    4. Test Adapter Zendure Solarflow
      lesiflo Most Active last edited by
      hier der Blockly-Code für die Umrechnung in kWh
        <variables>
          <variable id="gn:HU~SCGvnqbRCRMSCy">Neustart</variable>
          <variable id="H`8%Q[C];S#Po%f%^,*[">energie</variable>
          <variable id="B].n@]e_d8kNxs]d-Ky|">Laden_Akku</variable>
          <variable id="Ua?)Az%)A;%j}Z?Y(@qh">Entladen_Akku</variable>
          <variable id="rNmt]Ylyn6~w3v(K59#b">Abgabe_Haus</variable>
          <variable id="6-EW?O6)X$_9j`r)iuXZ">energie_start</variable>
        </variables>
        <block type="comment" id="j2:aNxn%Er`8Q_}@!!P$" x="488" y="1388">
          <field name="COMMENT">Reset Tageswerte</field>
            <block type="schedule" id="]L}6=Uyw4CKieYA8qo*{">
              <field name="SCHEDULE">2 0 * * *</field>
                <block type="control" id="wO]+tfPu:O]@8vg4)@^w">
                  <field name="OID">0_userdata.0.Eigene_Variablen.PV.Solarflow.packInputPower_kWh</field>
                    <block type="math_number" id="0-8b%VD~nqwRqI#LWXFs">
                      <field name="NUM">0</field>
                    <block type="control" id=":Xx0TE*B2+5{)MCyETx9">
                      <field name="OID">0_userdata.0.Eigene_Variablen.PV.Solarflow.outputPackPower_kWh</field>
                        <block type="math_number" id="%F@$?A{uLGsZVc@9nVkI">
                        <block type="control" id="!Ssd`Ac.tsL+mEscm.y!">
                          <field name="OID">0_userdata.0.Eigene_Variablen.PV.Solarflow.solarInputPower_kWh</field>
                            <block type="math_number" id="B.yO.QUgA{;$4X?-g8,h">
                            <block type="control" id="EW#t.vr$F-%Xm}DI79r$">
                              <field name="OID">0_userdata.0.Eigene_Variablen.PV.Solarflow.outputHomePower_kWh</field>
                                <block type="math_number" id=")~K]8GK6@)ZJoFk(PTjL">
                                <block type="variables_set" id="RfP%gUCE_#E^hZzbQAYj">
                                  <field name="VAR" id="H`8%Q[C];S#Po%f%^,*[">energie</field>
                                    <block type="get_object" id="fhJ-zn1s(d8_~@ror)Ga">
                                    <block type="variables_set" id="gw70B~d](MZS^tlJL$ZE">
                                      <field name="VAR" id="B].n@]e_d8kNxs]d-Ky|">Laden_Akku</field>
                                        <block type="get_object" id="nvgxO+GU:/NYyfGjd(T7">
                                        <block type="variables_set" id="(HL3sW/GTkqUWTykp!IY">
                                          <field name="VAR" id="Ua?)Az%)A;%j}Z?Y(@qh">Entladen_Akku</field>
                                            <block type="get_object" id="k8M@bC*%_F78uSqVwepP">
                                            <block type="variables_set" id=".j`=}xOL2?JBtSp_b6LK">
                                              <field name="VAR" id="rNmt]Ylyn6~w3v(K59#b">Abgabe_Haus</field>
                                                <block type="get_object" id="c[)j_kHXIV/jwf7+(%gs">
                <block type="variables_set" id="A.e$V`ynjg0#}qJnFF)w">
                  <field name="VAR" id="gn:HU~SCGvnqbRCRMSCy">Neustart</field>
                    <block type="logic_boolean" id="9Lm!l6t-vOXOddA~3mJg">
                    <block type="comment" id="RV+eO`6:RC~uyK=4f_nx">
                      <field name="COMMENT">Produktion PV</field>
                        <block type="variables_set" id="AgB0uh?CsFR}.}ii/]lj">
                            <block type="get_object" id="LHEv}In-fr%NySNK.%#/">
                            <block type="on_ext" id="TZZI45[#ikP]~r)[F#^K">
                              <value name="OID0">
                                <shadow type="field_oid" id="FYq7rQr_UY1$l*O%mT96">
                                  <field name="oid">zendure-solarflow.0.73bkTV.7rk1nVD9.solarInputPower</field>
                                <block type="controls_if" id="9ONCtcSN=;/2qz9[DzO~">
                                    <block type="logic_compare" id="4EEJBi[?ILa5iGd=EP**">
                                      <field name="OP">GT</field>
                                        <block type="on_source" id="^t~l#qd|9b]s|+=[u^;5">
                                        <block type="math_number" id="pmxSrG=-GuXXA_}`$X1D">
                                    <block type="math_change" id="4l|3nJK3ab*a;%4oOEr:">
                                      <value name="DELTA">
                                        <shadow type="math_number" id=",5ZCZx[AyTZPJRCD4}~t">
                                          <field name="NUM">1</field>
                                        <block type="math_arithmetic" id="*TjAL)Qm[^ij,1^%-zFp" inline="false">
                                          <field name="OP">DIVIDE</field>
                                            <shadow type="math_number" id="7TDAa@37OuJ`vcT;P%*S">
                                            <block type="math_arithmetic" id="f-yO-QtK`#*o44p4l~(z" inline="false">
                                                <shadow type="math_number" id="5~%F;bHMxZ^filO5NJlP">
                                                <block type="on_source" id=":[cP3-xt`]9uOyB~EA0|">
                                                  <field name="ATTR">oldState.val</field>
                                                <shadow type="math_number" id="pL#ugPnA,fA?t^ZJgf.Y">
                                                <block type="math_arithmetic" id="Lg(3A*d,5?1Nb.q|gM=s">
                                                    <shadow type="math_number" id="vD5aC,I(S]J9iOZ+c4J-">
                                                    <block type="on_source" id="Znb.rqcqheWmt5$ect[t">
                                                      <field name="ATTR">state.lc</field>
                                                    <shadow type="math_number" id="RlrE5saDi)]Sef;L+Ayu">
                                                    <block type="on_source" id="sC$AGCU(o~$];AuwLfa_">
                                                      <field name="ATTR">oldState.lc</field>
                                            <shadow type="math_number" id="f6(R_NuM*Zwyrg-(qhk}">
                                              <field name="NUM">3600000000</field>
                                        <block type="update" id="CII[{jcsb@hcMs[d|BQ(">
                                            <block type="math_rndfixed" id="~?Jqw`YNch87/XxEuB~~">
                                              <field name="n">3</field>
                                              <value name="x">
                                                <shadow type="math_number" id="${2/m,%T*ULKInSPhEs;">
                                                  <field name="NUM">3.1234</field>
                                                <block type="variables_get" id=";gMk*PhZzVvIU5*ye4Zc">
                                            <block type="control" id="Q!_jCcJF^7_-(qn6CvZ,">
                                              <field name="OID">mqtt.0.openWB.set.pv.2.WhCounter</field>
                                                <block type="math_arithmetic" id="Ea`xv/s7NDugI.AC@N@g" inline="false">
                                                    <shadow type="math_number" id="N=7tsj%3fV7yT+T#m[MR">
                                                    <block type="get_value" id="pmeKMtFb8gwAO1?l@QVQ">
                                                    <shadow type="math_number" id="w`C6H+RV?nMM32v2P^09">
                                                      <field name="NUM">1000</field>
                                                <block type="controls_if" id="l?PM69}O3Ny(k|n,4W!q" collapsed="true" disabled="true">
                                                    <block type="logic_compare" id="dxSHTy}..dX]31ELC?+*">
                                                      <field name="OP">EQ</field>
                                                        <block type="variables_get" id="n5dslA_mI9Ou])Gyt:6A">
                                                        <block type="logic_boolean" id="+uGx@r9=;yzVQ77vRIlg">
                                                    <block type="update" id="+|K^3$jkXW`=X}0xU/bc">
                                                        <block type="math_arithmetic" id="-fCShKtoQ)Ha2}/)PnuI">
                                                          <field name="OP">ADD</field>
                                                            <shadow type="math_number" id="OgbG}/M{KA~DNG^NVzQd">
                                                            <block type="variables_get" id="oo#pN(_vd0J(fEiw~B_x">
                                                              <field name="VAR" id="6-EW?O6)X$_9j`r)iuXZ">energie_start</field>
                                                            <shadow type="math_number" id="wPrBhM!5:VdrFq{;y9MF">
                                                            <block type="math_rndfixed" id="=Ztd-ze#r??+IaxSV}ua">
                                                              <value name="x">
        <block type="variables_get" id="v^;XU0)KEjM9-|/K~Bo4">
                                                        <block type="variables_set" id="jGEZLQ^+h]kw.X(h]dO!">
                                                            <block type="logic_boolean" id="w+YH-t6C!S|2;e.pm;aQ">
                                <block type="comment" id="S[uq}2B1D)vx]H[TnOay">
                                  <field name="COMMENT">Berechnung Akku laden in kWh</field>
                                    <block type="variables_set" id="Vx{@=gl.R24%PVZg^HjH">
                                        <block type="get_object" id="}PPbjk$IqE~P,cG)tO;Z">
                                        <block type="on_ext" id="tA7mP|%Y5`?gn6w1L-|D">
                                          <value name="OID0">
                                            <shadow type="field_oid" id="N7O~V4f9c?ea+dU1L`:X">
                                              <field name="oid">zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower</field>
                                            <block type="controls_if" id=")7LDT=K6QU!2Mi~2:ch[">
                                                <block type="logic_compare" id="~|FCyyy5ewSEEN=g(M/.">
                                                    <block type="on_source" id="P-hhEf#);IW^2rvTpOl~">
                                                    <block type="math_number" id="b[5`?J9:V/-r9#MPS,I~">
                                                <block type="math_change" id="3D[l(^?)Z9jp74dD.IzF">
                                                    <block type="math_arithmetic" id="3KN-HkP.|^dECn0i2/5#" inline="false">
                                                        <block type="math_arithmetic" id="@Sf}+Gea0jl=,%LWIFo2" inline="false">
                                                            <block type="on_source" id="$^@Qa.}3uMQQJvd+da*1">
                                                            <block type="math_arithmetic" id="#WpJ!YOf-_7#7PC5pBa5">
        <block type="on_source" id="{n03WD2#*3bft/ra((e5">
        <block type="on_source" id="4*MM-y!,o-]x%L{|$FGf">
                                                        <shadow type="math_number" id="BZE$ono{@LG}q4`:/JE6">
                                                    <block type="update" id="qXnE^jarf]|@.iM]pXSN">
                                                        <block type="math_rndfixed" id="As^GC*c3c#/ovcCj[Izk">
                                                          <value name="x">
                                                            <block type="variables_get" id="DVvB(,~+n;u?KX$i-3+{">
                                                        <block type="control" id="[)VC.[VO$|K8PP2]tY67">
                                                          <field name="OID">mqtt.0.openWB.set.houseBattery.WhImported</field>
                                                            <block type="math_arithmetic" id="AhC[[X(wwlT`p31ph@gH" inline="false">
        <block type="get_value" id="?,B:`OZ!(-V](MS~Z[jR">
        <shadow type="math_number" id="095(Ty8?(Bn804.AK%N@">
                                                            <block type="control" id="Z.d+spg1v98-k{7QJ@39">
                                                              <field name="OID">mqtt.0.openWB.housebattery.DailyYieldImportKwh</field>
        <block type="get_value" id="APZmsgLZl?fAgf?xyAEd">
                                            <block type="comment" id="c=~;P.ij`)3VXFF.QfJ9">
                                              <field name="COMMENT">Berechnung Akku entladen in kWh</field>
                                                <block type="variables_set" id=".iXLd,+o.#.:FMuVq*:F">
                                                    <block type="get_object" id="5#B%R6?L%PE)#VFhs8wc">
                                                    <block type="on_ext" id="!BqpT6L5Jt9!dy}Om1f_">
                                                      <value name="OID0">
                                                        <shadow type="field_oid" id="-$}N.4QXm{r96x(/6LPZ">
                                                          <field name="oid">zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower</field>
                                                        <block type="controls_if" id="8v:aj[g:]uaMl].C1`_.">
                                                            <block type="logic_compare" id="H3slbvS[c!1Lq#r^W74f">
        <block type="on_source" id="f.E$s3*Wp/UKOokR7Lob">
        <block type="math_number" id="#~(=zoaXW2j_5O/GTH$U">
                                                            <block type="math_change" id="riS3c}TAcXe_!!.plM@F">
        <block type="math_arithmetic" id="hT!A95o{|l`Dl-*L8~w0" inline="false">
        <block type="math_arithmetic" id="7h1m+`RNUVw,v~tSaaM8" inline="false">
        <block type="on_source" id="nb4yu%3.-{i95)0NjX?q">
        <block type="math_arithmetic" id="(k3DD)L{Sr1[9px73+zv">
        <block type="on_source" id="[d3)`-(trr7]Jc,DR!vG">
        <block type="on_source" id="!WejTQC/;ZkuwWS[LORL">
        <shadow type="math_number" id="rshwP?x0IX=aDOk|T6qZ">
        <block type="update" id=";^JXx3vl[5u[6j}uIq(0">
        <block type="math_rndfixed" id="o4%pJbXN;{br1M}:2,Sa">
        <value name="x">
        <block type="variables_get" id="e6xZibt(AEyrALe;?(`j">
        <block type="control" id="(06jUc?xnQ,eg+64uDv`">
        <field name="OID">mqtt.0.openWB.set.houseBattery.WhExported</field>
        <block type="math_arithmetic" id="G%YwXy}:JLdYme*1aOEN" inline="false">
        <block type="get_value" id="PH#Ytw3L8+aUa)$O|p3m">
        <shadow type="math_number" id="D|T1ZM^54Ur/]np;jQ~L">
        <block type="control" id="Y9A7~$-]]w7U3_Q~8{z." disabled="true">
        <field name="OID">mqtt.0.openWB.housebattery.DailyYieldExportKwh</field>
        <block type="get_value" id="eu()*N4cXr):1jd}|iRA">
                                                        <block type="comment" id="!Rz`~!wnwyL0;![Qh:}p">
                                                          <field name="COMMENT">Berechnung Abgabe Haus in kWh</field>
                                                            <block type="variables_set" id="m5[7D*Dasi6r#F2/!+c!">
        <block type="get_object" id="0;Fed2($nZ._EJVqt_hI">
        <block type="on_ext" id="lu.)LCKv`g8i-n#_TISE">
        <value name="OID0">
        <shadow type="field_oid" id="N3{ZrX7f+OsMsIP#/U9i">
        <field name="oid">zendure-solarflow.0.73bkTV.7rk1nVD9.outputHomePower</field>
        <block type="controls_if" id="+G8hcCGY@}X{m=_./ZS9">
        <block type="logic_compare" id="6?gQo4NovHN[5^(I,XC4">
        <block type="on_source" id="/),v0q8DTHi1duT7Tgk2">
        <block type="math_number" id="BB)1-0}6e._yDF76=WOt">
        <block type="math_change" id="fOOtZ|OD;Zg^wc=%q-vu">
        <block type="math_arithmetic" id="6`d(*2r1-^(nDnP22u}Y" inline="false">
        <block type="math_arithmetic" id=":(v{J5s[tylm.H@s?]DL" inline="false">
        <block type="on_source" id="H$z%4dk~6,]g.tJqB{L5">
        <block type="math_arithmetic" id="=~~6_;L{LVTuz+}g!4.p">
        <block type="on_source" id="?Fp$bU#F^_Hg*XTrF]`^">
        <block type="on_source" id="L^%o@Qx+t:=j#mGtra=E">
        <shadow type="math_number" id="_[!N:%RqJ25HdZ}=i7=-">
        <block type="update" id="NVg/pYOb]:Z0#~Y4x~^c">
        <block type="math_rndfixed" id="uT1DuxRN5JQjq:xj(%`+">
        <value name="x">
        <block type="variables_get" id="/AI?+5SzC8*}70Yiw`In">
      F D 3 Replies Last reply Reply Quote 0
        FloJo @lesiflo last edited by
        @lesiflo
        Super danke dir. Dann versuche ich mich mal dran.
          FloJo @FloJo last edited by
          @lesiflo
          Habe das Blocky mal importiert und entsprechend meine Datenpunkte eingetragen.
          Mal sehen ob sich was tut, falls Morgen die Sonne scheint.
          Ich habe nur erstmal die mqtt Blöcke deaktiviert:
          Wofür werden die benötigt? Und falls ich diese benötige, was muss ich dafür machen um das einzurichten?
          Würde mich freuen, wenn ich da nochmal Hilfe bekomme...
            lesiflo Most Active @FloJo last edited by
            @flojo Die brauche ich für die Weiterleitung der Daten an openWB (Wallbox). Kannst du also komplett rauslöschen.
              @lesiflo
                diet99 @lesiflo last edited by
                @lesiflo danke erstmal! Ich hab allerdings noch nicht ganz verstanden, was Du damit genau machst. Wo laufen die Daten hin bzw. wie werden die später dann visualisiert?
                Danke für ein paar mehr Details!
                  lesiflo Most Active @diet99 last edited by
                  @diet99 z.B. dafür:
                  Widget oben links und unten rechts
                    lesiflo Most Active last edited by lesiflo
                    @nograx: Hi, ich habe heute ein Firmware-Update vom Master auf V2.0.38 gemacht, seit dem kommen keine Daten mehr für pvPower1 und pwPower2 rein. Hat sich da eventuell etwas in der Datenstruktur/Namen verändert? Auf Github steht solarPower1 und solarPower2. Oder hast du das für den Adapter umbenannt?
                    nograx 2 Replies Last reply Reply Quote 0
                    • nograx
                      nograx Developer @lesiflo last edited by
                      @lesiflo Hi, ich habe die beiden Eingänge nur getauscht, weil Zendure in der App das auch so macht... kann das gerade leider nicht verifizieren, habe das Update noch nicht drauf - und lasse mir in der Regel immer etwas Zeit damit. Gab zuletzt ja auch öfters Probleme mit den Updates, und aktuell läuft mein System sehr zuverlässig. Never change a running system 😉
                      Können das andere auch nachvollziehen?
                      D L 2 Replies Last reply Reply Quote 0
                        diet99 @nograx last edited by
                        @nograx Kann ich bestätigen. Die einzelnen Solarleistungen werden nicht mehr angezeigt:
                          lesiflo Most Active @nograx last edited by lesiflo
                          @nograx OK, dann warte ich bis du auch so weit bist. Der Rest funktioniert ja.
                          Eventuell kannst du ja noch die Berechnung in kWh von mir mit aufnehmen, nur so als Vorschlag. Die API liefert das ja nicht. Die errechneten Werte stimmen ziemlich genau mit denen der App überein.
                            Klappt bei euch die Ausgabe der Lade/Entladezeit? Da ich hier keine Werte bekomme errechne ich mir das selber.
                            Akkukapazität in Ah = Akkuanzahl x Kapazität/Ah: 2 x 20 Ah = 40 Ah (bei 2 x AB1000)
                            Spannung_PV_Panel = Spannung des Moduls bei max. Leistung (aus Datenblatt vom Panel)
                            Die Variablen für "remainInputTime" und "remainOutTime" müsst ihr am besten unter 0_userdata.0 selber anlegen. Evtl. eigene Namen vergeben.
                            Ladezeit:
                            Entladezeit:
                            Export Blockly
                              <variables>
                                <variable id="y{EyYfI6aqO8WcNtPY2w">Akkukapazität</variable>
                                <variable id="JcbPVIO%aKu!SI`JU!JD">Spannung_PV_Panel</variable>
                                <variable id="!sszI/Un!f$3Hn!1tk]B">Restakku</variable>
                                <variable id="}bL170$YMV{_n7LhpGBh">Ladestrom</variable>
                                <variable id="`lOge52h.+zOY`PGJnbm">Ladezeit</variable>
                                <variable id="O^EBe~zb4T$B=87LqdjD">ladezeit_min</variable>
                                <variable id="=VOm[,NN_4Fw5ed:086w">ladezeit_std</variable>
                              </variables>
                              <block type="comment" id="0^!mX,ag|{B$l?KZ}|UK" x="775" y="539">
                                <field name="COMMENT">Ladezeit berechnen</field>
                                  <block type="variables_set" id="%Vl9XZ[$GMcs[`qohyq?">
                                    <field name="VAR" id="y{EyYfI6aqO8WcNtPY2w">Akkukapazität</field>
                                      <block type="math_number" id="V^nvYM1W~tFYLcrSW%?r">
                                        <field name="NUM">38.4</field>
                                      <block type="variables_set" id="pg#LClGOjY,#MY7d0jzj">
                                        <field name="VAR" id="JcbPVIO%aKu!SI`JU!JD">Spannung_PV_Panel</field>
                                          <block type="math_number" id="PA8C_0?Qc{R8fas-hV1q">
                                            <field name="NUM">31.21</field>
                                          <block type="on_ext" id="-*eavH]~|+T`*5!_u%e;">
                                            <value name="OID0">
                                              <shadow type="field_oid" id="`_;Zkj?K=RLIsH)Hx2K/">
                                              <block type="variables_set" id="s/YcoZ4hO]7s2=r0JtL^">
                                                <field name="VAR" id="!sszI/Un!f$3Hn!1tk]B">Restakku</field>
                                                  <block type="math_arithmetic" id="l2hqe6uq%QR)HjLZp[:)">
                                                      <shadow type="math_number" id="U.3*7Od6k;ghubO(hNz8">
                                                      <block type="variables_get" id="[fcQlzl5H[rk]Q.oM[t0">
                                                      <shadow type="math_number" id="tNY#^EVgu|?FCRcVcqRr">
                                                      <block type="math_arithmetic" id="c#6mk`@C`ErD^`Fqk}Sg" inline="false">
                                                          <shadow type="math_number" id="3e_E)w^DLR.[*$|bYW!6">
                                                          <block type="math_arithmetic" id="X/:pi@s:YDVIz14asd1?" inline="false">
                                                              <shadow type="math_number" id="z=JnJ[KV?c^5m{Rb,msG">
                                                              <block type="variables_get" id="C#O;Z){J.o#{DIpd6N?y">
                                                              <shadow type="math_number" id="*`j,@!H9ujzx3_f=l4cl">
                                                              <block type="get_value" id="_I:nxP70pMkv;kI^u66j">
        <field name="OID">zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel</field>
                                                          <shadow type="math_number" id="(4xaN|=t8Ba`uD%{U/H+">
                                                            <field name="NUM">100</field>
                                                  <block type="controls_if" id=":UFbeKem?j7-OimUDh3c">
                                                      <block type="logic_compare" id=".pvE#7x[T{-RFL?|/70P">
                                                          <block type="get_value" id="H)fS@0:/ZD0qnCcS(Cu5">
                                                            <field name="OID">zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower</field>
                                                          <block type="math_number" id=").TzP*5M$S[VM]%sH6xx">
                                                      <block type="variables_set" id="h(N?0XJj6L*4Ih,k?-Wb">
                                                        <field name="VAR" id="}bL170$YMV{_n7LhpGBh">Ladestrom</field>
                                                          <block type="math_arithmetic" id="Diq[[l,%jJoK~SEH%mgV">
                                                              <shadow type="math_number" id="`s}jI^~:y:H{K?lfg__K">
                                                              <block type="math_arithmetic" id="}_!SwYmvLqys9]5tA0];">
        <shadow type="math_number" id="llxw:a{n~#0Eyqq4NYy6">
        <block type="get_value" id="FRt=/;a{aDwSfX3PV8nx">
        <shadow type="math_number" id="NL#5MAp_EEg_m4,GUmv+">
        <block type="variables_get" id="2#|hmH%)^Z,;4b;rg0t)">
                                                              <shadow type="math_number" id="`ZA/6w^SAfpI61756S74">
        <field name="NUM">2</field>
                                                          <block type="variables_set" id="Xr5g_mKP!2ms[;a!F7t*">
                                                            <field name="VAR" id="`lOge52h.+zOY`PGJnbm">Ladezeit</field>
                                                              <block type="math_arithmetic" id="Y2EkD?z!ii7znx{8tzUQ">
        <shadow type="math_number" id="I:}-3F3h(R,9Lr:TVQ3`">
        <block type="math_arithmetic" id=";oFfIK[AcS_$Y*0/I,*X" inline="false">
        <shadow type="math_number" id="VZ2Ra3A*87J[t{Y2vCm7">
        <block type="math_arithmetic" id="ha|yev/:juj*Mz3K]4~j" inline="false">
        <shadow type="math_number" id="X2A9GcU3zX_vWAb_Z%3P">
        <block type="variables_get" id="}zAgf*nJ%Hvt{w_Oc,=I">
        <shadow type="math_number" id="s(bc]%.$C|CI21HcOf1K">
        <field name="NUM">1.3</field>
        <shadow type="math_number" id="A9K?p@IIdLLxXDS1S:Rd">
        <block type="variables_get" id="xbU:n8FrM:JzTOvc]XCV">
        <shadow type="math_number" id="U-s@rqdzd|J{mO|tLsZN">
        <field name="NUM">60</field>
                                                              <block type="variables_set" id="Cu62qYG.pn{)]-7k?Dk_">
        <field name="VAR" id="O^EBe~zb4T$B=87LqdjD">ladezeit_min</field>
        <block type="math_modulo" id="`?T]=8CW9!`l65y9_lA:">
        <value name="DIVIDEND">
        <shadow type="math_number" id="QZ|BCq[:AYInR?K:plOz">
        <field name="NUM">64</field>
        <block type="variables_get" id="wK;;QlJJ?8TI@KVKpECi">
        <value name="DIVISOR">
        <shadow type="math_number" id="Mx_LMHgznO/jsh)a_YvO">
        <block type="variables_set" id="`%3^%]{=n=omnx//?r.D">
        <field name="VAR" id="=VOm[,NN_4Fw5ed:086w">ladezeit_std</field>
        <block type="math_arithmetic" id="$8Em0!,(ju2X8:X7?F-f">
        <shadow type="math_number" id="#)P@)|RD%,^l[4mXA)Qg">
        <block type="math_arithmetic" id="6Nph4BRdjMeR7ypb/h;x" inline="false">
        <shadow type="math_number" id="gk(bxszYj-8oicyU^3X}">
        <block type="variables_get" id="(h(/9QZc@^$Ibtp@dLR4">
        <shadow type="math_number" id="]4~#=gBD*RDDL_(m}ug/">
        <block type="variables_get" id="E/!m;U7e@*%{qxgTRXN#">
        <shadow type="math_number" id="Dy!xFuu-eU4pQ-:%=-57">
        <block type="controls_if" id="6d-pWm-burHQ.*sRJC+9">
        <block type="logic_compare" id="5u$zbiWX0Tb(4Xsnx#.x">
        <field name="OP">LT</field>
        <block type="variables_get" id="p=wFsc/w|@vus?R?$dUJ">
        <block type="math_number" id="`-[L)p@1J(NF(,A{g8(Q">
        <field name="NUM">10</field>
        <block type="control" id="rQz^Bw5l3hI#=EhTBkTs">
        <field name="OID">0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime</field>
        <field name="DELAY_MS">1000</field>
        <field name="UNIT">ms</field>
        <block type="text_join" id="*A5Ks]vzGT4Q|+Z~v`%d">
        <mutation items="4"></mutation>
        <value name="ADD0">
        <block type="variables_get" id="~;NB[W.,7VV^nBTL:iXm">
        <value name="ADD1">
        <block type="text" id="AXN-`:E6N[c*r*v#^RAH">
        <field name="TEXT">:</field>
        <value name="ADD2">
        <block type="text" id=":~CD`PfoOYsHvQ=_7-$,">
        <field name="TEXT">0</field>
        <value name="ADD3">
        <block type="math_round" id="#6.cB,SUy]patR)*5$Cv">
        <field name="OP">ROUND</field>
        <value name="NUM">
        <shadow type="math_number" id="U+ZA*?oz60S#xQ]rsx0V">
        <field name="NUM">3.1</field>
        <block type="variables_get" id="xmgR9jeJEG47+FVO!he.">
        <statement name="ELSE">
        <block type="control" id="|w!Rr2kx+Pe0Yn,w.PsE">
        <block type="text_join" id="%I|CjdFI!yn`hZ9ZYUAr">
        <value name="ADD0">
        <block type="variables_get" id="V;h9~k{YnG_nY(/09sb$">
        <value name="ADD1">
        <block type="text" id="tA:JP+r(/3;rkg6be:j-">
        <value name="ADD2">
        <block type="math_round" id="~^WNC8MZCwi*w.F?,t9B">
        <value name="NUM">
        <block type="variables_get" id="M6E4q7eD;^fram%+FS%1">
                                                    <value name="IF1">
                                                      <block type="logic_compare" id="3g;pUDzNW0w3#WSXsB=B">
                                                          <block type="get_value" id="QGQ81pMxTZUo40StjM%V">
                                                            <field name="OID">zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower</field>
                                                          <block type="math_number" id="@3v$5PeaR=g)XHY@1#9#">
                                                    <statement name="DO1">
                                                      <block type="control" id="c6d6_.DK05Af^A4qw}($">
                                                          <block type="text" id=":3Dt+0b{~?o*xK#zl@2I">
                                              <block type="comment" id="/kKDTf.b[BXI;3@z?S^U">
                                                <field name="COMMENT">Endladezeit berechnen</field>
                                                  <block type="on_ext" id="-VY6uVv5|qV1,,%-c0ts">
                                                    <value name="OID0">
                                                      <shadow type="field_oid" id="RVw37Xv/+_l0a|vhZC@D">
                                                      <block type="variables_set" id="5}r@EE1q%$TVm}M@z!J2">
                                                          <block type="math_arithmetic" id="Mi.Sl*eD:fiWEr*E;`4B" inline="false">
                                                              <block type="math_arithmetic" id="nV=oWUzXOc@Z^EocV:,~" inline="false">
        <block type="variables_get" id="A3DFN1|%W7[ZHsAw{/fK">
        <block type="get_value" id="u%RzP+MN-@Z3q#|jH@p)">
                                                              <shadow type="math_number" id="J/edd2*@!L%W~x0czzO1">
                                                          <block type="controls_if" id="1.TOTFI#-9W]$,Aly6JT">
                                                              <block type="logic_compare" id="*y6Nrn`Y2t40FWw}r)A?">
        <block type="get_value" id="2qmOAlmhWKm2XMB1p4tH">
        <block type="math_number" id="QmHkzMr5vTTx8j49{CK}">
                                                              <block type="variables_set" id="Bk2jv4495@cW(2?w1pv_">
        <block type="math_arithmetic" id="a{DVP6E%%Ps]qEp;Qz0}">
        <block type="math_arithmetic" id="X0B/biEcj{Z0Dc=K$%Qe">
        <block type="get_value" id="C96_lVEC{G[tN[],:1D/">
        <block type="variables_get" id="Hs/#G!wi4nf+RG!lxO8/">
        <shadow type="math_number" id="7|w^L7BJPsr@kg^Q,-3A">
        <block type="variables_set" id="/)vg;u/FD2HB?f4*Dnk:">
        <block type="math_arithmetic" id="G@,1szYHo|[!!?REb[TT">
        <block type="math_arithmetic" id="_llKaN,--nmtiv|gW*sP" inline="false">
        <block type="math_arithmetic" id="BGhn@o3w5yLD_Nohz7H-" inline="false">
        <block type="variables_get" id="ab)5sQn$b5Rh}VYB~|$G">
        <shadow type="math_number" id="TS,XL3fPev?{(w{*gf14">
        <block type="variables_get" id="bqg^%unIv/[5Rx%2t+Qq">
        <shadow type="math_number" id="#[M{Gx!_HOq:#N#c3ua9">
        <block type="variables_set" id="Ny%ib{Z~rw*`tp|I73gN">
        <block type="math_modulo" id="$#I07pq%nO)(-zn.y7qI">
        <block type="variables_get" id="5N;b6|/v-bKAKq;AT6dZ">
        <shadow type="math_number" id="Uz)%aWJHTk)LQk#jQ!,E">
        <block type="variables_set" id="!41QYhGM9mn=V$qn%o5q">
        <block type="math_arithmetic" id="P*(8pIt)19s4W@F_Mj09">
        <block type="math_arithmetic" id="f.~-COZ?GmtTiO(xsPh!" inline="false">
        <block type="variables_get" id="?vYIGU^EaY9z^4FWXmm3">
        <block type="variables_get" id="cL($n5^l2;o.n]{X,XIg">
        <shadow type="math_number" id="@nnKwenc8Y?$5{DNJa]U">
        <block type="controls_if" id="+MrOC$PJ.s:XW*NKYU:8">
        <block type="logic_compare" id="@Dv]ZZnB-`1igoLsT)yQ">
        <block type="variables_get" id="~s2X^Ek_uF^Gh(PpqLrU">
        <block type="math_number" id="c+QVI{~dH_o`z7P6L?iK">
        <block type="control" id="wOk#YxmO2P(RKBUI~z(T">
        <field name="OID">0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime</field>
        <block type="text_join" id="kV0VQ#=Z?7@Ke,g=O!Hr">
        <value name="ADD0">
        <block type="variables_get" id="lepo)3#*;{!Be[!1bw!t">
        <value name="ADD1">
        <block type="text" id="G9E)4`[9t;;fS6/+m3NM">
        <value name="ADD2">
        <block type="text" id="U}0?xB^$R5D2RHJaN5q*">
        <value name="ADD3">
        <block type="math_round" id=",Sy[/DxUI{2t7ab},%E2">
        <value name="NUM">
        <block type="variables_get" id="rvUPj@!|eC7~tE/^:1yh">
        <block type="control" id="FJ#j^#R1/W,tjPMeMnlY">
        <block type="text_join" id="QjjLSj$P0uPc(@sIG;U]">
        <value name="ADD0">
        <block type="variables_get" id="U@;AtX-e6*IW4s.jbpX+">
        <value name="ADD1">
        <block type="text" id="GSZAzCP^huon7J/G(;5r">
        <value name="ADD2">
        <block type="math_round" id="k4C8?@`!m#r.InCJL[%r">
        <value name="NUM">
        <block type="variables_get" id="a$/wx}bNig,jH8M_^CqP">
                                                            <value name="IF1">
                                                              <block type="logic_compare" id="$4$UB$5N*porfZX$pFBH">
        <block type="get_value" id=";nP^D`kw35;XmX.UKq)U">
        <block type="math_number" id="?KbNiIWARUQf4zd_;m7}">
                                                              <block type="control" id="zSGxcU6SMNsk1T~_8f9%">
        <block type="text" id="*YGgeihzw5n:LX/n/b!s">
                            nograx 1 Reply Last reply Reply Quote 0
                            • nograx
                              nograx Developer @lesiflo last edited by nograx
                              @lesiflo Ist seit gestern in einem ersten Ansatz in der Latest Version drin.
                              Kannst du mir das Blockly mal als Javascript umwandeln (sollte ein Blockly/Javascript Button geben) dann kann ich sicher was davon verwenden. Danke.
                              Mal schauen ggf. traue ich mich ja dieses Wochenende das Update durchzuführen 😉 Dann schaue ich mal was Zendure da geändert hat. Meine Vermutung ist das sie durch das Vertauschen nun 2 neue Namen für die Werte genommen haben.
                                @nograx Bitte schön, Berechnung in kWh
                                var timeout, timeout2, timeout3, Entladen_Soll, Akkukapazit_C3_A4t, Spannung_PV_Panel, Restakku, Ladestrom, Ladezeit, ladezeit_min, ladezeit_std;
                                // Aktuelle PV-Leistung [W]
                                on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.solarInputPower']), change: 'ne' }, async (obj) => {
                                  let value = obj.state.val;
                                  if ((obj.state ? obj.state.val : '') > 0) {
                                    setStateDelayed('mqtt.0.openWB.set.pv.2.W' /* W */, (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.solarInputPower').val * -1), 50, false);
                                    (() => { if (timeout) { clearTimeout(timeout); timeout = null; }})();
                                  } else if ((obj.state ? obj.state.val : '') == 0) {
                                    timeout = setTimeout(async () => {
                                      timeout = null;
                                      setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.packState' /* packState */, 0);
                                      setState('mqtt.0.openWB.set.pv.2.W' /* W */, 0);
                                    }, 60000);
                                // Ladeleistung in Akku [W]
                                on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower']), change: 'ne' }, async (obj) => {
                                    setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.packState' /* packState */, 1);
                                    setState('mqtt.0.openWB.set.houseBattery.W' /* W */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val);
                                    if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val > 0) {
                                      setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower' /* InOutPackPower */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val);
                                      setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Wh' /* InOutPackPower_Wh */, (Math.round(getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.packInputPower_kWh').val * 1000)));
                                      setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Grafana' /* InOutPackPower_Grafana */, (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val * -1));
                                      setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime' /* remainOutTime */, 0, true, 1000, false);
                                      setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus' /* Ladestatus */, 'Laden [W]');
                                      setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus_Wh' /* Ladestatus_Wh */, 'Geladen [Wh]');
                                    if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val == 0 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val == 0) {
                                      setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower' /* InOutPackPower */, 0);
                                      setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Grafana' /* InOutPackPower_Grafana */, 0);
                                      setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime' /* remainInputTime */, 0, true, 1000, false);
                                      setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus' /* Ladestatus */, 'Standby');
                                    (() => { if (timeout2) { clearTimeout(timeout2); timeout2 = null; }})();
                                    timeout2 = setTimeout(async () => {
                                      timeout2 = null;
                                      setState('mqtt.0.openWB.set.houseBattery.W' /* W */, 0);
                                    }, 30000);
                                // Entnahmeleistung aus Akku [W]
                                on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower']), change: 'ne' }, async (obj) => {
                                    setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.packState' /* packState */, 2);
                                    setState('mqtt.0.openWB.set.houseBattery.W' /* W */, (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val * -1));
                                    if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val > 0) {
                                      setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower' /* InOutPackPower */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val);
                                      setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Wh' /* InOutPackPower_Wh */, (Math.round(getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.outputPackPower_kWh').val * 1000)));
                                      setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Grafana' /* InOutPackPower_Grafana */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val);
                                      setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus' /* Ladestatus */, 'Entladen [W]');
                                      setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus_Wh' /* Ladestatus_Wh */, 'Geliefert [Wh]');
                                    (() => { if (timeout3) { clearTimeout(timeout3); timeout3 = null; }})();
                                    timeout3 = setTimeout(async () => {
                                      timeout3 = null;
                                    }, 30000);
                                // Aktueller Ladestand des Akkus [%] und Ausgangsleistung auf 0 setzen
                                on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel']), change: 'ne' }, async (obj) => {
                                  setState('mqtt.0.openWB.set.houseBattery.%Soc' /* %Soc */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val);
                                  if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val <= getState('zendure-solarflow.0.73bkTV.7rk1nVD9.minSoc').val) {
                                    setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 0);
                                // Ausgangsleistung einstellen - Variabel
                                on({ id: [].concat(['0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus']).concat(['mqtt.0.openWB.global.WHouseConsumption']).concat(['0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu']), change: 'ne' }, async (obj) => {
                                  if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu').val == 1 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val >= getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Min_SOC_entladen').val) {
                                    if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 1 || getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 2 && compareTime(getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.AkkuOut_Start').val, '06:00', 'between', null)) {
                                      Entladen_Soll = getState('mqtt.0.openWB.global.WHouseConsumption').val + getState('mqtt.0.openWB.pv.W').val;
                                      if (Entladen_Soll > 50) {
                                        setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 50);
                                      } else if (Entladen_Soll > 100) {
                                        setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 100);
                                      } else if (Entladen_Soll > 200) {
                                        setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 200);
                                      } else if (Entladen_Soll > 300) {
                                        setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 300);
                                      } else if (Entladen_Soll > 400) {
                                        setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 400);
                                      } else if (Entladen_Soll > 500) {
                                        setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 500);
                                      } else if (Entladen_Soll > 600) {
                                        setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 600);
                                      } else if (Entladen_Soll <= 0) {
                                        setStateDelayed('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 0, 30000, false);
                                // Ausgangsleistung einstellen - Fest sofort
                                on({ id: [].concat(['0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus']).concat(['0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu']), change: 'ne' }, async (obj) => {
                                  if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu').val == 0 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val >= getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Min_SOC_entladen').val) {
                                    if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 1) {
                                      setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.SetOutputPower').val);
                                    } else if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 0 || getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 2) {
                                // Ausgangsleistung einstellen - Fest nach Zeit
                                schedule("2,17,32,47 17-22 * * *", async () => {
                                  if ((getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 2 && compareTime(getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.AkkuOut_Start').val, '23:00', 'between', null) && getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu').val == 0 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val >= getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Min_SOC_entladen').val)) {
                                // Ladezeit berechnen
                                Akkukapazit_C3_A4t = 38.4;
                                Spannung_PV_Panel = 31.21;
                                  Restakku = Akkukapazit_C3_A4t - (Akkukapazit_C3_A4t * getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val) / 100;
                                    Ladestrom = (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val / Spannung_PV_Panel) / 2;
                                    Ladezeit = ((Restakku / 1.3) / Ladestrom) * 60;
                                    ladezeit_min = Ladezeit % 60;
                                    ladezeit_std = (Ladezeit - ladezeit_min) / 60;
                                    if (ladezeit_min < 10) {
                                      setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime' /* remainInputTime */, ([ladezeit_std,':','0',Math.round(ladezeit_min)].join('')), 1000, false);
                                    } else {
                                      setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime' /* remainInputTime */, ([ladezeit_std,':',Math.round(ladezeit_min)].join('')), 1000, false);
                                  } else if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val == 0) {
                                    setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime' /* remainInputTime */, '0', 1000, false);
                                // Endladezeit berechnen
                                  Restakku = (Akkukapazit_C3_A4t * getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val) / 100;
                                    Ladestrom = (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val / Spannung_PV_Panel) / 2;
                                      setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime' /* remainOutTime */, ([ladezeit_std,':','0',Math.round(ladezeit_min)].join('')), 1000, false);
                                    } else {
                                      setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime' /* remainOutTime */, ([ladezeit_std,':',Math.round(ladezeit_min)].join('')), 1000, false);
                                    setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime' /* remainOutTime */, '0', 1000, false);
                                on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower']).concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower']), change: 'ne' }, async (obj) => {
                                    setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.Restzeit' /* Restzeit */, getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime').val, 1000, false);
                                  } else if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val > 0) {
                                    setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.Restzeit' /* Restzeit */, getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime').val, 1000, false);
                                  } else if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val == 0 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val == 0) {
                                    setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.Restzeit' /* Restzeit */, '0:00', 1000, false);
                                // Akkuheizung
                                on({ id: [].concat(['hm-rpc.0.LEQ0122954.1.TEMPERATURE']), change: 'ne' }, async (obj) => {
                                  if ((obj.state ? obj.state.val : '') < 10 && compareTime('07:00', '17:00', 'between', null) || (obj.state ? obj.state.val : '') < 8 && (compareTime('17:01', '23:59', 'between', null) || compareTime('00:00', '06:59', 'between', null))) {
                                    setState('shelly.0.SHPLG-S#5AD46F#1.Relay0.Switch' /* Switch */, true);
                                    setStateDelayed('shelly.0.SHPLG-S#5AD46F#1.Relay0.Switch' /* Switch */, false, 2700000, false);
                                  } else if ((obj.state ? obj.state.val : '') >= 15) {
                                    setState('shelly.0.SHPLG-S#5AD46F#1.Relay0.Switch' /* Switch */, false);
                                  @nograx Du solltest noch warten mit dem Update. Bei mir passen die Leistungsdaten in der App seit dem nicht mehr.
                                  Meine Akku's sind voll, 1920 Wh. An Solar wurde aber nur 1.53 kWh erzeugt. Die Akkus waren vorher auf 1%. Immerhin passen aber die errechneten Wert im iobroker.
                                    @lesiflo super - dankeschön!
                                    Was muß ich da jetzt alles auf mein System anpassen? Nur die vier Werte Solarleistung, Ladeleistung, Entladeleistung und Ausgangsleistung?
                                      @lesiflo Das scheint ein serverseitiges Problem zu sein. Wird im PV-Forum auch bereits diskutiert und trat wohl schon einige Tage vor der Auslieferung des Updates auf.
                                        diet99 @diet99 last edited by
                                        @lesiflo da kommen beim Start jetzt diese Fehlermeldungen. Muß ich die Variablen zuerst bei mir anlegen? So ganz habe ich das Prinzip irgendwie noch nicht verstanden.
                                        Danke!
                                          lesiflo Most Active @diet99 last edited by lesiflo
                                          @diet99 Ja, genau. Die 4 angemeckerten Variablen musst du bei dir am besten unter 0_userdata.0. in einem eigenen Ordner anlegen und dann im Script an der jeweiligen Stelle eintragen.
                                          Alles was gelb markiert ist kann du rauslöschen, ist für meine Wallbox.
                                            gelöscht
                                            1848
                                            701015
