    4. ioBroker manuelles Backup
    • 1
      1704eu @Glasfaser last edited by
      @glasfaser
      [DEBUG] Error message:
      [DEBUG] error: exec: "iob": executable file not found in $PATH
      und wenn ich im Terminal nun iob fix mache, dann kommt die Meldung permission denied
      1 Glasfaser 2 Replies Last reply Reply Quote 0
      • 1
        1704eu @1704eu last edited by
        @1704eu
        ok ich hab mal chmod 755 iobroker gemacht, das bringt mich wieder einen Schritt weiter
        Checking database connection... Failed.
        [DEBUG] Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
        [DEBUG] Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
        [DEBUG] Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
        [DEBUG]  Cannot read system.config: null (OK when migrating or restoring)
        [DEBUG] Error: no UUID found
        Please check your configuration and try again.
        For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs).
        [DEBUG] Debug mode prevents the container from exiting on errors.
        [DEBUG] This enables you to investigate or fix your issue on the command line.
        [DEBUG] If you want to stop or restart your container you have to do it manually.
        [DEBUG] IoBroker is not running!
          Homoran Global Moderator Administrators @1704eu last edited by
          @1704eu sagte in ioBroker manuelles Backup:
          wo lernt man sowas?
          derselbe von dem ncars kommt?
          iobroker hat seine Rechtestruktur nicht ohne Grund
          1 1 Reply Last reply Reply Quote 0
          • 1
            1704eu @Homoran last edited by
            @homoran said in ioBroker manuelles Backup:
            wo lernt man sowas?
            ich hab im alten Broker geschaut und dort war es 755 😕
              im alten Broker
              möglich. 2014-15(16??) wurde noch als root installiert
                Thomas Braun Most Active @1704eu last edited by
                Und aktuell werden ACLs gesetzt. Nix 755.
                • 1
                  1704eu @Thomas Braun last edited by
                  der alte Broker könnte schon so alt sein, aber mein Problem ist ja, dass ich nach meinem restore nun
                  und wenn ich im Terminal nun iob fix oder irgendwas iob xxx mache, dann kommt die Meldung permission denied
                  und ich frage mich wie ich davon wieder weg komme 😕
                  • Glasfaser
                    Glasfaser @1704eu last edited by Glasfaser
                    wie soll das gehen , denn :
                    weil er ja den Container stoppt
                    bitte die komplette Synology Ausgabe vom Log ( mit der Debug Env Einstellung ) ... kein Schnipsel hier posten !
                    Also ... alles nochmal von Neu ... so bringt das nichts .. wenn du hier rummspielst !
                    Neuen Container mit dem Image ... dann JS-Controller auf 3 , dann Backup einspielen ... auch bitte warten bis alles fertig ist
                    und wenn der Fehler kommt dann das LOG hier posten !
                    • 1
                      @glasfaser said in ioBroker manuelles Backup:
                      Ich hab eine Environment Variable "DEBUG" mit dem Wert true gesetzt. Dann stoppt er den Container nicht. Viel rumgespielt hatte ich nicht, aber hier ganz ohne rum gespielt:
                      • Container buanet/iobroker@latest
                        • Pfad /opt/iobroker auf neues leeres Verzeichnis
                        • Umgebungsvariable DEBUG auf TRUE
                      • Container gestartet - und Erstconfiguration im Webfrontend durch geklickert
                      • Container neu gestartet
                        • iob -version=> 3.3.15
                        • webfrontend läd nicht
                      Log File bis hier hin:
                      date	stream	content
                      2024-03-03 20:03:00	stdout	host.ioB check instance "system.adapter.backitup.0" for host "ioB"
                      2024-03-03 20:03:00	stdout	host.ioB check instance "system.adapter.discovery.0" for host "ioB"
                      2024-03-03 20:03:00	stdout	host.ioB check instance "system.adapter.admin.0" for host "ioB"
                      2024-03-03 20:02:56	stdout	##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
                      2024-03-03 20:02:56	stdout	Starting ioBroker...
                      2024-03-03 20:02:56	stdout	--------------------------------------------------------------------------------
                      2024-03-03 20:02:56	stdout	-----                    Step 5 of 5: ioBroker Startup                     -----
                      2024-03-03 20:02:56	stdout	For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs/).
                      2024-03-03 20:02:56	stdout	Some adapters have special requirements/ settings which can be activated by the use of environment variables.
                      2024-03-03 20:02:56	stdout	-----                Step 4 of 5: Applying Special Settings                -----
                      2024-03-03 20:02:56	stdout	No action required.
                      2024-03-03 20:02:56	stdout	Hostname in ioBroker matches the hostname of this container.
                      2024-03-03 20:02:26	stdout
                      2024-03-03 20:02:26	stdout	Checking database connection... Done.
                      2024-03-03 20:02:12	stdout
                      2024-03-03 20:02:12	stdout	(Re)setting permissions (This might take a while! Please be patient!)... Done.
                      2024-03-03 20:02:12	stdout	--------------------------------------------------------------------------------
                      2024-03-03 20:02:12	stdout	-----             Step 3 of 5: Checking ioBroker Installation              -----
                      2024-03-03 20:02:10	stdout	Existing installation of ioBroker detected in "/opt/iobroker".
                      2024-03-03 20:02:10	stdout	--------------------------------------------------------------------------------
                      2024-03-03 20:02:10	stdout	-----             Step 2 of 5: Detecting ioBroker Installation             -----
                      2024-03-03 20:02:10	stdout	This is not the first run of this container. Skipping first run preparation.
                      2024-03-03 20:02:10	stdout	-----                   Step 1 of 5: Preparing Container                   -----
                      2024-03-03 20:02:10	stdout	-----                    SETUID:              1000                         -----
                      2024-03-03 20:02:10	stdout	-----                    SETGID:              1000                         -----
                      2024-03-03 20:02:10	stdout	-----                    DEBUG:               TRUE                         -----
                      2024-03-03 20:02:10	stdout	-----                        Environment Variables                         -----
                      2024-03-03 20:02:10	stdout	-----        -----
                      2024-03-03 20:02:10	stdout	-----                    npm:                 10.2.3                       -----
                      2024-03-03 20:02:09	stdout	-----                    node:                v18.19.0                     -----
                      2024-03-03 20:02:09	stdout	-----                    build:               2024-02-13T23:44:30+00:00    -----
                      2024-03-03 20:02:09	stdout	-----                    image:               v9.1.1                       -----
                      2024-03-03 20:02:09	stdout	-----                          Version Information                         -----
                      2024-03-03 20:02:09	stdout	-----        -----
                      2024-03-03 20:02:09	stdout	-----                    hostname:            ioB                          -----
                      2024-03-03 20:02:09	stdout	-----                    arch:                x86_64                       -----
                      2024-03-03 20:02:09	stdout	-----                          System Information                          -----
                      2024-03-03 20:02:09	stdout	--------------------------------------------------------------------------------
                      2024-03-03 20:02:09	stdout	-----                          Please be patient!                          -----
                      2024-03-03 20:02:09	stdout	-----                    Startupscript is now running!                     -----
                      2024-03-03 20:02:09	stdout	-----              Welcome to your ioBroker Docker container!              -----
                      2024-03-03 20:02:09	stdout	----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
                      2024-03-03 20:02:09	stdout	----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
                      2024-03-03 20:02:09	stdout	----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
                      2024-03-03 20:02:09	stdout	----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
                      2024-03-03 20:02:09	stdout	----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
                      2024-03-03 20:02:09	stdout	----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
                      2024-03-03 20:02:09	stdout	-------------------------     2024-03-03 21:02:09      -------------------------
                      2024-03-03 19:59:44	stdout	================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                      2024-03-03 19:59:44	stdout	================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
                      2024-03-03 19:58:04	stdout	Send diag info: {"uuid":"8bd5b13d-8d5e-43fa-bf47-f1930f1b9613","language":"de","country":"Germany","hosts":[{"version":"5.0.17","platform":"Javascript/Node.js","type":"linux"}],"node":"v18.19.0","arch":"x64","docker":true,"adapters":{"admin":{"version":"6.13.16","platform":"Javascript/Node.js"},"discovery":{"version":"4.2.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.9.8","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":3,"compactMode":false,"noCompactInstances":0,"model":"Intel(R) Pentium(R) CPU  N3710  @ 1.60GHz","cpus":4,"mem":8287653888,"ostype":"Linux","city":"Gottmadingen"}
                      2024-03-03 19:57:14	stdout	================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
                      2024-03-03 19:55:34	stdout	================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                      2024-03-03 19:55:31	stdout	host.ioB check instance "system.adapter.backitup.0" for host "ioB"
                      2024-03-03 19:55:31	stdout	host.ioB check instance "system.adapter.discovery.0" for host "ioB"
                      2024-03-03 19:55:31	stdout	host.ioB check instance "system.adapter.admin.0" for host "ioB"
                      2024-03-03 19:55:28	stdout	##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
                      2024-03-03 19:55:28	stdout	Starting ioBroker...
                      2024-03-03 19:55:28	stdout	--------------------------------------------------------------------------------
                      2024-03-03 19:55:28	stdout	-----                    Step 5 of 5: ioBroker Startup                     -----
                      2024-03-03 19:55:28	stdout	For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs/).
                      2024-03-03 19:55:28	stdout	Some adapters have special requirements/ settings which can be activated by the use of environment variables.
                      2024-03-03 19:55:28	stdout	-----                Step 4 of 5: Applying Special Settings                -----
                      2024-03-03 19:55:28	stdout	Done.
                      2024-03-03 19:55:26	stdout	The host for instance "system.adapter.backitup.0" was changed from "buildkitsandbox" to "ioB".
                      2024-03-03 19:55:26	stdout	The host for instance "system.adapter.discovery.0" was changed from "buildkitsandbox" to "ioB".
                      2024-03-03 19:55:26	stdout	Updating hostname to "ioB"... The host for instance "system.adapter.admin.0" was changed from "buildkitsandbox" to "ioB".
                      2024-03-03 19:55:14	stdout	Hostname in ioBroker does not match the hostname of this container.
                      2024-03-03 19:54:48	stdout
                      2024-03-03 19:54:48	stdout	Initializing a fresh installation of ioBroker... Done.
                      2024-03-03 19:54:26	stdout
                      2024-03-03 19:54:26	stdout	(Re)setting permissions (This might take a while! Please be patient!)... Done.
                      2024-03-03 19:54:26	stdout	Replacing ioBroker executable to fix sudo bug... Done.
                      2024-03-03 19:54:25	stdout
                      2024-03-03 19:54:25	stdout	--------------------------------------------------------------------------------
                      2024-03-03 19:54:25	stdout	-----             Step 3 of 5: Checking ioBroker Installation              -----
                      2024-03-03 19:54:25	stdout	Restoring initial ioBroker installation... Done.
                      2024-03-03 19:53:18	stdout	There is no data detected in /opt/iobroker.
                      2024-03-03 19:53:18	stdout	--------------------------------------------------------------------------------
                      2024-03-03 19:53:18	stdout	-----             Step 2 of 5: Detecting ioBroker Installation             -----
                      2024-03-03 19:53:17	stdout
                      2024-03-03 19:53:17	stdout	--------------------------------------------------------------------------------
                      2024-03-03 19:53:17	stdout	-----                   Step 1 of 5: Preparing Container                   -----
                      2024-03-03 19:53:17	stdout	-----                    SETUID:              1000                         -----
                      2024-03-03 19:53:17	stdout	-----                    SETGID:              1000                         -----
                      2024-03-03 19:53:17	stdout	-----                    DEBUG:               TRUE                         -----
                      2024-03-03 19:53:17	stdout	-----                        Environment Variables                         -----
                      2024-03-03 19:53:17	stdout	-----        -----
                      2024-03-03 19:53:17	stdout	-----                    npm:                 10.2.3                       -----
                      2024-03-03 19:53:15	stdout	-----                    node:                v18.19.0                     -----
                      2024-03-03 19:53:15	stdout	-----                    build:               2024-02-13T23:44:30+00:00    -----
                      2024-03-03 19:53:15	stdout	-----                    image:               v9.1.1                       -----
                      2024-03-03 19:53:15	stdout	-----                          Version Information                         -----
                      2024-03-03 19:53:15	stdout	-----        -----
                      2024-03-03 19:53:15	stdout	-----                    hostname:            ioB                          -----
                      2024-03-03 19:53:15	stdout	-----                    arch:                x86_64                       -----
                      2024-03-03 19:53:15	stdout	-----                          System Information                          -----
                      2024-03-03 19:53:15	stdout	--------------------------------------------------------------------------------
                      2024-03-03 19:53:15	stdout	-----                          Please be patient!                          -----
                      2024-03-03 19:53:15	stdout	-----                    Startupscript is now running!                     -----
                      2024-03-03 19:53:15	stdout	-----              Welcome to your ioBroker Docker container!              -----
                      2024-03-03 19:53:15	stdout	----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
                      2024-03-03 19:53:15	stdout	----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
                      2024-03-03 19:53:15	stdout	----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
                      2024-03-03 19:53:15	stdout	----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
                      2024-03-03 19:53:15	stdout	----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
                      2024-03-03 19:53:15	stdout	----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
                      2024-03-03 19:53:15	stdout	-------------------------     2024-03-03 20:53:15      -------------------------
                      Dann geht es weiter
                      • pkill -u iobroker
                      • iobroker restore 0
                      host.ioB Using backup file 2024_02_22-09_23_10_backupiobroker.tar.gz
                      iobroker controller daemon is not running
                      host.ioB OK.
                      host.ioB Clear all objects and states...
                      clean 137 objects...
                      Server Objects 127.0.0.1:44437 Error from InMemDB: Error: Object is marked as non deletable
                      [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
                      [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
                      [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"
                      [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
                      [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}
                      [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.rep
                      ositories"]}}
                      clean 76 states...
                      host.ioB done.
                      host.ioB Processed 0/5374 states
                      host.ioB Processed 200/5374 states
                      host.ioB Processed 400/5374 states
                      host.ioB Processed 600/5374 states
                      host.ioB Processed 800/5374 states
                      host.ioB Processed 1000/5374 states
                      host.ioB Processed 1200/5374 states
                      host.ioB Processed 1400/5374 states
                      host.ioB Processed 1600/5374 states
                      host.ioB Processed 1800/5374 states
                      host.ioB Processed 2000/5374 states
                      host.ioB Processed 2200/5374 states
                      host.ioB Processed 2400/5374 states
                      host.ioB Processed 2600/5374 states
                      host.ioB Processed 2800/5374 states
                      host.ioB Processed 3000/5374 states
                      host.ioB Processed 3200/5374 states
                      host.ioB Processed 3400/5374 states
                      host.ioB Processed 3600/5374 states
                      host.ioB Processed 3800/5374 states
                      host.ioB Processed 4000/5374 states
                      host.ioB Processed 4200/5374 states
                      host.ioB Processed 4400/5374 states
                      host.ioB Processed 4600/5374 states
                      host.ioB Processed 4800/5374 states
                      host.ioB Processed 5000/5374 states
                      host.ioB Processed 5200/5374 states
                      5374 states restored.
                      host.ioB Processed 0/12234 objects
                      host.ioB Processed 200/12234 objects
                      host.ioB Processed 400/12234 objects
                      host.ioB Processed 600/12234 objects
                      host.ioB Processed 800/12234 objects
                      host.ioB Processed 1000/12234 objects
                      host.ioB Processed 1200/12234 objects
                      host.ioB Processed 1400/12234 objects
                      host.ioB Processed 1600/12234 objects
                      host.ioB Processed 1800/12234 objects
                      host.ioB Processed 2000/12234 objects
                      host.ioB Processed 2200/12234 objects
                      host.ioB Processed 2400/12234 objects
                      host.ioB Processed 2600/12234 objects
                      host.ioB Processed 2800/12234 objects
                      host.ioB Processed 3000/12234 objects
                      host.ioB Processed 3200/12234 objects
                      host.ioB Processed 3400/12234 objects
                      host.ioB Processed 3600/12234 objects
                      host.ioB Processed 3800/12234 objects
                      host.ioB Processed 4000/12234 objects
                      host.ioB Processed 4200/12234 objects
                      host.ioB Processed 4400/12234 objects
                      host.ioB Processed 4600/12234 objects
                      host.ioB Processed 4800/12234 objects
                      host.ioB Processed 5000/12234 objects
                      host.ioB Processed 5200/12234 objects
                      host.ioB Processed 5400/12234 objects
                      host.ioB Processed 5600/12234 objects
                      host.ioB Processed 5800/12234 objects
                      host.ioB Processed 6000/12234 objects
                      host.ioB Processed 6200/12234 objects
                      host.ioB Processed 6400/12234 objects
                      host.ioB Processed 6600/12234 objects
                      host.ioB Processed 6800/12234 objects
                      host.ioB Processed 7000/12234 objects
                      host.ioB Processed 7200/12234 objects
                      host.ioB Processed 7400/12234 objects
                      host.ioB Processed 7600/12234 objects
                      ... da ich alles screen für screen kopieren muss spare ich mir hier mal paar Zeilen :)
                      host.ioB Processed 12200/12234 objects
                      112234 objects restored.
                      host.ioB Upload user file "vis.0/fire/img/Benni.png
                      host.ioB Upload user file "vis.0/fire/img/Benni.webp
                      host.ioB Upload user file "vis.0/fire/img/Coffee_off.png
                      host.ioB Upload user file "vis.0/fire/img/Coffee_on.png
                      host.ioB Upload user file "vis.0/fire/img/Download.png
                      host.ioB Upload user file "vis.0/fire/img/EG-Overview.png
                      host.ioB Upload user file "vis.0/fire/img/EG-Overview2-09.png
                      host.ioB Upload user file "vis.0/fire/img/EG_dark-01.png
                      host.ioB Upload user file "vis.0/fire/img/EG_light-01.png
                      host.ioB Upload user file "vis.0/fire/img/Fenster_EG_auf_cut_L.png
                      host.ioB Upload user file "vis.0/fire/img/Fenster_EG_auf_cut_R.png
                      host.ioB Upload user file "vis.0/fire/img/Fenster_EG_zu_cut_L.png
                      host.ioB Upload user file "vis.0/fire/img/Fenster_EG_zu_cut_R.png
                      host.ioB Upload user file "vis.0/fire/img/Fenster_OG_auf_cut_L.png
                      host.ioB Upload user file "vis.0/fire/img/Fenster_OG_auf_cut_R.png
                      host.ioB Upload user file "vis.0/fire/img/Fenster_OG_zu_cut_L.png
                      host.ioB Upload user file "vis.0/fire/img/Fenster_OG_zu_cut_R.png
                      host.ioB Upload user file "vis.0/fire/img/Fenster_UG_auf_cut.png
                      host.ioB Upload user file "vis.0/fire/img/Fenster_UG_zu_cut.png
                      host.ioB Upload user file "vis.0/fire/img/Licht-EG-Essen-an.png
                      host.ioB Upload user file "vis.0/fire/img/Licht-EG-Essen-aus.png
                      host.ioB Upload user file "vis.0/fire/img/Licht-EG-Gang-an.png
                      host.ioB Upload user file "vis.0/fire/img/Licht-EG-Gang-aus.png
                      host.ioB Upload user file "vis.0/fire/img/Licht-EG-Kaemmerle-an.png
                      host.ioB Upload user file "vis.0/fire/img/Licht-EG-Kaemmerle-aus.png
                      host.ioB Upload user file "vis.0/fire/img/Licht-EG-WC-an.png
                      host.ioB Upload user file "vis.0/fire/img/Licht-EG-WC-aus.png
                      host.ioB Upload user file "vis.0/fire/img/Licht-EG-Wohnen-an.png
                      host.ioB Upload user file "vis.0/fire/img/Licht-EG-Wohnen-aus.png
                      host.ioB Upload user file "vis.0/fire/img/Licht-Wohnen-an.svg
                      host.ioB Upload user file "vis.0/fire/img/OG_dark-01.png
                      host.ioB Upload user file "vis.0/fire/img/OG_light-01.png
                      host.ioB Upload user file "vis.0/fire/img/Pati.webp
                      host.ioB Upload user file "vis.0/fire/img/UG_dark-01.png
                      host.ioB Upload user file "vis.0/fire/img/UG_light-01.png
                      host.ioB Upload user file "vis.0/fire/img/Untitled-1-01.png
                      host.ioB Upload user file "vis.0/fire/img/noun_Alarm_149379.png
                      host.ioB Upload user file "vis.0/fire/img/noun_Bell_149380.png
                      host.ioB Upload user file "vis.0/fire/img/pati.png
                      host.ioB Upload user file "vis.0/fire/img/shaw-maeht.gif
                      host.ioB Upload user file "vis.0/fire/vis-user.css
                      host.ioB Upload user file "vis.0/fire/vis-views.json
                      host.ioB Upload user file "vis.0/main/vis-views.json
                      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/t
                      ranslations.json application/json
                      upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modul
                      es_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.515442
                      35.chunk.js.map application/json
                      upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modul
                      es_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map cu
                      stom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iob
                      r-99c23e.847b8ad9.chunk.js.map application/json
                      upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobro
                      ker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js.map custom/static/js/node_modules_iobrok
                      er_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js.map application/json
                      upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobro
                      ker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js custom/static/js/node_modules_iobroker_a
                      dapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js application/javascript
                      upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobro
                      ker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js.map c
                      ustom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker
                      _a-de23731.74a7cfbb.chunk.js.map application/json
                      upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobro
                      ker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js custo
                      m/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-d
                      e23731.74a7cfbb.chunk.js application/javascript
                      upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobro
                      ker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js.map c
                      _a-de23730.df74e930.chunk.js.map application/json
                      upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobro
                      ker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js custo
                      e23730.df74e930.chunk.js application/javascript
                      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js.m
                      ap custom/static/js/main.681927cc.js.map application/json
                      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js c
                      ustom/static/js/main.681927cc.js application/javascript
                      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/
                      zh-cn.json application/json
                      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.
                      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.
                      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.j
                      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.j
                      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.j
                      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.j
                      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/es.json custom/i18n/es.j
                      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/en.json custom/i18n/en.j
                      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/de.json custom/i18n/de.j
                      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custo
                      m/customComponents.js.map application/json
                      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/cu
                      stomComponents.js application/javascript
                      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                      upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application
                      /javascript
                      upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/ht
                      ml
                      upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                      upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                      upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js applica
                      tion/javascript
                      upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html tex
                      t/html
                      upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/ht
                      ml
                      upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json
                      i18n/zh-cn/translations.json application/json
                      upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18
                      n/uk/translations.json application/json
                      upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18
                      n/ru/translations.json application/json
                      upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18
                      n/pt/translations.json application/json
                      upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n
                      /pl/translations.json application/json
                      upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n
                      /nl/translations.json application/json
                      upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n
                      /it/translations.json application/json
                      upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n
                      /fr/translations.json application/json
                      upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n
                      /es/translations.json application/json
                      upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n
                      /en/translations.json application/json
                      upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n
                      /de/translations.json application/json
                      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png imag
                      e/png
                      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-se
                      ttings.js application/javascript
                      upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js applicatio
                      n/javascript
                      upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateT
                      ools.js application/javascript
                      upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.h
                      tml text/html
                      upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html
                      text/html
                      upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html te
                      xt/html
                      upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/h
                      tml
                      upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png
                      image/png
                      System successfully restored!
                      So und das alles auch wirklich fertig ist geht es morgen hier weiter 🙂
                      Denn hier kam das Problem ....
                      • Glasfaser
                        Und was ist jetzt das Ergebnis !?
                        • 1
                          @glasfaser
                          Ich hab die debug ENV leider erst mit TRUE gesetzt statt mit true, drum im Log zwei Neustarts ohne Debug und dann erst mit.
                          er bleibt im Terminal bei "Checking database connection..." eine Weile stehen, dann kommt "failed" und dann "This Script will exit now."
                          Hier das Docker Log:
                          ![f33deaf4-f6af-443f-aa17-204cf3e90a7b-image.png](/assets/uploads/files/1709561120575-f33deaf4-f6af-443f-aa17-204cf3e90a7b-image.png) 04.03.2024 13:02	stdout	-----                    build:               2024-02-13T23:44:30+00:00    -----
                          04.03.2024 13:02	stdout	-----                    image:               v9.1.1                       -----
                          04.03.2024 13:02	stdout	-----                          Version Information                         -----
                          04.03.2024 13:02	stdout	-----        -----
                          04.03.2024 13:02	stdout	-----                    hostname:            ioB                          -----
                          04.03.2024 13:02	stdout	-----                    arch:                x86_64                       -----
                          04.03.2024 13:02	stdout	-----                          System Information                          -----
                          04.03.2024 13:02	stdout	--------------------------------------------------------------------------------
                          04.03.2024 13:02	stdout	-----                          Please be patient!                          -----
                          04.03.2024 13:02	stdout	-----                    Startupscript is now running!                     -----
                          04.03.2024 13:02	stdout	-----              Welcome to your ioBroker Docker container!              -----
                          04.03.2024 13:02	stdout	----- +-+  +-----+  +-----+  +-+  +-+  +-----+  +-+  +-+ +------+ +-+  +-+ -----
                          04.03.2024 13:02	stdout	----- ¦¦¦ +¦¦¦¦¦¦++ ¦¦¦¦¦¦++ ¦¦¦  ¦¦¦ +¦¦¦¦¦¦++ ¦¦¦  ¦¦+ ¦¦¦¦¦¦¦+ ¦¦¦  ¦¦¦ -----
                          04.03.2024 13:02	stdout	----- ¦¦¦ ¦¦¦   ¦¦¦ ¦¦+--¦¦+ ¦¦+--¦¦+ ¦¦¦   ¦¦¦ ¦¦+-¦¦+  ¦¦+--+   ¦¦+--¦¦+ -----
                          04.03.2024 13:02	stdout	----- ¦¦¦ ¦¦¦   ¦¦¦ ¦¦¦¦¦¦++ ¦¦¦¦¦¦++ ¦¦¦   ¦¦¦ ¦¦¦¦¦++  ¦¦¦¦¦+   ¦¦¦¦¦¦++ -----
                          04.03.2024 13:02	stdout	----- ¦¦¦ ¦¦+---¦¦+ ¦¦+--¦¦+ ¦¦+--¦¦+ ¦¦+---¦¦+ ¦¦¦ ¦¦++ ¦¦+----+ ¦¦+--¦¦+ -----
                          04.03.2024 13:02	stdout	----- ¦¦+  ¦¦¦¦¦¦+  ¦¦¦¦¦¦+  ¦¦¦¦¦¦+   ¦¦¦¦¦¦+  ¦¦+  ¦¦+ ¦¦¦¦¦¦¦+ ¦¦¦¦¦¦+  -----
                          04.03.2024 13:02	stdout	-------------------------     2024-03-04 14:02:09      -------------------------
                          04.03.2024 13:02	stdout	-----                    node:                v18.19.0                     -----
                          04.03.2024 13:02	stdout	-----             Step 2 of 5: Detecting ioBroker Installation             -----
                          04.03.2024 13:02	stdout	This is not the first run of this container. Skipping first run preparation.
                          04.03.2024 13:02	stdout	-----                   Step 1 of 5: Preparing Container                   -----
                          04.03.2024 13:02	stdout	-----                    SETUID:              1000                         -----
                          04.03.2024 13:02	stdout	-----                    SETGID:              1000                         -----
                          04.03.2024 13:02	stdout	-----                    DEBUG:               TRUE                         -----
                          04.03.2024 13:02	stdout	-----                        Environment Variables                         -----
                          04.03.2024 13:02	stdout	-----                    npm:                 10.2.3                       -----
                          04.03.2024 13:02	stdout	-----             Step 3 of 5: Checking ioBroker Installation              -----
                          04.03.2024 13:02	stdout	Existing installation of ioBroker detected in "/opt/iobroker".
                          04.03.2024 13:02	stdout	(Re)setting permissions (This might take a while! Please be patient!)... Done.
                          04.03.2024 13:02	stdout	This Script will exit now.
                          04.03.2024 13:02	stdout	For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs).
                          04.03.2024 13:02	stdout	Please check your configuration and try again.
                          04.03.2024 13:02	stdout	Checking database connection... Failed.
                          04.03.2024 13:02	stdout	-------------------------     2024-03-04 14:02:42      -------------------------
                          04.03.2024 13:04	stdout	-----                    node:                v18.19.0                     -----
                          04.03.2024 13:04	stdout	-----                    build:               2024-02-13T23:44:30+00:00    -----
                          04.03.2024 13:04	stdout	-----                    image:               v9.1.1                       -----
                          04.03.2024 13:04	stdout	-----                          Version Information                         -----
                          04.03.2024 13:04	stdout	-----        -----
                          04.03.2024 13:04	stdout	-----                    hostname:            ioB                          -----
                          04.03.2024 13:04	stdout	-----                    arch:                x86_64                       -----
                          04.03.2024 13:04	stdout	-----                          System Information                          -----
                          04.03.2024 13:04	stdout	--------------------------------------------------------------------------------
                          04.03.2024 13:04	stdout	-----                          Please be patient!                          -----
                          04.03.2024 13:04	stdout	-----                    Startupscript is now running!                     -----
                          04.03.2024 13:04	stdout	-----              Welcome to your ioBroker Docker container!              -----
                          04.03.2024 13:04	stdout	----- +-+  +-----+  +-----+  +-+  +-+  +-----+  +-+  +-+ +------+ +-+  +-+ -----
                          04.03.2024 13:04	stdout	----- ¦¦¦ +¦¦¦¦¦¦++ ¦¦¦¦¦¦++ ¦¦¦  ¦¦¦ +¦¦¦¦¦¦++ ¦¦¦  ¦¦+ ¦¦¦¦¦¦¦+ ¦¦¦  ¦¦¦ -----
                          04.03.2024 13:04	stdout	----- ¦¦¦ ¦¦¦   ¦¦¦ ¦¦+--¦¦+ ¦¦+--¦¦+ ¦¦¦   ¦¦¦ ¦¦+-¦¦+  ¦¦+--+   ¦¦+--¦¦+ -----
                          04.03.2024 13:04	stdout	----- ¦¦¦ ¦¦¦   ¦¦¦ ¦¦¦¦¦¦++ ¦¦¦¦¦¦++ ¦¦¦   ¦¦¦ ¦¦¦¦¦++  ¦¦¦¦¦+   ¦¦¦¦¦¦++ -----
                          04.03.2024 13:04	stdout	----- ¦¦¦ ¦¦+---¦¦+ ¦¦+--¦¦+ ¦¦+--¦¦+ ¦¦+---¦¦+ ¦¦¦ ¦¦++ ¦¦+----+ ¦¦+--¦¦+ -----
                          04.03.2024 13:04	stdout	----- ¦¦+  ¦¦¦¦¦¦+  ¦¦¦¦¦¦+  ¦¦¦¦¦¦+   ¦¦¦¦¦¦+  ¦¦+  ¦¦+ ¦¦¦¦¦¦¦+ ¦¦¦¦¦¦+  -----
                          04.03.2024 13:04	stdout	-------------------------     2024-03-04 14:04:00      -------------------------
                          04.03.2024 13:04	stdout	-----             Step 2 of 5: Detecting ioBroker Installation             -----
                          04.03.2024 13:04	stdout	This is not the first run of this container. Skipping first run preparation.
                          04.03.2024 13:04	stdout	-----                   Step 1 of 5: Preparing Container                   -----
                          04.03.2024 13:04	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                          04.03.2024 13:04	stdout	!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
                          04.03.2024 13:04	stdout	!!!!     For more information see ioBroker Docker image documentation:      !!!!
                          04.03.2024 13:04	stdout	!!!!          Please make sure to deactivate if no longer needed.           !!!!
                          04.03.2024 13:04	stdout	!!!! This will extend the logging output and may slow down container start. !!!!
                          04.03.2024 13:04	stdout	!!!!               Environment variable DEBUG is set to true.               !!!!
                          04.03.2024 13:04	stdout	!!!!                            DEBUG LOG ACTIVE                            !!!!
                          04.03.2024 13:04	stdout	-----                    SETUID:              1000                         -----
                          04.03.2024 13:04	stdout	-----                    SETGID:              1000                         -----
                          04.03.2024 13:04	stdout	-----                    DEBUG:               true                         -----
                          04.03.2024 13:04	stdout	-----                        Environment Variables                         -----
                          04.03.2024 13:04	stdout	-----                    npm:                 10.2.3                       -----
                          04.03.2024 13:04	stdout	(Re)setting permissions (This might take a while! Please be patient!)... Done.
                          04.03.2024 13:04	stdout	-----             Step 3 of 5: Checking ioBroker Installation              -----
                          04.03.2024 13:04	stdout	Existing installation of ioBroker detected in "/opt/iobroker".
                          04.03.2024 13:04	stdout	[DEBUG] Done.
                          04.03.2024 13:04	stdout	[DEBUG] No custom states db settings detected.
                          04.03.2024 13:04	stdout	[DEBUG] Checking custom states db settings...
                          04.03.2024 13:04	stdout	[DEBUG] No custom objects db settings detected.
                          04.03.2024 13:04	stdout	[DEBUG] Checking custom objects db settings...
                          04.03.2024 13:04	stdout	[DEBUG] No multihost settings detected.
                          04.03.2024 13:04	stdout	[DEBUG] Checking multihost settings...
                          04.03.2024 13:04	stdout	[DEBUG] IoBroker is not running!
                          04.03.2024 13:04	stdout	[DEBUG] If you want to stop or restart your container you have to do it manually.
                          04.03.2024 13:04	stdout	[DEBUG] This enables you to investigate or fix your issue on the command line.
                          04.03.2024 13:04	stdout	[DEBUG] Debug mode prevents the container from exiting on errors.
                          04.03.2024 13:04	stdout	For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs).
                          04.03.2024 13:04	stdout	Please check your configuration and try again.
                          04.03.2024 13:04	stdout	[DEBUG] Error: no UUID found
                          04.03.2024 13:04	stdout	[DEBUG]  Cannot read system.config: null (OK when migrating or restoring)
                          04.03.2024 13:04	stdout	[DEBUG] Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
                          04.03.2024 13:04	stdout	[DEBUG] Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
                          04.03.2024 13:04	stdout	[DEBUG] Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
                          04.03.2024 13:04	stdout	[DEBUG] Error message:
                          04.03.2024 13:04	stdout	Checking database connection... Failed.
                          2024-03-03 19:55:31"	stdout	host.ioB check instance system.adapter.backitup.0" for host "ioB"
                          • Glasfaser
                            Ich denke ... ich selber komme hier nicht weiter ...
                            wie schon geschrieben war es nur ein Versuch , da es hier ein sehr großer Versions" Rücksprung " ist.
                            Aber ... eins fehlt hier mir als Information zu deinem bestehenden ioBroker !?
                            @glasfaser sagte in ioBroker manuelles Backup:
                            iob fixund iob diag sind auf dem alten broker nicht vorhanden.
                            dann zeige mal
                            iob list instances
                            iob list adapters
                            und
                            type -P nodejs && nodejs -v && type -P node && node -v && type -P npm && npm -v && type -P npx && npx -v && apt policy nodejs && ls -lh /opt/iobroker/iobroker-data/&& iob version
                            diese Info fehlt noch !
                            • 1
                              @glasfaser
                              iob list instances und iob list adapter oder auch iobroker list instances ergeben folgende Meldung:
                              bash: /usr/bin/iobroker: /usr/bin/bash: Defekter Interpreter: Datei oder Verzeichnis nicht gefunden
                              das andere funktioniert überwiegend:
                              /usr/bin/nodejs
                              v10.18.1
                              /usr/bin/node
                              v10.18.1
                              /usr/bin/npm
                              6.13.4
                              /usr/bin/npx
                              6.13.4
                              nodejs:
                                Installiert:           10.18.1-1nodesource1
                                Installationskandidat: 10.18.1-1nodesource1
                                Versionstabelle:
                               *** 10.18.1-1nodesource1 100
                                      100 /var/lib/dpkg/status
                              insgesamt 27M
                              drwxr-xr-x 1 iobroker iobroker 3,3K Mär  4 21:30 backup-objects
                              -rwxr-xr-x 1 iobroker iobroker  27K Mär  4 18:07 doorbird.0.snap.jpg
                              drwxr-xr-x 1 iobroker iobroker 1,1K Feb 21 20:47 files
                              drwxr-xr-x 1 iobroker iobroker  22K Mär  4 00:04 history
                              -rwxr-xr-x 1 iobroker iobroker 4,3K Mär  1 08:32 iobroker.json
                              -rwxr-xr-x 1 iobroker iobroker    3 Mär  1 11:46 notifications.json
                              -rwxr-xr-x 1 iobroker iobroker  12M Mär  4 22:51 objects.json
                              -rwxr-xr-x 1 iobroker iobroker  12M Mär  4 22:45 objects.json.bak
                              drwxr-xr-x 1 iobroker iobroker   18 Feb 21 20:53 sqlite
                              -rwxr-xr-x 1 iobroker iobroker 1,3M Mär  4 22:53 states.json
                              -rwxr-xr-x 1 iobroker iobroker 1,3M Mär  4 22:53 states.json.bak
                              -rwxr-xr-x 1 iobroker iobroker    0 Feb 19  2023 states.json.broken
                              drwxr-xr-x 1 iobroker iobroker   20 Feb 21 20:53 tmp
                              drwxr-xr-x 1 iobroker iobroker  256 Feb 21 20:53 yahka.0.hapdata
                              bash: /usr/bin/iob: /usr/bin/bash: Defekter Interpreter: Datei oder Verzeichnis nicht gefunden
                              ich hab ja einen Container v4 und aktuell ist v9. Ich könnte ja auch versuchen über mehrere Zwischenstufen der Containerversion Stück für Stück nach oben zu kommen? Container v6 js-Controller runter ziehen, backup einspielen, js-controller hoch, backup erstellen, ....?
                              Oder mir auch nicht unsympathisch, ich setze einen ganz neuen Broker auf, installiere die Adapter die ich brauche Stück für Stück manuell, ABER alle enums, scripte, ... das wäre echt Arbeit 😞 und vor allem... alle history Daten wären dann vermutlich nicht zu retten, oder?
                                @1704eu
                                Mit nodejs@10 kannste natürlich nix mehr reißen...
                                Never touch a rumpling süstem?
                                Leute... Es funktioniert nicht, einmal irgendwas auf die Kisten zu knallen und dann nie mehr anzupacken.
                                Je länger da gepennt wird desto schwieriger bis aussichtsloser wird der Versuch eines Upgrades.
                                • 1
                                  Da hast du schon recht, das bringt mich jetzt aber leider nicht weiter.
                                  • Marc Berg
                                    Marc Berg Most Active last edited by
                                    Ich habe das mal durchgespielt. Vom js-controller 3.3.15 zum aktuellen 5.0.19 bin ich mit einem Zwischenschritt (Image v6.1.0 mit Nodejs 14) gekommen. Von dort aus auf js-controller 4.0.24. Dieser ist wiederum auf dem v9 Image lauffähig. Das Ganze ohne Backup/Restore, sondern nur durch Updaten des Images.
                                    Wenn du den Weg über Backup/Restore gehst und das Image v6 nutzt, musst du neben dem js-controller auch den Admin downgraden. Die Version 5.1.0 ist z.B. mit deinem uralten Controller kompatibel.
                                    Ob das auch auf einem voll installiertem System mit vielen Adaptern so geht? 🤷‍♂️
                                    3763
