    4. Mulitihost
    Mulitihost
      toki1973 @Homoran last edited by
      Nein habe ich nicht konfiguriert
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-17-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       12:04:58 up 5 days, 22:39,  4 users,  load average: 2.88, 3.69, 2.82
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Tue 2024-03-05 12:04:58 CET
                 Universal time: Tue 2024-03-05 11:04:58 UTC
                       RTC time: Tue 2024-03-05 11:04:58
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      toki
      /home/toki
      toki cdrom floppy sudo audio dip video plugdev users netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            6.3G        4.0G        1.4G        524K        1.2G        2.3G
      Swap:           1.0G        4.1M        1.0G
      Total:          7.4G        4.0G        2.4G
               6051 M total memory
               3841 M used memory
                527 M active memory
               3690 M inactive memory
               1317 M free memory
                240 M buffer memory
                943 M swap cache
                974 M total swap
                  3 M used swap
                971 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.0G     0  3.0G   0% /dev
      tmpfs          tmpfs     606M  572K  605M   1% /run
      /dev/sda1      ext4       31G  7.2G   22G  25% /
      tmpfs          tmpfs     3.0G     0  3.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     606M     0  606M   0% /run/user/1000
      [Wed Feb 28 13:25:12 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Feb 28 13:25:15 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
      [Fri Mar  1 02:16:56 2024] Modules linked in: sha512_generic cmac nls_utf8 cifs cifs_arc4 cifs_md4 dns_resolver fscache netfs sunrpc cdc_acm virtio_console virtio_balloon joydev evdev sg button serio_raw pcspkr binfmt_misc dm_mod fuse loop configfs efi_pstore qemu_fw_cfg ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic hid_generic usbhid hid sd_mod t10_pi crc64_rocksoft crc64 crc_t10dif crct10dif_generic crct10dif_common sr_mod bochs drm_vram_helper cdrom drm_kms_helper virtio_net drm_ttm_helper ttm net_failover failover virtio_scsi ata_generic xhci_pci xhci_hcd ata_piix uhci_hcd ehci_hcd drm libata usbcore psmouse virtio_pci virtio_pci_legacy_dev virtio_pci_modern_dev virtio virtio_ring scsi_mod i2c_piix4 usb_common scsi_common floppy
      [Fri Mar  1 02:18:22 2024] Modules linked in: sha512_generic cmac nls_utf8 cifs cifs_arc4 cifs_md4 dns_resolver fscache netfs sunrpc cdc_acm virtio_console virtio_balloon joydev evdev sg button serio_raw pcspkr binfmt_misc dm_mod fuse loop configfs efi_pstore qemu_fw_cfg ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic hid_generic usbhid hid sd_mod t10_pi crc64_rocksoft crc64 crc_t10dif crct10dif_generic crct10dif_common sr_mod bochs drm_vram_helper cdrom drm_kms_helper virtio_net drm_ttm_helper ttm net_failover failover virtio_scsi ata_generic xhci_pci xhci_hcd ata_piix uhci_hcd ehci_hcd drm libata usbcore psmouse virtio_pci virtio_pci_legacy_dev virtio_pci_modern_dev virtio virtio_ring scsi_mod i2c_piix4 usb_common scsi_common floppy
      [Tue Mar  5 12:00:42 2024] Modules linked in: sha512_generic cmac nls_utf8 cifs cifs_arc4 cifs_md4 dns_resolver fscache netfs sunrpc cdc_acm virtio_console virtio_balloon joydev evdev sg button serio_raw pcspkr binfmt_misc dm_mod fuse loop configfs efi_pstore qemu_fw_cfg ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic hid_generic usbhid hid sd_mod t10_pi crc64_rocksoft crc64 crc_t10dif crct10dif_generic crct10dif_common sr_mod bochs drm_vram_helper cdrom drm_kms_helper virtio_net drm_ttm_helper ttm net_failover failover virtio_scsi ata_generic xhci_pci xhci_hcd ata_piix uhci_hcd ehci_hcd drm libata usbcore psmouse virtio_pci virtio_pci_legacy_dev virtio_pci_modern_dev virtio virtio_ring scsi_mod i2c_piix4 usb_common scsi_common floppy
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      589M    /var/
      246M    /var/cache
      239M    /var/cache/apt
      172M    /var/lib
      171M    /var/log
      Archived and active journals take up 24.4M in the file system.
      /opt/iobroker/backups:
      52M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      855M    /opt/iobroker/iobroker-data/
      594M    /opt/iobroker/iobroker-data/files
      168M    /opt/iobroker/iobroker-data/backup-objects
      93M     /opt/iobroker/iobroker-data/files/vis.0
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      70M     /opt/iobroker/iobroker-data/objects.jsonl
      36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if03
      /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.1-1nodesource1
        Version table:
           18.19.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
       *** 18.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   2
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.ble.0                    : ble                   : iobroker                                 - disabled
      + system.adapter.bluelink.0               : bluelink              : iobroker                                 -  enabled
        system.adapter.broadlink2.0             : broadlink2            : iobroker                                 - disabled
        system.adapter.bshb.0                   : bshb                  : iobroker                                 - disabled
        system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
        system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
        system.adapter.devices.0                : devices               : iobroker                                 - disabled
        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
        system.adapter.echarts.0                : echarts               : iobroker                                 - disabled
      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        system.adapter.evcc.0                   : evcc                  : iobroker                                 - disabled, port: 7070
        system.adapter.firetv.0                 : firetv                : iobroker                                 - disabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
      + system.adapter.go-e.0                   : go-e                  : iobroker                                 -  enabled
        system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 - disabled
        system.adapter.history.0                : history               : iobroker                                 - disabled
        system.adapter.homeconnect.0            : homeconnect           : iobroker                                 - disabled
        system.adapter.hue-extended.0           : hue-extended          : iobroker                                 - disabled
      + system.adapter.hue-extended.1           : hue-extended          : iobroker                                 -  enabled
      + system.adapter.hue.1                    : hue                   : iobroker                                 -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.javascript.1             : javascript            : iobroker                                 - disabled
        system.adapter.luftdaten.0              : luftdaten             : iobroker                                 - disabled
        system.adapter.megaesp.0                : megaesp               : iobroker                                 - disabled, port: 80
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
        system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
        system.adapter.modbus.2                 : modbus                : iobroker                                 - disabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
        system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
        system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
        system.adapter.radar2.0                 : radar2                : iobroker                                 - disabled
        system.adapter.reolink.0                : reolink               : iobroker                                 - disabled
        system.adapter.samsung.0                : samsung               : iobroker                                 - disabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
      + system.adapter.signal-cmb.0             : signal-cmb            : iobroker                                 -  enabled
        system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
        system.adapter.solarwetter.0            : solarwetter           : iobroker                                 -  enabled
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sonoff.1                 : sonoff                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 - disabled
        system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
      + system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8088, bind: 0.0.0.0, run as: admin
      + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
        system.adapter.time-switch.0            : time-switch           : iobroker                                 - disabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
        system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
        system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.web.1                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
      + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 - disabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "bshb"         : 0.2.7    , installed 0.2.7
      Adapter    "chromecast"   : 3.2.0    , installed 3.2.0
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
      Adapter    "evcc"         : 0.1.1    , installed 0.1.1
      Adapter    "firetv"       : 2.0.2    , installed 2.0.2
      Adapter    "followthesun" : 0.5.0    , installed 0.5.0
      Adapter    "fullybrowser" : 3.0.11   , installed 3.0.11
      Adapter    "go-e"         : 1.0.29   , installed 1.0.29
      Adapter    "heatingcontrol": 2.12.3  , installed 2.12.3
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Adapter    "hue"          : 3.10.2   , installed 3.10.2
      Adapter    "influxdb"     : 4.0.2    , installed 3.2.0  [Updatable]
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.19   , installed 5.0.17 [Updatable]
      Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
      Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
      Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "node-red"     : 5.1.0    , installed 5.1.0
      Adapter    "notification-manager": 1.0.0, installed 1.0.0
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
      Adapter    "radar2"       : 2.1.0    , installed 2.1.0
      Adapter    "reolink"      : 1.0.3    , installed 1.0.3
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "solarwetter"  : 1.1.5    , installed 1.1.5
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 3.1.0    , installed 3.1.0
      Adapter    "telegram-menu": 1.5.1    , installed 1.5.1
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "trashschedule": 3.2.0    , installed 3.2.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "unifi"        : 0.6.7    , installed 0.6.7
      Adapter    "vis-2-widgets-gauges": 1.0.2, installed 1.0.2
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Adapter    "yeelight-2"   : 1.3.1    , installed 1.3.1
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Objects and States
      Objects:        120296
      States:         93115
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 30
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17813483   4166491/node-red
      tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       17814072   4166094/io.shelly.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17813696   4166120/io.sonoff.1
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17814533   4166055/io.mqtt.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       17813328   4166095/io.sonoff.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13290      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15279      452/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17811245   4165726/iobroker.js
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17811571   4165726/iobroker.js
      tcp6       0      0 :::111                  :::*                    LISTEN      0          13293      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15290      452/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17812502   4165751/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17813993   4166381/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       17813974   4166382/io.ws.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13412      1/init
      udp6       0      0 :::111                  :::*                                0          13415      1/init
      2024-03-05 12:07:15.931  - info: javascript.0 (4165800) script.js.common.Gaszähler: + 0.005
      2024-03-05 12:07:15.931  - info: javascript.0 (4165800) script.js.common.Gaszähler: 7020.875
      2024-03-05 12:07:16.690  - info: javascript.0 (4165800) script.js.common.Gaszähler:  in Brennwert
      2024-03-05 12:07:16.691  - info: javascript.0 (4165800) script.js.common.Gaszähler: 76391.547
      2024-03-05 12:07:16.691  - info: javascript.0 (4165800) script.js.common.Gaszähler: 7020.875
      2024-03-05 12:07:16.692  - info: javascript.0 (4165800) script.js.common.Gaszähler: 76391.6014245125
      2024-03-05 12:07:16.692  - info: javascript.0 (4165800) script.js.common.Gaszähler: Brennwert kWh in DP geschieben
      2024-03-05 12:07:21.867  - debug: shelly.0 (4166094) [createObjects] Finished object creation of  (undefined / undefined / undefined)
      2024-03-05 12:07:21.868  - debug: shelly.0 (4166094) [MQTT] Last will for client id "shellyplus2pm-d48afc7cfa64" saved: {"retain":true,"qos":0,"topic":"shellyplus2pm-d48afc7cfa64/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}}
      2024-03-05 12:07:21.868  - debug: shelly.0 (4166094) [setIP] New IP for device undefined: 192.168.0.5 (source: MQTT connect)
      2024-03-05 12:07:21.885  - error: shelly.0 (4166094) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-d48afc7cfa64"
      2024-03-05 12:07:26.494  - debug: shelly.0 (4166094) [MQTT Server] New connection from 192.168.0.5
      2024-03-05 12:07:26.496  - debug: shelly.0 (4166094) [MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":94,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellyplus2pm-d48afc7cfa64/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus2pm-d48afc7cfa64","username":"admin","password":{"type":"Buffer","data":[97,100,109,105,110]}}
      2024-03-05 12:07:26.496  - debug: shelly.0 (4166094) [BaseClient] Destroying 192.168.0.5 (undefined / undefined / undefined)
      2024-03-05 12:07:26.497  - debug: shelly.0 (4166094) [MQTT] Destroying
      2024-03-05 12:07:26.497  - info: shelly.0 (4166094) [MQTT] Device with client id "shellyplus2pm-d48afc7cfa64" connected!
      2024-03-05 12:07:26.644  - debug: shelly.0 (4166094) Configured device mode of  (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1) by state "shellyplus2pm#d48afc7cfa64#1.Sys.deviceMode" (fallback): cover
      2024-03-05 12:07:29.985  - debug: shelly.0 (4166094) [createObjects] Starting object creation of  (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1) for mode: cover
      2024-03-05 12:07:31.497  - info: javascript.0 (4165800) Stop script script.js.common.Beleuchtung_HUE
      2024-03-05 12:07:31.641  - info: javascript.0 (4165800) script.js.common.Gaszähler: + 0.005
      2024-03-05 12:07:31.641  - info: javascript.0 (4165800) script.js.common.Gaszähler: 7020.88
      2024-03-05 12:07:31.665  - debug: shelly.0 (4166094) [onlineCheck] Checking shellyplus2pm#d48afc7cfa64#1 on 192.168.0.5:80
      2024-03-05 12:07:31.681  - debug: shelly.0 (4166094) [deviceStatusUpdate] shellyplus2pm#d48afc7cfa64#1: true
      2024-03-05 12:07:31.835  - debug: shelly.0 (4166094) [onlineCheck] Checking shellyplus1pm#d48afc597dfc#1 on 192.168.0.53:80
        Thomas Braun Most Active @toki1973 last edited by Thomas Braun
        @toki1973 sagte in Mulitihost:
        Pending Updates: 30
        Patches einspielen, gilt auch für den ioBroker-Bereich.
        Bei Zigbee nicht /dev/ttyACM0 sondern den richtigen Link von hier verwenden:
          toki1973 @Thomas Braun last edited by
          @thomas-braun Ja mache ich gleich - ich war auf dem Weg dahin - habe iob gestopt, iob fix und dann starten wollen bevor ich die Updates über
          sudo apt update
          sudo apt dist-upgrade
          sudo reboot
          machen wollte - siehst du die Ursache des Multihosts?
            @thomas-braun said in Mulitihost:
            Pending Updates: 30
            In den zigbee Instanz das einstellen?
              Ja, eines der beiden Interfaces. Vermutlich if00.
                Homoran Global Moderator Administrators @toki1973 last edited by
                nein!
                aber hast du 2 zigbee-sticks am Rechner?
                T Thomas Braun 2 Replies Last reply Reply Quote 0
                  @homoran Nein ich habe nur einen
                    @thomas-braun Das wird wohl nur verkürzt angezeigt
                      @toki1973
                      Nein. Trag da den vollständigen Pfad ein:
                        nein, du hast es verkürzt eingetragen.
                        nach einem Neustart können sich die Ports ändern, deswegen auf das eindeutige device mappen!
                          @homoran sagte in Mulitihost:
                          Nein, aber einen mit zwei Interfaces.
                            @thomas-braun ich habe mal den USB Port gewechselt - vlt. daher
                              @toki1973
                              Und genau solche Aktionen laufen glatter, wenn man by-id nimmt. Die Geräte Datei kann sich nämlich dann ändern, die ID nicht.
                              Kiste durchgepatcht?
                              iob diag
                              Schau nun wie aus?
                                @thomas-braun Ja sieht nun besser aus.
                                Anderes Thema das ich eigentlich dachte das sich nach einem Reboot löst. Ich bekomme ein neues hue0 Objekt unter Objecte angezeigt. Wenn ich einen Datenpunkt des Objektes in Blockly einbinden will erscheint er aber nicht im Objektauswahl Dialog. Wie kann man das aktualisieren?
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Chassis: vm 🖴
                                  Virtualization: kvm
                                          Kernel: Linux 6.1.0-18-amd64
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : amd64
                                 15:20:27 up 37 min,  2 users,  load average: 2.62, 2.10, 2.03
                                CPU threads: 4
                                               Local time: Tue 2024-03-05 15:20:27 CET
                                           Universal time: Tue 2024-03-05 14:20:27 UTC
                                                 RTC time: Tue 2024-03-05 14:20:27
                                              NTP service: active
                                          RTC in local TZ: no
                                toki
                                /home/toki
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            6.3G        4.5G        1.5G        585K        677M        1.9G
                                Swap:           1.0G          0B        1.0G
                                Total:          7.4G        4.5G        2.5G
                                         6051 M total memory
                                         4244 M used memory
                                          339 M active memory
                                         4035 M inactive memory
                                         1393 M free memory
                                           53 M buffer memory
                                          591 M swap cache
                                          974 M total swap
                                            0 M used swap
                                          974 M free swap
                                *** FILESYSTEM ***
                                /dev/sda1      ext4       31G  7.3G   22G  26% /
                                [Tue Mar  5 14:43:21 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                [Tue Mar  5 14:43:24 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                                /var:
                                604M    /var/
                                246M    /var/cache
                                239M    /var/cache/apt
                                185M    /var/log
                                172M    /var/lib
                                Archived and active journals take up 28.4M in the file system.
                                952M    /opt/iobroker/iobroker-data/
                                107M    /opt/iobroker/iobroker-data/states.jsonl
                                83M     /opt/iobroker/iobroker-data/objects.jsonl
                                USB-Devices by-id:
                                /usr/bin/nodejs         v18.19.1
                                /usr/bin/node           v18.19.1
                                /usr/bin/npm            10.2.4
                                /usr/bin/npx            10.2.4
                                nodejs:
                                  Installed: 18.19.1-1nodesource1
                                  Version table:
                                 *** 18.19.1-1nodesource1 1001
                                     18.13.0+dfsg1-1 500
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.13.16
                                javascript:     7.8.0
                                Adapter State
                                + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if00
                                + instance is alive
                                Objects and States
                                Objects:        120048
                                States:         92869
                                Pending Updates: 0
                                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18505      1111/node-red
                                tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       19542      723/io.shelly.0
                                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17118      755/io.sonoff.1
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18514      718/io.mqtt.0
                                tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       17099      744/io.sonoff.0
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16180      431/iobroker.js-con
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16187      431/iobroker.js-con
                                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13366      1/init
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14070      451/sshd: /usr/sbin
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17339      484/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18735      1009/io.web.0
                                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       18717      1020/io.ws.0
                                tcp6       0      0 :::111                  :::*                    LISTEN      0          13369      1/init
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          14072      451/sshd: /usr/sbin
                                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14348      1/init
                                udp6       0      0 :::111                  :::*                                0          14351      1/init
                                2024-03-05 15:23:05.050  - debug: shelly.0 (723) [MQTT] State change 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): shellyplus2pm-d48afc7cfa64/status/cover:0 -> state: shellyplus2pm#d48afc7cfa64#1.Cover0.temperatureC, value: 46.6
                                2024-03-05 15:23:09.557  - info: javascript.0 (564) script.js.common.Gaszähler: + 0.005
                                2024-03-05 15:23:09.573  - info: javascript.0 (564) script.js.common.Gaszähler: 7026.32
                                2024-03-05 15:23:09.615  - debug: shelly.0 (723) [httpIoBrokerState] State change 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): state: shellyplus2pm#d48afc7cfa64#1.uptime, value: 338374
                                2024-03-05 15:23:09.616  - debug: shelly.0 (723) [httpIoBrokerState] State change 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): state: shellyplus2pm#d48afc7cfa64#1.rssi, value: -75
                                2024-03-05 15:23:09.684  - warn: shelly.0 (723) [authEnabled] 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): This device is not protected via restricted login (see adapter documentation for details)
                                2024-03-05 15:23:10.259  - info: javascript.0 (564) script.js.common.Gaszähler:  in Brennwert
                                2024-03-05 15:23:10.259  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.792
                                2024-03-05 15:23:10.259  - info: javascript.0 (564) script.js.common.Gaszähler: 7026.32
                                2024-03-05 15:23:10.260  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.846500056
                                2024-03-05 15:23:10.260  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.847
                                2024-03-05 15:23:10.260  - info: javascript.0 (564) script.js.common.Gaszähler: Brennwert kWh in DP geschieben
                                2024-03-05 15:23:11.839  - info: sonoff.1 (755) State value to set for "sonoff.1.SugerValley.NeoPool_pH_Data" has to be type "string" but received type "number"
                                2024-03-05 15:23:12.126  - info: sonoff.1 (755) State value to set for "sonoff.1.SugerValley.NeoPool_Redox_Data" has to be type "string" but received type "number"
                                2024-03-05 15:23:12.183  - info: sonoff.1 (755) State value to set for "sonoff.1.SugerValley.NeoPool_Hydrolysis_Data" has to be type "string" but received type "number"
                                2024-03-05 15:23:13.772  - info: sonoff.0 (744) Client [GosBlitzw_EP2] reconnected. Old secret 1709648189940_2039. New secret 1709648593772_7398
                                2024-03-05 15:23:13.854  - info: admin.0 (484) ==> Connected system.user.admin from ::ffff:192.168.0.148
                                2024-03-05 15:23:14.084  - info: javascript.0 (564) script.js.common.Gaszähler: + 0.005
                                2024-03-05 15:23:14.085  - info: javascript.0 (564) script.js.common.Gaszähler: 7026.325
                                2024-03-05 15:23:14.480  - info: javascript.0 (564) script.js.common.Gaszähler:  in Brennwert
                                2024-03-05 15:23:14.480  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.847
                                2024-03-05 15:23:14.481  - info: javascript.0 (564) script.js.common.Gaszähler: 7026.325
                                2024-03-05 15:23:14.484  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.90090324749
                                2024-03-05 15:23:14.485  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.901
                                2024-03-05 15:23:14.485  - info: javascript.0 (564) script.js.common.Gaszähler: Brennwert kWh in DP geschieben
                                  @toki1973
                                  sudo usermod -a -G adm toki
                                  sudo systemctl set-default multi-user.target
                                  Und bring den js-controller und den influxdb-Adapter auf Stand.
                                    @thomas-braun Vielen Dank!
                                    632
