    4. Raspberry "friert ein" nach Aufruf von ioBroker
    • wendy2702
      wendy2702 @Greenhorn last edited by
      @greenhorn
      Du hast ein log vom fix Befehl gepostet.
      Da steht am Ende drin das Iob noch läuft und zuerst gestoppt werden soll.
      Hast du das gelesen und gemacht?
      Das mit dem NodeJS was du gepostet hast, ist das was vollständiges?
      G 2 Replies Last reply Reply Quote 0
        Greenhorn @wendy2702 last edited by
        @wendy2702 Sorry, ich komme da leider nicht ganz mit. Wie kann ich das mit dem NodeJS vollständig erhalten?
          @wendy2702
          simon@iobroker:~ $ iob stop
          simon@iobroker:~ $ iob fix
          library: loaded
          Library version=2024-01-04
          Welcome to the ioBroker installation fixer!
          Script version: 2024-01-04
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
          Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,049 B]
          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
          Hit:7 https://apt.grafana.com stable InRelease
          Err:5 https://repos.influxdata.com/debian bullseye InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          Reading package lists... Done
          W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
          N: Updating from such a repository can't be done securely, and is therefore disabled by default.
          N: See apt-secure(8) manpage for repository creation and user configuration details.
          Checking ioBroker user and directory permissions (2/5)
          Created /etc/sudoers.d/iobroker
          Fixing directory permissions...
          Check and cleanup npm temporary directories (3/5)
          Done.
          Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          usage: sudo -h | -K | -k | -V
          usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
          usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user] [command]
          usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] [VAR=value] [-i|-s] [<command>]
          usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
          main: line 14: [: -lt: unary operator expected
          sudo: npm: command not found
          Checking autostart (5/5)
          Enabling autostart...
          Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
          simon@iobroker:~ $ iobroker start
          simon@iobroker:~ $
          • wendy2702
            Diese Reihenfolge
            iob stop
            iob fix
            Dann die komplette Ausgabe davon hier als Text posten.
            Dann schauen wir mal weiter
            Edit: ht sich überschnitten mit deinem post
            • wendy2702
              Dann jetzt mal
              iob diag
              Davon dann auch die Langfassung Ausgabe mal zeigen
                @wendy2702 said in Raspberry "friert ein" nach Aufruf von ioBroker:
                iob diag
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                   Static hostname: iobroker
                         Icon name: computer
                  Operating System: Debian GNU/Linux 11 (bullseye)
                            Kernel: Linux 6.1.21-v8+
                      Architecture: arm64
                Model		: Raspberry Pi 4 Model B Rev 1.5
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : arm64
                Systemuptime and Load:
                 19:47:29 up 32 min,  1 user,  load average: 0.31, 0.55, 0.47
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Sun 2024-02-25 19:47:30 GMT
                           Universal time: Sun 2024-02-25 19:47:30 UTC
                                 RTC time: n/a
                                Time zone: Europe/London (GMT, +0000)
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                simon
                /home/simon
                simon adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server: 	false
                Desktop:
                Terminal: 	tty
                Boot Target: 	multi-user.target
                *** MEMORY ***
                Mem:            3.8G        1.8G        955M        1.0M        1.0G        2.2G
                Swap:            99M          0B         99M
                Total:          3.9G        1.8G        1.1G
                         3794 M total memory
                         1830 M used memory
                         1700 M active memory
                          921 M inactive memory
                          955 M free memory
                           75 M buffer memory
                          932 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** FILESYSTEM ***
                /dev/root      ext4       29G  4.7G   24G  17% /
                devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                tmpfs          tmpfs     759M  1.2M  758M   1% /run
                /dev/mmcblk0p1 vfat      255M   32M  223M  13% /boot
                tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                [Sun Feb 25 19:14:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Sun Feb 25 19:14:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Sun Feb 25 19:14:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Sun Feb 25 19:14:37 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                TARGET  SOURCE         FSTYPE OPTIONS
                /       /dev/mmcblk0p2 ext4   rw,noatime
                `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                1.4G	/var/
                859M	/var/log
                841M	/var/log/journal/2afb5f7f70fe4270a1433886fb089ee5
                302M	/var/cache
                Archived and active journals take up 840.1M in the file system.
                /opt/iobroker/backups:
                55M	/opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                463M	/opt/iobroker/iobroker-data/
                135M	/opt/iobroker/iobroker-data/files
                52M	/opt/iobroker/iobroker-data/files/javascript.admin
                40M	/opt/iobroker/iobroker-data/backup-objects
                34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                285M	/opt/iobroker/iobroker-data/objects.jsonl
                7.1M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
                6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                5.8M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
                4.6M	/opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                USB-Devices by-id:
                *** NodeJS-Installation ***
                /usr/bin/nodejs 	v12.22.12
                /usr/bin/node 		v12.22.12
                /home/iobroker/.diag.sh: line 279: npm: command not found
                /home/iobroker/.diag.sh: line 280: npx: command not found
                /home/iobroker/.diag.sh: line 281: corepack: command not found
                /home/iobroker/.diag.sh: line 290: npm: command not found
                /home/iobroker/.diag.sh: line 291: npx: command not found
                *** nodejs is NOT correctly installed ***
                nodejs:
                  Installed: 12.22.12~dfsg-1~deb11u4
                  Candidate: 18.19.1-1nodesource1
                  Version table:
                     18.19.1-1nodesource1 500
                     18.19.0-1nodesource1 500
                     18.18.2-1nodesource1 500
                     18.18.1-1nodesource1 500
                     18.18.0-1nodesource1 500
                     18.17.1-1nodesource1 500
                     18.17.0-1nodesource1 500
                     18.16.1-1nodesource1 500
                     18.16.0-1nodesource1 500
                     18.15.0-1nodesource1 500
                     18.14.2-1nodesource1 500
                     18.14.1-1nodesource1 500
                     18.14.0-1nodesource1 500
                     18.13.0-1nodesource1 500
                     18.12.0-1nodesource1 500
                     18.11.0-1nodesource1 500
                     18.10.0-1nodesource1 500
                     18.9.1-1nodesource1 500
                     18.9.0-1nodesource1 500
                     18.8.0-1nodesource1 500
                     18.7.0-1nodesource1 500
                     18.6.0-1nodesource1 500
                     18.5.0-1nodesource1 500
                     18.4.0-1nodesource1 500
                     18.3.0-1nodesource1 500
                     18.2.0-1nodesource1 500
                     18.1.0-1nodesource1 500
                     18.0.0-1nodesource1 500
                 *** 12.22.12~dfsg-1~deb11u4 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                        100 /var/lib/dpkg/status
                No problems detected
                Errors in npm tree:
                /home/iobroker/.diag.sh: line 360: npm: command not found
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller: 	4.0.24
                admin: 		6.8.0
                javascript: 	7.1.4
                /home/iobroker/.diag.sh: line 375: npm: command not found
                Adapters from github: 	0
                Adapter State
                  system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
                + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                  system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
                + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                  system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                  system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
                + system.adapter.link.0                   : link                  : iobroker                                 -  enabled
                + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
                  system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
                + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                  system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
                  system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 6.13.16  , installed 6.8.0  [Updatable]
                Adapter    "backitup"     : 2.10.11  , installed 2.6.23 [Updatable]
                Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
                Adapter    "hmip"         : 1.21.0   , installed 1.20.0 [Updatable]
                Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                Adapter    "jarvis"       : 3.1.8    , installed 3.1.2  [Updatable]
                Adapter    "javascript"   : 7.8.0    , installed 7.1.4  [Updatable]
                Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
                Adapter    "link"         : 0.5.12   , installed 0.5.12
                Adapter    "midea"        : 0.0.7    , installed 0.0.7
                Adapter    "mqtt"         : 5.2.0    , installed 4.1.1  [Updatable]
                Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
                Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
                Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
                Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
                Adapter    "ws"           : 2.5.10   , installed 1.3.0  [Updatable]
                Adapter    "zigbee"       : 1.10.1   , installed 1.9.7  [Updatable]
                Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
                Objects and States
                Objects: 	3908
                States: 	3264
                Pending Updates: 3
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        14428      512/influxd
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       28796      4257/io.sonoff.0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13142      553/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27223      4238/iobroker.js-co
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28486      4238/iobroker.js-co
                tcp6       0      0 :::8086                 :::*                    LISTEN      110        14037      512/influxd
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27330      4313/io.web.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          13153      553/sshd: /usr/sbin
                tcp6       0      0 :::3000                 :::*                    LISTEN      111        14178      692/grafana
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12258      400/avahi-daemon: r
                udp        0      0 0.0.0.0:42522           0.0.0.0:*                           108        12260      400/avahi-daemon: r
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14048      691/dhcpcd
                udp6       0      0 :::5353                 :::*                                108        12259      400/avahi-daemon: r
                udp6       0      0 :::57185                :::*                                108        12261      400/avahi-daemon: r
                2024-02-25 19:41:36.839  - info: iqontrol.0 (4359) Creating Popup States...
                2024-02-25 19:41:37.570  - info: iqontrol.0 (4359) Creating Widget States...
                2024-02-25 19:41:37.571  - info: iqontrol.0 (4359) Lists deactivated.
                2024-02-25 19:41:37.572  - info: iqontrol.0 (4359) Deleting unused Objects...
                2024-02-25 19:41:37.574  - info: iqontrol.0 (4359) Subscribing to states...
                2024-02-25 19:41:37.575  - info: iqontrol.0 (4359) iQontrol ready.
                2024-02-25 19:41:43.883  - info: hmip.0 (4272) ws connection opened
                2024-02-25 19:41:44.152  - info: hmip.0 (4272) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-73,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false},"authorized":true,"actionParameter":"NOT_CUSTOMISABLE","actionCodeConfigured":false},"14":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":14,"groupIndex":7,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}},"15":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":15,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_PRIMARY_ACTION_CHANNEL","groups":[],"channelRole":null,"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false},"authorized":true,"actionParameter":"NOT_CUSTOMISABLE","actionCodeConfigured":false},"16":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":16,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}}},"deviceArchetype":"HMIP","manuallyUpdateForced":true,"measuredAttributes":{},"updateState":"UP_TO_DATE","firmwareVersion":"1.0.12","modelType":"HmIP-WKP","permanentlyReachable":false,"connectionType":"HMIP_RF","firmwareVersionInteger":65548,"liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","modelId":441,"availableFirmwareVersion":"1.0.12","serializedGlobalTradeItemNumber":"3014F711A0002E9F29992FF7","manufacturerCode":1,"oem":"eQ-3"}
                2024-02-25 19:41:54.684  - info: hmip.0 (4272) hmip adapter connected and ready
                Copy text starting here:
                			v.2023-10-10
                         Icon name: computer
                      Architecture: arm64
                Installation: 		native
                Kernel: 		aarch64
                Userland: 		arm64
                Timezone: 		Europe/London (GMT, +0000)
                User-ID: 		1000
                X-Server: 		false
                Pending OS-Updates: 	3
                Pending iob updates: 	14
                Nodejs-Installation: 	/usr/bin/nodejs 	v12.22.12
                /home/iobroker/.diag.sh: line 488: npm: command not found
                /home/iobroker/.diag.sh: line 489: npx: command not found
                /home/iobroker/.diag.sh: line 490: corepack: command not found
                Recommended versions are nodejs  and npm
                Wrong installation path detected. This needs to be fixed.
                Please check
                https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                for more information on how to fix these errors.
                MEMORY:
                Mem:            3.8G        1.9G        909M        1.0M        998M        2.1G
                Swap:            99M          0B         99M
                Total:          3.9G        1.9G        1.0G
                Active iob-Instances: 	9
                ioBroker Core: 		js-controller 		4.0.24
                			admin 			6.8.0
                ioBroker Status: 	iobroker is running on this host.
                Objects type: jsonl
                States  type: jsonl
                Objects: 		3908
                States: 		3264
                Size of iob-Database:
                4.2M	/opt/iobroker/iobroker-data/states.jsonl
                === Mark text until here for copying ===
                wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
                  Musste zwischendrin etwas ausschneiden, weil der Eintrag sonst zu lang geworden wäre...
                  • wendy2702
                    @greenhorn
                    Jetzt
                    iob nodejs-update
                    Dauert wahrscheinlich was länger.
                      iob nodejs-update
                      ioBroker nodejs updater 2023-10-13
                      No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
                      Your current setup is:
                      /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
                      /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
                      /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
                      /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
                      We found these nodejs versions available for installation:
                      nodejs:
                      Version table:
                      Your nodejs-Installation seems to be faulty. Shall we try to fix it?
                      Press <y> to continue or any other key to quit
                      Fixing your nodejs setup
                      *** Deleting ***
                      rm: cannot remove '': No such file or directory
                      *** Deleting ***
                      Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
                      You are running nodejs v12.22.12. Do you want to install latest version from nodejs v.18 tree?
                      Update der Installation läuft gerade noch...
                        *** Deleting ***
                        *** Deleting ***
                        Trying to update your installation now. Please be patient.
                        Waiting for ioBroker to shut down - Give me a minute...
                        *** These repos are active on your system:
                        Hit:1 http://deb.debian.org/debian bullseye InRelease
                        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:5 https://apt.grafana.com stable InRelease
                        Get:6 https://repos.influxdata.com/debian bullseye InRelease [7049 B]
                        Err:6 https://repos.influxdata.com/debian bullseye InRelease
                        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                        *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                        Package: nodejs
                        Pin: origin deb.nodesource.com
                        Pin-Priority: 1001
                        *** These repos are active after the adjustments:
                        Get:5 https://repos.influxdata.com/debian bullseye InRelease [7049 B]
                        Hit:6 https://apt.grafana.com stable InRelease
                        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Installing the recommended nodejs version now!
                        Exact recommended version unknown, installing a fallback!
                        (Reading database ... 55472 files and directories currently installed.)
                        Removing nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
                        dpkg: libnode72:arm64: dependency problems, but removing anyway as you requested:
                        nodejs depends on libnode72 (= 12.22.12~dfsg-1~deb11u4).
                        Removing libnode72:arm64 (12.22.12~dfsg-1~deb11u4) ...
                        (Reading database ... 55284 files and directories currently installed.)
                        Preparing to unpack .../nodejs_18.0.0-1nodesource1_arm64.deb ...
                        Unpacking nodejs (18.0.0-1nodesource1) over (12.22.12~dfsg-1~deb11u4) ...
                        Setting up nodejs (18.0.0-1nodesource1) ...
                        Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...
                        Processing triggers for man-db (2.9.4-2) ...
                        Updating fallback to latest nodejs v18 release
                        Preconfiguring packages ...
                        (Reading database ... 60946 files and directories currently installed.)
                        Preparing to unpack .../tar_1.34+dfsg-1+deb11u1_arm64.deb ...
                        Unpacking tar (1.34+dfsg-1+deb11u1) over (1.34+dfsg-1) ...
                        Setting up tar (1.34+dfsg-1+deb11u1) ...
                        Preparing to unpack .../tzdata_2024a-0+deb11u1_all.deb ...
                        Unpacking tzdata (2024a-0+deb11u1) over (2021a-1+deb11u11) ...
                        Preparing to unpack .../distro-info-data_0.51+deb11u5_all.deb ...
                        Unpacking distro-info-data (0.51+deb11u5) over (0.51+deb11u4) ...
                        Preparing to unpack .../nodejs_18.19.1-1nodesource1_arm64.deb ...
                        Detected old npm client, removing...
                        Unpacking nodejs (18.19.1-1nodesource1) over (18.0.0-1nodesource1) ...
                        Setting up distro-info-data (0.51+deb11u5) ...
                        Setting up nodejs (18.19.1-1nodesource1) ...
                        Setting up tzdata (2024a-0+deb11u1) ...
                        Current default time zone: 'Europe/London'
                        Local time is now: Sun Feb 25 20:02:26 GMT 2024.
                        Universal Time is now: Sun Feb 25 20:02:26 UTC 2024.
                        Run 'dpkg-reconfigure tzdata' if you wish to change it.
                        Processing triggers for mailcap (3.69) ...
                        v18.19.1 has been installed! You are using the latest version now!
                        Installing the recommended nodejs version!
                        We tried our best to update or fix your nodejs. Please run iob diag again to verify.
                        *** RESTARTING ioBroker NOW! ***
                        Please refresh or restart your browser in a few moments.
                        simon@iobroker:~ $
                          Thomas Braun Most Active @Greenhorn last edited by
                          @greenhorn sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                          Stell das richtig ein. Geht in
                          sudo raspi-config
                          Dann
                          sudo rm /etc/apt/sources.list.d/influ*
                          wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                          echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                          echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                          rm influxdata-archive_compat.key
                          sudo apt update
                          sudo apt full-upgrade
                          sudo reboot
                          Dann
                          iob update
                          iob upgrade all -y
                          iob stop
                          iob upgrade self
                          iob restart
                            OK, grad mal noch neues iob.diag
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                             20:05:04 up 50 min,  1 user,  load average: 1.40, 1.04, 0.64
                            CPU threads: 4
                            Current issues:
                                           Local time: Sun 2024-02-25 20:05:04 GMT
                                       Universal time: Sun 2024-02-25 20:05:04 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            simon
                            /home/simon
                            X-Server: 	false
                            Desktop:
                            Terminal: 	tty
                            *** MEMORY ***
                            Mem:            3.8G        1.7G        740M        1.0M        1.4G        2.1G
                            Swap:            99M          0B         99M
                            Total:          3.9G        1.7G        840M
                                     3794 M total memory
                                     1680 M used memory
                                     1813 M active memory
                                      990 M inactive memory
                                      740 M free memory
                                      124 M buffer memory
                                     1247 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /dev/root      ext4       29G  4.9G   23G  18% /
                            /var:
                            1.5G	/var/
                            859M	/var/log
                            356M	/var/cache
                            505M	/opt/iobroker/iobroker-data/
                            325M	/opt/iobroker/iobroker-data/objects.jsonl
                            5.1M	/opt/iobroker/iobroker-data/states.jsonl
                            USB-Devices by-id:
                            /usr/bin/nodejs 	v18.19.1
                            /usr/bin/node 		v18.19.1
                            /usr/bin/npm 		10.2.4
                            /usr/bin/npx 		10.2.4
                            /usr/bin/corepack 	0.22.0
                            nodejs:
                              Installed: 18.19.1-1nodesource1
                              Version table:
                             *** 18.19.1-1nodesource1 1001
                                 18.19.0-1nodesource1 1001
                                 18.18.2-1nodesource1 1001
                                 18.18.1-1nodesource1 1001
                                 18.18.0-1nodesource1 1001
                                 18.17.1-1nodesource1 1001
                                 18.17.0-1nodesource1 1001
                                 18.16.1-1nodesource1 1001
                                 18.16.0-1nodesource1 1001
                                 18.15.0-1nodesource1 1001
                                 18.14.2-1nodesource1 1001
                                 18.14.1-1nodesource1 1001
                                 18.14.0-1nodesource1 1001
                                 18.13.0-1nodesource1 1001
                                 18.12.0-1nodesource1 1001
                                 18.11.0-1nodesource1 1001
                                 18.10.0-1nodesource1 1001
                                 18.9.1-1nodesource1 1001
                                 18.9.0-1nodesource1 1001
                                 18.8.0-1nodesource1 1001
                                 18.7.0-1nodesource1 1001
                                 18.6.0-1nodesource1 1001
                                 18.5.0-1nodesource1 1001
                                 18.4.0-1nodesource1 1001
                                 18.3.0-1nodesource1 1001
                                 18.2.0-1nodesource1 1001
                                 18.1.0-1nodesource1 1001
                                 18.0.0-1nodesource1 1001
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin: 		6.8.0
                            javascript: 	7.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            • wendy2702
                              @greenhorn du musst dich in Geduld üben und auch lesen was da steht. Die Ausgabe war noch nicht fertig
                                • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.178.96
                                • system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0
                                Die liegen nauf dem gleichen Port.
                                  Greenhorn @Thomas Braun last edited by
                                  @thomas-braun said in Raspberry "friert ein" nach Aufruf von ioBroker:
                                  iob upgrade all -y
                                  Läuft noch...melde mich wenn fertig.
                                    iob restart
                                    Alles einwandfrei durchgelaufen bis auf:
                                    simon@iobroker:~ $ iob upgrade self
                                    No connection to databases possible ...
                                      @greenhorn
                                      iob restart
                                      iob diag
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : arm64
                                         21:25:58 up 11 min,  1 user,  load average: 1.35, 1.50, 1.02
                                        CPU threads: 4
                                        Current issues:
                                                       Local time: Sun 2024-02-25 21:25:58 CET
                                                   Universal time: Sun 2024-02-25 20:25:58 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        simon
                                        /home/simon
                                        X-Server: 	false
                                        Desktop:
                                        Terminal: 	tty
                                        *** MEMORY ***
                                        Mem:            3.8G        1.6G        905M        1.0M        1.2G        2.1G
                                        Swap:            99M          0B         99M
                                        Total:          3.9G        1.6G        1.0G
                                                 3794 M total memory
                                                 1639 M used memory
                                                  913 M inactive memory
                                                  905 M free memory
                                                   42 M buffer memory
                                                 1206 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       29G  5.3G   23G  19% /
                                        [Sun Feb 25 21:14:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Sun Feb 25 21:14:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Sun Feb 25 21:14:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                        [Sun Feb 25 21:14:17 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                        /var:
                                        1.5G	/var/
                                        859M	/var/log
                                        356M	/var/cache
                                        657M	/opt/iobroker/iobroker-data/
                                        163M	/opt/iobroker/iobroker-data/files
                                        57M	/opt/iobroker/iobroker-data/files/javascript.admin
                                        38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                                        447M	/opt/iobroker/iobroker-data/objects.jsonl
                                        22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                                        8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                                        7.0M	/opt/iobroker/iobroker-data/states.jsonl
                                        7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                                        USB-Devices by-id:
                                        /usr/bin/npm 		10.2.4
                                        /usr/bin/npx 		10.2.4
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin: 		6.13.16
                                        javascript: 	7.8.0
                                        Adapter State
                                        + instance is alive
                                        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                                        Adapter    "hmip"         : 1.21.0   , installed 1.21.0
                                        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                                        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                        Adapter    "web"          : 6.2.3    , installed 6.2.3
                                        Adapter    "ws"           : 2.5.10   , installed 2.5.10
                                        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                                        bjects and States
                                        Objects: 	3913
                                        States: 	3266
                                        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Hit:6 https://repos.influxdata.com/debian stable InRelease
                                        Pending Updates: 0
                                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        15913      680/influxd
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14621      549/sshd: /usr/sbin
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16545      1473/iobroker.js-co
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14257      1473/iobroker.js-co
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14320      1491/io.sonoff.0
                                        tcp6       0      0 :::3000                 :::*                    LISTEN      111        13763      776/grafana
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          14632      549/sshd: /usr/sbin
                                        tcp6       0      0 :::8086                 :::*                    LISTEN      110        14730      680/influxd
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19518      1547/io.web.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11579      414/avahi-daemon: r
                                        udp        0      0 0.0.0.0:42734           0.0.0.0:*                           108        11581      414/avahi-daemon: r
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13649      671/dhcpcd
                                        udp6       0      0 :::5353                 :::*                                108        11580      414/avahi-daemon: r
                                        udp6       0      0 :::54756                :::*                                108        11582      414/avahi-daemon: r
                                        2024-02-25 21:24:07.730  - info: iqontrol.0 (1592) Deleting unused Objects...
                                        2024-02-25 21:24:07.732  - info: iqontrol.0 (1592) Subscribing to states...
                                        2024-02-25 21:24:07.733  - info: iqontrol.0 (1592) iQontrol ready.
                                        2024-02-25 21:24:09.208  - info: mqtt.0 (1521) All states published
                                        2024-02-25 21:24:13.736  - info: hmip.0 (1506) ws connection opened
                                        2024-02-25 21:24:13.909  - info: hmip.0 (1506) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rss
                                        2024-02-25 21:24:24.169  - info: hmip.0 (1506) hmip adapter connected and ready
                                        2024-02-25 21:25:48.312  - warn: sonoff.0 (1491) Client [Steckdose Schreibtischlampe] has invalid password or username
                                        2024-02-25 21:25:48.480  - warn: sonoff.0 (1491) Client [Steckdose Gartenpumpe] has invalid password or username
                                        iob diag has finished.
                                        			v.2023-10-10
                                                 Icon name: computer
                                              Architecture: arm64
                                        Kernel: 		aarch64
                                        Userland: 		arm64
                                        Timezone: 		Europe/Berlin (CET, +0100)
                                        User-ID: 		1000
                                        X-Server: 		false
                                        Pending OS-Updates: 	0
                                        Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
                                        			/usr/bin/npm 		10.2.4
                                        			/usr/bin/npx 		10.2.4
                                        MEMORY:
                                        Mem:            3.8G        1.8G        657M        1.0M        1.4G        2.0G
                                        Swap:            99M          0B         99M
                                        Total:          3.9G        1.8G        757M
                                        			admin 			6.13.16
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects: 		3913
                                        States: 		3266
                                        7.2M	/opt/iobroker/iobroker-data/states.jsonl
                                        simon@iobroker:~ $
                                          @greenhorn
                                          iob stop
                                          iob upgrade self
                                          iob start
                                            iob start
                                            simon@iobroker:~ $ iob start
                                            simon@iobroker:~ $
                                            5293
