    3. Off Topic
    4. Grafana
    5. Grafana startet nicht mehr nach Anpassungen in grafana.ini
      wibear last edited by
      Liebes Forum, nachdem ich versucht habe, grafana.ini im Kapitel SMTP für Email Alerting anzupassen, gab es zuerst eine Fehlermeldung und danach stürzte Grafana ab. Obwohl ich alle Änderungen in grafana.ini rückgängig gamacht habe, startet Grafana nicht mehr.
      Ein Log-Auszug aus status:
      logger=authn.service t=2024-02-23T10:25:47.727674047+01:00 level=warn msg="Failed to authenticate request" client=auth.client.session error="user token not found"
      logger=context userId=0 orgId=1 uname= t=2024-02-23T10:25:47.731032945+01:00 level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=192.168.178.33 time_ms=4 duration=4.332429ms size=0 referer= handle>
      logger=authn.service t=2024-02-23T10:25:48.039858131+01:00 level=warn msg="Failed to authenticate request" client=auth.client.session error="user token not found"
      logger=context userId=0 orgId=1 uname= t=2024-02-23T10:25:48.043068977+01:00 level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=192.168.178.33 time_ms=4 duration=4.13649ms size=0 referer= handler>
      logger=authn.service t=2024-02-23T10:25:48.807421902+01:00 level=warn msg="Failed to authenticate request" client=auth.client.session error="user token not found"
      logger=authn.service t=2024-02-23T10:25:48.825884331+01:00 level=warn msg="Failed to authenticate request" client=auth.client.session error="user token not found"
      logger=context userId=1 orgId=1 uname=admin t=2024-02-23T15:18:08.307789143+01:00 level=info msg="Not found" error="[publicdashboards.notFound] FindByDashboardUid: Public dashboard not found by orgId: 1 and dashboardUid: ece513e1->
      logger=context userId=1 orgId=1 uname=admin t=2024-02-23T15:18:08.308084469+01:00 level=info msg="Request Completed" method=GET path=/api/dashboards/uid/ece513e1-76f5-4986-9a56-f12bda09f3e5/public-dashboards status=404 remote_addr>
      logger=authn.service t=2024-02-23T15:18:51.237613838+01:00 level=warn msg="Failed to authenticate request" client=auth.client.session error="user token not found"
      loggger=authn.service t=2024-02-23T15:18:52.551637332+01:00 level=warn msg="Failed to authenticate request" client=auth.client.session error="user token not found"
      logger=context userId=0 orgId=1 uname= t=2024-02-23T15:18:52.554469082+01:00 level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=192.168.178.33 time_ms=3 duration=3.596029ms size=0 referer= handle>
      logger=authn.service t=2024-02-23T15:18:53.039540135+01:00 level=warn msg="Failed to authenticate request" client=auth.client.session error="user token not found"
      logger=context userId=0 orgId=1 uname= t=2024-02-23T15:18:53.042234721+01:00 level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=192.168.178.33 time_ms=3 duration=3.446847ms size=0 referer= handle>
      logger=authn.service t=2024-02-23T15:18:53.292821647+01:00 level=warn msg="Failed to authenticate request" client=auth.client.session error="user token not found"
      logger=authn.service t=2024-02-23T15:18:53.338587547+01:00 level=warn msg="Failed to authenticate request" client=auth.client.session error="user token not found"
      logger=settings t=2024-02-23T18:34:08.69127539+01:00 level=error msg="failed to parse "/etc/grafana/grafana.ini": key-value delimiter not found: w##################### Grafana Configuration Example #####################\n"
      logger=settings t=2024-02-23T18:34:09.543904098+01:00 level=error msg="failed to parse "/etc/grafana/grafana.ini": key-value delimiter not found: w##################### Grafana Configuration Example #####################\n"
      Grafana Version: 10.3.3
      Raspberry 4 mit IOBroker und Grafana bereits neu gestartet.
      Reinstall auch ausgeführt: sudo apt install --reinstall grafana
      Bitte um Hinweise.
      Danke im Voraus und Grüße
      arteck Marc Berg 2 Replies Last reply Reply Quote 0
        arteck Developer Most Active @wibear last edited by arteck
        @wibear sagte in Grafana startet nicht mehr nach Anpassungen in grafana.ini:
        Bitte um Hinweise.
        die stehen da im log
        Grafana kann mit der influxdb nicht kommunizieren da der token fehlt
        ausserdem ist da ein fehler in der /etc/grafana/grafana.ini
        irgendwo hast du zu viel oder zu wenig zurückgesetzt
          wibear @arteck last edited by
          @arteck Kann ich es noch retten? Was schlägst Du vor? Danke.
          • Marc Berg
            Marc Berg Most Active @wibear last edited by Marc Berg
            Wie @arteck schon schrieb, in deiner grafana.ini steht offenbar Grütze. Die musst du korrigieren/Backup zurückspielen.
            Das ist in diesem Fall kein InfluxDB Token, sondern der interne Grafana-Token, der bei der Anmeldung erzeugt und in einem Cookie gespeichert wird. Du könntest versuchen, Cookies in deinem Browser zu löschen. In jedem Fall muss aber vorher die grafana.ini sauber sein.
            grafana grafana.ini
