    4. geht das?: via modbus Zellspannungen von venusOS in ioBroker
      marioF @Homoran last edited by
      Die EINS 🙂
      _address	deviceId	name	description	unit	type	len	factor	offset	formula	role	room	cw	isScale
      258	1	Battery power	BMS	W	int16be	1	1	0		value.battery		false	false
      259	1	Battery voltage	BMS	V	uint16be	1	0,01	0		value.battery		false	false
      261	1	Current	BMS	A	int16be	1	10	0		value.battery		false	false
      262	1	Battery temperature	BMS	°C	int16be	1	0,1	0		value.battery		false	false
      263	1	Mid-point voltage of the battery bank	BMS	V	uint16be	1	100	0		value.battery		false	false
      264	1	Mid-point deviation of the battery bank	BMS	%	uint16be	1	100	0		value.battery		false	false
      265	1	Consumed Amphours	BMS	Ah	uint16be	1	-10	0		value.battery		false	false
      266	1	State of charge	BMS	%	uint16be	1	0,1	0		value.battery		false	false
      267	1	Alarm	BMS		uint16be	1	1	0		value.battery		false	false
      268	1	Low voltage alarm	BMS		uint16be	1	1	0		value.battery		false	false
      269	1	High voltage alarm	BMS		uint16be	1	1	0		value.battery		false	false
      272	1	Low State-of-charge alarm	BMS		uint16be	1	1	0		value.battery		false	false
      273	1	Low temperature alarm	BMS		uint16be	1	1	0		value.battery		false	false
      274	1	High temperature alarm	BMS		uint16be	1	1	0		value.battery		false	false
      275	1	Mid-voltage alarm	BMS		uint16be	1	1	0		value.battery		false	false
      276	1	Low fused-voltage alarm	BMS		uint16be	1	1	0		value.battery		false	false
      277	1	High fused-voltage alarm	BMS		uint16be	1	1	0		value.battery		false	false
      278	1	Fuse blown alarm	BMS		uint16be	1	1	0		value.battery		false	false
      279	1	High internal-temperature alarm	BMS		uint16be	1	1	0		value.battery		false	false
      280	1	Relay status	BMS		uint16be	1	1	0		value.battery		false	false
      304	1	State of health	BMS	%	uint16be	1	10	0		value.battery		false	false
      305	1	Max charge voltage	BMS	V	uint16be	1	0,1	0		value.battery		false	false
      306	1	Min discharge voltage	BMS	V	uint16be	1	0,1	0		value.battery		false	false
      307	1	Max charge current	BMS	A	uint16be	1	0.1	0		value.battery		false	false
      308	1	Max discharge current	BMS	A	uint16be	1	0,1	0		value.battery		false	false
      309	1	Capacity	BMS	Ah	uint16be	1	0,1	0		value.battery		false	false
      1290	1	MinCellVoltage	BMS	V	uint16be	1	0.01	0		value.battery		false	false
      1291	1	MaxCellVoltage	BMS	V	uint16be	1	0.01	0		value.battery		false	false
      1303	1	System-number of modules online	BMS		uint16be	1	1	0		value.battery		false	false
      1306	1	ID of module with lowest cell voltage	BMS		string	4	1	0		value.battery		false	false
      1310	1	ID of module with highest cell voltage	BMS		string	4	1	0		value.battery		false	false
        Homoran Global Moderator Administrators @marioF last edited by
        @mariof sagte in geht das?: via modbus Zellspannungen von venusOS in ioBroker:
        Die EINS
        nein, nicht da
        Einstellungen - Dienste - Modbus - verfügbare Dienste
          @homoran hoppla,... ich hatte Deine erste Zeile überlesen. 😕 Nachtrag:
          über ein RS485 Konverter -> RS485 Adapter -> Treiber: https://github.com/Louisvdw/dbus-serialbattery
            und als welche Geräte ID identifiziert die Venus dieses Konstrukt?
                Homoran Global Moderator Administrators @marioF last edited by Homoran
                als Eins (?).
                oops! Da auch?
                ist das ein Raspi Spezifikum?
                ich hab den Cerbo.
                stay tuned, ich checke was.
                EDIT
                eine ID 1 ist mir nirgendwo untergekommen, sorry
                • adcrafter27
                  adcrafter27 last edited by
                  Hallo ich konnte die daten auch nicht Über Modbus Auslesen, nur min,max und div
                  Musste dann auch alles Über Mqtt machen, dort bekommst du alle daten
                  M S 2 Replies Last reply Reply Quote 0
                    marioF @adcrafter27 last edited by
                    @adcrafter27 merci für die info & ein entspannten rest-3.-advent.
                      @mariof
                      ich hab jetzt auch mein jk bms für die Yttrium Batterie im Wohnmobil.
                      Was hast du für ein Kabel zum Anschluss an den Cerbo/Venus-Pi?
                      Wo bekommt man das?
                        schneire @adcrafter27 last edited by
                        @adcrafter27
                        Servus bis hierher bin ich nun auch gekommen und modbus liefert nicht die Daten.
                        Wie hast du Mqtt hier angebunden? VG Reiner
                        adcrafter27 1 Reply Last reply Reply Quote 0
                        • adcrafter27
                          adcrafter27 @schneire last edited by
                          @schneire
                          Hier wurde das ganze schon behandelt
                          https://forum.iobroker.net/topic/72404/mqtt-zum-victron-cerbo-gx/7?_=1708937571773
                            @adcrafter27 danke ich werde mich dort schlau machen.
                            1120
