    4. Open EPaper Display - Puppeteer
      Beowolf last edited by
      Alles läuft auf einen Raspberry pi4 mit linux drauf.
      Eine chromium Datei liegt in /usr/bin/chromium
      Wenn ich es zurück ändere, startet der Puppeteer Adapter nicht. Bleibt rot.
      Ich habe ja die Änderung hier her.
      https://forum.iobroker.net/topic/66380/eps-e-ink-display-ansteuerung-statusdisplay-für-2/265?_=1708378635528
        So, ich habe jetzt mal ioBroker auf meinem neuen PI5 installiert.
        Alles upgedatet. Neuer geht nicht.
        Im ioBroker nach der neuen Installation NUR mit dem Puppeteer-Adapter installiert.
        Und er läuft nicht.
        Es kommt diese Meldung
        host.raspberrypi
        	2024-02-21 10:01:06.184	warn	Do not restart adapter system.adapter.puppeteer.0 because restart loop detected
        host.raspberrypi
        	2024-02-21 10:01:06.184	info	Restart adapter system.adapter.puppeteer.0 because enabled
        host.raspberrypi
        	2024-02-21 10:01:06.184	error	instance system.adapter.puppeteer.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.raspberrypi
        	2024-02-21 10:01:06.184	error	host.raspberrypi Caught by controller[0]: If you encounter any bugs, please report them to https://github.com/puppeteer/puppeteer/issues/new/choose.
        host.raspberrypi
        	2024-02-21 10:01:06.184	error	Caught by controller[0]: Consider opting in early by passing `headless: "new"` to `puppeteer.launch()`
        host.raspberrypi
        	2024-02-21 10:01:06.184	error	Caught by controller[0]: information, please see https://developer.chrome.com/articles/new-headless/.
        host.raspberrypi
        	2024-02-21 10:01:06.184	error	Caught by controller[0]: for Chrome instead of the old Headless implementation. For more
        host.raspberrypi
        	2024-02-21 10:01:06.184	error	Caught by controller[0]: In the near feature `headless: true` will default to the new Headless mode
        host.raspberrypi
        	2024-02-21 10:01:06.184	error	host.raspberrypi Caught by controller[0]: Puppeteer old Headless deprecation warning:
        host.raspberrypi
        	2024-02-21 10:01:06.183	error	host.raspberrypi Caught by controller[0]:
        puppeteer.0
        	2024-02-21 10:01:06.169	info	terminating
        puppeteer.0
        	2024-02-21 10:01:05.668	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        puppeteer.0
        	2024-02-21 10:01:05.667	info	terminating
        puppeteer.0
        	2024-02-21 10:01:05.663	error	Failed to launch the browser process! undefinedTROUBLESHOOTING: https://pptr.dev/troubleshooting
        puppeteer.0
        	2024-02-21 10:01:05.663	error	Error: Failed to launch the browser process! undefinedTROUBLESHOOTING: https://pptr.dev/troubleshooting at ChildProcess.onClose (/opt/iobroker/node_modules/@puppeteer/browsers/lib/cjs/launch.js:262:24) at ChildProcess.emit (node:events:529:35) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
        puppeteer.0
        	2024-02-21 10:01:05.662	error	unhandled promise rejection: Failed to launch the browser process! undefinedTROUBLESHOOTING: https://pptr.dev/troubleshooting
        puppeteer.0
        	2024-02-21 10:01:05.662	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        puppeteer.0
        	2024-02-21 10:01:05.638	info	starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v18.19.1, js-controller: 5.0.19
          A Former User @Beowolf last edited by
          @beowolf sagte in Open EPaper Display - Puppeteer:
          und, was passiert, wenn du den aufruf von chrome mit =old startest, wie in der Hilfe dazu angegeben?
            OK, das mit dem "old" hat funktioniert.
            Aber auch nur mit dieser Änderung in der main.js Datei
            async onReady() {
                this.browser = await import_puppeteer.default.launch({ headless: "old", defaultViewport: null, executablePath: '/usr/bin/chromium', args: ['--no-sandbox', '--disable-setuid-sandbox'] });
                this.subscribeStates("url");
                this.log.info("Ready to take screenshots");
            Jetzt bleibt der Adapter auf grün.
            Danke für die schnelle Hilfe.👍 👍 👍
              Beowolf last edited by Beowolf
              Zu früh gefreut.
              Jetzt kommen diese Meldungen.
              javascript.0
              	2024-02-21 17:19:04.287	warn	script.js.common.EPaper-Displays.Kellergeschoss.Heizung.Heizungsanzeige: Fehler beim Aufruf der View: http://192.168.49.38:8082/vis/index.html?openepaper#Heizung => undefined
              javascript.0
              	2024-02-21 17:18:39.753	warn	script.js.common.EPaper-Displays.Obergeschoss.Hauswirtschaftsraum: Fehler beim Aufruf der View: http://192.168.49.38:8082/vis/index.html?E-Paper-Obergeschoss#EPaper-HWR => undefined
              javascript.0
              	2024-02-21 17:18:22.551	warn	script.js.common.EPaper-Displays.Dachgeschoss.Seminarraum: Fehler beim Aufruf der View: http://192.168.49.38:8082/vis/index.html?E-Paper-Dachgeschoss#EPaper-Seminarraum => undefined
              Bei diesem Blockly
                <variables>
                  <variable id="#6wGK,7)K9MvKS1Y^m7w">imageSaveToFilenameWithPath</variable>
                  <variable id="/34/q/S9,6lBaN0B^0p+">urlOfVISView</variable>
                  <variable id="VtK5T):T+/?(:RTltehP">viewWidth</variable>
                  <variable id="d%Y)z(!gms*2[:-Q?srZ">viewHeight</variable>
                  <variable id="yI1;;SNF[v//PXeFn75c">cutoutX</variable>
                  <variable id="ixza1C+:$RS#_aO(+mTw">cutoutY</variable>
                  <variable id="JHgH!or}TSYU@4ok~:dD">cutoutWidth</variable>
                  <variable id="pui*x3;[n/WA5nodRtex">cutoutHeight</variable>
                  <variable id="{l]%ubA0HMv*]m|`-bQ#">jpgQuality</variable>
                  <variable id="^}k9.{.g,!Q=P%/G;/%p">waitForSelector</variable>
                  <variable id="O}nZ-9?%oQZ/=~9D;8MW">imageUploadURL</variable>
                  <variable id="$iC+L#(86gFYKS_:{d3%">ePaperMAC</variable>
                  <variable id="rhi=.r4Y.hIfC3yoRsIA">AP-URL</variable>
                  <variable id="LtmH{pRY8k?L^i{3%2^~">Wohnzimmer</variable>
                </variables>
                <block type="procedures_defcustomnoreturn" id="od4:#LN4MMPOX5Cuwv0G" x="138" y="-13">
                  <mutation statements="false">
                    <arg name="imageSaveToFilenameWithPath" varid="#6wGK,7)K9MvKS1Y^m7w"></arg>
                    <arg name="urlOfVISView" varid="/34/q/S9,6lBaN0B^0p+"></arg>
                    <arg name="viewWidth" varid="VtK5T):T+/?(:RTltehP"></arg>
                    <arg name="viewHeight" varid="d%Y)z(!gms*2[:-Q?srZ"></arg>
                    <arg name="cutoutX" varid="yI1;;SNF[v//PXeFn75c"></arg>
                    <arg name="cutoutY" varid="ixza1C+:$RS#_aO(+mTw"></arg>
                    <arg name="cutoutWidth" varid="JHgH!or}TSYU@4ok~:dD"></arg>
                    <arg name="cutoutHeight" varid="pui*x3;[n/WA5nodRtex"></arg>
                    <arg name="jpgQuality" varid="{l]%ubA0HMv*]m|`-bQ#"></arg>
                    <arg name="waitForSelector" varid="^}k9.{.g,!Q=P%/G;/%p"></arg>
                    <arg name="imageUploadURL" varid="O}nZ-9?%oQZ/=~9D;8MW"></arg>
                    <arg name="ePaperMAC" varid="$iC+L#(86gFYKS_:{d3%"></arg>
                  </mutation>
                  <field name="NAME">ScreenshotVISandUpload2OpenEPaperLink</field>
                  <field name="SCRIPT">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</field>
                <block type="on_ext" id="JKXn.h;3vC`f:OW42AC:" x="138" y="13">
                  <mutation xmlns="http://www.w3.org/1999/xhtml" items="4"></mutation>
                  <value name="OID0">
                    <shadow type="field_oid" id="2[)gbd6DWFVFnX}G[(EC">
                      <field name="oid">hm-rpc.0.OEQ1248163.4.ACTUAL_TEMPERATURE</field>
                  <value name="OID1">
                    <shadow type="field_oid" id="sj|;_wFBXtfS+Yl_zT|6">
                      <field name="oid">hm-rpc.0.OEQ1248163.4.SET_TEMPERATURE</field>
                  <value name="OID2">
                    <shadow type="field_oid" id="~3HYOS]U0T^B#3iL+OX]">
                      <field name="oid">hm-rpc.0.OEQ1248163.4.VALVE_STATE</field>
                  <value name="OID3">
                    <shadow type="field_oid" id="*{gdp{Lw%gcdf9n;f~v.">
                      <field name="oid">hm-rpc.0.OEQ1248163.4.BATTERY_STATE</field>
                    <block type="variables_set" id="_#_fs%Kcfjp1C?gCKDT1">
                      <field name="VAR" id="rhi=.r4Y.hIfC3yoRsIA">AP-URL</field>
                        <block type="text" id="+l/L.V(WVELt{nzG1sMl">
                          <field name="TEXT">http://192.168.49.186/imgupload</field>
                        <block type="variables_set" id="i8~V6knJldbHLWdHYkeU">
                          <field name="VAR" id="LtmH{pRY8k?L^i{3%2^~">Wohnzimmer</field>
                            <block type="text" id="L6w1~I6/$PuN8iz@6rVZ">
                              <field name="TEXT">000001814B813B35</field>
                            <block type="procedures_callcustomnoreturn" id="0nQ0@(q^Ki^qi0,9R;J2">
                              <mutation name="ScreenshotVISandUpload2OpenEPaperLink">
                                <arg name="imageSaveToFilenameWithPath"></arg>
                                <arg name="urlOfVISView"></arg>
                                <arg name="viewWidth"></arg>
                                <arg name="viewHeight"></arg>
                                <arg name="cutoutX"></arg>
                                <arg name="cutoutY"></arg>
                                <arg name="cutoutWidth"></arg>
                                <arg name="cutoutHeight"></arg>
                                <arg name="jpgQuality"></arg>
                                <arg name="waitForSelector"></arg>
                                <arg name="imageUploadURL"></arg>
                                <arg name="ePaperMAC"></arg>
                              </mutation>
                              <value name="ARG0">
                                <block type="text" id="|{r-M(tWVgp?p^G!3-W0">
                                  <field name="TEXT">/tmp/wohnzimmer.jpg</field>
                              <value name="ARG1">
                                <block type="text" id="*hw_+vHE0WnkLr0CRV8/">
                                  <field name="TEXT">http://192.168.49.38:8082/vis/index.html?E-Paper-Obergeschoss#EPaper-Wohnzimmer</field>
                              <value name="ARG2">
                                <block type="math_number" id="yhNC-+wg^qQSvoYLW%Aa">
                                  <field name="NUM">800</field>
                              <value name="ARG3">
                                <block type="math_number" id="{%*mqb.r,;_8*VThfrsf">
                                  <field name="NUM">600</field>
                              <value name="ARG4">
                                <block type="math_number" id="mg#W`=iLeMy{e`A6/b2R">
                                  <field name="NUM">0</field>
                              <value name="ARG5">
                                <block type="math_number" id="IXuOm%/dmLb7v~I$8*.f">
                              <value name="ARG6">
                                <block type="math_number" id="r2qX^fde=*rB9_:2/W$u">
                                  <field name="NUM">296</field>
                              <value name="ARG7">
                                <block type="math_number" id="$k;hZ0hajjf1ot[*!5vn">
                                  <field name="NUM">128</field>
                              <value name="ARG8">
                                <block type="math_number" id="?*EMShBY,yo;R|6:44G}">
                                  <field name="NUM">100</field>
                              <value name="ARG9">
                                <block type="text" id="J{+9jVAK!K)3S#tR{32M">
                                  <field name="TEXT">#w00052</field>
                              <value name="ARG10">
                                <block type="variables_get" id="Zc1)TBn?Oph/-$0Wr=t$">
                              <value name="ARG11">
                                <block type="variables_get" id="k)x^4wfzdRD||QkJ9dz$">
                                <block type="debug" id="2L@u~1`Ydt?8kNiCL-xe">
                                  <value name="TEXT">
                                    <shadow type="text" id="j%D-azTOZ5.4fBg2E[uQ">
                                      <field name="TEXT">TAG-Wohnzimmeranzeige wurde aktualisiert</field>
                @beowolf
                Setz mal das timeout etwas höher.. ich nutze dieses Script nicht, aber ich hatte einen ähnlichen Effekt…
                  Ich habe das jetzt von 10000 auf 20000 gesetzt.
                  Die Meldungen kommen trotzdem. Ist das zu wenig?
                    @beowolf
                    Anscheinend findet er die view nicht
                    Ist die wirklich da? Mal im Browser eingeben..
                      Die sind alle da.
                      Mit der Version 0.2.7 funktioniert ja alles.
                        diwoma last edited by
                        Wenn ich hier mal einhaken darf, es passt zum Titel, aber nicht zum ersten gemeldeten Problem.
                        Ich habe jetzt auch meinen Adapter (V4) und spiele damit herum. Auf einem Test-ioBroker in einem LXC von Proxmox.
                        Gibt es etwas auf das man beim Puppetier (V0.2.8) speziell beachten muss. Ich verwende ihn aus den mormalen Installation ohne Änderungen um folgende View anzuzeigen:
                        Das gerenderte Bild ist allerdings:
                        Der Text, der nicht angezeigt wird steht in einem normalen basic-text Widget.
                          diwoma @diwoma last edited by
                          @diwoma
                          OK, ich kann mir selbst antworten:
                          Das waren Text-Elemente, die auf ein Value gemappt werden mussten. Für die Überschrift sollte ich das Widget basic-html verwenden.
                          Wie heißt es so schön ? "Si te tacuisses ..." bzw, auf mich gemünzt:
                          Hätte ich vorher weiter versucht, hätte ich die Frage nicht stellen müssen.
                          721
