    4. Raspberry "friert ein" nach Aufruf von ioBroker
      Greenhorn last edited by
      OK, grad mal noch neues iob.diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model		: Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       20:05:04 up 50 min,  1 user,  load average: 1.40, 1.04, 0.64
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sun 2024-02-25 20:05:04 GMT
                 Universal time: Sun 2024-02-25 20:05:04 UTC
                       RTC time: n/a
                      Time zone: Europe/London (GMT, +0000)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      simon
      /home/simon
      simon adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	multi-user.target
      *** MEMORY ***
      Mem:            3.8G        1.7G        740M        1.0M        1.4G        2.1G
      Swap:            99M          0B         99M
      Total:          3.9G        1.7G        840M
               3794 M total memory
               1680 M used memory
               1813 M active memory
                990 M inactive memory
                740 M free memory
                124 M buffer memory
               1247 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G  4.9G   23G  18% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  1.2M  758M   1% /run
      /dev/mmcblk0p1 vfat      255M   32M  223M  13% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Sun Feb 25 19:14:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun Feb 25 19:14:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Feb 25 19:14:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun Feb 25 19:14:37 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.5G	/var/
      859M	/var/log
      841M	/var/log/journal/2afb5f7f70fe4270a1433886fb089ee5
      356M	/var/cache
      Archived and active journals take up 840.1M in the file system.
      /opt/iobroker/backups:
      55M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      505M	/opt/iobroker/iobroker-data/
      135M	/opt/iobroker/iobroker-data/files
      52M	/opt/iobroker/iobroker-data/files/javascript.admin
      40M	/opt/iobroker/iobroker-data/backup-objects
      34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      325M	/opt/iobroker/iobroker-data/objects.jsonl
      7.1M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
      6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      5.8M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
      5.1M	/opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.19.1
      /usr/bin/node 		v18.19.1
      /usr/bin/npm 		10.2.4
      /usr/bin/npx 		10.2.4
      /usr/bin/corepack 	0.22.0
      nodejs:
        Installed: 18.19.1-1nodesource1
        Candidate: 18.19.1-1nodesource1
        Version table:
       *** 18.19.1-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	4.0.24
      admin: 		6.8.0
      javascript: 	7.1.4
      Adapters from github: 	0
      Adapter State
        system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
        system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
      + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
        system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
        system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
      + system.adapter.link.0                   : link                  : iobroker                                 -  enabled
      + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
        system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
        system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 6.8.0  [Updatable]
      Adapter    "backitup"     : 2.10.11  , installed 2.6.23 [Updatable]
      Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
      Adapter    "hmip"         : 1.21.0   , installed 1.20.0 [Updatable]
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.2  [Updatable]
      Adapter    "javascript"   : 7.8.0    , installed 7.1.4  [Updatable]
      Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
      Adapter    "link"         : 0.5.12   , installed 0.5.12
      Adapter    "midea"        : 0.0.7    , installed 0.0.7
      Adapter    "mqtt"         : 5.2.0    , installed 4.1.1  [Updatable]
      Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
      Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
      Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
      Adapter    "ws"           : 2.5.10   , installed 1.3.0  [Updatable]
      Adapter    "zigbee"       : 1.10.1   , installed 1.9.7  [Updatable]
      Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
      Objects and States
      wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
      • wendy2702
        wendy2702 @Greenhorn last edited by
        @greenhorn du musst dich in Geduld üben und auch lesen was da steht. Die Ausgabe war noch nicht fertig
          Thomas Braun Most Active @Greenhorn last edited by
          @greenhorn sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
          • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.178.96
          • system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0
          Die liegen nauf dem gleichen Port.
            Greenhorn @Thomas Braun last edited by
            @thomas-braun said in Raspberry "friert ein" nach Aufruf von ioBroker:
            iob upgrade all -y
            Läuft noch...melde mich wenn fertig.
              iob restart
              Alles einwandfrei durchgelaufen bis auf:
              simon@iobroker:~ $ iob upgrade self
              No connection to databases possible ...
                @greenhorn
                iob restart
                iob diag
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                   21:25:58 up 11 min,  1 user,  load average: 1.35, 1.50, 1.02
                  CPU threads: 4
                  Current issues:
                                 Local time: Sun 2024-02-25 21:25:58 CET
                             Universal time: Sun 2024-02-25 20:25:58 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  simon
                  /home/simon
                  X-Server: 	false
                  Desktop:
                  Terminal: 	tty
                  *** MEMORY ***
                  Mem:            3.8G        1.6G        905M        1.0M        1.2G        2.1G
                  Swap:            99M          0B         99M
                  Total:          3.9G        1.6G        1.0G
                           3794 M total memory
                           1639 M used memory
                            913 M inactive memory
                            905 M free memory
                             42 M buffer memory
                           1206 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /dev/root      ext4       29G  5.3G   23G  19% /
                  [Sun Feb 25 21:14:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fe379c38-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Sun Feb 25 21:14:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Sun Feb 25 21:14:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Sun Feb 25 21:14:17 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  /var:
                  1.5G	/var/
                  859M	/var/log
                  356M	/var/cache
                  657M	/opt/iobroker/iobroker-data/
                  163M	/opt/iobroker/iobroker-data/files
                  57M	/opt/iobroker/iobroker-data/files/javascript.admin
                  38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                  447M	/opt/iobroker/iobroker-data/objects.jsonl
                  22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                  8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                  7.0M	/opt/iobroker/iobroker-data/states.jsonl
                  7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                  USB-Devices by-id:
                  /usr/bin/npm 		10.2.4
                  /usr/bin/npx 		10.2.4
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin: 		6.13.16
                  javascript: 	7.8.0
                  Adapter State
                  + instance is alive
                  Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                  Adapter    "hmip"         : 1.21.0   , installed 1.21.0
                  Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                  Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                  Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                  Adapter    "web"          : 6.2.3    , installed 6.2.3
                  Adapter    "ws"           : 2.5.10   , installed 2.5.10
                  Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                  bjects and States
                  Objects: 	3913
                  States: 	3266
                  Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                  Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:5 https://apt.grafana.com stable InRelease
                  Hit:6 https://repos.influxdata.com/debian stable InRelease
                  Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        15913      680/influxd
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14621      549/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16545      1473/iobroker.js-co
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14257      1473/iobroker.js-co
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14320      1491/io.sonoff.0
                  tcp6       0      0 :::3000                 :::*                    LISTEN      111        13763      776/grafana
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14632      549/sshd: /usr/sbin
                  tcp6       0      0 :::8086                 :::*                    LISTEN      110        14730      680/influxd
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19518      1547/io.web.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11579      414/avahi-daemon: r
                  udp        0      0 0.0.0.0:42734           0.0.0.0:*                           108        11581      414/avahi-daemon: r
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13649      671/dhcpcd
                  udp6       0      0 :::5353                 :::*                                108        11580      414/avahi-daemon: r
                  udp6       0      0 :::54756                :::*                                108        11582      414/avahi-daemon: r
                  2024-02-25 21:24:07.730  - info: iqontrol.0 (1592) Deleting unused Objects...
                  2024-02-25 21:24:07.732  - info: iqontrol.0 (1592) Subscribing to states...
                  2024-02-25 21:24:07.733  - info: iqontrol.0 (1592) iQontrol ready.
                  2024-02-25 21:24:09.208  - info: mqtt.0 (1521) All states published
                  2024-02-25 21:24:13.736  - info: hmip.0 (1506) ws connection opened
                  2024-02-25 21:24:13.909  - info: hmip.0 (1506) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rss
                  l":"","deviceId":"3014F711A0002E9F29992FF7","index":16,"groupIndex":8,"functionalChannelType":"CODE_PROTECTED_SECONDARY_ACTION_CHANNEL","groups":[],"supportedOptionalFeatures":{"IFeatureGarageGroupSensorChannel":false,"IFeatureLightGroupSensorChannel":false,"IFeatureAccessAuthorizationSensorChannel":false,"IFeatureShadingGroupSensorChannel":false}}},"deviceArchetype":"HMIP","manuallyUpdateForced":true,"measuredAttributes":{},"updateState":"UP_TO_DATE","firmwareVersion":"1.0.12","modelType":"HmIP-WKP","permanentlyReachable":false,"connectionType":"HMIP_RF","firmwareVersionInteger":65548,"liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","modelId":441,"availableFirmwareVersion":"1.0.12","serializedGlobalTradeItemNumber":"3014F711A0002E9F29992FF7","manufacturerCode":1,"oem":"eQ-3"}
                  2024-02-25 21:24:24.169  - info: hmip.0 (1506) hmip adapter connected and ready
                  2024-02-25 21:25:48.312  - warn: sonoff.0 (1491) Client [Steckdose Schreibtischlampe] has invalid password or username
                  2024-02-25 21:25:48.480  - warn: sonoff.0 (1491) Client [Steckdose Gartenpumpe] has invalid password or username
                  iob diag has finished.
                  Copy text starting here:
                  			v.2023-10-10
                           Icon name: computer
                        Architecture: arm64
                  Installation: 		native
                  Kernel: 		aarch64
                  Userland: 		arm64
                  Timezone: 		Europe/Berlin (CET, +0100)
                  User-ID: 		1000
                  X-Server: 		false
                  Pending OS-Updates: 	0
                  Pending iob updates: 	1
                  Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
                  			/usr/bin/npm 		10.2.4
                  			/usr/bin/npx 		10.2.4
                  Recommended versions are nodejs  and npm
                  MEMORY:
                  Mem:            3.8G        1.8G        657M        1.0M        1.4G        2.0G
                  Swap:            99M          0B         99M
                  Total:          3.9G        1.8G        757M
                  Active iob-Instances: 	9
                  ioBroker Core: 		js-controller 		4.0.24
                  			admin 			6.13.16
                  ioBroker Status: 	iobroker is running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		3913
                  States: 		3266
                  Size of iob-Database:
                  7.2M	/opt/iobroker/iobroker-data/states.jsonl
                  === Mark text until here for copying ===
                  simon@iobroker:~ $
                    @greenhorn
                    iob stop
                    iob upgrade self
                    iob start
                      iob start
                      simon@iobroker:~ $ iob stop
                      simon@iobroker:~ $ iob start
                      simon@iobroker:~ $
                        @greenhorn
                        Kein Wunder. Die ist ja auch RIESIG:
                        Versuch mal ein
                        iob stop
                        iob fix
                        iob upgade self
                          Greenhorn @Thomas Braun last edited by wendy2702
                          Update js-controller from @4.0.24 to @5.0.19
                          Stopped Objects DB
                          Stopped States DB
                          NPM version: 10.2.4
                          Installing iobroker.js-controller@5.0.19... (System call)
                          added 2 packages, removed 12 packages, and changed 29 packages in 1m
                          136 packages are looking for funding
                            run `npm fund` for details
                          simon@iobroker:~ $
                            @greenhorn
                            Dann sollte es das nun gewesen sein.
                              Kann den iobroker aber leider immer noch nicht wieder aufrufen 😞
                                @greenhorn
                                iob diag
                                • wendy2702
                                  wendy2702 last edited by
                                  Wenn ich jetzt nicht die Themen durcheinander werfe lief der Admin eben nicht und wird es jetzt wohl auch noch nicht
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                     21:51:48 up 37 min,  1 user,  load average: 2.22, 0.79, 0.73
                                    CPU threads: 4
                                    Current issues:
                                                   Local time: Sun 2024-02-25 21:51:48 CET
                                               Universal time: Sun 2024-02-25 20:51:48 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    simon
                                    /home/simon
                                    X-Server: 	false
                                    Desktop:
                                    Terminal: 	tty
                                    *** MEMORY ***
                                    Mem:            3.8G        2.1G        494M        1.0M        1.2G        1.6G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        2.1G        594M
                                             3794 M total memory
                                             2118 M used memory
                                             2335 M active memory
                                              732 M inactive memory
                                              494 M free memory
                                               84 M buffer memory
                                             1097 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       29G  5.0G   23G  19% /
                                    /var:
                                    1.5G	/var/
                                    859M	/var/log
                                    356M	/var/cache
                                    318M	/opt/iobroker/iobroker-data/
                                    115M	/opt/iobroker/iobroker-data/objects.jsonl
                                    USB-Devices by-id:
                                    /usr/bin/npm 		10.2.4
                                    /usr/bin/npx 		10.2.4
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    js-controller: 	5.0.19
                                    admin: 		6.13.16
                                    javascript: 	7.8.0
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects: 	3913
                                    States: 	3266
                                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Pending Updates: 0
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27403      4362/iobroker.js-co
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27410      4362/iobroker.js-co
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       26316      4380/io.sonoff.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28508      4439/io.web.0
                                    2024-02-25 21:51:29.577  - info: iqontrol.0 (4485) Deleting unused Objects...
                                    2024-02-25 21:51:29.579  - info: iqontrol.0 (4485) Subscribing to states...
                                    2024-02-25 21:51:29.583  - info: iqontrol.0 (4485) iQontrol ready.
                                    2024-02-25 21:51:29.843  - info: mqtt.0 (4412) All states published
                                    2024-02-25 21:51:36.597  - info: hmip.0 (4396) ws connection opened
                                    2024-02-25 21:51:36.933  - info: hmip.0 (4396) unknown channel type - DEVICE_BLOCKING - {"id":"3014F711A0002E9F29992FF7","type":"WALL_MOUNTED_KEY_PAD","homeId":"ef659a5d-aae8-47d2-a3b5-9223631a7821","lastStatusUpdate":1708888089958,"label":"Keypad Alarm + Haustürschloss","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0002E9F29992FF7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BLOCKING","groups":["31ff38e1-dd53-4727-b20e-1ea692736b01"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-73,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IFeatureDeviceDaliBusError":false,"IOptionalFeatureDutyCycle":t
                                    v.2023-10-10
                                    Icon name: computer
                                    Architecture: arm64
                                    Kernel: aarch64
                                    Userland: arm64
                                    User-ID: 1000
                                    X-Server: false
                                    Pending iob updates: 0
                                    /usr/bin/npm 10.2.4
                                    /usr/bin/npx 10.2.4
                                    MEMORY:
                                    total used free shared buff/cache available
                                    Mem: 3.8G 1.7G 894M 1.0M 1.2G 2.1G
                                    Swap: 99M 0B 99M
                                    Total: 3.9G 1.7G 994M
                                    ioBroker Core: js-controller 5.0.19
                                    admin 6.13.16
                                    Objects type: jsonl
                                    States type: jsonl
                                    • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    Objects: 3913
                                    States: 3266
                                    116M /opt/iobroker/iobroker-data/objects.jsonl
                                    1.3M /opt/iobroker/iobroker-data/states.jsonl
                                    simon@iobroker:~ $
                                      Homoran Global Moderator Administrators @wendy2702 last edited by
                                      @wendy2702 sagte in Raspberry "friert ein" nach Aufruf von ioBroker:
                                      so ist es!
                                      @Greenhorn
                                      iob start admin
                                        Greenhorn @Homoran last edited by
                                        Ja, stimmt.
                                        kann den ioBroker aber immer noch nicht öffnen...
                                        wendy2702 Homoran 2 Replies Last reply Reply Quote 0
                                        • wendy2702
                                          @greenhorn zeige uns ein/Ausgabe des Befehls
                                          Mach mal so
                                          iob start admin.0
                                            Homoran Global Moderator Administrators @Greenhorn last edited by
                                            @greenhorn ist der admin jetzt aktiv?
                                            wenn nein, was hindert ihn daran? =was steht im log?
                                            5311
