    3. Einsteigerfragen
    4. Speicherverbrauch durch im Admin UI aufgeblähte Objekte
      A Former User @Homoran last edited by
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: xs35v3l
             Icon name: computer-desktop
               Chassis: desktop 🖥️
                Kernel: Linux 6.1.0-18-amd64
          Architecture: x86-64
       Hardware Vendor: Intel Corporation
        Hardware Model: NUC7CJYH
      Firmware Version: JYGLKCPX.86A.0071.2023.0825.1034
      model name      : Intel(R) Celeron(R) J4005 CPU @ 2.00GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       20:48:21 up  1:14,  3 users,  load average: 0.08, 0.13, 0.17
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Thu 2024-02-29 20:48:21 CET
                 Universal time: Thu 2024-02-29 19:48:21 UTC
                       RTC time: Thu 2024-02-29 19:48:21
                    NTP service: n/a
                RTC in local TZ: no
      *** User and Groups ***
      thomas
      /home/thomas
      thomas cdrom floppy sudo audio dip video plugdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.7G        3.3G        126M        1.9M        454M        382M
      Swap:           4.3G        2.1G        2.2G
      Total:          8.0G        5.4G        2.3G
               3498 M total memory
               3134 M used memory
               1591 M active memory
               1494 M inactive memory
                121 M free memory
                 39 M buffer memory
                393 M swap cache
               4095 M total swap
               2002 M used swap
               2093 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                  Type      Size  Used Avail Use% Mounted on
      udev                        devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs                       tmpfs     350M  2.5M  348M   1% /run
      /dev/sda2                   ext4      289G   61G  214G  22% /
      tmpfs                       tmpfs     1.8G     0  1.8G   0% /dev/shm
      tmpfs                       tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/sda1                   vfat      487M  148K  486M   1% /boot/efi
      tmpfs                       tmpfs     350M     0  350M   0% /run/user/0
      tmpfs                       tmpfs     350M     0  350M   0% /run/user/1000
      [Thu Feb 29 19:34:17 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Thu Feb 29 19:34:18 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET              SOURCE                      FSTYPE OPTIONS
      /                   /dev/sda2                   ext4   rw,relatime,errors=remount-ro
      |-/boot/efi         /dev/sda1                   vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      /var:
      12G     /var/
      5.4G    /var/cache/apt
      5.4G    /var/cache
      5.3G    /var/cache/apt/archives
      4.3G    /var/log
      Archived and active journals take up 153.3M in the file system.
      /opt/iobroker/backups:
      7.7M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      243M    /opt/iobroker/iobroker-data/
      102M    /opt/iobroker/iobroker-data/files
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      40M     /opt/iobroker/iobroker-data/backup-objects
      38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      101M    /opt/iobroker/iobroker-data/objects.jsonl
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
      8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI04GXWR-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.1
      /usr/bin/node           v18.19.1
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.1-1nodesource1
        Candidate: 18.19.1-1nodesource1
        Version table:
       *** 18.19.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security stable-security/main amd64 Packages
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian stable/main amd64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : xs35v3l                                  -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.backitup.0               : backitup              : xs35v3l                                  -  enabled
      + system.adapter.discovery.0              : discovery             : xs35v3l                                  -  enabled
        system.adapter.history.0                : history               : xs35v3l                                  - disabled
      + system.adapter.javascript.0             : javascript            : xs35v3l                                  -  enabled
        system.adapter.modbus.0                 : modbus                : xs35v3l                                  - disabled
      + system.adapter.openknx.0                : openknx               : xs35v3l                                  -  enabled
      + system.adapter.rest-api.0               : rest-api              : xs35v3l                                  -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
        system.adapter.sql.0                    : sql                   : xs35v3l                                  - disabled, port: 3306
      + system.adapter.tuya.0                   : tuya                  : xs35v3l                                  -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "openknx"      : 0.6.3    , installed 0.6.3
      Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Objects and States
      Objects:        1179
      States:         673
      W: http://ppa.launchpad.net/linuxuprising/java/ubuntu/dists/bionic/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      W: http://ppa.launchpad.net/webupd8team/java/ubuntu/dists/disco/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      Hit:1 http://ppa.launchpad.net/linuxuprising/java/ubuntu bionic InRelease
      Hit:2 http://deb.debian.org/debian stable InRelease
      Hit:3 http://ppa.launchpad.net/webupd8team/java/ubuntu disco InRelease
      Hit:4 http://deb.debian.org/debian-security stable-security InRelease
      Hit:5 http://deb.debian.org/debian stable-updates InRelease
      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8084            0.0.0.0:*               LISTEN      0          20283      782/perl
      tcp        0      0 0.0.0.0:38801           0.0.0.0:*               LISTEN      0          19824      792/rpc.mountd
      tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN      0          20282      782/perl
      tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          28808      1046/perl
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          47715      1510/exim4
      tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      106        18092      914/mariadbd
      tcp        0      0 0.0.0.0:1234            0.0.0.0:*               LISTEN      0          20284      782/perl
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       46415      757/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       47792      757/iobroker.js-con
      tcp        0      0 0.0.0.0:34177           0.0.0.0:*               LISTEN      0          19805      792/rpc.mountd
      tcp        0      0 0.0.0.0:44335           0.0.0.0:*               LISTEN      0          19913      -
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          45343      1090/smbd
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2020       1/init
      tcp        0      0 127.0.0.1:1883          0.0.0.0:*               LISTEN      114        17988      772/mosquitto
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17999      801/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          19895      -
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          45342      1090/smbd
      tcp        0      0 0.0.0.0:53597           0.0.0.0:*               LISTEN      102        17973      795/rpc.statd
      tcp        0      0 0.0.0.0:35079           0.0.0.0:*               LISTEN      0          19816      792/rpc.mountd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1002       46849      1544/io.admin.0
      tcp6       0      0 :::8080                 :::*                    LISTEN      0          47541      1262/apache2
      tcp6       0      0 :::8093                 :::*                    LISTEN      1002       47021      1687/io.rest-api.0
      tcp6       0      0 :::53001                :::*                    LISTEN      0          19812      792/rpc.mountd
      tcp6       0      0 ::1:1883                :::*                    LISTEN      114        17989      772/mosquitto
      tcp6       0      0 :::35919                :::*                    LISTEN      0          19916      -
      tcp6       0      0 :::35881                :::*                    LISTEN      0          19828      792/rpc.mountd
      tcp6       0      0 :::58705                :::*                    LISTEN      0          19820      792/rpc.mountd
      tcp6       0      0 :::6720                 :::*                    LISTEN      0          19491      1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          47716      1510/exim4
      tcp6       0      0 :::139                  :::*                    LISTEN      0          45341      1090/smbd
      tcp6       0      0 :::111                  :::*                    LISTEN      0          2022       1/init
      tcp6       0      0 :::80                   :::*                    LISTEN      0          47537      1262/apache2
      tcp6       0      0 :::22                   :::*                    LISTEN      0          18010      801/sshd: /usr/sbin
      tcp6       0      0 :::2049                 :::*                    LISTEN      0          19905      -
      tcp6       0      0 :::445                  :::*                    LISTEN      0          45340      1090/smbd
      tcp6       0      0 :::443                  :::*                    LISTEN      0          47545      1262/apache2
      tcp6       0      0 :::37181                :::*                    LISTEN      102        17979      795/rpc.statd
      udp        0      0 0.0.0.0:3671            0.0.0.0:*                           113        46367      1513/knxd
      udp        0      0 192.168.2.189:44740     0.0.0.0:*                           113        46370      1513/knxd
      udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          28809      1046/perl
      udp        0      0 0.0.0.0:57161           0.0.0.0:*                           0          19803      792/rpc.mountd
      udp        0      0 127.0.0.1:61340         0.0.0.0:*                           0          45296      782/perl
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17803      685/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2021       1/init
      udp        0      0 192.168.2.189:123       0.0.0.0:*                           0          40808      1140/ntpd
      udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          40806      1140/ntpd
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          40802      1140/ntpd
      udp        0      0 192.168.2.255:137       0.0.0.0:*                           0          40705      929/nmbd
      udp        0      0 192.168.2.189:137       0.0.0.0:*                           0          40704      929/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          20041      929/nmbd
      udp        0      0 192.168.2.255:138       0.0.0.0:*                           0          40707      929/nmbd
      udp        0      0 192.168.2.189:138       0.0.0.0:*                           0          40706      929/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          20042      929/nmbd
      udp        0      0 0.0.0.0:32960           0.0.0.0:*                           1002       48234      1634/io.openknx.0
      udp        0      0 0.0.0.0:49352           0.0.0.0:*                           0          45298      782/perl
      udp        0      0 0.0.0.0:55654           0.0.0.0:*                           102        17970      795/rpc.statd
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1002       48273      1645/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1002       48274      1645/io.tuya.0
      udp        0      0 0.0.0.0:57913           0.0.0.0:*                           0          19911      -
      udp        0      0 0.0.0.0:52054           0.0.0.0:*                           0          19822      792/rpc.mountd
      udp        0      0 127.0.0.1:971           0.0.0.0:*                           0          19851      795/rpc.statd
      udp        0      0 0.0.0.0:38168           0.0.0.0:*                           0          19814      792/rpc.mountd
      udp6       0      0 :::40608                :::*                                0          19807      792/rpc.mountd
      udp6       0      0 :::111                  :::*                                0          2023       1/init
      udp6       0      0 2003:ee:1f0c:8d00:9:123 :::*                                116        46295      1140/ntpd
      udp6       0      0 fe80::96c6:91ff:fe1:123 :::*                                0          40814      1140/ntpd
      udp6       0      0 ::1:123                 :::*                                0          40810      1140/ntpd
      udp6       0      0 :::123                  :::*                                0          40799      1140/ntpd
      udp6       0      0 :::35648                :::*                                0          19818      792/rpc.mountd
      udp6       0      0 :::37778                :::*                                0          19914      -
      udp6       0      0 :::40054                :::*                                0          19826      792/rpc.mountd
      udp6       0      0 :::40329                :::*                                102        17976      795/rpc.statd
      2024-02-29 19:35:01.500  - info: openknx.0 (1634) Connected!
      2024-02-29 19:35:01.728  - info: openknx.0 (1634) Found 802 valid KNX objects of 805 objects in adapter.
      2024-02-29 19:35:02.097  - info: discovery.0 (1661) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.1, js-controller: 5.0.19
      2024-02-29 19:35:01.343  - info: tuya.0 (1645) Existing devices initialized
      2024-02-29 19:35:01.362  - info: tuya.0 (1645) Try to sync devices from Cloud using stored cloud credentials
      2024-02-29 19:35:02.318  - info: tuya.0 (1645) Listen for local Tuya devices on port 6666
      2024-02-29 19:35:02.319  - info: tuya.0 (1645) Listen for encrypted local Tuya devices on port 6667
      2024-02-29 19:35:02.762  - info: tuya.0 (1645) IOT Cloud ID/Secret not configured, disabling real time State updates from Cloud MQTT
      2024-02-29 19:35:02.962  - warn: host.xs35v3l Your system has only 75 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
      2024-02-29 19:35:03.034  - info: host.xs35v3l instance system.adapter.rest-api.0 started with pid 1687
      2024-02-29 19:35:03.497  - info: tuya.0 (1645) bffdb60b394a5e22davhuk: Connect locally to device
      2024-02-29 19:35:06.888  - info: javascript.0 (1563) requesting all states
      2024-02-29 19:35:06.906  - info: javascript.0 (1563) requesting all objects
      2024-02-29 19:35:19.873  - info: rest-api.0 (1687) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.rest-api, node: v18.19.1, js-controller: 5.0.19
      2024-02-29 19:35:20.488  - info: admin.0 (1544) Repository received successfully.
      2024-02-29 19:35:21.629  - warn: rest-api.0 (1687) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
      2024-02-29 19:35:21.655  - info: rest-api.0 (1687) http server listening on port 8093
      2024-02-29 19:35:28.711  - info: javascript.0 (1563) received all states
      2024-02-29 19:35:38.795  - info: javascript.0 (1563) received all objects
      2024-02-29 19:35:38.972  - info: javascript.0 (1563) script.js.externe_Parameter.openwb: compiling TypeScript source...
      2024-02-29 19:35:39.052  - info: javascript.0 (1563) script.js.externe_Parameter.openwb: source code did not change, using cached compilation result...
      2024-02-29 19:35:39.230  - info: javascript.0 (1563) script.js.externe_Parameter.openwb: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
      2024-02-29 19:35:39.238  - info: javascript.0 (1563) script.js.externe_Parameter.Solaredge_Converter: compiling TypeScript source...
      2024-02-29 19:35:39.247  - info: javascript.0 (1563) script.js.externe_Parameter.Solaredge_Converter: source code did not change, using cached compilation result...
      2024-02-29 19:35:39.253  - info: javascript.0 (1563) script.js.externe_Parameter.Solaredge_Converter: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      ? Homoran 2 Replies Last reply Reply Quote 0
        A Former User @Guest last edited by
        hier die ersten Zeilen von TOP.
                PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
                782 root      20   0  123008  45424   9100 S   3,7   1,3   1:57.81 perl
                757 iobroker  20   0   11,9g 873700  18004 S   0,7  24,4   1:10.28 iobroker.js-con
                365 root      20   0       0      0      0 I   0,3   0,0   0:05.54 kworker/1:2-events
               1339 www-data  20   0  271196  15248  12372 S   0,3   0,4   0:00.26 apache2
               1563 iobroker  20   0 1790840 762564  19208 S   0,3  21,3   0:50.54 io.javascript.0
               3106 root      20   0   13840   6452   3992 R   0,3   0,2   0:00.05 top
                  1 root      20   0  168268   8636   6348 S   0,0   0,2   0:01.27 systemd
        • Samson71
          Samson71 Global Moderator @Homoran last edited by
          @homoran sagte in Hardware Voraussetzungen bzw. Speicherverbrauch iobroker:
          @thomas_ sagte in Hardware Voraussetzungen bzw. Speicherverbrauch iobroker:
          So einer liegt hier auch noch rum. Den habe ich vor Jahren schon aussortiert.
            Homoran Global Moderator Administrators @Guest last edited by
            @thomas_ frisch gestartet?
            und wirklich nichts mehr frei?
            Da wäre top jetzt noch interessanter
              wenn's um Mem geht bitte auch danach sortieren
              und vor allem den Header zeigen
                @homoran das TOP ist von jetzt und er ist vor 2 Stunden neu gestartet. Das Bild ist immer das selbe.
                Schau her:
                thomas@xs35v3l:~$ free -m
                              gesamt       benutzt     frei      gemns.  Puffer/Cache verfügbar
                Speicher:       3498        2628         664           1         441         869
                Swap:           4095        2463        1632
                thomas@xs35v3l:~$ iob stop
                Speicher:       3498         686        2605           1         442        2812
                Swap:           4095         489        3606
                thomas@xs35v3l:~$ iob start
                Speicher:       3498        1321        1866           1         545        2177
                Swap:           4095         489        3606
                Speicher:       3498        1581        1607           1         545        1917
                Swap:           4095         489        3606
                Speicher:       3498        1646        1538           1         548        1852
                Swap:           4095         489        3606
                Speicher:       3498        1727        1452           1         553        1770
                Swap:           4095         489        3606
                Speicher:       3498        2002        1177           1         553        1495
                Swap:           4095         489        3606
                Speicher:       3498        2129        1050           1         553        1369
                Swap:           4095         489        3606
                Speicher:       3498        2341         833           1         558        1157
                Swap:           4095         489        3606
                Speicher:       3498        2466         695           1         573        1032
                Swap:           4095         489        3606
                Speicher:       3498        2594         564           1         575         904
                Swap:           4095         489        3606
                Speicher:       3498        2698         458           1         578         800
                Swap:           4095         489        3606
                thomas@xs35v3l:~$
                  Homoran Global Moderator Administrators @Guest last edited by Homoran
                  Schau her:
                  das ist aber nicht der Header von top
                  und der RAM Verbrauch je Prozess ist da auch nicht zu sehen.
                  wenn sich schon controller + js adapter fast die Hälfte des RAM schnappen und auch der SWAP deutlich in Gebrauch ist, klemmt es
                  jetzt ist aber reichlich verfügbar in der diag waren es nur noch 3xxMB
                    paul53 @Guest last edited by paul53
                    @thomas_ sagte: ich habe 1181 Objekte...
                    Über 1,5 GB für die Javascript-Instanz: Da läuft offenbar mind. ein Skript Amok.
                    ? 2 Replies Last reply Reply Quote 1
                      A Former User @paul53 last edited by A Former User
                      Es hüpft jetzt auf einmal ständig hin und her.
                      1,5 GB admin, dann 600 MB
                      javascript 40 MB, dann 1,5GB.
                      Die anderen sehen vernünftig aus.
                      Die Javascripte sind nur zwei:
                      Das erste liest alle 5 Minuten eine URL aus, die eine Zahl ausspuckt und schreibt die Zahl auf den KNX Bus
                      Das zweite hat 5 ON-Events drin, aus dem Modus und würde auch die ins KNX schreiben, aber der Modbus Adapter ist ja deaktiviert - das tut also gar nichts
                      edit: das funktioniert auch alles, ich habe die history der objekte geprüft. da kommt nichts an. nicht, dass ihr denkt, meine skripte schreiben halt alle 2 ms nen neuen wert oder sowas ^^
                         7463 iobroker  20   0 1916916   1,1g  14768 S   1,0  31,5   0:40.20 iobroker.js-con
                         7504 iobroker  20   0 1383092 719332  14380 R 127,8  20,1   0:17.72 io.javascript.0
                          914 mysql     20   0 1887640 227456   9096 S   0,0   6,3   5:30.09 mariadbd
                         7589 iobroker  20   0   10,7g 143904  19692 S   0,0   4,0   0:03.89 io.rest-api.0
                         7488 iobroker  20   0 1759200 143072  10928 S   0,0   4,0   0:10.89 io.admin.0
                         7549 iobroker  20   0 1009312 137884  11872 S   0,0   3,8   0:02.40 io.tuya.0
                        jetzt hat es sich eingependelt
                               7488 iobroker  20   0 1723044 834036  22436 S   0,0  23,3   0:28.68 io.admin.0
                               7463 iobroker  20   0 1742872 822992  15616 S   0,7  23,0   0:52.81 iobroker.js-con
                               7504 iobroker  20   0 1744268 773680  19448 S   0,0  21,6   0:49.13 io.javascript.0
                                914 mysql     20   0 1822104 131300  11336 S   0,0   3,7   5:32.98 mariadbd
                               7549 iobroker  20   0  975860  61388  14352 S   0,0   1,7   0:03.06 io.tuya.0
                               7589 iobroker  20   0   10,7g  58580  12752 S   0,0   1,6   0:04.53 io.rest-api.0
                               7548 iobroker  20   0  690040  50564  15384 S   0,3   1,4   0:05.85 io.openknx.0
                                932 root      20   0 3538940  38364  12912 S   0,0   1,1   0:25.76 java
                                782 root      20   0  125268  37644   7940 S   4,0   1,1   3:47.61 perl
                               7570 iobroker  20   0  679596  34368  12472 S   0,0   1,0   0:01.87 io.discovery.0
                          @thomas_ das sieht dann wirklich nach einem amoklaufenden Skript aus, dass wahrscheinlich zeitgesteuert startet
                            iobroker neu gestartet mit deaktivierten Skripten.
                            Ergebnis:
                               7904 iobroker  20   0 1484584 878440  15504 S   0,0  24,5   0:10.88 io.javascript.0
                               7859 iobroker  20   0 1884872 846588  15236 D  30,5  23,6   0:29.92 iobroker.js-con
                               7882 iobroker  20   0 1766296 745928  15296 S   0,0  20,8   0:10.92 io.admin.0
                               7940 iobroker  20   0 1009412 154080  15332 S   0,0   4,3   0:02.13 io.tuya.0
                               7994 iobroker  20   0   10,7g 129052  23408 S   0,0   3,6   0:02.66 node
                              Wieso stehen denn da 103 Eingabewerte ganz ohne Skripte?
                                passt!
                                in ein, zwei Minuten sollte es weniger sein.
                                  @thomas_ weil der Adapter gerade alle states abonniert
                                  aber 1,3 GB RAM kommt mir etwas viel vor
                                    A Former User @Homoran last edited by A Former User
                                    ja, mir ja auch ^^
                                    und weniger als 700 MB werden es nicht:
                                      Jetzt hab ich es mal zum Test auf einem anderen debian Server installiert, der mehr RAM hat, aber der Verbrauch ist ja genau der gleiche:
                                      2347370 	iobroker 	819.41 MiB 	io.admin.0
                                      2347431 	iobroker 	76.58 MiB 	io.backitup.0
                                      2351527 	iobroker 	865.33 MiB 	io.javascript.0
                                      2351574 	iobroker 	76.55 MiB 	io.openknx.0
                                      2347340 	iobroker 	1.42 GiB 	iobroker.js-controller
                                      Dann scheint das wohl so normal zu sein?
                                      • Marc Berg
                                        Marc Berg Most Active @Guest last edited by
                                        @thomas_
                                        Nein. Ich habe ca. die zehnfache Anzahl der Objekte, bei nur ca. einem Zehntel Speicherverbrauch.
                                        Wie sieht der Speicher bei frisch installiertem ioBroker aus?
                                        ? MartinP 2 Replies Last reply Reply Quote 0
                                          A Former User @Marc Berg last edited by
                                          @marc-berg das ist beides ein frisch installierter iobroker 🤷‍♂️
                                          Der erste, kleinere PC, 4-5 Tage alt.
                                          Bei dem zweiten Server habe ich im Prinzip nur die Objekte importiert. Aber sonst hab ich ja eh nichts am Laufen... CPU Auslastung ist ja auch Null.
                                            nein!
                                            da sind schon weitere Adapter installiert und aktiv
                                            ? 1 Reply Last reply Reply Quote 1
                                            4567
