    4. Teilweise über 200% CPU Auslastung im Docker
    • Dr.Pie
      Dr.Pie @DJMarc75 last edited by
      @djmarc75 sagte in Teilweise über 200% CPU Auslastung im Docker:
      @dr-pie sagte in Teilweise über 200% CPU Auslastung im Docker:
      Die lange Version ginge natürlich auch
      und die wäre schön zu sehen 😉
      Mach halt nochmal - und am Ende keine Taste drücken
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Hardware Vendor : Synology
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v8.0.1
      Virtualization  : Docker
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       15:50:36 up 20:49,  0 users,  load average: 3.28, 3.01, 2.98
      CPU threads: 4
      *** Time and Time Zones ***
      Thu Feb 22 14:50:36 UTC 2024
      Thu Feb 22 15:50:36 CET 2024
      CET +0100
      Etc/UTC
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            7.8G        5.3G        590M        120M        1.9G        2.1G
      Swap:           6.7G         34M        6.7G
      Total:           14G        5.4G        7.3G
               7802 M total memory
               5319 M used memory
               4777 M active memory
               1528 M inactive memory
                590 M free memory
                 38 M buffer memory
               1854 M swap cache
               6731 M total swap
                 34 M used swap
               6697 M free swap
      *** FILESYSTEM ***
      Filesystem             Type   Size  Used Avail Use% Mounted on
      /dev/mapper/cachedev_4 btrfs  3.5T  2.0T  1.6T  56% /
      tmpfs                  tmpfs   64M     0   64M   0% /dev
      tmpfs                  tmpfs  3.9G     0  3.9G   0% /sys/fs/cgroup
      shm                    tmpfs   64M     0   64M   0% /dev/shm
      /dev/mapper/cachedev_4 btrfs  3.5T  2.0T  1.6T  56% /opt/iobroker
      /dev/mapper/cachedev_4 btrfs  3.5T  2.0T  1.6T  56% /etc/hosts
      tmpfs                  tmpfs  3.9G     0  3.9G   0% /proc/acpi
      tmpfs                  tmpfs  3.9G     0  3.9G   0% /proc/scsi
      tmpfs                  tmpfs  3.9G     0  3.9G   0% /sys/firmware
      sudo: unable to resolve host iobroker: Name or service not known
      [Wed Feb 21 19:01:19 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Wed Feb 21 19:01:19 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Wed Feb 21 19:01:19 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
      [Wed Feb 21 19:01:25 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Wed Feb 21 19:01:25 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Wed Feb 21 19:01:25 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
      TARGET             SOURCE        FSTYPE OPTIONS
      /                  /dev/mapper/cachedev_4[/@syno/@docker/btrfs/subvolumes/2082bc39f93f33f788e3c7fa290317a1b738ac8cf85a4217a83d22a38aceec36]       btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=724572,subvol=/@syno/@docker/btrfs/subvolumes/2082bc39f93f33f788e3c7fa290317a1b738ac8cf85a4217a83d22a38aceec36
      |-/opt/iobroker    /dev/mapper/cachedev_4[/@syno/docker/iobroker]        btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=724400,subvol=/@syno/docker
      |-/etc/resolv.conf /dev/mapper/cachedev_4[/@syno/@docker/containers/0450185fc3ce5afab5101aa2eabbba0a1f80981592975fc06d13c4fc7271dbd6/resolv.conf] btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
      |-/etc/hostname    /dev/mapper/cachedev_4[/@syno/@docker/containers/0450185fc3ce5afab5101aa2eabbba0a1f80981592975fc06d13c4fc7271dbd6/hostname]    btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
      `-/etc/hosts       /dev/mapper/cachedev_4[/@syno/@docker/containers/0450185fc3ce5afab5101aa2eabbba0a1f80981592975fc06d13c4fc7271dbd6/hosts]       btrfs  rw,nodev,relatime,relatime_period=30,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
      /var:
      33M     /var/
      31M     /var/lib
      18M     /var/lib/apt/lists
      18M     /var/lib/apt
      13M     /var/lib/dpkg
      /opt/iobroker/backups:
      3.2G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      498M    /opt/iobroker/iobroker-data/
      363M    /opt/iobroker/iobroker-data/files
      137M    /opt/iobroker/iobroker-data/files/vis-2
      94M     /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/vis-2/static
      26M     /opt/iobroker/iobroker-data/objects.jsonl
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      18M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e642d05b.js.map
      18M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.2b7aff38.js.map
      18M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      /usr/bin/corepack       0.18.0
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
              500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
       Cannot determine Lua scripts strategy: Connection is closed. ["cfg.o.system.host.iobroker"]
      No connection to databases possible ...
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   3
      Adapter State
      /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
              throw e;
      Error: Connection is closed.
          at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
          at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
          at Object.onceWrapper (node:events:629:26)
          at Socket.emit (node:events:514:28)
          at TCP.<anonymous> (node:net:323:12)
      Emitted 'error' event on ScanStream instance at:
          at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
          at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
          at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      Node.js v18.17.1
      ioBroker-Repositories
              throw e;
      Node.js v18.17.1
      Installed ioBroker-Instances
      Objects and States
      Objects:        3
      States:         3
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 28
      *** Listening Ports ***
      tcp        0      0 192.168.178.203:8081    0.0.0.0:*               LISTEN      1000       134867     -
      tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      297536     82661      -
      tcp        0      0 192.168.178.203:8082    0.0.0.0:*               LISTEN      1000       145247     -
      tcp        0      0 172.17.0.1:53           0.0.0.0:*               LISTEN      115492     103340     -
      tcp        0      0 172.17.0.1:53           0.0.0.0:*               LISTEN      115492     103339     -
      tcp        0      0 172.17.0.1:53           0.0.0.0:*               LISTEN      115492     103338     -
      tcp        0      0 172.17.0.1:53           0.0.0.0:*               LISTEN      115492     103337     -
      tcp        0      0 169.254.241.18:53       0.0.0.0:*               LISTEN      115492     76525      -
      tcp        0      0 169.254.241.18:53       0.0.0.0:*               LISTEN      115492     76524      -
      tcp        0      0 169.254.241.18:53       0.0.0.0:*               LISTEN      115492     76523      -
      tcp        0      0 169.254.241.18:53       0.0.0.0:*               LISTEN      115492     76522      -
      tcp        0      0 192.168.178.203:53      0.0.0.0:*               LISTEN      115492     76517      -
      tcp        0      0 192.168.178.203:53      0.0.0.0:*               LISTEN      115492     76516      -
      tcp        0      0 192.168.178.203:53      0.0.0.0:*               LISTEN      115492     76515      -
      tcp        0      0 192.168.178.203:53      0.0.0.0:*               LISTEN      115492     76514      -
      tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      115492     78686      -
      tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      115492     78688      -
      tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      115492     78687      -
      tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      115492     78685      -
      tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      0          54769      -
      tcp        0      0 0.0.0.0:662             0.0.0.0:*               LISTEN      0          36461      -
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          31027      -
      tcp        0      0 127.0.0.1:40247         0.0.0.0:*               LISTEN      297536     97536      -
      tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN      0          59416      -
      tcp        0      0 127.0.0.1:38008         0.0.0.0:*               LISTEN      0          110742     -
      tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      297536     98173      -
      tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         71637      -
      tcp        0      0 127.0.0.1:33304         0.0.0.0:*               LISTEN      0          34158      -
      tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      115492     78695      -
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       145106     -
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          47395      -
      tcp        0      0 0.0.0.0:892             0.0.0.0:*               LISTEN      0          36195      -
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          53837      -
      tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          114413     -
      tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          55954      -
      tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0          45472      -
      tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN      0          106312     -
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       135803     -
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       131823     -
      tcp        0      0 0.0.0.0:873             0.0.0.0:*               LISTEN      0          54571      -
      tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          47391      -
      tcp        0      0 127.0.0.1:38443         0.0.0.0:*               LISTEN      0          110744     -
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          53838      -
      tcp        0      0 0.0.0.0:5003            0.0.0.0:*               LISTEN      0          47389      -
      tcp        0      0 0.0.0.0:4045            0.0.0.0:*               LISTEN      0          55976      -
      tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          49341      -
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          22207      -
      tcp        0      0 0.0.0.0:32400           0.0.0.0:*               LISTEN      297536     82659      -
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          47393      -
      tcp6       0      0 2a02:8109:2740:2e30::53 :::*                    LISTEN      115492     172337     -
      tcp6       0      0 2a02:8109:2740:2e30::53 :::*                    LISTEN      115492     172336     -
      tcp6       0      0 2a02:8109:2740:2e30::53 :::*                    LISTEN      115492     172335     -
      tcp6       0      0 2a02:8109:2740:2e30::53 :::*                    LISTEN      115492     172334     -
      tcp6       0      0 fe80::211:32ff:fe9b::53 :::*                    LISTEN      115492     78692      -
      tcp6       0      0 fe80::211:32ff:fe9b::53 :::*                    LISTEN      115492     78691      -
      tcp6       0      0 fe80::211:32ff:fe9b::53 :::*                    LISTEN      115492     78690      -
      tcp6       0      0 fe80::211:32ff:fe9b::53 :::*                    LISTEN      115492     78689      -
      tcp6       0      0 ::1:53                  :::*                    LISTEN      115492     76533      -
      tcp6       0      0 ::1:53                  :::*                    LISTEN      115492     76532      -
      tcp6       0      0 ::1:53                  :::*                    LISTEN      115492     76531      -
      tcp6       0      0 ::1:53                  :::*                    LISTEN      115492     76530      -
      tcp6       0      0 :::21                   :::*                    LISTEN      0          54770      -
      tcp6       0      0 :::8086                 :::*                    LISTEN      1000       130412     -
      tcp6       0      0 :::662                  :::*                    LISTEN      0          36466      -
      tcp6       0      0 :::22                   :::*                    LISTEN      0          31034      -
      tcp6       0      0 :::631                  :::*                    LISTEN      0          59417      -
      tcp6       0      0 :::3000                 :::*                    LISTEN      472        124181     -
      tcp6       0      0 ::1:38008               :::*                    LISTEN      0          110743     -
      tcp6       0      0 :::443                  :::*                    LISTEN      0          47396      -
      tcp6       0      0 :::892                  :::*                    LISTEN      0          36199      -
      tcp6       0      0 :::445                  :::*                    LISTEN      0          53835      -
      tcp6       0      0 :::3261                 :::*                    LISTEN      0          48771      -
      tcp6       0      0 :::5566                 :::*                    LISTEN      0          77124      -
      tcp6       0      0 :::3263                 :::*                    LISTEN      0          49871      -
      tcp6       0      0 :::3264                 :::*                    LISTEN      0          49873      -
      tcp6       0      0 :::2049                 :::*                    LISTEN      0          55966      -
      tcp6       0      0 :::3265                 :::*                    LISTEN      0          51895      -
      tcp6       0      0 :::6690                 :::*                    LISTEN      0          106313     -
      tcp6       0      0 :::515                  :::*                    LISTEN      0          58487      -
      tcp6       0      0 :::61991                :::*                    LISTEN      1000       148897     -
      tcp6       0      0 :::6281                 :::*                    LISTEN      0          90992      -
      tcp6       0      0 :::873                  :::*                    LISTEN      0          54572      -
      tcp6       0      0 :::5001                 :::*                    LISTEN      0          47392      -
      tcp6       0      0 ::1:38443               :::*                    LISTEN      0          110745     -
      tcp6       0      0 :::139                  :::*                    LISTEN      0          53836      -
      tcp6       0      0 :::5003                 :::*                    LISTEN      0          47390      -
      tcp6       0      0 :::4045                 :::*                    LISTEN      0          55978      -
      tcp6       0      0 :::5357                 :::*                    LISTEN      0          49342      -
      tcp6       0      0 :::111                  :::*                    LISTEN      0          22210      -
      tcp6       0      0 :::80                   :::*                    LISTEN      0          47394      -
      udp        0      0 0.0.0.0:55696           0.0.0.0:*                           1000       151886     -
      udp        0      0 127.0.0.1:55957         0.0.0.0:*                           297536     96010      -
      udp        0      0 0.0.0.0:56016           0.0.0.0:*                           1000       142224     -
      udp        0      0 0.0.0.0:56346           0.0.0.0:*                           0          22206      -
      udp        0      0 0.0.0.0:44094           0.0.0.0:*                           1000       141012     -
      udp        0      0 0.0.0.0:56769           0.0.0.0:*                           1000       136498     -
      udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         36872      -
      udp        0      0 0.0.0.0:32410           0.0.0.0:*                           297536     96004      -
      udp        0      0 0.0.0.0:32412           0.0.0.0:*                           297536     96005      -
      udp        0      0 0.0.0.0:32413           0.0.0.0:*                           297536     96006      -
      udp        0      0 0.0.0.0:32414           0.0.0.0:*                           297536     96003      -
      udp        0      0 0.0.0.0:44880           0.0.0.0:*                           1000       138310     -
      udp        0      0 0.0.0.0:53169           0.0.0.0:*                           0          35295      -
      udp        0      0 0.0.0.0:4045            0.0.0.0:*                           0          55975      -
      udp        0      0 0.0.0.0:49146           0.0.0.0:*                           1000       135059     -
      udp        0      0 172.17.0.1:53           0.0.0.0:*                           115492     103335     -
      udp        0      0 172.17.0.1:53           0.0.0.0:*                           115492     103336     -
      udp        0      0 172.17.0.1:53           0.0.0.0:*                           115492     103334     -
      udp        0      0 172.17.0.1:53           0.0.0.0:*                           115492     103333     -
      udp        0      0 169.254.241.18:53       0.0.0.0:*                           115492     76521      -
      udp        0      0 169.254.241.18:53       0.0.0.0:*                           115492     76520      -
      udp        0      0 169.254.241.18:53       0.0.0.0:*                           115492     76519      -
      udp        0      0 169.254.241.18:53       0.0.0.0:*                           115492     76518      -
      udp        0      0 192.168.178.203:53      0.0.0.0:*                           115492     76513      -
      udp        0      0 192.168.178.203:53      0.0.0.0:*                           115492     76512      -
      udp        0      0 192.168.178.203:53      0.0.0.0:*                           115492     76511      -
      udp        0      0 192.168.178.203:53      0.0.0.0:*                           115492     76510      -
      udp        0      0 127.0.0.1:53            0.0.0.0:*                           115492     78684      -
      udp        0      0 127.0.0.1:53            0.0.0.0:*                           115492     78683      -
      udp        0      0 127.0.0.1:53            0.0.0.0:*                           115492     78682      -
      udp        0      0 127.0.0.1:53            0.0.0.0:*                           115492     78681      -
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          29720      -
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          22205      -
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          36521      -
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          170893     -
      udp        0      0 192.168.178.203:137     0.0.0.0:*                           0          170892     -
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          171950     -
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          170895     -
      udp        0      0 192.168.178.203:138     0.0.0.0:*                           0          170894     -
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          171951     -
      udp        0      0 127.0.0.1:161           0.0.0.0:*                           0          45471      -
      udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          36519      -
      udp        0      0 192.168.178.203:49483   0.0.0.0:*                           297536     96008      -
      udp        0      0 0.0.0.0:41316           0.0.0.0:*                           1000       145040     -
      udp        0      0 0.0.0.0:49618           0.0.0.0:*                           1000       145934     -
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       148908     -
      udp        0      0 169.254.241.18:49723    0.0.0.0:*                           297536     96015      -
      udp        0      0 127.0.0.1:619           0.0.0.0:*                           0          36388      -
      udp        0      0 0.0.0.0:41620           0.0.0.0:*                           1000       149081     -
      udp        0      0 0.0.0.0:662             0.0.0.0:*                           0          36457      -
      udp        0      0 0.0.0.0:892             0.0.0.0:*                           0          36193      -
      udp        0      0 169.254.241.18:37759    0.0.0.0:*                           297536     96009      -
      udp        0      0 192.168.178.203:33717   0.0.0.0:*                           297536     96014      -
      udp        0      0 0.0.0.0:41941           0.0.0.0:*                           1000       149120     -
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       151729     -
      udp        0      0 192.168.178.203:5353    0.0.0.0:*                           1000       143158     -
      udp        0      0 192.168.178.203:5353    0.0.0.0:*                           1000       143641     -
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          35293      -
      udp        0      0 127.0.0.1:54514         0.0.0.0:*                           297536     96007      -
      udp        0      0 0.0.0.0:58694           0.0.0.0:*                           1000       146404     -
      udp        0      0 0.0.0.0:38214           0.0.0.0:*                           1000       135736     -
      udp        0      0 0.0.0.0:42386           0.0.0.0:*                           1000       131903     -
      udp        0      0 0.0.0.0:42458           0.0.0.0:*                           1000       147997     -
      udp        0      0 0.0.0.0:54762           0.0.0.0:*                           1000       144365     -
      udp        0      0 0.0.0.0:42518           0.0.0.0:*                           1000       139000     -
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       141042     -
      udp        0      0 0.0.0.0:54877           0.0.0.0:*                           1000       150072     -
      udp        0      0 0.0.0.0:34406           0.0.0.0:*                           1000       134738     -
      udp        0      0 0.0.0.0:34425           0.0.0.0:*                           1000       151824     -
      udp        0      0 0.0.0.0:38577           0.0.0.0:*                           1000       148893     -
      udp        0      0 0.0.0.0:34528           0.0.0.0:*                           1000       6247571    -
      udp        0      0 192.168.178.203:46830   0.0.0.0:*                           297536     96011      -
      udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          29938      -
      udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          29937      -
      udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          29936      -
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          49219      -
      udp        0      0 0.0.0.0:1901            0.0.0.0:*                           297536     96013      -
      udp        0      0 0.0.0.0:51087           0.0.0.0:*                           1000       139389     -
      udp        0      0 169.254.241.18:42991    0.0.0.0:*                           297536     96012      -
      udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          55965      -
      udp        0      0 0.0.0.0:51385           0.0.0.0:*                           1000       141194     -
      udp        0      0 0.0.0.0:55516           0.0.0.0:*                           1000       154626     -
      udp        0      0 0.0.0.0:43312           0.0.0.0:*                           1000       142990     -
      udp6       0      0 :::3702                 :::*                                99         36874      -
      udp6       0      0 :::4045                 :::*                                0          55977      -
      udp6       0      0 2a02:8109:2740:2e30::53 :::*                                115492     172333     -
      udp6       0      0 2a02:8109:2740:2e30::53 :::*                                115492     172332     -
      udp6       0      0 2a02:8109:2740:2e30::53 :::*                                115492     172331     -
      udp6       0      0 2a02:8109:2740:2e30::53 :::*                                115492     172330     -
      udp6       0      0 fe80::211:32ff:fe9b::53 :::*                                115492     76537      -
      udp6       0      0 fe80::211:32ff:fe9b::53 :::*                                115492     76536      -
      udp6       0      0 fe80::211:32ff:fe9b::53 :::*                                115492     76535      -
      udp6       0      0 fe80::211:32ff:fe9b::53 :::*                                115492     76534      -
      udp6       0      0 ::1:53                  :::*                                115492     76529      -
      udp6       0      0 ::1:53                  :::*                                115492     76528      -
      udp6       0      0 ::1:53                  :::*                                115492     76527      -
      udp6       0      0 ::1:53                  :::*                                115492     76526      -
      udp6       0      0 :::111                  :::*                                0          22208      -
      udp6       0      0 :::123                  :::*                                0          36522      -
      udp6       0      0 ::1:323                 :::*                                0          36520      -
      udp6       0      0 :::37315                :::*                                0          35296      -
      udp6       0      0 :::662                  :::*                                0          36464      -
      udp6       0      0 :::892                  :::*                                0          36197      -
      udp6       0      0 :::5353                 :::*                                0          35294      -
      udp6       0      0 :::58682                :::*                                0          22209      -
      udp6       0      0 :::2049                 :::*                                0          55967      -
      2024-02-22 15:53:42.856  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef62c9c" connected!
      2024-02-22 15:53:47.028  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef5afd0" connected!
      2024-02-22 15:53:49.586  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-4855199c1ee8 / shellyplus1pm#4855199c1ee8#1) (false)
      2024-02-22 15:53:52.654  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-0cdc7ef6696c / shellyplus1pm#0cdc7ef6696c#1) (false)
      2024-02-22 15:53:52.679  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-4855199d205c" connected!
      2024-02-22 15:53:52.854  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-0cdc7ef62c9c / shellyplus1pm#0cdc7ef62c9c#1) (false)
      2024-02-22 15:53:54.229  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-4855199d1ee8" connected!
      2024-02-22 15:53:56.551  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef62910" connected!
      2024-02-22 15:53:57.025  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-0cdc7ef5afd0 / shellyplus1pm#0cdc7ef5afd0#1) (false)
      2024-02-22 15:53:57.950  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef5a954" connected!
      2024-02-22 15:54:01.850  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-0cdc7ef62cbc" connected!
      2024-02-22 15:54:02.131  - info: shelly.1 (450) [MQTT] Device with client id "shellyplus1pm-4855199cfa60" connected!
      2024-02-22 15:54:02.670  - info: shelly.1 (450) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-4855199d205c / shellyplus1pm#4855199d205c#1) (false)
      • OliverIO
        OliverIO @Dr.Pie last edited by
        @dr-pie
        Ich tippe mal ein Problem mit dem device watcher.
        Lese mal hier.
        https://github.com/ciddi89/ioBroker.device-watcher/issues/283
        Stoppe mal den Adapter ob sich dann die Auslastung normalisiert.
        Dr.Pie 2 Replies Last reply Reply Quote 0
        • Dr.Pie
          Dr.Pie @OliverIO last edited by
          @oliverio sagte in Teilweise über 200% CPU Auslastung im Docker:
          @dr-pie
          Lese mal hier.
          Ich komme ja nicht auf die iob-Oberfläche.
          Der Editor funktioniert nach ca. 15 Minuten. Auch die Vis ist verfügbar.Jeder klick in der Vis bedeutet aber waaaaarten
          • Dr.Pie
            @dr-pie
            In einer Millisekunde konnte ich auf den iob kommen.
            Habe dann den "device watcher" angehalten ... und siehe da ...die CPU Auslastung normalisierte sich wieder.
            • OliverIO
              @dr-pie
              Man kann Adapter auch über console Befehle starten und stoppen
              Dr.Pie 1 Reply Last reply Reply Quote 0
              • Dr.Pie
                @dr-pie
                Hab ich gerade raus gefunden. 👍 👍 👍
                • Glasfaser
                  Glasfaser last edited by
                  Docker : v8.0.1
                  /usr/bin/npm 9.6.7
                  /usr/bin/npx 9.6.7
                  nodejs:
                  Docker Image ist alt und du bleibst auf der nodejs Version stehen .
                  • Dr.Pie
                    Dr.Pie @Glasfaser last edited by
                    @glasfaser sagte in Teilweise über 200% CPU Auslastung im Docker:
                    Docker : v8.0.1
                    /usr/bin/npm 9.6.7
                    /usr/bin/npx 9.6.7
                    nodejs:
                    Liegt vielleicht daran dass ich nicht wirklich weiss wie 🙇‍♂️
                    OliverIO Glasfaser 2 Replies Last reply Reply Quote 0
                    • OliverIO
                      OliverIO @Dr.Pie last edited by OliverIO
                      @dr-pie
                      hach, wenn es nur eine beschreibung dafür geben würde, wo das alles genauch beschrieben ist.
                      huch
                      https://docs.buanet.de/de/iobroker-docker-image/docs/#hochrustung-upgrade
                      oder alternativ die ältere doku für portainer
                      https://smarthome.buanet.de/2020/10/iobroker-docker-container-updates-upgrades/
                      • Glasfaser
                        Glasfaser @Dr.Pie last edited by
                        Jein ...
                        Aber @OliverIO hat dir schon ein Tip zur Auslastung von einem bestimmten Adapter genannt , der hier bei vielen Probleme macht !
                        Und das mit der Synology Anzeige / Diagramm ist ein Schätzeisen ...
                        aber das Thema haben ich und @OliverIO schon mehrmals hier im Forum durchgekaut .
                        648
