    4. Raspberry "friert ein" nach Aufruf von ioBroker
      Greenhorn @Meister Mopper last edited by
      @meister-mopper said in Raspberry "friert ein" nach Aufruf von ioBroker:
      iob diag
      Hoffe, das ist richtig:
      Copy text starting here:
      			v.2023-10-10
         Static hostname: iobroker
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Installation: 		native
      Kernel: 		aarch64
      Userland: 		arm64
      Timezone: 		Europe/London (GMT, +0000)
      User-ID: 		1000
      X-Server: 		false
      Boot Target: 		multi-user.target
      Pending OS-Updates: 	3
      Pending iob updates: 	14
      Nodejs-Installation: 	/usr/bin/nodejs 	v12.22.12
      			/usr/bin/node 		v12.22.12
      /home/iobroker/.diag.sh: line 488: npm: command not found
      /home/iobroker/.diag.sh: line 489: npx: command not found
      /home/iobroker/.diag.sh: line 490: corepack: command not found
      Recommended versions are nodejs Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"! and npm
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed.
      Please check
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      for more information on how to fix these errors.
      MEMORY:
      Mem:            3.8G        2.0G        947M        1.0M        885M        2.0G
      Swap:            99M          0B         99M
      Total:          3.9G        2.0G        1.0G
      Active iob-Instances: 	9
      Active repo(s): stable
      ioBroker Core: 		js-controller 		4.0.24
      			admin 			6.8.0
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
        system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 		3908
      States: 		3264
      Size of iob-Database:
      244M	/opt/iobroker/iobroker-data/objects.jsonl
      2.5M	/opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      simon@iobroker:~ $
        Greenhorn @wendy2702 last edited by
        @wendy2702 said in Raspberry "friert ein" nach Aufruf von ioBroker:
        iob
        simon@iobroker:~ $ iob fix
        library: loaded
        Library version=2024-01-04
        ioBroker or some processes are still running:
        io.sonoff.0
        io.hmip.0
        io.mqtt.0
        io.discovery.0
        io.web.0
        io.link.0
        io.midea.0
        io.iqontrol.0
        Please stop them first and try again!
        simon@iobroker:~ $
        simon@iobroker:~ $ NODE_MAJOR=18
        simon@iobroker:~ $ sudo apt update
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://apt.grafana.com stable InRelease
        Get:6 https://repos.influxdata.com/debian bullseye InRelease [7,049 B]
        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Err:6 https://repos.influxdata.com/debian bullseye InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        Reading package lists... Done
        W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
        simon@iobroker:~ $
        • wendy2702
          wendy2702 @Greenhorn last edited by
          @greenhorn ist zwar nur die Kurzfassung aber:
          Altes OS mit uralter NodeJs Version.
          Hast du Backups?
          Dein Admin läuft nicht wenn ich das richtig sehe:
             iob start admin.0
            @wendy2702 Nein, leider kein richtiges Backup...
            • wendy2702
              @greenhorn
              Du hast ein log vom fix Befehl gepostet.
              Da steht am Ende drin das Iob noch läuft und zuerst gestoppt werden soll.
              Hast du das gelesen und gemacht?
              Das mit dem NodeJS was du gepostet hast, ist das was vollständiges?
              G 2 Replies Last reply Reply Quote 0
                @wendy2702 Sorry, ich komme da leider nicht ganz mit. Wie kann ich das mit dem NodeJS vollständig erhalten?
                  @wendy2702
                  simon@iobroker:~ $ iob stop
                  library: loaded
                  Welcome to the ioBroker installation fixer!
                  Script version: 2024-01-04
                  You might need to enter your password a couple of times.
                  Installing prerequisites (1/5)
                  Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                  Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,049 B]
                  Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Hit:7 https://apt.grafana.com stable InRelease
                  Err:5 https://repos.influxdata.com/debian bullseye InRelease
                  Checking ioBroker user and directory permissions (2/5)
                  Created /etc/sudoers.d/iobroker
                  Fixing directory permissions...
                  Check and cleanup npm temporary directories (3/5)
                  Done.
                  Database maintenance (4/5)
                  Checking for uncompressed JSONL databases... This might take a while!
                  usage: sudo -h | -K | -k | -V
                  usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
                  usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user] [command]
                  usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] [VAR=value] [-i|-s] [<command>]
                  usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
                  main: line 14: [: -lt: unary operator expected
                  sudo: npm: command not found
                  Checking autostart (5/5)
                  Enabling autostart...
                  Autostart enabled!
                  Your installation was fixed successfully
                  Run iobroker start to start ioBroker again!
                  simon@iobroker:~ $ iobroker start
                  simon@iobroker:~ $
                  • wendy2702
                    Diese Reihenfolge
                    iob stop
                    iob fix
                    Dann die komplette Ausgabe davon hier als Text posten.
                    Dann schauen wir mal weiter
                    Edit: ht sich überschnitten mit deinem post
                    • wendy2702
                      Dann jetzt mal
                      iob diag
                      Davon dann auch die Langfassung Ausgabe mal zeigen
                        iob diag
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Model		: Raspberry Pi 4 Model B Rev 1.5
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : arm64
                        Systemuptime and Load:
                         19:47:29 up 32 min,  1 user,  load average: 0.31, 0.55, 0.47
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** Time and Time Zones ***
                                       Local time: Sun 2024-02-25 19:47:30 GMT
                                   Universal time: Sun 2024-02-25 19:47:30 UTC
                                         RTC time: n/a
                                        Time zone: Europe/London (GMT, +0000)
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        simon
                        /home/simon
                        simon adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server: 	false
                        Desktop:
                        Terminal: 	tty
                        *** MEMORY ***
                        Mem:            3.8G        1.8G        955M        1.0M        1.0G        2.2G
                        Swap:            99M          0B         99M
                        Total:          3.9G        1.8G        1.1G
                                 3794 M total memory
                                 1830 M used memory
                                 1700 M active memory
                                  921 M inactive memory
                                  955 M free memory
                                   75 M buffer memory
                                  932 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/root      ext4       29G  4.7G   24G  17% /
                        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                        tmpfs          tmpfs     759M  1.2M  758M   1% /run
                        /dev/mmcblk0p1 vfat      255M   32M  223M  13% /boot
                        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                        [Sun Feb 25 19:14:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Sun Feb 25 19:14:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Sun Feb 25 19:14:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Sun Feb 25 19:14:37 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                        TARGET  SOURCE         FSTYPE OPTIONS
                        /       /dev/mmcblk0p2 ext4   rw,noatime
                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        1.4G	/var/
                        859M	/var/log
                        841M	/var/log/journal/2afb5f7f70fe4270a1433886fb089ee5
                        302M	/var/cache
                        Archived and active journals take up 840.1M in the file system.
                        /opt/iobroker/backups:
                        55M	/opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        463M	/opt/iobroker/iobroker-data/
                        135M	/opt/iobroker/iobroker-data/files
                        52M	/opt/iobroker/iobroker-data/files/javascript.admin
                        40M	/opt/iobroker/iobroker-data/backup-objects
                        34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                        285M	/opt/iobroker/iobroker-data/objects.jsonl
                        7.1M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
                        6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                        5.8M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
                        4.6M	/opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                        USB-Devices by-id:
                        *** NodeJS-Installation ***
                        /home/iobroker/.diag.sh: line 279: npm: command not found
                        /home/iobroker/.diag.sh: line 280: npx: command not found
                        /home/iobroker/.diag.sh: line 281: corepack: command not found
                        /home/iobroker/.diag.sh: line 290: npm: command not found
                        /home/iobroker/.diag.sh: line 291: npx: command not found
                        nodejs:
                          Installed: 12.22.12~dfsg-1~deb11u4
                          Candidate: 18.19.1-1nodesource1
                          Version table:
                             18.19.1-1nodesource1 500
                             18.19.0-1nodesource1 500
                             18.18.2-1nodesource1 500
                             18.18.1-1nodesource1 500
                             18.18.0-1nodesource1 500
                             18.17.1-1nodesource1 500
                             18.17.0-1nodesource1 500
                             18.16.1-1nodesource1 500
                             18.16.0-1nodesource1 500
                             18.15.0-1nodesource1 500
                             18.14.2-1nodesource1 500
                             18.14.1-1nodesource1 500
                             18.14.0-1nodesource1 500
                             18.13.0-1nodesource1 500
                             18.12.0-1nodesource1 500
                             18.11.0-1nodesource1 500
                             18.10.0-1nodesource1 500
                             18.9.1-1nodesource1 500
                             18.9.0-1nodesource1 500
                             18.8.0-1nodesource1 500
                             18.7.0-1nodesource1 500
                             18.6.0-1nodesource1 500
                             18.5.0-1nodesource1 500
                             18.4.0-1nodesource1 500
                             18.3.0-1nodesource1 500
                             18.2.0-1nodesource1 500
                             18.1.0-1nodesource1 500
                             18.0.0-1nodesource1 500
                         *** 12.22.12~dfsg-1~deb11u4 500
                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                100 /var/lib/dpkg/status
                        No problems detected
                        Errors in npm tree:
                        /home/iobroker/.diag.sh: line 360: npm: command not found
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller: 	4.0.24
                        admin: 		6.8.0
                        javascript: 	7.1.4
                        /home/iobroker/.diag.sh: line 375: npm: command not found
                        Adapters from github: 	0
                        Adapter State
                          system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
                        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                        + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                          system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
                        + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                          system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                          system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
                        + system.adapter.link.0                   : link                  : iobroker                                 -  enabled
                        + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
                          system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                          system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
                          system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
                        + instance is alive
                        ioBroker-Repositories
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 6.13.16  , installed 6.8.0  [Updatable]
                        Adapter    "backitup"     : 2.10.11  , installed 2.6.23 [Updatable]
                        Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
                        Adapter    "hmip"         : 1.21.0   , installed 1.20.0 [Updatable]
                        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                        Adapter    "jarvis"       : 3.1.8    , installed 3.1.2  [Updatable]
                        Adapter    "javascript"   : 7.8.0    , installed 7.1.4  [Updatable]
                        Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
                        Adapter    "link"         : 0.5.12   , installed 0.5.12
                        Adapter    "midea"        : 0.0.7    , installed 0.0.7
                        Adapter    "mqtt"         : 5.2.0    , installed 4.1.1  [Updatable]
                        Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
                        Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
                        Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
                        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                        Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
                        Adapter    "ws"           : 2.5.10   , installed 1.3.0  [Updatable]
                        Adapter    "zigbee"       : 1.10.1   , installed 1.9.7  [Updatable]
                        Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
                        Objects and States
                        Objects: 	3908
                        States: 	3264
                        Pending Updates: 3
                        *** Listening Ports ***
                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        14428      512/influxd
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       28796      4257/io.sonoff.0
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13142      553/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27223      4238/iobroker.js-co
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28486      4238/iobroker.js-co
                        tcp6       0      0 :::8086                 :::*                    LISTEN      110        14037      512/influxd
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27330      4313/io.web.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          13153      553/sshd: /usr/sbin
                        tcp6       0      0 :::3000                 :::*                    LISTEN      111        14178      692/grafana
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12258      400/avahi-daemon: r
                        udp        0      0 0.0.0.0:42522           0.0.0.0:*                           108        12260      400/avahi-daemon: r
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14048      691/dhcpcd
                        udp6       0      0 :::5353                 :::*                                108        12259      400/avahi-daemon: r
                        udp6       0      0 :::57185                :::*                                108        12261      400/avahi-daemon: r
                        2024-02-25 19:41:36.839  - info: iqontrol.0 (4359) Creating Popup States...
                        2024-02-25 19:41:37.570  - info: iqontrol.0 (4359) Creating Widget States...
                        2024-02-25 19:41:37.571  - info: iqontrol.0 (4359) Lists deactivated.
                        2024-02-25 19:41:37.572  - info: iqontrol.0 (4359) Deleting unused Objects...
                        2024-02-25 19:41:37.574  - info: iqontrol.0 (4359) Subscribing to states...
                        2024-02-25 19:41:37.575  - info: iqontrol.0 (4359) iQontrol ready.
                        2024-02-25 19:41:43.883  - info: hmip.0 (4272) ws connection opened
                        2024-02-25 19:41:44.152  - info: hmip.0 (4272) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-73,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false},"authorized":true,"actionParameter":"NOT_CUSTOMISABLE","actionCodeConfigured":false},"14":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":14,"groupIndex":7,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}},"15":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":15,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_PRIMARY_ACTION_CHANNEL","groups":[],"channelRole":null,"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false},"authorized":true,"actionParameter":"NOT_CUSTOMISABLE","actionCodeConfigured":false},"16":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":16,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}}},"deviceArchetype":"HMIP","manuallyUpdateForced":true,"measuredAttributes":{},"updateState":"UP_TO_DATE","firmwareVersion":"1.0.12","modelType":"HmIP-WKP","permanentlyReachable":false,"connectionType":"HMIP_RF","firmwareVersionInteger":65548,"liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","modelId":441,"availableFirmwareVersion":"1.0.12","serializedGlobalTradeItemNumber":"3014F711A0002E9F29992FF7","manufacturerCode":1,"oem":"eQ-3"}
                        2024-02-25 19:41:54.684  - info: hmip.0 (4272) hmip adapter connected and ready
                        			v.2023-10-10
                                 Icon name: computer
                              Architecture: arm64
                        Kernel: 		aarch64
                        Userland: 		arm64
                        User-ID: 		1000
                        X-Server: 		false
                        Recommended versions are nodejs  and npm
                        Please check
                        MEMORY:
                        Mem:            3.8G        1.9G        909M        1.0M        998M        2.1G
                        Swap:            99M          0B         99M
                        Total:          3.9G        1.9G        1.0G
                        			admin 			6.8.0
                        Objects type: jsonl
                        States  type: jsonl
                        Objects: 		3908
                        States: 		3264
                        4.2M	/opt/iobroker/iobroker-data/states.jsonl
                        wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
                          Musste zwischendrin etwas ausschneiden, weil der Eintrag sonst zu lang geworden wäre...
                          • wendy2702
                            @greenhorn
                            Jetzt
                            iob nodejs-update
                            Dauert wahrscheinlich was länger.
                              iob nodejs-update
                              ioBroker nodejs updater 2023-10-13
                              No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
                              Your current setup is:
                              /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
                              /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
                              /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
                              /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
                              We found these nodejs versions available for installation:
                              nodejs:
                              Version table:
                              Your nodejs-Installation seems to be faulty. Shall we try to fix it?
                              Press <y> to continue or any other key to quit
                              Fixing your nodejs setup
                              *** Deleting ***
                              rm: cannot remove '': No such file or directory
                              *** Deleting ***
                              Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
                              You are running nodejs v12.22.12. Do you want to install latest version from nodejs v.18 tree?
                              Update der Installation läuft gerade noch...
                                *** Deleting ***
                                *** Deleting ***
                                Trying to update your installation now. Please be patient.
                                Waiting for ioBroker to shut down - Give me a minute...
                                *** These repos are active on your system:
                                Hit:1 http://deb.debian.org/debian bullseye InRelease
                                Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                Get:6 https://repos.influxdata.com/debian bullseye InRelease [7049 B]
                                *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                                *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                                deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                                Package: nodejs
                                Pin: origin deb.nodesource.com
                                Pin-Priority: 1001
                                *** These repos are active after the adjustments:
                                Get:5 https://repos.influxdata.com/debian bullseye InRelease [7049 B]
                                Hit:6 https://apt.grafana.com stable InRelease
                                Installing the recommended nodejs version now!
                                Exact recommended version unknown, installing a fallback!
                                (Reading database ... 55472 files and directories currently installed.)
                                Removing nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
                                dpkg: libnode72:arm64: dependency problems, but removing anyway as you requested:
                                nodejs depends on libnode72 (= 12.22.12~dfsg-1~deb11u4).
                                Removing libnode72:arm64 (12.22.12~dfsg-1~deb11u4) ...
                                (Reading database ... 55284 files and directories currently installed.)
                                Preparing to unpack .../nodejs_18.0.0-1nodesource1_arm64.deb ...
                                Unpacking nodejs (18.0.0-1nodesource1) over (12.22.12~dfsg-1~deb11u4) ...
                                Setting up nodejs (18.0.0-1nodesource1) ...
                                Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...
                                Processing triggers for man-db (2.9.4-2) ...
                                Updating fallback to latest nodejs v18 release
                                Preconfiguring packages ...
                                (Reading database ... 60946 files and directories currently installed.)
                                Preparing to unpack .../tar_1.34+dfsg-1+deb11u1_arm64.deb ...
                                Unpacking tar (1.34+dfsg-1+deb11u1) over (1.34+dfsg-1) ...
                                Setting up tar (1.34+dfsg-1+deb11u1) ...
                                Preparing to unpack .../tzdata_2024a-0+deb11u1_all.deb ...
                                Unpacking tzdata (2024a-0+deb11u1) over (2021a-1+deb11u11) ...
                                Preparing to unpack .../distro-info-data_0.51+deb11u5_all.deb ...
                                Unpacking distro-info-data (0.51+deb11u5) over (0.51+deb11u4) ...
                                Preparing to unpack .../nodejs_18.19.1-1nodesource1_arm64.deb ...
                                Detected old npm client, removing...
                                Unpacking nodejs (18.19.1-1nodesource1) over (18.0.0-1nodesource1) ...
                                Setting up distro-info-data (0.51+deb11u5) ...
                                Setting up nodejs (18.19.1-1nodesource1) ...
                                Setting up tzdata (2024a-0+deb11u1) ...
                                Current default time zone: 'Europe/London'
                                Local time is now: Sun Feb 25 20:02:26 GMT 2024.
                                Universal Time is now: Sun Feb 25 20:02:26 UTC 2024.
                                Run 'dpkg-reconfigure tzdata' if you wish to change it.
                                Processing triggers for mailcap (3.69) ...
                                v18.19.1 has been installed! You are using the latest version now!
                                Installing the recommended nodejs version!
                                We tried our best to update or fix your nodejs. Please run iob diag again to verify.
                                *** RESTARTING ioBroker NOW! ***
                                Please refresh or restart your browser in a few moments.
                                simon@iobroker:~ $
                                  Thomas Braun Most Active @Greenhorn last edited by
                                  @greenhorn sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                                  Stell das richtig ein. Geht in
                                  sudo raspi-config
                                  Dann
                                  sudo rm /etc/apt/sources.list.d/influ*
                                  wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                  echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                                  echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                  rm influxdata-archive_compat.key
                                  sudo apt update
                                  sudo apt full-upgrade
                                  sudo reboot
                                  Dann
                                  iob update
                                  iob upgrade all -y
                                  iob stop
                                  iob upgrade self
                                  iob restart
                                    OK, grad mal noch neues iob.diag
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                     20:05:04 up 50 min,  1 user,  load average: 1.40, 1.04, 0.64
                                    CPU threads: 4
                                    Current issues:
                                                   Local time: Sun 2024-02-25 20:05:04 GMT
                                               Universal time: Sun 2024-02-25 20:05:04 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    simon
                                    /home/simon
                                    X-Server: 	false
                                    Desktop:
                                    Terminal: 	tty
                                    *** MEMORY ***
                                    Mem:            3.8G        1.7G        740M        1.0M        1.4G        2.1G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        1.7G        840M
                                             3794 M total memory
                                             1680 M used memory
                                             1813 M active memory
                                              990 M inactive memory
                                              740 M free memory
                                              124 M buffer memory
                                             1247 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       29G  4.9G   23G  18% /
                                    /var:
                                    1.5G	/var/
                                    859M	/var/log
                                    356M	/var/cache
                                    505M	/opt/iobroker/iobroker-data/
                                    325M	/opt/iobroker/iobroker-data/objects.jsonl
                                    5.1M	/opt/iobroker/iobroker-data/states.jsonl
                                    USB-Devices by-id:
                                    /usr/bin/nodejs 	v18.19.1
                                    /usr/bin/node 		v18.19.1
                                    /usr/bin/npm 		10.2.4
                                    /usr/bin/npx 		10.2.4
                                    /usr/bin/corepack 	0.22.0
                                    nodejs:
                                      Installed: 18.19.1-1nodesource1
                                      Version table:
                                     *** 18.19.1-1nodesource1 1001
                                         18.19.0-1nodesource1 1001
                                         18.18.2-1nodesource1 1001
                                         18.18.1-1nodesource1 1001
                                         18.18.0-1nodesource1 1001
                                         18.17.1-1nodesource1 1001
                                         18.17.0-1nodesource1 1001
                                         18.16.1-1nodesource1 1001
                                         18.16.0-1nodesource1 1001
                                         18.15.0-1nodesource1 1001
                                         18.14.2-1nodesource1 1001
                                         18.14.1-1nodesource1 1001
                                         18.14.0-1nodesource1 1001
                                         18.13.0-1nodesource1 1001
                                         18.12.0-1nodesource1 1001
                                         18.11.0-1nodesource1 1001
                                         18.10.0-1nodesource1 1001
                                         18.9.1-1nodesource1 1001
                                         18.9.0-1nodesource1 1001
                                         18.8.0-1nodesource1 1001
                                         18.7.0-1nodesource1 1001
                                         18.6.0-1nodesource1 1001
                                         18.5.0-1nodesource1 1001
                                         18.4.0-1nodesource1 1001
                                         18.3.0-1nodesource1 1001
                                         18.2.0-1nodesource1 1001
                                         18.1.0-1nodesource1 1001
                                         18.0.0-1nodesource1 1001
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin: 		6.8.0
                                    javascript: 	7.1.4
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    • wendy2702
                                      @greenhorn du musst dich in Geduld üben und auch lesen was da steht. Die Ausgabe war noch nicht fertig
                                        • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.178.96
                                        • system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0
                                        Die liegen nauf dem gleichen Port.
                                          Greenhorn @Thomas Braun last edited by
                                          @thomas-braun said in Raspberry "friert ein" nach Aufruf von ioBroker:
                                          iob upgrade all -y
                                          Läuft noch...melde mich wenn fertig.
                                            iob restart
                                            Alles einwandfrei durchgelaufen bis auf:
                                            simon@iobroker:~ $ iob upgrade self
                                            No connection to databases possible ...
                                            5294
