    4. Absturz jede Woche beheben
      Homoran Global Moderator Administrators @G.Hawk last edited by
      @g-hawk u d jetzt bitte nochmal iob diag
        Thomas Braun Most Active @G.Hawk last edited by
        @g-hawk sagte in Absturz jede Woche beheben:
        Wie finde ich denn raus, was so viel Speicher belegt?
        Per top / htop z.B.
        Aber zeig zuerst mal die Ausgabe von
        iob diag
        nach einem Reboot.
          sagt das diag, und wenn nicht, dann ncdu
            G.Hawk @Thomas Braun last edited by G.Hawk
            Skript v.2023-10-10
            *** BASE SYSTEM ***
               Static hostname: Raspberrypi
                     Icon name: computer
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.1
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : arm64
            Systemuptime and Load:
             15:31:47 up 11 min,  1 user,  load average: 1.73, 1.93, 1.28
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Sun 2024-03-03 15:31:47 CET
                       Universal time: Sun 2024-03-03 14:31:47 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            3.8G        2.4G        538M        1.0M        876M        1.3G
            Swap:            99M          0B         99M
            Total:          3.9G        2.4G        638M
                     3794 M total memory
                     2379 M used memory
                     2553 M active memory
                      505 M inactive memory
                      538 M free memory
                       83 M buffer memory
                      793 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            /dev/root      ext4       29G   22G  5.9G  80% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     759M  1.2M  758M   1% /run
            /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
            tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
            [Sun Mar  3 15:20:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:55:41:9B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9f25eb3f-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Sun Mar  3 15:20:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sun Mar  3 15:20:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Sun Mar  3 15:20:16 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            3.4G    /var/
            3.0G    /var/log
            2.9G    /var/log/journal/8a77618cf05141ac85d0ba5400363024
            225M    /var/lib
            Archived and active journals take up 2.8G in the file system.
            /opt/iobroker/backups:
            803M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            604M    /opt/iobroker/iobroker-data/
            422M    /opt/iobroker/iobroker-data/files
            108M    /opt/iobroker/iobroker-data/backup-objects
            78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
            57M     /opt/iobroker/iobroker-data/files/javascript.admin
            42M     /opt/iobroker/iobroker-data/objects.jsonl
            34M     /opt/iobroker/iobroker-data/states.jsonl
            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
            22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
            8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
            USB-Devices by-id:
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.19.1
            /usr/bin/node           v18.19.1
            /usr/bin/npm            10.2.4
            /usr/bin/npx            10.2.4
            /usr/bin/corepack       0.22.0
            nodejs:
              Installed: 18.19.1-1nodesource1
              Candidate: 18.19.1-1nodesource1
              Version table:
             *** 18.19.1-1nodesource1 1001
                    100 /var/lib/dpkg/status
                 18.19.0-1nodesource1 1001
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
            No problems detected
            Errors in npm tree:
            npm ERR! code ELSPROBLEMS
            npm ERR! missing: homebridge-blink-for-home@^3.7.6, required by iobroker.ham@5.3.1
            npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-03T14_31_56_171Z-debug-0.log
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.19
            admin:          6.13.16
            javascript:     7.8.0
            Adapters from github:   3
            Adapter State
            + system.adapter.admin.0                  : admin                 : Raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : Raspberrypi                              -  enabled
            + system.adapter.backitup.0               : backitup              : Raspberrypi                              -  enabled
              system.adapter.daswetter.0              : daswetter             : Raspberrypi                              -  enabled
            + system.adapter.discovery.0              : discovery             : Raspberrypi                              -  enabled
              system.adapter.dwd.0                    : dwd                   : Raspberrypi                              -  enabled
            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : Raspberrypi                              -  enabled
            + system.adapter.fully-tablet-control.0   : fully-tablet-control  : Raspberrypi                              -  enabled
            + system.adapter.harmony.0                : harmony               : Raspberrypi                              -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : Raspberrypi                              -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : Raspberrypi                              -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : Raspberrypi                              -  enabled, port: 0
              system.adapter.hm-rpc.2                 : hm-rpc                : Raspberrypi                              - disabled, port: 0
              system.adapter.ical.0                   : ical                  : Raspberrypi                              -  enabled
              system.adapter.ical.1                   : ical                  : Raspberrypi                              -  enabled
              system.adapter.ical.2                   : ical                  : Raspberrypi                              -  enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: Raspberrypi                              - disabled
              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : Raspberrypi                              - disabled
              system.adapter.icons-icons8.0           : icons-icons8          : Raspberrypi                              - disabled
              system.adapter.icons-material-png.0     : icons-material-png    : Raspberrypi                              - disabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : Raspberrypi                              - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : Raspberrypi                              - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Raspberrypi                              - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Raspberrypi                              - disabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Raspberrypi                              - disabled
            + system.adapter.influxdb.0               : influxdb              : Raspberrypi                              -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : Raspberrypi                              -  enabled
            + system.adapter.iot.0                    : iot                   : Raspberrypi                              -  enabled
            + system.adapter.javascript.0             : javascript            : Raspberrypi                              -  enabled
            + system.adapter.opendtu.0                : opendtu               : Raspberrypi                              -  enabled
            + system.adapter.ping.0                   : ping                  : Raspberrypi                              -  enabled
            + system.adapter.pushover.0               : pushover              : Raspberrypi                              -  enabled
            + system.adapter.reolink.0                : reolink               : Raspberrypi                              -  enabled
            + system.adapter.reolink.1                : reolink               : Raspberrypi                              -  enabled
            + system.adapter.reolink.2                : reolink               : Raspberrypi                              -  enabled
            + system.adapter.reolink.3                : reolink               : Raspberrypi                              -  enabled
            + system.adapter.reolink.5                : reolink               : Raspberrypi                              -  enabled
            + system.adapter.rpi2.0                   : rpi2                  : Raspberrypi                              -  enabled
            + system.adapter.simple-api.0             : simple-api            : Raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.tankerkoenig.0           : tankerkoenig          : Raspberrypi                              -  enabled
              system.adapter.telegram.0               : telegram              : Raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
            + system.adapter.tr-064.0                 : tr-064                : Raspberrypi                              -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : Raspberrypi                              -  enabled
            + system.adapter.tuya.0                   : tuya                  : Raspberrypi                              -  enabled
            + system.adapter.upnp.0                   : upnp                  : Raspberrypi                              -  enabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Raspberrypi                              - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Raspberrypi                              - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : Raspberrypi                              - disabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : Raspberrypi                              -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Raspberrypi                              - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : Raspberrypi                              - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : Raspberrypi                              - disabled
              system.adapter.vis-plumb.0              : vis-plumb             : Raspberrypi                              -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : Raspberrypi                              - disabled
              system.adapter.vis-weather.0            : vis-weather           : Raspberrypi                              - disabled
              system.adapter.vis.0                    : vis                   : Raspberrypi                              -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : Raspberrypi                              -  enabled
            + system.adapter.web.0                    : web                   : Raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.yamaha.0                 : yamaha                : Raspberrypi                              -  enabled
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
            Adapter    "backitup"     : 2.10.11  , installed 2.10.11
            Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
            Adapter    "fb-checkpresence": 1.2.3 , installed 1.2.3
            Adapter    "ham"          : 5.3.1    , installed 5.3.1
            Adapter    "harmony"      : 1.3.0    , installed 1.3.0
            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
            Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "iot"          : 2.0.11   , installed 2.0.11
            Adapter    "javascript"   : 7.8.0    , installed 7.8.0
            Adapter    "libre"        : 0.0.4    , installed 0.0.5
            Adapter    "node-red"     : 5.1.0    , installed 5.1.0
            Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
            Adapter    "pushover"     : 3.0.6    , installed 3.0.6
            Adapter    "reolink"      : 1.0.3    , installed 1.0.3
            Adapter    "synology"     : 3.0.1    , installed 3.0.1
            Adapter    "telegram"     : 3.0.1    , installed 3.0.1
            Adapter    "trashschedule": 3.2.0    , installed 3.2.0
            Adapter    "tuya"         : 3.15.0   , installed 3.15.0
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
            Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
            Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
            Adapter    "weatherunderground": 3.6.0, installed 3.6.0
            Adapter    "web"          : 6.2.3    , installed 6.2.3
            Adapter    "ws"           : 2.5.10   , installed 2.5.10
            Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
            Objects and States
            Objects:        26458
            States:         22834
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 http://deb.debian.org/debian bullseye InRelease
            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:5 https://repos.influxdata.com/debian stable InRelease
            Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 192.168.10.13:2010      0.0.0.0:*               LISTEN      1001       15854      1107/io.hm-rpc.1
            tcp        0      0 192.168.10.13:2001      0.0.0.0:*               LISTEN      1001       17707      1106/io.hm-rpc.0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14898      598/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1768       685/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1712       685/iobroker.js-con
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13207      560/cupsd
            tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       54747      11706/nc
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13206      560/cupsd
            tcp6       0      0 :::61991                :::*                    LISTEN      1001       20670      1568/io.harmony.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          14900      598/sshd: /usr/sbin
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21128      1922/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16430      919/io.admin.0
            tcp6       0      0 :::8086                 :::*                    LISTEN      999        14240      430/influxd
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20837      1673/io.simple-api.
            tcp6       0      0 :::8000                 :::*                    LISTEN      1001       28026      1828/io.upnp.0
            tcp6       0      0 :::3389                 :::*                    LISTEN      116        1617       622/xrdp
            tcp6       0      0 ::1:3350                :::*                    LISTEN      0          1560       583/xrdp-sesman
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       17135      1343/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       17136      1343/io.tuya.0
            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       19674      1568/io.harmony.0
            udp        0      0 0.0.0.0:55907           0.0.0.0:*                           1001       21916      1828/io.upnp.0
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13215      632/cups-browsed
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13134      394/avahi-daemon: r
            udp        0      0 0.0.0.0:40632           0.0.0.0:*                           108        13136      394/avahi-daemon: r
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       21092      1828/io.upnp.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14263      476/dhcpcd
            udp6       0      0 :::546                  :::*                                0          1660       476/dhcpcd
            udp6       0      0 :::54437                :::*                                108        13137      394/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        13135      394/avahi-daemon: r
            iob diag has finished.
            Press any key for a summary
              @g-hawk
              Soweit schaut das okay aus.
              Aber installier und deinstallier den iobroker.ham-Adapter nochmal.
              Der ist irgendwie krumm im System.
                OK Welcher ist das genau?
                Ich finde keinen der so heißt.
                MartinP Thomas Braun 2 Replies Last reply Reply Quote 0
                • MartinP
                  MartinP @G.Hawk last edited by
                  @g-hawk Homebridge
                  Errors in npm tree:
                    @g-hawk
                    Steht bei den ausgewiesenen npm-Errors dabei.
                    Und lösche die Links zu den privaten Kalendern aus dem Log.
                      Habe ich hoffentlich.
                      Wie kann ich den HTOP posten, das kann ich nicht kopieren.
                      Meister Mopper Thomas Braun 2 Replies Last reply Reply Quote 0
                      • Meister Mopper
                        Meister Mopper @G.Hawk last edited by
                        Shift-Taste halten und markieren.
                          @g-hawk
                          Verwende
                          top
                            pi@Raspberrypi:~ $ top
                            top - 16:45:12 up  1:24,  1 user,  load average: 1,32, 1,01, 0,93
                            Tasks: 201 total,   3 running, 198 sleeping,   0 stopped,   0 zombie
                            %CPU(s): 34,8 us,  7,0 sy,  0,0 ni, 56,0 id,  0,2 wa,  0,0 hi,  2,0 si,  0,0 st
                            MiB Spch:   3794,3 total,    622,7 free,   2711,8 used,    459,8 buff/cache
                            MiB Swap:    100,0 total,    100,0 free,      0,0 used.    958,3 avail Spch
                                PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
                              64063 iobroker  20   0  878736 111268  36540 R  70,5   2,9   0:05.75 io.daswetter.0
                                685 iobroker  20   0 5538148 524296  43196 S  54,0  13,5  25:34.32 iobroker.js-con
                               1922 iobroker  20   0  993072 134848  37468 S  12,6   3,5   3:36.06 io.web.0
                                930 iobroker  20   0 1119776 262500  41504 R  11,9   6,8   6:49.58 io.javascript.0
                                979 iobroker  20   0  990288 113728  36288 S   8,3   2,9   3:21.37 io.influxdb.0
                               1270 iobroker  20   0  698396 105584  41816 S   5,6   2,7   1:47.06 io.tr-064.0
                               2067 iobroker  20   0  689412  85740  36956 S   1,7   2,2   0:35.80 io.reolink.2
                               2129 iobroker  20   0  689180  84880  36868 S   1,7   2,2   0:36.03 io.reolink.3
                               2153 iobroker  20   0  688852  86144  36940 S   1,7   2,2   0:35.81 io.reolink.5
                               1647 iobroker  20   0  694904  92824  41664 S   1,0   2,4   0:48.43 io.opendtu.0
                                394 avahi     20   0    7144   3272   2764 S   0,7   0,1   0:04.02 avahi-daemon
                                430 influxdb  20   0 1162896 170236  61164 S   0,7   4,4   1:05.01 influxd
                                919 iobroker  20   0 1027740 190380  42792 S   0,7   4,9   2:06.77 io.admin.0
                               1228 iobroker  20   0  687832  82524  36156 S   0,7   2,1   0:39.56 io.ping.0
                               1541 iobroker  20   0  690648 106452  41820 S   0,7   2,7   0:33.34 io.fully-tablet
                              63567 pi        20   0   10304   3468   2832 R   0,7   0,1   0:00.27 top
                               1003 iobroker  20   0 9350992 101416  44388 S   0,3   2,6   0:13.41 io.backitup.0
                               1343 iobroker  20   0  991168 140148  42544 S   0,3   3,6   1:02.80 io.tuya.0
                              63548 pi        20   0   16060   4664   3420 S   0,3   0,1   0:00.05 sshd
                                  1 root      20   0  164996  10036   7328 S   0,0   0,3   0:02.87 systemd
                                  2 root      20   0       0      0      0 S   0,0   0,0   0:00.03 kthreadd
                                  3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
                                  4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
                                  5 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 slub_flushwq
                                  6 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 netns
                                 10 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
                                 11 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_kthread
                                 12 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_rude_kthread
                                 13 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_trace_kthread
                                 14 root      20   0       0      0      0 S   0,0   0,0   0:01.45 ksoftirqd/0
                                 15 root      20   0       0      0      0 I   0,0   0,0   0:08.45 rcu_preempt
                                 16 root      rt   0       0      0      0 S   0,0   0,0   0:00.01 migration/0
                                 17 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
                                 18 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
                                 19 root      rt   0       0      0      0 S   0,0   0,0   0:00.02 migration/1
                                 20 root      20   0       0      0      0 S   0,0   0,0   0:00.52 ksoftirqd/1
                                 23 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/2
                                 24 root      rt   0       0      0      0 S   0,0   0,0   0:00.01 migration/2
                                 25 root      20   0       0      0      0 S   0,0   0,0   0:00.51 ksoftirqd/2
                                 28 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/3
                                 29 root      rt   0       0      0      0 S   0,0   0,0   0:00.01 migration/3
                                 30 root      20   0       0      0      0 S   0,0   0,0   0:00.45 ksoftirqd/3
                                 33 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kdevtmpfs
                                 34 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 inet_frag_wq
                                 36 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kauditd
                                 38 root      20   0       0      0      0 S   0,0   0,0   0:00.00 khungtaskd
                                 40 root      20   0       0      0      0 S   0,0   0,0   0:00.00 oom_reaper
                                 41 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 writeback
                                 42 root      20   0       0      0      0 S   0,0   0,0   0:01.36 kcompactd0
                                 43 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kintegrityd
                                 44 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kblockd
                                 45 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 blkcg_punt_bio
                                 46 root     -51   0       0      0      0 S   0,0   0,0   0:00.00 watchdogd
                                 50 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rpciod
                            MIB SWAP ist irgendwann voll und dann stürzt er ab.
                            Oder ich warte mal wenn es wieder passiert und poste dann den log.
                              @g-hawk was ist denn mit deinem Wetter Adapter los?
                                G.Hawk @Homoran last edited by
                                Ich weiß es nicht, ist da was falsch?
                                  ist da was falsch?
                                  70% CPU ist definitiv nicht richtig
                                      685 iobroker  20   0 5538316 524848  43196 S  10,6  13,5  28:12.16 iobroker.js-con
                                        930 iobroker  20   0 1113292 254616  41504 S   4,3   6,6   7:25.09 io.javascript.0
                                       1922 iobroker  20   0  992800 134144  37468 S   4,0   3,5   4:32.80 io.web.0
                                       1270 iobroker  20   0  698396 105620  41816 S   3,3   2,7   1:58.72 io.tr-064.0
                                        430 influxdb  20   0 1162896 170956  61164 S   2,7   4,4   1:13.06 influxd
                                       1343 iobroker  20   0  991888 140904  42544 S   2,7   3,6   1:09.23 io.tuya.0
                                        979 iobroker  20   0  990256 113036  36288 S   2,3   2,9   3:43.55 io.influxdb.0
                                       1647 iobroker  20   0  695388  94176  41664 S   1,3   2,4   0:53.42 io.opendtu.0
                                       2067 iobroker  20   0  689704  86468  36956 S   1,0   2,2   0:39.57 io.reolink.2
                                        394 avahi     20   0    7144   3272   2764 S   0,7   0,1   0:04.66 avahi-daemon
                                         15 root      20   0       0      0      0 I   0,3   0,0   0:09.28 rcu_preempt
                                       1568 iobroker  20   0  681412  74640  36316 S   0,3   1,9   0:13.01 io.harmony.0
                                      69037 root      20   0       0      0      0 I   0,3   0,0   0:00.02 kworker/u8:0-events_unbound
                                      71584 pi        20   0   10256   3416   2836 R   0,3   0,1   0:00.18 top
                                          1 root      20   0  164996  10036   7328 S   0,0   0,3   0:02.89 systemd
                                         14 root      20   0       0      0      0 S   0,0   0,0   0:01.61 ksoftirqd/0
                                         20 root      20   0       0      0      0 S   0,0   0,0   0:00.56 ksoftirqd/1
                                         25 root      20   0       0      0      0 S   0,0   0,0   0:00.56 ksoftirqd/2
                                         29 root      rt   0       0      0      0 S   0,0   0,0   0:00.02 migration/3
                                         30 root      20   0       0      0      0 S   0,0   0,0   0:00.49 ksoftirqd/3
                                         42 root      20   0       0      0      0 S   0,0   0,0   0:01.39 kcompactd0
                                         51 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 xprtiod
                                         55 root      20   0       0      0      0 S   0,0   0,0   0:00.55 kswapd0
                                         56 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 nfsiod
                                         57 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kthrotld
                                         65 root      20   0       0      0      0 S   0,0   0,0   0:00.00 hwrng
                                         66 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 iscsi_conn_clea
                                      @g-hawk das ist eine scheduled Instanz.
                                      Die startet kurz, macht ihre Arbeit und legt sich wieder schlafen.
                                      klar, dass das Leistung kostet. Ich habe den Adapter nicht, aber 70% CPU ist imho nicht normal
                                        Also ich beobachte das ganze mal.
                                        Erstmal vielen Dank für die Hilfe.
                                        Gruß G.Hawk
                                          G.Hawk @G.Hawk last edited by
                                          Hallo
                                          Eben war ich am Skripte schreiben als er wieder abgestürzt ist.
                                          Folgendes steht im Log, das steht da immer wenn er abstürzt.
                                          Interessant sind die Zeiten...
                                          Was sagt ihr dazu kann man da irgendwas dran erkennen?
                                          2024-03-04 14:50:52.843 - info: smartmeter.0 (1271) Received 19 values, 8 updated
                                          2024-03-04 14:50:59.633 - info: smartmeter.1 (1281) Received 19 values, 10 updated
                                          2024-03-04 14:31:15.741 - info: host.Raspberrypi iobroker.js-controller version 5.0.19 js-controller starting
                                          2024-03-04 14:31:15.748 - info: host.Raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                          2024-03-04 14:31:15.749 - info: host.Raspberrypi hostname: Raspberrypi, node: v18.19.1
                                          2024-03-04 14:31:15.750 - info: host.Raspberrypi ip addresses: fd00::c7f0:7c62:3e69:b975 fe80::6213:58b0:7758:34f6
                                          2024-03-04 14:31:20.834 - info: host.Raspberrypi connected to Objects and States
                                          2024-03-04 14:31:20.955 - info: host.Raspberrypi added notifications configuration of host
                                          2024-03-04 14:31:22.401 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.nodeCurrent"
                                          2024-03-04 14:31:22.404 - info: host.Raspberrypi 61 instances found
                                          2024-03-04 14:31:22.527 - info: host.Raspberrypi starting 42 instances
                                          2024-03-04 14:31:22.789 - info: host.Raspberrypi instance system.adapter.admin.0 started with pid 930
                                          2024-03-04 14:31:22.815 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.nodeNewest"
                                          2024-03-04 14:31:22.868 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.nodeNewestNext"
                                          2024-03-04 14:31:22.922 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.npmCurrent"
                                          2024-03-04 14:31:22.977 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.npmNewest"
                                          2024-03-04 14:31:23.029 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.npmNewestNext"
                                          2024-03-04 14:31:23.080 - info: host.Raspberrypi Some obsolete host states deleted.
                                          2024-03-04 14:31:26.368 - error: admin.0 (930) admin.0 already running
                                          2024-03-04 14:31:26.372 - warn: admin.0 (930) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2024-03-04 14:31:26.720 - info: host.Raspberrypi instance system.adapter.javascript.0 started with pid 941
                                          2024-03-04 14:31:27.169 - error: host.Raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2024-03-04 14:31:27.170 - info: host.Raspberrypi Restart adapter system.adapter.admin.0 because enabled
                                          2024-03-04 14:31:30.725 - info: host.Raspberrypi instance system.adapter.pushover.0 started with pid 963
                                          2024-03-04 14:31:31.150 - error: javascript.0 (941) javascript.0 already running
                                          2024-03-04 14:31:31.154 - warn: javascript.0 (941) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2024-03-04 14:31:31.897 - error: host.Raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2024-03-04 14:31:31.898 - info: host.Raspberrypi Restart adapter system.adapter.javascript.0 because enabled
                                          2024-03-04 14:31:33.149 - error: pushover.0 (963) pushover.0 already running
                                          2024-03-04 14:31:33.155 - warn: pushover.0 (963) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2024-03-04 14:31:33.922 - error: host.Raspberrypi instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2024-03-04 14:31:33.923 - info: host.Raspberrypi Restart adapter system.adapter.pushover.0 because enabled
                                          2024-03-04 14:31:34.723 - info: host.Raspberrypi instance system.adapter.influxdb.0 started with pid 974
                                          2024-03-04 14:58:15.470 - error: influxdb.0 (974) influxdb.0 already running
                                          2024-03-04 14:58:15.474 - warn: influxdb.0 (974) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2024-03-04 14:58:16.168 - error: host.Raspberrypi instance system.adapter.influxdb.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2024-03-04 14:58:16.169 - info: host.Raspberrypi Restart adapter system.adapter.influxdb.0 because enabled
                                          2024-03-04 14:58:16.770 - info: host.Raspberrypi instance system.adapter.backitup.0 started with pid 990
                                          2024-03-04 14:58:19.145 - error: backitup.0 (990) backitup.0 already running
                                          2024-03-04 14:58:19.149 - warn: backitup.0 (990) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2024-03-04 14:58:19.845 - error: host.Raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2024-03-04 14:58:19.846 - info: host.Raspberrypi Restart adapter system.adapter.backitup.0 because enabled
                                          2024-03-04 14:58:20.766 - info: host.Raspberrypi instance system.adapter.alexa2.0 started with pid 1001
                                          2024-03-04 14:58:23.177 - error: alexa2.0 (1001) alexa2.0 already running
                                          2024-03-04 14:58:23.182 - warn: alexa2.0 (1001) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2024-03-04 14:58:23.873 - error: host.Raspberrypi instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2024-03-04 14:58:23.874 - info: host.Raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
                                          2024-03-04 14:58:24.770 - info: host.Raspberrypi instance system.adapter.hm-rega.0 started with pid 1014
                                          2024-03-04 14:58:27.245 - error: hm-rega.0 (1014) hm-rega.0 already running
                                          2024-03-04 14:58:27.250 - warn: hm-rega.0 (1014) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2024-03-04 14:58:27.946 - error: host.Raspberrypi instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2024-03-04 14:58:27.948 - info: host.Raspberrypi Restart adapter system.adapter.hm-rega.0 because enabled
                                          2024-03-04 14:58:28.777 - info: host.Raspberrypi instance system.adapter.hm-rpc.0 started with pid 1025
                                          2024-03-04 14:58:29.135 - info: host.Raspberrypi instance system.adapter.hm-rega.0 started with pid 1034
                                          2024-03-04 14:58:31.626 - error: hm-rpc.0 (1025) hm-rpc.0 already running
                                          2024-03-04 14:58:31.632 - warn: hm-rpc.0 (1025) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2024-03-04 14:58:32.368 - error: host.Raspberrypi instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2024-03-04 14:58:32.369 - info: host.Raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                                          2024-03-04 14:58:32.769 - info: host.Raspberrypi instance system.adapter.hm-rpc.1 started with pid 1049
                                          2024-03-04 14:58:32.859 - info: hm-rega.0 (1034) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v18.19.1, js-controller: 5.0.19
                                          2024-03-04 14:58:33.674 - info: host.Raspberrypi instance system.adapter.hm-rpc.0 started with pid 1060
                                          2024-03-04 14:58:33.736 - info: hm-rega.0 (1034) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                                          2024-03-04 14:58:33.852 - info: hm-rega.0 (1034) ReGaHSS 192.168.10.19 up
                                          2024-03-04 14:58:33.959 - info: hm-rega.0 (1034) time difference local-ccu 1s
                                          2024-03-04 14:58:35.724 - info: host.Raspberrypi instance system.adapter.admin.0 started with pid 1075
                                          2024-03-04 14:58:35.842 - error: hm-rpc.1 (1049) hm-rpc.1 already running
                                          2024-03-04 14:58:35.849 - warn: hm-rpc.1 (1049) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2024-03-04 14:58:36.937 - error: host.Raspberrypi instance system.adapter.hm-rpc.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2024-03-04 14:58:36.938 - info: host.Raspberrypi Restart adapter system.adapter.hm-rpc.1 because enabled
                                          2024-03-04 14:58:37.037 - info: host.Raspberrypi instance scheduled system.adapter.ical.0 0,30 * * * *
                                          2024-03-04 14:58:37.044 - info: host.Raspberrypi instance system.adapter.ical.0 started with pid 1082
                                          2024-03-04 14:58:38.222 - info: host.Raspberrypi instance system.adapter.hm-rpc.1 started with pid 1089
                                          2024-03-04 14:58:38.440 - info: hm-rpc.0 (1060) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.1, js-controller: 5.0.19
                                          2024-03-04 14:58:39.360 - info: hm-rpc.0 (1060) xmlrpc server is trying to listen on 192.168.10.13:2001
                                          2024-03-04 14:58:39.362 - info: hm-rpc.0 (1060) xmlrpc client is trying to connect to 192.168.10.19:2001/ with ["http://192.168.10.13:2001","Raspberrypi:hm-rpc.0:5328f3ff804d13e23c227f6c4373fef7"]
                                          2024-03-04 14:58:39.523 - info: hm-rpc.0 (1060) xmlrpc <- system.listMethods ["Raspberrypi:hm-rpc.0:5328f3ff804d13e23c227f6c4373fef7"]
                                          2024-03-04 14:58:39.556 - info: hm-rpc.0 (1060) xmlrpc <- listDevices ["Raspberrypi:hm-rpc.0:5328f3ff804d13e23c227f6c4373fef7"]
                                          2024-03-04 14:58:40.021 - info: hm-rpc.0 (1060) xmlrpc -> 252 devices
                                          2024-03-04 14:58:40.130 - info: hm-rpc.0 (1060) Connected
                                          2024-03-04 14:58:40.486 - info: host.Raspberrypi instance system.adapter.javascript.0 started with pid 1108
                                          2024-03-04 14:58:41.252 - info: host.Raspberrypi instance scheduled system.adapter.ical.1 0,30 * * * *
                                          Homoran Thomas Braun da_Woody 3 Replies Last reply Reply Quote 0
                                            das ist das log beim Neustart, leider nicht von davor. Das müsste aber als Datei vorliegen.
                                            Die Zeiten scheinen daher zu rühren, dass es etwas dauert, bis der Raspi sich wieder mit dem ntp-Server synchronisiert.
                                            2620
