    4. Hilfe! Nach Update des javascript Adapters 404
      Mika 0 @Thomas Braun last edited by Mika 0
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: Pi400
             Icon name: computer
      Operating System: Raspbian GNU/Linux 12 (bookworm)
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 400 Rev 1.0
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : armhf
      Systemuptime and Load:
       20:45:21 up 8 min,  4 users,  load average: 1.68, 2.41, 1.50
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sat 2024-03-02 20:45:22 CET
                 Universal time: Sat 2024-03-02 19:45:22 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      iobroker
      /home/iobroker
      iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth lpadmin redis gpio i
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        2.0G        1.0G         61M        1.1G        2.0G
      Swap:           104M          0B        104M
      Total:          4.1G        2.0G        1.1G
               3792 M total memory
               1929 M used memory
               2094 M active memory
                458 M inactive memory
                956 M free memory
                 90 M buffer memory
                949 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
      * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
      * rc-local.service      loaded failed failed /etc/rc.local Compatibility
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  7.2M  373M   2% /run
      /dev/sda2      ext4       35G   11G   23G  32% /
      tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
      tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
      /dev/sda3      ext4       75G   25G   46G  35% /home/iobroker/Kamera
      /dev/sda1      vfat      510M  113M  398M  23% /boot/firmware
      log2ram        tmpfs      50M   18M   33M  35% /var/log
      tmpfs          tmpfs     380M   56K  380M   1% /run/user/1000
      [Sat Mar  2 20:36:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:16:A9:81 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff0000115200 console=tty1 root=PARTUUID=a6c93f24-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-se80211.ieee80211_regdom=DE
      [Sat Mar  2 20:36:41 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Mar  2 20:36:43 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      [Sat Mar  2 20:36:46 2024] EXT4-fs (sda3): recovery complete
      [Sat Mar  2 20:36:46 2024] EXT4-fs (sda3): mounted filesystem with ordered data mode. Quota mode: none.
      TARGET                  SOURCE              FSTYPE OPTIONS
      /                       /dev/sda2           ext4   rw,noatime
      |-/home/iobroker/Kamera /dev/sda3           ext4   rw,noatime
      |-/boot/firmware        /dev/sda1           vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shors=remount-ro
      `-/var/log.bak          /dev/sda2[/var/log] ext4   rw,noatime
      /var:
      2.9G    /var/
      2.3G    /var/opt/emoncms
      2.3G    /var/opt
      2.0G    /var/opt/emoncms/phpfina
      272M    /var/lib
      Archived and active journals take up 4.7M in the file system.
      /opt/iobroker/backups:
      29M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      902M    /opt/iobroker/iobroker-data/
      693M    /opt/iobroker/iobroker-data/files
      143M    /opt/iobroker/iobroker-data/backup-objects
      138M    /opt/iobroker/iobroker-data/files/vis-2
      78M     /opt/iobroker/iobroker-data/files/vis-2/static
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      38M     /opt/iobroker/iobroker-data/objects.jsonl
      36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      20M     /opt/iobroker/iobroker-data/files/s7.admin/static/js/main.4fb08967.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-VictronEnergy_BV_VE_Direct_cable_VE4X89GM-if00-port0
      /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.1-1nodesource1
        Version table:
           18.19.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           18.19.0+dfsg-6~deb12u1+rpi1 500
              500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
       *** 18.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : Pi400                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : Pi400                                    - disabled
        system.adapter.alias-manager.0          : alias-manager         : Pi400                                    - disabled
        system.adapter.asterisk.0               : asterisk              : Pi400                                    - disabled, port: 5038
        system.adapter.awattar.0                : awattar               : Pi400                                    -  enabled
      + system.adapter.backitup.0               : backitup              : Pi400                                    -  enabled
        system.adapter.countdown.0              : countdown             : Pi400                                    - disabled
      + system.adapter.daikin-cloud.0           : daikin-cloud          : Pi400                                    -  enabled
        system.adapter.daswetter.0              : daswetter             : Pi400                                    -  enabled
      + system.adapter.discovery.0              : discovery             : Pi400                                    -  enabled
        system.adapter.dwd.0                    : dwd                   : Pi400                                    -  enabled
      + system.adapter.enigma2.0                : enigma2               : Pi400                                    -  enabled
      + system.adapter.enigma2.1                : enigma2               : Pi400                                    -  enabled
        system.adapter.feiertage.0              : feiertage             : Pi400                                    -  enabled
      + system.adapter.harmony.0                : harmony               : Pi400                                    -  enabled
      + system.adapter.history.0                : history               : Pi400                                    -  enabled
        system.adapter.ical.0                   : ical                  : Pi400                                    -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: Pi400                                    - disabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : Pi400                                    - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : Pi400                                    - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : Pi400                                    - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : Pi400                                    - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Pi400                                    - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Pi400                                    - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Pi400                                    - disabled
      + system.adapter.info.0                   : info                  : Pi400                                    -  enabled
      + system.adapter.jarvis.0                 : jarvis                : Pi400                                    -  enabled
        system.adapter.javascript.0             : javascript            : Pi400                                    - disabled
        system.adapter.material.0               : material              : Pi400                                    - disabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : Pi400                                    -  enabled, port: 54321
      + system.adapter.mqtt.0                   : mqtt                  : Pi400                                    -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : Pi400                                    -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.pollenflug.0             : pollenflug            : Pi400                                    -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : Pi400                                    -  enabled
      + system.adapter.s7.0                     : s7                    : Pi400                                    -  enabled
      + system.adapter.s7.1                     : s7                    : Pi400                                    -  enabled
      + system.adapter.s7.2                     : s7                    : Pi400                                    -  enabled
      + system.adapter.scheduler.0              : scheduler             : Pi400                                    -  enabled
        system.adapter.shuttercontrol.0         : shuttercontrol        : Pi400                                    - disabled
        system.adapter.solarwetter.0            : solarwetter           : Pi400                                    -  enabled
        system.adapter.telegram-menu.0          : telegram-menu         : Pi400                                    - disabled
      + system.adapter.telegram.0               : telegram              : Pi400                                    -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : Pi400                                    -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      + system.adapter.text2command.0           : text2command          : Pi400                                    -  enabled
        system.adapter.tibberlink.0             : tibberlink            : Pi400                                    - disabled
        system.adapter.time-switch.0            : time-switch           : Pi400                                    - disabled
      + system.adapter.tr-064.0                 : tr-064                : Pi400                                    -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : Pi400                                    -  enabled
        system.adapter.vis-2.0                  : vis-2                 : Pi400                                    - disabled
        system.adapter.vis-bars.0               : vis-bars              : Pi400                                    - disabled
        system.adapter.vis-history.0            : vis-history           : Pi400                                    - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Pi400                                    - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : Pi400                                    -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Pi400                                    - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : Pi400                                    - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : Pi400                                    - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : Pi400                                    - disabled
        system.adapter.vis-metro.0              : vis-metro             : Pi400                                    - disabled
        system.adapter.vis-players.0            : vis-players           : Pi400                                    - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : Pi400                                    - disabled
        system.adapter.vis-weather.0            : vis-weather           : Pi400                                    - disabled
        system.adapter.vis.0                    : vis                   : Pi400                                    -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : Pi400                                    -  enabled
      + system.adapter.web.0                    : web                   : Pi400                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.web.1                    : web                   : Pi400                                    -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
      Adapter    "awattar"      : 1.0.6    , installed 1.0.6
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "countdown"    : 2.2.0    , installed 2.2.0
      Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.1
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
      Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "harmony"      : 1.3.0    , installed 1.3.0
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "node-red"     : 5.1.0    , installed 5.1.0
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
      Adapter    "s7"           : 1.4.2    , installed 1.4.2
      Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
      Adapter    "shuttercontrol": 1.7.0   , installed 1.6.3  [Updatable]
      Adapter    "solarwetter"  : 1.1.5    , installed 1.1.5
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram-menu": 1.5.1    , installed 1.5.1
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tibberlink"   : 2.2.2    , installed 2.0.1  [Updatable]
      Adapter    "trashschedule": 3.2.0    , installed 3.2.0
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.11 [Updatable]
      Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Objects and States
      Objects:        21646
      States:         18855
      W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
      Hit:2 https://linux.teamviewer.com/deb stable InRelease
      Hit:3 https://packages.sury.org/php bookworm InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 138
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:45227           0.0.0.0:*               LISTEN      102        21713      1387/rpc.statd
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          23637      1681/smbd
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       43540      3120/io.jarvis.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19594      880/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      115        22755      1465/proftpd: (acce
      tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          22720      -
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11382      1/init
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          23636      1681/smbd
      tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          21933      1397/teamviewerd
      tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      112        18149      997/mariadbd
      tcp        0      0 0.0.0.0:39707           0.0.0.0:*               LISTEN      0          20272      -
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18803      823/cupsd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       22851      923/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       22909      923/iobroker.js-con
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      113        18858      830/redis-server 12
      tcp        0      0 0.0.0.0:42935           0.0.0.0:*               LISTEN      0          22633      1393/rpc.mountd
      tcp        0      0 0.0.0.0:44969           0.0.0.0:*               LISTEN      0          22675      1393/rpc.mountd
      tcp        0      0 0.0.0.0:51113           0.0.0.0:*               LISTEN      0          22654      1393/rpc.mountd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        17991      889/mosquitto
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       24573      2463/node-red
      tcp6       0      0 :::139                  :::*                    LISTEN      0          23635      1681/smbd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          19607      880/sshd: /usr/sbin
      tcp6       0      0 :::2049                 :::*                    LISTEN      0          22724      -
      tcp6       0      0 :::111                  :::*                    LISTEN      0          11383      1/init
      tcp6       0      0 :::80                   :::*                    LISTEN      0          18842      915/apache2
      tcp6       0      0 :::445                  :::*                    LISTEN      0          23634      1681/smbd
      tcp6       0      0 :::47383                :::*                    LISTEN      0          22666      1393/rpc.mountd
      tcp6       0      0 :::61991                :::*                    LISTEN      1000       48050      3205/io.harmony.0
      tcp6       0      0 :::37815                :::*                    LISTEN      0          20274      -
      tcp6       0      0 :::37857                :::*                    LISTEN      102        21717      1387/rpc.statd
      tcp6       0      0 :::58325                :::*                    LISTEN      0          22639      1393/rpc.mountd
      tcp6       0      0 ::1:6379                :::*                    LISTEN      113        18859      830/redis-server 12
      tcp6       0      0 :::44397                :::*                    LISTEN      0          22683      1393/rpc.mountd
      tcp6       0      0 :::8083                 :::*                    LISTEN      1000       67764      3735/io.web.1
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       40827      2996/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       25990      2291/io.admin.0
      tcp6       0      0 :::8088                 :::*                    LISTEN      1000       57699      3361/io.terminal.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18802      823/cupsd
      tcp6       0      0 :::1883                 :::*                    LISTEN      114        17992      889/mosquitto
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1017       1/init
      udp        0      0 192.168.2.255:137       0.0.0.0:*                           0          20479      1460/nmbd
      udp        0      0 192.168.2.4:137         0.0.0.0:*                           0          20478      1460/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          20304      1460/nmbd
      udp        0      0 192.168.2.255:138       0.0.0.0:*                           0          23553      1460/nmbd
      udp        0      0 192.168.2.4:138         0.0.0.0:*                           0          20480      1460/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          20305      1460/nmbd
      udp        0      0 0.0.0.0:47259           0.0.0.0:*                           102        21711      1387/rpc.statd
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       51809      3285/io.mihome-vacu
      udp        0      0 0.0.0.0:41153           0.0.0.0:*                           0          20271      -
      udp        0      0 0.0.0.0:57605           0.0.0.0:*                           104        12131      666/avahi-daemon: r
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       48051      3205/io.harmony.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          20877      1369/cups-browsed
      udp        0      0 127.0.0.1:715           0.0.0.0:*                           0          21707      1387/rpc.statd
      udp        0      0 0.0.0.0:56328           0.0.0.0:*                           0          22651      1393/rpc.mountd
      udp        0      0 0.0.0.0:50270           0.0.0.0:*                           0          22621      1393/rpc.mountd
      udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1000       36455      2499/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        12129      666/avahi-daemon: r
      udp        0      0 0.0.0.0:38825           0.0.0.0:*                           0          22672      1393/rpc.mountd
      udp6       0      0 :::111                  :::*                                0          1018       1/init
      udp6       0      0 :::47311                :::*                                0          22636      1393/rpc.mountd
      udp6       0      0 fe80::b6b0:25d8:733:546 :::*                                0          22951      797/NetworkManager
      udp6       0      0 :::43885                :::*                                0          20273      -
      udp6       0      0 :::37921                :::*                                104        12132      666/avahi-daemon: r
      udp6       0      0 :::44220                :::*                                0          22657      1393/rpc.mountd
      udp6       0      0 :::5353                 :::*                                104        12130      666/avahi-daemon: r
      udp6       0      0 :::54863                :::*                                102        21715      1387/rpc.statd
      udp6       0      0 :::47056                :::*                                0          22678      1393/rpc.mountd
      2024-03-02 20:46:39.096  - info: node-red.0 (2463) State value to set for "node-red.0.solpiplog2.pip.acin" has to be type "string" but received type "number"
      2024-03-02 20:46:39.106  - warn: node-red.0 (2463) Read-only state "node-red.0.solpiplog2.pip.acoutw" has been written without ack-flag with value "1096"
      2024-03-02 20:46:39.875  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:39 - [info] [rpi-gpio out:Relay Heizung Stufe Poti GPIO27-13] out: 1
      2024-03-02 20:46:39.877  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:39 - [info] [rpi-gpio out:Relay GPIO05-29] out: 1
      2024-03-02 20:46:39.881  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:39 - [info] [rpi-gpio out:Relay GPIO05-29] out: 1
      2024-03-02 20:46:40.076  - info: node-red.0 (2463) State value to set for "node-red.0.solpiplog.pip.acin" has to be type "string" but received type "number"
      2024-03-02 20:46:40.082  - warn: node-red.0 (2463) Read-only state "node-red.0.solpiplog.pip.acoutw" has been written without ack-flag with value "1122"
      2024-03-02 20:46:44.096  - info: node-red.0 (2463) State value to set for "node-red.0.solpiplog2.pip.acin" has to be type "string" but received type "number"
      2024-03-02 20:46:44.101  - warn: node-red.0 (2463) Read-only state "node-red.0.solpiplog2.pip.acoutw" has been written without ack-flag with value "1110"
      2024-03-02 20:46:44.537  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:44 - [info] [rpi-gpio out:GPIO06 - Pin 31 Ansteuerung Zusatzrelais Lüfter (hinter Pi)] out: 0
      2024-03-02 20:46:44.878  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:44 - [info] [rpi-gpio out:Relay Heizung Stufe Poti GPIO27-13] out: 1
      2024-03-02 20:46:44.883  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:44 - [info] [rpi-gpio out:Relay GPIO05-29] out: 1
      2024-03-02 20:46:44.889  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:44 - [info] [rpi-gpio out:Relay GPIO05-29] out: 1
      2024-03-02 20:46:44.967  - info: node-red.0 (2463) State value to set for "node-red.0.solpiplog.pip.acin" has to be type "string" but received type "number"
      2024-03-02 20:46:45.045  - warn: node-red.0 (2463) Read-only state "node-red.0.solpiplog.pip.acoutw" has been written without ack-flag with value "1133"
      2024-03-02 20:46:49.114  - info: node-red.0 (2463) State value to set for "node-red.0.solpiplog2.pip.acin" has to be type "string" but received type "number"
      2024-03-02 20:46:49.168  - warn: node-red.0 (2463) Read-only state "node-red.0.solpiplog2.pip.acoutw" has been written without ack-flag with value "1138"
      2024-03-02 20:46:49.889  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:49 - [info] [rpi-gpio out:Relay Heizung Stufe Poti GPIO27-13] out: 1
      2024-03-02 20:46:49.892  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:49 - [info] [rpi-gpio out:Relay GPIO05-29] out: 1
      2024-03-02 20:46:49.895  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:49 - [info] [rpi-gpio out:Relay GPIO05-29] out: 1
      2024-03-02 20:46:49.941  - info: node-red.0 (2463) State value to set for "node-red.0.solpiplog.pip.acin" has to be type "string" but received type "number"
      2024-03-02 20:46:49.953  - warn: node-red.0 (2463) Read-only state "node-red.0.solpiplog.pip.acoutw" has been written without ack-flag with value "1148"
      2024-03-02 20:46:54.068  - info: node-red.0 (2463) State value to set for "node-red.0.solpiplog2.pip.acin" has to be type "string" but received type "number"
      2024-03-02 20:46:54.070  - warn: node-red.0 (2463) Read-only state "node-red.0.solpiplog2.pip.acoutw" has been written without ack-flag with value "1144"
      2024-03-02 20:46:54.548  - info: node-red.0 (2369) Node-RED: 2 Mar 20:46:54 - [info] [rpi-gpio out:GPIO06 - Pin 31 Ansteuerung Zusatzrelais Lüfter (hinter Pi)] out: 0
      iob diag has finished.
      Copy text starting here:
                              v.2023-10-10
             Icon name: computer
          Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               armhf
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               true
      Boot Target:            graphical.target
      Pending OS-Updates:     138
      Pending iob updates:    3
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
      Recommended versions are nodejs 18.19.1 and npm 10.2.4
      MEMORY:
      Mem:            4.0G        2.0G        1.2G         63M        912M        2.0G
      Swap:           104M          0B        104M
      Total:          4.1G        2.0G        1.4G
      Active iob-Instances:   28
      ioBroker Core:          js-controller           5.0.19
                              admin                   6.13.16
      Objects type: jsonl
      States  type: jsonl
      Objects:                21646
      States:                 18855
      Size of iob-Database:
      11M     /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      Nachdem ich Javaspript Instanz aktiviert habe, ist Ram voll gelaufen und Swap Partition auch voll gelaufen. Leider konnte ich nicht mehr stoppen und der Pi ist abgeschmiert. 20 min warten oder Stromversorgung trennen. Ich muss nach Restart gleich wieder die Java Insanz stoppen.
        Thomas Braun Most Active @Mika 0 last edited by Thomas Braun
        @mika-0 sagte in Hilfe! Nach Java Update Skripte 404:
        Kernel: aarch64 Userland: armhf
        Installier das Betriebssystem NEU als reine 64Bit-Version in der Lite-Variante, ohne Desktop und dem TeamViewer-Quark.
        Hau die 138 Updates für das OS rein und die 3 iob-Updates.
          @thomas-braun Ähhhh das geht nicht. Ich habe PV 32bit Programme die eine Desktop Oberfläche benötigen. Um gelegentlich diese PV Programme remote bedienen zu können war früher VNC drauf. Das geht aber nicht bei Bookworm mit 32bit. Daher Teamviewer drauf.
          ging das Java schief? Kann ich was machen damit ich das System retten kann?
          Aufsetzen auf gleichem Stand vor Update wäre möglich, aber aufwändig
            Falsches Setup...
              @thomas-braun Da gibt es leider kein Setup was ich auswählen könnte. Die laufen halt nur auf ner GUI. Die ganze Zeit lief es ja auch stabil. Bis nach dem Update vorhin. Sorry, aber ich bin kein Experte, sonst würde ich hier nicht fragen. Daher nochmal. Kann ich das aktuelle System retten und wenn ja mit welchen Befehlen?
                @mika-0
                Und die beiden ominösen Programme verhindern auch, das du die Kiste auf einem aktuellen Stand hältst?
                Da zuerst ran.
                Offenbar nicht. Dann würdest du nämlich nicht so ein strubbeliges System fahren.
                  @thomas-braun Also die OS Updates laufen. Währenddessen.... Was wäre denn aus deiner Sicht ein besseres "Setup"? Lieber die PV Programme auf einem kleinen Pi laufen und iobroker auf dem anderen der direkt neben dran liegt?
                  Mir war die Reihenfolge nicht bekannt, erst OS Updates, dann iobroker Updates. Kann ich aber gerne in Zukunft so machen.
                  Gibt es denn eine zeitliche Regel, nach den OS Updates zu suchen? Täglich, weekly?
                  Edit: Von der Leistung des Pi 4 bin ich absolut zufrieden. Da gab es bisher nie irgend eine Performancelücke
                  Thomas Braun mrbungle64 2 Replies Last reply Reply Quote 0
                    wie oben bereits gesagt: Reines 64Bit-System ohne Desktop-Geraffel.
                    Wurscht, hauptsache regelmäßig. So alle 2 Wochen.
                    • mrbungle64
                      mrbungle64 Developer @Mika 0 last edited by
                      @mika-0
                      Man erhöht grundsätzlich die Wahrscheinlichkeit auf ein stabiles ioBroker-System, wenn es ein dediziertes System für den ioBroker ist - ohne weitere Software nebenbei (auch wenn es die Performance hergeben würde).
                      Auf einem dedizierten ioBroker-System läuft dann eben auch keine Desktop-Umgebung.
                      Btw.: ändere bitte mal den Betreff auf "Nach Update des javascript Adapters 404".
                      Java ist beim ioBroker nämlich irrelevant.
                        Mika 0 @mrbungle64 last edited by Mika 0
                        @mrbungle64 Auch dir Danke für den Input. Muss ich schauen wie ich das HW seitig umsetzen kann. Gerne ändern ich den Betreff, aber wo ist da ein Bearbeiten Button?
                        & an @Thomas-Braun
                        OS Updates sind drauf. Der RAM läuft immer noch voll. Kann es sein, dass durch das Update ein Skript schuld sein könnte? Kann man das herausfinden welches es sein könnte?
                        Edit: Thread Titel ändern geschafft. 😉
                          Mika 0 @Mika 0 last edited by
                          Wäre folgender Vorschlag eine bessere Vorgehensweise mit iobroker:
                          iobroker auf SSD am Pi 4 mit Bookworm 64bit ohne GUI und steuert auch GPIO Pins
                          PV Programme auf SSD am Pi 3 mit Bookworm / Bullseye 32bit und GUI
                          Und wo sollte ich dann die Datalogger Grafana / Emoncms laufen lassen? Daten kommen aber von beiden Pi´s
                            Mika 0 @Mika 0 last edited by Mika 0
                            Leider kam zu meinem Vorschlag zu einer richtigen Umsetzung kein Vorschlag. Also habe ich es so umgesetzt.
                            ioBroker ist nun auf einem ganz frischen Raspberry Pi 4 Bookworm 64 bit lite aufgesetzt. Kein Desktop, keiner weiteren Programme.
                            Ich habe ein älteres backup restored. Zack RAM vollgelaufen und der Pi hat sich aufgehängt.
                            Ich bin nun trotz Aufwand der letzten Tage keinen Schritt weiter.
                            @mrbungle64 @Thomas-Braun oder andere Experten. Wer kann mir bitte helfen?
                              @mika-0 sagte in Hilfe! Nach Update des javascript Adapters 404:
                              Da wirst du selber ran müssen. Wird wohl ein Skript sein, das da ausflippt.
                                @thomas-braun OK Danke, auf die Idee bin ich auch schon gekommen und deaktiviere alle. Dann wird nach und nach zugeschaltet.
                                Wenigstens ist der iobroker nun separat zu den PV Programmen, was ja definitiv nicht schaden kann 😉 Melde mich wenn ich Erfolg hatte.
                                  @thomas-braun Also ich habe den info adapter ausfindig gemacht. Seit dem ich den deaktiviert habe, kam der RAM Überlauf nicht mehr. Habe ich deinstalliert.
                                  Nun kam vom Javaskript die Update Meldung
                                  Das ging ca, 5 min gut, dann kam es während dem Update zum Überlauf und schlussendlich zum Crash.
                                  Alle anderen Adapter sind aktuell.
                                  Kann man aus dem bisschen Text etwas heraus lesen an was das liegen könnte?
                                    @mika-0
                                    iob diag
                                    anschauen.
                                      @thomas-braun ```
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                       Static hostname: iobroker
                                             Icon name: computer
                                                Kernel: Linux 6.1.0-rpi8-rpi-v8
                                          Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : arm64
                                       22:16:22 up 6 min,  2 users,  load average: 4.49, 3.59, 1.69
                                      CPU threads: 4
                                      Current issues:
                                      ~ Under-voltage detected
                                      ~ Arm frequency capped
                                      ~ Under-voltage has occurred
                                      ~ Arm frequency capping has occurred
                                                     Local time: Thu 2024-03-07 22:16:22 CET
                                                 Universal time: Thu 2024-03-07 21:16:22 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      iobroker
                                      /home/iobroker
                                      iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      Boot Target:    multi-user.target
                                      *** MEMORY ***
                                      Mem:            4.0G        2.4G        903M        1.2M        731M        1.6G
                                      Swap:           104M          0B        104M
                                      Total:          4.1G        2.4G        1.0G
                                               3792 M total memory
                                               2310 M used memory
                                               2347 M active memory
                                                434 M inactive memory
                                                860 M free memory
                                                 70 M buffer memory
                                                627 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      0 loaded units listed.
                                      *** FILESYSTEM ***
                                      tmpfs          tmpfs     380M  1.2M  379M   1% /run
                                      /dev/sda2      ext4      110G  5.4G   99G   6% /
                                      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                      /dev/sda1      vfat      510M   61M  450M  12% /boot/firmware
                                      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                      [sudo] password for iobroker:
                                      [Thu Mar  7 22:09:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:16:A9:81 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=8488418b-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                                      [Thu Mar  7 22:10:00 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Thu Mar  7 22:10:01 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      /var:
                                      523M    /var/
                                      202M    /var/cache
                                      197M    /var/cache/apt
                                      164M    /var/lib
                                      132M    /var/lib/apt/lists
                                      Archived and active journals take up 55.6M in the file system.
                                      808M    /opt/iobroker/iobroker-data/
                                      730M    /opt/iobroker/iobroker-data/files
                                      142M    /opt/iobroker/iobroker-data/files/vis-2
                                      81M     /opt/iobroker/iobroker-data/files/vis-2/static
                                      80M     /opt/iobroker/iobroker-data/files/vis-2/static/js
                                      51M     /opt/iobroker/iobroker-data/objects.jsonl
                                      21M     /opt/iobroker/iobroker-data/states.jsonl
                                      USB-Devices by-id:
                                      /usr/bin/nodejs         v18.19.1
                                      /usr/bin/node           v18.19.1
                                      /usr/bin/npm            10.2.4
                                      /usr/bin/npx            10.2.4
                                      nodejs:
                                        Installed: 18.19.1-1nodesource1
                                        Version table:
                                       *** 18.19.1-1nodesource1 1001
                                           18.19.0+dfsg-6~deb12u1 500
                                           18.13.0+dfsg1-1 500
                                      Errors in npm tree:
                                      npm ERR! code ELSPROBLEMS
                                      npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                                      npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                                      npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                                      npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
                                      npm ERR! extraneous: jsonata@2.0.4 /opt/iobroker/node_modules/jsonata
                                      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                      npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                                      npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                                      npm ERR! extraneous: typescript@5.3.3 /opt/iobroker/node_modules/typescript
                                      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                                      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                      npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
                                      npm ERR! extraneous: @types/iobroker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker
                                      npm ERR! extraneous: @types/linkify-it@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/linkify-it
                                      npm ERR! extraneous: @types/mdurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/mdurl
                                      npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
                                      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
                                      npm ERR! invalid: asynckit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit
                                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-07T21_16_55_302Z-debug-0.log
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.13.16
                                      javascript:     7.8.0
                                      Adapters from github:   0
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
                                        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                                        system.adapter.asterisk.0               : asterisk              : iobroker                                 - disabled, port: 5038
                                        system.adapter.awattar.0                : awattar               : iobroker                                 - disabled
                                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                        system.adapter.countdown.0              : countdown             : iobroker                                 - disabled
                                        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                                        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                      + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
                                      + system.adapter.enigma2.1                : enigma2               : iobroker                                 -  enabled
                                        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                                      + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
                                        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
                                        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                                        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
                                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                                        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                                        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
                                      + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                        system.adapter.material.0               : material              : iobroker                                 - disabled
                                      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                                      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                                      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                      + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
                                      + system.adapter.s7.1                     : s7                    : iobroker                                 -  enabled
                                      + system.adapter.s7.2                     : s7                    : iobroker                                 -  enabled
                                        system.adapter.scheduler.0              : scheduler             : iobroker                                 - disabled
                                        system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled
                                        system.adapter.solarwetter.0            : solarwetter           : iobroker                                 -  enabled
                                        system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled
                                      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                        system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                                      + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                                        system.adapter.tibberlink.0             : tibberlink            : iobroker                                 - disabled
                                        system.adapter.time-switch.0            : time-switch           : iobroker                                 - disabled
                                      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                        system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                                        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                                        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
                                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                                        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                                        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                                        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                                        system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                                        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                      + instance is alive
                                      Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
                                      Adapter    "telegram"     : 3.1.0    , installed 3.1.0
                                      Adapter    "tibberlink"   : 2.2.2    , installed 2.2.2
                                      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                                      Objects and States
                                      Objects:        19580
                                      States:         17301
                                      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                      Pending Updates: 0
                                      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       21187      1360/node-red
                                      tcp        0      0 0.0.0.0:56101           0.0.0.0:*               LISTEN      103        21179      1525/rpc.statd
                                      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       22118      1481/io.jarvis.0
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          21151      1/init
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16500      708/sshd: /usr/sbin
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       13869      695/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       13907      695/iobroker.js-con
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       18272      979/io.admin.0
                                      tcp6       0      0 :::8083                 :::*                    LISTEN      1000       23665      1617/io.web.1
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       22918      1610/io.web.0
                                      tcp6       0      0 :::42753                :::*                    LISTEN      103        21183      1525/rpc.statd
                                      tcp6       0      0 :::61991                :::*                    LISTEN      1000       23576      1463/io.harmony.0
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          21155      1/init
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          16502      708/sshd: /usr/sbin
                                      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       23577      1463/io.harmony.0
                                      udp        0      0 0.0.0.0:39575           0.0.0.0:*                           104        14516      504/avahi-daemon: r
                                      udp        0      0 127.0.0.1:854           0.0.0.0:*                           0          21173      1525/rpc.statd
                                      udp        0      0 192.168.2.40:5353       0.0.0.0:*                           1000       22893      1352/io.tr-064.0
                                      udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1000       22892      1352/io.tr-064.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14514      504/avahi-daemon: r
                                      udp        0      0 0.0.0.0:53294           0.0.0.0:*                           103        21177      1525/rpc.statd
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          21153      1/init
                                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       19034      1169/io.mihome-vacu
                                      udp6       0      0 fe80::1cf:9104:829e:546 :::*                                0          16573      633/NetworkManager
                                      udp6       0      0 fe80::4419:5dba:1b6:546 :::*                                0          16132      633/NetworkManager
                                      udp6       0      0 :::5353                 :::*                                104        14515      504/avahi-daemon: r
                                      udp6       0      0 :::54748                :::*                                104        14517      504/avahi-daemon: r
                                      udp6       0      0 :::57020                :::*                                103        21181      1525/rpc.statd
                                      udp6       0      0 :::111                  :::*                                0          21157      1/init
                                      2024-03-07 22:19:27.121  - info: javascript.0 (1676) script.js.SynologyPhotos.Photos_zählen: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                      2024-03-07 22:19:27.123  - info: javascript.0 (1676) Start javascript script.js.System.Neustart_Fritzbox
                                      2024-03-07 22:19:27.146  - info: javascript.0 (1676) script.js.System.Neustart_Fritzbox: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2024-03-07 22:19:27.147  - info: javascript.0 (1676) Start javascript script.js.System.Partition_Kamera_reinigen
                                      2024-03-07 22:19:27.185  - info: javascript.0 (1676) script.js.System.Partition_Kamera_reinigen: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                      2024-03-07 22:19:27.186  - info: javascript.0 (1676) Start javascript script.js.System.Pi_einmalig_neustarten
                                      2024-03-07 22:19:27.248  - info: javascript.0 (1676) script.js.System.Pi_einmalig_neustarten: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                      2024-03-07 22:19:27.705  - warn: javascript.0 (1676) script.js.Fritzbox.Klingel_Bild_Telegram: Fehler beim Bild speichern: Error: ENOENT: no such file or directory, open '/home/iobroker/Kamera/Klingel/Klingel_0.jpg'
                                      2024-03-07 22:19:29.249  - info: javascript.0 (1676) Start javascript script.js.System.Speicherplatz_umrechnen
                                      2024-03-07 22:19:29.266  - info: javascript.0 (1676) script.js.System.Speicherplatz_umrechnen: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2024-03-07 22:19:29.268  - info: javascript.0 (1676) Start javascript script.js.System.Uptime
                                      2024-03-07 22:19:29.330  - info: javascript.0 (1676) script.js.System.Uptime: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2024-03-07 22:19:29.332  - info: javascript.0 (1676) Start javascript script.js.System.Vis_Funktions_Buttons
                                      2024-03-07 22:19:29.433  - info: javascript.0 (1676) script.js.System.Vis_Funktions_Buttons: registered 14 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2024-03-07 22:19:29.434  - info: javascript.0 (1676) Start javascript script.js.Telegram.Briefkasten_Bild_Telegram
                                      2024-03-07 22:19:29.570  - info: javascript.0 (1676) script.js.Telegram.Briefkasten_Bild_Telegram: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2024-03-07 22:19:29.572  - info: javascript.0 (1676) Start javascript script.js.Telegram.Telegram-Menu.HILFE_ANLEITUNG
                                      2024-03-07 22:19:29.587  - info: javascript.0 (1676) script.js.Telegram.Telegram-Menu.HILFE_ANLEITUNG: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2024-03-07 22:19:29.588  - info: javascript.0 (1676) Start javascript script.js.Telegram.Telegram-Menu.Start-Menu
                                      2024-03-07 22:19:29.609  - info: javascript.0 (1676) script.js.Telegram.Telegram-Menu.Start-Menu: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2024-03-07 22:19:29.611  - info: javascript.0 (1676) Start javascript script.js.Visualisierung.MyMüll
                                      2024-03-07 22:19:29.641  - info: javascript.0 (1676) script.js.Visualisierung.MyMüll: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                      2024-03-07 22:19:29.643  - info: javascript.0 (1676) Start javascript script.js.Visualisierung.Vis_Änderung_Telegram
                                      2024-03-07 22:19:29.659  - info: javascript.0 (1676) script.js.Visualisierung.Vis_Änderung_Telegram: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2024-03-07 22:19:30.266  - warn: javascript.0 (1676) script.js.Telegram.Briefkasten_Bild_Telegram: Fehler beim Bild speichern: Error: ENOENT: no such file or directory, open '/home/iobroker/Kamera/Briefkasten/Briefkasten_0.jpg'
                                        @mika-0
                                        Besorg dir ein stabileres Netzteil.
                                        Und schau nach asynckit. Das Modul ist falsch installiert, installier das nochmal. Oder den javaskript-Adapter. Jenachdem wo es genau klemmt.
                                        cd /opt/iobroker
                                        npm ls asynckit@
                                          @thomas-braun @thomas-braun sagte in Hilfe! Nach Update des javascript Adapters 404:
                                          cd /opt/iobroker
                                          npm ls asynckit@
                                          Das mit dem Netzteil habe ich auch gelesen. Das war im Kauf Bundle damals dabei (ist ein originales) OK dann muss ein neues her, habe vorübergehend ein anderes genommen, das zeigt bei nochmaligem Durchlauf von iob diag keinen Fehler an.
                                          Danke der Info, hier das Ergebnis:
                                          npm ls asynckit@
                                          iobroker.inst@3.0.0 /opt/iobroker
                                          ├─┬ @types/request@2.48.12 extraneous
                                          │ └─┬ form-data@2.5.1 extraneous
                                          │   └── asynckit@0.4.0
                                          ├─┬ iobroker.admin@6.13.16
                                          │ └─┬ axios@1.6.7
                                          │   └─┬ form-data@4.0.0
                                          │     └── asynckit@0.4.0 deduped
                                          ├─┬ iobroker.javascript@7.8.0
                                          │ ├─┬ @types/request@2.48.12
                                          │ │ └─┬ form-data@2.5.1
                                          │ │   └── asynckit@0.4.0
                                          │ ├─┬ axios@1.6.7
                                          │ │ └─┬ form-data@4.0.0
                                          │ └─┬ request@2.88.2
                                          │   └─┬ form-data@2.3.3
                                          ├─┬ iobroker.mihome-vacuum@4.1.1
                                          └─┬ iobroker.telegram@3.1.0
                                            └─┬ node-telegram-bot-api@0.64.0
                                              └─┬ @cypress/request@3.0.1
                                                └─┬ form-data@2.3.3
                                          Also von einem asynckit habe ich noch nichts gelesen, was das ist oder wozu ich das installiert haben könnte.
                                          Kann man daran erkennen ob ein asynckit oder javaskript fehlerhaft installiert wurden und ein Hinweis wäre nett, wie ich das neu installieren kann. Ich möchte nichts falsches drücken. Besten Dank vorab.
                                          1408
