Mulitihost
Wie kommt der Multihost zustande und wie bekomme ich das wieder weg?
toki@iobroker:~$ iob start toki@iobroker:~$ iob status Cannot determine Set feature status: Connection is closed. Connection is closed. Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:459:23) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed. Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed. Unable to subscribe to meta namespace "meta." changes: Connection is closed. toki@iobroker:~$
@toki1973 sagte in Mulitihost:
hast du keinen konfiguriert?
Bitte
iob diag
in der Langfassung -
Nein habe ich nicht konfiguriert======== Start marking the full check here =========
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: iobroker Icon name: computer-vm Chassis: vm 🖴 Virtualization: kvm Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-17-amd64 Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Firmware Version: rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org model name : Common KVM processor Docker : false Virtualization : kvm Kernel : x86_64 Userland : amd64 Systemuptime and Load: 12:04:58 up 5 days, 22:39, 4 users, load average: 2.88, 3.69, 2.82 CPU threads: 4 *** Time and Time Zones *** Local time: Tue 2024-03-05 12:04:58 CET Universal time: Tue 2024-03-05 11:04:58 UTC RTC time: Tue 2024-03-05 11:04:58 Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** toki /home/toki toki cdrom floppy sudo audio dip video plugdev users netdev iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 6.3G 4.0G 1.4G 524K 1.2G 2.3G Swap: 1.0G 4.1M 1.0G Total: 7.4G 4.0G 2.4G 6051 M total memory 3841 M used memory 527 M active memory 3690 M inactive memory 1317 M free memory 240 M buffer memory 943 M swap cache 974 M total swap 3 M used swap 971 M free swap *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.0G 0 3.0G 0% /dev tmpfs tmpfs 606M 572K 605M 1% /run /dev/sda1 ext4 31G 7.2G 22G 25% / tmpfs tmpfs 3.0G 0 3.0G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 606M 0 606M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Wed Feb 28 13:25:12 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none. [Wed Feb 28 13:25:15 2024] EXT4-fs (sda1): re-mounted. Quota mode: none. [Fri Mar 1 02:16:56 2024] Modules linked in: sha512_generic cmac nls_utf8 cifs cifs_arc4 cifs_md4 dns_resolver fscache netfs sunrpc cdc_acm virtio_console virtio_balloon joydev evdev sg button serio_raw pcspkr binfmt_misc dm_mod fuse loop configfs efi_pstore qemu_fw_cfg ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic hid_generic usbhid hid sd_mod t10_pi crc64_rocksoft crc64 crc_t10dif crct10dif_generic crct10dif_common sr_mod bochs drm_vram_helper cdrom drm_kms_helper virtio_net drm_ttm_helper ttm net_failover failover virtio_scsi ata_generic xhci_pci xhci_hcd ata_piix uhci_hcd ehci_hcd drm libata usbcore psmouse virtio_pci virtio_pci_legacy_dev virtio_pci_modern_dev virtio virtio_ring scsi_mod i2c_piix4 usb_common scsi_common floppy [Fri Mar 1 02:18:22 2024] Modules linked in: sha512_generic cmac nls_utf8 cifs cifs_arc4 cifs_md4 dns_resolver fscache netfs sunrpc cdc_acm virtio_console virtio_balloon joydev evdev sg button serio_raw pcspkr binfmt_misc dm_mod fuse loop configfs efi_pstore qemu_fw_cfg ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic hid_generic usbhid hid sd_mod t10_pi crc64_rocksoft crc64 crc_t10dif crct10dif_generic crct10dif_common sr_mod bochs drm_vram_helper cdrom drm_kms_helper virtio_net drm_ttm_helper ttm net_failover failover virtio_scsi ata_generic xhci_pci xhci_hcd ata_piix uhci_hcd ehci_hcd drm libata usbcore psmouse virtio_pci virtio_pci_legacy_dev virtio_pci_modern_dev virtio virtio_ring scsi_mod i2c_piix4 usb_common scsi_common floppy [Tue Mar 5 12:00:42 2024] Modules linked in: sha512_generic cmac nls_utf8 cifs cifs_arc4 cifs_md4 dns_resolver fscache netfs sunrpc cdc_acm virtio_console virtio_balloon joydev evdev sg button serio_raw pcspkr binfmt_misc dm_mod fuse loop configfs efi_pstore qemu_fw_cfg ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic hid_generic usbhid hid sd_mod t10_pi crc64_rocksoft crc64 crc_t10dif crct10dif_generic crct10dif_common sr_mod bochs drm_vram_helper cdrom drm_kms_helper virtio_net drm_ttm_helper ttm net_failover failover virtio_scsi ata_generic xhci_pci xhci_hcd ata_piix uhci_hcd ehci_hcd drm libata usbcore psmouse virtio_pci virtio_pci_legacy_dev virtio_pci_modern_dev virtio virtio_ring scsi_mod i2c_piix4 usb_common scsi_common floppy Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 589M /var/ 246M /var/cache 239M /var/cache/apt 172M /var/lib 171M /var/log Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 24.4M in the file system. /opt/iobroker/backups: 52M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 855M /opt/iobroker/iobroker-data/ 594M /opt/iobroker/iobroker-data/files 168M /opt/iobroker/iobroker-data/backup-objects 93M /opt/iobroker/iobroker-data/files/vis.0 57M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 70M /opt/iobroker/iobroker-data/objects.jsonl 36M /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if03 /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if00 *** NodeJS-Installation *** /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.1-1nodesource1 Version table: 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages *** 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0+dfsg1-1 500 500 http://deb.debian.org/debian bookworm/main amd64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.17 admin: 6.13.16 javascript: 7.8.0 Adapters from github: 2 Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : iobroker - enabled + system.adapter.backitup.0 : backitup : iobroker - enabled system.adapter.ble.0 : ble : iobroker - disabled + system.adapter.bluelink.0 : bluelink : iobroker - enabled system.adapter.broadlink2.0 : broadlink2 : iobroker - disabled system.adapter.bshb.0 : bshb : iobroker - disabled system.adapter.chromecast.0 : chromecast : iobroker - disabled system.adapter.cloud.0 : cloud : iobroker - disabled system.adapter.daswetter.0 : daswetter : iobroker - enabled system.adapter.device-reminder.0 : device-reminder : iobroker - disabled system.adapter.devices.0 : devices : iobroker - disabled system.adapter.discovery.0 : discovery : iobroker - disabled system.adapter.echarts.0 : echarts : iobroker - disabled + system.adapter.energiefluss.0 : energiefluss : iobroker - enabled system.adapter.evcc.0 : evcc : iobroker - disabled, port: 7070 system.adapter.firetv.0 : firetv : iobroker - disabled system.adapter.flot.0 : flot : iobroker - disabled + system.adapter.followthesun.0 : followthesun : iobroker - enabled system.adapter.fullybrowser.0 : fullybrowser : iobroker - disabled + system.adapter.go-e.0 : go-e : iobroker - enabled system.adapter.heatingcontrol.0 : heatingcontrol : iobroker - disabled system.adapter.history.0 : history : iobroker - disabled system.adapter.homeconnect.0 : homeconnect : iobroker - disabled system.adapter.hue-extended.0 : hue-extended : iobroker - disabled + system.adapter.hue-extended.1 : hue-extended : iobroker - enabled + system.adapter.hue.1 : hue : iobroker - enabled, port: 80 system.adapter.ical.0 : ical : iobroker - enabled system.adapter.ical.1 : ical : iobroker - enabled system.adapter.icons-icons8.0 : icons-icons8 : iobroker - enabled system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker - enabled + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.info.0 : info : iobroker - enabled + system.adapter.iot.0 : iot : iobroker - enabled system.adapter.jarvis.0 : jarvis : iobroker - disabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.javascript.0 : javascript : iobroker - enabled system.adapter.javascript.1 : javascript : iobroker - disabled system.adapter.luftdaten.0 : luftdaten : iobroker - disabled system.adapter.megaesp.0 : megaesp : iobroker - disabled, port: 80 system.adapter.mihome-vacuum.0 : mihome-vacuum : iobroker - disabled, port: 54321 system.adapter.mobile.0 : mobile : iobroker - disabled + system.adapter.modbus.0 : modbus : iobroker - enabled + system.adapter.modbus.1 : modbus : iobroker - enabled system.adapter.modbus.2 : modbus : iobroker - disabled + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0 system.adapter.net-tools.0 : net-tools : iobroker - disabled system.adapter.netatmo-crawler.0 : netatmo-crawler : iobroker - disabled + system.adapter.node-red.0 : node-red : iobroker - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.notification-manager.0 : notification-manager : iobroker - enabled system.adapter.ping.0 : ping : iobroker - disabled + system.adapter.pollenflug.0 : pollenflug : iobroker - enabled system.adapter.proxmox.0 : proxmox : iobroker - disabled, port: 8006 + system.adapter.pushover.0 : pushover : iobroker - enabled + system.adapter.pvforecast.0 : pvforecast : iobroker - enabled system.adapter.radar2.0 : radar2 : iobroker - disabled system.adapter.reolink.0 : reolink : iobroker - disabled system.adapter.samsung.0 : samsung : iobroker - disabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1881, bind: 0.0.0.0 + system.adapter.signal-cmb.0 : signal-cmb : iobroker - enabled system.adapter.smartmeter.0 : smartmeter : iobroker - disabled system.adapter.solarwetter.0 : solarwetter : iobroker - enabled + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.sonoff.1 : sonoff : iobroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - enabled system.adapter.sprinklecontrol.0 : sprinklecontrol : iobroker - disabled system.adapter.synology.0 : synology : iobroker - disabled, port: 5000 + system.adapter.telegram-menu.0 : telegram-menu : iobroker - enabled + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.1 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 system.adapter.terminal.0 : terminal : iobroker - disabled, port: 8088, bind: 0.0.0.0, run as: admin + system.adapter.text2command.0 : text2command : iobroker - enabled system.adapter.time-switch.0 : time-switch : iobroker - disabled + system.adapter.trashschedule.0 : trashschedule : iobroker - enabled system.adapter.tuya.0 : tuya : iobroker - disabled system.adapter.unifi.0 : unifi : iobroker - disabled system.adapter.vis-2-widgets-gauges.0 : vis-2-widgets-gauges : iobroker - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : iobroker - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobroker - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - disabled system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled system.adapter.vis-justgage.0 : vis-justgage : iobroker - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker - disabled system.adapter.vis-rgraph.0 : vis-rgraph : iobroker - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - disabled system.adapter.vis-weather.0 : vis-weather : iobroker - disabled system.adapter.vis.0 : vis : iobroker - enabled + system.adapter.vw-connect.0 : vw-connect : iobroker - enabled system.adapter.web-speedy.0 : web-speedy : iobroker - disabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.web.1 : web : iobroker - disabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker - enabled + system.adapter.ws.0 : ws : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin system.adapter.yeelight-2.0 : yeelight-2 : iobroker - disabled + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyACM0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hue.1 : hue : iobroker - enabled, port: 80 + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.node-red.0 : node-red : iobroker - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1881, bind: 0.0.0.0 + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.sonoff.1 : sonoff : iobroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.1 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyACM0 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.13.16 , installed 6.13.16 Adapter "alexa2" : 3.26.4 , installed 3.26.4 Adapter "backitup" : 2.10.11 , installed 2.10.11 Adapter "bluelink" : 2.3.6 , installed 2.3.6 Adapter "broadlink2" : 2.1.5 , installed 2.1.5 Adapter "bshb" : 0.2.7 , installed 0.2.7 Adapter "chromecast" : 3.2.0 , installed 3.2.0 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "daswetter" : 3.1.13 , installed 3.1.13 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "echarts" : 1.7.2 , installed 1.7.2 Adapter "energiefluss" : 3.6.0 , installed 3.6.0 Adapter "evcc" : 0.1.1 , installed 0.1.1 Adapter "firetv" : 2.0.2 , installed 2.0.2 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "followthesun" : 0.5.0 , installed 0.5.0 Adapter "fullybrowser" : 3.0.11 , installed 3.0.11 Adapter "go-e" : 1.0.29 , installed 1.0.29 Adapter "heatingcontrol": 2.12.3 , installed 2.12.3 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "homeconnect" : 1.3.0 , installed 1.3.0 Adapter "hue" : 3.10.2 , installed 3.10.2 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "influxdb" : 4.0.2 , installed 3.2.0 [Updatable] Adapter "iot" : 2.0.11 , installed 2.0.11 Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 7.8.0 , installed 7.8.0 Controller "js-controller": 5.0.19 , installed 5.0.17 [Updatable] Adapter "luftdaten" : 3.1.0 , installed 3.1.0 Adapter "megaesp" : 0.1.0 , installed 0.1.0 Adapter "mihome-vacuum": 4.1.1 , installed 4.1.1 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "modbus" : 6.1.0 , installed 6.1.0 Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1 Adapter "node-red" : 5.1.0 , installed 5.1.0 Adapter "notification-manager": 1.0.0, installed 1.0.0 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "proxmox" : 2.2.3 , installed 2.2.3 Adapter "pushover" : 3.0.6 , installed 3.0.6 Adapter "pvforecast" : 2.9.1 , installed 2.9.1 Adapter "radar2" : 2.1.0 , installed 2.1.0 Adapter "reolink" : 1.0.3 , installed 1.0.3 Adapter "samsung" : 0.5.11 , installed 0.5.11 Adapter "shelly" : 6.6.1 , installed 6.6.1 Adapter "signal-cmb" : 0.3.0 , installed 0.3.0 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartmeter" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "solarwetter" : 1.1.5 , installed 1.1.5 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "sprinklecontrol": 0.2.13 , installed 0.2.13 Adapter "synology" : 3.0.1 , installed 3.0.1 Adapter "telegram" : 3.1.0 , installed 3.1.0 Adapter "telegram-menu": 1.5.1 , installed 1.5.1 Adapter "terminal" : 1.0.0 , installed 1.0.0 Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "trashschedule": 3.2.0 , installed 3.2.0 Adapter "tuya" : 3.15.0 , installed 3.15.0 Adapter "unifi" : 0.6.7 , installed 0.6.7 Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "vis-2-widgets-gauges": 1.0.2, installed 1.0.2 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 1.3.0 , installed 1.3.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-justgage" : 2.1.0 , installed 2.1.0 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.9 , installed 2.5.9 Adapter "web" : 6.2.3 , installed 6.2.3 Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3 Adapter "ws" : 2.5.10 , installed 2.5.10 Adapter "yeelight-2" : 1.3.1 , installed 1.3.1 Adapter "zigbee" : 1.10.1 , installed 1.10.1 Objects and States Please stand by - This may take a while Objects: 120296 States: 93115 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security bookworm-security InRelease Hit:2 http://deb.debian.org/debian bookworm InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 30 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 17813483 4166491/node-red tcp 0 0 0.0.0.0:1881 0.0.0.0:* LISTEN 1001 17814072 4166094/io.shelly.0 tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 17813696 4166120/io.sonoff.1 tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 17814533 4166055/io.mqtt.0 tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 17813328 4166095/io.sonoff.0 tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 13290 1/init tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 15279 452/sshd: /usr/sbin tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 17811245 4165726/iobroker.js tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 17811571 4165726/iobroker.js tcp6 0 0 :::111 :::* LISTEN 0 13293 1/init tcp6 0 0 :::22 :::* LISTEN 0 15290 452/sshd: /usr/sbin tcp6 0 0 :::8081 :::* LISTEN 1001 17812502 4165751/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 17813993 4166381/io.web.0 tcp6 0 0 :::8084 :::* LISTEN 1001 17813974 4166382/io.ws.0 udp 0 0 0.0.0.0:111 0.0.0.0:* 0 13412 1/init udp6 0 0 :::111 :::* 0 13415 1/init *** Log File - Last 25 Lines *** 2024-03-05 12:07:15.931 - info: javascript.0 (4165800) script.js.common.Gaszähler: + 0.005 2024-03-05 12:07:15.931 - info: javascript.0 (4165800) script.js.common.Gaszähler: 7020.875 2024-03-05 12:07:16.690 - info: javascript.0 (4165800) script.js.common.Gaszähler: in Brennwert 2024-03-05 12:07:16.691 - info: javascript.0 (4165800) script.js.common.Gaszähler: 76391.547 2024-03-05 12:07:16.691 - info: javascript.0 (4165800) script.js.common.Gaszähler: 7020.875 2024-03-05 12:07:16.692 - info: javascript.0 (4165800) script.js.common.Gaszähler: 76391.6014245125 2024-03-05 12:07:16.692 - info: javascript.0 (4165800) script.js.common.Gaszähler: 76391.601 2024-03-05 12:07:16.692 - info: javascript.0 (4165800) script.js.common.Gaszähler: Brennwert kWh in DP geschieben 2024-03-05 12:07:21.867 - debug: shelly.0 (4166094) [createObjects] Finished object creation of (undefined / undefined / undefined) 2024-03-05 12:07:21.868 - debug: shelly.0 (4166094) [MQTT] Last will for client id "shellyplus2pm-d48afc7cfa64" saved: {"retain":true,"qos":0,"topic":"shellyplus2pm-d48afc7cfa64/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}} 2024-03-05 12:07:21.868 - debug: shelly.0 (4166094) [setIP] New IP for device undefined: 192.168.0.5 (source: MQTT connect) 2024-03-05 12:07:21.885 - error: shelly.0 (4166094) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-d48afc7cfa64" 2024-03-05 12:07:26.494 - debug: shelly.0 (4166094) [MQTT Server] New connection from 192.168.0.5 2024-03-05 12:07:26.496 - debug: shelly.0 (4166094) [MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":94,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellyplus2pm-d48afc7cfa64/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus2pm-d48afc7cfa64","username":"admin","password":{"type":"Buffer","data":[97,100,109,105,110]}} 2024-03-05 12:07:26.496 - debug: shelly.0 (4166094) [BaseClient] Destroying 192.168.0.5 (undefined / undefined / undefined) 2024-03-05 12:07:26.497 - debug: shelly.0 (4166094) [MQTT] Destroying 2024-03-05 12:07:26.497 - info: shelly.0 (4166094) [MQTT] Device with client id "shellyplus2pm-d48afc7cfa64" connected! 2024-03-05 12:07:26.644 - debug: shelly.0 (4166094) Configured device mode of (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1) by state "shellyplus2pm#d48afc7cfa64#1.Sys.deviceMode" (fallback): cover 2024-03-05 12:07:29.985 - debug: shelly.0 (4166094) [createObjects] Starting object creation of (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1) for mode: cover 2024-03-05 12:07:31.497 - info: javascript.0 (4165800) Stop script script.js.common.Beleuchtung_HUE 2024-03-05 12:07:31.641 - info: javascript.0 (4165800) script.js.common.Gaszähler: + 0.005 2024-03-05 12:07:31.641 - info: javascript.0 (4165800) script.js.common.Gaszähler: 7020.88 2024-03-05 12:07:31.665 - debug: shelly.0 (4166094) [onlineCheck] Checking shellyplus2pm#d48afc7cfa64#1 on 192.168.0.5:80 2024-03-05 12:07:31.681 - debug: shelly.0 (4166094) [deviceStatusUpdate] shellyplus2pm#d48afc7cfa64#1: true 2024-03-05 12:07:31.835 - debug: shelly.0 (4166094) [onlineCheck] Checking shellyplus1pm#d48afc597dfc#1 on 192.168.0.53:80
Pending Updates: 30
Patches einspielen, gilt auch fĂĽr den ioBroker-Bereich.
Bei Zigbee nicht /dev/ttyACM0 sondern den richtigen Link von hier verwenden:
@thomas-braun Ja mache ich gleich - ich war auf dem Weg dahin - habe iob gestopt, iob fix und dann starten wollen bevor ich die Updates ĂĽber
sudo apt update sudo apt dist-upgrade sudo reboot
machen wollte - siehst du die Ursache des Multihosts?
@thomas-braun said in Mulitihost:
Pending Updates: 30
In den zigbee Instanz das einstellen?
Ja, eines der beiden Interfaces. Vermutlich if00.
nein!
aber hast du 2 zigbee-sticks am Rechner? -
@homoran Nein ich habe nur einen
@thomas-braun Das wird wohl nur verkĂĽrzt angezeigt
Nein. Trag da den vollständigen Pfad ein:
nein, du hast es verkĂĽrzt eingetragen.
nach einem Neustart können sich die Ports ändern, deswegen auf das eindeutige device mappen!
@homoran sagte in Mulitihost:
Nein, aber einen mit zwei Interfaces.
@thomas-braun ich habe mal den USB Port gewechselt - vlt. daher
Und genau solche Aktionen laufen glatter, wenn man by-id nimmt. Die Geräte Datei kann sich nämlich dann ändern, die ID nicht.
Kiste durchgepatcht?
iob diag
Schau nun wie aus?
@thomas-braun Ja sieht nun besser aus.
Anderes Thema das ich eigentlich dachte das sich nach einem Reboot löst. Ich bekomme ein neues hue0 Objekt unter Objecte angezeigt. Wenn ich einen Datenpunkt des Objektes in Blockly einbinden will erscheint er aber nicht im Objektauswahl Dialog. Wie kann man das aktualisieren?
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: iobroker Icon name: computer-vm Chassis: vm 🖴 Virtualization: kvm Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-18-amd64 Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Firmware Version: rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org model name : Common KVM processor Docker : false Virtualization : kvm Kernel : x86_64 Userland : amd64 Systemuptime and Load: 15:20:27 up 37 min, 2 users, load average: 2.62, 2.10, 2.03 CPU threads: 4 *** Time and Time Zones *** Local time: Tue 2024-03-05 15:20:27 CET Universal time: Tue 2024-03-05 14:20:27 UTC RTC time: Tue 2024-03-05 14:20:27 Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** toki /home/toki toki cdrom floppy sudo audio dip video plugdev users netdev iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 6.3G 4.5G 1.5G 585K 677M 1.9G Swap: 1.0G 0B 1.0G Total: 7.4G 4.5G 2.5G 6051 M total memory 4244 M used memory 339 M active memory 4035 M inactive memory 1393 M free memory 53 M buffer memory 591 M swap cache 974 M total swap 0 M used swap 974 M free swap *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.0G 0 3.0G 0% /dev tmpfs tmpfs 606M 572K 605M 1% /run /dev/sda1 ext4 31G 7.3G 22G 26% / tmpfs tmpfs 3.0G 0 3.0G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 606M 0 606M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Tue Mar 5 14:43:21 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none. [Tue Mar 5 14:43:24 2024] EXT4-fs (sda1): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 604M /var/ 246M /var/cache 239M /var/cache/apt 185M /var/log 172M /var/lib Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 28.4M in the file system. /opt/iobroker/backups: 52M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 952M /opt/iobroker/iobroker-data/ 594M /opt/iobroker/iobroker-data/files 168M /opt/iobroker/iobroker-data/backup-objects 93M /opt/iobroker/iobroker-data/files/vis.0 57M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 107M /opt/iobroker/iobroker-data/states.jsonl 83M /opt/iobroker/iobroker-data/objects.jsonl 36M /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if00 /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if03 *** NodeJS-Installation *** /usr/bin/nodejs v18.19.1 /usr/bin/node v18.19.1 /usr/bin/npm 10.2.4 /usr/bin/npx 10.2.4 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.1-1nodesource1 Candidate: 18.19.1-1nodesource1 Version table: *** 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.19.0+dfsg-6~deb12u1 500 500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0+dfsg1-1 500 500 http://deb.debian.org/debian bookworm/main amd64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.17 admin: 6.13.16 javascript: 7.8.0 Adapters from github: 2 Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : iobroker - enabled + system.adapter.backitup.0 : backitup : iobroker - enabled system.adapter.ble.0 : ble : iobroker - disabled + system.adapter.bluelink.0 : bluelink : iobroker - enabled system.adapter.broadlink2.0 : broadlink2 : iobroker - disabled system.adapter.bshb.0 : bshb : iobroker - disabled system.adapter.chromecast.0 : chromecast : iobroker - disabled system.adapter.cloud.0 : cloud : iobroker - disabled system.adapter.daswetter.0 : daswetter : iobroker - enabled system.adapter.device-reminder.0 : device-reminder : iobroker - disabled system.adapter.devices.0 : devices : iobroker - disabled system.adapter.discovery.0 : discovery : iobroker - disabled system.adapter.echarts.0 : echarts : iobroker - disabled + system.adapter.energiefluss.0 : energiefluss : iobroker - enabled system.adapter.evcc.0 : evcc : iobroker - disabled, port: 7070 system.adapter.firetv.0 : firetv : iobroker - disabled system.adapter.flot.0 : flot : iobroker - disabled + system.adapter.followthesun.0 : followthesun : iobroker - enabled system.adapter.fullybrowser.0 : fullybrowser : iobroker - disabled + system.adapter.go-e.0 : go-e : iobroker - enabled system.adapter.heatingcontrol.0 : heatingcontrol : iobroker - disabled system.adapter.history.0 : history : iobroker - disabled system.adapter.homeconnect.0 : homeconnect : iobroker - disabled system.adapter.hue-extended.0 : hue-extended : iobroker - disabled + system.adapter.hue-extended.1 : hue-extended : iobroker - enabled + system.adapter.hue.1 : hue : iobroker - enabled, port: 80 system.adapter.ical.0 : ical : iobroker - enabled system.adapter.ical.1 : ical : iobroker - enabled system.adapter.icons-icons8.0 : icons-icons8 : iobroker - enabled system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker - enabled + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.info.0 : info : iobroker - enabled + system.adapter.iot.0 : iot : iobroker - enabled system.adapter.jarvis.0 : jarvis : iobroker - disabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.javascript.0 : javascript : iobroker - enabled system.adapter.javascript.1 : javascript : iobroker - disabled system.adapter.luftdaten.0 : luftdaten : iobroker - disabled system.adapter.megaesp.0 : megaesp : iobroker - disabled, port: 80 system.adapter.mihome-vacuum.0 : mihome-vacuum : iobroker - disabled, port: 54321 system.adapter.mobile.0 : mobile : iobroker - disabled + system.adapter.modbus.0 : modbus : iobroker - enabled + system.adapter.modbus.1 : modbus : iobroker - enabled system.adapter.modbus.2 : modbus : iobroker - disabled + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0 system.adapter.net-tools.0 : net-tools : iobroker - disabled system.adapter.netatmo-crawler.0 : netatmo-crawler : iobroker - disabled + system.adapter.node-red.0 : node-red : iobroker - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.notification-manager.0 : notification-manager : iobroker - enabled system.adapter.ping.0 : ping : iobroker - disabled + system.adapter.pollenflug.0 : pollenflug : iobroker - enabled system.adapter.proxmox.0 : proxmox : iobroker - disabled, port: 8006 + system.adapter.pushover.0 : pushover : iobroker - enabled + system.adapter.pvforecast.0 : pvforecast : iobroker - enabled system.adapter.radar2.0 : radar2 : iobroker - disabled system.adapter.reolink.0 : reolink : iobroker - disabled system.adapter.samsung.0 : samsung : iobroker - disabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1881, bind: 0.0.0.0 + system.adapter.signal-cmb.0 : signal-cmb : iobroker - enabled system.adapter.smartmeter.0 : smartmeter : iobroker - disabled system.adapter.solarwetter.0 : solarwetter : iobroker - enabled + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.sonoff.1 : sonoff : iobroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - enabled system.adapter.sprinklecontrol.0 : sprinklecontrol : iobroker - disabled system.adapter.synology.0 : synology : iobroker - disabled, port: 5000 + system.adapter.telegram-menu.0 : telegram-menu : iobroker - enabled + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.1 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 system.adapter.terminal.0 : terminal : iobroker - disabled, port: 8088, bind: 0.0.0.0, run as: admin + system.adapter.text2command.0 : text2command : iobroker - enabled system.adapter.time-switch.0 : time-switch : iobroker - disabled + system.adapter.trashschedule.0 : trashschedule : iobroker - enabled system.adapter.tuya.0 : tuya : iobroker - disabled system.adapter.unifi.0 : unifi : iobroker - disabled system.adapter.vis-2-widgets-gauges.0 : vis-2-widgets-gauges : iobroker - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : iobroker - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobroker - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - disabled system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled system.adapter.vis-justgage.0 : vis-justgage : iobroker - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker - disabled system.adapter.vis-rgraph.0 : vis-rgraph : iobroker - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - disabled system.adapter.vis-weather.0 : vis-weather : iobroker - disabled system.adapter.vis.0 : vis : iobroker - enabled + system.adapter.vw-connect.0 : vw-connect : iobroker - enabled system.adapter.web-speedy.0 : web-speedy : iobroker - disabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.web.1 : web : iobroker - disabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker - enabled + system.adapter.ws.0 : ws : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin system.adapter.yeelight-2.0 : yeelight-2 : iobroker - disabled + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if00 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hue.1 : hue : iobroker - enabled, port: 80 + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.node-red.0 : node-red : iobroker - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1881, bind: 0.0.0.0 + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.sonoff.1 : sonoff : iobroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.1 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if00 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.13.16 , installed 6.13.16 Adapter "alexa2" : 3.26.4 , installed 3.26.4 Adapter "backitup" : 2.10.11 , installed 2.10.11 Adapter "bluelink" : 2.3.6 , installed 2.3.6 Adapter "broadlink2" : 2.1.5 , installed 2.1.5 Adapter "bshb" : 0.2.7 , installed 0.2.7 Adapter "chromecast" : 3.2.0 , installed 3.2.0 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "daswetter" : 3.1.13 , installed 3.1.13 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "echarts" : 1.7.2 , installed 1.7.2 Adapter "energiefluss" : 3.6.0 , installed 3.6.0 Adapter "evcc" : 0.1.1 , installed 0.1.1 Adapter "firetv" : 2.0.2 , installed 2.0.2 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "followthesun" : 0.5.0 , installed 0.5.0 Adapter "fullybrowser" : 3.0.11 , installed 3.0.11 Adapter "go-e" : 1.0.29 , installed 1.0.29 Adapter "heatingcontrol": 2.12.3 , installed 2.12.3 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "homeconnect" : 1.3.0 , installed 1.3.0 Adapter "hue" : 3.10.2 , installed 3.10.2 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "influxdb" : 4.0.2 , installed 3.2.0 [Updatable] Adapter "iot" : 2.0.11 , installed 2.0.11 Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 7.8.0 , installed 7.8.0 Controller "js-controller": 5.0.19 , installed 5.0.17 [Updatable] Adapter "luftdaten" : 3.1.0 , installed 3.1.0 Adapter "megaesp" : 0.1.0 , installed 0.1.0 Adapter "mihome-vacuum": 4.1.1 , installed 4.1.1 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "modbus" : 6.1.0 , installed 6.1.0 Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1 Adapter "node-red" : 5.1.0 , installed 5.1.0 Adapter "notification-manager": 1.0.0, installed 1.0.0 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "proxmox" : 2.2.3 , installed 2.2.3 Adapter "pushover" : 3.0.6 , installed 3.0.6 Adapter "pvforecast" : 2.9.1 , installed 2.9.1 Adapter "radar2" : 2.1.0 , installed 2.1.0 Adapter "reolink" : 1.0.3 , installed 1.0.3 Adapter "samsung" : 0.5.11 , installed 0.5.11 Adapter "shelly" : 6.6.1 , installed 6.6.1 Adapter "signal-cmb" : 0.3.0 , installed 0.3.0 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartmeter" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "solarwetter" : 1.1.5 , installed 1.1.5 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "sprinklecontrol": 0.2.13 , installed 0.2.13 Adapter "synology" : 3.0.1 , installed 3.0.1 Adapter "telegram" : 3.1.0 , installed 3.1.0 Adapter "telegram-menu": 1.5.1 , installed 1.5.1 Adapter "terminal" : 1.0.0 , installed 1.0.0 Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "trashschedule": 3.2.0 , installed 3.2.0 Adapter "tuya" : 3.15.0 , installed 3.15.0 Adapter "unifi" : 0.6.7 , installed 0.6.7 Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "vis-2-widgets-gauges": 1.0.2, installed 1.0.2 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 1.3.0 , installed 1.3.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-justgage" : 2.1.0 , installed 2.1.0 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.9 , installed 2.5.9 Adapter "web" : 6.2.3 , installed 6.2.3 Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3 Adapter "ws" : 2.5.10 , installed 2.5.10 Adapter "yeelight-2" : 1.3.1 , installed 1.3.1 Adapter "zigbee" : 1.10.1 , installed 1.10.1 Objects and States Please stand by - This may take a while Objects: 120048 States: 92869 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security bookworm-security InRelease Hit:2 http://deb.debian.org/debian bookworm InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 18505 1111/node-red tcp 0 0 0.0.0.0:1881 0.0.0.0:* LISTEN 1001 19542 723/io.shelly.0 tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 17118 755/io.sonoff.1 tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 18514 718/io.mqtt.0 tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 17099 744/io.sonoff.0 tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 16180 431/iobroker.js-con tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 16187 431/iobroker.js-con tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 13366 1/init tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14070 451/sshd: /usr/sbin tcp6 0 0 :::8081 :::* LISTEN 1001 17339 484/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 18735 1009/io.web.0 tcp6 0 0 :::8084 :::* LISTEN 1001 18717 1020/io.ws.0 tcp6 0 0 :::111 :::* LISTEN 0 13369 1/init tcp6 0 0 :::22 :::* LISTEN 0 14072 451/sshd: /usr/sbin udp 0 0 0.0.0.0:111 0.0.0.0:* 0 14348 1/init udp6 0 0 :::111 :::* 0 14351 1/init *** Log File - Last 25 Lines *** 2024-03-05 15:23:05.050 - debug: shelly.0 (723) [MQTT] State change 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): shellyplus2pm-d48afc7cfa64/status/cover:0 -> state: shellyplus2pm#d48afc7cfa64#1.Cover0.temperatureC, value: 46.6 2024-03-05 15:23:09.557 - info: javascript.0 (564) script.js.common.Gaszähler: + 0.005 2024-03-05 15:23:09.573 - info: javascript.0 (564) script.js.common.Gaszähler: 7026.32 2024-03-05 15:23:09.615 - debug: shelly.0 (723) [httpIoBrokerState] State change 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): state: shellyplus2pm#d48afc7cfa64#1.uptime, value: 338374 2024-03-05 15:23:09.616 - debug: shelly.0 (723) [httpIoBrokerState] State change 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): state: shellyplus2pm#d48afc7cfa64#1.rssi, value: -75 2024-03-05 15:23:09.684 - warn: shelly.0 (723) [authEnabled] 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): This device is not protected via restricted login (see adapter documentation for details) 2024-03-05 15:23:10.259 - info: javascript.0 (564) script.js.common.Gaszähler: in Brennwert 2024-03-05 15:23:10.259 - info: javascript.0 (564) script.js.common.Gaszähler: 76450.792 2024-03-05 15:23:10.259 - info: javascript.0 (564) script.js.common.Gaszähler: 7026.32 2024-03-05 15:23:10.260 - info: javascript.0 (564) script.js.common.Gaszähler: 76450.846500056 2024-03-05 15:23:10.260 - info: javascript.0 (564) script.js.common.Gaszähler: 76450.847 2024-03-05 15:23:10.260 - info: javascript.0 (564) script.js.common.Gaszähler: Brennwert kWh in DP geschieben 2024-03-05 15:23:11.839 - info: sonoff.1 (755) State value to set for "sonoff.1.SugerValley.NeoPool_pH_Data" has to be type "string" but received type "number" 2024-03-05 15:23:12.126 - info: sonoff.1 (755) State value to set for "sonoff.1.SugerValley.NeoPool_Redox_Data" has to be type "string" but received type "number" 2024-03-05 15:23:12.183 - info: sonoff.1 (755) State value to set for "sonoff.1.SugerValley.NeoPool_Hydrolysis_Data" has to be type "string" but received type "number" 2024-03-05 15:23:13.772 - info: sonoff.0 (744) Client [GosBlitzw_EP2] reconnected. Old secret 1709648189940_2039. New secret 1709648593772_7398 2024-03-05 15:23:13.854 - info: admin.0 (484) ==> Connected system.user.admin from ::ffff:192.168.0.148 2024-03-05 15:23:14.084 - info: javascript.0 (564) script.js.common.Gaszähler: + 0.005 2024-03-05 15:23:14.085 - info: javascript.0 (564) script.js.common.Gaszähler: 7026.325 2024-03-05 15:23:14.480 - info: javascript.0 (564) script.js.common.Gaszähler: in Brennwert 2024-03-05 15:23:14.480 - info: javascript.0 (564) script.js.common.Gaszähler: 76450.847 2024-03-05 15:23:14.481 - info: javascript.0 (564) script.js.common.Gaszähler: 7026.325 2024-03-05 15:23:14.484 - info: javascript.0 (564) script.js.common.Gaszähler: 76450.90090324749 2024-03-05 15:23:14.485 - info: javascript.0 (564) script.js.common.Gaszähler: 76450.901 2024-03-05 15:23:14.485 - info: javascript.0 (564) script.js.common.Gaszähler: Brennwert kWh in DP geschieben
sudo usermod -a -G adm toki sudo systemctl set-default multi-user.target
Und bring den js-controller und den influxdb-Adapter auf Stand.
@thomas-braun Vielen Dank!
