    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Shelly Adapterinstanz bleibt gelb
    • Chriz
      Chriz @haselchen last edited by Chriz
      @haselchen
      ua, tut mir Leid 🤦
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Hardware Vendor : To Be Filled By O.E.M.
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.1.1
      Virtualization  : Docker
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       18:06:16 up 60 days,  2:37,  0 user,  load average: 10.21, 9.20, 7.21
      CPU threads: 8
      *** Time and Time Zones ***
      Wed Feb 28 17:06:16 UTC 2024
      Wed Feb 28 18:06:16 CET 2024
      CET +0100
      Etc/UTC
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             12G        5.5G        306M        554M        7.6G        7.0G
      Swap:            10G        733M         10G
      Total:           23G        6.2G         10G
              11915 M total memory
               5260 M used memory
               3617 M active memory
               6264 M inactive memory
                292 M free memory
                  1 M buffer memory
               7202 M swap cache
              10239 M total swap
                699 M used swap
               9540 M free swap
      *** FILESYSTEM ***
      Filesystem     Type       Size  Used Avail Use% Mounted on
      /dev/loop2     btrfs       25G  7.0G   18G  29% /
      tmpfs          tmpfs       64M     0   64M   0% /dev
      shm            tmpfs       64M     0   64M   0% /dev/shm
      shfs           fuse.shfs  932G  267G  665G  29% /opt/iobroker
      /dev/loop2     btrfs       25G  7.0G   18G  29% /etc/hosts
      tmpfs          tmpfs      5.9G     0  5.9G   0% /proc/acpi
      tmpfs          tmpfs      5.9G     0  5.9G   0% /sys/firmware
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET             SOURCE        FSTYPE    OPTIONS
      /                  /dev/loop2[/btrfs/subvolumes/5322bd356013345d50636c8434e2e273c4ab5d4b4738c2d12790a6eb3c1c2d59]       btrfs     rw,noatime,ssd,space_cache=v2,subvolid=949,subvol=/btrfs/subvolumes/5322bd356013345d50636c8434e2e273c4ab5d4b4738c2d12790a6eb3c1c2d59
      |-/opt/iobroker    shfs[/appdata/iobroker/data]        fuse.shfs rw,nosuid,nodev,noatime,user_id=0,group_id=0,default_permissions,allow_other
      |-/opt/userscripts shfs[/appdata/iobroker/scripts]        fuse.shfs rw,nosuid,nodev,noatime,user_id=0,group_id=0,default_permissions,allow_other
      |-/etc/resolv.conf /dev/loop2[/containers/22646d536096c5b460e9e9871d278aeec6ba4c324f924b103e2617abcc5650f9/resolv.conf] btrfs     rw,noatime,ssd,space_cache=v2,subvolid=5,subvol=/
      |-/etc/hostname    /dev/loop2[/containers/22646d536096c5b460e9e9871d278aeec6ba4c324f924b103e2617abcc5650f9/hostname]    btrfs     rw,noatime,ssd,space_cache=v2,subvolid=5,subvol=/
      `-/etc/hosts       /dev/loop2[/containers/22646d536096c5b460e9e9871d278aeec6ba4c324f924b103e2617abcc5650f9/hosts]       btrfs     rw,noatime,ssd,space_cache=v2,subvolid=5,subvol=/
      /var:
      34M     /var/
      32M     /var/lib
      19M     /var/lib/apt/lists
      19M     /var/lib/apt
      13M     /var/lib/dpkg
      /opt/iobroker/backups:
      9.6M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      403M    /opt/iobroker/iobroker-data/
      199M    /opt/iobroker/iobroker-data/files
      128M    /opt/iobroker/iobroker-data/backup-objects
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      43M     /opt/iobroker/iobroker-data/files/iot.admin
      33M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      15M     /opt/iobroker/iobroker-data/states.jsonl
      13M     /opt/iobroker/iobroker-data/objects.json.migrated
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_3a866a46ae89eb118f103dc07d11dc1e-if00-port0
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_de4ef275ea5fec118396325f25bfaa52-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.1
      /usr/bin/node           v18.19.1
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.1-1nodesource1
        Candidate: 18.19.1-1nodesource1
        Version table:
       *** 18.19.1-1nodesource1 1001
             1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : 22646d536096                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : 22646d536096                             -  enabled
      + system.adapter.backitup.0               : backitup              : 22646d536096                             -  enabled
      + system.adapter.denon.0                  : denon                 : 22646d536096                             -  enabled
      + system.adapter.discovery.0              : discovery             : 22646d536096                             -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : 22646d536096                             -  enabled
      + system.adapter.influxdb.0               : influxdb              : 22646d536096                             -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : 22646d536096                             -  enabled
      + system.adapter.iot.0                    : iot                   : 22646d536096                             -  enabled
      + system.adapter.javascript.0             : javascript            : 22646d536096                             -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : 22646d536096                             -  enabled
      + system.adapter.loxone.0                 : loxone                : 22646d536096                             -  enabled, port: 80
      + system.adapter.luxtronik2.0             : luxtronik2            : 22646d536096                             -  enabled, port: 8214
      + system.adapter.mqtt.0                   : mqtt                  : 22646d536096                             -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.nuki-extended.0          : nuki-extended         : 22646d536096                             -  enabled
      + system.adapter.octoprint.0              : octoprint             : 22646d536096                             -  enabled
      + system.adapter.shelly.0                 : shelly                : 22646d536096                             -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.signal-cmb.0             : signal-cmb            : 22646d536096                             -  enabled
      + system.adapter.simple-api.0             : simple-api            : 22646d536096                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : 22646d536096                             -  enabled
      + system.adapter.tr-064.0                 : tr-064                : 22646d536096                             -  enabled
        system.adapter.vis-history.0            : vis-history           : 22646d536096                             -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : 22646d536096                             -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : 22646d536096                             -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : 22646d536096                             -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : 22646d536096                             -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : 22646d536096                             -  enabled
        system.adapter.vis-metro.0              : vis-metro             : 22646d536096                             -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : 22646d536096                             -  enabled
        system.adapter.vis-weather.0            : vis-weather           : 22646d536096                             -  enabled
        system.adapter.vis.0                    : vis                   : 22646d536096                             -  enabled
        system.adapter.vw-connect.1             : vw-connect            : 22646d536096                             - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : 22646d536096                             -  enabled
      + system.adapter.web.0                    : web                   : 22646d536096                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : 22646d536096                             -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_de4ef275ea5fec118396325f25bfaa52-if00-port0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "denon"        : 1.15.5   , installed 1.15.5
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
      Adapter    "loxone"       : 3.0.1    , installed 3.0.1
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
      Adapter    "ring"         : 5.0.10   , installed 5.0.10
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Objects and States
      Objects:        15099
      States:         15252
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      99         538520712  -
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      99         538521626  -
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      99         538524912  -
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      99         538678861  -
      tcp6       0      0 :::8082                 :::*                    LISTEN      99         538556277  -
      tcp6       0      0 :::8081                 :::*                    LISTEN      99         538520745  -
      tcp6       0      0 :::8087                 :::*                    LISTEN      99         538559721  -
      2024-02-28 17:54:19.665  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 17:54:50.675  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 17:55:21.671  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 17:55:52.663  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 17:56:23.667  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 17:56:54.668  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 17:57:25.667  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 17:57:56.666  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 17:58:27.664  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 17:58:58.706  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 17:59:29.667  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 18:00:00.676  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 18:00:31.662  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 18:01:02.663  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 18:01:33.674  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 18:02:04.658  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 18:02:35.658  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 18:03:06.657  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 18:03:37.662  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 18:04:08.656  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 18:04:39.654  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 18:05:10.672  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 18:05:41.654  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 18:06:12.654  - info: smartmeter.0 (321) Received 9 values, 6 updated
      2024-02-28 18:06:43.657  - info: smartmeter.0 (321) Received 9 values, 6 updated
      ich hoffe da steht nix drin, was nicht im Netz stehen sollte 😕
      melde mich morgen wieder dazu, muss leider noch weg, jetzt.
      Schonmal jetzt vielen Dank an euch, ich hoffe ich kann morgenw ieder auf euch zählen 🙂
      • DJMarc75
        DJMarc75 @Chriz last edited by
        @chriz
        User ROOT schonmal mehr als falsch 😉
        @chriz sagte in Shelly Adapterinstanz bleibt gelb:
        heiliges Blechle 🤕
        Da läuft was mehr als aus dem Ruder
        Chriz 1 Reply Last reply Reply Quote 0
        • Chriz
          Chriz @DJMarc75 last edited by
          @djmarc75
          Was ist denn falsch bzw. schlimm?
          • DJMarc75
            Na wie geschrieben meldet man sich nicht als root auf der Kiste an sondern mit einem gescheiten User 😉
            Dann sind die loads über dem Limit, bei 8 Kernen. Laufen da vll ein paar Skripte bei Dir Amok ?
            iob fix
            auch mal machen.
            • Chriz
              Chriz @DJMarc75 last edited by Chriz
              @djmarc75
              Wieso nicht als root anmelden?
              Läuft bei mir seit Jahren so ohne Probleme..
              Um ehrlich zu sein wüsste ich nicht mal das ich mich überhaupt irgendwo anmelden müsste... 😕
              Scripte habe ich 3 Stück wovon eines nur läuft. Und das macht nix weiter als eine Nachricht zu schicken wenn sich ein bestimmter Datenpunkt verändert. Passiert aber nur alle paar Monate mal.
              Mein System ist eigentlich gar nicht ausgelastet. CPU Auslastung liegt immer zwischen 20 und 50%, je nachdem was gerade an Surveillance so codiert wird...
              Magst du mir mal erklären woher deine Annahme kommt? Ich verstehe die Werte nicht die du da geschrieben hast. 😢
              • Codierknecht
                Codierknecht Developer Most Active @Chriz last edited by
                Weil man ja auch keine Dampframme nimmt, um einen Nagel in die Wand zu schlagen.
                Der User root hat viel zu viele Rechte. Da hat man schneller was verbogen als einem lieb ist.
                Auf einem vernünftig aufgesetzten System darf root sich nicht mal in der Konsole anmelden.
                Chriz Homoran 2 Replies Last reply Reply Quote 0
                • Chriz
                  Chriz @Codierknecht last edited by
                  @codierknecht
                  okay verstehe.
                  Bei mir läuft das alles aber seit Jahren so und da ist nie was "schlimmes" passiert.
                  Ich gehe davon aus, das jetzt zu ändern würde zu sehr vielen Anpassungen im System führen.
                  Wie gesagt ich wüsste auch nicht mal wie man sowas ändert.
                  Als Programmierlaie würde ich erwarten das man beim ersten Systemstart auf sowas hingewiesen wird.
                  Vielleicht habt ihr ja ein kleines laienverständliches Tutorial was ich mir bei Gelegenheit mal angucken kann?
                  Aber zurück zum Problem, hat noch jemand eine Ahnung was mit dem Adapter sein kann?
                    Homoran Global Moderator Administrators @Codierknecht last edited by
                    @codierknecht
                    Installation: Docker
                    Chriz Codierknecht 2 Replies Last reply Reply Quote 1
                    • Chriz
                      Chriz @Homoran last edited by
                      ich vermute dein Quote bedeutet, das im Dockercontainer alles unter root läuft?
                      Hatte sowas ähnliches im Sinn, aber hab mich nicht getraut das zu erwähnen, da ich da leider zu wenig Ahnung von habe.
                      Aber das mit dem Adapter kann da nicht dran liegen?
                      Ich vermute es hat was mit dem Shelly zu tun das der Adapter nicht grün wird.
                      Er findet halt keine Geräte, obwohl das Log ja zeigt das er "zuhört" (listening)...
                      Kann ich irgendwie überprüfen ob mein Shelly kommuniziert?
                      • Codierknecht
                        Codierknecht Developer Most Active @Homoran last edited by
                        @homoran sagte in Shelly Adapterinstanz bleibt gelb:
                        Glatt überlesen 😞
                        Ob das unter Docker grundsätzlich so ist, kann ich nicht sagen.
                        Falls das auf einer Synology läuft, hast Du Recht. Da geht das gar nicht anders.
                        @Chriz Welche Hardware läuft da?
                        • Samson71
                          Samson71 Global Moderator @Chriz last edited by
                          @chriz
                          Bei Docker bin ich auch weitestgehend raus, aber passen die Ports? Die müssen doch unter Docker ggf. gemappt werden?
                          Für Docker haben wir eigene "Spezialisten". Evtl. können da @Glasfaser oder @Marc-Berg besser weiterhelfen.
                          Codierknecht Chriz 2 Replies Last reply Reply Quote 1
                          • Codierknecht
                            Codierknecht Developer Most Active @Samson71 last edited by
                            @samson71 sagte in Shelly Adapterinstanz bleibt gelb:
                            Betreibe das auf der Synology nur noch für eines meiner Testsysteme.
                            @Chriz
                            Betreibst Du den Container im Bridge-Mode? Wenn ja: Sind die benötigten Ports in den Container durchgereicht?
                            Chriz 1 Reply Last reply Reply Quote 2
                            • Chriz
                              Chriz @Samson71 last edited by
                              @samson71 said in Shelly Adapterinstanz bleibt gelb:
                              @chriz
                              Samson DU BIST DER BESTE und ich bin so ein Idiot!
                              Ich habe vergessen den Port zu mappen 😠
                              Sorry das ich euch alle bemühen musste, wegen diesem trivialen Thema 😞
                              • Chriz
                                Chriz @Codierknecht last edited by Chriz
                                @codierknecht
                                Samsung hat ja bereits das gleiche geschrieben, das war tatsächlöich das Problem.
                                Ist mir ein wenig peinlich.
                                Am liebsten wäre mir, wir löschen den ganzen Thread 🙄
                                Aber vielleicht vergisst es nochmal der ein oder andere und denkt dann daran.
                                PS: Kann man aus den DIag Infos und Screenshots irgendwas rauslesen, was man besser nicht im Netz stehen haben sollte?
                                Wenn ja, darf ich den inhalt der Diags und die Screenshots löschen, oder spricht da was gegen?
                                • Codierknecht
                                  @chriz
                                  Hauptsache, das Problem konnte gelöst werden.
                                  Dazu ist ja das Forum da. Und wenn die Diskussion nur dazu dient, den Schubs in die richtige Richtung zu geben.
                                  Mein Produktivsystem hatte ich aus genau diesem Grund im Host-Mode betrieben.
                                  Solange keine Konflikte bzgl. Ports drohen, ist das wesentlich stressfreier.
                                  Ich sehe da nix verfängliches. Lass mal ruhig stehen.
                                  2283
