    4. Absturz jede Woche beheben
      G.Hawk @Thomas Braun last edited by Homoran
      Copy text starting here:
                              v.2023-10-10
         Static hostname: Raspberrypi
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               arm64
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               true
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      /home/iobroker/.diag.sh: line 486: nodejs: command not found
      Nodejs-Installation:
                              /usr/local/bin/node             v18.18.0
                              /usr/local/bin/npm              9.8.1
                              /usr/local/bin/npx              9.8.1
                              /usr/local/bin/corepack         0.19.0
      Recommended versions are nodejs 18.19.1 and npm 10.2.4
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed.
      Please check
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      for more information on how to fix these errors.
      MEMORY:
      Mem:            3.8G        2.7G        256M         14M        805M        956M
      Swap:            99M          0B         99M
      Total:          3.9G        2.7G        356M
      Active iob-Instances:   33
      Active repo(s): stable
      ioBroker Core:          js-controller           5.0.19
                              admin                   6.13.16
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : Raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : Raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                26458
      States:                 22683
      Size of iob-Database:
      53M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      pi@Raspberrypi:~ $ ======= Start marking the full check here =========
      -bash: =======: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ ```
      > Skript v.2023-10-10
      > *** BASE SYSTEM ***
      >          Icon name: computer
      >       Architecture: arm64
      > Model           : Raspberry Pi 4 Model B Rev 1.1
      > Docker          : false
      > Virtualization  : none
      > Kernel          : aarch64
      > Userland        : arm64
      > Systemuptime and Load:
      >  14:59:47 up  1:41,  1 user,  load average: 0.67, 0.68, 0.77
      > CPU threads: 4
      > *** RASPBERRY THROTTLING ***
      > Current issues:
      > No throttling issues detected.
      > Previously detected issues:
      > *** Time and Time Zones ***
      >                Local time: Sun 2024-03-03 14:59:47 CET
      >            Universal time: Sun 2024-03-03 13:59:47 UTC
      >                  RTC time: n/a
      >                 Time zone: Europe/Berlin (CET, +0100)
      > System clock synchronized: yes
      >               NTP service: active
      >           RTC in local TZ: no
      > *** User and Groups ***
      > pi
      > /home/pi
      > pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      > *** X-Server-Setup ***
      > X-Server:       true
      > Desktop:
      > Terminal:       tty
      > *** MEMORY ***
      >                total        used        free      shared  buff/cache   available
      > Mem:            3.8G        2.7G        703M         14M        436M        1.0G
      > Swap:            99M          0B         99M
      > Total:          3.9G        2.7G        803M
      >          3794 M total memory
      >          2654 M used memory
      >          2891 M active memory
      >            33 M inactive memory
      >           703 M free memory
      >            10 M buffer memory
      >           425 M swap cache
      >            99 M total swap
      >             0 M used swap
      >            99 M free swap
      > Raspberry only:
      > oom events: 0
      > lifetime oom required: 0 Mbytes
      > total time in oom handler: 0 ms
      > max time spent in oom handler: 0 ms
      > *** FAILED SERVICES ***
      >   UNIT LOAD ACTIVE SUB DESCRIPTION
      > 0 loaded units listed.
      > *** FILESYSTEM ***
      > Filesystem     Type      Size  Used Avail Use% Mounted on
      > /dev/root      ext4       29G   22G  5.8G  80% /
      > devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      > tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      > tmpfs          tmpfs     759M  1.2M  758M   1% /run
      > tmpfs          tmpfs     5.0M  4.0K  5.0M   1% /run/lock
      > /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      > tmpfs          tmpfs     380M   16K  380M   1% /run/user/110
      > tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
      > Messages concerning ext4 filesystem in dmesg:
      > [Sun Mar  3 13:18:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:55:41:9B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9f25eb3f-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      > [Sun Mar  3 13:18:14 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      > [Sun Mar  3 13:18:14 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      > [Sun Mar  3 13:18:14 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      > [Sun Mar  3 13:18:14 2024] EXT4-fs (mmcblk0p2): 2 orphan inodes deleted
      > [Sun Mar  3 13:18:14 2024] EXT4-fs (mmcblk0p2): recovery complete
      > [Sun Mar  3 13:18:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      > [Sun Mar  3 13:18:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      > [Sun Mar  3 13:18:17 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      > Show mounted filesystems \(real ones only\):
      > TARGET  SOURCE         FSTYPE OPTIONS
      > /       /dev/mmcblk0p2 ext4   rw,noatime
      > `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      -bash: Skript: Kommando nicht gefunden.
      -bash: Bookshelf: Kommando nicht gefunden.
      -bash: Static: Kommando nicht gefunden.
      -bash: Icon: Kommando nicht gefunden.
      -bash: command substitution: Zeile 7: Syntaxfehler beim unerwarteten Symbol »(«
      -bash: command substitution: Zeile 7: `  Operating System: Debian GNU/Linux 11 (bullseye)'
      -bash: -/boot: Datei oder Verzeichnis nicht gefunden
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ Files in neuralgic directories:
      -bash: Files: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ /var:
      -bash: /var:: Datei oder Verzeichnis nicht gefunden
      pi@Raspberrypi:~ $ 3.4G    /var/
      -bash: 3.4G: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ 3.0G    /var/log
      -bash: 3.0G: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ 2.9G    /var/log/journal/8a77618cf05141ac85d0ba5400363024
      -bash: 2.9G: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ 225M    /var/lib
      -bash: 225M: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ Archived and active journals take up 2.8G in the file system.
      -bash: Archived: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ /opt/iobroker/backups:
      -bash: /opt/iobroker/backups:: Datei oder Verzeichnis nicht gefunden
      pi@Raspberrypi:~ $ 803M    /opt/iobroker/backups/
      -bash: 803M: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ /opt/iobroker/iobroker-data:
      -bash: /opt/iobroker/iobroker-data:: Datei oder Verzeichnis nicht gefunden
      pi@Raspberrypi:~ $ 600M    /opt/iobroker/iobroker-data/
      -bash: 600M: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ 422M    /opt/iobroker/iobroker-data/files
      -bash: 422M: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ 108M    /opt/iobroker/iobroker-data/backup-objects
      -bash: 108M: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ 78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      -bash: 78M: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ 57M     /opt/iobroker/iobroker-data/files/javascript.admin
      -bash: 57M: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ The five largest files in iobroker-data are:
      -bash: The: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ 53M     /opt/iobroker/iobroker-data/objects.jsonl
      -bash: 53M: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ 33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      -bash: 33M: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ 22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      -bash: 22M: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ 19M     /opt/iobroker/iobroker-data/states.jsonl
      -bash: 19M: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ 8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
      -bash: 8.5M: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ USB-Devices by-id:
      -bash: USB-Devices: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
      -bash: USB-Sticks: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ find: '/dev/serial/by-id/': No such file or directory
      -bash: find:: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ *** NodeJS-Installation ***
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ /home/iobroker/.diag.sh: line 277: nodejs: command not found
      -bash: /home/iobroker/.diag.sh:: Datei oder Verzeichnis nicht gefunden
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ /usr/local/bin/node             v18.18.0
      node:internal/modules/cjs/loader:1080
        throw err;
      Error: Cannot find module '/home/pi/v18.18.0'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
          at Module._load (node:internal/modules/cjs/loader:922:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12)
          at node:internal/main/run_main_module:23:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.18.0
      pi@Raspberrypi:~ $ /usr/local/bin/npm              9.8.1
      Unknown command: "9.8.1"
      To see a list of supported npm commands, run:
        npm help
      pi@Raspberrypi:~ $ /usr/local/bin/npx              9.8.1
      npm notice
      npm notice New major version of npm available! 9.8.1 -> 10.5.0
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.5.0
      npm notice Run npm install -g npm@10.5.0 to update!
      npm notice
      npm ERR! code E404
      npm ERR! 404 Not Found - GET https://registry.npmjs.org/9.8.1 - Not found
      npm ERR! 404
      npm ERR! 404  '9.8.1@*' is not in this registry.
      npm ERR! 404
      npm ERR! 404 Note that you can also install from a
      npm ERR! 404 tarball, folder, http url, or git url.
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-03T14_02_47_545Z-debug-0.log
      pi@Raspberrypi:~ $ /usr/local/bin/corepack         0.19.0
      Unknown Syntax Error: Command not found; did you mean one of:
        0. corepack -h
        1. corepack -v
        2. corepack enable [--install-directory #0] ...
        3. corepack disable [--install-directory #0] ...
        4. corepack hydrate [--activate] <fileName>
        5. corepack prepare [--activate] [--all] [--json] [-o,--output] ...
      While running 0.19.0
      pi@Raspberrypi:~ $ /home/iobroker/.diag.sh: line 288: nodejs: command not found
      pi@Raspberrypi:~ $ *** nodejs is NOT correctly installed ***
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ nodejs:
      -bash: nodejs:: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   Installed: 18.17.1-deb-1nodesource1
      -bash: Installed:: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   Candidate: 18.17.1-deb-1nodesource1
      -bash: Candidate:: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   Version table:
      -bash: Version: Kommando nicht gefunden.
      pi@Raspberrypi:~ $  *** 18.17.1-deb-1nodesource1 500
      pi@Raspberrypi:~ $         500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
      -bash: 500: Kommando nicht gefunden.
      pi@Raspberrypi:~ $         100 /var/lib/dpkg/status
      -bash: 100: Kommando nicht gefunden.
      pi@Raspberrypi:~ $      12.22.12~dfsg-1~deb11u4 500
      -bash: 12.22.12~dfsg-1~deb11u4: Kommando nicht gefunden.
      pi@Raspberrypi:~ $         500 http://deb.debian.org/debian bullseye/main arm64 Packages
      pi@Raspberrypi:~ $         500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ Temp directories causing npm8 problem: 0
      -bash: Temp: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ No problems detected
      -bash: No: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ Errors in npm tree:
      -bash: Errors: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ npm ERR! code ELSPROBLEMS
      Unknown command: "ERR!"
        npm help
      pi@Raspberrypi:~ $ npm ERR! missing: homebridge-blink-for-home@^3.7.6, required by iobroker.ham@5.3.1
        npm help
      pi@Raspberrypi:~ $ npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
        npm help
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-03T14_00_04_769Z-debug-0.log
                      : ping                  : Raspberrypi                              -  enabled
      + system.adapter.Unknown command: "ERR!"
        npm help
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ *** ioBroker-Installation ***
      pi@Raspberrypi:~ $
      opi@Raspberrypi:~ $ ioBroker Status
      -bash: ioBroker: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ iobroker is running on this host.
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
        iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
        iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
        iobroker rebuild [<module>]                                  Rebuild all native modules or path
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
        iobroker object                                              Object management  [aliases: o]
        iobroker state                                               State management  [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation  [aliases: id]
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
      Options:
        --help  Show help  [boolean]
      pi@Raspberrypi:~ $
       pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ Objects type: jsonl
      -bash: Objects: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ States  type: jsonl
      -bash: States: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      ipi@Raspberrypi:~ $ Core adapters versions
      -bash: Core: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ js-controller:  5.0.19
      -bash: js-controller:: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ admin:          6.13.16
      -bash: admin:: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ javascript:     7.8.0
      -bash: javascript:: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      api@Raspberrypi:~ $ Adapters from github:   3
      -bash: Adapters: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ Adapter State
      -bash: Adapter: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ + system.adapter.admin.0                  : admin                 : Raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      -bash: +: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ + system.adapter.alexa2.0                 : alexa2                : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.backitup.0               : backitup              : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.daswetter.0              : daswetter             : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.discovery.0              : discovery             : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $   system.adapter.dwd.0                    : dwd                   : Raspberrypi                              -  enabled
      -bash: system.adapter.dwd.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ + system.adapter.fb-checkpresence.0       : fb-checkpresence      : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.fully-tablet-control.0   : fully-tablet-control  : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.harmony.0                : harmony               : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.hm-rega.0                : hm-rega               : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.hm-rpc.0                 : hm-rpc                : Raspberrypi                              -  enabled, port: 0
      pi@Raspberrypi:~ $ + system.adapter.hm-rpc.1                 : hm-rpc                : Raspberrypi                              -  enabled, port: 0
      pi@Raspberrypi:~ $   system.adapter.hm-rpc.2                 : hm-rpc                : Raspberrypi                              - disabled, port: 0
      -bash: system.adapter.hm-rpc.2: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.ical.0                   : ical                  : Raspberrypi                              -  enabled
      -bash: system.adapter.ical.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.ical.1                   : ical                  : Raspberrypi                              -  enabled
      -bash: system.adapter.ical.1: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.ical.2                   : ical                  : Raspberrypi                              -  enabled
      -bash: system.adapter.ical.2: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: Raspberrypi                              - disabled
      -bash: system.adapter.icons-addictive-flavour-png.0:: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : Raspberrypi                              - disabled
      -bash: system.adapter.icons-fatcow-hosting.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.icons-icons8.0           : icons-icons8          : Raspberrypi                              - disabled
      -bash: system.adapter.icons-icons8.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.icons-material-png.0     : icons-material-png    : Raspberrypi                              - disabled
      -bash: system.adapter.icons-material-png.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.icons-material-svg.0     : icons-material-svg    : Raspberrypi                              - disabled
      -bash: system.adapter.icons-material-svg.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.icons-mfd-png.0          : icons-mfd-png         : Raspberrypi                              - disabled
      -bash: system.adapter.icons-mfd-png.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Raspberrypi                              - disabled
      -bash: system.adapter.icons-mfd-svg.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Raspberrypi                              - disabled
      -bash: system.adapter.icons-open-icon-library-png.0:: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Raspberrypi                              - disabled
      -bash: system.adapter.icons-ultimate-png.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ + system.adapter.influxdb.0               : influxdb              : Raspberrypi                              -  enabled, port: 8086
      pi@Raspberrypi:~ $ + system.adapter.info.0                   : info                  : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.iot.0                    : iot                   : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.javascript.0             : javascript            : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.opendtu.0                : opendtu               : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.ping.0                   : ping                  : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.pushover.0               : pushover              : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.reolink.0                : reolink               : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.reolink.1                : reolink               : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.reolink.2                : reolink               : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.reolink.3                : reolink               : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.reolink.5                : reolink               : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.rpi2.0                   : rpi2                  : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.simple-api.0             : simple-api            : Raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      pi@Raspberrypi:~ $ + system.adapter.tankerkoenig.0           : tankerkoenig          : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $   system.adapter.telegram.0               : telegram              : Raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
      -bash: system.adapter.telegram.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ + system.adapter.tr-064.0                 : tr-064                : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.trashschedule.0          : trashschedule         : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.tuya.0                   : tuya                  : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $ + system.adapter.upnp.0                   : upnp                  : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $   system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Raspberrypi                              - disabled
      -bash: system.adapter.vis-canvas-gauges.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Raspberrypi                              - disabled
      -bash: system.adapter.vis-hqwidgets.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.vis-icontwo.0            : vis-icontwo           : Raspberrypi                              - disabled
      -bash: system.adapter.vis-icontwo.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ + system.adapter.vis-inventwo.0           : vis-inventwo          : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $   system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Raspberrypi                              - disabled
      -bash: system.adapter.vis-jqui-mfd.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.vis-justgage.0           : vis-justgage          : Raspberrypi                              - disabled
      -bash: system.adapter.vis-justgage.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.vis-materialdesign.0     : vis-materialdesign    : Raspberrypi                              - disabled
      -bash: system.adapter.vis-materialdesign.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.vis-plumb.0              : vis-plumb             : Raspberrypi                              -  enabled
      -bash: system.adapter.vis-plumb.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.vis-timeandweather.0     : vis-timeandweather    : Raspberrypi                              - disabled
      -bash: system.adapter.vis-timeandweather.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.vis-weather.0            : vis-weather           : Raspberrypi                              - disabled
      -bash: system.adapter.vis-weather.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.vis.0                    : vis                   : Raspberrypi                              -  enabled
      -bash: system.adapter.vis.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $   system.adapter.weatherunderground.0     : weatherunderground    : Raspberrypi                              -  enabled
      -bash: system.adapter.weatherunderground.0: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ + system.adapter.web.0                    : web                   : Raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      pi@Raspberrypi:~ $ + system.adapter.yamaha.0                 : yamaha                : Raspberrypi                              -  enabled
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ + instance is alive
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ Enabled adapters with bindings
      -bash: Enabled: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ ioBroker-Repositories
      -bash: ioBroker-Repositories: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ stable        : http://download.iobroker.net/sources-dist.json
      -bash: stable: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ beta          : http://download.iobroker.net/sources-dist-latest.json
      -bash: beta: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ Active repo(s): stable
      -bash: Syntaxfehler beim unerwarteten Symbol »(«
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ Installed ioBroker-Instances
      -bash: Installed: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ Used repository: stable
      -bash: Used: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ Adapter    "admin"        : 6.13.16  , installed 6.13.16
      pi@Raspberrypi:~ $ Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      pi@Raspberrypi:~ $ Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      pi@Raspberrypi:~ $ Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
      pi@Raspberrypi:~ $ Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      pi@Raspberrypi:~ $ Adapter    "dwd"          : 2.8.5    , installed 2.8.5
      pi@Raspberrypi:~ $ Adapter    "fb-checkpresence": 1.2.3 , installed 1.2.3
      pi@Raspberrypi:~ $ Adapter    "ham"          : 5.3.1    , installed 5.3.1
      pi@Raspberrypi:~ $ Adapter    "harmony"      : 1.3.0    , installed 1.3.0
      pi@Raspberrypi:~ $ Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      pi@Raspberrypi:~ $ Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
      pi@Raspberrypi:~ $ Adapter    "ical"         : 1.13.3   , installed 1.13.3
      pi@Raspberrypi:~ $ Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
      pi@Raspberrypi:~ $ Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      pi@Raspberrypi:~ $ Adapter    "icons-icons8" : 0.0.1    , installed 0.0.1
      pi@Raspberrypi:~ $ Adapter    "icons-material-png": 0.1.0, installed 0.1.0
      pi@Raspberrypi:~ $ Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      pi@Raspberrypi:~ $ Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      pi@Raspberrypi:~ $ Adapter    "icons-mfd-svg": 1.2.0    , installed 1.2.0
      pi@Raspberrypi:~ $ Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      pi@Raspberrypi:~ $ Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
      pi@Raspberrypi:~ $ Adapter    "influxdb"     : 4.0.2    , installed 4.0.2
      pi@Raspberrypi:~ $ Adapter    "iot"          : 2.0.11   , installed 2.0.11
      pi@Raspberrypi:~ $ Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      pi@Raspberrypi:~ $ Controller "js-controller": 5.0.19   , installed 5.0.19
      -bash: Controller: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ Adapter    "libre"        : 0.0.4    , installed 0.0.5
      pi@Raspberrypi:~ $ Adapter    "node-red"     : 5.1.0    , installed 5.1.0
      pi@Raspberrypi:~ $ Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
      pi@Raspberrypi:~ $ Adapter    "ping"         : 1.6.2    , installed 1.6.2
      pi@Raspberrypi:~ $ Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      pi@Raspberrypi:~ $ Adapter    "reolink"      : 1.0.3    , installed 1.0.3
      pi@Raspberrypi:~ $ Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
      pi@Raspberrypi:~ $ Adapter    "simple-api"   : 2.7.2    , installed 2.7.2
      pi@Raspberrypi:~ $ Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      pi@Raspberrypi:~ $ Adapter    "synology"     : 3.0.1    , installed 3.0.1
      pi@Raspberrypi:~ $ Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
      pi@Raspberrypi:~ $ Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      pi@Raspberrypi:~ $ Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
      pi@Raspberrypi:~ $ Adapter    "trashschedule": 3.2.0    , installed 3.2.0
      pi@Raspberrypi:~ $ Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      pi@Raspberrypi:~ $ Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      pi@Raspberrypi:~ $ Adapter    "vis"          : 1.5.4    , installed 1.5.4
      pi@Raspberrypi:~ $ Adapter    "vis-canvas-gauges": 1.0.1, installed 1.0.1
      pi@Raspberrypi:~ $ Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
      pi@Raspberrypi:~ $ Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      pi@Raspberrypi:~ $ Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
      pi@Raspberrypi:~ $ Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.0.12
      pi@Raspberrypi:~ $ Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
      pi@Raspberrypi:~ $ Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
      pi@Raspberrypi:~ $ Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
      pi@Raspberrypi:~ $ Adapter    "vis-timeandweather": 1.2.2, installed 1.2.2
      pi@Raspberrypi:~ $ Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      pi@Raspberrypi:~ $ Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      pi@Raspberrypi:~ $ Adapter    "web"          : 6.2.3    , installed 6.2.3
      pi@Raspberrypi:~ $ Adapter    "ws"           : 2.5.10   , installed 2.5.10
      pi@Raspberrypi:~ $ Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ Objects and States
      pi@Raspberrypi:~ $ Please stand by - This may take a while
      -bash: Please: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ Objects:        26458
      -bash: Objects:: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ States:         22683
      -bash: States:: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ *** OS-Repositories and Updates ***
      pi@Raspberrypi:~ $ Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      -bash: Hit:1: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ Hit:2 http://deb.debian.org/debian bullseye InRelease
      -bash: Hit:2: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      -bash: Hit:3: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ Hit:4 https://repos.influxdata.com/debian stable InRelease
      -bash: Hit:4: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
      -bash: Hit:5: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ Get:6 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
      -bash: Get:6: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ Fetched 4586 B in 3s (1682 B/s)
      pi@Raspberrypi:~ $ Reading package lists...
      -bash: Reading: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ Pending Updates: 0
      -bash: Pending: Kommando nicht gefunden.
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ *** Listening Ports ***
      pi@Raspberrypi:~ $ Active Internet connections (only servers)
      pi@Raspberrypi:~ $ Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
      -bash: Proto: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13158      559/cupsd
      -bash: tcp: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15758      738/iobroker.js-con
      pi@Raspberrypi:~ $ tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15749      738/iobroker.js-con
      pi@Raspberrypi:~ $ tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14322      594/sshd: /usr/sbin
      pi@Raspberrypi:~ $ tcp        0      0 192.168.10.13:2001      0.0.0.0:*               LISTEN      1001       17588      1135/io.hm-rpc.0
      pi@Raspberrypi:~ $ tcp        0      0 192.168.10.13:2010      0.0.0.0:*               LISTEN      1001       16698      1167/io.hm-rpc.1
      pi@Raspberrypi:~ $ tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       229959     82516/nc
      pi@Raspberrypi:~ $ tcp6       0      0 :::61991                :::*                    LISTEN      1001       19295      1909/io.harmony.0
      -bash: tcp6: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ tcp6       0      0 ::1:3350                :::*                    LISTEN      0          14747      580/xrdp-sesman
      pi@Raspberrypi:~ $ tcp6       0      0 :::22                   :::*                    LISTEN      0          14333      594/sshd: /usr/sbin
      pi@Raspberrypi:~ $ tcp6       0      0 :::8000                 :::*                    LISTEN      1001       29604      2070/io.upnp.0
      pi@Raspberrypi:~ $ tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20027      2008/io.simple-api.
      pi@Raspberrypi:~ $ tcp6       0      0 :::8086                 :::*                    LISTEN      999        839        424/influxd
      pi@Raspberrypi:~ $ tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21891      2110/io.web.0
      pi@Raspberrypi:~ $ tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18437      1147/io.admin.0
      pi@Raspberrypi:~ $ tcp6       0      0 :::3389                 :::*                    LISTEN      116        13177      634/xrdp
      pi@Raspberrypi:~ $ tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13157      559/cupsd
      pi@Raspberrypi:~ $ udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13211      472/dhcpcd
      -bash: udp: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ udp        0      0 0.0.0.0:39411           0.0.0.0:*                           108        13001      397/avahi-daemon: r
      pi@Raspberrypi:~ $ udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19347      1630/io.tuya.0
      pi@Raspberrypi:~ $ udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19348      1630/io.tuya.0
      pi@Raspberrypi:~ $ udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       19296      1909/io.harmony.0
      pi@Raspberrypi:~ $ udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13172      648/cups-browsed
      pi@Raspberrypi:~ $ udp        0      0 0.0.0.0:44041           0.0.0.0:*                           1001       20062      2070/io.upnp.0
      pi@Raspberrypi:~ $ udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12999      397/avahi-daemon: r
      pi@Raspberrypi:~ $ udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       22873      2070/io.upnp.0
      pi@Raspberrypi:~ $ udp6       0      0 :::546                  :::*                                0          13270      472/dhcpcd
      -bash: udp6: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ udp6       0      0 :::50030                :::*                                108        13002      397/avahi-daemon: r
      pi@Raspberrypi:~ $ udp6       0      0 :::5353                 :::*                                108        13000      397/avahi-daemon: r
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ *** Log File - Last 25 Lines ***
      pi@Raspberrypi:~ $
      pi@Raspberrypi:~ $ 2024-03-03 15:00:09.617  - info: dwd.0 (80086) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      pi@Raspberrypi:~ $ 2024-03-03 15:00:10.214  - info: host.Raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      pi@Raspberrypi:~ $ 2024-03-03 15:00:10.516  - info: daswetter.0 (80239) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.18.0, js-controller: 5.0.19
      pi@Raspberrypi:~ $ 2024-03-03 15:00:12.739  - info: host.Raspberrypi instance system.adapter.ical.1 started with pid 80346
      -bash: 2024-03-03: Kommando nicht gefunden.
      pi@Raspberrypi:~ $ 2024-03-03 15:00:15.042  - info: ical.0 (80325) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.0, js-controller: 5.0.19
      pi@Raspberrypi:~ $ 2024-03-03 15:00:17.169  - info: host.Raspberrypi instance system.adapter.ical.2 started with pid 80366
      pi@Raspberrypi:~ $ 2024-03-03 15:00:17.591  - info: ical.0 (80325) processing URL: Martin https://calendar.google.com/calendar/ical/grohmann.falke%40gmail.com/private-33cf3b9b480cf151b587e08cdb657793/basic.ics
      pi@Raspberrypi:~ $ 2024-03-03 15:00:18.443  - info: ical.0 (80325) processing URL: Familie https://calendar.google.com/calendar/ical/oqdksoo4285g8vudhidpt4d484%40group.calendar.google.com/private-243e162a08e6b938d42c73b459e5dc9b/basic.ics
      pi@Raspberrypi:~ $ 2024-03-03 15:00:19.008  - info: ical.0 (80325) processing URL: Theo https://calendar.google.com/calendar/ical/theo.grohmann.falke%40gmail.com/private-d689461d330c8361fec6707481faa8df/basic.ics
      pi@Raspberrypi:~ $ 2024-03-03 15:00:19.887  - info: ical.0 (80325) processing URL: Tine https://calendar.google.com/calendar/ical/christine.grohmann.falke%40gmail.com/private-f4edbb2f1591984fd0c9adefad2230f2/basic.ics
      pi@Raspberrypi:~ $ 2024-03-03 15:00:20.494  - info: ical.0 (80325) processing URL: Anton https://calendar.google.com/calendar/ical/anton.grohmann.falke%40gmail.com/private-6d5086f3585024d752b648c293474233/basic.ics
      pi@Raspberrypi:~ $ 2024-03-03 15:00:20.587  - info: ical.1 (80346) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.0, js-controller: 5.0.19
      pi@Raspberrypi:~ $ 2024-03-03 15:00:22.947  - info: ical.0 (80325) processing URL: Dienstplan https://calendar.google.com/calendar/ical/53emmvi0fglfd48de8guu7jko4%40group.calendar.google.com/private-befeb661bc78fc68a1767d18aaf51078/basic.ics
      pi@Raspberrypi:~ $ 2024-03-03 15:00:23.014  - info: ical.1 (80346) processing URL: Müll https://calendar.google.com/calendar/ical/p1utqrhlgmn9hlh02bfop2a31s%40group.calendar.google.com/public/basic.ics
      pi@Raspberrypi:~ $ 2024-03-03 15:00:25.091  - info: ical.2 (80366) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.0, js-controller: 5.0.19
      pi@Raspberrypi:~ $ 2024-03-03 15:00:26.347  - info: ical.2 (80366) processing URL: Ferien https://calendar.google.com/calendar/ical/fqli0b9bnlu28nlo1fig6uk9ec%40group.calendar.google.com/private-2de65fdc58cad83c9103b2e33c4e7009/basic.ics
      pi@Raspberrypi:~ $ 2024-03-03 15:00:29.367  - info: ical.1 (80346) Terminated (NO_ERROR): Without reason
      pi@Raspberrypi:~ $ 2024-03-03 15:00:29.936  - info: host.Raspberrypi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
      pi@Raspberrypi:~ $ 2024-03-03 15:00:31.595  - info: ical.2 (80366) Terminated (NO_ERROR): Without reason
      pi@Raspberrypi:~ $ 2024-03-03 15:00:31.602  - info: ical.0 (80325) Terminated (NO_ERROR): Without reason
      pi@Raspberrypi:~ $ 2024-03-03 15:00:32.169  - info: host.Raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      pi@Raspberrypi:~ $ 2024-03-03 15:00:32.172  - info: host.Raspberrypi instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
      pi@Raspberrypi:~ $ 2024-03-03 15:01:04.744  - info: daswetter.0 (80239) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      pi@Raspberrypi:~ $ 2024-03-03 15:01:05.273  - info: daswetter.0 (80239) cleaned everything up...
      pi@Raspberrypi:~ $ 2024-03-03 15:01:05.312  - info: host.Raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      pi@Raspberrypi:~ $
      > ============ Mark until here for C&P =============
      > iob diag has finished.
      > Press any key for a summary
        Homoran Global Moderator Administrators @G.Hawk last edited by
        @g-hawk sagte in Absturz jede Woche beheben:
        da scheint aber noch was zu klemmen
        mqch erst mal ein iob nodejs-update
          G.Hawk @Homoran last edited by
          ioBroker nodejs updater 2023-10-13
          Recommended nodejs-version is: 18.19.1
          Checking your installation now. Please be patient!
          Your current setup is:
          /usr/bin/nodejs         v18.19.1
          /usr/bin/node           v18.19.1
          /usr/bin/npm            10.2.4
          /usr/bin/npx            10.2.4
          /usr/bin/corepack       0.22.0
          We found these nodejs versions available for installation:
          nodejs:
            Installed: 18.19.1-1nodesource1
            Candidate: 18.19.1-1nodesource1
            Version table:
           *** 18.19.1-1nodesource1 1001
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          Nothing to do - Your installation is using the correct paths.
          Nothing to do - Your version is the recommended one.
          You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
          Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
          pi@Raspberrypi:~ $ ioBroker nodejs updater 2023-10-13
          /usr/bin/npm            10.2.4
          /usr/bin/npx            10.2.4
          nodejs:
            Version table:
          pi@Raspberrypi:~ $node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
            Thomas Braun Most Active @G.Hawk last edited by Thomas Braun
            X-Server: true
            sudo systemctl set-default multi-user.target
            iob nodejs-update
            sudo reboot
            Und statt in das Terminal den Output derr Langfassung besser ins Forum kopieren.
              @thomas-braun sagte in Absturz jede Woche beheben:
              > iob nodejs-update
              /usr/bin/npm            10.2.4
              /usr/bin/npx            10.2.4
              nodejs:
                Version table:
              pi@Raspberrypi:~ $
                Alles gut.
                  OK
                  Wie finde ich denn raus, was so viel Speicher belegt?
                  Ich suche mal ein log bevor er abgestürzt ist.
                  Ich habe vorhin probiert auf Repositories Beta umzustellen, da ist er auch direkt abgestürzt.
                    @g-hawk u d jetzt bitte nochmal iob diag
                      Per top / htop z.B.
                      Aber zeig zuerst mal die Ausgabe von
                      iob diag
                      nach einem Reboot.
                        sagt das diag, und wenn nicht, dann ncdu
                          G.Hawk @Thomas Braun last edited by G.Hawk
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : arm64
                           15:31:47 up 11 min,  1 user,  load average: 1.73, 1.93, 1.28
                          CPU threads: 4
                          Current issues:
                                         Local time: Sun 2024-03-03 15:31:47 CET
                                     Universal time: Sun 2024-03-03 14:31:47 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          Boot Target:    multi-user.target
                          *** MEMORY ***
                          Mem:            3.8G        2.4G        538M        1.0M        876M        1.3G
                          Swap:            99M          0B         99M
                          Total:          3.9G        2.4G        638M
                                   3794 M total memory
                                   2379 M used memory
                                   2553 M active memory
                                    505 M inactive memory
                                    538 M free memory
                                     83 M buffer memory
                                    793 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /dev/root      ext4       29G   22G  5.9G  80% /
                          [Sun Mar  3 15:20:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:55:41:9B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9f25eb3f-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                          [Sun Mar  3 15:20:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sun Mar  3 15:20:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Sun Mar  3 15:20:16 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                          /var:
                          3.4G    /var/
                          3.0G    /var/log
                          225M    /var/lib
                          604M    /opt/iobroker/iobroker-data/
                          42M     /opt/iobroker/iobroker-data/objects.jsonl
                          34M     /opt/iobroker/iobroker-data/states.jsonl
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.4
                          /usr/bin/npx            10.2.4
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-03T14_31_56_171Z-debug-0.log
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.13.16
                          javascript:     7.8.0
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        26458
                          States:         22834
                          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:3 http://deb.debian.org/debian bullseye InRelease
                          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:5 https://repos.influxdata.com/debian stable InRelease
                          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Pending Updates: 0
                          tcp        0      0 192.168.10.13:2010      0.0.0.0:*               LISTEN      1001       15854      1107/io.hm-rpc.1
                          tcp        0      0 192.168.10.13:2001      0.0.0.0:*               LISTEN      1001       17707      1106/io.hm-rpc.0
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14898      598/sshd: /usr/sbin
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1768       685/iobroker.js-con
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1712       685/iobroker.js-con
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13207      560/cupsd
                          tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       54747      11706/nc
                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13206      560/cupsd
                          tcp6       0      0 :::61991                :::*                    LISTEN      1001       20670      1568/io.harmony.0
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          14900      598/sshd: /usr/sbin
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21128      1922/io.web.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16430      919/io.admin.0
                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        14240      430/influxd
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20837      1673/io.simple-api.
                          tcp6       0      0 :::8000                 :::*                    LISTEN      1001       28026      1828/io.upnp.0
                          tcp6       0      0 :::3389                 :::*                    LISTEN      116        1617       622/xrdp
                          tcp6       0      0 ::1:3350                :::*                    LISTEN      0          1560       583/xrdp-sesman
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       17135      1343/io.tuya.0
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       17136      1343/io.tuya.0
                          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       19674      1568/io.harmony.0
                          udp        0      0 0.0.0.0:55907           0.0.0.0:*                           1001       21916      1828/io.upnp.0
                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13215      632/cups-browsed
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13134      394/avahi-daemon: r
                          udp        0      0 0.0.0.0:40632           0.0.0.0:*                           108        13136      394/avahi-daemon: r
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       21092      1828/io.upnp.0
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14263      476/dhcpcd
                          udp6       0      0 :::546                  :::*                                0          1660       476/dhcpcd
                          udp6       0      0 :::54437                :::*                                108        13137      394/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                108        13135      394/avahi-daemon: r
                            @g-hawk
                            Soweit schaut das okay aus.
                            Aber installier und deinstallier den iobroker.ham-Adapter nochmal.
                            Der ist irgendwie krumm im System.
                              OK Welcher ist das genau?
                              Ich finde keinen der so heißt.
                              MartinP Thomas Braun 2 Replies Last reply Reply Quote 0
                              • MartinP
                                MartinP @G.Hawk last edited by
                                @g-hawk Homebridge
                                Errors in npm tree:
                                  @g-hawk
                                  Steht bei den ausgewiesenen npm-Errors dabei.
                                  Und lösche die Links zu den privaten Kalendern aus dem Log.
                                    Habe ich hoffentlich.
                                    Wie kann ich den HTOP posten, das kann ich nicht kopieren.
                                    Meister Mopper Thomas Braun 2 Replies Last reply Reply Quote 0
                                    • Meister Mopper
                                      Meister Mopper @G.Hawk last edited by
                                      Shift-Taste halten und markieren.
                                        @g-hawk
                                        Verwende
                                        top
                                          pi@Raspberrypi:~ $ top
                                          top - 16:45:12 up  1:24,  1 user,  load average: 1,32, 1,01, 0,93
                                          Tasks: 201 total,   3 running, 198 sleeping,   0 stopped,   0 zombie
                                          %CPU(s): 34,8 us,  7,0 sy,  0,0 ni, 56,0 id,  0,2 wa,  0,0 hi,  2,0 si,  0,0 st
                                          MiB Spch:   3794,3 total,    622,7 free,   2711,8 used,    459,8 buff/cache
                                          MiB Swap:    100,0 total,    100,0 free,      0,0 used.    958,3 avail Spch
                                              PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
                                            64063 iobroker  20   0  878736 111268  36540 R  70,5   2,9   0:05.75 io.daswetter.0
                                              685 iobroker  20   0 5538148 524296  43196 S  54,0  13,5  25:34.32 iobroker.js-con
                                             1922 iobroker  20   0  993072 134848  37468 S  12,6   3,5   3:36.06 io.web.0
                                              930 iobroker  20   0 1119776 262500  41504 R  11,9   6,8   6:49.58 io.javascript.0
                                              979 iobroker  20   0  990288 113728  36288 S   8,3   2,9   3:21.37 io.influxdb.0
                                             1270 iobroker  20   0  698396 105584  41816 S   5,6   2,7   1:47.06 io.tr-064.0
                                             2067 iobroker  20   0  689412  85740  36956 S   1,7   2,2   0:35.80 io.reolink.2
                                             2129 iobroker  20   0  689180  84880  36868 S   1,7   2,2   0:36.03 io.reolink.3
                                             2153 iobroker  20   0  688852  86144  36940 S   1,7   2,2   0:35.81 io.reolink.5
                                             1647 iobroker  20   0  694904  92824  41664 S   1,0   2,4   0:48.43 io.opendtu.0
                                              394 avahi     20   0    7144   3272   2764 S   0,7   0,1   0:04.02 avahi-daemon
                                              430 influxdb  20   0 1162896 170236  61164 S   0,7   4,4   1:05.01 influxd
                                              919 iobroker  20   0 1027740 190380  42792 S   0,7   4,9   2:06.77 io.admin.0
                                             1228 iobroker  20   0  687832  82524  36156 S   0,7   2,1   0:39.56 io.ping.0
                                             1541 iobroker  20   0  690648 106452  41820 S   0,7   2,7   0:33.34 io.fully-tablet
                                            63567 pi        20   0   10304   3468   2832 R   0,7   0,1   0:00.27 top
                                             1003 iobroker  20   0 9350992 101416  44388 S   0,3   2,6   0:13.41 io.backitup.0
                                             1343 iobroker  20   0  991168 140148  42544 S   0,3   3,6   1:02.80 io.tuya.0
                                            63548 pi        20   0   16060   4664   3420 S   0,3   0,1   0:00.05 sshd
                                                1 root      20   0  164996  10036   7328 S   0,0   0,3   0:02.87 systemd
                                                2 root      20   0       0      0      0 S   0,0   0,0   0:00.03 kthreadd
                                                3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
                                                4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
                                                5 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 slub_flushwq
                                                6 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 netns
                                               10 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
                                               11 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_kthread
                                               12 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_rude_kthread
                                               13 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_trace_kthread
                                               14 root      20   0       0      0      0 S   0,0   0,0   0:01.45 ksoftirqd/0
                                               15 root      20   0       0      0      0 I   0,0   0,0   0:08.45 rcu_preempt
                                               16 root      rt   0       0      0      0 S   0,0   0,0   0:00.01 migration/0
                                               17 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
                                               18 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
                                               19 root      rt   0       0      0      0 S   0,0   0,0   0:00.02 migration/1
                                               20 root      20   0       0      0      0 S   0,0   0,0   0:00.52 ksoftirqd/1
                                               23 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/2
                                               24 root      rt   0       0      0      0 S   0,0   0,0   0:00.01 migration/2
                                               25 root      20   0       0      0      0 S   0,0   0,0   0:00.51 ksoftirqd/2
                                               28 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/3
                                               29 root      rt   0       0      0      0 S   0,0   0,0   0:00.01 migration/3
                                               30 root      20   0       0      0      0 S   0,0   0,0   0:00.45 ksoftirqd/3
                                               33 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kdevtmpfs
                                               34 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 inet_frag_wq
                                               36 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kauditd
                                               38 root      20   0       0      0      0 S   0,0   0,0   0:00.00 khungtaskd
                                               40 root      20   0       0      0      0 S   0,0   0,0   0:00.00 oom_reaper
                                               41 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 writeback
                                               42 root      20   0       0      0      0 S   0,0   0,0   0:01.36 kcompactd0
                                               43 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kintegrityd
                                               44 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kblockd
                                               45 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 blkcg_punt_bio
                                               46 root     -51   0       0      0      0 S   0,0   0,0   0:00.00 watchdogd
                                               50 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rpciod
                                          MIB SWAP ist irgendwann voll und dann stürzt er ab.
                                          Oder ich warte mal wenn es wieder passiert und poste dann den log.
                                            @g-hawk was ist denn mit deinem Wetter Adapter los?
                                            2620
