    4. Absturz jede Woche beheben
      G.Hawk @Homoran last edited by
      Also ich beobachte das ganze mal.
      Erstmal vielen Dank für die Hilfe.
      Gruß G.Hawk
        G.Hawk @G.Hawk last edited by
        Hallo
        Eben war ich am Skripte schreiben als er wieder abgestürzt ist.
        Folgendes steht im Log, das steht da immer wenn er abstürzt.
        Interessant sind die Zeiten...
        Was sagt ihr dazu kann man da irgendwas dran erkennen?
        2024-03-04 14:50:52.843 - info: smartmeter.0 (1271) Received 19 values, 8 updated
        2024-03-04 14:50:59.633 - info: smartmeter.1 (1281) Received 19 values, 10 updated
        2024-03-04 14:31:15.741 - info: host.Raspberrypi iobroker.js-controller version 5.0.19 js-controller starting
        2024-03-04 14:31:15.748 - info: host.Raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
        2024-03-04 14:31:15.749 - info: host.Raspberrypi hostname: Raspberrypi, node: v18.19.1
        2024-03-04 14:31:15.750 - info: host.Raspberrypi ip addresses: fd00::c7f0:7c62:3e69:b975 fe80::6213:58b0:7758:34f6
        2024-03-04 14:31:20.834 - info: host.Raspberrypi connected to Objects and States
        2024-03-04 14:31:20.955 - info: host.Raspberrypi added notifications configuration of host
        2024-03-04 14:31:22.401 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.nodeCurrent"
        2024-03-04 14:31:22.404 - info: host.Raspberrypi 61 instances found
        2024-03-04 14:31:22.527 - info: host.Raspberrypi starting 42 instances
        2024-03-04 14:31:22.789 - info: host.Raspberrypi instance system.adapter.admin.0 started with pid 930
        2024-03-04 14:31:22.815 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.nodeNewest"
        2024-03-04 14:31:22.868 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.nodeNewestNext"
        2024-03-04 14:31:22.922 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.npmCurrent"
        2024-03-04 14:31:22.977 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.npmNewest"
        2024-03-04 14:31:23.029 - info: host.Raspberrypi Delete state "system.host.Raspberrypi.versions.npmNewestNext"
        2024-03-04 14:31:23.080 - info: host.Raspberrypi Some obsolete host states deleted.
        2024-03-04 14:31:26.368 - error: admin.0 (930) admin.0 already running
        2024-03-04 14:31:26.372 - warn: admin.0 (930) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2024-03-04 14:31:26.720 - info: host.Raspberrypi instance system.adapter.javascript.0 started with pid 941
        2024-03-04 14:31:27.169 - error: host.Raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2024-03-04 14:31:27.170 - info: host.Raspberrypi Restart adapter system.adapter.admin.0 because enabled
        2024-03-04 14:31:30.725 - info: host.Raspberrypi instance system.adapter.pushover.0 started with pid 963
        2024-03-04 14:31:31.150 - error: javascript.0 (941) javascript.0 already running
        2024-03-04 14:31:31.154 - warn: javascript.0 (941) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2024-03-04 14:31:31.897 - error: host.Raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2024-03-04 14:31:31.898 - info: host.Raspberrypi Restart adapter system.adapter.javascript.0 because enabled
        2024-03-04 14:31:33.149 - error: pushover.0 (963) pushover.0 already running
        2024-03-04 14:31:33.155 - warn: pushover.0 (963) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2024-03-04 14:31:33.922 - error: host.Raspberrypi instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2024-03-04 14:31:33.923 - info: host.Raspberrypi Restart adapter system.adapter.pushover.0 because enabled
        2024-03-04 14:31:34.723 - info: host.Raspberrypi instance system.adapter.influxdb.0 started with pid 974
        2024-03-04 14:58:15.470 - error: influxdb.0 (974) influxdb.0 already running
        2024-03-04 14:58:15.474 - warn: influxdb.0 (974) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2024-03-04 14:58:16.168 - error: host.Raspberrypi instance system.adapter.influxdb.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2024-03-04 14:58:16.169 - info: host.Raspberrypi Restart adapter system.adapter.influxdb.0 because enabled
        2024-03-04 14:58:16.770 - info: host.Raspberrypi instance system.adapter.backitup.0 started with pid 990
        2024-03-04 14:58:19.145 - error: backitup.0 (990) backitup.0 already running
        2024-03-04 14:58:19.149 - warn: backitup.0 (990) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2024-03-04 14:58:19.845 - error: host.Raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2024-03-04 14:58:19.846 - info: host.Raspberrypi Restart adapter system.adapter.backitup.0 because enabled
        2024-03-04 14:58:20.766 - info: host.Raspberrypi instance system.adapter.alexa2.0 started with pid 1001
        2024-03-04 14:58:23.177 - error: alexa2.0 (1001) alexa2.0 already running
        2024-03-04 14:58:23.182 - warn: alexa2.0 (1001) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2024-03-04 14:58:23.873 - error: host.Raspberrypi instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2024-03-04 14:58:23.874 - info: host.Raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
        2024-03-04 14:58:24.770 - info: host.Raspberrypi instance system.adapter.hm-rega.0 started with pid 1014
        2024-03-04 14:58:27.245 - error: hm-rega.0 (1014) hm-rega.0 already running
        2024-03-04 14:58:27.250 - warn: hm-rega.0 (1014) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2024-03-04 14:58:27.946 - error: host.Raspberrypi instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2024-03-04 14:58:27.948 - info: host.Raspberrypi Restart adapter system.adapter.hm-rega.0 because enabled
        2024-03-04 14:58:28.777 - info: host.Raspberrypi instance system.adapter.hm-rpc.0 started with pid 1025
        2024-03-04 14:58:29.135 - info: host.Raspberrypi instance system.adapter.hm-rega.0 started with pid 1034
        2024-03-04 14:58:31.626 - error: hm-rpc.0 (1025) hm-rpc.0 already running
        2024-03-04 14:58:31.632 - warn: hm-rpc.0 (1025) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2024-03-04 14:58:32.368 - error: host.Raspberrypi instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2024-03-04 14:58:32.369 - info: host.Raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
        2024-03-04 14:58:32.769 - info: host.Raspberrypi instance system.adapter.hm-rpc.1 started with pid 1049
        2024-03-04 14:58:32.859 - info: hm-rega.0 (1034) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v18.19.1, js-controller: 5.0.19
        2024-03-04 14:58:33.674 - info: host.Raspberrypi instance system.adapter.hm-rpc.0 started with pid 1060
        2024-03-04 14:58:33.736 - info: hm-rega.0 (1034) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
        2024-03-04 14:58:33.852 - info: hm-rega.0 (1034) ReGaHSS 192.168.10.19 up
        2024-03-04 14:58:33.959 - info: hm-rega.0 (1034) time difference local-ccu 1s
        2024-03-04 14:58:35.724 - info: host.Raspberrypi instance system.adapter.admin.0 started with pid 1075
        2024-03-04 14:58:35.842 - error: hm-rpc.1 (1049) hm-rpc.1 already running
        2024-03-04 14:58:35.849 - warn: hm-rpc.1 (1049) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2024-03-04 14:58:36.937 - error: host.Raspberrypi instance system.adapter.hm-rpc.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2024-03-04 14:58:36.938 - info: host.Raspberrypi Restart adapter system.adapter.hm-rpc.1 because enabled
        2024-03-04 14:58:37.037 - info: host.Raspberrypi instance scheduled system.adapter.ical.0 0,30 * * * *
        2024-03-04 14:58:37.044 - info: host.Raspberrypi instance system.adapter.ical.0 started with pid 1082
        2024-03-04 14:58:38.222 - info: host.Raspberrypi instance system.adapter.hm-rpc.1 started with pid 1089
        2024-03-04 14:58:38.440 - info: hm-rpc.0 (1060) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.1, js-controller: 5.0.19
        2024-03-04 14:58:39.360 - info: hm-rpc.0 (1060) xmlrpc server is trying to listen on 192.168.10.13:2001
        2024-03-04 14:58:39.362 - info: hm-rpc.0 (1060) xmlrpc client is trying to connect to 192.168.10.19:2001/ with ["http://192.168.10.13:2001","Raspberrypi:hm-rpc.0:5328f3ff804d13e23c227f6c4373fef7"]
        2024-03-04 14:58:39.523 - info: hm-rpc.0 (1060) xmlrpc <- system.listMethods ["Raspberrypi:hm-rpc.0:5328f3ff804d13e23c227f6c4373fef7"]
        2024-03-04 14:58:39.556 - info: hm-rpc.0 (1060) xmlrpc <- listDevices ["Raspberrypi:hm-rpc.0:5328f3ff804d13e23c227f6c4373fef7"]
        2024-03-04 14:58:40.021 - info: hm-rpc.0 (1060) xmlrpc -> 252 devices
        2024-03-04 14:58:40.130 - info: hm-rpc.0 (1060) Connected
        2024-03-04 14:58:40.486 - info: host.Raspberrypi instance system.adapter.javascript.0 started with pid 1108
        2024-03-04 14:58:41.252 - info: host.Raspberrypi instance scheduled system.adapter.ical.1 0,30 * * * *
        Homoran Thomas Braun da_Woody 3 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @G.Hawk last edited by
          @g-hawk sagte in Absturz jede Woche beheben:
          das ist das log beim Neustart, leider nicht von davor. Das müsste aber als Datei vorliegen.
          Die Zeiten scheinen daher zu rühren, dass es etwas dauert, bis der Raspi sich wieder mit dem ntp-Server synchronisiert.
            Thomas Braun Most Active @G.Hawk last edited by
            @g-hawk
            Könnte auch etwas zu viel sein.
            • da_Woody
              da_Woody @G.Hawk last edited by
              @g-hawk hab jetzt beim durscrollen erst mitbekommen.
              RP4 mit proxmox auf einer 32er Karte?
              Sorry... Da wundert mich nichts.
                Homoran Global Moderator Administrators @da_Woody last edited by
                @da_woody sagte in Absturz jede Woche beheben:
                mit proxmox
                das hab ich nicht gelesen.
                Warum hackt ihr auf der 32GB Karte rum?
                Solange die nicht voll ist, ist das ok
                da_Woody Thomas Braun 2 Replies Last reply Reply Quote 0
                • da_Woody
                  da_Woody @Homoran last edited by
                  @homoran sorry, war 12er Eintrag von @MartinP
                    @homoran sagte in Absturz jede Woche beheben:
                    Kannste auch nicht gelesen haben, ist nämlich kein virtuelles System.
                    Aber auf dem Weg dorthin. 80% ist gut gefüllt.
                      G.Hawk @Thomas Braun last edited by
                      Wieviel Instanzen kann der denn vertragen?
                      Wäre vielleicht ein PI5 8 GB mit m2 eine Alternative?
                      Ich dachte eigentlich immer ich habe es gar nicht so übertrieben.
                      Ich habe ca 40 Instanzen, 25000 Objekte und ca. 200 Skripte und eine recht umfangreiche VIS.
                      Ist das zuviel für den PI 4 mit 4GB?
                      DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
                      • DJMarc75
                        DJMarc75 @G.Hawk last edited by
                        Ja - grenzwertig 😉
                          Joh.
                          Alleine die 40 Adapter kannst du mit je 80 - 100 MB veranschlagen. Damit biste also damit schon an der Grenze.
                          Dann braucht das OS noch ein wenig usw.
                          Wenn dann was läuft, was nochmal richtig RAM frisst (Backup z. B.) ist dann Schicht im Schacht.
                            Das komische ist nur dass es eine Woche lang gut geht und dann auf einmal nicht mehr.
                            Was wäre denn eine Alternative mit mehr Leistung?
                            Meister Mopper Thomas Braun 2 Replies Last reply Reply Quote 0
                            • Meister Mopper
                              Meister Mopper @G.Hawk last edited by
                              Na ja, ein Raspberrypi 4B mit 8G oder ein 5er mit 8G oder ein MiniPC mit Proxmox. Such dir was aus 🤷‍♂️ .
                                Dann kippt dir das halt nach einer Woche um.
                                  Ich habe jetzt mal einen Test gemacht und alles neu gemacht.
                                  Alles läuft so weit und die SD Karte ist nur noch zu 18% gefüllt.
                                  Ich habe nur ein Problem die Influxdb Datenbank wiederherzustellen.
                                  Ich habe ein Backup von Influx über den Backitup Adapter beim Restore vom folgendes:
                                  Started restore ...
                                  [DEBUG] [influxDB] - Created tmp directory
                                  [DEBUG] [influxDB] - Start infuxDB Restore ...
                                  [DEBUG] [influxDB] - influxdb.0 is stopped
                                  [ERROR] [influxDB] - Error: failed to check existence of organization "G.Hawk": 401 Unauthorized: unauthorized access
                                  [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                                  [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                                  [DEBUG] [influxDB] - infuxDB Restore completed successfully
                                  [EXIT] influxDB restore done
                                  [DEBUG] [influxDB] - influxdb.0 started
                                  Kann mir jemand sagen, wie ich das Backup wieder einspiele?
                                  Gruß G.Hawk
                                    @g-hawk
                                    Update: mit dem PI 5 8GB läuft alles super.
                                    2620
