    4. Parameter begrenzen (oder shedulen) in Modbus
      Delphinis @arteck last edited by
      @arteck said in Parameter begrenzen (oder shedulen) in Modbus:
      kannst du in der konsole aufrufen
      C:\ioBroker>iob diag
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
        iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
        iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
        iobroker rebuild [<module>]                                  Rebuild all native modules or path
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
        iobroker object                                              Object management  [aliases: o]
        iobroker state                                               State management  [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation  [aliases: id]
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
        arteck Developer Most Active @Delphinis last edited by arteck
        @delphinis ja auf windows gehts nich
        machmal
        iobroker info
          die ip adresse passt da nicht
          check deine Einstellungen
          Muss da nicht die IP des WR rein?
          Ping auf diese Adresse geht.
            @delphinis ja da muss die WR ip rein
            hier steht aber was anderes
            und firewall regel checken.. nicht das die dir was blockieren
              Delphinis @arteck last edited by Delphinis
              @arteck Ach so, mein Fehler, hab inzwischen eine neue Instanz von Modbus gemacht, um auf der frischen Wiese anzfangen und da war diese noch falsch.
                @delphinis mach den noch rein
                und lass vorerst nur EINE instanz auf den WR
                  mach den noch rein
                  Hab ich gemacht. Leider keine Änderung. Auch im Log die selben Meldungen.
                  Mach ich schon
                  Firewall hab ich alles abgeschalet, was ich in den Einstellungen gefunden hab (Win 11)
                    @delphinis dann starte den WR mal neu
                      @arteck
                      Mach ich dann abends, mal. Jetzt ist der voll am Regeln und ich will gerade kein Stromausfall
                      Aber ich hab schon den Modbus im WR deaktiviert und wieder aktiviert, damit konnte ich schon mal das Problem beheben.
                      Hat aber heute nichts gebracht...
                      Aber was mir noch aufgefallen ist:
                      Die neue Instanz von Modbus hat eine neue Kollonne namens Slave-ID (zweite von links):
                      Ach so ist das wegen "Mehrere Geräte ID's"?
                        @delphinis da muss eine 3 rein
                        ist standard im wR hinterlegt... und wiso solltest du Stromausfall haben wenn der WR neu gestartet wird..
                          @arteck
                          Da ist mein Hausnetz dran
                          Ich weiss ehrlich gesagt auch gerade nicht wie man den neu startet.
                            @delphinis sagte in Parameter begrenzen (oder shedulen) in Modbus:
                            hä........
                            auf der linken Seite ist ein Schalter
                            ich will dir nicht zu nahe tretten ..aber Grundkentnisse solltest du schon haben wenn du mit Modbus rumhantieren willst
                            D W 2 Replies Last reply Reply Quote 0
                              @arteck
                              Ist das ein Missverständnis wegen der Abkürzung? Ich meine WR = Wechselrichter
                                Der schaltet nur die PV weg.
                                  So,
                                  hab jetzt den WR geresettet,
                                  die Verbindung zum Modbus läuft jetzt wieder....
                                    warp735 @arteck last edited by
                                    @arteck sagte in Parameter begrenzen (oder shedulen) in Modbus:
                                    hä........
                                    scheint für dich ein Unding zu sein? Bei uns hängt auch das komplette Haus am WR. Hat den Vorteil, bei Stromausfall wird in 4ms auf Backup umgeschaltet und keiner bekommt den Stromausfall mit.
                                    Nachteil: fahr ich den WR runter, ist die Bude dunkel 😉
                                      Delphinis @warp735 last edited by Delphinis
                                      @warp735
                                      Leider hat der modbus nach Neustart des PC's wieder nicht mehr funktioniert.
                                      Eventuell hab ich das Problem aber jetzt gefunden. Ich hab die Option "Modbus P-Vorgaben auf Eingang 2" rausgenommen. Ich weiss zwar nicht was das ist, aber Modbus geht jetzt und das sunnyportal liefert auch seine Werte immer noch.
                                      In der Beschreibung steht:
                                      "Wirkleistungsvorgaben über Modbus werden auf Sollwerteingang 2 verarbeitet. Dadurch ist der Parallelbetrieb mit SMA Anlagensteuerung möglich."
                                      Hab ich wohl nicht...
                                      Aber ich bin immer noch unsicher, weil ich nicht genau weiss was das ist und auch im INet nichts genaueres darüber erfahren habe.
                                      Ich weiss nicht, ob das was mit der Begrenzung der Wirkleistung tun hat, was bei mir aber nicht notwendig ist.
                                      Sonst ist das Verhalten von WR, Solar und Batt normal.
                                      Ob das ganze anhält, werde ich morgen sehen, wenn ich den PC wieder über Nacht runterfahre. (Hab den iobroker im Moment nur zum testen/konfigurieren am Windows PC, den ich Nachts natürlich runter fahre. Ich werds auch gleich jetzt zum Test nochmals tun, um zu schauen, ob es mit dem Runter Fahren des iobrokers zu tun hat.
                                      So, hab jetzt den PC neu gestartet und der Modbus läuft jetzt immer noch/wieder.
                                        Delphinis @Delphinis last edited by
                                        Nach ein paar Stunden ist der Modbus wieder ausgefallen, das war also noch nicht die Lösung.
                                        Mir ist aufgefallen, dass der PC in den Standby gegangen ist. Könnte das das Problem sein, dass der Modbus sich aufhängt?
                                        • wendy2702
                                          wendy2702 @Delphinis last edited by
                                          @delphinis Welcher PC geht in den Standby? Der auf dem iobroker läuft bzw. die Modbus Instanz läuft?
                                            Delphinis @wendy2702 last edited by Delphinis
                                            @wendy2702
                                            Der auf dem iobroker läuft, das andere ist der Wechselrichter, der läuft immer.
                                            Ich hab den auf dem PC, weil da die Konfiguration einfacher ist und kopier das dann auf den Rechner wo es dann fortlaufend laufen soll.
                                            Ich schalte das Standby mal ab. Aber im Moment läuft es wieder nicht. Muss wohl wieder den WR reseten (vom Strom trennen). Aber das ist nicht so toll wenn alle im Haushalt Strom/Internet wollen 🙂
                                            Und das kann ja nicht die Lösung sein...
                                            1184
