    4. System mit Master/Slave neu aufsetzen
    • Marc Berg
      Marc Berg Most Active @Lollo_C last edited by
      @lollo_c sagte in System mit Master/Slave neu aufsetzen:
      Zeile auskommentiert, neu gestartet und keine Veränderung.
      Dann zeig jetzt nochmal das iob diag. Wenn sich da nichts geändert hat, wird die redis.conf nicht verwendet.
        Lollo_C @Marc Berg last edited by
        @marc-berg
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: RasPi4
               Icon name: computer
                  Kernel: Linux 6.1.0-rpi8-rpi-v8
            Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         11:05:30 up 7 min,  2 users,  load average: 0.61, 1.15, 0.69
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sat 2024-03-02 11:05:30 CET
                   Universal time: Sat 2024-03-02 10:05:30 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            4.0G        2.1G        882M        1.2M        1.0G        1.8G
        Swap:           104M          0B        104M
        Total:          4.1G        2.1G        987M
                 3792 M total memory
                 2029 M used memory
                 2558 M active memory
                  256 M inactive memory
                  842 M free memory
                   71 M buffer memory
                  924 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     380M  1.2M  379M   1% /run
        /dev/sda2      ext4       29G  5.4G   22G  20% /
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        /dev/sda1      vfat      510M   61M  450M  12% /boot/firmware
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Sat Mar  2 10:58:12 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A6:44:D3 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=a45a8ca6-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Sat Mar  2 10:58:14 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sat Mar  2 10:58:15 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
        TARGET           SOURCE    FSTYPE OPTIONS
        /                /dev/sda2 ext4   rw,noatime
        `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.1G    /var/
        538M    /var/cache
        524M    /var/cache/apt
        410M    /var/cache/apt/archives
        262M    /var/log
        Archived and active journals take up 260.8M in the file system.
        /opt/iobroker/backups:
        75M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        370M    /opt/iobroker/iobroker-data/
        303M    /opt/iobroker/iobroker-data/files
        57M     /opt/iobroker/iobroker-data/files/javascript.admin
        45M     /opt/iobroker/iobroker-data/files/devices.admin/static
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
        20M     /opt/iobroker/iobroker-data/objects.jsonl
        8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.1
        /usr/bin/node           v18.19.1
        /usr/bin/npm            10.2.4
        /usr/bin/npx            10.2.4
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.1-1nodesource1
          Candidate: 18.19.1-1nodesource1
          Version table:
         *** 18.19.1-1nodesource1 1001
                100 /var/lib/dpkg/status
             18.19.0+dfsg-6~deb12u1 500
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.13.16
        javascript:     7.8.0
        Adapters from github:   1
        Adapter State
        + system.adapter.admin.0                  : admin                 : RasPi4                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : RasPi4                                   -  enabled
          system.adapter.broadlink2.0             : broadlink2            : RasPi4                                   - disabled
          system.adapter.cloud.0                  : cloud                 : RasPi4                                   - disabled
          system.adapter.devices.0                : devices               : RasPi4                                   - disabled
        + system.adapter.discovery.0              : discovery             : RasPi4                                   -  enabled
          system.adapter.dwd.0                    : dwd                   : RasPi3                                   -  enabled
          system.adapter.flot.0                   : flot                  : RasPi4                                   - disabled
        + system.adapter.hm-rega.1                : hm-rega               : RasPi4                                   -  enabled
        + system.adapter.hm-rpc.2                 : hm-rpc                : RasPi4                                   -  enabled, port: 0
        + system.adapter.hm-rpc.3                 : hm-rpc                : RasPi4                                   -  enabled, port: 0
        + system.adapter.hmip.0                   : hmip                  : RasPi4                                   -  enabled
          system.adapter.ical.0                   : ical                  : RasPi3                                   -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : RasPi4                                   - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : RasPi4                                   - disabled
        + system.adapter.influxdb.0               : influxdb              : RasPi4                                   -  enabled, port: 8086
        + system.adapter.influxdb.1               : influxdb              : RasPi4                                   -  enabled, port: 8086
        + system.adapter.influxdb.2               : influxdb              : RasPi4                                   -  enabled, port: 8086
        + system.adapter.javascript.0             : javascript            : RasPi4                                   -  enabled
          system.adapter.luftdaten.0              : luftdaten             : RasPi3                                   -  enabled
          system.adapter.luftdaten.1              : luftdaten             : RasPi3                                   -  enabled
          system.adapter.luftdaten.2              : luftdaten             : RasPi3                                   -  enabled
          system.adapter.mobile.0                 : mobile                : RasPi4                                   - disabled
        + system.adapter.modbus.0                 : modbus                : RasPi4                                   -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : RasPi4                                   -  enabled, port: 1882, bind: 127.0.0.1
        + system.adapter.nut.0                    : nut                   : RasPi4                                   -  enabled
          system.adapter.openweathermap.0         : openweathermap        : RasPi3                                   -  enabled
          system.adapter.owfs.0                   : owfs                  : RasPi3                                   -  enabled, port: 4304
        + system.adapter.ping.0                   : ping                  : RasPi4                                   -  enabled
          system.adapter.pvforecast.0             : pvforecast            : RasPi3                                   -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : RasPi4                                   -  enabled
          system.adapter.rpi2.1                   : rpi2                  : RasPi3                                   -  enabled
        + system.adapter.scenes.0                 : scenes                : RasPi4                                   -  enabled
        + system.adapter.shelly.0                 : shelly                : RasPi4                                   -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : RasPi4                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.smartmeter.0             : smartmeter            : RasPi3                                   -  enabled
        + system.adapter.socketio.0               : socketio              : RasPi4                                   -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sonos.0                  : sonos                 : RasPi4                                   -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : RasPi4                                   -  enabled
        + system.adapter.telegram.0               : telegram              : RasPi4                                   -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : RasPi4                                   -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : RasPi4                                   - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : RasPi4                                   -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : RasPi4                                   - disabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : RasPi4                                   - disabled
          system.adapter.vis-material.0           : vis-material          : RasPi4                                   - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : RasPi4                                   - disabled
          system.adapter.vis-metro.0              : vis-metro             : RasPi4                                   - disabled
          system.adapter.vis-players.0            : vis-players           : RasPi4                                   - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : RasPi4                                   - disabled
          system.adapter.vis-weather.0            : vis-weather           : RasPi4                                   - disabled
          system.adapter.vis.0                    : vis                   : RasPi4                                   -  enabled
        + system.adapter.web.0                    : web                   : RasPi4                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.ws.0                     : ws                    : RasPi4                                   -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : RasPi4                                   -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
        Adapter    "hmip"         : 1.21.0   , installed 1.22.0
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "modbus"       : 6.1.0    , installed 6.1.0
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
        Objects and States
        Objects:        11484
        States:         9871
        Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 https://repos.influxdata.com/debian stable InRelease
        Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:5 https://apt.grafana.com stable InRelease
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:7 http://deb.debian.org/debian bookworm-updates InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        14726      780/influxd
        tcp        0      0 127.0.0.1:1882          0.0.0.0:*               LISTEN      1001       15228      1154/io.mqtt.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      107        13291      721/mosquitto
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       22667      1216/io.shelly.0
        tcp        0      0 192.168.2.210:42001     0.0.0.0:*               LISTEN      1001       18287      1106/io.hm-rpc.3
        tcp        0      0 192.168.2.210:42010     0.0.0.0:*               LISTEN      1001       17120      1091/io.hm-rpc.2
        tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      106        13311      699/redis-server *:
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13302      725/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       16472      852/iobroker.js-con
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       22722      1267/io.sonos.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        13908      780/influxd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       25883      1405/io.simple-api.
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       23776      1323/io.socketio.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       24397      1390/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14777      896/io.admin.0
        tcp6       0      0 :::1882                 :::*                    LISTEN      107        13292      721/mosquitto
        tcp6       0      0 :::6379                 :::*                    LISTEN      106        13312      699/redis-server *:
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13304      725/sshd: /usr/sbin
        tcp6       0      0 :::3000                 :::*                    LISTEN      108        13926      851/grafana
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13072      541/avahi-daemon: r
        udp        0      0 0.0.0.0:44362           0.0.0.0:*                           104        13074      541/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        13073      541/avahi-daemon: r
        udp6       0      0 fe80::5635:5d6e:3e1:546 :::*                                0          17493      653/NetworkManager
        udp6       0      0 :::37488                :::*                                104        13075      541/avahi-daemon: r
        2024-03-02 11:06:22.563  - warn: shelly.0 (1216) [authEnabled] 192.168.2.32 (shellyplug-s / shellyplug-s-4022D881C8A0 / SHPLG-S#4022D881C8A0#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:22.883  - info: javascript.0 (984) script.js.EIGENE_SCRIPTE.Geraete.Kuehlgeraete.Gefrierschrank_Status_v1: Status 2 | Gefrierschrank LÄUFT
        2024-03-02 11:06:23.695  - warn: shelly.0 (1216) [authEnabled] 192.168.2.37 (shellyplug-s / shellyplug-s-4022D881C855 / SHPLG-S#4022D881C855#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:23.746  - warn: shelly.0 (1216) [authEnabled] 192.168.2.33 (shellyplug-s / shellyplug-s-7A34A5 / SHPLG-S#7A34A5#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:23.752  - warn: shelly.0 (1216) [authEnabled] 192.168.2.34 (shellyplug-s / shellyplug-s-041B6E / SHPLG-S#041B6E#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:26.761  - warn: host.RasPi4 "system.host.RasPi3" is offline
        2024-03-02 11:06:26.913  - warn: host.RasPi4 "system.host.RasPi3" is offline
        2024-03-02 11:06:27.028  - warn: host.RasPi4 "system.host.RasPi3" is offline
        2024-03-02 11:06:32.598  - warn: shelly.0 (1216) [authEnabled] 192.168.2.31 (shellyplug-s / shellyplug-s-04119D / SHPLG-S#04119D#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:32.622  - warn: shelly.0 (1216) [authEnabled] 192.168.2.35 (shellyplug-s / shellyplug-s-F1AEC2 / SHPLG-S#F1AEC2#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:32.654  - warn: shelly.0 (1216) [authEnabled] 192.168.2.48 (shellyplug-s / shellyplug-s-9DCC68 / SHPLG-S#9DCC68#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:32.939  - warn: shelly.0 (1216) [authEnabled] 192.168.2.32 (shellyplug-s / shellyplug-s-4022D881C8A0 / SHPLG-S#4022D881C8A0#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:33.743  - warn: sonos.0 (1267) State "sonos.0.root.192_168_2_44.current_track_number" has no existing object, this might lead to an error in future versions
        2024-03-02 11:06:33.818  - warn: sonos.0 (1267) State "sonos.0.root.192_168_2_44.current_track_number" has no existing object, this might lead to an error in future versions
        2024-03-02 11:06:33.968  - warn: shelly.0 (1216) [authEnabled] 192.168.2.37 (shellyplug-s / shellyplug-s-4022D881C855 / SHPLG-S#4022D881C855#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:34.035  - warn: shelly.0 (1216) [authEnabled] 192.168.2.33 (shellyplug-s / shellyplug-s-7A34A5 / SHPLG-S#7A34A5#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:34.043  - warn: shelly.0 (1216) [authEnabled] 192.168.2.34 (shellyplug-s / shellyplug-s-041B6E / SHPLG-S#041B6E#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:42.709  - warn: shelly.0 (1216) [authEnabled] 192.168.2.31 (shellyplug-s / shellyplug-s-04119D / SHPLG-S#04119D#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:42.763  - warn: shelly.0 (1216) [authEnabled] 192.168.2.35 (shellyplug-s / shellyplug-s-F1AEC2 / SHPLG-S#F1AEC2#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:42.827  - warn: shelly.0 (1216) [authEnabled] 192.168.2.48 (shellyplug-s / shellyplug-s-9DCC68 / SHPLG-S#9DCC68#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:43.084  - warn: shelly.0 (1216) [authEnabled] 192.168.2.32 (shellyplug-s / shellyplug-s-4022D881C8A0 / SHPLG-S#4022D881C8A0#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:44.137  - warn: shelly.0 (1216) [authEnabled] 192.168.2.37 (shellyplug-s / shellyplug-s-4022D881C855 / SHPLG-S#4022D881C855#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:44.231  - warn: shelly.0 (1216) [authEnabled] 192.168.2.34 (shellyplug-s / shellyplug-s-041B6E / SHPLG-S#041B6E#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:44.236  - warn: shelly.0 (1216) [authEnabled] 192.168.2.33 (shellyplug-s / shellyplug-s-7A34A5 / SHPLG-S#7A34A5#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-02 11:06:47.696  - info: javascript.0 (984) script.js.EIGENE_SCRIPTE.Geraete.Kuehlgeraete.Gefrierschrank_Status_v1: Status 2 | Gefrierschrank LÄUFT
        • Marc Berg
          Marc Berg Most Active last edited by
          Das sieht jetzt eigentlich gut aus. Habe erstmal keine Idee, was da noch schief sein könnte. Die IP auf dem Slave passt ganz sicher?
            @marc-berg sagte in System mit Master/Slave neu aufsetzen:
            Im Standard hört die redis DB dann auf alle verfügbaren Interfaces.
            sicher?
            ich meine 0.0.0.0 muss explizit freigegeben werden
              @marc-berg
              Am Slave habe ich ja nichts geändert. Ich kann mit Putty auf ihn zugreifen. Die iob diag vom Slave sieht wie folgt aus:
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                 Static hostname: RasPi3
                       Icon name: computer
                Operating System: Raspbian GNU/Linux 10 (buster)
                          Kernel: Linux 5.10.103-v7+
                    Architecture: arm
              Model           : Raspberry Pi 3 Model B Plus Rev 1.3
              Docker          : false
              Kernel          : armv7l
              Userland        : armhf
               11:22:26 up 16:07,  1 user,  load average: 0.32, 0.25, 0.21
              CPU threads: 4
              Current issues:
              ~ Under-voltage has occurred
                             Local time: Sat 2024-03-02 11:22:26 CET
                         Universal time: Sat 2024-03-02 10:22:26 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:           923M        211M        262M         15M        449M        733M
              Swap:           99M        3.0M         96M
              Total:         1.0G        214M        359M
                        923 M total memory
                        211 M used memory
                        283 M active memory
                        312 M inactive memory
                        262 M free memory
                         79 M buffer memory
                        369 M swap cache
                         99 M total swap
                          3 M used swap
                         96 M free swap
              Raspberry only:
              oom events: 0
              0 loaded units listed. Pass --all to see loaded but inactive units, too.
              To show all installed unit files use 'systemctl list-unit-files'.
              *** FILESYSTEM ***
              /dev/root      ext4       15G  5.5G  8.2G  40% /
              devtmpfs       devtmpfs  430M     0  430M   0% /dev
              tmpfs          tmpfs     462M     0  462M   0% /dev/shm
              tmpfs          tmpfs     462M   18M  444M   4% /run
              tmpfs          tmpfs     462M     0  462M   0% /sys/fs/cgroup
              /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
              tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
              [Fri Mar  1 19:15:07 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
              [Fri Mar  1 19:15:10 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
              [Fri Mar  1 19:15:10 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Fri Mar  1 19:15:13 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
              /             /dev/mmcblk0p2 ext4      rw,noatime
              |-/sys/fs/bpf none           bpf       rw,nosuid,nodev,noexec,relatime,mode=700
              |-/run/owfs   OWFS           fuse.OWFS rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              `-/boot       /dev/mmcblk0p1 vfat      rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              2.6G    /var/
              2.3G    /var/cache/apt/archives
              2.3G    /var/cache/apt
              2.3G    /var/cache
              147M    /var/lib
              Archived and active journals take up 17.3M in the file system.
              169M    /opt/iobroker/backups/
              42M     /opt/iobroker/iobroker-data/
              15M     /opt/iobroker/iobroker-data/backup-objects
              8.0M    /opt/iobroker/iobroker-data/files/vis
              7.9M    /opt/iobroker/iobroker-data/files/web
              2.0M    /opt/iobroker/iobroker-data/objects.json.migrated
              2.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
              636K    /opt/iobroker/iobroker-data/backup-objects/2020-11-18_19-20_objects.json.gz
              632K    /opt/iobroker/iobroker-data/backup-objects/2020-11-18_19-28_objects.json.gz
              632K    /opt/iobroker/iobroker-data/backup-objects/2020-11-18_19-25_objects.json.gz
              USB-Devices by-id:
              /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DK0EJEOL-if00-port0
              /usr/bin/npm            10.2.4
              /usr/bin/npx            10.2.4
              nodejs:
                Version table:
               *** 18.19.1-1nodesource1 600
                      500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                   18.19.0-1nodesource1 600
                   18.18.2-1nodesource1 600
                   18.18.1-1nodesource1 600
                   18.18.0-1nodesource1 600
                   18.17.1-1nodesource1 600
                   18.17.0-1nodesource1 600
                   18.16.1-1nodesource1 600
                   18.16.0-1nodesource1 600
                   18.15.0-1nodesource1 600
                   18.14.2-1nodesource1 600
                   18.14.1-1nodesource1 600
                   18.14.0-1nodesource1 600
                   18.13.0-1nodesource1 600
                   18.12.0-1nodesource1 600
                   18.11.0-1nodesource1 600
                   18.10.0-1nodesource1 600
                   18.9.1-1nodesource1 600
                   18.9.0-1nodesource1 600
                   18.8.0-1nodesource1 600
                   18.7.0-1nodesource1 600
                   18.6.0-1nodesource1 600
                   18.5.0-1nodesource1 600
                   18.4.0-1nodesource1 600
                   18.3.0-1nodesource1 600
                   18.2.0-1nodesource1 600
                   18.1.0-1nodesource1 600
                   18.0.0-1nodesource1 600
                   10.24.0~dfsg-1~deb10u3 500
              Errors in npm tree:
              ioBroker Status
              No connection to states 192.168.2.210:6379[redis]
              admin:          6.3.5
              javascript:     "javascript" not found
              Adapters from github:   0
              Adapter State
              Objects and States
              Objects:        1
              States:         1
              W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
              W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
              W: Some index files failed to download. They have been ignored, or old ones used instead.
              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:3 http://phoscon.de/apt/deconz buster InRelease
              Get:4 https://repos.influxdata.com/debian buster InRelease [7047 B]
              Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
              Err:4 https://repos.influxdata.com/debian buster InRelease
              Fetched 7047 B in 2s (4327 B/s)
              Pending Updates: 2
              tcp        0      0 0.0.0.0:2120            0.0.0.0:*               LISTEN      109        15414      327/owftpd
              tcp        0      0 0.0.0.0:2121            0.0.0.0:*               LISTEN      109        16506      456/owhttpd
              tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          15896      637/node
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15836      642/sshd
              tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16526      409/influxd
              tcp6       0      0 :::3500                 :::*                    LISTEN      0          15898      637/node
              tcp6       0      0 :::4304                 :::*                    LISTEN      0          13594      1/init
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        16006      409/influxd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          15846      642/sshd
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14849      635/dhcpcd
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14734      346/avahi-daemon: r
              udp        0      0 0.0.0.0:42936           0.0.0.0:*                           108        14736      346/avahi-daemon: r
              udp6       0      0 :::45220                :::*                                108        14737      346/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        14735      346/avahi-daemon: r
              udp6       0      0 :::546                  :::*                                0          14993      635/dhcpcd
              2024-03-02 11:22:20.955  - info: host.RasPi3 iobroker _restart
              2024-03-02 11:22:29.592  - info: host.RasPi3 iobroker.js-controller version 5.0.19 js-controller starting
              2024-03-02 11:22:29.605  - info: host.RasPi3 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
              2024-03-02 11:22:29.607  - info: host.RasPi3 hostname: RasPi3, node: v18.19.1
              2024-03-02 11:22:29.609  - info: host.RasPi3 ip addresses: 192.168.2.30 2003:e0:9712:9a00:bee:e5c2:b6b8:6aad fe80::df32:ad2b:5f7d:3ca
              2024-03-02 11:22:59.685  - error: host.RasPi3 No connection to databases possible, restart
              2024-03-02 11:22:59.699  - info: host.RasPi3 iobroker _restart
              2024-03-02 11:23:07.999  - info: host.RasPi3 iobroker.js-controller version 5.0.19 js-controller starting
              2024-03-02 11:23:08.011  - info: host.RasPi3 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
              2024-03-02 11:23:08.013  - info: host.RasPi3 hostname: RasPi3, node: v18.19.1
              2024-03-02 11:23:08.016  - info: host.RasPi3 ip addresses: 192.168.2.30 2003:e0:9712:9a00:bee:e5c2:b6b8:6aad fe80::df32:ad2b:5f7d:3ca
              2024-03-02 11:23:38.096  - error: host.RasPi3 No connection to databases possible, restart
              2024-03-02 11:23:38.123  - info: host.RasPi3 iobroker _restart
              2024-03-02 11:23:46.193  - info: host.RasPi3 iobroker.js-controller version 5.0.19 js-controller starting
              2024-03-02 11:23:46.207  - info: host.RasPi3 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
              2024-03-02 11:23:46.210  - info: host.RasPi3 hostname: RasPi3, node: v18.19.1
              2024-03-02 11:23:46.212  - info: host.RasPi3 ip addresses: 192.168.2.30 2003:e0:9712:9a00:bee:e5c2:b6b8:6aad fe80::df32:ad2b:5f7d:3ca
              2024-03-02 11:24:16.265  - error: host.RasPi3 No connection to databases possible, restart
              2024-03-02 11:24:16.280  - info: host.RasPi3 iobroker _restart
              2024-03-02 11:24:24.292  - info: host.RasPi3 iobroker.js-controller version 5.0.19 js-controller starting
              2024-03-02 11:24:24.302  - info: host.RasPi3 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
              2024-03-02 11:24:24.304  - info: host.RasPi3 hostname: RasPi3, node: v18.19.1
              2024-03-02 11:24:24.305  - info: host.RasPi3 ip addresses: 192.168.2.30 2003:e0:9712:9a00:bee:e5c2:b6b8:6aad fe80::df32:ad2b:5f7d:3ca
              2024-03-02 11:24:54.355  - error: host.RasPi3 No connection to databases possible, restart
              2024-03-02 11:24:54.369  - info: host.RasPi3 iobroker _restart
                Homoran Global Moderator Administrators @Lollo_C last edited by Homoran
                mach da mal iob setup custom und prüfe/korrigiere die Parameter
                laut Konfiguration im ersten Post hast du jsonl eingestellt
                EDIT
                SORRY, war Blödsinn
                  Lollo_C @Homoran last edited by
                  Bevor ich das mache: wären das die richtigen Parameter, oder muss ich bei Host auf states die des Master angeben?
                  Type of objects DB [file, couch, redis], default [jsonl]: ENTER
                  Host of objects DB(file), default[127.0.0.1]: <0.0.0.0>
                  Port of objects DB(file), default[9001]: ENTER
                  Type of states DB [file, redis], default [redis]: ENTER
                  Host of states DB (file), default[0.0.0.0]: ENTER
                  Port of states DB (file), default[6379]: ENTER
                  Host name of this machine [RasPi3]: ENTER
                    @lollo_c Dein slave soll doch auf die Redis des Masters zugreifen
                    (wieso überhaupt redis?)
                    dann muss hier (beim Slave) auch die IP des Masters rein.
                    bei den objects mit JSONL bin ich mir da nicht sicher
                      Warum redis: weil irgendwann mal gesagt wurde, dann läuft der iobroker schneller. (Sorry, aber ich habe mein Wissen meist von YT). Egal: ich habe beim Slave kontrolliert:
                      Current configuration:
                      - Objects database:
                        - Type: jsonl
                        - Host/Unix Socket: 192.168.2.210
                        - Port: 9001
                      - States database:
                        - Type: redis
                        - Port: 6379
                      - Data Directory: ../../iobroker-data/
                      Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
                      Host / Unix Socket of objects DB(jsonl), default[192.168.2.210]:
                      Port of objects DB(jsonl), default[9001]:
                      Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [jsonl]: r
                      Host / Unix Socket of states DB (redis), default[192.168.2.210]:
                      Port of states DB (redis), default[6379]:
                      updating conf/iobroker.json
                      Sieht für mich erst einmal i.O. aus, oder?
                        ja, bei Raspberry v1/2 und ähnlichen.
                        und läuft's jetzt?
                          Lollo_C @Homoran last edited by Lollo_C
                          @homoran sagte in System mit Master/Slave neu aufsetzen:
                          und läuft's jetzt?
                          nein, leider nicht.
                            und läuft's jetzt?
                            nein, leider nicht.
                            dann bitte nochmal auf dem Master in der redis.conf explizit die 0.0.0.0 freigeben (über bind)
                            wenn das auch nicht hilft, Master und slave neu starten (ggf. 2x im Wechsel)
                              Ich glaube, jetzt habe ich was falsch eingegeben. In der redis.config:
                              bind 127.0.0.1 0.0.0.0
                              Beim "sudo service redis-server restart" kommt Fehlermeldung
                              Job for redis-server.service failed because the control process exited with error code.
                              See "systemctl status redis-server.service" and "journalctl -xeu redis-server.service" for details.
                              • Marc Berg
                                Marc Berg Most Active @Lollo_C last edited by Marc Berg
                                Das geht so nicht. Wenn, dann musst du
                                bind  0.0.0.0
                                eingeben. Aber wie oben bereits erwähnt, ist es das gleiche, als wenn du gar nichts konfigurierst. Und man hat ja schon gesehen, dass es funktionierte:
                                • Marc Berg
                                  Hast du
                                  protected-mode no
                                  in der redis.conf eingestellt?
                                  L Homoran 3 Replies Last reply Reply Quote 1
                                    Hast du
                                    protected-mode no
                                    Nein, steht auf YES
                                      Hast du
                                      protected-mode no
                                      DAS WAR ES! Vielen Dank, jetzt ist der Slave da.
                                        Lollo_C @Lollo_C last edited by
                                        @lollo_c
                                        Ich benötige doch noch einmal Hilfe. Master und Slave laufen nun. Im #tab-instances sind alle (bis auf die ws.0) Instanzen grün. Es werden auch Daten in die Objekte geschrieben. Wenn ich die Einstellungen der Instanzen auf dem Slave öffnen möchte, dann bleibt die Seite weiß und es erscheint eine Meldung
                                        [JsonConfig] Cannot read file: Not exists
                                        Bei den Protokollen werden jede Menge Warnungen zu Instanzen vom Slave angezeigt.
                                          Homoran Global Moderator Administrators @Marc Berg last edited by
                                          Hast du
                                          protected-mode no
                                          ist das neu(er)?
                                          und deswegen jetzt 0.0.0.0 als default?
                                            A Former User @Lollo_C last edited by
                                            @lollo_c
                                            Mach mal ein
                                            bind 0.0.0.0
                                            Anstatt des localhosts…
                                            1878
