    4. Test Adapter Philips-TV v0.2.x
    • foxriver76
      foxriver76 Developer @teletapi last edited by
      @teletapi dann mal F12 Browser Konsole öffnen und schauen was da für ein Error steht und hier posten.
      teletapi 2 Replies Last reply Reply Quote 0
      • teletapi
        teletapi @foxriver76 last edited by
        @foxriver76 Danke für deine Hilfe mach ich aber morgen vormittag, für heute muss gut sein
        • teletapi
          teletapi @foxriver76 last edited by teletapi
          @foxriver76
          So jetzt mal den Fehler aus der Konsole, das ist jetzt Lan die IP mit der .136 am ende
          Cannot parse json data: 192.168.178.136 console.ts:40:19
          OK console.ts:40:19
          Error: Minified React error #130; visit https://reactjs.org/docs/error-decoder.html?invariant=130&args[]=undefined&args[]= for the full message or use the non-minified dev environment for full errors and additional helpful warnings
          Und noch ein IOB Diag
          ```Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           11:02:46 up 41 min,  1 user,  load average: 0.79, 0.77, 0.90
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sun 2023-12-24 11:02:46 CET
                     Universal time: Sun 2023-12-24 10:02:46 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            7.8G        2.4G        3.8G        1.0M        1.6G        5.3G
          Swap:            99M          0B         99M
          Total:          7.9G        2.4G        3.9G
                   7811 M total memory
                   2368 M used memory
                   3396 M active memory
                    412 M inactive memory
                   3826 M free memory
                    130 M buffer memory
                   1486 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       59G   12G   45G  21% /
          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
          /dev/sda1      vfat      255M   31M  225M  13% /boot
          tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
          [Sun Dec 24 10:20:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Sun Dec 24 10:20:58 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sun Dec 24 10:20:58 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Sun Dec 24 10:20:59 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
          TARGET  SOURCE    FSTYPE OPTIONS
          /       /dev/sda2 ext4   rw,noatime
          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.9G    /var/
          1.1G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
          1.1G    /var/log
          631M    /var/lib
          Archived and active journals take up 1.0G in the file system.
          /opt/iobroker/backups:
          1.5G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          366M    /opt/iobroker/iobroker-data/
          183M    /opt/iobroker/iobroker-data/files
          76M     /opt/iobroker/iobroker-data/backup-objects
          71M     /opt/iobroker/iobroker-data/node-red/node_modules
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          24M     /opt/iobroker/iobroker-data/objects.jsonl
          22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
          8.8M    /opt/iobroker/iobroker-data/states.jsonl
          8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          /usr/bin/corepack       0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0-1nodesource1 1001
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.13.5
          javascript:     7.5.1
          Adapters from github:   2
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
          + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
          + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
          + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
          + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
          + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): beta
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "admin"        : 6.13.5   , installed 6.13.5
          Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
          Adapter    "hue"          : 3.10.1   , installed 3.10.1
          Adapter    "ical"         : 1.13.5   , installed 1.13.5
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "iopooleco"    : 0.5.1    , installed 0.5.1
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
          Adapter    "javascript"   : 7.5.1    , installed 7.5.1
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
          Adapter    "node-red"     : 5.0.2    , installed 5.0.2
          Adapter    "nuki"         : 1.6.0    , installed 1.6.0
          Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
          Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
          Adapter    "shelly"       : 6.7.0    , installed 6.7.0
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "ws"           : 2.5.10   , installed 2.5.10
          Objects and States
          Objects:        9657
          States:         9725
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 https://apt.grafana.com stable InRelease
          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       16204      1300/io.hm-rpc.1
          tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       16953      1317/io.hm-rpc.2
          tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       24647      2135/io.simple-api.
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18345      1486/io.sonoff.0
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       16919      1212/node-red
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        1999       559/mosquitto
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17227      1511/io.shelly.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          30562      3094/sshd: /usr/sbi
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       21874      1876/io.jarvis.0
          tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       14136      1278/io.hm-rpc.0
          tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       17963      1375/io.hm-rpc.3
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15623      656/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15141      656/iobroker.js-con
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13693      541/cupsd
          tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       22276      1910/io.nuki.0
          tcp6       0      0 :::1883                 :::*                    LISTEN      116        2000       559/mosquitto
          tcp6       0      0 :::22                   :::*                    LISTEN      0          30564      3094/sshd: /usr/sbi
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       23340      2184/io.socketio.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        15452      549/influxd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13912      849/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20044      1638/io.web.0
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13692      541/cupsd
          tcp6       0      0 :::3000                 :::*                    LISTEN      117        15499      655/grafana
          udp        0      0 0.0.0.0:48065           0.0.0.0:*                           108        14876      400/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15056      464/dhcpcd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2012       614/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14874      400/avahi-daemon: r
          udp6       0      0 :::36425                :::*                                108        14877      400/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          15086      464/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        14875      400/avahi-daemon: r
          2023-12-24 10:59:56.141  - debug: philips-tv.0 (9316) Objects client ready ... initialize now
          2023-12-24 10:59:56.144  - debug: philips-tv.0 (9316) Objects create System PubSub Client
          2023-12-24 10:59:56.145  - debug: philips-tv.0 (9316) Objects create User PubSub Client
          2023-12-24 10:59:56.228  - debug: philips-tv.0 (9316) Objects client initialize lua scripts
          2023-12-24 10:59:56.237  - debug: philips-tv.0 (9316) Objects connected to redis: 127.0.0.1:9001
          2023-12-24 10:59:56.241  - silly: philips-tv.0 (9316) redis psubscribe cfg.o.system.user.*
          2023-12-24 10:59:56.291  - silly: philips-tv.0 (9316) redis psubscribe cfg.o.enum.*
          2023-12-24 10:59:56.294  - silly: philips-tv.0 (9316) objectDB connected
          2023-12-24 10:59:56.298  - debug: philips-tv.0 (9316) Redis States: Use Redis connection: 127.0.0.1:9000
          2023-12-24 10:59:56.329  - debug: philips-tv.0 (9316) States create System PubSub Client
          2023-12-24 10:59:56.331  - debug: philips-tv.0 (9316) States create User PubSub Client
          2023-12-24 10:59:56.428  - debug: philips-tv.0 (9316) States connected to redis: 127.0.0.1:9000
          2023-12-24 10:59:56.429  - silly: philips-tv.0 (9316) statesDB connected
          2023-12-24 10:59:57.343  - info: philips-tv.0 (9316) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v18.19.0, js-controller: 5.0.17
          2023-12-24 10:59:57.379  - info: philips-tv.0 (9316) Starting with ip "192.168.178.136" (API v6 - Android)
          2023-12-24 10:59:57.387  - warn: philips-tv.0 (9316) Please authenticate via the adapter configuration page
          2023-12-24 10:59:57.416  - silly: philips-tv.0 (9316) States system redis pmessage system.adapter.philips-tv.0.logLevel/system.adapter.philips-tv.0.logLevel:{"val":"silly","ack":true,"ts":1703411997391,"q":0,"from":"system.adapter.philips-tv.0","lc":1703411997391}
          2023-12-24 11:00:00.163  - info: host.iobroker instance system.adapter.ical.0 started with pid 9335
          2023-12-24 11:00:03.622  - info: ical.0 (9335) starting. Version 1.13.5 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
          2023-12-24 11:00:09.909  - info: ical.0 (9335) Terminated (NO_ERROR): Without reason
          2023-12-24 11:00:10.444  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          iob diag has finished.
          Press any key for a summary
          L foxriver76 2 Replies Last reply Reply Quote 0
            Lucky_ESA Developer Most Active @teletapi last edited by
            @teletapi Du must in der Instanzen Ansicht erst den Adapter aktivieren und dann in den Instanz EInstellungen die Pin eingeben.
            teletapi 1 Reply Last reply Reply Quote 0
            • teletapi
              teletapi @Lucky_ESA last edited by teletapi
              @lucky_esa Das versteh ich jetzt nicht, ohne das der Adapter aktiv ist ist doch der Button zum Pairen garnicht aktiv.
              Wenn ich auf Pairing starten gehe, kommt am Fernsehn der Pin den geb ich ein und gehe auf Pin bestätigen, im gleichen Moment stürzt der Adapter ab
              Aber das spielt auch keine Rolle der Adapter stürzt immer ab,egal ob ich einen Pin eingebe oder nicht sobald ich auf Pin bestätigen drücke wars das.
              • foxriver76
                @teletapi probier mal bitte während die Konsole offen ist den Error zu provozieren, evtl. wird die Meldung dann etwas aufschlussreicher.
                • teletapi
                  @foxriver76
                      ot console.ts:40
                      _onClick ConfigSendto.tsx:221
                      onClick ConfigSendto.tsx:346
                      React 11
                      r helpers.ts:98
                  OK console.ts:40:19
                  Error: Minified React error #130; visit https://reactjs.org/docs/error-decoder.html?invariant=130&args[]=undefined&args[]= for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
                      React 20
                      onClick ConfigSendto.tsx:344
                      React 11
                      r helpers.ts:98
                  console.ts:40:19
                      ot console.ts:40
                      React 15
                      React 11
                      r helpers.ts:98
                  teletapi 1 Reply Last reply Reply Quote 1
                  • teletapi
                    teletapi @teletapi last edited by teletapi
                    So der Adapter ist endlich grün
                    Der Fehler bzw. die Lösung....
                    Ein einfaches " iob upload all" brachte das in Ordnung
                    Danke für eure Mühe, hätte ich eigentlich auch schon früher drauf kommen können.
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                     01:33:11 up 15:12,  1 user,  load average: 1.32, 0.86, 0.90
                    CPU threads: 4
                    Current issues:
                                   Local time: Mon 2023-12-25 01:33:11 CET
                               Universal time: Mon 2023-12-25 00:33:11 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            7.8G        3.0G        1.1G        1.0M        3.7G        4.7G
                    Swap:            99M          0B         99M
                    Total:          7.9G        3.0G        1.2G
                             7811 M total memory
                             3022 M used memory
                             5054 M active memory
                             1437 M inactive memory
                             1067 M free memory
                              184 M buffer memory
                             3536 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    1.9G    /var/
                    1.1G    /var/log
                    629M    /var/lib
                    352M    /opt/iobroker/iobroker-data/
                    14M     /opt/iobroker/iobroker-data/objects.jsonl
                    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.13.9
                    javascript:     7.5.1
                    Adapter State
                    + instance is alive
                    Adapter    "admin"        : 6.13.9   , installed 6.13.9
                    Objects and States
                    Objects:        9665
                    States:         9732
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                    Pending Updates: 0
                    tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       2425281    140650/io.simple-ap
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2228473    128643/cupsd
                    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       2421701    140580/io.socketio.
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2351329    136052/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2426005    140522/io.web.0
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2228472    128643/cupsd
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2226608    128646/cups-browsed
                    2023-12-25 01:22:52.333  - info: philips-tv.0 (141369) Got terminate signal TERMINATE_YOURSELF
                    2023-12-25 01:22:52.451  - info: host.iobroker stopInstance system.adapter.philips-tv.0 send kill signal
                    2023-12-25 01:22:52.518  - info: philips-tv.0 (141369) terminating
                    2023-12-25 01:22:52.520  - info: philips-tv.0 (141369) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-12-25 01:22:52.839  - info: philips-tv.0 (141369) terminating
                    2023-12-25 01:22:53.150  - info: host.iobroker instance system.adapter.philips-tv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-12-25 01:22:55.591  - info: host.iobroker instance system.adapter.philips-tv.0 started with pid 141384
                    2023-12-25 01:22:58.922  - info: philips-tv.0 (141384) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v18.19.0, js-controller: 5.0.17
                    2023-12-25 01:22:58.948  - info: philips-tv.0 (141384) Starting with ip "192.168.178.136" (API v6 - Android)
                    2023-12-25 01:23:01.146  - info: admin.0 (136052) <== Disconnect system.user.admin from ::ffff:192.168.178.23 admin
                    2023-12-25 01:23:02.120  - info: admin.0 (136052) ==> Connected system.user.admin from ::ffff:192.168.178.23
                    2023-12-25 01:26:35.217  - info: admin.0 (136052) <== Disconnect system.user.admin from ::ffff:192.168.178.23 admin
                    2023-12-25 01:26:40.999  - info: admin.0 (136052) ==> Connected system.user.admin from ::ffff:192.168.178.23
                    2023-12-25 01:27:24.211  - info: admin.0 (136052) <== Disconnect system.user.admin from ::ffff:192.168.178.23 admin
                    2023-12-25 01:30:00.200  - info: host.iobroker instance system.adapter.ical.0 started with pid 142393
                    2023-12-25 01:30:03.335  - info: ical.0 (142393) starting. Version 1.13.5 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                    2023-12-25 01:30:09.489  - info: ical.0 (142393) Terminated (NO_ERROR): Without reason
                    2023-12-25 01:30:10.076  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                    2023-12-25 01:32:39.084  - info: admin.0 (136052) ==> Connected system.user.admin from ::ffff:192.168.178.63
                    2023-12-25 01:33:57.940  - info: web.0 (140522) ==> Connected system.user.admin from ::ffff:192.168.178.63
                    2023-12-25 01:34:21.433  - info: web.0 (140522) <== Disconnect system.user.admin from ::ffff:192.168.178.63
                      ltsalvatore last edited by
                      hey, erst mal danke, dass dieser adapter zur verfügung gestellt wird.
                      ich habe gestern etwas damit rumgespielt und es scheint alles einwandfrei zu funktionieren.
                      ich muss sagen, so toll ich meinen Philips - 65OLED807-12 finde so wahr ist es aber auch, dass das OS der letzte rotz ist. es ist tatsächlich so negativ wie alle im netz behaupten.
                      hinzu kommt auch noch, dass der alexa skill alles andere als nützlich ist. wenig bis keine funktionen und was die zuverlässigkeit angeht, da kann man auch lotto spielen.
                      hinzu kommt noch, dass es auch wirklich keine einzige funktionierende android app gibt, welche man als virtuelle tastatur hätte nutzen können.
                      umso erfreulicher, dass ich mit dem adapter hier beides mir jetzt selbst mit VIS und IoT Adapter zusammenbasteln kann.
                      und jetzt zu meiner eigentlichen frage.. hat jemand zufälligerweise einen bereits fertigen VIS, den er bereit ist zu teilen? 😊🙏🏾
                        Lucky_ESA Developer Most Active @ltsalvatore last edited by
                        @ltsalvatore Schau mal hier nach. Die sind zwar für LG aber das kann man ja ändern.
                        Gruß//Lucky
                          PrinzVonBillAir last edited by
                          Ich erhalte folgenden Fehler beim Versuch das TV (55PUS8808) zu pairen. Ich hatte das TV vor einigen Monaten (8-10) bereits mal gepaired, aber dann den Adapter zwischenzeitlich nochmal gelöscht und soeben wieder neu installiert. Nun erscheint nur folgende Fehlermeldung, auch bei den Protokollen kommt keine Meldung eines Fehlers, selbst bei Logstufe "Alles/Silly". Mir scheint es so, als dass überhaupt nichts an das TV gesendet wird und daher auch kein Pairing-Code angezeigt wird. Oder muss ich irgendwo im TV zuerst das alte Pairing löschen? Wenn ja, wo? Ich habe in den TV-Einstellungen bestimmt über eine Stunde jedes Untermenü durchsucht und finde nichts.
                            RappiRN Most Active @PrinzVonBillAir last edited by
                            @prinzvonbillair
                            Hast du zufällig auch vor ein paar Tagen ein Update am TV gemacht? Bei mir kamen die Fehlermeldungen just in dem Moment, wo der TV nach dem Update neu gestartet ist.
                            Habe auch schon ne ganze Menge probiert, das letzte, was ich jetzt noch machen könnte, wäre ein Downgrade am TV.
                            Das Pairen (des TV) an sich scheint zu funktionieren, eine App hat sich angemeldet und es wurde ein Code am TV angezeigt.
                            Enrico
                              RappiRN Most Active @RappiRN last edited by
                              @rappirn
                              Also den TV habe ich mal auf die vorherige Version zurückgesetzt, es hat nichts gebracht.
                              Habe auch noch einmal alle Adapterversionen ab 0.3.0 versucht, auch ohne Erfolg. Heute Abend werde ich nochmal versuchen, die Adapterversionen jeweils mit einer kompletten Neuinstallation zu installieren.
                              Was mir mal immer wieder aufgefallen ist. Meist kam die Fehlermeldung sofort und manchmal, vielleicht nach einer Installation oder einem Adapterneustart (das kann ich noch nicht genau sagen), dauert es einige Sekunden, bis die Fehlermeldung kommt. Leider gibt es im log keine brauchbaren Infos.
                              Enrico
                                Dimi @RappiRN last edited by
                                @rappirn
                                Ich habe das selbe Problem mit meinem TV. Beim Pairing kommt die Fehlermeldung "Unknown message payload for "Pairing": null". Ich habe das Modell 65OLED854 mit dem seit kurzem verfügbaren Android TV 11. Ich habe es mit der Version 0.5.3 und mit der 0.5.2 probiert.
                                Dimi
                                  Adri525 @Dimi last edited by
                                  ich habe einen 65OLED935/12 Philips TV mit der aktuellsten Software und Android 11, welcher via LAN verbunden ist.
                                  Ohne MAC Adresse für WOL wird der Adapter grün und funktioniert einwandfrei.
                                  Ich möchte den Adapter aber nur nutzen um das Ambilght einschalten zu können und dazu benötige ich WOL. Sobald ich die MAC (welche in den Netzwerkeinstellungen vom TV steht / Ethernet MAC Adresse) eintrage wird der Adapter nicht mehr grün.
                                  Anbei der Log:
                                  2024-07-02 20:30:15.001 - debug: philips-tv.0 (12498) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  2024-07-02 20:30:15.122 - debug: philips-tv.0 (12498) Objects client ready ... initialize now
                                  2024-07-02 20:30:15.159 - debug: philips-tv.0 (12498) Objects create System PubSub Client
                                  2024-07-02 20:30:15.162 - debug: philips-tv.0 (12498) Objects create User PubSub Client
                                  2024-07-02 20:30:15.337 - debug: philips-tv.0 (12498) Objects client initialize lua scripts
                                  2024-07-02 20:30:15.351 - debug: philips-tv.0 (12498) Objects connected to redis: 127.0.0.1:9001
                                  2024-07-02 20:30:15.457 - debug: philips-tv.0 (12498) Redis States: Use Redis connection: 127.0.0.1:9000
                                  2024-07-02 20:30:15.512 - debug: philips-tv.0 (12498) States create System PubSub Client
                                  2024-07-02 20:30:15.514 - debug: philips-tv.0 (12498) States create User PubSub Client
                                  2024-07-02 20:30:15.618 - debug: philips-tv.0 (12498) States connected to redis: 127.0.0.1:9000
                                  2024-07-02 20:30:16.290 - info: philips-tv.0 (12498) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v18.20.2, js-controller: 5.0.19
                                  2024-07-02 20:30:16.324 - info: philips-tv.0 (12498) Starting with ip "192.168.1.50" (API v6 - Android)
                                  2024-07-02 20:30:16.331 - error: philips-tv.0 (12498) Cannot create API client Provided MAC is not an MAC Address!
                                  Der Log sagt ja dass die MAC keine MAC Adresse ist.
                                  Habe die MAC Adresse auch nochmal in meiner Unifi Dream Machine Pro geprüft, Sie stimmt...
                                  Hat jemand eine Idee und kann mir helfen?
                                  Vielen Dank im Voraus!
                                  Adri
                                  DJMarc75 1 Reply Last reply Reply Quote 1
                                  • DJMarc75
                                    DJMarc75 @Adri525 last edited by
                                    @adri525 sagte in Test Adapter Philips-TV v0.2.x:
                                    die MAC Adresse
                                    zeig mal die MAC welche Du im Adapter einträgst bitte.
                                      Adri525 @DJMarc75 last edited by
                                      @djmarc75
                                      • DJMarc75
                                        @adri525 hmmm... copy paste mit Leerzeichen am Ende ?
                                        Sonst passt das ja eigentlich.
                                          @djmarc75
                                          Nein, es ist kein Leerzeichen o.ä. drin.
                                          Habe die MAC händisch eingetragen und nicht kopiert...
                                            ltsalvatore @Adri525 last edited by
                                            @djmarc75
                                            bei mir hab ich alles mit großbuchstaben drin.. wäre ein versuch wert.
                                            philips philips tv
                                            84
                                            550
                                            131360
