Zigbee-Adapter zickt. Flashen lassen oder tauschen?
Oben habe ich eine LOG gepostet nach einem kompletten Neustart des Raspi. Soll ich das wiederholen?
@dexic sagte in Zigbee-Adapter zickt. Flashen lassen oder tauschen?:
ich will jetzt sehen..
adapter stop..adapter starten.. dann posten..
@dexic von debug Einstellung war nicht die rede...
also noch mal... und nochmal 50 Zeilen pi mal auge NACH ADAPTER START.. nicht das komplette LOG
@arteck
Ich hoffe, das passt jetzt. Sorry für das Missverständnis.zigbee.0 2024-02-24 09:38:53.568 warn DeviceAvailability:Failed to ping 0xa4c13872a43d86fd TS011F zigbee.0 2024-02-24 09:38:53.553 warn DeviceAvailability:Failed to ping 0xa4c1381cbfd11d66 TS011F zigbee.0 2024-02-24 09:38:53.537 warn DeviceAvailability:Failed to ping 0xa4c138867bdf42a2 TS011F zigbee.0 2024-02-24 09:38:53.520 warn DeviceAvailability:Failed to ping 0xa4c138de74061d48 TS011F zigbee.0 2024-02-24 09:38:53.504 warn DeviceAvailability:Failed to ping 0xa4c1386363b09d42 TS011F zigbee.0 2024-02-24 09:38:53.488 warn DeviceAvailability:Failed to ping 0xa4c1389f9914931e TS011F zigbee.0 2024-02-24 09:38:53.472 warn DeviceAvailability:Failed to ping 0xa4c138e7c52b7d7f TS011F zigbee.0 2024-02-24 09:38:53.429 warn DeviceAvailability:Failed to ping 0xa4c138d046d9d5ae TS011F zigbee.0 2024-02-24 09:38:47.367 info debug devices set to [] zigbee.0 2024-02-24 09:38:47.031 info Zigbee started zigbee.0 2024-02-24 09:38:47.030 info 0xa4c13872a43d86fd (addr 47187): A1Z - Nous Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 09:38:47.027 info 0xa4c1381cbfd11d66 (addr 50830): A1Z - Nous Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 09:38:47.024 info 0xa4c138867bdf42a2 (addr 22255): A1Z - Nous Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 09:38:47.021 info 0xa4c138de74061d48 (addr 32429): A1Z - Nous Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 09:38:47.018 info 0x00158d000949a629 (addr 29713): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2024-02-24 09:38:47.016 info 0x00158d0009451e5b (addr 13394): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice) zigbee.0 2024-02-24 09:38:47.013 info 0x00158d0008746aee (addr 58357): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice) zigbee.0 2024-02-24 09:38:47.009 info 0x00158d0008dffe7e (addr 56436): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice) zigbee.0 2024-02-24 09:38:47.006 info 0x00158d0008d02230 (addr 31821): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice) zigbee.0 2024-02-24 09:38:47.002 info 0x00158d00094651c7 (addr 29657): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2024-02-24 09:38:46.999 info 0x00158d00091b229a (addr 43507): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2024-02-24 09:38:46.997 info 0xa4c1386363b09d42 (addr 37503): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 09:38:46.994 info 0xa4c1389f9914931e (addr 51274): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 09:38:46.991 info 0x00158d00094651a4 (addr 60844): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2024-02-24 09:38:46.989 info 0x003c84fffed660a9 (addr 62062): BRT-100-TRV - Moes Thermostatic radiator valve (EndDevice) zigbee.0 2024-02-24 09:38:46.975 info 0xa4c138e7c52b7d7f (addr 38827): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 09:38:46.967 info 0xa4c138d046d9d5ae (addr 102): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 09:38:46.888 info Currently 17 devices are joined: zigbee.0 2024-02-24 09:38:46.869 info --> transmitPower : high+ zigbee.0 2024-02-24 09:38:46.848 info Unable to disable LED, unsupported function. zigbee.0 2024-02-24 09:38:46.831 info Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}} zigbee.0 2024-02-24 09:38:42.086 info Installed Version: iobroker.zigbee@1.10.1 zigbee.0 2024-02-24 09:38:41.795 info Starting Zigbee npm ... zigbee.0 2024-02-24 09:38:41.793 info delete old Backup files. keep only last 10 zigbee.0 2024-02-24 09:38:41.693 info starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.19 host.raspberrypi 2024-02-24 09:38:37.278 info instance system.adapter.zigbee.0 started with pid 5548 host.raspberrypi 2024-02-24 09:38:37.234 info "system.adapter.zigbee.0" enabled host.raspberrypi 2024-02-24 09:38:34.825 info instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) zigbee.0 2024-02-24 09:38:34.250 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason zigbee.0 2024-02-24 09:38:34.248 info terminating host.raspberrypi 2024-02-24 09:38:33.830 info stopInstance system.adapter.zigbee.0 send kill signal zigbee.0 2024-02-24 09:38:33.751 info Zigbee: disabling joining new devices. zigbee.0 2024-02-24 09:38:33.747 info cleaned everything up... zigbee.0 2024-02-24 09:38:33.744 info Got terminate signal TERMINATE_YOURSELF host.raspberrypi 2024-02-24 09:38:33.732 info stopInstance system.adapter.zigbee.0 (force=false, process=true) -
TS011F
sieht doch gut aus...
musst nur die
0xa4c138d046d9d5ae TS011Fneu anlernen
@dexic mach erstmal.. wenn die Router im netz sind kann sein dass der rest dann von sich aus rein kommt.
machmal bitte
https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
und schau nochmal.. kein plan warum der pairing modus nicht startet
@arteck said in Zigbee-Adapter zickt. Flashen lassen oder tauschen?:
Den USB-Adapter habe ich am RPi schon getauscht. Jetzt kommt beim Einschalten des Kopplungsmodus dieser komische Fehler im Schirm.
GIT-Install habe ich durchgeführt mit exit code = 0, also problemlos. Das ist das Ergebnis:
Leider bleiben die Geräte alle weiterhin unverbunden. Das Protokoll sagt jetzt:
zigbee.0 2024-02-24 11:03:40.839 warn DeviceAvailability:Failed to ping 0xa4c13872a43d86fd TS011F zigbee.0 2024-02-24 11:03:40.820 warn DeviceAvailability:Failed to ping 0xa4c1381cbfd11d66 TS011F zigbee.0 2024-02-24 11:03:40.805 warn DeviceAvailability:Failed to ping 0xa4c138867bdf42a2 TS011F zigbee.0 2024-02-24 11:03:40.789 warn DeviceAvailability:Failed to ping 0xa4c138de74061d48 TS011F zigbee.0 2024-02-24 11:03:40.753 warn DeviceAvailability:Failed to ping 0xa4c1386363b09d42 TS011F zigbee.0 2024-02-24 11:03:40.734 warn DeviceAvailability:Failed to ping 0xa4c1389f9914931e TS011F zigbee.0 2024-02-24 11:03:40.718 warn DeviceAvailability:Failed to ping 0xa4c138e7c52b7d7f TS011F zigbee.0 2024-02-24 11:03:40.702 warn DeviceAvailability:Failed to ping 0xa4c138d046d9d5ae TS011F zigbee.0 2024-02-24 11:03:34.022 info debug devices set to [] zigbee.0 2024-02-24 11:03:33.886 info Zigbee started zigbee.0 2024-02-24 11:03:33.885 info 0xa4c13872a43d86fd (addr 47187): A1Z - Nous Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 11:03:33.883 info 0xa4c1381cbfd11d66 (addr 50830): A1Z - Nous Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 11:03:33.880 info 0xa4c138867bdf42a2 (addr 22255): A1Z - Nous Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 11:03:33.877 info 0xa4c138de74061d48 (addr 32429): A1Z - Nous Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 11:03:33.873 info 0x00158d000949a629 (addr 29713): MCCGQ11LM - Aqara Door and window sensor (EndDevice) zigbee.0 2024-02-24 11:03:33.871 info 0x00158d0009451e5b (addr 13394): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) zigbee.0 2024-02-24 11:03:33.868 info 0x00158d0008746aee (addr 58357): DJT11LM - Aqara Vibration sensor (EndDevice) zigbee.0 2024-02-24 11:03:33.865 info 0x00158d0008dffe7e (addr 56436): SJCGQ11LM - Aqara Water leak sensor (EndDevice) zigbee.0 2024-02-24 11:03:33.861 info 0x00158d0008d02230 (addr 31821): WXKG11LM - Aqara Wireless mini switch (EndDevice) zigbee.0 2024-02-24 11:03:33.857 info 0x00158d00094651c7 (addr 29657): MCCGQ11LM - Aqara Door and window sensor (EndDevice) zigbee.0 2024-02-24 11:03:33.855 info 0x00158d00091b229a (addr 43507): MCCGQ11LM - Aqara Door and window sensor (EndDevice) zigbee.0 2024-02-24 11:03:33.852 info 0xa4c1386363b09d42 (addr 37503): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 11:03:33.850 info 0xa4c1389f9914931e (addr 51274): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 11:03:33.847 info 0x00158d00094651a4 (addr 60844): MCCGQ11LM - Aqara Door and window sensor (EndDevice) zigbee.0 2024-02-24 11:03:33.844 info 0x003c84fffed660a9 (addr 62062): BRT-100-TRV - Moes Thermostatic radiator valve (EndDevice) zigbee.0 2024-02-24 11:03:33.830 info 0xa4c138e7c52b7d7f (addr 38827): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 11:03:33.822 info 0xa4c138d046d9d5ae (addr 102): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2024-02-24 11:03:33.742 info Currently 17 devices are joined: zigbee.0 2024-02-24 11:03:33.718 info --> transmitPower : high+ zigbee.0 2024-02-24 11:03:33.693 info Unable to disable LED, unsupported function. zigbee.0 2024-02-24 11:03:33.669 info Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}} zigbee.0 2024-02-24 11:03:29.107 info Installed Version: ioBroker/ioBroker.zigbee#789c70c588651e4a06ba495ddf572adb8d9a1b7c zigbee.0 2024-02-24 11:03:28.741 info Starting Zigbee npm ... zigbee.0 2024-02-24 11:03:28.739 info delete old Backup files. keep only last 10 zigbee.0 2024-02-24 11:03:28.637 info starting. Version 1.10.2 (non-npm: ioBroker/ioBroker.zigbee#789c70c588651e4a06ba495ddf572adb8d9a1b7c) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.19 host.raspberrypi 2024-02-24 11:03:23.952 info instance system.adapter.zigbee.0 started with pid 5990 host.raspberrypi 2024-02-24 11:03:23.876 info "system.adapter.zigbee.0" enabled host.raspberrypi 2024-02-24 11:03:22.208 info instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) -
@dexic kannst du jetzt das pairing starten ?
@arteck
Nein, noch immer nicht.
Ich bin ratlos... -
Soll ich mal einen Sonoff testen?
Was ist denn ein brauchbarer Zigbee Stick ? (CC2652P, Sonoff...?) -
@dexic poste mal den fehler ..nachdem du auf pairing gedrückt hast
Das passiert mit dem CC2652P, den ich als Ersatz für den 2531 genommen habe. Den Sonoff habe ich noch nicht ausprobiert.
Error: Failed to open the network: Error: SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)') at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:320:27 at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:206:13 at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at ZStackAdapter.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:203:9) at Controller.permitJoinInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:246:13) at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:234:9) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:521:17). undefined Pairing started -
@dexic installier nochmal von GIT
Kurzer Kommentar: Der Fehler war vor und nach der Installation von GIT der gleiche. Ich wiederhole jetzt die Installation und prüfe dann die Fehlermeldung.
- Installation von GIT
Exit code 0 - Neustart des RPi
Laut Protokoll konnten nur die TS011F Steckdosen nicht angepingt werden - Prüfung der Fehlermeldung beim Koppeln
Die gleiche Fehlermeldung wie sonst auch.
Ich werde morgen mal den Sonoff auspacken und testen.
So, Zwischenstand. Der Sonoff 3.0 scheint halbwegs durchzukommen. Ich bekomme Stück um Stück immer mehr alte Verbindungen erneuert. Mal sehen, ob morgen noch mehr Verbindungen dazu kommen, dann lasse ich es weiterlaufen.
Liebe Gemeinde,
wie gehe ich jetzt mit den letzten vier Zigbee-Geräten um, die sich noch nicht ans Netz gehängt haben? Den Außentemperatursensor (https://www.zigbee2mqtt.io/devices/WSDCGQ11LM.html) ich in den Kopplungsmodus gebracht (Taste lange halten, blaue LED blinkt) und das Pairing gestartet, jedoch ohne Erfolg. Direkt ein Stockwerk unten drunter sind zwei Zigbee-Steckdosen, die die Verbindung herstellen sollten, oder denke ich da falsch? Muss ich mit den Geräten zurück zum RasPi und dort neu koppeln? Was ist in so einem Fall die empfohlene Vorgehensweise?
Vielen Dank!
@dexic welche Steckdosen sind das.. und sind die schon im Netz ??
