    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Shelly Adapterinstanz bleibt gelb
    • Chriz
      Chriz @haselchen last edited by
      @haselchen ```
                              v.2023-10-10
      model name      : Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.1.1
      Installation:           Docker
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Etc/UTC
      User-ID:                0
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.1
                              /usr/bin/node           v18.19.1
                              /usr/bin/npm            10.2.4
                              /usr/bin/npx            10.2.4
                              /usr/bin/corepack       0.22.0
      Recommended versions are nodejs 18.19.1 and npm 10.2.4
      MEMORY:
      Mem:             12G        5.5G        306M        554M        7.6G        7.0G
      Swap:            10G        733M         10G
      Total:           23G        6.2G         10G
      Active iob-Instances:   24
      Active repo(s): Stable (default)
      ioBroker Core:          js-controller           5.0.19
                              admin                   6.13.16
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : 22646d536096                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : 22646d536096                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                15099
      States:                 15252
      Size of iob-Database:
      33M     /opt/iobroker/iobroker-data/objects.jsonl
      13M     /opt/iobroker/iobroker-data/objects.json.migrated
      13M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      14M     /opt/iobroker/iobroker-data/states.jsonl
      3.0M    /opt/iobroker/iobroker-data/states.json.migrated
      3.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      === Mark text until here for copying ===
      haselchen Samson71 2 Replies Last reply Reply Quote 1
      • haselchen
        haselchen Most Active @Chriz last edited by
        @chriz
        Jetzt noch die Langfassung davon 🙂
        Chriz 1 Reply Last reply Reply Quote 1
        • Samson71
          Samson71 Global Moderator @Chriz last edited by
          @Chriz
          Das ist "nur" der Summary. Nicht die Komplett Ausgabe.
          • Chriz
            Chriz @haselchen last edited by Chriz
            @haselchen
            ua, tut mir Leid 🤦
            Skript v.2023-10-10
            *** BASE SYSTEM ***
            Hardware Vendor : To Be Filled By O.E.M.
            Kernel          : x86_64
            Userland        : amd64
            Docker          : v9.1.1
            Virtualization  : Docker
            Kernel          : x86_64
            Userland        : amd64
            Systemuptime and Load:
             18:06:16 up 60 days,  2:37,  0 user,  load average: 10.21, 9.20, 7.21
            CPU threads: 8
            *** Time and Time Zones ***
            Wed Feb 28 17:06:16 UTC 2024
            Wed Feb 28 18:06:16 CET 2024
            CET +0100
            Etc/UTC
            *** User and Groups ***
            root
            /root
            root
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
            Swap:            10G        733M         10G
            Total:           23G        6.2G         10G
                    11915 M total memory
                     5260 M used memory
                     3617 M active memory
                     6264 M inactive memory
                      292 M free memory
                        1 M buffer memory
                     7202 M swap cache
                    10239 M total swap
                      699 M used swap
                     9540 M free swap
            *** FILESYSTEM ***
            Filesystem     Type       Size  Used Avail Use% Mounted on
            /dev/loop2     btrfs       25G  7.0G   18G  29% /
            tmpfs          tmpfs       64M     0   64M   0% /dev
            shm            tmpfs       64M     0   64M   0% /dev/shm
            shfs           fuse.shfs  932G  267G  665G  29% /opt/iobroker
            /dev/loop2     btrfs       25G  7.0G   18G  29% /etc/hosts
            tmpfs          tmpfs      5.9G     0  5.9G   0% /proc/acpi
            tmpfs          tmpfs      5.9G     0  5.9G   0% /sys/firmware
            dmesg: read kernel buffer failed: Operation not permitted
            TARGET             SOURCE        FSTYPE    OPTIONS
            /                  /dev/loop2[/btrfs/subvolumes/5322bd356013345d50636c8434e2e273c4ab5d4b4738c2d12790a6eb3c1c2d59]       btrfs     rw,noatime,ssd,space_cache=v2,subvolid=949,subvol=/btrfs/subvolumes/5322bd356013345d50636c8434e2e273c4ab5d4b4738c2d12790a6eb3c1c2d59
            |-/opt/iobroker    shfs[/appdata/iobroker/data]        fuse.shfs rw,nosuid,nodev,noatime,user_id=0,group_id=0,default_permissions,allow_other
            |-/opt/userscripts shfs[/appdata/iobroker/scripts]        fuse.shfs rw,nosuid,nodev,noatime,user_id=0,group_id=0,default_permissions,allow_other
            |-/etc/resolv.conf /dev/loop2[/containers/22646d536096c5b460e9e9871d278aeec6ba4c324f924b103e2617abcc5650f9/resolv.conf] btrfs     rw,noatime,ssd,space_cache=v2,subvolid=5,subvol=/
            |-/etc/hostname    /dev/loop2[/containers/22646d536096c5b460e9e9871d278aeec6ba4c324f924b103e2617abcc5650f9/hostname]    btrfs     rw,noatime,ssd,space_cache=v2,subvolid=5,subvol=/
            `-/etc/hosts       /dev/loop2[/containers/22646d536096c5b460e9e9871d278aeec6ba4c324f924b103e2617abcc5650f9/hosts]       btrfs     rw,noatime,ssd,space_cache=v2,subvolid=5,subvol=/
            /var:
            34M     /var/
            32M     /var/lib
            19M     /var/lib/apt/lists
            19M     /var/lib/apt
            13M     /var/lib/dpkg
            /opt/iobroker/backups:
            9.6M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            403M    /opt/iobroker/iobroker-data/
            199M    /opt/iobroker/iobroker-data/files
            128M    /opt/iobroker/iobroker-data/backup-objects
            57M     /opt/iobroker/iobroker-data/files/javascript.admin
            43M     /opt/iobroker/iobroker-data/files/iot.admin
            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
            22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
            15M     /opt/iobroker/iobroker-data/states.jsonl
            USB-Devices by-id:
            /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_3a866a46ae89eb118f103dc07d11dc1e-if00-port0
            /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_de4ef275ea5fec118396325f25bfaa52-if00-port0
            *** NodeJS-Installation ***
            /usr/bin/npm            10.2.4
            /usr/bin/npx            10.2.4
            nodejs:
              Installed: 18.19.1-1nodesource1
              Candidate: 18.19.1-1nodesource1
              Version table:
             *** 18.19.1-1nodesource1 1001
                   1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                 18.19.0-1nodesource1 1001
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0+dfsg1-1 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.19
            admin:          6.13.16
            javascript:     7.8.0
            Adapters from github:   1
            Adapter State
            + system.adapter.alexa2.0                 : alexa2                : 22646d536096                             -  enabled
            + system.adapter.backitup.0               : backitup              : 22646d536096                             -  enabled
            + system.adapter.denon.0                  : denon                 : 22646d536096                             -  enabled
            + system.adapter.discovery.0              : discovery             : 22646d536096                             -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : 22646d536096                             -  enabled
            + system.adapter.influxdb.0               : influxdb              : 22646d536096                             -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : 22646d536096                             -  enabled
            + system.adapter.iot.0                    : iot                   : 22646d536096                             -  enabled
            + system.adapter.javascript.0             : javascript            : 22646d536096                             -  enabled
            + system.adapter.lgtv.0                   : lgtv                  : 22646d536096                             -  enabled
            + system.adapter.loxone.0                 : loxone                : 22646d536096                             -  enabled, port: 80
            + system.adapter.luxtronik2.0             : luxtronik2            : 22646d536096                             -  enabled, port: 8214
            + system.adapter.mqtt.0                   : mqtt                  : 22646d536096                             -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.nuki-extended.0          : nuki-extended         : 22646d536096                             -  enabled
            + system.adapter.octoprint.0              : octoprint             : 22646d536096                             -  enabled
            + system.adapter.shelly.0                 : shelly                : 22646d536096                             -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.signal-cmb.0             : signal-cmb            : 22646d536096                             -  enabled
            + system.adapter.simple-api.0             : simple-api            : 22646d536096                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.smartmeter.0             : smartmeter            : 22646d536096                             -  enabled
            + system.adapter.tr-064.0                 : tr-064                : 22646d536096                             -  enabled
              system.adapter.vis-history.0            : vis-history           : 22646d536096                             -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : 22646d536096                             -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : 22646d536096                             -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : 22646d536096                             -  enabled
              system.adapter.vis-justgage.0           : vis-justgage          : 22646d536096                             -  enabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : 22646d536096                             -  enabled
              system.adapter.vis-metro.0              : vis-metro             : 22646d536096                             -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : 22646d536096                             -  enabled
              system.adapter.vis-weather.0            : vis-weather           : 22646d536096                             -  enabled
              system.adapter.vis.0                    : vis                   : 22646d536096                             -  enabled
              system.adapter.vw-connect.1             : vw-connect            : 22646d536096                             - disabled
              system.adapter.weatherunderground.0     : weatherunderground    : 22646d536096                             -  enabled
            + system.adapter.zigbee.0                 : zigbee                : 22646d536096                             -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_de4ef275ea5fec118396325f25bfaa52-if00-port0
            + instance is alive
            ioBroker-Repositories
            Stable (default): http://download.iobroker.net/sources-dist.json
            Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
            Installed ioBroker-Instances
            Used repository: Stable (default)
            Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
            Adapter    "backitup"     : 2.10.11  , installed 2.10.11
            Adapter    "denon"        : 1.15.5   , installed 1.15.5
            Adapter    "iot"          : 2.0.11   , installed 2.0.11
            Adapter    "javascript"   : 7.8.0    , installed 7.8.0
            Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
            Adapter    "loxone"       : 3.0.1    , installed 3.0.1
            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
            Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
            Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
            Adapter    "ring"         : 5.0.10   , installed 5.0.10
            Adapter    "shelly"       : 6.6.1    , installed 6.6.1
            Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
            Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
            Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
            Adapter    "weatherunderground": 3.6.0, installed 3.6.0
            Adapter    "web"          : 6.2.3    , installed 6.2.3
            Adapter    "ws"           : 2.5.10   , installed 2.5.10
            Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
            Objects and States
            Objects:        15099
            States:         15252
            Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      99         538520712  -
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      99         538521626  -
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      99         538524912  -
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      99         538678861  -
            tcp6       0      0 :::8082                 :::*                    LISTEN      99         538556277  -
            tcp6       0      0 :::8081                 :::*                    LISTEN      99         538520745  -
            tcp6       0      0 :::8087                 :::*                    LISTEN      99         538559721  -
            2024-02-28 17:54:19.665  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 17:54:50.675  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 17:55:21.671  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 17:55:52.663  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 17:56:23.667  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 17:56:54.668  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 17:57:25.667  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 17:57:56.666  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 17:58:27.664  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 17:58:58.706  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 17:59:29.667  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 18:00:00.676  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 18:00:31.662  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 18:01:02.663  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 18:01:33.674  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 18:02:04.658  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 18:02:35.658  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 18:03:06.657  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 18:03:37.662  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 18:04:08.656  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 18:04:39.654  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 18:05:10.672  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 18:05:41.654  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 18:06:12.654  - info: smartmeter.0 (321) Received 9 values, 6 updated
            2024-02-28 18:06:43.657  - info: smartmeter.0 (321) Received 9 values, 6 updated
            ich hoffe da steht nix drin, was nicht im Netz stehen sollte 😕
            melde mich morgen wieder dazu, muss leider noch weg, jetzt.
            Schonmal jetzt vielen Dank an euch, ich hoffe ich kann morgenw ieder auf euch zählen 🙂
            • DJMarc75
              DJMarc75 @Chriz last edited by
              @chriz
              User ROOT schonmal mehr als falsch 😉
              @chriz sagte in Shelly Adapterinstanz bleibt gelb:
              heiliges Blechle 🤕
              Da läuft was mehr als aus dem Ruder
              Chriz 1 Reply Last reply Reply Quote 0
              • Chriz
                Chriz @DJMarc75 last edited by
                @djmarc75
                Was ist denn falsch bzw. schlimm?
                • DJMarc75
                  Na wie geschrieben meldet man sich nicht als root auf der Kiste an sondern mit einem gescheiten User 😉
                  Dann sind die loads über dem Limit, bei 8 Kernen. Laufen da vll ein paar Skripte bei Dir Amok ?
                  iob fix
                  auch mal machen.
                  • Chriz
                    Chriz @DJMarc75 last edited by Chriz
                    @djmarc75
                    Wieso nicht als root anmelden?
                    Läuft bei mir seit Jahren so ohne Probleme..
                    Um ehrlich zu sein wüsste ich nicht mal das ich mich überhaupt irgendwo anmelden müsste... 😕
                    Scripte habe ich 3 Stück wovon eines nur läuft. Und das macht nix weiter als eine Nachricht zu schicken wenn sich ein bestimmter Datenpunkt verändert. Passiert aber nur alle paar Monate mal.
                    Mein System ist eigentlich gar nicht ausgelastet. CPU Auslastung liegt immer zwischen 20 und 50%, je nachdem was gerade an Surveillance so codiert wird...
                    Magst du mir mal erklären woher deine Annahme kommt? Ich verstehe die Werte nicht die du da geschrieben hast. 😢
                    • Codierknecht
                      Codierknecht Developer Most Active @Chriz last edited by
                      Weil man ja auch keine Dampframme nimmt, um einen Nagel in die Wand zu schlagen.
                      Der User root hat viel zu viele Rechte. Da hat man schneller was verbogen als einem lieb ist.
                      Auf einem vernünftig aufgesetzten System darf root sich nicht mal in der Konsole anmelden.
                      Chriz Homoran 2 Replies Last reply Reply Quote 0
                      • Chriz
                        Chriz @Codierknecht last edited by
                        @codierknecht
                        okay verstehe.
                        Bei mir läuft das alles aber seit Jahren so und da ist nie was "schlimmes" passiert.
                        Ich gehe davon aus, das jetzt zu ändern würde zu sehr vielen Anpassungen im System führen.
                        Wie gesagt ich wüsste auch nicht mal wie man sowas ändert.
                        Als Programmierlaie würde ich erwarten das man beim ersten Systemstart auf sowas hingewiesen wird.
                        Vielleicht habt ihr ja ein kleines laienverständliches Tutorial was ich mir bei Gelegenheit mal angucken kann?
                        Aber zurück zum Problem, hat noch jemand eine Ahnung was mit dem Adapter sein kann?
                          Homoran Global Moderator Administrators @Codierknecht last edited by
                          @codierknecht
                          Chriz Codierknecht 2 Replies Last reply Reply Quote 1
                          • Chriz
                            Chriz @Homoran last edited by
                            ich vermute dein Quote bedeutet, das im Dockercontainer alles unter root läuft?
                            Hatte sowas ähnliches im Sinn, aber hab mich nicht getraut das zu erwähnen, da ich da leider zu wenig Ahnung von habe.
                            Aber das mit dem Adapter kann da nicht dran liegen?
                            Ich vermute es hat was mit dem Shelly zu tun das der Adapter nicht grün wird.
                            Er findet halt keine Geräte, obwohl das Log ja zeigt das er "zuhört" (listening)...
                            Kann ich irgendwie überprüfen ob mein Shelly kommuniziert?
                            • Codierknecht
                              Codierknecht Developer Most Active @Homoran last edited by
                              @homoran sagte in Shelly Adapterinstanz bleibt gelb:
                              Glatt überlesen 😞
                              Ob das unter Docker grundsätzlich so ist, kann ich nicht sagen.
                              Falls das auf einer Synology läuft, hast Du Recht. Da geht das gar nicht anders.
                              @Chriz Welche Hardware läuft da?
                              • Samson71
                                @chriz
                                Bei Docker bin ich auch weitestgehend raus, aber passen die Ports? Die müssen doch unter Docker ggf. gemappt werden?
                                Für Docker haben wir eigene "Spezialisten". Evtl. können da @Glasfaser oder @Marc-Berg besser weiterhelfen.
                                Codierknecht Chriz 2 Replies Last reply Reply Quote 1
                                • Codierknecht
                                  Codierknecht Developer Most Active @Samson71 last edited by
                                  @samson71 sagte in Shelly Adapterinstanz bleibt gelb:
                                  Betreibe das auf der Synology nur noch für eines meiner Testsysteme.
                                  @Chriz
                                  Betreibst Du den Container im Bridge-Mode? Wenn ja: Sind die benötigten Ports in den Container durchgereicht?
                                  Chriz 1 Reply Last reply Reply Quote 2
                                  • Chriz
                                    Chriz @Samson71 last edited by
                                    @samson71 said in Shelly Adapterinstanz bleibt gelb:
                                    @chriz
                                    Samson DU BIST DER BESTE und ich bin so ein Idiot!
                                    Ich habe vergessen den Port zu mappen 😠
                                    Sorry das ich euch alle bemühen musste, wegen diesem trivialen Thema 😞
                                    • Chriz
                                      Chriz @Codierknecht last edited by Chriz
                                      @codierknecht
                                      Samsung hat ja bereits das gleiche geschrieben, das war tatsächlöich das Problem.
                                      Ist mir ein wenig peinlich.
                                      Am liebsten wäre mir, wir löschen den ganzen Thread 🙄
                                      Aber vielleicht vergisst es nochmal der ein oder andere und denkt dann daran.
                                      PS: Kann man aus den DIag Infos und Screenshots irgendwas rauslesen, was man besser nicht im Netz stehen haben sollte?
                                      Wenn ja, darf ich den inhalt der Diags und die Screenshots löschen, oder spricht da was gegen?
                                      • Codierknecht
                                        @chriz
                                        Hauptsache, das Problem konnte gelöst werden.
                                        Dazu ist ja das Forum da. Und wenn die Diskussion nur dazu dient, den Schubs in die richtige Richtung zu geben.
                                        Mein Produktivsystem hatte ich aus genau diesem Grund im Host-Mode betrieben.
                                        Solange keine Konflikte bzgl. Ports drohen, ist das wesentlich stressfreier.
                                        Ich sehe da nix verfängliches. Lass mal ruhig stehen.
                                        2283
