    4. Raspberry "friert ein" nach Aufruf von ioBroker
      Greenhorn last edited by
      Your nodejs-Installation seems to be faulty. Shall we try to fix it?
      Press <y> to continue or any other key to quit
      Fixing your nodejs setup
      *** Deleting ***
      rm: cannot remove '': No such file or directory
      *** Deleting ***
      Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
      You are running nodejs v12.22.12. Do you want to install latest version from nodejs v.18 tree?
      Trying to update your installation now. Please be patient.
      Waiting for ioBroker to shut down - Give me a minute...
      *** These repos are active on your system:
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Get:6 https://repos.influxdata.com/debian bullseye InRelease [7049 B]
      Err:6 https://repos.influxdata.com/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      Reading package lists... Done
      W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
      Get:5 https://repos.influxdata.com/debian bullseye InRelease [7049 B]
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Err:5 https://repos.influxdata.com/debian bullseye InRelease
      Installing the recommended nodejs version now!
      Exact recommended version unknown, installing a fallback!
      (Reading database ... 55472 files and directories currently installed.)
      Removing nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
      dpkg: libnode72:arm64: dependency problems, but removing anyway as you requested:
      nodejs depends on libnode72 (= 12.22.12~dfsg-1~deb11u4).
      Removing libnode72:arm64 (12.22.12~dfsg-1~deb11u4) ...
      (Reading database ... 55284 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.0.0-1nodesource1_arm64.deb ...
      Unpacking nodejs (18.0.0-1nodesource1) over (12.22.12~dfsg-1~deb11u4) ...
      Setting up nodejs (18.0.0-1nodesource1) ...
      Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...
      Processing triggers for man-db (2.9.4-2) ...
      Updating fallback to latest nodejs v18 release
      Preconfiguring packages ...
      (Reading database ... 60946 files and directories currently installed.)
      Preparing to unpack .../tar_1.34+dfsg-1+deb11u1_arm64.deb ...
      Unpacking tar (1.34+dfsg-1+deb11u1) over (1.34+dfsg-1) ...
      Setting up tar (1.34+dfsg-1+deb11u1) ...
      Preparing to unpack .../tzdata_2024a-0+deb11u1_all.deb ...
      Unpacking tzdata (2024a-0+deb11u1) over (2021a-1+deb11u11) ...
      Preparing to unpack .../distro-info-data_0.51+deb11u5_all.deb ...
      Unpacking distro-info-data (0.51+deb11u5) over (0.51+deb11u4) ...
      Preparing to unpack .../nodejs_18.19.1-1nodesource1_arm64.deb ...
      Detected old npm client, removing...
      Unpacking nodejs (18.19.1-1nodesource1) over (18.0.0-1nodesource1) ...
      Setting up distro-info-data (0.51+deb11u5) ...
      Setting up nodejs (18.19.1-1nodesource1) ...
      Setting up tzdata (2024a-0+deb11u1) ...
      Current default time zone: 'Europe/London'
      Local time is now: Sun Feb 25 20:02:26 GMT 2024.
      Universal Time is now: Sun Feb 25 20:02:26 UTC 2024.
      Run 'dpkg-reconfigure tzdata' if you wish to change it.
      Processing triggers for mailcap (3.69) ...
      v18.19.1 has been installed! You are using the latest version now!
      Installing the recommended nodejs version!
      We tried our best to update or fix your nodejs. Please run iob diag again to verify.
      *** RESTARTING ioBroker NOW! ***
      Please refresh or restart your browser in a few moments.
      simon@iobroker:~ $
        Thomas Braun Most Active @Greenhorn last edited by
        @greenhorn sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                    Time zone: Europe/London (GMT, +0000)
        Stell das richtig ein. Geht in
        sudo raspi-config
        Dann
        sudo rm /etc/apt/sources.list.d/influ*
        wget -q https://repos.influxdata.com/influxdata-archive_compat.key
        echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
        echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
        rm influxdata-archive_compat.key
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        Dann
        iob update
        iob upgrade all -y
        iob stop
        iob upgrade self
        iob restart
        G 2 Replies Last reply Reply Quote 0
          OK, grad mal noch neues iob.diag
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model		: Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           20:05:04 up 50 min,  1 user,  load average: 1.40, 1.04, 0.64
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sun 2024-02-25 20:05:04 GMT
                     Universal time: Sun 2024-02-25 20:05:04 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          simon
          /home/simon
          simon adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          Boot Target: 	multi-user.target
          *** MEMORY ***
          Mem:            3.8G        1.7G        740M        1.0M        1.4G        2.1G
          Swap:            99M          0B         99M
          Total:          3.9G        1.7G        840M
                   3794 M total memory
                   1680 M used memory
                   1813 M active memory
                    990 M inactive memory
                    740 M free memory
                    124 M buffer memory
                   1247 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       29G  4.9G   23G  18% /
          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     759M  1.2M  758M   1% /run
          /dev/mmcblk0p1 vfat      255M   32M  223M  13% /boot
          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
          [Sun Feb 25 19:14:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Sun Feb 25 19:14:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sun Feb 25 19:14:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Sun Feb 25 19:14:37 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.5G	/var/
          859M	/var/log
          841M	/var/log/journal/2afb5f7f70fe4270a1433886fb089ee5
          356M	/var/cache
          Archived and active journals take up 840.1M in the file system.
          /opt/iobroker/backups:
          55M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          505M	/opt/iobroker/iobroker-data/
          135M	/opt/iobroker/iobroker-data/files
          52M	/opt/iobroker/iobroker-data/files/javascript.admin
          40M	/opt/iobroker/iobroker-data/backup-objects
          34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
          325M	/opt/iobroker/iobroker-data/objects.jsonl
          7.1M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
          6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          5.8M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
          5.1M	/opt/iobroker/iobroker-data/states.jsonl
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v18.19.1
          /usr/bin/node 		v18.19.1
          /usr/bin/npm 		10.2.4
          /usr/bin/npx 		10.2.4
          /usr/bin/corepack 	0.22.0
          nodejs:
            Installed: 18.19.1-1nodesource1
            Candidate: 18.19.1-1nodesource1
            Version table:
           *** 18.19.1-1nodesource1 1001
                  100 /var/lib/dpkg/status
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	4.0.24
          admin: 		6.8.0
          javascript: 	7.1.4
          Adapters from github: 	0
          Adapter State
            system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
            system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
          + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
            system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
            system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
          + system.adapter.link.0                   : link                  : iobroker                                 -  enabled
          + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
            system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
            system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.13.16  , installed 6.8.0  [Updatable]
          Adapter    "backitup"     : 2.10.11  , installed 2.6.23 [Updatable]
          Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
          Adapter    "hmip"         : 1.21.0   , installed 1.20.0 [Updatable]
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.2  [Updatable]
          Adapter    "javascript"   : 7.8.0    , installed 7.1.4  [Updatable]
          Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
          Adapter    "link"         : 0.5.12   , installed 0.5.12
          Adapter    "midea"        : 0.0.7    , installed 0.0.7
          Adapter    "mqtt"         : 5.2.0    , installed 4.1.1  [Updatable]
          Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
          Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
          Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
          Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
          Adapter    "ws"           : 2.5.10   , installed 1.3.0  [Updatable]
          Adapter    "zigbee"       : 1.10.1   , installed 1.9.7  [Updatable]
          Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
          Objects and States
          wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
          • wendy2702
            wendy2702 @Greenhorn last edited by
            @greenhorn du musst dich in Geduld üben und auch lesen was da steht. Die Ausgabe war noch nicht fertig
              • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.178.96
              • system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0
              Die liegen nauf dem gleichen Port.
                Greenhorn @Thomas Braun last edited by
                @thomas-braun said in Raspberry "friert ein" nach Aufruf von ioBroker:
                iob upgrade all -y
                Läuft noch...melde mich wenn fertig.
                  iob restart
                  Alles einwandfrei durchgelaufen bis auf:
                  simon@iobroker:~ $ iob upgrade self
                  No connection to databases possible ...
                    @greenhorn
                    iob restart
                    iob diag
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                       21:25:58 up 11 min,  1 user,  load average: 1.35, 1.50, 1.02
                      CPU threads: 4
                      Current issues:
                                     Local time: Sun 2024-02-25 21:25:58 CET
                                 Universal time: Sun 2024-02-25 20:25:58 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      simon
                      /home/simon
                      X-Server: 	false
                      Desktop:
                      Terminal: 	tty
                      *** MEMORY ***
                      Mem:            3.8G        1.6G        905M        1.0M        1.2G        2.1G
                      Swap:            99M          0B         99M
                      Total:          3.9G        1.6G        1.0G
                               3794 M total memory
                               1639 M used memory
                                913 M inactive memory
                                905 M free memory
                                 42 M buffer memory
                               1206 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/root      ext4       29G  5.3G   23G  19% /
                      [Sun Feb 25 21:14:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Sun Feb 25 21:14:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Sun Feb 25 21:14:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Sun Feb 25 21:14:17 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                      /var:
                      1.5G	/var/
                      859M	/var/log
                      356M	/var/cache
                      657M	/opt/iobroker/iobroker-data/
                      163M	/opt/iobroker/iobroker-data/files
                      57M	/opt/iobroker/iobroker-data/files/javascript.admin
                      38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                      447M	/opt/iobroker/iobroker-data/objects.jsonl
                      22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                      8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                      7.0M	/opt/iobroker/iobroker-data/states.jsonl
                      7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                      USB-Devices by-id:
                      /usr/bin/npm 		10.2.4
                      /usr/bin/npx 		10.2.4
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin: 		6.13.16
                      javascript: 	7.8.0
                      Adapter State
                      + instance is alive
                      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                      Adapter    "hmip"         : 1.21.0   , installed 1.21.0
                      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                      Adapter    "web"          : 6.2.3    , installed 6.2.3
                      Adapter    "ws"           : 2.5.10   , installed 2.5.10
                      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                      bjects and States
                      Objects: 	3913
                      States: 	3266
                      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:2 http://deb.debian.org/debian bullseye InRelease
                      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:6 https://repos.influxdata.com/debian stable InRelease
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        15913      680/influxd
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14621      549/sshd: /usr/sbin
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16545      1473/iobroker.js-co
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14257      1473/iobroker.js-co
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14320      1491/io.sonoff.0
                      tcp6       0      0 :::3000                 :::*                    LISTEN      111        13763      776/grafana
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          14632      549/sshd: /usr/sbin
                      tcp6       0      0 :::8086                 :::*                    LISTEN      110        14730      680/influxd
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19518      1547/io.web.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11579      414/avahi-daemon: r
                      udp        0      0 0.0.0.0:42734           0.0.0.0:*                           108        11581      414/avahi-daemon: r
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13649      671/dhcpcd
                      udp6       0      0 :::5353                 :::*                                108        11580      414/avahi-daemon: r
                      udp6       0      0 :::54756                :::*                                108        11582      414/avahi-daemon: r
                      2024-02-25 21:24:07.730  - info: iqontrol.0 (1592) Deleting unused Objects...
                      2024-02-25 21:24:07.732  - info: iqontrol.0 (1592) Subscribing to states...
                      2024-02-25 21:24:07.733  - info: iqontrol.0 (1592) iQontrol ready.
                      2024-02-25 21:24:09.208  - info: mqtt.0 (1521) All states published
                      2024-02-25 21:24:13.736  - info: hmip.0 (1506) ws connection opened
                      2024-02-25 21:24:13.909  - info: hmip.0 (1506) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rss
                      l":"","deviceId":"3014F711A0002E9F29992FF7","index":16,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}}},"deviceArchetype":"HMIP","manuallyUpdateForced":true,"measuredAttributes":{},"updateState":"UP_TO_DATE","firmwareVersion":"1.0.12","modelType":"HmIP-WKP","permanentlyReachable":false,"connectionType":"HMIP_RF","firmwareVersionInteger":65548,"liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","modelId":441,"availableFirmwareVersion":"1.0.12","serializedGlobalTradeItemNumber":"3014F711A0002E9F29992FF7","manufacturerCode":1,"oem":"eQ-3"}
                      2024-02-25 21:24:24.169  - info: hmip.0 (1506) hmip adapter connected and ready
                      2024-02-25 21:25:48.312  - warn: sonoff.0 (1491) Client [Steckdose Schreibtischlampe] has invalid password or username
                      2024-02-25 21:25:48.480  - warn: sonoff.0 (1491) Client [Steckdose Gartenpumpe] has invalid password or username
                      iob diag has finished.
                      Copy text starting here:
                      			v.2023-10-10
                               Icon name: computer
                            Architecture: arm64
                      Installation: 		native
                      Kernel: 		aarch64
                      Userland: 		arm64
                      Timezone: 		Europe/Berlin (CET, +0100)
                      User-ID: 		1000
                      X-Server: 		false
                      Pending OS-Updates: 	0
                      Pending iob updates: 	1
                      Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
                      			/usr/bin/npm 		10.2.4
                      			/usr/bin/npx 		10.2.4
                      Recommended versions are nodejs  and npm
                      MEMORY:
                      Mem:            3.8G        1.8G        657M        1.0M        1.4G        2.0G
                      Swap:            99M          0B         99M
                      Total:          3.9G        1.8G        757M
                      Active iob-Instances: 	9
                      ioBroker Core: 		js-controller 		4.0.24
                      			admin 			6.13.16
                      ioBroker Status: 	iobroker is running on this host.
                      Objects type: jsonl
                      States  type: jsonl
                      Objects: 		3913
                      States: 		3266
                      Size of iob-Database:
                      7.2M	/opt/iobroker/iobroker-data/states.jsonl
                      === Mark text until here for copying ===
                      simon@iobroker:~ $
                        @greenhorn
                        iob stop
                        iob upgrade self
                        iob start
                          iob start
                          simon@iobroker:~ $ iob stop
                          simon@iobroker:~ $ iob start
                          simon@iobroker:~ $
                            @greenhorn
                            Kein Wunder. Die ist ja auch RIESIG:
                            Versuch mal ein
                            iob stop
                            iob fix
                            iob upgade self
                              Greenhorn @Thomas Braun last edited by wendy2702
                              Update js-controller from @4.0.24 to @5.0.19
                              Stopped Objects DB
                              Stopped States DB
                              NPM version: 10.2.4
                              Installing iobroker.js-controller@5.0.19... (System call)
                              added 2 packages, removed 12 packages, and changed 29 packages in 1m
                              136 packages are looking for funding
                                run `npm fund` for details
                              simon@iobroker:~ $
                                @greenhorn
                                Dann sollte es das nun gewesen sein.
                                  Kann den iobroker aber leider immer noch nicht wieder aufrufen 😞
                                    @greenhorn
                                    iob diag
                                    • wendy2702
                                      wendy2702 last edited by
                                      Wenn ich jetzt nicht die Themen durcheinander werfe lief der Admin eben nicht und wird es jetzt wohl auch noch nicht
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : arm64
                                         21:51:48 up 37 min,  1 user,  load average: 2.22, 0.79, 0.73
                                        CPU threads: 4
                                        Current issues:
                                                       Local time: Sun 2024-02-25 21:51:48 CET
                                                   Universal time: Sun 2024-02-25 20:51:48 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        simon
                                        /home/simon
                                        X-Server: 	false
                                        Desktop:
                                        Terminal: 	tty
                                        *** MEMORY ***
                                        Mem:            3.8G        2.1G        494M        1.0M        1.2G        1.6G
                                        Swap:            99M          0B         99M
                                        Total:          3.9G        2.1G        594M
                                                 3794 M total memory
                                                 2118 M used memory
                                                 2335 M active memory
                                                  732 M inactive memory
                                                  494 M free memory
                                                   84 M buffer memory
                                                 1097 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       29G  5.0G   23G  19% /
                                        /var:
                                        1.5G	/var/
                                        859M	/var/log
                                        356M	/var/cache
                                        318M	/opt/iobroker/iobroker-data/
                                        115M	/opt/iobroker/iobroker-data/objects.jsonl
                                        USB-Devices by-id:
                                        /usr/bin/npm 		10.2.4
                                        /usr/bin/npx 		10.2.4
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        js-controller: 	5.0.19
                                        admin: 		6.13.16
                                        javascript: 	7.8.0
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects: 	3913
                                        States: 	3266
                                        Pending Updates: 0
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27403      4362/iobroker.js-co
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27410      4362/iobroker.js-co
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       26316      4380/io.sonoff.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28508      4439/io.web.0
                                        2024-02-25 21:51:29.577  - info: iqontrol.0 (4485) Deleting unused Objects...
                                        2024-02-25 21:51:29.579  - info: iqontrol.0 (4485) Subscribing to states...
                                        2024-02-25 21:51:29.583  - info: iqontrol.0 (4485) iQontrol ready.
                                        2024-02-25 21:51:29.843  - info: mqtt.0 (4412) All states published
                                        2024-02-25 21:51:36.597  - info: hmip.0 (4396) ws connection opened
                                        2024-02-25 21:51:36.933  - info: hmip.0 (4396) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-73,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IFeatureDeviceDaliBusError":false,"IOptionalFeatureDutyCycle":t
                                        v.2023-10-10
                                        Icon name: computer
                                        Architecture: arm64
                                        Kernel: aarch64
                                        Userland: arm64
                                        User-ID: 1000
                                        X-Server: false
                                        Pending iob updates: 0
                                        /usr/bin/npm 10.2.4
                                        /usr/bin/npx 10.2.4
                                        MEMORY:
                                        total used free shared buff/cache available
                                        Mem: 3.8G 1.7G 894M 1.0M 1.2G 2.1G
                                        Swap: 99M 0B 99M
                                        Total: 3.9G 1.7G 994M
                                        ioBroker Core: js-controller 5.0.19
                                        admin 6.13.16
                                        Objects type: jsonl
                                        States type: jsonl
                                        • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        Objects: 3913
                                        States: 3266
                                        116M /opt/iobroker/iobroker-data/objects.jsonl
                                        1.3M /opt/iobroker/iobroker-data/states.jsonl
                                        simon@iobroker:~ $
                                          Homoran Global Moderator Administrators @wendy2702 last edited by
                                          @wendy2702 sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                                          so ist es!
                                          @Greenhorn
                                          iob start admin
                                            Greenhorn @Homoran last edited by
                                            Ja, stimmt.
                                            kann den ioBroker aber immer noch nicht öffnen...
                                            wendy2702 Homoran 2 Replies Last reply Reply Quote 0
                                            5295
