    3. Einsteigerfragen
    4. Adapter rot umrandet?
    • wendy2702
      wendy2702 @mcm1957 last edited by
      @mcm57 ja…
      Mit eventuell. Das lässt Spielraum 😁
        sailor_2011 @mcm1957 last edited by
        @wendy2702
        Das ist alles nicht so einfach hier...
        ![0_1708946252780_diag.jpg](Uploading 100%)
          sailor_2011 @mcm1957 last edited by wendy2702
          @mcm57
          Ich bin leider kein Experte, da weiss man manchmal nicht, was man tut 🙂
          Im Prinzip läuft alles, bislang war ich immer der Ansicht "do no disturb a running system" - aber die Sonoff-Thermostate hätte ich schon geren eingebunden - ohne mir das ganze System zu zerschießen 🙂
          *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 10 (buster)
                      Kernel: Linux 5.10.103-v7l+
                Architecture: arm
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : armhf
          Systemuptime and Load:
           12:21:49 up 96 days, 17:44,  1 user,  load average: 0.39, 0.37, 0.44
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Mon 2024-02-26 12:21:50 CET
                     Universal time: Mon 2024-02-26 11:21:50 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:           1.9G        1.2G        194M         30M        483M        662M
          Swap:           99M         99M        0.0K
          Total:         2.0G        1.3G        195M
                   1871 M total memory
                   1192 M used memory
                    411 M active memory
                   1162 M inactive memory
                    194 M free memory
                     82 M buffer memory
                    401 M swap cache
                     99 M total swap
                     99 M used swap
                      0 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed. Pass --all to see loaded but inactive units, too.
          To show all installed unit files use 'systemctl list-unit-files'.
          *** FILESYSTEM ***
          /dev/root      ext4       59G  3.6G   53G   7% /
          devtmpfs       devtmpfs  775M     0  775M   0% /dev
          tmpfs          tmpfs     936M     0  936M   0% /dev/shm
          tmpfs          tmpfs     936M   64M  873M   7% /run
          tmpfs          tmpfs     936M     0  936M   0% /sys/fs/cgroup
          /dev/sda1      vfat      253M   49M  204M  20% /boot
          tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
          [Tue Nov 21 18:37:19 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:1E:BF:C7 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=341e5e98-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Tue Nov 21 18:37:21 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
          [Tue Nov 21 18:37:21 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Tue Nov 21 18:37:23 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
          TARGET        SOURCE    FSTYPE OPTIONS
          /             /dev/sda2 ext4   rw,noatime
          |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
          `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          322M    /var/
          128M    /var/cache
          123M    /var/cache/apt
          92M     /var/lib
          69M     /var/lib/apt/lists
          Archived and active journals take up 62.7M in the file system.
          /opt/iobroker/backups:
          448M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          269M    /opt/iobroker/iobroker-data/
          201M    /opt/iobroker/iobroker-data/files
          78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
          51M     /opt/iobroker/iobroker-data/files/javascript.admin
          49M     /opt/iobroker/iobroker-data/backup-objects
          17M     /opt/iobroker/iobroker-data/objects.jsonl
          6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
          6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
          4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
          USB-Devices by-id:
          /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
          *** NodeJS-Installation ***
          /home/iobroker/.diag.sh: line 277: nodejs: command not found
          /usr/bin/node           v16.19.0
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          /usr/bin/corepack       0.15.1
          /home/iobroker/.diag.sh: line 288: nodejs: command not found
          *** nodejs is NOT correctly installed ***
          nodejs:
            Installed: 16.19.0-deb-1nodesource1
            Candidate: 16.20.2-deb-1nodesource1
            Version table:
               16.20.2-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
           *** 16.19.0-deb-1nodesource1 100
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u3 500
          No problems detected
          Errors in npm tree:
          npm ERR! code ELSPROBLEMS
          npm ERR! invalid: @types/node@14.18.36 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
          npm ERR!     /home/pi/.npm/_logs/2024-02-26T11_21_57_808Z-debug-0.log
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  4.0.23
          admin:          6.3.5
          javascript:     6.1.4
          Adapters from github:   1
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.mihome.0                 : mihome                : raspberrypi                              -  enabled, port: 9898, bind: 0.0.0.0
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, port: 8883, bind: 0.0.0.0
            system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
          + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
          + system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 192.168.178.21
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
            system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
            system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.yeelight-2.0             : yeelight-2            : raspberrypi                              -  enabled
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
            system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.13.16  , installed 6.3.5  [Updatable]
          Adapter    "backitup"     : 2.10.11  , installed 2.8.1  [Updatable]
          Adapter    "cloud"        : 4.4.1    , installed 4.2.1  [Updatable]
          Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
          Adapter    "fb-checkpresence": 1.2.3 , installed 1.1.20 [Updatable]
          Adapter    "fritzdect"    : 2.5.9    , installed 2.3.1  [Updatable]
          Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
          Adapter    "javascript"   : 7.8.0    , installed 6.1.4  [Updatable]
          Controller "js-controller": 5.0.19   , installed 4.0.23 [Updatable]
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "mqtt"         : 5.2.0    , installed 4.0.7  [Updatable]
          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
          Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
          Adapter    "pushover"     : 3.0.6    , installed 2.0.5  [Updatable]
          Adapter    "radar2"       : 2.1.0    , installed 2.0.3  [Updatable]
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
          Adapter    "vis"          : 1.5.4    , installed 1.4.15 [Updatable]
          Adapter    "vis-hqwidgets": 1.4.0    , installed 1.3.0  [Updatable]
          Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
          Adapter    "ws"           : 2.5.10   , installed 1.3.0  [Updatable]
          Adapter    "yeelight-2"   : 1.2.1    , installed 1.1.2  [Updatable]
          Adapter    "zigbee"       : 1.10.1   , installed 1.8.23 [Updatable]
          Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
          Objects and States
          Objects:        6065
          States:         5112
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
          Reading package lists...
          Pending Updates: 112
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17550      594/sshd
          tcp        0      0 192.168.178.21:1882     0.0.0.0:*               LISTEN      1001       43812454   5087/io.shelly.1
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       73054069   19612/io.sonoff.0
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       66740610   21120/io.mqtt.0
          tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       66740611   21120/io.mqtt.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16219      588/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17638      588/iobroker.js-con
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15206      667/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21512      1054/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          17552      594/sshd
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       42229772   28958/io.shelly.0
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       3494084    23479/io.radar2.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14855      586/dhcpcd
          udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       48542939   721/io.mihome.0
          udp        0      0 0.0.0.0:59611           0.0.0.0:*                           108        16515      336/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16513      336/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          52230902   586/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        16514      336/avahi-daemon: r
          udp6       0      0 :::55601                :::*                                108        16516      336/avahi-daemon: r
          2024-02-26 12:22:34.604  - warn: shelly.0 (28958) [authEnabled] 192.168.178.43 (ShellyBulbDuo / ShellyBulbDuo-8CAAB55F70E3 / SHBDUO-1#8CAAB55F70E3#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:36.535  - warn: shelly.0 (28958) [authEnabled] 192.168.178.35 (shellyplug-s / shellyplug-s-6F3F63 / SHPLG-S#6F3F63#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:36.664  - warn: shelly.0 (28958) [authEnabled] 192.168.178.75 (shellyplug-s / shellyplug-s-284864 / SHPLG2-1#284864#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:39.063  - info: mqtt.1 (23232) Reconnected to localhost
          2024-02-26 12:22:39.065  - error: mqtt.1 (23232) Client error:Error: connect ECONNREFUSED 127.0.0.1:8883
          2024-02-26 12:22:39.066  - info: mqtt.1 (23232) Disconnected from localhost
          2024-02-26 12:22:39.135  - warn: shelly.0 (28958) [authEnabled] 192.168.178.68 (shellyplug-s / shellyplug-s-2CC717 / SHPLG2-1#2CC717#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:39.857  - warn: shelly.0 (28958) [authEnabled] 192.168.178.106 (shellyplug-s / shellyplug-s-3CE90ED7C056 / SHPLG-S#3CE90ED7C056#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:41.309  - warn: shelly.0 (28958) [authEnabled] 192.168.178.37 (shelly1 / shelly1-BCDDC277BD38 / SHSW-1#BCDDC277BD38#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:41.422  - warn: shelly.0 (28958) [authEnabled] 192.168.178.45 (shellyplug-s / shellyplug-s-2842C8 / SHPLG2-1#2842C8#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:46.458  - warn: shelly.0 (28958) [authEnabled] 192.168.178.63 (shellyswitch25 / shellyswitch25-98CDAC24B972 / SHSW-25#98CDAC24B972#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:47.146  - warn: shelly.0 (28958) [authEnabled] 192.168.178.95 (shellycolorbulb / shellycolorbulb-3494546B07F2 / SHCB-1#3494546B07F2#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:49.068  - info: mqtt.1 (23232) Reconnected to localhost
          2024-02-26 12:22:49.070  - error: mqtt.1 (23232) Client error:Error: connect ECONNREFUSED 127.0.0.1:8883
          2024-02-26 12:22:49.070  - info: mqtt.1 (23232) Disconnected from localhost
          2024-02-26 12:22:49.694  - warn: shelly.0 (28958) [authEnabled] 192.168.178.43 (ShellyBulbDuo / ShellyBulbDuo-8CAAB55F70E3 / SHBDUO-1#8CAAB55F70E3#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:51.642  - warn: shelly.0 (28958) [authEnabled] 192.168.178.35 (shellyplug-s / shellyplug-s-6F3F63 / SHPLG-S#6F3F63#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:51.799  - warn: shelly.0 (28958) [authEnabled] 192.168.178.75 (shellyplug-s / shellyplug-s-284864 / SHPLG2-1#284864#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:54.270  - warn: shelly.0 (28958) [authEnabled] 192.168.178.68 (shellyplug-s / shellyplug-s-2CC717 / SHPLG2-1#2CC717#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:54.969  - warn: shelly.0 (28958) [authEnabled] 192.168.178.106 (shellyplug-s / shellyplug-s-3CE90ED7C056 / SHPLG-S#3CE90ED7C056#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:56.551  - warn: shelly.0 (28958) [authEnabled] 192.168.178.45 (shellyplug-s / shellyplug-s-2842C8 / SHPLG2-1#2842C8#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:56.628  - warn: shelly.0 (28958) [authEnabled] 192.168.178.37 (shelly1 / shelly1-BCDDC277BD38 / SHSW-1#BCDDC277BD38#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-02-26 12:22:59.072  - info: mqtt.1 (23232) Reconnected to localhost
          2024-02-26 12:22:59.073  - error: mqtt.1 (23232) Client error:Error: connect ECONNREFUSED 127.0.0.1:8883
          2024-02-26 12:22:59.074  - info: mqtt.1 (23232) Disconnected from localhost
          MOD EDIT: LOG in CODE TAGS
          Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @sailor_2011 last edited by
            @sailor_2011 sagte in Adapter rot umrandet?:
            Falsche Ansicht.
            Bring das Ding in Gänze auf Stand. Buster/Raspberry OS 10 ist abgekündigt.
            Installier da NEU ein Raspberry OS 12 'Bookworm' in der 64Bit-Lite-Version.
            nodejs ist auch veraltet und wird nicht mehr unterstützt. Update auf v18.
            Die ganzen Adapter bringst du auch auf einen aktuellen Stand, inkl. js-controller.
              sailor_2011 @Thomas Braun last edited by
              Ok, danke. Das klingt nach ner Menge Arbeit 🙂
                sailor_2011 @sailor_2011 last edited by
                @sailor_2011
                Bookworm ist jetzt drauf.
                Aber den Zigbee-Adapter bekomme ich nicht zum Laufen.
                Mit ls -l /dev/serial/by-id habe ich mir die Daten für den com-Anschluss für den Adapter geholt.
                Der Zigbee-Stick ist von Sonoff.
                zigbee.0
                2024-02-26 18:34:21.559 info Installed Version: iobroker.zigbee@1.10.1
                zigbee.0
                2024-02-26 18:34:21.519 error Error herdsman start
                zigbee.0
                2024-02-26 18:34:21.518 error Failed to start Zigbee
                zigbee.0
                2024-02-26 18:34:21.514 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c0501f1070d8ed11a2f76f6162c613ac-if00-port0'"
                Ich werd´hier noch irre - oder bin ich es schon?
                Helft mir bitte mal auf die Sprünge...
                • Marc Berg
                  Marc Berg Most Active @sailor_2011 last edited by Marc Berg
                  Da muss der gesamte Pfad rein:
                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c0501f1070d8ed11a2f76f6162c613ac-if00-port0
                    @mcm57 sagte in Adapter rot umrandet?:
                    Bist du ev noch auf node 16?
                    Ab 1.9.irgendwas ist node 18 erforderlich
                    schließ mich hier mal mit an, allerdings
                    mario@IoBroker:~$ nodejs -v
                    v18.19.1
                      sailor_2011 @Marc Berg last edited by
                      @marc-berg
                      Danke - das hab ich geändert.
                      Aber nun kommt dies hier:
                      zigbee.0
                      2024-02-26 20:03:57.911 error Error herdsman start
                      zigbee.0
                      2024-02-26 20:03:57.910 error Failed to start Zigbee
                      zigbee.0
                      2024-02-26 20:03:57.906 error Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
                      zigbee.0
                      2024-02-26 20:02:52.122 info Installed Version: iobroker.zigbee@1.10.1
                      zigbee.0
                      2024-02-26 20:02:51.833 info Starting Zigbee npm ...
                      zigbee.0
                      2024-02-26 20:02:51.732 info starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.1, js-controller: 5.0.19
                      Diese PAN ID als auch die Erweiterte PAN ID habe ich geändert - trotzdem bleibt der Adapter "gelb"
                        @marc-berg
                        zigbee.0
                        2024-02-26 20:10:13.055 error Error herdsman start
                        zigbee.0
                        2024-02-26 20:10:13.054 error Failed to start Zigbee
                        zigbee.0
                        2024-02-26 20:10:13.053 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                          crunchip Forum Testing Most Active @sailor_2011 last edited by
                          zigbee.0
                          verstehe ich irgendwie nicht so ganz
                          S 4 Replies Last reply Reply Quote 0
                            sailor_2011 @crunchip last edited by
                            @crunchip
                            Weiss auch nicht, wie es vorhin bei der Installation zu 10.1 kam - hab erst jetrzt gesehen, dass man noch mal updaten konnte - Resultat:
                            Adapter ist G R Ü N 🙂
                            Daaaanke euch allen! 👍 👍 👍
                              @crunchip
                              ups - er w a r "Grün" - aber nur kurz
                                @crunchip
                                zigbee.0
                                2024-02-26 20:18:37.564 error Error herdsman start
                                zigbee.0
                                2024-02-26 20:18:37.564 error Failed to start Zigbee
                                zigbee.0
                                2024-02-26 20:18:37.563 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                zigbee.0
                                2024-02-26 20:18:37.350 info Installed Version: iobroker.zigbee@1.10.2
                                Das ist ein Ding ohne Ende... 😖
                                  @crunchip
                                  zigbee.0
                                  2024-02-26 20:26:42.021 error Error herdsman start
                                  zigbee.0
                                  2024-02-26 20:26:42.020 error Failed to start Zigbee
                                  zigbee.0
                                  2024-02-26 20:26:42.019 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                  zigbee.0
                                  2024-02-26 20:26:41.818 info Installed Version: iobroker.zigbee@1.10.2
                                  zigbee.0
                                  2024-02-26 20:26:41.805 info Starting Zigbee npm ...
                                  zigbee.0
                                  2024-02-26 20:26:41.804 info Try to reconnect. 1 attempts left
                                  zigbee.0
                                  2024-02-26 20:26:31.800 error Error herdsman start
                                  zigbee.0
                                  2024-02-26 20:26:31.800 error Failed to start Zigbee
                                  zigbee.0
                                  2024-02-26 20:26:31.799 error Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                  zigbee.0
                                  2024-02-26 20:26:31.686 error Re-commissioning your network will require re-pairing of all devices!
                                  zigbee.0
                                  2024-02-26 20:26:31.686 error If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                                  zigbee.0
                                  2024-02-26 20:26:31.685 error Please update configuration to prevent further issues.
                                  zigbee.0
                                  2024-02-26 20:26:31.684 error - Channel List: configured=11, adapter=11
                                  zigbee.0
                                  2024-02-26 20:26:31.684 error - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                                  zigbee.0
                                  2024-02-26 20:26:31.683 error - Extended PAN ID: configured=00124b002c3ae63d, adapter=00124b002c3ae63d
                                  zigbee.0
                                  2024-02-26 20:26:31.682 error - PAN ID: configured=1419, adapter=1417
                                  zigbee.0
                                  2024-02-26 20:26:31.681 error Configuration is not consistent with adapter state/backup!
                                  If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json. - das hab ich eben gemacht...
                                  Und jetzt... bleibt das Lämpchen auf G R Ü N - meine Güte, was für eine Wissenschaft...
                                  Vielen Dank nochmals Euch allen 🙂
                                    Die muss übereinstimmen. Also im Adapter entsprechend ändern.
                                      Hallo Gemeinde.
                                      Ich wollte mich noch mal (abschließend) melden.
                                      Hatte noch mal einen neuen Post bez. des Zigbee-Adapters, Adapter war "Grün", trotzdem ließ sich nichts einbinden, auch keine Meldungen im Protololl.
                                      Viel (mit eurer Hilfe) ausprobiert, irgendwie führte nichts zum Erfolg.
                                      Nun habe ich einen letzten Schritt/Versuch gemacht: Sonoff-Stick zurück gesandt, Conbee bestellt - und nun läuft es - da gab es überhaupt keine Huddelei beim Einbinden, keine Fehlermeldungen, nichts dergleichen.
                                        Auch die Signalwerte sind bei dem Conbee höher. Bei dem Sonoff-Stick kam es nicht höher, als ca. 125
                                        844
