    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
      Thomas Braun Most Active last edited by Thomas Braun
      @thisoft sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
      Pending iob updates: 6
      Hau die Updates druff.
      Und dann die Langfassung bitte.
      Und schau mal danach:
      du -h /opt/iobroker/iobroker-data/backup-objects/
      https://forum.iobroker.net/topic/54655/probleme-von-4-0-21-auf-4-0-23/16
      Thisoft 1 Reply Last reply Reply Quote 0
      • Thisoft
        Thisoft @Thomas Braun last edited by
        @thomas-braun sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
        109M    /opt/iobroker/iobroker-data/backup-objects/
        Und hier die Langfassung von iob diag:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: iob-ubuntu
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Ubuntu 22.04.4 LTS
                  Kernel: Linux 5.15.0-97-generic
            Architecture: x86-64
         Hardware Vendor: QEMU
          Hardware Model: Standard PC _i440FX + PIIX, 1996_
        model name      : Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         10:28:27 up 10:25,  2 users,  load average: 0.19, 0.29, 0.21
        CPU threads: 8
        *** Time and Time Zones ***
                       Local time: Sat 2024-02-24 10:28:27 CET
                   Universal time: Sat 2024-02-24 09:28:27 UTC
                         RTC time: Sat 2024-02-24 09:28:27
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        iobroker
        /home/iobroker
        iobroker adm tty dialout cdrom sudo audio dip video plugdev lxd
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.9G        2.9G        3.3G        1.0M        1.8G        4.8G
        Swap:           3.1G          0B        3.1G
        Total:           11G        2.9G        6.4G
                 7937 M total memory
                 2872 M used memory
                  748 M active memory
                 3401 M inactive memory
                 3262 M free memory
                  269 M buffer memory
                 1532 M swap cache
                 3114 M total swap
                    0 M used swap
                 3114 M free swap
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                        Type   Size  Used Avail Use% Mounted on
        tmpfs                             tmpfs  794M  1.1M  793M   1% /run
        /dev/mapper/ubuntu--vg-ubuntu--lv ext4    15G   12G  2.3G  84% /
        tmpfs                             tmpfs  3.9G     0  3.9G   0% /dev/shm
        tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
        /dev/sda2                         ext4   2.0G  251M  1.6G  14% /boot
        //192.168.137.42/motion           cifs   869G  840G   30G  97% /var/lib/motion/NAS
        tmpfs                             tmpfs  794M  4.0K  794M   1% /run/user/1000
        [Sat Feb 24 00:03:06 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Sat Feb 24 00:03:07 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
        [Sat Feb 24 00:03:08 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        TARGET                SOURCE                            FSTYPE   OPTIONS
        /                     /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
        |-/snap/core20/2105   /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
        |-/snap/core20/2182   /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
        |-/snap/lxd/27037     /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
        |-/snap/lxd/26975     /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
        |-/snap/snapd/20671   /dev/loop5                        squashfs ro,nodev,relatime,errors=continue
        |-/snap/snapd/20290   /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
        |-/boot               /dev/sda2                         ext4     rw,relatime
        `-/var/lib/motion/NAS //192.168.137.42/motion           cifs     rw,relatime,vers=default,cache=strict,username=motion,uid=1001,forceuid,gid=0,noforcegid,addr=192.168.137.42,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
        /var:
        3.9G    /var/
        3.0G    /var/lib
        2.2G    /var/lib/motion/NAS
        1.9G    /var/lib/motion/NAS/Cam4
        Archived and active journals take up 384.1M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        346M    /opt/iobroker/iobroker-data/
        199M    /opt/iobroker/iobroker-data/files
        57M     /opt/iobroker/iobroker-data/files/javascript.admin
        38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        31M     /opt/iobroker/iobroker-data/objects.jsonl
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
        8.2M    /opt/iobroker/iobroker-data/states.jsonl
        7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.1
        /usr/bin/node           v18.19.1
        /usr/bin/npm            10.2.4
        /usr/bin/npx            10.2.4
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.1-1nodesource1
          Candidate: 18.19.1-1nodesource1
          Version table:
         *** 18.19.1-1nodesource1 100
                100 /var/lib/dpkg/status
             12.22.9~dfsg-1ubuntu3.3 500
                500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.14.1
        javascript:     7.8.0
        Adapters from github:   1
        Adapter State
        + system.adapter.admin.0                  : admin                 : iob-ubuntu                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alias-manager.0          : alias-manager         : iob-ubuntu                               - disabled
        + system.adapter.backitup.0               : backitup              : iob-ubuntu                               -  enabled
          system.adapter.daswetter.0              : daswetter             : iob-ubuntu                               -  enabled
          system.adapter.daswetter.1              : daswetter             : iob-ubuntu                               - disabled
          system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iob-ubuntu                               - disabled
          system.adapter.feiertage.0              : feiertage             : iob-ubuntu                               -  enabled
          system.adapter.flot.0                   : flot                  : iob-ubuntu                               - disabled
          system.adapter.gruenbeck.0              : gruenbeck             : iob-ubuntu                               - disabled
        + system.adapter.hm-rega.0                : hm-rega               : iob-ubuntu                               -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iob-ubuntu                               -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iob-ubuntu                               -  enabled, port: 0
          system.adapter.homeconnect.0            : homeconnect           : iob-ubuntu                               - disabled
          system.adapter.ical.0                   : ical                  : iob-ubuntu                               -  enabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : iob-ubuntu                               - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iob-ubuntu                               - disabled
        + system.adapter.info.0                   : info                  : iob-ubuntu                               -  enabled
        + system.adapter.javascript.0             : javascript            : iob-ubuntu                               -  enabled
        + system.adapter.javascript.1             : javascript            : iob-ubuntu                               -  enabled
        + system.adapter.javascript.2             : javascript            : iob-ubuntu                               -  enabled
        + system.adapter.javascript.3             : javascript            : piPivCCU                                 -  enabled
        + system.adapter.javascript.4             : javascript            : doorpi                                   -  enabled
        + system.adapter.link.0                   : link                  : iob-ubuntu                               -  enabled
          system.adapter.mielecloudservice.0      : mielecloudservice     : iob-ubuntu                               - disabled
        + system.adapter.mqtt.0                   : mqtt                  : iob-ubuntu                               -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.onvif.0                  : onvif                 : iob-ubuntu                               - disabled
        + system.adapter.parcel.0                 : parcel                : iob-ubuntu                               -  enabled
        + system.adapter.ping.0                   : ping                  : iob-ubuntu                               -  enabled
          system.adapter.pollenflug.0             : pollenflug            : iob-ubuntu                               - disabled
          system.adapter.pvforecast.0             : pvforecast            : iob-ubuntu                               - disabled
          system.adapter.repetierserver.0         : repetierserver        : iob-ubuntu                               - disabled
        + system.adapter.rpi2.0                   : rpi2                  : piPivCCU                                 -  enabled
          system.adapter.sayit.0                  : sayit                 : VISFlur                                  - disabled
        + system.adapter.shelly.0                 : shelly                : iob-ubuntu                               -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : iob-ubuntu                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartmeter.0             : smartmeter            : piPivCCU                                 -  enabled
        + system.adapter.smartmeter.1             : smartmeter            : piPivCCU                                 -  enabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iob-ubuntu                               -  enabled
        + system.adapter.sql.0                    : sql                   : iob-ubuntu                               -  enabled, port: 3306
          system.adapter.sql.1                    : sql                   : iob-ubuntu                               - disabled, port: 3306
        + system.adapter.statistics.0             : statistics            : iob-ubuntu                               -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iob-ubuntu                               -  enabled
        + system.adapter.telegram.0               : telegram              : iob-ubuntu                               -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.terminal.0               : terminal              : doorpi                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
          system.adapter.terminal.1               : terminal              : iob-ubuntu                               - disabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.tr-064.0                 : tr-064                : iob-ubuntu                               -  enabled
        + system.adapter.tuya.0                   : tuya                  : iob-ubuntu                               -  enabled
        + system.adapter.upnp.0                   : upnp                  : iob-ubuntu                               -  enabled
          system.adapter.vis-bars.0               : vis-bars              : iob-ubuntu                               - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob-ubuntu                               - disabled
          system.adapter.vis-history.0            : vis-history           : iob-ubuntu                               - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob-ubuntu                               - disabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : iob-ubuntu                               - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob-ubuntu                               - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : iob-ubuntu                               - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : iob-ubuntu                               - disabled
          system.adapter.vis-material.0           : vis-material          : iob-ubuntu                               - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob-ubuntu                               - disabled
          system.adapter.vis-metro.0              : vis-metro             : iob-ubuntu                               - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : iob-ubuntu                               - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iob-ubuntu                               - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-ubuntu                               - disabled
          system.adapter.vis-weather.0            : vis-weather           : iob-ubuntu                               - disabled
          system.adapter.vis.0                    : vis                   : iob-ubuntu                               -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : iob-ubuntu                               -  enabled
          system.adapter.weatherunderground.1     : weatherunderground    : doorpi                                   - disabled
        + system.adapter.web.0                    : web                   : iob-ubuntu                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iob-ubuntu                               -  enabled
          system.adapter.windows-control.0        : windows-control       : iob-ubuntu                               - disabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 6.14.1   , installed 6.14.1
        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
        Adapter    "ecovacs-deebot": 1.4.14  , installed 1.4.14
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
        Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
        Adapter    "ical"         : 1.14.2   , installed 1.14.2
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Adapter    "link"         : 0.5.12   , installed 0.5.12
        Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "onvif"        : 1.1.2    , installed 1.1.2
        Adapter    "parcel"       : 0.2.7    , installed 0.2.7
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
        Adapter    "shelly"       : 6.8.0    , installed 6.8.0
        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "sql"          : 2.2.0    , installed 2.2.0
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "telegram"     : 3.1.0    , installed 3.1.0
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "windows-control": 0.1.5  , installed 0.1.5
        Adapter    "ws"           : 2.5.11   , installed 2.5.11
        Objects and States
        Objects:        16680
        States:         12396
        W: GPG error: https://deb.nodesource.com/node_18.x jammy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1655A0AB68576280
        E: The repository 'https://deb.nodesource.com/node_18.x jammy InRelease' is not signed.
        Pending Updates: 1
        *** Listening Ports ***
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        22581      634/systemd-resolve
        tcp        0      0 192.168.137.9:2001      0.0.0.0:*               LISTEN      1000       74428      9493/io.hm-rpc.0
        tcp        0      0 192.168.137.9:2010      0.0.0.0:*               LISTEN      1000       76092      9512/io.hm-rpc.1
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          19150      1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2924       696/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       74988      9317/iobroker.js-co
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       74995      9317/iobroker.js-co
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       76117      9545/io.mqtt.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       76116      9545/io.mqtt.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       181646     13688/io.shelly.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       77176      10186/io.simple-api
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       73464      9637/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       75045      9335/io.admin.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          2295       1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          2926       696/sshd: /usr/sbin
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        22580      634/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19663      1/init
        udp        0      0 192.168.137.9:5353      0.0.0.0:*                           1000       167139     13352/io.tr-064.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       78958      10248/io.upnp.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       75347      9622/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       75348      9622/io.tuya.0
        udp6       0      0 :::111                  :::*                                0          19151      1/init
        2024-02-24 10:08:08.699  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T3.VOLTAGEist 23.5°C // 2.55V
        2024-02-24 10:08:08.699  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
        2024-02-24 10:10:00.004  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
        2024-02-24 10:15:00.004  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
        2024-02-24 10:15:00.362  - info: statistics.0 (10216) State value to set for "statistics.0.save.avg.upnp.0.WANDevice_-_FRITZ!Box_6842_LTE.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived.15MinAvg" has to be type "number" but received type "string"
        2024-02-24 10:15:00.409  - info: statistics.0 (10216) State value to set for "statistics.0.temp.avg.upnp.0.WANDevice_-_FRITZ!Box_6842_LTE.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived.15MinAvg" has to be type "number" but received type "string"
        2024-02-24 10:15:00.457  - info: statistics.0 (10216) State value to set for "statistics.0.temp.avg.upnp.0.WANDevice_-_FRITZ!Box_6842_LTE.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived.15MinSum" has to be type "number" but received type "string"
        2024-02-24 10:15:24.548  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T0.VOLTAGEist 35.5°C // 3.74V
        2024-02-24 10:15:24.548  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
        2024-02-24 10:15:25.339  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T1.VOLTAGEist 23.7°C // 2.57V
        2024-02-24 10:15:25.339  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
        2024-02-24 10:15:25.354  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T2.VOLTAGEist 24.1°C // 2.61V
        2024-02-24 10:15:25.354  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
        2024-02-24 10:15:25.443  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T3.VOLTAGEist 23.4°C // 2.54V
        2024-02-24 10:15:25.443  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
        2024-02-24 10:20:00.005  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
        2024-02-24 10:22:42.339  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T0.VOLTAGEist 35.6°C // 3.75V
        2024-02-24 10:22:42.340  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
        2024-02-24 10:22:42.543  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T1.VOLTAGEist 23.8°C // 2.58V
        2024-02-24 10:22:42.544  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
        2024-02-24 10:22:42.545  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T2.VOLTAGEist 23.7°C // 2.57V
        2024-02-24 10:22:42.546  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
        2024-02-24 10:22:42.550  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T3.VOLTAGEist 23.4°C // 2.54V
        2024-02-24 10:22:42.550  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
        2024-02-24 10:25:00.006  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
        Danke für's Checken.
          Thomas Braun Most Active @Thisoft last edited by
          @thisoft
          sudo systemctl set-default multi-user.target
          iob nodejs-update 18
          Und meld dich nicht als user iobroker an sondern als der user mit der UserID 1000. Wie auch immer der heißt.
          grep 1000 /etc/passwd
          sagt dir das.
          Thisoft 2 Replies Last reply Reply Quote 0
          • Thisoft
            sagt mir:
            iobroker@iob-ubuntu:~$ grep 1000 /etc/passwd
            iobroker:x:1000:1000:iobroker:/home/iobroker:/bin/bash
            muss ich irgendwie nicht verstehen... wüsste auch nicht dass ich bewusst einen anderen User angelegt hätte...
            • Thisoft
              Thisoft @Thomas Braun last edited by Thisoft
              sorry, aber was soll mir das sagen?
                Das sollst du in deinem Terminal ausführen.
                • Thisoft
                  OK. Hab ich. Und jetzt nochmal iob diag
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Chassis: vm
                    Virtualization: kvm
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : amd64
                   16:00:27 up 6 min,  2 users,  load average: 0.29, 0.30, 0.15
                  CPU threads: 8
                                 Local time: Sat 2024-02-24 16:00:27 CET
                             Universal time: Sat 2024-02-24 15:00:27 UTC
                                   RTC time: Sat 2024-02-24 15:00:27
                                NTP service: active
                            RTC in local TZ: no
                  iobroker
                  /home/iobroker
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            7.9G        189M        7.2G        1.0M        580M        7.5G
                  Swap:           3.1G          0B        3.1G
                  Total:           11G        189M         10G
                           7937 M total memory
                            190 M used memory
                            240 M active memory
                            345 M inactive memory
                           7166 M free memory
                             53 M buffer memory
                            527 M swap cache
                           3114 M total swap
                              0 M used swap
                           3114 M free swap
                    UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                  * iobroker.service loaded failed failed ioBroker Server
                  LOAD   = Reflects whether the unit definition was properly loaded.
                  ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                  SUB    = The low-level unit activation state, values depend on unit type.
                  1 loaded units listed.
                  *** FILESYSTEM ***
                  [sudo] password for iobroker:
                  [Sat Feb 24 15:54:27 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Sat Feb 24 15:54:28 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
                  [Sat Feb 24 15:54:28 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  |-/snap/lxd/26975     /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
                  |-/snap/snapd/20290   /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
                  |-/snap/lxd/27037     /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
                  /var:
                  3.9G    /var/
                  3.0G    /var/lib
                  Archived and active journals take up 392.1M in the file system.
                  352M    /opt/iobroker/iobroker-data/
                  33M     /opt/iobroker/iobroker-data/objects.jsonl
                  11M     /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.4
                  /usr/bin/npx            10.2.4
                  nodejs:
                    Version table:
                   *** 18.19.1-1nodesource1 1001
                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                       18.19.0-1nodesource1 1001
                       18.18.2-1nodesource1 1001
                       18.18.1-1nodesource1 1001
                       18.18.0-1nodesource1 1001
                       18.17.1-1nodesource1 1001
                       18.17.0-1nodesource1 1001
                       18.16.1-1nodesource1 1001
                       18.16.0-1nodesource1 1001
                       18.15.0-1nodesource1 1001
                       18.14.2-1nodesource1 1001
                       18.14.1-1nodesource1 1001
                       18.14.0-1nodesource1 1001
                       18.13.0-1nodesource1 1001
                       18.12.0-1nodesource1 1001
                       18.11.0-1nodesource1 1001
                       18.10.0-1nodesource1 1001
                       18.9.1-1nodesource1 1001
                       18.9.0-1nodesource1 1001
                       18.8.0-1nodesource1 1001
                       18.7.0-1nodesource1 1001
                       18.6.0-1nodesource1 1001
                       18.5.0-1nodesource1 1001
                       18.4.0-1nodesource1 1001
                       18.3.0-1nodesource1 1001
                       18.2.0-1nodesource1 1001
                       18.1.0-1nodesource1 1001
                       18.0.0-1nodesource1 1001
                  Errors in npm tree:
                  ioBroker Status
                  Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
                  iobroker is not running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.14.1
                  javascript:     7.8.0
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        16682
                  States:         12104
                  Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                  Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
                  Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
                  Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
                  Reading package lists...
                  Pending Updates: 0
                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        2695       637/systemd-resolve
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          16297      1/init
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23780      699/sshd: /usr/sbin
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          19827      1/init
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          23791      699/sshd: /usr/sbin
                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        2694       637/systemd-resolve
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2340       1/init
                  udp6       0      0 :::111                  :::*                                0          2343       1/init
                  2024-02-24 15:59:34.769  - info: host.iob-ubuntu instance system.adapter.javascript.1 terminated with code 0 (NO_ERROR)
                  2024-02-24 15:59:34.811  - info: host.iob-ubuntu instance system.adapter.javascript.2 terminated with code 0 (NO_ERROR)
                  2024-02-24 15:59:34.812  - info: host.iob-ubuntu instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                  2024-02-24 15:59:34.848  - info: host.iob-ubuntu instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                  2024-02-24 15:59:34.848  - info: host.iob-ubuntu instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                  2024-02-24 15:59:34.861  - info: host.iob-ubuntu instance system.adapter.statistics.0 terminated with code 0 (NO_ERROR)
                  2024-02-24 15:59:34.874  - info: host.iob-ubuntu instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
                  2024-02-24 15:59:35.068  - warn: host.iob-ubuntu instance system.adapter.telegram.0 terminated due to SIGTERM
                  2024-02-24 15:59:35.068  - info: host.iob-ubuntu instance system.adapter.telegram.0 terminated with code null ()
                  2024-02-24 15:59:35.092  - warn: host.iob-ubuntu instance system.adapter.whatsapp-cmb.0 terminated due to SIGTERM
                  2024-02-24 15:59:35.092  - info: host.iob-ubuntu instance system.adapter.whatsapp-cmb.0 terminated with code null ()
                  2024-02-24 15:59:35.092  - warn: host.iob-ubuntu instance system.adapter.hm-rega.0 terminated due to SIGTERM
                  2024-02-24 15:59:35.092  - info: host.iob-ubuntu instance system.adapter.hm-rega.0 terminated with code null ()
                  2024-02-24 15:59:35.122  - warn: host.iob-ubuntu instance system.adapter.hm-rpc.1 terminated due to SIGTERM
                  2024-02-24 15:59:35.122  - info: host.iob-ubuntu instance system.adapter.hm-rpc.1 terminated with code null ()
                  2024-02-24 15:59:35.122  - warn: host.iob-ubuntu instance system.adapter.ping.0 terminated due to SIGTERM
                  2024-02-24 15:59:35.122  - info: host.iob-ubuntu instance system.adapter.ping.0 terminated with code null ()
                  2024-02-24 15:59:35.143  - warn: host.iob-ubuntu instance system.adapter.web.0 terminated due to SIGTERM
                  2024-02-24 15:59:35.143  - info: host.iob-ubuntu instance system.adapter.web.0 terminated with code null ()
                  2024-02-24 15:59:35.188  - info: host.iob-ubuntu instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
                  2024-02-24 15:59:36.360  - info: tuya.0 (1198) terminating
                  2024-02-24 15:59:36.361  - info: tuya.0 (1198) Terminated (NO_ERROR): Without reason
                  2024-02-24 15:59:36.913  - info: host.iob-ubuntu instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
                  2024-02-24 15:59:36.913  - info: host.iob-ubuntu All instances are stopped.
                  2024-02-24 15:59:37.111  - info: host.iob-ubuntu terminated
                    @thisoft
                    Und dann den iobroker wieder starten.
                    • Thisoft
                      Hab ich gemacht. Das wäre dann alles?
                        @thisoft
                        Läuft der iobroker denn nun wieder ohne Meldungen?
                        • Thisoft
                          Ja tut er. Er hatte auch vorher nur das Problem dass der Parcel-Adapter sich nicht bei DHL eingeloggt hat. Was ja offensichtlich erst ab nodejs 18.19.1 wieder funktioniert. Ansonsten hatte ich kein Problem damit. Aber wenn das jetzt alles sauber gefixt ist umso besser.
                          • bahnuhr
                            Guten Abend,
                            muss jetzt auch mal fragen zur grundsätzlichen Vorgehensweise
                            a) DHL
                            Habe meinen Benutzer und Pass eingegeben und die Daten kommen.
                            Für was ist der Pin-Code ?
                            Braucht man den und für was?
                            Daten kommen ja an.
                            b) Hermes
                            Habe mich dort angemeldet. Aber die Lieferung war nicht automatisch drin. Musste die Nr. manuell einpflegen.
                            Braucht man dafür dann 17Track?
                            Also die Mails weiter leiten an 17Track und diese analysieren die Mails und senden dann die Daten an den Adapter.
                            Richtig ?
                            c) Wie funktioniert dies bei DPD, GLS, UPS, Amazon?
                            Hier habe ich noch nichts.
                            Muss ich einen Benutzer überall anmelden und dann jedesmal 17Track ?
                            mfg
                            Dieter
                            • bahnuhr
                              bahnuhr Forum Testing Most Active last edited by bahnuhr
                              Datum, Uhrzeit anzeigen:
                              Habe hier des öfteren schon gesehen, dass auch das Datum + Uhrzeit in VIS angezeigt wird.
                              Bei mir nicht.
                              Aber im DP sind die Daten wohl drin.
                              Frage:
                              Wie bekomme ich Datum und Uhrzeit angezeigt ?
                              • bahnuhr
                                So, und nun letzte Frage zu Hermes
                                Hatte ja die Nr. manuell bei Hermes eingetragen. Dies wurde dann auch übertragen.
                                Im DP steht auch der Absender:
                                In VIS nicht, dort "undefined"
                                So, das wars erst einmal.
                                • DJMarc75
                                  DJMarc75 @bahnuhr last edited by
                                  @bahnuhr
                                  Im Prinzip empfängt der Adapter nur die Daten vom jeweiligen Provider.
                                  Und die Provider sind schon zeitweise recht "kacke" 😉
                                  Da ändert jeder Provider öfter mal die Daten und der Developer kommt da fast nicht nach.
                                  Ich verlasse mich schon ewig nur noch auf DHL, der Rest ist für mich nur "Spass" da es meist nicht zuverlässig klappt (GLS ist eine Katastrophe)
                                  Amazon nutze ich nicht da dies ja anscheinend zum Ko**en ist, da die Vögel da immer was ändern.
                                  Ist aber nur meine eigene Erfahrung und kann bei anderen Usern auch besser funktionieren.
                                  • bahnuhr
                                    bahnuhr Forum Testing Most Active @DJMarc75 last edited by
                                    @djmarc75
                                    Muss man sich bei gls anmelden ?
                                    Oder reicht die Mail Weiterleitung an 17track ?
                                    • DJMarc75
                                      @bahnuhr sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                      Na man muss sich mMn schon bei jedem Provider anmelden.
                                      Mit 17track hab ich keine Erfahrungen.
                                      • bahnuhr
                                        @djmarc75 sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                        Ich habe das so verstanden, dass man eine Mail Weiterleitung an 17track macht. Und diese nehmen die Mail dann auseinander und der Adapter holt die Daten von 17track.
                                        Dann würde es keine Anmeldung beim provider brauchen.
                                        • DJMarc75
                                          @bahnuhr Da musst Du mal im ersten Beitrag nachlesen, das weiß ich leider nicht.
                                          • bahnuhr
                                            Der ist gut.
                                            Da hab ich schon 50x gelesen. Aber offensichtlich nicht die richtigen Infos gefunden.
                                            17track amazon briefe dhl dpd gls ups
                                            124
                                            1538
                                            536903
