    4. [Gelöst] Keine Netzwerkverbindung zum iobroker mehr möglich
      Thomas Braun Most Active @Airframe75 last edited by
      @airframe75
      systemctl status iobroker
      sagt?
      • wendy2702
        wendy2702 last edited by
        Was passiert wenn du den fixer per Curl aus @Homoran Signatur aufrufst?
        Was sagt
        iob status
          Airframe75 @Homoran last edited by
          @homoran said in Keine Netzwerkverbindung zum iobroker mehr möglich:
          und bei iob -v auch nichts?
          und dann bei nur iob?
          Bei beiden passiert nichts
            Airframe75 @wendy2702 last edited by
            @wendy2702 @hormoran
            Hier der etrakt aus dem curl Befehl
            Skript v.2023-10-10
            *** BASE SYSTEM ***
               Static hostname: iobroker
                     Icon name: computer
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.5
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : arm64
            Systemuptime and Load:
             21:11:36 up  1:35,  1 user,  load average: 0.00, 0.00, 0.00
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Sun 2024-02-25 21:11:36 CET
                       Universal time: Sun 2024-02-25 20:11:36 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            iobroker
            /home/iobroker
            iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            3.8G         85M        3.5G        1.0M        188M        3.6G
            Swap:            99M          0B         99M
            Total:          3.9G         85M        3.6G
                     3794 M total memory
                       85 M used memory
                      160 M active memory
                       32 M inactive memory
                     3520 M free memory
                       15 M buffer memory
                      172 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FAILED SERVICES ***
              UNIT             LOAD   ACTIVE SUB    DESCRIPTION
            * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            1 loaded units listed.
            *** FILESYSTEM ***
            /dev/root      ext4       29G  6.4G   22G  23% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     759M  1.2M  758M   1% /run
            /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
            tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
            [sudo] password for iobroker:
            [Sun Feb 25 19:36:26 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FB:C3:CA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8f761cd6-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Sun Feb 25 19:36:27 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sun Feb 25 19:36:27 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Sun Feb 25 19:36:29 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            2.9G    /var/
            2.4G    /var/log
            801M    /var/log/journal/54548f5b193440069d487fa9f59dd13a
            288M    /var/cache
            Archived and active journals take up 800.4M in the file system.
            /opt/iobroker/backups:
            239M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            353M    /opt/iobroker/iobroker-data/
            237M    /opt/iobroker/iobroker-data/files
            75M     /opt/iobroker/iobroker-data/backup-objects
            52M     /opt/iobroker/iobroker-data/files/javascript.admin
            43M     /opt/iobroker/iobroker-data/files/iot.admin
            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
            24M     /opt/iobroker/iobroker-data/states.jsonl
            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
            18M     /opt/iobroker/iobroker-data/objects.jsonl
            18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
            *** NodeJS-Installation ***
            diag.sh: line 277: nodejs: command not found
            /usr/bin/node           v18.17.1
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            /usr/bin/corepack       0.18.0
            diag.sh: line 288: nodejs: command not found
            *** nodejs is NOT correctly installed ***
            nodejs:
              Installed: 18.17.1-deb-1nodesource1
              Candidate: 18.17.1-deb-1nodesource1
              Version table:
             *** 18.17.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Core adapters versions
            js-controller:
            admin:
            javascript:
            Adapters from github:   1
            Adapter State
            ioBroker-Repositories
            Installed ioBroker-Instances
            Objects and States
            Objects:        0
            States:         0
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian bullseye InRelease
            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
            Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:6 https://repos.influxdata.com/debian bullseye InRelease
            Reading package lists... Done
            Pending Updates: 39
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12181      536/sshd: /usr/sbin
            tcp6       0      0 :::22                   :::*                    LISTEN      0          12192      536/sshd: /usr/sbin
            udp        0      0 0.0.0.0:60921           0.0.0.0:*                           108        14732      391/avahi-daemon: r
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14809      789/dhcpcd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14730      391/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          1692       789/dhcpcd
            udp6       0      0 :::46147                :::*                                108        14733      391/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        14731      391/avahi-daemon: r
            A Homoran 2 Replies Last reply Reply Quote 0
              Airframe75 @Airframe75 last edited by
              @hormoran
              Copy text starting here:
                                      v.2023-10-10
                       Icon name: computer
                    Architecture: arm64
              Installation:           native
              Kernel:                 aarch64
              Userland:               arm64
              Timezone:               Europe/Berlin (CET, +0100)
              User-ID:                1000
              X-Server:               false
              Pending OS-Updates:     39
              Pending iob updates:    0
              diag.sh: line 486: nodejs: command not found
              Nodejs-Installation:
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
              Recommended versions are nodejs  and npm
              Wrong installation path detected. This needs to be fixed.
              Please check
              https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
              for more information on how to fix these errors.
              MEMORY:
              Mem:            3.8G         82M        3.2G        1.0M        467M        3.6G
              Swap:            99M          0B         99M
              Total:          3.9G         82M        3.3G
              Active iob-Instances:   0
              ioBroker Core:          js-controller
                                      admin
              ioBroker Status:
              Objects:                0
              States:                 0
              Size of iob-Database:
              === Mark text until here for copying ===
                Airframe75 @Thomas Braun last edited by
                iobroker@iobroker:~ $ systemctl status iobroker
                ● iobroker.service
                     Loaded: masked (Reason: Unit iobroker.service is masked.)
                     Active: inactive (dead)
                • wendy2702
                  wendy2702 @Airframe75 last edited by
                  @airframe75 im Summary steht drin was zu tun ist.
                    Thomas Braun Most Active @Airframe75 last edited by Thomas Braun
                    @airframe75
                    sudo systemctl unmask iobroker.service
                    iob nodejs-update
                    sudo reboot
                      Die erste Zeile ging, bei update ging es nicht mehr
                      ● iobroker.service
                      iobroker@iobroker:~ $ systemctl unmask iobroker.service
                      ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
                      Authentication is required to manage system service or unit files.
                      Authenticating as: ,,, (iobroker)
                      Password:
                      ==== AUTHENTICATION COMPLETE ===
                      ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
                      Authentication is required to reload the systemd state.
                      Password:
                        Homoran Global Moderator Administrators @Airframe75 last edited by
                        @airframe75 sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
                        läuft da nix?
                        ioBroker Status
                        ist iobroker überhaupt installiert?
                        wie hast du das gemacht?
                        was hat daran 2 Wochen gedauert?
                        A 2 Replies Last reply Reply Quote 0
                          Bis vor zwei Monaten lief alles super.
                            @airframe75
                            iob nodejs-update
                            sudo reboot
                              Ja natürlich habe ich den dort installiert 🙂
                                wie hast du iobroker installiert?
                                was hastcdu vor Wochen geändert?
                                • wendy2702
                                  Zeigen!
                                    Ich habe gar nichts gemacht.
                                      @airframe75 bleibt die Frage
                                      @homoran sagte in Keine Netzwerkverbindung zum iobroker mehr möglich:
                                        @wendy2702
                                        ● iobroker.service
                                        Password:
                                        Password:
                                        iobroker@iobroker:~ $ iob nodejs-update
                                        iobroker@iobroker:~ $ sudo reboot```
                                        code_text
                                          freedesktop
                                          was ist denn das?
                                            Ich habe den ioBroker masterkurs von Matthias Kleine besucht, mir die Videos angeschaut und das nachgemacht.
                                            6865
