    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Shelly Adapterinstanz bleibt gelb
    • Samson71
      Samson71 Global Moderator @Chriz last edited by
      @Chriz
      Das ist "nur" der Summary. Nicht die Komplett Ausgabe.
      • Chriz
        Chriz @haselchen last edited by Chriz
        @haselchen
        ua, tut mir Leid 🤦
        Skript v.2023-10-10
        *** BASE SYSTEM ***
        Hardware Vendor : To Be Filled By O.E.M.
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v9.1.1
        Virtualization  : Docker
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         18:06:16 up 60 days,  2:37,  0 user,  load average: 10.21, 9.20, 7.21
        CPU threads: 8
        *** Time and Time Zones ***
        Wed Feb 28 17:06:16 UTC 2024
        Wed Feb 28 18:06:16 CET 2024
        CET +0100
        Etc/UTC
        *** User and Groups ***
        root
        /root
        root
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:             12G        5.5G        306M        554M        7.6G        7.0G
        Swap:            10G        733M         10G
        Total:           23G        6.2G         10G
                11915 M total memory
                 5260 M used memory
                 3617 M active memory
                 6264 M inactive memory
                  292 M free memory
                    1 M buffer memory
                 7202 M swap cache
                10239 M total swap
                  699 M used swap
                 9540 M free swap
        *** FILESYSTEM ***
        Filesystem     Type       Size  Used Avail Use% Mounted on
        /dev/loop2     btrfs       25G  7.0G   18G  29% /
        tmpfs          tmpfs       64M     0   64M   0% /dev
        shm            tmpfs       64M     0   64M   0% /dev/shm
        shfs           fuse.shfs  932G  267G  665G  29% /opt/iobroker
        /dev/loop2     btrfs       25G  7.0G   18G  29% /etc/hosts
        tmpfs          tmpfs      5.9G     0  5.9G   0% /proc/acpi
        tmpfs          tmpfs      5.9G     0  5.9G   0% /sys/firmware
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET             SOURCE        FSTYPE    OPTIONS
        /                  /dev/loop2[/btrfs/subvolumes/5322bd356013345d50636c8434e2e273c4ab5d4b4738c2d12790a6eb3c1c2d59]       btrfs     rw,noatime,ssd,space_cache=v2,subvolid=949,subvol=/btrfs/subvolumes/5322bd356013345d50636c8434e2e273c4ab5d4b4738c2d12790a6eb3c1c2d59
        |-/opt/iobroker    shfs[/appdata/iobroker/data]        fuse.shfs rw,nosuid,nodev,noatime,user_id=0,group_id=0,default_permissions,allow_other
        |-/opt/userscripts shfs[/appdata/iobroker/scripts]        fuse.shfs rw,nosuid,nodev,noatime,user_id=0,group_id=0,default_permissions,allow_other
        |-/etc/resolv.conf /dev/loop2[/containers/22646d536096c5b460e9e9871d278aeec6ba4c324f924b103e2617abcc5650f9/resolv.conf] btrfs     rw,noatime,ssd,space_cache=v2,subvolid=5,subvol=/
        |-/etc/hostname    /dev/loop2[/containers/22646d536096c5b460e9e9871d278aeec6ba4c324f924b103e2617abcc5650f9/hostname]    btrfs     rw,noatime,ssd,space_cache=v2,subvolid=5,subvol=/
        `-/etc/hosts       /dev/loop2[/containers/22646d536096c5b460e9e9871d278aeec6ba4c324f924b103e2617abcc5650f9/hosts]       btrfs     rw,noatime,ssd,space_cache=v2,subvolid=5,subvol=/
        /var:
        34M     /var/
        32M     /var/lib
        19M     /var/lib/apt/lists
        19M     /var/lib/apt
        13M     /var/lib/dpkg
        /opt/iobroker/backups:
        9.6M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        403M    /opt/iobroker/iobroker-data/
        199M    /opt/iobroker/iobroker-data/files
        128M    /opt/iobroker/iobroker-data/backup-objects
        57M     /opt/iobroker/iobroker-data/files/javascript.admin
        43M     /opt/iobroker/iobroker-data/files/iot.admin
        33M     /opt/iobroker/iobroker-data/objects.jsonl
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
        15M     /opt/iobroker/iobroker-data/states.jsonl
        13M     /opt/iobroker/iobroker-data/objects.json.migrated
        USB-Devices by-id:
        /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_3a866a46ae89eb118f103dc07d11dc1e-if00-port0
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_de4ef275ea5fec118396325f25bfaa52-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.1
        /usr/bin/node           v18.19.1
        /usr/bin/npm            10.2.4
        /usr/bin/npx            10.2.4
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.1-1nodesource1
          Candidate: 18.19.1-1nodesource1
          Version table:
         *** 18.19.1-1nodesource1 1001
               1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.19.0+dfsg-6~deb12u1 500
                500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.13.16
        javascript:     7.8.0
        Adapters from github:   1
        Adapter State
        + system.adapter.admin.0                  : admin                 : 22646d536096                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : 22646d536096                             -  enabled
        + system.adapter.backitup.0               : backitup              : 22646d536096                             -  enabled
        + system.adapter.denon.0                  : denon                 : 22646d536096                             -  enabled
        + system.adapter.discovery.0              : discovery             : 22646d536096                             -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : 22646d536096                             -  enabled
        + system.adapter.influxdb.0               : influxdb              : 22646d536096                             -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : 22646d536096                             -  enabled
        + system.adapter.iot.0                    : iot                   : 22646d536096                             -  enabled
        + system.adapter.javascript.0             : javascript            : 22646d536096                             -  enabled
        + system.adapter.lgtv.0                   : lgtv                  : 22646d536096                             -  enabled
        + system.adapter.loxone.0                 : loxone                : 22646d536096                             -  enabled, port: 80
        + system.adapter.luxtronik2.0             : luxtronik2            : 22646d536096                             -  enabled, port: 8214
        + system.adapter.mqtt.0                   : mqtt                  : 22646d536096                             -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.nuki-extended.0          : nuki-extended         : 22646d536096                             -  enabled
        + system.adapter.octoprint.0              : octoprint             : 22646d536096                             -  enabled
        + system.adapter.shelly.0                 : shelly                : 22646d536096                             -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.signal-cmb.0             : signal-cmb            : 22646d536096                             -  enabled
        + system.adapter.simple-api.0             : simple-api            : 22646d536096                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartmeter.0             : smartmeter            : 22646d536096                             -  enabled
        + system.adapter.tr-064.0                 : tr-064                : 22646d536096                             -  enabled
          system.adapter.vis-history.0            : vis-history           : 22646d536096                             -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : 22646d536096                             -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : 22646d536096                             -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : 22646d536096                             -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : 22646d536096                             -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : 22646d536096                             -  enabled
          system.adapter.vis-metro.0              : vis-metro             : 22646d536096                             -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : 22646d536096                             -  enabled
          system.adapter.vis-weather.0            : vis-weather           : 22646d536096                             -  enabled
          system.adapter.vis.0                    : vis                   : 22646d536096                             -  enabled
          system.adapter.vw-connect.1             : vw-connect            : 22646d536096                             - disabled
          system.adapter.weatherunderground.0     : weatherunderground    : 22646d536096                             -  enabled
        + system.adapter.web.0                    : web                   : 22646d536096                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : 22646d536096                             -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_de4ef275ea5fec118396325f25bfaa52-if00-port0
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): Stable (default)
        Installed ioBroker-Instances
        Used repository: Stable (default)
        Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
        Adapter    "denon"        : 1.15.5   , installed 1.15.5
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
        Adapter    "loxone"       : 3.0.1    , installed 3.0.1
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
        Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
        Adapter    "ring"         : 5.0.10   , installed 5.0.10
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
        Objects and States
        Objects:        15099
        States:         15252
        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      99         538520712  -
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      99         538521626  -
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      99         538524912  -
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      99         538678861  -
        tcp6       0      0 :::8082                 :::*                    LISTEN      99         538556277  -
        tcp6       0      0 :::8081                 :::*                    LISTEN      99         538520745  -
        tcp6       0      0 :::8087                 :::*                    LISTEN      99         538559721  -
        2024-02-28 17:54:19.665  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 17:54:50.675  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 17:55:21.671  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 17:55:52.663  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 17:56:23.667  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 17:56:54.668  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 17:57:25.667  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 17:57:56.666  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 17:58:27.664  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 17:58:58.706  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 17:59:29.667  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 18:00:00.676  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 18:00:31.662  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 18:01:02.663  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 18:01:33.674  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 18:02:04.658  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 18:02:35.658  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 18:03:06.657  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 18:03:37.662  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 18:04:08.656  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 18:04:39.654  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 18:05:10.672  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 18:05:41.654  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 18:06:12.654  - info: smartmeter.0 (321) Received 9 values, 6 updated
        2024-02-28 18:06:43.657  - info: smartmeter.0 (321) Received 9 values, 6 updated
        ich hoffe da steht nix drin, was nicht im Netz stehen sollte 😕
        melde mich morgen wieder dazu, muss leider noch weg, jetzt.
        Schonmal jetzt vielen Dank an euch, ich hoffe ich kann morgenw ieder auf euch zählen 🙂
        • DJMarc75
          DJMarc75 @Chriz last edited by
          @chriz
          User ROOT schonmal mehr als falsch 😉
          @chriz sagte in Shelly Adapterinstanz bleibt gelb:
          heiliges Blechle 🤕
          Da läuft was mehr als aus dem Ruder
          Chriz 1 Reply Last reply Reply Quote 0
          • Chriz
            Chriz @DJMarc75 last edited by
            @djmarc75
            Was ist denn falsch bzw. schlimm?
            • DJMarc75
              Na wie geschrieben meldet man sich nicht als root auf der Kiste an sondern mit einem gescheiten User 😉
              Dann sind die loads über dem Limit, bei 8 Kernen. Laufen da vll ein paar Skripte bei Dir Amok ?
              iob fix
              auch mal machen.
              • Chriz
                Chriz @DJMarc75 last edited by Chriz
                @djmarc75
                Wieso nicht als root anmelden?
                Läuft bei mir seit Jahren so ohne Probleme..
                Um ehrlich zu sein wüsste ich nicht mal das ich mich überhaupt irgendwo anmelden müsste... 😕
                Scripte habe ich 3 Stück wovon eines nur läuft. Und das macht nix weiter als eine Nachricht zu schicken wenn sich ein bestimmter Datenpunkt verändert. Passiert aber nur alle paar Monate mal.
                Mein System ist eigentlich gar nicht ausgelastet. CPU Auslastung liegt immer zwischen 20 und 50%, je nachdem was gerade an Surveillance so codiert wird...
                Magst du mir mal erklären woher deine Annahme kommt? Ich verstehe die Werte nicht die du da geschrieben hast. 😢
                • Codierknecht
                  Codierknecht Developer Most Active @Chriz last edited by
                  Weil man ja auch keine Dampframme nimmt, um einen Nagel in die Wand zu schlagen.
                  Der User root hat viel zu viele Rechte. Da hat man schneller was verbogen als einem lieb ist.
                  Auf einem vernünftig aufgesetzten System darf root sich nicht mal in der Konsole anmelden.
                  Chriz Homoran 2 Replies Last reply Reply Quote 0
                  • Chriz
                    Chriz @Codierknecht last edited by
                    @codierknecht
                    okay verstehe.
                    Bei mir läuft das alles aber seit Jahren so und da ist nie was "schlimmes" passiert.
                    Ich gehe davon aus, das jetzt zu ändern würde zu sehr vielen Anpassungen im System führen.
                    Wie gesagt ich wüsste auch nicht mal wie man sowas ändert.
                    Als Programmierlaie würde ich erwarten das man beim ersten Systemstart auf sowas hingewiesen wird.
                    Vielleicht habt ihr ja ein kleines laienverständliches Tutorial was ich mir bei Gelegenheit mal angucken kann?
                    Aber zurück zum Problem, hat noch jemand eine Ahnung was mit dem Adapter sein kann?
                      Homoran Global Moderator Administrators @Codierknecht last edited by
                      @codierknecht
                      Installation: Docker
                      Chriz Codierknecht 2 Replies Last reply Reply Quote 1
                      • Chriz
                        Chriz @Homoran last edited by
                        ich vermute dein Quote bedeutet, das im Dockercontainer alles unter root läuft?
                        Hatte sowas ähnliches im Sinn, aber hab mich nicht getraut das zu erwähnen, da ich da leider zu wenig Ahnung von habe.
                        Aber das mit dem Adapter kann da nicht dran liegen?
                        Ich vermute es hat was mit dem Shelly zu tun das der Adapter nicht grün wird.
                        Er findet halt keine Geräte, obwohl das Log ja zeigt das er "zuhört" (listening)...
                        Kann ich irgendwie überprüfen ob mein Shelly kommuniziert?
                        • Codierknecht
                          Codierknecht Developer Most Active @Homoran last edited by
                          @homoran sagte in Shelly Adapterinstanz bleibt gelb:
                          Glatt überlesen 😞
                          Ob das unter Docker grundsätzlich so ist, kann ich nicht sagen.
                          Falls das auf einer Synology läuft, hast Du Recht. Da geht das gar nicht anders.
                          @Chriz Welche Hardware läuft da?
                          • Samson71
                            @chriz
                            Bei Docker bin ich auch weitestgehend raus, aber passen die Ports? Die müssen doch unter Docker ggf. gemappt werden?
                            Für Docker haben wir eigene "Spezialisten". Evtl. können da @Glasfaser oder @Marc-Berg besser weiterhelfen.
                            Codierknecht Chriz 2 Replies Last reply Reply Quote 1
                            • Codierknecht
                              Codierknecht Developer Most Active @Samson71 last edited by
                              @samson71 sagte in Shelly Adapterinstanz bleibt gelb:
                              Betreibe das auf der Synology nur noch für eines meiner Testsysteme.
                              @Chriz
                              Betreibst Du den Container im Bridge-Mode? Wenn ja: Sind die benötigten Ports in den Container durchgereicht?
                              Chriz 1 Reply Last reply Reply Quote 2
                              • Chriz
                                Chriz @Samson71 last edited by
                                @samson71 said in Shelly Adapterinstanz bleibt gelb:
                                @chriz
                                Samson DU BIST DER BESTE und ich bin so ein Idiot!
                                Ich habe vergessen den Port zu mappen 😠
                                Sorry das ich euch alle bemühen musste, wegen diesem trivialen Thema 😞
                                • Chriz
                                  Chriz @Codierknecht last edited by Chriz
                                  @codierknecht
                                  Samsung hat ja bereits das gleiche geschrieben, das war tatsächlöich das Problem.
                                  Ist mir ein wenig peinlich.
                                  Am liebsten wäre mir, wir löschen den ganzen Thread 🙄
                                  Aber vielleicht vergisst es nochmal der ein oder andere und denkt dann daran.
                                  PS: Kann man aus den DIag Infos und Screenshots irgendwas rauslesen, was man besser nicht im Netz stehen haben sollte?
                                  Wenn ja, darf ich den inhalt der Diags und die Screenshots löschen, oder spricht da was gegen?
                                  • Codierknecht
                                    @chriz
                                    Hauptsache, das Problem konnte gelöst werden.
                                    Dazu ist ja das Forum da. Und wenn die Diskussion nur dazu dient, den Schubs in die richtige Richtung zu geben.
                                    Mein Produktivsystem hatte ich aus genau diesem Grund im Host-Mode betrieben.
                                    Solange keine Konflikte bzgl. Ports drohen, ist das wesentlich stressfreier.
                                    Ich sehe da nix verfängliches. Lass mal ruhig stehen.
                                    2283
