bin/npm 9.6.7
                              /usr/bin/npx 9.6.7
                              nodejs:
                              Liegt vielleicht daran dass ich nicht wirklich weiss wie 🙇‍♂️
                              OliverIO Glasfaser 2 Replies Last reply Reply Quote 0
                              • OliverIO
                                OliverIO @Dr.Pie last edited by OliverIO
                                @dr-pie
                                hach, wenn es nur eine beschreibung dafür geben würde, wo das alles genauch beschrieben ist.
                                huch
                                https://docs.buanet.de/de/iobroker-docker-image/docs/#hochrustung-upgrade
                                oder alternativ die ältere doku für portainer
                                https://smarthome.buanet.de/2020/10/iobroker-docker-container-updates-upgrades/
                                • Glasfaser
                                  Glasfaser @Dr.Pie last edited by
                                  Jein ...
                                  Aber @OliverIO hat dir schon ein Tip zur Auslastung von einem bestimmten Adapter genannt , der hier bei vielen Probleme macht !
                                  Und das mit der Synology Anzeige / Diagramm ist ein Schätzeisen ...
                                  aber das Thema haben ich und @OliverIO schon mehrmals hier im Forum durchgekaut .
                                  648
