    4. Test Adapter hekr wisen elro App v0.0.x
      Lucky_ESA Developer Most Active @konetti last edited by
      @konetti sagte in Test Adapter hekr wisen elro App v0.0.x:
      @lucky_esa da passiert leider nichts, außer das im Log folgende Meldung erscheint: "Command raw not implemented"
      Du sollst auch diesen nehmen hekr.0.xxx.status.raw_manually
      Hats du diesen nicht dann bitte mal direkt vom GIT laden.
        konetti @Lucky_ESA last edited by konetti
        @lucky_esa raw_manually gab es bei mir gerade noch gar nicht. Es war jetzt erst nach einer Neuinstallation des Adapters da. Aber leider auch da passiert nichts.
        Im Debug Log steht folgendes:
        023-07-19 14:55:50.707 - debug: hekr.0 (14400) Command 4810020007090000ff00
        2023-07-19 14:55:50.724 - debug: hekr.0 (14400) WS devSend:{"msgId":65,"action":"appSendResp","code":1400025,"desc":"RAW not valid, Please check your protocol template"}
        2023-07-19 14:55:50.724 - debug: hekr.0 (14400) WS received:{"msgId":65,"action":"appSendResp","code":1400025,"desc":"RAW not valid, Please check your protocol template"}
        2023-07-19 14:55:52.548 - debug: hekr.0 (14400) WS devSend:{"msgId":25806,"action":"devSend","params":{"devTid":"ESP_2M_84CCA8A67F7C","appTid":[],"subDevTid":null,"ctrlKey":"**","data":{"cleaning":0,"B":0,"RGB_Sw":0,"sw":1,"G":0,"raw":"48110144010100000200000000000000A2","light_Sw":0,"speed":0,"tm_Minutes":0,"R":0,"cmdId":1,"Statue":2,"fitter":0}}}
        2023-07-19 14:55:57.875 - debug: hekr.0 (14400) WS devSend:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:55:57.877 - debug: hekr.0 (14400) WS received:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:56:07.876 - debug: hekr.0 (14400) WS devSend:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:56:07.877 - debug: hekr.0 (14400) WS received:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:56:17.877 - debug: hekr.0 (14400) WS devSend:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:56:17.878 - debug: hekr.0 (14400) WS received:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:56:22.116 - debug: hekr.0 (14400) Model: M002
        2023-07-19 14:56:22.173 - debug: hekr.0 (14400) Command 48100200070900000000
        2023-07-19 14:56:22.190 - debug: hekr.0 (14400) WS devSend:{"msgId":65,"action":"appSendResp","code":1400025,"desc":"RAW not valid, Please check your protocol template"}
        2023-07-19 14:56:22.191 - debug: hekr.0 (14400) WS received:{"msgId":65,"action":"appSendResp","code":1400025,"desc":"RAW not valid, Please check your protocol template"}
        2023-07-19 14:56:22.545 - debug: hekr.0 (14400) WS devSend:{"msgId":25808,"action":"devSend","params":{"devTid":"ESP_2M_84CCA8A67F7C","appTid":[],"subDevTid":null,"ctrlKey":"**","data":{"raw":"48110145010100000200000000000000A3"}}}
        2023-07-19 14:56:27.878 - debug: hekr.0 (14400) WS devSend:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:56:27.879 - debug: hekr.0 (14400) WS received:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:56:37.878 - debug: hekr.0 (14400) WS devSend:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:56:37.879 - debug: hekr.0 (14400) WS received:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:56:47.880 - debug: hekr.0 (14400) WS devSend:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:56:47.881 - debug: hekr.0 (14400) WS received:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:56:52.547 - debug: hekr.0 (14400) WS devSend:{"msgId":25811,"action":"devSend","params":{"devTid":"ESP_2M_84CCA8A67F7C","appTid":[],"subDevTid":null,"ctrlKey":"**","data":{"raw":"48110146010100000200000000000000A4"}}}
        2023-07-19 14:56:57.880 - debug: hekr.0 (14400) WS devSend:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:56:57.881 - debug: hekr.0 (14400) WS received:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:57:07.880 - debug: hekr.0 (14400) WS devSend:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:57:07.881 - debug: hekr.0 (14400) WS received:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:57:17.879 - debug: hekr.0 (14400) WS devSend:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:57:17.880 - debug: hekr.0 (14400) WS received:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:57:22.559 - debug: hekr.0 (14400) WS devSend:{"msgId":25813,"action":"devSend","params":{"devTid":"ESP_2M_84CCA8A67F7C","appTid":[],"subDevTid":null,"ctrlKey":"**","data":{"cleaning":0,"B":0,"RGB_Sw":0,"sw":1,"G":0,"raw":"48110147010100000200000000000000A5","light_Sw":0,"speed":0,"tm_Minutes":0,"R":0,"cmdId":1,"Statue":2,"fitter":0}}}
        2023-07-19 14:57:22.560 - debug: hekr.0 (14400) WS write:{"msgId":25813,"action":"devSend","params":{"devTid":"ESP_2M_84CCA8A67F7C","appTid":[],"subDevTid":null,"ctrlKey":"*","data":{"cleaning":0,"B":0,"RGB_Sw":0,"sw":1,"G":0,"raw":"48110147010100000200000000000000A5","light_Sw":0,"speed":0,"tm_Minutes":0,"R":0,"cmdId":1,"Statue":2,"fitter":0}}}
        2023-07-19 14:57:27.884 - debug: hekr.0 (14400) WS devSend:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
        2023-07-19 14:57:27.885 - debug: hekr.0 (14400) WS received:{"msgId":53,"action":"heartbeatResp","code":200,"desc":"success"}
          @konetti Dann wie bereits gesagt 30 poste zurück lesen.
          Zum Beispiel dieser
          Gruß//Lucky
            @lucky_esa
            Ok, wie kann ich es mit einem Androidhandy selbst auslesen?
            Dazu noch eine Frage zu den Posts von oben: Müsste es theoretisch klappen, wenn sich die raw ändert, wenn ich an der Haube das Licht anschalte und dann diesen raw bei raw_manually eintrage? Bei mir funktioniert es nämlich nicht.
              @konetti
              Bin mir nicht sicher ob das überhaupt funktioniert. Muss ich mal testen aber das kann ich erst in 3 Wochen. Nimm Wireshark. Da du mit der APP Remote deine Haube schaltest wird dieser Befehl als Klartext erfasst. Du musst aber vorher die Remote Funktion in der APP aktivieren bevor du deine Haube auswählst..
              Gruß//Lucky
                @lucky_esa
                Danke soweit für die Hilfe.
                Als erstes ein Hinweis: Den Modus, dass es übers lokale Netzwerk gesendet wird, kann man auch in der App für iOS einstellen.
                Leider zeigt es mir bei beiden an, dass die Haube offline ist, wenn ich den Modus aktiviere. Interessanterweise ist das Verhalten danach wie im Adapter. Ich kann nicht steuern, sehe aber, wenn ich an der Haube eine Änderung durch die Taster mache. Mir fehlt leider die Zeit weiter rum zu probieren. Wenn aber mal wieder Zeit bei mir ist, werde ich als erstes die Haube neu einbinden und dann schauen, wie es auf den lokalen Modus reagiert. Wenn es dann nicht besser ist, werde ich dem Hersteller schreiben, dass da etwas defekt ist. Mal schauen wie dieser reagiert.
                Ich schreibe hier wieder, wenn es etwas neues gibt.
                kontti
                  @konetti Wie bereits von @SpacerX bemerkt, solltest du die Haube vom Netz nehmen und dann erneut anlernen. Bei der Fritzbox kann man 5Ghz deaktivieren womit das anlernen sehr leicht ist.
                  Gruß//Lucky
                    biker1602 @Lucky_ESA last edited by biker1602
                    Hallo
                    Ich habe mal eine Frage. Bis Vorgestern hat alles funktioniert auch mit der App auch wenn man ab und zu mal in der App den Cache und die Daten löschen musste. Nach Anmeldung funktionierte aber alles wieder. Seit 2 Tagen funktioniert weder die App noch der Adapter im iobroker. Kann es sein das sie die App abgeschaltet haben weil die neuen Abzugshauben diese App nicht mehr nutzen.
                    "Tauchen Sie ein in die Zukunft der Küchentechnologie mit unserer hochmodernen Dunstabzugshaube. Dieses Modell, ausgestattet mit der neuesten WLAN-Technologie und dem renommierten Standard Tuya Smart / Smart Life, stellt nicht nur ein technisches Highlight dar, sondern bietet auch die Möglichkeit für erhöhte Sicherheit. Für Räume, die sowohl eine Dunstabzugshaube als auch eine Feuerstätte beherbergen, ist ein Fensterkontaktschalter von großem Nutzen. Dieser optional im Handel erhältliche Schalter stellt sicher, dass stets ausreichend Frischluft vorhanden ist, indem er die Dunstabzugshaube nur dann aktiviert, wenn ein Fenster geöffnet ist. Ein solches System minimiert Risiken und schützt vor unerwünschten Unterdrucksituationen. Dank der Kompatibilität mit unserer hauseigenen KKT.Control-App haben Sie die Möglichkeit, alle Funktionen bequem zu steuern und zu überwachen – und das alles direkt von Ihrem Smartphone oder Tablet aus. Erleben Sie ein sicheres und innovatives Küchenerlebnis auf einem neuen Level!"
                    Hat jemand das gleiche Problem?
                      Lucky_ESA Developer Most Active @biker1602 last edited by
                      @biker1602
                      Kann es leider mit der APP Version 1.8.9 bestätigen. Entweder haben die den Server abgeschaltet oder der ist nur down. Es gibt im Internet noch die Version 1.9.1. Hier muss man sich aber neu registrieren. Habe diese APP noch nicht getestet da man die Dunstabzugshaube kurz vom Netz nehmen muss. Leider komme ich derzeit nicht an die Steckdose...
                      Gruß//Lucky
                        SpacerX @Lucky_ESA last edited by
                        @lucky_esa wenn man nicht an die Steckdose kommt, dann gibt es ja noch die Sicherung. 😀
                          Lucky_ESA Developer Most Active @SpacerX last edited by
                          @spacerx sagte in Test Adapter hekr wisen elro App v0.0.x:
                          Da hatte ich auch schon dran gedacht aber schnell verworfen. Da hängt leider zu viel dran...Aber ich habe mal die Abdeckung abgeschraubt und versucht diese neu anzulernen. Leider bekomme ich den Anlernmodus nicht aktiviert. Dieser ist immer nur für ca. 2 Sekunden aktiv und das reicht leider nicht. Habe diese auch aus meiner Fritzbox gelöscht (steht in der Anleitung aber was soll das bringen) und für ca. 30 Minuten vom Stromnetz genommen. Hat leider auch nichts gebracht. Bitte teste das nicht selber...Habe mal geschaut was eine APP so macht und das gefiel mir überhaupt nicht. Muss noch mal andere Downloads ausprobieren.
                          Gruß//Lucky
                            timredlich last edited by
                            Hallo ,
                            ich habe eine KTT Kolbe Dunstabzugshaube 90cm EASY909SHCM RGBW . Ich versuche seit einiger Zeit diese in den IOBroker zu bekommen. Ich habe bereits verschiedene Versionen der WISEN APP ausprobiert, aber ich bekomme Die Dunstabzugshaube dort einfach nicht rein. In der Ktt Kolbe Control App wird sie sofort gefunden. Hat irgendjemand noch nie idee wir ich die Abzugshaube in den IO Broker bekommen kann.
                            L T B 3 Replies Last reply Reply Quote 0
                              Lucky_ESA Developer Most Active @timredlich last edited by
                              @timredlich sagte in Test Adapter hekr wisen elro App v0.0.x:
                              Hallo ,
                              Hier kannst du nur @tombox fragen, ob er mit deinen Zugangsdaten einen Adapter erstellt...Oder er gibt mir die Daten und ich schreibe diesen. Oder hier einen Request erstellen. Die Wisen APP ist wohl für immer down...
                                timredlich @timredlich last edited by
                                Adapter fänd ich super, wenn ich etwas dazu beitragen kann, dann würde ich dies tun.
                                Tim
                                  biker1602 @timredlich last edited by
                                  @timredlich said in Test Adapter hekr wisen elro App v0.0.x:
                                  Hallo ,
                                  Also die Wisen App funktioniert ja erstmal wieder aber bei mir war es so das meine Haube unter der KKT Kolbe App garnicht erkannt wurde sondern nur unter der Wisen App. Ich denke es gab bitter böse Schreiben an KKT Kolbe das es Leute gegeben hat die Ihre Abzugshaube erst ein Jahr hatten und dann war sie plötzlich über die App nicht mehr zu bedienen.
                                  Ich hatte ja auch mit der Technik Kontakt die mir bestätigt hatten das die Wisen App abgeschaltet ist da sie nicht von denen ist. Ich habe dann auch nicht so freundlich zurück geschrieben und 3 Tage später ging die App dann komischerweise wieder. Ich denke in den Haube sind unterschiedliche Systeme verbaut und deswegen einige nur mit der Wisen und andere nur mit der KKT Kolbe App funktionieren.
                                    Alex061273 last edited by
                                    Hi
                                    Wieso nicht die Haube in der Smart Life App integrieren und dann im IO Broker die Tuya App nutzen?
                                    Eisbaeeer 1 Reply Last reply Reply Quote 0
                                    • Eisbaeeer
                                      Eisbaeeer Developer @Alex061273 last edited by Eisbaeeer
                                      Ich habe seit kurzem eine KKT Kolbe Multi-Insel-HC Haube mit der KKT.Control App.
                                      Mir stellt sich die Frage, ob und wie ich die integriert bekomme?
                                      Grüße Lars
                                      EDIT:
                                      Hat sich eben erledigt. Hab einfach mal versucht, die Haube mit der Tuya App zu koppeln. Hat funktioniert. Damit ist die Haube nun in iobroker über Tuya integriert.
                                      79.9k
                                      106
                                      7595
