    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
      Thomas Braun Most Active @Thisoft last edited by
      @thisoft sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
      zwischendurch auch paar zweifelhafte Meldungen zur nodejs-Version kamen.
      Welche genau?
      Ich vermute eher, das dein Setup da 'zweifelhaft' ist...
      iob diag
      sagt?
      Thisoft 1 Reply Last reply Reply Quote 0
      • Thisoft
        Thisoft @Thomas Braun last edited by
                                v.2023-10-10
         Static hostname: iob-ubuntu
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Ubuntu 22.04.4 LTS
                  Kernel: Linux 5.15.0-97-generic
            Architecture: x86-64
         Hardware Vendor: QEMU
          Hardware Model: Standard PC _i440FX + PIIX, 1996_
        Installation:           kvm
        Kernel:                 x86_64
        Userland:               amd64
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               false
        Boot Target:            graphical.target
        Pending OS-Updates:     0
        Pending iob updates:    6
        Nodejs-Installation:    /usr/bin/nodejs         v18.19.1
                                /usr/bin/node           v18.19.1
                                /usr/bin/npm            10.2.4
                                /usr/bin/npx            10.2.4
                                /usr/bin/corepack       0.22.0
        Recommended versions are nodejs Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
        18.19.1 and npm Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
        10.2.4
        MEMORY:
        Mem:            7.9G        206M        6.3G        1.0M        1.5G        7.4G
        Swap:           3.1G          0B        3.1G
        Total:           11G        206M        9.4G
        Active iob-Instances:   1
        Active repo(s): beta
        ioBroker Core:          js-controller           5.0.19
                                admin                   6.13.21
        ioBroker Status:        Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
          system.adapter.admin.0                  : admin                 : iob-ubuntu                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.web.0                    : web                   : iob-ubuntu                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                16769
        States:                 12169
        Size of iob-Database:
        19M     /opt/iobroker/iobroker-data/objects.jsonl
        4.6M    /opt/iobroker/iobroker-data/states.jsonl
          Thomas Braun Most Active last edited by Thomas Braun
          Hau die Updates druff.
          Und dann die Langfassung bitte.
          Und schau mal danach:
          du -h /opt/iobroker/iobroker-data/backup-objects/
          https://forum.iobroker.net/topic/54655/probleme-von-4-0-21-auf-4-0-23/16
          • Thisoft
            @thomas-braun sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
            109M    /opt/iobroker/iobroker-data/backup-objects/
            Und hier die Langfassung von iob diag:
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Chassis: vm
              Virtualization: kvm
            model name      : Common KVM processor
            Docker          : false
            Virtualization  : kvm
            Kernel          : x86_64
            Userland        : amd64
            Systemuptime and Load:
             10:28:27 up 10:25,  2 users,  load average: 0.19, 0.29, 0.21
            CPU threads: 8
            *** Time and Time Zones ***
                           Local time: Sat 2024-02-24 10:28:27 CET
                       Universal time: Sat 2024-02-24 09:28:27 UTC
                             RTC time: Sat 2024-02-24 09:28:27
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            iobroker
            /home/iobroker
            iobroker adm tty dialout cdrom sudo audio dip video plugdev lxd
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            7.9G        2.9G        3.3G        1.0M        1.8G        4.8G
            Swap:           3.1G          0B        3.1G
            Total:           11G        2.9G        6.4G
                     7937 M total memory
                     2872 M used memory
                      748 M active memory
                     3401 M inactive memory
                     3262 M free memory
                      269 M buffer memory
                     1532 M swap cache
                     3114 M total swap
                        0 M used swap
                     3114 M free swap
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            Filesystem                        Type   Size  Used Avail Use% Mounted on
            tmpfs                             tmpfs  794M  1.1M  793M   1% /run
            /dev/mapper/ubuntu--vg-ubuntu--lv ext4    15G   12G  2.3G  84% /
            tmpfs                             tmpfs  3.9G     0  3.9G   0% /dev/shm
            tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
            /dev/sda2                         ext4   2.0G  251M  1.6G  14% /boot
            //192.168.137.42/motion           cifs   869G  840G   30G  97% /var/lib/motion/NAS
            tmpfs                             tmpfs  794M  4.0K  794M   1% /run/user/1000
            [Sat Feb 24 00:03:06 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
            [Sat Feb 24 00:03:07 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
            [Sat Feb 24 00:03:08 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
            TARGET                SOURCE                            FSTYPE   OPTIONS
            /                     /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
            |-/snap/core20/2105   /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/core20/2182   /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/lxd/27037     /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/lxd/26975     /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/snapd/20671   /dev/loop5                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/snapd/20290   /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
            |-/boot               /dev/sda2                         ext4     rw,relatime
            `-/var/lib/motion/NAS //192.168.137.42/motion           cifs     rw,relatime,vers=default,cache=strict,username=motion,uid=1001,forceuid,gid=0,noforcegid,addr=192.168.137.42,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
            /var:
            3.9G    /var/
            3.0G    /var/lib
            2.2G    /var/lib/motion/NAS
            1.9G    /var/lib/motion/NAS/Cam4
            Archived and active journals take up 384.1M in the file system.
            /opt/iobroker/backups:
            4.0K    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            346M    /opt/iobroker/iobroker-data/
            199M    /opt/iobroker/iobroker-data/files
            57M     /opt/iobroker/iobroker-data/files/javascript.admin
            38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
            31M     /opt/iobroker/iobroker-data/objects.jsonl
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
            8.2M    /opt/iobroker/iobroker-data/states.jsonl
            7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
            USB-Devices by-id:
            *** NodeJS-Installation ***
            /usr/bin/npm            10.2.4
            /usr/bin/npx            10.2.4
            nodejs:
              Installed: 18.19.1-1nodesource1
              Candidate: 18.19.1-1nodesource1
              Version table:
             *** 18.19.1-1nodesource1 100
                    100 /var/lib/dpkg/status
                 12.22.9~dfsg-1ubuntu3.3 500
                    500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                    500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                 12.22.9~dfsg-1ubuntu3 500
                    500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.19
            admin:          6.14.1
            javascript:     7.8.0
            Adapters from github:   1
            Adapter State
            + system.adapter.admin.0                  : admin                 : iob-ubuntu                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.alias-manager.0          : alias-manager         : iob-ubuntu                               - disabled
            + system.adapter.backitup.0               : backitup              : iob-ubuntu                               -  enabled
              system.adapter.daswetter.0              : daswetter             : iob-ubuntu                               -  enabled
              system.adapter.daswetter.1              : daswetter             : iob-ubuntu                               - disabled
              system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iob-ubuntu                               - disabled
              system.adapter.feiertage.0              : feiertage             : iob-ubuntu                               -  enabled
              system.adapter.flot.0                   : flot                  : iob-ubuntu                               - disabled
              system.adapter.gruenbeck.0              : gruenbeck             : iob-ubuntu                               - disabled
            + system.adapter.hm-rega.0                : hm-rega               : iob-ubuntu                               -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iob-ubuntu                               -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : iob-ubuntu                               -  enabled, port: 0
              system.adapter.homeconnect.0            : homeconnect           : iob-ubuntu                               - disabled
              system.adapter.ical.0                   : ical                  : iob-ubuntu                               -  enabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : iob-ubuntu                               - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iob-ubuntu                               - disabled
            + system.adapter.info.0                   : info                  : iob-ubuntu                               -  enabled
            + system.adapter.javascript.0             : javascript            : iob-ubuntu                               -  enabled
            + system.adapter.javascript.1             : javascript            : iob-ubuntu                               -  enabled
            + system.adapter.javascript.2             : javascript            : iob-ubuntu                               -  enabled
            + system.adapter.javascript.3             : javascript            : piPivCCU                                 -  enabled
            + system.adapter.javascript.4             : javascript            : doorpi                                   -  enabled
            + system.adapter.link.0                   : link                  : iob-ubuntu                               -  enabled
              system.adapter.mielecloudservice.0      : mielecloudservice     : iob-ubuntu                               - disabled
            + system.adapter.mqtt.0                   : mqtt                  : iob-ubuntu                               -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.onvif.0                  : onvif                 : iob-ubuntu                               - disabled
            + system.adapter.parcel.0                 : parcel                : iob-ubuntu                               -  enabled
            + system.adapter.ping.0                   : ping                  : iob-ubuntu                               -  enabled
              system.adapter.pollenflug.0             : pollenflug            : iob-ubuntu                               - disabled
              system.adapter.pvforecast.0             : pvforecast            : iob-ubuntu                               - disabled
              system.adapter.repetierserver.0         : repetierserver        : iob-ubuntu                               - disabled
            + system.adapter.rpi2.0                   : rpi2                  : piPivCCU                                 -  enabled
              system.adapter.sayit.0                  : sayit                 : VISFlur                                  - disabled
            + system.adapter.shelly.0                 : shelly                : iob-ubuntu                               -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.simple-api.0             : simple-api            : iob-ubuntu                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.smartmeter.0             : smartmeter            : piPivCCU                                 -  enabled
            + system.adapter.smartmeter.1             : smartmeter            : piPivCCU                                 -  enabled
            + system.adapter.sourceanalytix.0         : sourceanalytix        : iob-ubuntu                               -  enabled
            + system.adapter.sql.0                    : sql                   : iob-ubuntu                               -  enabled, port: 3306
              system.adapter.sql.1                    : sql                   : iob-ubuntu                               - disabled, port: 3306
            + system.adapter.statistics.0             : statistics            : iob-ubuntu                               -  enabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iob-ubuntu                               -  enabled
            + system.adapter.telegram.0               : telegram              : iob-ubuntu                               -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.terminal.0               : terminal              : doorpi                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
              system.adapter.terminal.1               : terminal              : iob-ubuntu                               - disabled, port: 8088, bind: 0.0.0.0, run as: admin
            + system.adapter.tr-064.0                 : tr-064                : iob-ubuntu                               -  enabled
            + system.adapter.tuya.0                   : tuya                  : iob-ubuntu                               -  enabled
            + system.adapter.upnp.0                   : upnp                  : iob-ubuntu                               -  enabled
              system.adapter.vis-bars.0               : vis-bars              : iob-ubuntu                               - disabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob-ubuntu                               - disabled
              system.adapter.vis-history.0            : vis-history           : iob-ubuntu                               - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob-ubuntu                               - disabled
              system.adapter.vis-inventwo.0           : vis-inventwo          : iob-ubuntu                               - disabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob-ubuntu                               - disabled
              system.adapter.vis-keyboard.0           : vis-keyboard          : iob-ubuntu                               - disabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : iob-ubuntu                               - disabled
              system.adapter.vis-material.0           : vis-material          : iob-ubuntu                               - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob-ubuntu                               - disabled
              system.adapter.vis-metro.0              : vis-metro             : iob-ubuntu                               - disabled
              system.adapter.vis-plumb.0              : vis-plumb             : iob-ubuntu                               - disabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : iob-ubuntu                               - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-ubuntu                               - disabled
              system.adapter.vis-weather.0            : vis-weather           : iob-ubuntu                               - disabled
              system.adapter.vis.0                    : vis                   : iob-ubuntu                               -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : iob-ubuntu                               -  enabled
              system.adapter.weatherunderground.1     : weatherunderground    : doorpi                                   - disabled
            + system.adapter.web.0                    : web                   : iob-ubuntu                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iob-ubuntu                               -  enabled
              system.adapter.windows-control.0        : windows-control       : iob-ubuntu                               - disabled
            + instance is alive
            ioBroker-Repositories
            Installed ioBroker-Instances
            Used repository: beta
            Adapter    "admin"        : 6.14.1   , installed 6.14.1
            Adapter    "backitup"     : 2.10.11  , installed 2.10.11
            Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
            Adapter    "ecovacs-deebot": 1.4.14  , installed 1.4.14
            Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
            Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
            Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
            Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
            Adapter    "ical"         : 1.14.2   , installed 1.14.2
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "javascript"   : 7.8.0    , installed 7.8.0
            Adapter    "link"         : 0.5.12   , installed 0.5.12
            Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
            Adapter    "onvif"        : 1.1.2    , installed 1.1.2
            Adapter    "parcel"       : 0.2.7    , installed 0.2.7
            Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
            Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
            Adapter    "shelly"       : 6.8.0    , installed 6.8.0
            Adapter    "socketio"     : 6.6.1    , installed 6.6.1
            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
            Adapter    "sql"          : 2.2.0    , installed 2.2.0
            Adapter    "statistics"   : 2.4.0    , installed 2.4.0
            Adapter    "telegram"     : 3.1.0    , installed 3.1.0
            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
            Adapter    "tuya"         : 3.15.0   , installed 3.15.0
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
            Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
            Adapter    "vis-material" : 0.1.3    , installed 0.1.3
            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
            Adapter    "weatherunderground": 3.6.0, installed 3.6.0
            Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
            Adapter    "windows-control": 0.1.5  , installed 0.1.5
            Adapter    "ws"           : 2.5.11   , installed 2.5.11
            Objects and States
            Objects:        16680
            States:         12396
            W: GPG error: https://deb.nodesource.com/node_18.x jammy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1655A0AB68576280
            E: The repository 'https://deb.nodesource.com/node_18.x jammy InRelease' is not signed.
            Pending Updates: 1
            *** Listening Ports ***
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        22581      634/systemd-resolve
            tcp        0      0 192.168.137.9:2001      0.0.0.0:*               LISTEN      1000       74428      9493/io.hm-rpc.0
            tcp        0      0 192.168.137.9:2010      0.0.0.0:*               LISTEN      1000       76092      9512/io.hm-rpc.1
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          19150      1/init
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2924       696/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       74988      9317/iobroker.js-co
            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       74995      9317/iobroker.js-co
            tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       76117      9545/io.mqtt.0
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       76116      9545/io.mqtt.0
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       181646     13688/io.shelly.0
            tcp6       0      0 :::8087                 :::*                    LISTEN      1000       77176      10186/io.simple-api
            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       73464      9637/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       75045      9335/io.admin.0
            tcp6       0      0 :::111                  :::*                    LISTEN      0          2295       1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          2926       696/sshd: /usr/sbin
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        22580      634/systemd-resolve
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19663      1/init
            udp        0      0 192.168.137.9:5353      0.0.0.0:*                           1000       167139     13352/io.tr-064.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       78958      10248/io.upnp.0
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       75347      9622/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       75348      9622/io.tuya.0
            udp6       0      0 :::111                  :::*                                0          19151      1/init
            2024-02-24 10:08:08.699  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T3.VOLTAGEist 23.5°C // 2.55V
            2024-02-24 10:08:08.699  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
            2024-02-24 10:10:00.004  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
            2024-02-24 10:15:00.004  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
            2024-02-24 10:15:00.362  - info: statistics.0 (10216) State value to set for "statistics.0.save.avg.upnp.0.WANDevice_-_FRITZ!Box_6842_LTE.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived.15MinAvg" has to be type "number" but received type "string"
            2024-02-24 10:15:00.409  - info: statistics.0 (10216) State value to set for "statistics.0.temp.avg.upnp.0.WANDevice_-_FRITZ!Box_6842_LTE.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived.15MinAvg" has to be type "number" but received type "string"
            2024-02-24 10:15:00.457  - info: statistics.0 (10216) State value to set for "statistics.0.temp.avg.upnp.0.WANDevice_-_FRITZ!Box_6842_LTE.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived.15MinSum" has to be type "number" but received type "string"
            2024-02-24 10:15:24.548  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T0.VOLTAGEist 35.5°C // 3.74V
            2024-02-24 10:15:24.548  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
            2024-02-24 10:15:25.339  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T1.VOLTAGEist 23.7°C // 2.57V
            2024-02-24 10:15:25.339  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
            2024-02-24 10:15:25.354  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T2.VOLTAGEist 24.1°C // 2.61V
            2024-02-24 10:15:25.354  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
            2024-02-24 10:15:25.443  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T3.VOLTAGEist 23.4°C // 2.54V
            2024-02-24 10:15:25.443  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
            2024-02-24 10:20:00.005  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
            2024-02-24 10:22:42.339  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T0.VOLTAGEist 35.6°C // 3.75V
            2024-02-24 10:22:42.340  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
            2024-02-24 10:22:42.543  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T1.VOLTAGEist 23.8°C // 2.58V
            2024-02-24 10:22:42.544  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
            2024-02-24 10:22:42.545  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T2.VOLTAGEist 23.7°C // 2.57V
            2024-02-24 10:22:42.546  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
            2024-02-24 10:22:42.550  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T3.VOLTAGEist 23.4°C // 2.54V
            2024-02-24 10:22:42.550  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
            2024-02-24 10:25:00.006  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
            Danke für's Checken.
              @thisoft
              sudo systemctl set-default multi-user.target
              iob nodejs-update 18
              Und meld dich nicht als user iobroker an sondern als der user mit der UserID 1000. Wie auch immer der heißt.
              grep 1000 /etc/passwd
              sagt dir das.
              Thisoft 2 Replies Last reply Reply Quote 0
              • Thisoft
                sagt mir:
                iobroker@iob-ubuntu:~$ grep 1000 /etc/passwd
                iobroker:x:1000:1000:iobroker:/home/iobroker:/bin/bash
                muss ich irgendwie nicht verstehen... wüsste auch nicht dass ich bewusst einen anderen User angelegt hätte...
                • Thisoft
                  Thisoft @Thomas Braun last edited by Thisoft
                  sorry, aber was soll mir das sagen?
                    Das sollst du in deinem Terminal ausführen.
                    • Thisoft
                      OK. Hab ich. Und jetzt nochmal iob diag
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Chassis: vm
                        Virtualization: kvm
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                       16:00:27 up 6 min,  2 users,  load average: 0.29, 0.30, 0.15
                      CPU threads: 8
                                     Local time: Sat 2024-02-24 16:00:27 CET
                                 Universal time: Sat 2024-02-24 15:00:27 UTC
                                       RTC time: Sat 2024-02-24 15:00:27
                                    NTP service: active
                                RTC in local TZ: no
                      iobroker
                      /home/iobroker
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      Boot Target:    multi-user.target
                      *** MEMORY ***
                      Mem:            7.9G        189M        7.2G        1.0M        580M        7.5G
                      Swap:           3.1G          0B        3.1G
                      Total:           11G        189M         10G
                               7937 M total memory
                                190 M used memory
                                240 M active memory
                                345 M inactive memory
                               7166 M free memory
                                 53 M buffer memory
                                527 M swap cache
                               3114 M total swap
                                  0 M used swap
                               3114 M free swap
                        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                      * iobroker.service loaded failed failed ioBroker Server
                      LOAD   = Reflects whether the unit definition was properly loaded.
                      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                      SUB    = The low-level unit activation state, values depend on unit type.
                      1 loaded units listed.
                      *** FILESYSTEM ***
                      [sudo] password for iobroker:
                      [Sat Feb 24 15:54:27 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Sat Feb 24 15:54:28 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
                      [Sat Feb 24 15:54:28 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      |-/snap/lxd/26975     /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
                      |-/snap/snapd/20290   /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
                      |-/snap/lxd/27037     /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
                      /var:
                      3.9G    /var/
                      3.0G    /var/lib
                      Archived and active journals take up 392.1M in the file system.
                      352M    /opt/iobroker/iobroker-data/
                      33M     /opt/iobroker/iobroker-data/objects.jsonl
                      11M     /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.4
                      /usr/bin/npx            10.2.4
                      nodejs:
                        Version table:
                       *** 18.19.1-1nodesource1 1001
                              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                           18.19.0-1nodesource1 1001
                           18.18.2-1nodesource1 1001
                           18.18.1-1nodesource1 1001
                           18.18.0-1nodesource1 1001
                           18.17.1-1nodesource1 1001
                           18.17.0-1nodesource1 1001
                           18.16.1-1nodesource1 1001
                           18.16.0-1nodesource1 1001
                           18.15.0-1nodesource1 1001
                           18.14.2-1nodesource1 1001
                           18.14.1-1nodesource1 1001
                           18.14.0-1nodesource1 1001
                           18.13.0-1nodesource1 1001
                           18.12.0-1nodesource1 1001
                           18.11.0-1nodesource1 1001
                           18.10.0-1nodesource1 1001
                           18.9.1-1nodesource1 1001
                           18.9.0-1nodesource1 1001
                           18.8.0-1nodesource1 1001
                           18.7.0-1nodesource1 1001
                           18.6.0-1nodesource1 1001
                           18.5.0-1nodesource1 1001
                           18.4.0-1nodesource1 1001
                           18.3.0-1nodesource1 1001
                           18.2.0-1nodesource1 1001
                           18.1.0-1nodesource1 1001
                           18.0.0-1nodesource1 1001
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.14.1
                      javascript:     7.8.0
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        16682
                      States:         12104
                      Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                      Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
                      Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
                      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
                      Reading package lists...
                      Pending Updates: 0
                      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        2695       637/systemd-resolve
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          16297      1/init
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23780      699/sshd: /usr/sbin
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          19827      1/init
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          23791      699/sshd: /usr/sbin
                      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        2694       637/systemd-resolve
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2340       1/init
                      udp6       0      0 :::111                  :::*                                0          2343       1/init
                      2024-02-24 15:59:34.769  - info: host.iob-ubuntu instance system.adapter.javascript.1 terminated with code 0 (NO_ERROR)
                      2024-02-24 15:59:34.811  - info: host.iob-ubuntu instance system.adapter.javascript.2 terminated with code 0 (NO_ERROR)
                      2024-02-24 15:59:34.812  - info: host.iob-ubuntu instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                      2024-02-24 15:59:34.848  - info: host.iob-ubuntu instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                      2024-02-24 15:59:34.848  - info: host.iob-ubuntu instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                      2024-02-24 15:59:34.861  - info: host.iob-ubuntu instance system.adapter.statistics.0 terminated with code 0 (NO_ERROR)
                      2024-02-24 15:59:34.874  - info: host.iob-ubuntu instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
                      2024-02-24 15:59:35.068  - warn: host.iob-ubuntu instance system.adapter.telegram.0 terminated due to SIGTERM
                      2024-02-24 15:59:35.068  - info: host.iob-ubuntu instance system.adapter.telegram.0 terminated with code null ()
                      2024-02-24 15:59:35.092  - warn: host.iob-ubuntu instance system.adapter.whatsapp-cmb.0 terminated due to SIGTERM
                      2024-02-24 15:59:35.092  - info: host.iob-ubuntu instance system.adapter.whatsapp-cmb.0 terminated with code null ()
                      2024-02-24 15:59:35.092  - warn: host.iob-ubuntu instance system.adapter.hm-rega.0 terminated due to SIGTERM
                      2024-02-24 15:59:35.092  - info: host.iob-ubuntu instance system.adapter.hm-rega.0 terminated with code null ()
                      2024-02-24 15:59:35.122  - warn: host.iob-ubuntu instance system.adapter.hm-rpc.1 terminated due to SIGTERM
                      2024-02-24 15:59:35.122  - info: host.iob-ubuntu instance system.adapter.hm-rpc.1 terminated with code null ()
                      2024-02-24 15:59:35.122  - warn: host.iob-ubuntu instance system.adapter.ping.0 terminated due to SIGTERM
                      2024-02-24 15:59:35.122  - info: host.iob-ubuntu instance system.adapter.ping.0 terminated with code null ()
                      2024-02-24 15:59:35.143  - warn: host.iob-ubuntu instance system.adapter.web.0 terminated due to SIGTERM
                      2024-02-24 15:59:35.143  - info: host.iob-ubuntu instance system.adapter.web.0 terminated with code null ()
                      2024-02-24 15:59:35.188  - info: host.iob-ubuntu instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
                      2024-02-24 15:59:36.360  - info: tuya.0 (1198) terminating
                      2024-02-24 15:59:36.361  - info: tuya.0 (1198) Terminated (NO_ERROR): Without reason
                      2024-02-24 15:59:36.913  - info: host.iob-ubuntu instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
                      2024-02-24 15:59:36.913  - info: host.iob-ubuntu All instances are stopped.
                      2024-02-24 15:59:37.111  - info: host.iob-ubuntu terminated
                        @thisoft
                        Und dann den iobroker wieder starten.
                        • Thisoft
                          Hab ich gemacht. Das wäre dann alles?
                            @thisoft
                            Läuft der iobroker denn nun wieder ohne Meldungen?
                            • Thisoft
                              Ja tut er. Er hatte auch vorher nur das Problem dass der Parcel-Adapter sich nicht bei DHL eingeloggt hat. Was ja offensichtlich erst ab nodejs 18.19.1 wieder funktioniert. Ansonsten hatte ich kein Problem damit. Aber wenn das jetzt alles sauber gefixt ist umso besser.
                              • bahnuhr
                                Guten Abend,
                                muss jetzt auch mal fragen zur grundsätzlichen Vorgehensweise
                                a) DHL
                                Habe meinen Benutzer und Pass eingegeben und die Daten kommen.
                                Für was ist der Pin-Code ?
                                Braucht man den und für was?
                                Daten kommen ja an.
                                b) Hermes
                                Habe mich dort angemeldet. Aber die Lieferung war nicht automatisch drin. Musste die Nr. manuell einpflegen.
                                Braucht man dafür dann 17Track?
                                Also die Mails weiter leiten an 17Track und diese analysieren die Mails und senden dann die Daten an den Adapter.
                                Richtig ?
                                c) Wie funktioniert dies bei DPD, GLS, UPS, Amazon?
                                Hier habe ich noch nichts.
                                Muss ich einen Benutzer überall anmelden und dann jedesmal 17Track ?
                                mfg
                                Dieter
                                • bahnuhr
                                  bahnuhr Forum Testing Most Active last edited by bahnuhr
                                  Datum, Uhrzeit anzeigen:
                                  Habe hier des öfteren schon gesehen, dass auch das Datum + Uhrzeit in VIS angezeigt wird.
                                  Bei mir nicht.
                                  Aber im DP sind die Daten wohl drin.
                                  Frage:
                                  Wie bekomme ich Datum und Uhrzeit angezeigt ?
                                  • bahnuhr
                                    So, und nun letzte Frage zu Hermes
                                    Hatte ja die Nr. manuell bei Hermes eingetragen. Dies wurde dann auch übertragen.
                                    Im DP steht auch der Absender:
                                    In VIS nicht, dort "undefined"
                                    So, das wars erst einmal.
                                    • DJMarc75
                                      DJMarc75 @bahnuhr last edited by
                                      @bahnuhr
                                      Im Prinzip empfängt der Adapter nur die Daten vom jeweiligen Provider.
                                      Und die Provider sind schon zeitweise recht "kacke" 😉
                                      Da ändert jeder Provider öfter mal die Daten und der Developer kommt da fast nicht nach.
                                      Ich verlasse mich schon ewig nur noch auf DHL, der Rest ist für mich nur "Spass" da es meist nicht zuverlässig klappt (GLS ist eine Katastrophe)
                                      Amazon nutze ich nicht da dies ja anscheinend zum Ko**en ist, da die Vögel da immer was ändern.
                                      Ist aber nur meine eigene Erfahrung und kann bei anderen Usern auch besser funktionieren.
                                      • bahnuhr
                                        bahnuhr Forum Testing Most Active @DJMarc75 last edited by
                                        @djmarc75
                                        Muss man sich bei gls anmelden ?
                                        Oder reicht die Mail Weiterleitung an 17track ?
                                        • DJMarc75
                                          @bahnuhr sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                          Na man muss sich mMn schon bei jedem Provider anmelden.
                                          Mit 17track hab ich keine Erfahrungen.
                                          • bahnuhr
                                            @djmarc75 sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                            Ich habe das so verstanden, dass man eine Mail Weiterleitung an 17track macht. Und diese nehmen die Mail dann auseinander und der Adapter holt die Daten von 17track.
                                            Dann würde es keine Anmeldung beim provider brauchen.
                                            17track amazon briefe dhl dpd gls ups
                                            123
                                            1537
                                            536351
