    4. Absturz jede Woche beheben
      Homoran Global Moderator Administrators @G.Hawk last edited by
      @g-hawk sagte in Absturz jede Woche beheben:
      was so viel Speicher belegt?
      sagt das diag, und wenn nicht, dann ncdu
        G.Hawk @Thomas Braun last edited by G.Hawk
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: Raspberrypi
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         15:31:47 up 11 min,  1 user,  load average: 1.73, 1.93, 1.28
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sun 2024-03-03 15:31:47 CET
                   Universal time: Sun 2024-03-03 14:31:47 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            3.8G        2.4G        538M        1.0M        876M        1.3G
        Swap:            99M          0B         99M
        Total:          3.9G        2.4G        638M
                 3794 M total memory
                 2379 M used memory
                 2553 M active memory
                  505 M inactive memory
                  538 M free memory
                   83 M buffer memory
                  793 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       29G   22G  5.9G  80% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
        [Sun Mar  3 15:20:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:55:41:9B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9f25eb3f-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Sun Mar  3 15:20:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Mar  3 15:20:14 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sun Mar  3 15:20:16 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        3.4G    /var/
        3.0G    /var/log
        2.9G    /var/log/journal/8a77618cf05141ac85d0ba5400363024
        225M    /var/lib
        Archived and active journals take up 2.8G in the file system.
        /opt/iobroker/backups:
        803M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        604M    /opt/iobroker/iobroker-data/
        422M    /opt/iobroker/iobroker-data/files
        108M    /opt/iobroker/iobroker-data/backup-objects
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        57M     /opt/iobroker/iobroker-data/files/javascript.admin
        42M     /opt/iobroker/iobroker-data/objects.jsonl
        34M     /opt/iobroker/iobroker-data/states.jsonl
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
        8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.1
        /usr/bin/node           v18.19.1
        /usr/bin/npm            10.2.4
        /usr/bin/npx            10.2.4
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.1-1nodesource1
          Candidate: 18.19.1-1nodesource1
          Version table:
         *** 18.19.1-1nodesource1 1001
                100 /var/lib/dpkg/status
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! missing: homebridge-blink-for-home@^3.7.6, required by iobroker.ham@5.3.1
        npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-03T14_31_56_171Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.13.16
        javascript:     7.8.0
        Adapters from github:   3
        Adapter State
        + system.adapter.admin.0                  : admin                 : Raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : Raspberrypi                              -  enabled
        + system.adapter.backitup.0               : backitup              : Raspberrypi                              -  enabled
          system.adapter.daswetter.0              : daswetter             : Raspberrypi                              -  enabled
        + system.adapter.discovery.0              : discovery             : Raspberrypi                              -  enabled
          system.adapter.dwd.0                    : dwd                   : Raspberrypi                              -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : Raspberrypi                              -  enabled
        + system.adapter.fully-tablet-control.0   : fully-tablet-control  : Raspberrypi                              -  enabled
        + system.adapter.harmony.0                : harmony               : Raspberrypi                              -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : Raspberrypi                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : Raspberrypi                              -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : Raspberrypi                              -  enabled, port: 0
          system.adapter.hm-rpc.2                 : hm-rpc                : Raspberrypi                              - disabled, port: 0
          system.adapter.ical.0                   : ical                  : Raspberrypi                              -  enabled
          system.adapter.ical.1                   : ical                  : Raspberrypi                              -  enabled
          system.adapter.ical.2                   : ical                  : Raspberrypi                              -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: Raspberrypi                              - disabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : Raspberrypi                              - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : Raspberrypi                              - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : Raspberrypi                              - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : Raspberrypi                              - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : Raspberrypi                              - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Raspberrypi                              - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Raspberrypi                              - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Raspberrypi                              - disabled
        + system.adapter.influxdb.0               : influxdb              : Raspberrypi                              -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : Raspberrypi                              -  enabled
        + system.adapter.iot.0                    : iot                   : Raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : Raspberrypi                              -  enabled
        + system.adapter.opendtu.0                : opendtu               : Raspberrypi                              -  enabled
        + system.adapter.ping.0                   : ping                  : Raspberrypi                              -  enabled
        + system.adapter.pushover.0               : pushover              : Raspberrypi                              -  enabled
        + system.adapter.reolink.0                : reolink               : Raspberrypi                              -  enabled
        + system.adapter.reolink.1                : reolink               : Raspberrypi                              -  enabled
        + system.adapter.reolink.2                : reolink               : Raspberrypi                              -  enabled
        + system.adapter.reolink.3                : reolink               : Raspberrypi                              -  enabled
        + system.adapter.reolink.5                : reolink               : Raspberrypi                              -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : Raspberrypi                              -  enabled
        + system.adapter.simple-api.0             : simple-api            : Raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.tankerkoenig.0           : tankerkoenig          : Raspberrypi                              -  enabled
          system.adapter.telegram.0               : telegram              : Raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : Raspberrypi                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : Raspberrypi                              -  enabled
        + system.adapter.tuya.0                   : tuya                  : Raspberrypi                              -  enabled
        + system.adapter.upnp.0                   : upnp                  : Raspberrypi                              -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Raspberrypi                              - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : Raspberrypi                              - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : Raspberrypi                              -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Raspberrypi                              - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : Raspberrypi                              - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : Raspberrypi                              - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : Raspberrypi                              -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : Raspberrypi                              - disabled
          system.adapter.vis-weather.0            : vis-weather           : Raspberrypi                              - disabled
          system.adapter.vis.0                    : vis                   : Raspberrypi                              -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : Raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : Raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yamaha.0                 : yamaha                : Raspberrypi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
        Adapter    "fb-checkpresence": 1.2.3 , installed 1.2.3
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "harmony"      : 1.3.0    , installed 1.3.0
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Adapter    "libre"        : 0.0.4    , installed 0.0.5
        Adapter    "node-red"     : 5.1.0    , installed 5.1.0
        Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
        Adapter    "pushover"     : 3.0.6    , installed 3.0.6
        Adapter    "reolink"      : 1.0.3    , installed 1.0.3
        Adapter    "synology"     : 3.0.1    , installed 3.0.1
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "trashschedule": 3.2.0    , installed 3.2.0
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
        Objects and States
        Objects:        26458
        States:         22834
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 https://repos.influxdata.com/debian stable InRelease
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.10.13:2010      0.0.0.0:*               LISTEN      1001       15854      1107/io.hm-rpc.1
        tcp        0      0 192.168.10.13:2001      0.0.0.0:*               LISTEN      1001       17707      1106/io.hm-rpc.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14898      598/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1768       685/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1712       685/iobroker.js-con
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13207      560/cupsd
        tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       54747      11706/nc
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13206      560/cupsd
        tcp6       0      0 :::61991                :::*                    LISTEN      1001       20670      1568/io.harmony.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14900      598/sshd: /usr/sbin
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21128      1922/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16430      919/io.admin.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        14240      430/influxd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20837      1673/io.simple-api.
        tcp6       0      0 :::8000                 :::*                    LISTEN      1001       28026      1828/io.upnp.0
        tcp6       0      0 :::3389                 :::*                    LISTEN      116        1617       622/xrdp
        tcp6       0      0 ::1:3350                :::*                    LISTEN      0          1560       583/xrdp-sesman
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       17135      1343/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       17136      1343/io.tuya.0
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       19674      1568/io.harmony.0
        udp        0      0 0.0.0.0:55907           0.0.0.0:*                           1001       21916      1828/io.upnp.0
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13215      632/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13134      394/avahi-daemon: r
        udp        0      0 0.0.0.0:40632           0.0.0.0:*                           108        13136      394/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       21092      1828/io.upnp.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14263      476/dhcpcd
        udp6       0      0 :::546                  :::*                                0          1660       476/dhcpcd
        udp6       0      0 :::54437                :::*                                108        13137      394/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        13135      394/avahi-daemon: r
        iob diag has finished.
        Press any key for a summary
          Thomas Braun Most Active @G.Hawk last edited by
          @g-hawk
          Soweit schaut das okay aus.
          Aber installier und deinstallier den iobroker.ham-Adapter nochmal.
          Der ist irgendwie krumm im System.
            OK Welcher ist das genau?
            Ich finde keinen der so heißt.
            MartinP Thomas Braun 2 Replies Last reply Reply Quote 0
            • MartinP
              MartinP @G.Hawk last edited by
              @g-hawk Homebridge
              Errors in npm tree:
                @g-hawk
                Steht bei den ausgewiesenen npm-Errors dabei.
                Und lösche die Links zu den privaten Kalendern aus dem Log.
                  Habe ich hoffentlich.
                  Wie kann ich den HTOP posten, das kann ich nicht kopieren.
                  Meister Mopper Thomas Braun 2 Replies Last reply Reply Quote 0
                  • Meister Mopper
                    Meister Mopper @G.Hawk last edited by
                    Shift-Taste halten und markieren.
                      @g-hawk
                      Verwende
                      top
                        pi@Raspberrypi:~ $ top
                        top - 16:45:12 up  1:24,  1 user,  load average: 1,32, 1,01, 0,93
                        Tasks: 201 total,   3 running, 198 sleeping,   0 stopped,   0 zombie
                        %CPU(s): 34,8 us,  7,0 sy,  0,0 ni, 56,0 id,  0,2 wa,  0,0 hi,  2,0 si,  0,0 st
                        MiB Spch:   3794,3 total,    622,7 free,   2711,8 used,    459,8 buff/cache
                        MiB Swap:    100,0 total,    100,0 free,      0,0 used.    958,3 avail Spch
                            PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
                          64063 iobroker  20   0  878736 111268  36540 R  70,5   2,9   0:05.75 io.daswetter.0
                            685 iobroker  20   0 5538148 524296  43196 S  54,0  13,5  25:34.32 iobroker.js-con
                           1922 iobroker  20   0  993072 134848  37468 S  12,6   3,5   3:36.06 io.web.0
                            930 iobroker  20   0 1119776 262500  41504 R  11,9   6,8   6:49.58 io.javascript.0
                            979 iobroker  20   0  990288 113728  36288 S   8,3   2,9   3:21.37 io.influxdb.0
                           1270 iobroker  20   0  698396 105584  41816 S   5,6   2,7   1:47.06 io.tr-064.0
                           2067 iobroker  20   0  689412  85740  36956 S   1,7   2,2   0:35.80 io.reolink.2
                           2129 iobroker  20   0  689180  84880  36868 S   1,7   2,2   0:36.03 io.reolink.3
                           2153 iobroker  20   0  688852  86144  36940 S   1,7   2,2   0:35.81 io.reolink.5
                           1647 iobroker  20   0  694904  92824  41664 S   1,0   2,4   0:48.43 io.opendtu.0
                            394 avahi     20   0    7144   3272   2764 S   0,7   0,1   0:04.02 avahi-daemon
                            430 influxdb  20   0 1162896 170236  61164 S   0,7   4,4   1:05.01 influxd
                            919 iobroker  20   0 1027740 190380  42792 S   0,7   4,9   2:06.77 io.admin.0
                           1228 iobroker  20   0  687832  82524  36156 S   0,7   2,1   0:39.56 io.ping.0
                           1541 iobroker  20   0  690648 106452  41820 S   0,7   2,7   0:33.34 io.fully-tablet
                          63567 pi        20   0   10304   3468   2832 R   0,7   0,1   0:00.27 top
                           1003 iobroker  20   0 9350992 101416  44388 S   0,3   2,6   0:13.41 io.backitup.0
                           1343 iobroker  20   0  991168 140148  42544 S   0,3   3,6   1:02.80 io.tuya.0
                          63548 pi        20   0   16060   4664   3420 S   0,3   0,1   0:00.05 sshd
                              1 root      20   0  164996  10036   7328 S   0,0   0,3   0:02.87 systemd
                              2 root      20   0       0      0      0 S   0,0   0,0   0:00.03 kthreadd
                              3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
                              4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
                              5 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 slub_flushwq
                              6 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 netns
                             10 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
                             11 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_kthread
                             12 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_rude_kthread
                             13 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_trace_kthread
                             14 root      20   0       0      0      0 S   0,0   0,0   0:01.45 ksoftirqd/0
                             15 root      20   0       0      0      0 I   0,0   0,0   0:08.45 rcu_preempt
                             16 root      rt   0       0      0      0 S   0,0   0,0   0:00.01 migration/0
                             17 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
                             18 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
                             19 root      rt   0       0      0      0 S   0,0   0,0   0:00.02 migration/1
                             20 root      20   0       0      0      0 S   0,0   0,0   0:00.52 ksoftirqd/1
                             23 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/2
                             24 root      rt   0       0      0      0 S   0,0   0,0   0:00.01 migration/2
                             25 root      20   0       0      0      0 S   0,0   0,0   0:00.51 ksoftirqd/2
                             28 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/3
                             29 root      rt   0       0      0      0 S   0,0   0,0   0:00.01 migration/3
                             30 root      20   0       0      0      0 S   0,0   0,0   0:00.45 ksoftirqd/3
                             33 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kdevtmpfs
                             34 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 inet_frag_wq
                             36 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kauditd
                             38 root      20   0       0      0      0 S   0,0   0,0   0:00.00 khungtaskd
                             40 root      20   0       0      0      0 S   0,0   0,0   0:00.00 oom_reaper
                             41 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 writeback
                             42 root      20   0       0      0      0 S   0,0   0,0   0:01.36 kcompactd0
                             43 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kintegrityd
                             44 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kblockd
                             45 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 blkcg_punt_bio
                             46 root     -51   0       0      0      0 S   0,0   0,0   0:00.00 watchdogd
                             50 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rpciod
                        MIB SWAP ist irgendwann voll und dann stürzt er ab.
                        Oder ich warte mal wenn es wieder passiert und poste dann den log.
                          @g-hawk was ist denn mit deinem Wetter Adapter los?
                            G.Hawk @Homoran last edited by
                            Ich weiß es nicht, ist da was falsch?
                              ist da was falsch?
                              70% CPU ist definitiv nicht richtig
                                  685 iobroker  20   0 5538316 524848  43196 S  10,6  13,5  28:12.16 iobroker.js-con
                                    930 iobroker  20   0 1113292 254616  41504 S   4,3   6,6   7:25.09 io.javascript.0
                                   1922 iobroker  20   0  992800 134144  37468 S   4,0   3,5   4:32.80 io.web.0
                                   1270 iobroker  20   0  698396 105620  41816 S   3,3   2,7   1:58.72 io.tr-064.0
                                    430 influxdb  20   0 1162896 170956  61164 S   2,7   4,4   1:13.06 influxd
                                   1343 iobroker  20   0  991888 140904  42544 S   2,7   3,6   1:09.23 io.tuya.0
                                    979 iobroker  20   0  990256 113036  36288 S   2,3   2,9   3:43.55 io.influxdb.0
                                   1647 iobroker  20   0  695388  94176  41664 S   1,3   2,4   0:53.42 io.opendtu.0
                                   2067 iobroker  20   0  689704  86468  36956 S   1,0   2,2   0:39.57 io.reolink.2
                                    394 avahi     20   0    7144   3272   2764 S   0,7   0,1   0:04.66 avahi-daemon
                                     15 root      20   0       0      0      0 I   0,3   0,0   0:09.28 rcu_preempt
                                   1568 iobroker  20   0  681412  74640  36316 S   0,3   1,9   0:13.01 io.harmony.0
                                  69037 root      20   0       0      0      0 I   0,3   0,0   0:00.02 kworker/u8:0-events_unbound
                                  71584 pi        20   0   10256   3416   2836 R   0,3   0,1   0:00.18 top
                                      1 root      20   0  164996  10036   7328 S   0,0   0,3   0:02.89 systemd
                                     14 root      20   0       0      0      0 S   0,0   0,0   0:01.61 ksoftirqd/0
                                     20 root      20   0       0      0      0 S   0,0   0,0   0:00.56 ksoftirqd/1
                                     25 root      20   0       0      0      0 S   0,0   0,0   0:00.56 ksoftirqd/2
                                     29 root      rt   0       0      0      0 S   0,0   0,0   0:00.02 migration/3
                                     30 root      20   0       0      0      0 S   0,0   0,0   0:00.49 ksoftirqd/3
                                     42 root      20   0       0      0      0 S   0,0   0,0   0:01.39 kcompactd0
                                     51 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 xprtiod
                                     55 root      20   0       0      0      0 S   0,0   0,0   0:00.55 kswapd0
                                     56 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 nfsiod
                                     57 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kthrotld
                                     65 root      20   0       0      0      0 S   0,0   0,0   0:00.00 hwrng
                                     66 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 iscsi_conn_clea
                                  @g-hawk das ist eine scheduled Instanz.
                                  Die startet kurz, macht ihre Arbeit und legt sich wieder schlafen.
                                  klar, dass das Leistung kostet. Ich habe den Adapter nicht, aber 70% CPU ist imho nicht normal
                                    Also ich beobachte das ganze mal.
                                    Erstmal vielen Dank für die Hilfe.
                                    Gruß G.Hawk
                                      G.Hawk @G.Hawk last edited by
                                      Hallo
                                      Eben war ich am Skripte schreiben als er wieder abgestürzt ist.
                                      Folgendes steht im Log, das steht da immer wenn er abstürzt.
                                      Interessant sind die Zeiten...
                                      Was sagt ihr dazu kann man da irgendwas dran erkennen?
                                      2024-03-04 14:50:52.843 - info: smartmeter.0 (1271) Received 19 values, 8 updated
                                      2024-03-04 14:50:59.633 - info: smartmeter.1 (1281) Received 19 values, 10 updated
                                      2024-03-04 14:31:15.741 - info: host.Raspberrypi iobroker.js-controller version 5.0.19 js-controller starting
                                      2024-03-04 14:31:15.748 - info: host.Raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                      2024-03-04 14:31:15.749 - info: host.Raspberrypi hostname: Raspberrypi, node: v18.19.1
                                      2024-03-04 14:31:15.750 - info: host.Raspberrypi ip addresses: fd00::c7f0:7c62:3e69:b975 fe80::6213:58b0:7758:34f6
                                      2024-03-04 14:31:20.834 - info: host.Raspberrypi connected to Objects and States
                                      2024-03-04 14:31:20.955 - info: host.Raspberrypi added notifications configuration of host
                                      2024-03-04 14:31:22.401 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.nodeCurrent"
                                      2024-03-04 14:31:22.404 - info: host.Raspberrypi 61 instances found
                                      2024-03-04 14:31:22.527 - info: host.Raspberrypi starting 42 instances
                                      2024-03-04 14:31:22.789 - info: host.Raspberrypi instance system.adapter.admin.0 started with pid 930
                                      2024-03-04 14:31:22.815 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.nodeNewest"
                                      2024-03-04 14:31:22.868 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.nodeNewestNext"
                                      2024-03-04 14:31:22.922 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.npmCurrent"
                                      2024-03-04 14:31:22.977 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.npmNewest"
                                      2024-03-04 14:31:23.029 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.npmNewestNext"
                                      2024-03-04 14:31:23.080 - info: host.Raspberrypi Some obsolete host states deleted.
                                      2024-03-04 14:31:26.368 - error: admin.0 (930) admin.0 already running
                                      2024-03-04 14:31:26.372 - warn: admin.0 (930) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                      2024-03-04 14:31:26.720 - info: host.Raspberrypi instance system.adapter.javascript.0 started with pid 941
                                      2024-03-04 14:31:27.169 - error: host.Raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2024-03-04 14:31:27.170 - info: host.Raspberrypi Restart adapter system.adapter.admin.0 because enabled
                                      2024-03-04 14:31:30.725 - info: host.Raspberrypi instance system.adapter.pushover.0 started with pid 963
                                      2024-03-04 14:31:31.150 - error: javascript.0 (941) javascript.0 already running
                                      2024-03-04 14:31:31.154 - warn: javascript.0 (941) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                      2024-03-04 14:31:31.897 - error: host.Raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2024-03-04 14:31:31.898 - info: host.Raspberrypi Restart adapter system.adapter.javascript.0 because enabled
                                      2024-03-04 14:31:33.149 - error: pushover.0 (963) pushover.0 already running
                                      2024-03-04 14:31:33.155 - warn: pushover.0 (963) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                      2024-03-04 14:31:33.922 - error: host.Raspberrypi instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2024-03-04 14:31:33.923 - info: host.Raspberrypi Restart adapter system.adapter.pushover.0 because enabled
                                      2024-03-04 14:31:34.723 - info: host.Raspberrypi instance system.adapter.influxdb.0 started with pid 974
                                      2024-03-04 14:58:15.470 - error: influxdb.0 (974) influxdb.0 already running
                                      2024-03-04 14:58:15.474 - warn: influxdb.0 (974) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                      2024-03-04 14:58:16.168 - error: host.Raspberrypi instance system.adapter.influxdb.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2024-03-04 14:58:16.169 - info: host.Raspberrypi Restart adapter system.adapter.influxdb.0 because enabled
                                      2024-03-04 14:58:16.770 - info: host.Raspberrypi instance system.adapter.backitup.0 started with pid 990
                                      2024-03-04 14:58:19.145 - error: backitup.0 (990) backitup.0 already running
                                      2024-03-04 14:58:19.149 - warn: backitup.0 (990) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                      2024-03-04 14:58:19.845 - error: host.Raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2024-03-04 14:58:19.846 - info: host.Raspberrypi Restart adapter system.adapter.backitup.0 because enabled
                                      2024-03-04 14:58:20.766 - info: host.Raspberrypi instance system.adapter.alexa2.0 started with pid 1001
                                      2024-03-04 14:58:23.177 - error: alexa2.0 (1001) alexa2.0 already running
                                      2024-03-04 14:58:23.182 - warn: alexa2.0 (1001) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                      2024-03-04 14:58:23.873 - error: host.Raspberrypi instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2024-03-04 14:58:23.874 - info: host.Raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
                                      2024-03-04 14:58:24.770 - info: host.Raspberrypi instance system.adapter.hm-rega.0 started with pid 1014
                                      2024-03-04 14:58:27.245 - error: hm-rega.0 (1014) hm-rega.0 already running
                                      2024-03-04 14:58:27.250 - warn: hm-rega.0 (1014) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                      2024-03-04 14:58:27.946 - error: host.Raspberrypi instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2024-03-04 14:58:27.948 - info: host.Raspberrypi Restart adapter system.adapter.hm-rega.0 because enabled
                                      2024-03-04 14:58:28.777 - info: host.Raspberrypi instance system.adapter.hm-rpc.0 started with pid 1025
                                      2024-03-04 14:58:29.135 - info: host.Raspberrypi instance system.adapter.hm-rega.0 started with pid 1034
                                      2024-03-04 14:58:31.626 - error: hm-rpc.0 (1025) hm-rpc.0 already running
                                      2024-03-04 14:58:31.632 - warn: hm-rpc.0 (1025) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                      2024-03-04 14:58:32.368 - error: host.Raspberrypi instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2024-03-04 14:58:32.369 - info: host.Raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                                      2024-03-04 14:58:32.769 - info: host.Raspberrypi instance system.adapter.hm-rpc.1 started with pid 1049
                                      2024-03-04 14:58:32.859 - info: hm-rega.0 (1034) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v18.19.1, js-controller: 5.0.19
                                      2024-03-04 14:58:33.674 - info: host.Raspberrypi instance system.adapter.hm-rpc.0 started with pid 1060
                                      2024-03-04 14:58:33.736 - info: hm-rega.0 (1034) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                                      2024-03-04 14:58:33.852 - info: hm-rega.0 (1034) ReGaHSS 192.168.10.19 up
                                      2024-03-04 14:58:33.959 - info: hm-rega.0 (1034) time difference local-ccu 1s
                                      2024-03-04 14:58:35.724 - info: host.Raspberrypi instance system.adapter.admin.0 started with pid 1075
                                      2024-03-04 14:58:35.842 - error: hm-rpc.1 (1049) hm-rpc.1 already running
                                      2024-03-04 14:58:35.849 - warn: hm-rpc.1 (1049) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                      2024-03-04 14:58:36.937 - error: host.Raspberrypi instance system.adapter.hm-rpc.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2024-03-04 14:58:36.938 - info: host.Raspberrypi Restart adapter system.adapter.hm-rpc.1 because enabled
                                      2024-03-04 14:58:37.037 - info: host.Raspberrypi instance scheduled system.adapter.ical.0 0,30 * * * *
                                      2024-03-04 14:58:37.044 - info: host.Raspberrypi instance system.adapter.ical.0 started with pid 1082
                                      2024-03-04 14:58:38.222 - info: host.Raspberrypi instance system.adapter.hm-rpc.1 started with pid 1089
                                      2024-03-04 14:58:38.440 - info: hm-rpc.0 (1060) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.1, js-controller: 5.0.19
                                      2024-03-04 14:58:39.360 - info: hm-rpc.0 (1060) xmlrpc server is trying to listen on 192.168.10.13:2001
                                      2024-03-04 14:58:39.362 - info: hm-rpc.0 (1060) xmlrpc client is trying to connect to 192.168.10.19:2001/ with ["http://192.168.10.13:2001","Raspberrypi:hm-rpc.0:5328f3ff804d13e23c227f6c4373fef7"]
                                      2024-03-04 14:58:39.523 - info: hm-rpc.0 (1060) xmlrpc <- system.listMethods ["Raspberrypi:hm-rpc.0:5328f3ff804d13e23c227f6c4373fef7"]
                                      2024-03-04 14:58:39.556 - info: hm-rpc.0 (1060) xmlrpc <- listDevices ["Raspberrypi:hm-rpc.0:5328f3ff804d13e23c227f6c4373fef7"]
                                      2024-03-04 14:58:40.021 - info: hm-rpc.0 (1060) xmlrpc -> 252 devices
                                      2024-03-04 14:58:40.130 - info: hm-rpc.0 (1060) Connected
                                      2024-03-04 14:58:40.486 - info: host.Raspberrypi instance system.adapter.javascript.0 started with pid 1108
                                      2024-03-04 14:58:41.252 - info: host.Raspberrypi instance scheduled system.adapter.ical.1 0,30 * * * *
                                      Homoran Thomas Braun da_Woody 3 Replies Last reply Reply Quote 0
                                        das ist das log beim Neustart, leider nicht von davor. Das müsste aber als Datei vorliegen.
                                        Die Zeiten scheinen daher zu rühren, dass es etwas dauert, bis der Raspi sich wieder mit dem ntp-Server synchronisiert.
                                          @g-hawk
                                          Könnte auch etwas zu viel sein.
                                          • da_Woody
                                            da_Woody @G.Hawk last edited by
                                            @g-hawk hab jetzt beim durscrollen erst mitbekommen.
                                            RP4 mit proxmox auf einer 32er Karte?
                                            Sorry... Da wundert mich nichts.
                                            2620
