    4. Test Adapter Zendure Solarflow
      lesiflo Most Active @nograx last edited by
      @nograx Bitte schön, Berechnung in kWh
      var timeout, timeout2, timeout3, Entladen_Soll, Akkukapazit_C3_A4t, Spannung_PV_Panel, Restakku, Ladestrom, Ladezeit, ladezeit_min, ladezeit_std;
      // Aktuelle PV-Leistung [W]
      on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.solarInputPower']), change: 'ne' }, async (obj) => {
        let value = obj.state.val;
        if ((obj.state ? obj.state.val : '') > 0) {
          setStateDelayed('mqtt.0.openWB.set.pv.2.W' /* W */, (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.solarInputPower').val * -1), 50, false);
          (() => { if (timeout) { clearTimeout(timeout); timeout = null; }})();
        } else if ((obj.state ? obj.state.val : '') == 0) {
          timeout = setTimeout(async () => {
            timeout = null;
            setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.packState' /* packState */, 0);
            setState('mqtt.0.openWB.set.pv.2.W' /* W */, 0);
          }, 60000);
      // Ladeleistung in Akku [W]
      on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower']), change: 'ne' }, async (obj) => {
          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.packState' /* packState */, 1);
          setState('mqtt.0.openWB.set.houseBattery.W' /* W */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val);
          if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val > 0) {
            setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower' /* InOutPackPower */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val);
            setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Wh' /* InOutPackPower_Wh */, (Math.round(getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.packInputPower_kWh').val * 1000)));
            setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Grafana' /* InOutPackPower_Grafana */, (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val * -1));
            setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime' /* remainOutTime */, 0, true, 1000, false);
            setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus' /* Ladestatus */, 'Laden [W]');
            setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus_Wh' /* Ladestatus_Wh */, 'Geladen [Wh]');
          if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val == 0 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val == 0) {
            setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower' /* InOutPackPower */, 0);
            setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Grafana' /* InOutPackPower_Grafana */, 0);
            setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime' /* remainInputTime */, 0, true, 1000, false);
            setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus' /* Ladestatus */, 'Standby');
          (() => { if (timeout2) { clearTimeout(timeout2); timeout2 = null; }})();
          timeout2 = setTimeout(async () => {
            timeout2 = null;
            setState('mqtt.0.openWB.set.houseBattery.W' /* W */, 0);
          }, 30000);
      // Entnahmeleistung aus Akku [W]
      on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower']), change: 'ne' }, async (obj) => {
          setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.packState' /* packState */, 2);
          setState('mqtt.0.openWB.set.houseBattery.W' /* W */, (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val * -1));
          if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val > 0) {
            setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower' /* InOutPackPower */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val);
            setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Wh' /* InOutPackPower_Wh */, (Math.round(getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.outputPackPower_kWh').val * 1000)));
            setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.InOutPackPower_Grafana' /* InOutPackPower_Grafana */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val);
            setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus' /* Ladestatus */, 'Entladen [W]');
            setState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Ladestatus_Wh' /* Ladestatus_Wh */, 'Geliefert [Wh]');
          (() => { if (timeout3) { clearTimeout(timeout3); timeout3 = null; }})();
          timeout3 = setTimeout(async () => {
            timeout3 = null;
          }, 30000);
      // Aktueller Ladestand des Akkus [%] und Ausgangsleistung auf 0 setzen
      on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel']), change: 'ne' }, async (obj) => {
        setState('mqtt.0.openWB.set.houseBattery.%Soc' /* %Soc */, getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val);
        if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val <= getState('zendure-solarflow.0.73bkTV.7rk1nVD9.minSoc').val) {
          setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 0);
      // Ausgangsleistung einstellen - Variabel
      on({ id: [].concat(['0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus']).concat(['mqtt.0.openWB.global.WHouseConsumption']).concat(['0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu']), change: 'ne' }, async (obj) => {
        if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu').val == 1 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val >= getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Min_SOC_entladen').val) {
          if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 1 || getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 2 && compareTime(getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.AkkuOut_Start').val, '06:00', 'between', null)) {
            Entladen_Soll = getState('mqtt.0.openWB.global.WHouseConsumption').val + getState('mqtt.0.openWB.pv.W').val;
            if (Entladen_Soll > 50) {
              setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 50);
            } else if (Entladen_Soll > 100) {
              setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 100);
            } else if (Entladen_Soll > 200) {
              setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 200);
            } else if (Entladen_Soll > 300) {
              setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 300);
            } else if (Entladen_Soll > 400) {
              setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 400);
            } else if (Entladen_Soll > 500) {
              setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 500);
            } else if (Entladen_Soll > 600) {
              setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 600);
            } else if (Entladen_Soll <= 0) {
              setStateDelayed('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, 0, 30000, false);
      // Ausgangsleistung einstellen - Fest sofort
      on({ id: [].concat(['0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus']).concat(['0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu']), change: 'ne' }, async (obj) => {
        if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu').val == 0 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val >= getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Min_SOC_entladen').val) {
          if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 1) {
            setState('zendure-solarflow.0.73bkTV.7rk1nVD9.control.setOutputLimit' /* Einzustellende Ausgangsleistung */, getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.SetOutputPower').val);
          } else if (getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 0 || getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 2) {
      // Ausgangsleistung einstellen - Fest nach Zeit
      schedule("2,17,32,47 17-22 * * *", async () => {
        if ((getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Entladen_Modus').val == 2 && compareTime(getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.AkkuOut_Start').val, '23:00', 'between', null) && getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Umschalten_Auto_Manu').val == 0 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val >= getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.Min_SOC_entladen').val)) {
      // Ladezeit berechnen
      Akkukapazit_C3_A4t = 38.4;
      Spannung_PV_Panel = 31.21;
        Restakku = Akkukapazit_C3_A4t - (Akkukapazit_C3_A4t * getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val) / 100;
          Ladestrom = (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val / Spannung_PV_Panel) / 2;
          Ladezeit = ((Restakku / 1.3) / Ladestrom) * 60;
          ladezeit_min = Ladezeit % 60;
          ladezeit_std = (Ladezeit - ladezeit_min) / 60;
          if (ladezeit_min < 10) {
            setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime' /* remainInputTime */, ([ladezeit_std,':','0',Math.round(ladezeit_min)].join('')), 1000, false);
          } else {
            setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime' /* remainInputTime */, ([ladezeit_std,':',Math.round(ladezeit_min)].join('')), 1000, false);
        } else if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val == 0) {
          setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime' /* remainInputTime */, '0', 1000, false);
      // Endladezeit berechnen
        Restakku = (Akkukapazit_C3_A4t * getState('zendure-solarflow.0.73bkTV.7rk1nVD9.electricLevel').val) / 100;
          Ladestrom = (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val / Spannung_PV_Panel) / 2;
            setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime' /* remainOutTime */, ([ladezeit_std,':','0',Math.round(ladezeit_min)].join('')), 1000, false);
          } else {
            setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime' /* remainOutTime */, ([ladezeit_std,':',Math.round(ladezeit_min)].join('')), 1000, false);
          setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime' /* remainOutTime */, '0', 1000, false);
      on({ id: [].concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower']).concat(['zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower']), change: 'ne' }, async (obj) => {
          setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.Restzeit' /* Restzeit */, getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainInputTime').val, 1000, false);
        } else if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val > 0) {
          setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.Restzeit' /* Restzeit */, getState('0_userdata.0.Eigene_Variablen.PV.Solarflow.remainOutTime').val, 1000, false);
        } else if (getState('zendure-solarflow.0.73bkTV.7rk1nVD9.outputPackPower').val == 0 && getState('zendure-solarflow.0.73bkTV.7rk1nVD9.packInputPower').val == 0) {
          setStateDelayed('0_userdata.0.Eigene_Variablen.PV.Solarflow.Restzeit' /* Restzeit */, '0:00', 1000, false);
      // Akkuheizung
      on({ id: [].concat(['hm-rpc.0.LEQ0122954.1.TEMPERATURE']), change: 'ne' }, async (obj) => {
        if ((obj.state ? obj.state.val : '') < 10 && compareTime('07:00', '17:00', 'between', null) || (obj.state ? obj.state.val : '') < 8 && (compareTime('17:01', '23:59', 'between', null) || compareTime('00:00', '06:59', 'between', null))) {
          setState('shelly.0.SHPLG-S#5AD46F#1.Relay0.Switch' /* Switch */, true);
          setStateDelayed('shelly.0.SHPLG-S#5AD46F#1.Relay0.Switch' /* Switch */, false, 2700000, false);
        } else if ((obj.state ? obj.state.val : '') >= 15) {
          setState('shelly.0.SHPLG-S#5AD46F#1.Relay0.Switch' /* Switch */, false);
        @nograx Du solltest noch warten mit dem Update. Bei mir passen die Leistungsdaten in der App seit dem nicht mehr.
        Meine Akku's sind voll, 1920 Wh. An Solar wurde aber nur 1.53 kWh erzeugt. Die Akkus waren vorher auf 1%. Immerhin passen aber die errechneten Wert im iobroker.
          diet99 @lesiflo last edited by
          @lesiflo super - dankeschön!
          Was muß ich da jetzt alles auf mein System anpassen? Nur die vier Werte Solarleistung, Ladeleistung, Entladeleistung und Ausgangsleistung?
            @lesiflo Das scheint ein serverseitiges Problem zu sein. Wird im PV-Forum auch bereits diskutiert und trat wohl schon einige Tage vor der Auslieferung des Updates auf.
              diet99 @diet99 last edited by
              @lesiflo da kommen beim Start jetzt diese Fehlermeldungen. Muß ich die Variablen zuerst bei mir anlegen? So ganz habe ich das Prinzip irgendwie noch nicht verstanden.
              Danke!
                lesiflo Most Active @diet99 last edited by lesiflo
                @diet99 Ja, genau. Die 4 angemeckerten Variablen musst du bei dir am besten unter 0_userdata.0. in einem eigenen Ordner anlegen und dann im Script an der jeweiligen Stelle eintragen.
                Alles was gelb markiert ist kann du rauslöschen, ist für meine Wallbox.
                  gelöscht
                    @diet99 sagte in Test Adapter Zendure Solarflow:
                    Ok, ist mir nicht aufgefallen da ich immer auf meine errechneten Werte geschaut habe, die passen ja.
                      diet99 @lesiflo last edited by diet99
                      @lesiflo Super - vielen Dank. Klappt jetzt offenbar.
                      Die Zeilen mit mqtt wollte ich gerade noch nachfragen, aber das hast Du ja geschrieben, daß die rauskönnen.
                      Nun muß ich nur noch schauen, wie ich die erzeugten Daten visualisieren kann.
                      Werden die eigentlich irgendwo als historische Daten abgelegt, oder wie funktioniert das genau?
                        @diet99 Dafür gibt es mehrere Möglichkeiten. Am besten den history-Adapter installieren und dann für die jeweiligen Datenobjekte auswählen.
                        History-Adapter
                        Rechts auf das Zahnrad klicken
                        Dann auf "Aktiviert" klicken. Ich nutze jedoch influxdb und nicht history. Damit kann man noch etwas mehr machen.
                          Visualisieren z.B. damit:
                            @lesiflo ich hätte mir jetzt eher sowas vorgestellt:
                            b27faf59-5d2f-4621-af2a-c8a36dad6254-1709224143460-25534441-b687-4f3f-90c3-bc0be652a035-image.png
                            Dein Script läuft jedenfalls sauber! Ich hab gerade mal den PVHub angeworfen, um den restlichen Tagesertrag einzuspeisen:
                            Danke dafür 👏
                              @diet99 Für rechts unten benötigst du die influxdb und Grafana. Darüber reicht der history Adapter und der Adapter für die Material Design Widget's. Links oben ist der energiefluss-erweitert adapter
                              • nograx
                                nograx Developer @lesiflo last edited by nograx
                                @lesiflo ich habe eine neue Version bereitgestellt, sollte heute Nacht ins Latest wandern, schneller per Installation von github. Die PV Inputs funktionieren dann auch wieder mit der neuen Firmware.
                                Verbrauchswerte werden da von mir auch im calculations Ordner berechnet. Das wird per eigenen Script gemacht und können von der App abweichen. Wenn es funktioniert würde ich die dann um 0 Uhr immer in einen „yesterday“ datenpunkt schieben sodass man mit einem history Adapter für eine visualisierung arbeiten kann.
                                L D 3 Replies Last reply Reply Quote 0
                                  lesiflo Most Active @nograx last edited by lesiflo
                                  @nograx Alles klar. Hab's mal installiert. Energie-Daten kommen auch rein ebenso wieder für pvPower1 und pvPower2. Sieht bisher gut aus, werde das mal bis heute Abend beobachten und dir Rückmeldung geben. Top ! Danke dafür.
                                  Es gibt ja jetzt auch Datenpunkte für die Lade/Entladezeit, die allerdings bei mir noch nicht befüllt werden. Kommt da noch was?
                                  nograx 1 Reply Last reply Reply Quote 0
                                  • nograx
                                    @lesiflo ja entladezeit sollte gehen. Ladezeit aktuell nicht - da übermittelt Zendure tatsächlich keine Daten. Da werde ich mir noch was überlegen. Die Prozentanzeige funktioniert bei mir auch überhaupt nicht, da ich die Einspeisung über die Spannung der Akkus stoppe wenn unter 46,2 Volt damit die nicht leer laufen. Dann zieht mir der Standby aber Energie aus dem Akku welcher bei der % keine Auswirkung hat. Hatte das schon so weit das er angeblich 50% hatte aber faktisch leer war… die Grenze verschiebt sich erst wieder wenn der Akku wieder voll ist.
                                      @nograx OK, für die Lade/Entladezeit habe ich mir ja schon selbst was geschrieben. Bei mir kommt das gut hin.
                                      Webranger 1 Reply Last reply Reply Quote 0
                                      • Webranger
                                        Webranger @lesiflo last edited by
                                        Ich hab im Log viele dieser meldungen!?
                                          lesiflo Most Active @Webranger last edited by
                                          @webranger Setz mal im Adapter die Protokollebene auf "error" dann werden nur noch Fehler ausgegeben.
                                            diet99 @nograx last edited by diet99
                                            @nograx Cool! Vielen Dank!
                                            Die Solareingänge zeigen wieder was an - und die Calculations werde ich ab morgen mal mit denen von @lesiflo vergleichen 👍
                                            Noch eine Frage zu den Spannungen: aktuell sieht das hier so aus:
                                            Keine Ahnung, ob das plausibel ist. Auf 100% war ich schon länger nicht mehr.
                                            1626
                                            412435
