    4. Test Adapter TrashSchedule
    • DJMarc75
      DJMarc75 @Virus2K12 last edited by
      @virus2k12
      Dann starte mal den kompletten PI neu.
      Virus2K12 1 Reply Last reply Reply Quote 0
        Thomas Braun Most Active @Virus2K12 last edited by
        @virus2k12
        systemctl status iobroker.service
        sagt?
        Virus2K12 2 Replies Last reply Reply Quote 0
        • Virus2K12
          Virus2K12 @Thomas Braun last edited by
          @thomas-braun ich mach grade einen reboot, mal abwarten was er dann zeigt.
          • Virus2K12
            @thomas-braun sagt: das alles läuft
            • Virus2K12
              Virus2K12 @DJMarc75 last edited by
              @djmarc75 zeigt trotzdem nichts an.
              na egal ich muss jetzt bissl schlafen, hab dann noch Nachtschicht.
              Danke erstmal soweit für die Tipps. Es läuft ja soweit.
                Thomas Braun Most Active @Virus2K12 last edited by Thomas Braun
                @virus2k12 sagte in Test Adapter TrashSchedule:
                Zeigen, nix nacherzählen.
                • Virus2K12
                  Virus2K12 @Thomas Braun last edited by Negalein
                  pi@raspberrypi:~ $ systemctl status iobroker.service
                  * iobroker.service - ioBroker Server
                       Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: ena>
                       Active: active (running) since Thu 2024-03-07 13:41:39 CET; 27min ago
                         Docs: http://iobroker.net
                     Main PID: 1239 (iobroker.js-con)
                        Tasks: 374 (limit: 4915)
                          CPU: 1h 6min 20.668s
                       CGroup: /system.slice/iobroker.service
                               |-1239 iobroker.js-controller
                               |-1454 io.admin.0
                               |-1466 io.history.0
                               |-1505 io.javascript.0
                               |-1525 io.telegram.0
                               |-1560 io.alexa2.0
                               |-1576 io.backitup.0
                               |-1614 io.hmip.0
                               |-1621 io.hue.0
                               |-1667 io.mqtt-client.0
                               |-1706 io.mqtt.1
                               |-1718 io.shelly.0
                               |-1759 io.sonoff.0
                               |-1773 io.tr-064.0
                               |-1801 io.tr-064.1
                               |-1812 io.tuya.0
                               |-1870 io.wifilight.0
                               |-1890 io.awtrix-light.0
                               |-1924 io.bring.0
                               |-1972 io.device-watcher.0
                               |-1983 io.discovery.0
                               |-2027 io.echarts.0
                               |-2068 io.hue-extended.0
                               |-2087 io.info.0
                               |-2160 io.simple-api.0
                               |-2171 io.snmp.0
                               |-2182 io.text2command.0
                               |-2211 io.trashschedule.0
                               |-2252 io.vesync.0
                               |-2263 io.vis-2.0
                               |-2305 io.vis-inventwo.0
                               |-2342 io.web.0
                               |-2349 io.wled.0
                               `-2372 io.ws.0
                  Mar 07 13:42:13 raspberrypi bash[1239]: host.raspberrypi check instance "system>
                  Mar 07 13:42:25 raspberrypi bash[1239]: ================================== > LO>
                  Mar 07 13:42:28 raspberrypi bash[1239]: Send diag info: {"uuid":"a2e3c321-5dd7->
                  pi@raspberrypi:~ $
                    @virus2k12
                    Ruf das mal auf:
                    curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                    Dürfte ein Netzwerk-Thema sein.
                    • haus-automatisierung
                      haus-automatisierung Developer Most Active @Codierknecht last edited by haus-automatisierung
                      @codierknecht sagte in Test Adapter TrashSchedule:
                      @virus2k12
                      Wie sieht denn Dein Schedule dazu aus?
                      Warum hast Du denn einen Neustart-Zeitplan für die Instanz hinterlegt? Ist nicht notwendig.
                      Wird das überhaupt gebraucht?
                      Nein. Das startet ja bei Dir die Instanz 2x jede Stunde neu. Warum sollte man das tun? Wäre das nötig, würde der Adapter das mitbringen. Ist halt auch eine Option für Experten und deswegen (aus Gründen) nur im Expertenmodus sichtbar.
                      • Codierknecht
                        Codierknecht Developer Most Active @haus-automatisierung last edited by
                        Wie gesagt: Keine Ahnung, warum das drin ist.
                        Vielleicht mal zu Testzwecken reingekommen und vergessen wieder zu entfernen.
                          Expertenmodus einfach immer auslassen (wozu braucht man den überhaupt?) 🙂
                          • Codierknecht
                            @haus-automatisierung sagte in Test Adapter TrashSchedule:
                            Ist er auch - in der Regel.
                            Und wenn ich ihn einschalte, dann nicht dauerhaft.
                            Um z.B. mal den Loglevel zu verändern.
                            Oder das Schedule für beispielsweise "iCal" oder "DasWetter", damit die ihre Daten nicht zu vollen Stunde holen.
                              Für Schedule-Adapter kann man den Zeitplan auch ohne Expertenmodus anpassen 🙂
                              • Codierknecht
                                Stimmt. Das mache ich halt so selten 😉
                                Für Loglevel braucht man den EM trotzdem. Aber eben auch nur sehr selten.
                                • Virus2K12
                                  @djmarc75
                                  Copy text starting here:
                                  			v.2023-10-25
                                   Static hostname: raspberrypi
                                         Icon name: computer
                                  Operating System: Raspbian GNU/Linux 12 (bookworm)
                                            Kernel: Linux 5.10.103-v7l+
                                      Architecture: arm
                                  Installation: 		native
                                  Kernel: 		armv7l
                                  Userland: 		armhf
                                  Timezone: 		Europe/Berlin (CET, +0100)
                                  User-ID: 		1000
                                  X-Server: 		true
                                  Boot Target: 		graphical.target
                                  Pending OS-Updates: 	0
                                  Pending iob updates: 	1
                                  Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
                                  			/usr/bin/node 		v18.19.1
                                  			/usr/bin/npm 		10.5.0
                                  			/usr/bin/npx 		10.5.0
                                  			/usr/bin/corepack 	0.22.0
                                  Recommended versions are nodejs 18.19.1 and npm 10.2.4
                                  MEMORY:
                                  Mem:            4.0G        3.0G        487M         13M        705M        1.0G
                                  Swap:           104M        104M        4.1K
                                  Total:          4.1G        3.1G        487M
                                  Active iob-Instances: 	34
                                  Active repo(s): Beta (latest)
                                  ioBroker Core: 		js-controller 		5.0.19
                                  			admin 			6.15.2
                                  ioBroker Status: 	iobroker is running on this host.
                                  Objects type: jsonl
                                  States  type: jsonl
                                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  Objects: 		21621
                                  States: 		14503
                                  Size of iob-Database:
                                  27M	/opt/iobroker/iobroker-data/objects.jsonl
                                  115M	/opt/iobroker/iobroker-data/states.jsonl
                                  === Mark text until here for copying ===
                                    @virus2k12
                                    Da stimmt was nicht mit npm.
                                    iob stop
                                    sudo apt install --reinstall nodejs
                                    iob restart
                                    Und dann nochmal die Langfassung von iob diag.
                                    Finger von npm lassen!
                                    • Codierknecht
                                      Codierknecht Developer Most Active @Thomas Braun last edited by
                                      @Virus2K12
                                      ... und den Desktop ausschalten.
                                        Thomas Braun Most Active @Codierknecht last edited by
                                        @Virus2K12
                                        Oh, ganz übersehen. Natürlich.
                                        Und auch mal prüfen, ob die Hardware nicht 64Bit verträgt.
                                        • Virus2K12
                                          Desktop aus und reinstall nodejs gemacht.
                                          Hier jetzt erst einmal die lange Fassung von iob diag
                                          Skript v.2023-10-25
                                          *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm
                                          Model		: Raspberry Pi 4 Model B Rev 1.1
                                          Docker          : false
                                          Virtualization  : none
                                          Kernel          : armv7l
                                          Userland        : armhf
                                          Systemuptime and Load:
                                           11:46:10 up 4 min,  1 user,  load average: 4.35, 2.76, 1.17
                                          CPU threads: 4
                                          *** RASPBERRY THROTTLING ***
                                          Current issues:
                                          Previously detected issues:
                                          *** Time and Time Zones ***
                                                         Local time: Fri 2024-03-08 11:46:10 CET
                                                     Universal time: Fri 2024-03-08 10:46:10 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** User and Groups ***
                                          pi
                                          /home/pi
                                          pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                          *** X-Server-Setup ***
                                          X-Server: 	false
                                          Desktop:
                                          Terminal: 	tty
                                          Boot Target: 	multi-user.target
                                          *** MEMORY ***
                                          Mem:            4.0G        2.4G        670M        4.8M        1.1G        1.6G
                                          Swap:           104M          0B        104M
                                          Total:          4.1G        2.4G        775M
                                                   3837 M total memory
                                                   2303 M used memory
                                                    235 M active memory
                                                   2842 M inactive memory
                                                    638 M free memory
                                                    244 M buffer memory
                                                    788 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FAILED SERVICES ***
                                            UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                                          * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
                                          LOAD   = Reflects whether the unit definition was properly loaded.
                                          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                          SUB    = The low-level unit activation state, values depend on unit type.
                                          1 loaded units listed.
                                          *** FILESYSTEM ***
                                          /dev/root      ext4      219G   24G  185G  12% /
                                          devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                                          tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
                                          tmpfs          tmpfs     768M  2.1M  766M   1% /run
                                          tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                                          /dev/loop1     squashfs   43M   43M     0 100% /snap/certbot/3642
                                          /dev/loop2     squashfs   91M   91M     0 100% /snap/core/16207
                                          /dev/loop0     squashfs   42M   42M     0 100% /snap/certbot/3568
                                          /dev/loop4     squashfs   54M   54M     0 100% /snap/core20/2106
                                          /dev/loop3     squashfs   91M   91M     0 100% /snap/core/16575
                                          /dev/loop5     squashfs   54M   54M     0 100% /snap/core20/2185
                                          /dev/sda1      vfat      253M   93M  160M  37% /boot
                                          tmpfs          tmpfs     384M   80K  384M   1% /run/user/1000
                                          [Fri Mar  8 11:41:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=DC:A6:32:4F:AC:15 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=048e52a3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles fsck.mode=force cfg80211.ieee80211_regdom=DE
                                          [Fri Mar  8 11:41:27 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                                          [Fri Mar  8 11:41:27 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                          [Fri Mar  8 11:42:02 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
                                          Show mounted filesystems:
                                          TARGET                         SOURCE      FSTYPE      OPTIONS
                                          /                              /dev/sda2   ext4        rw,noatime
                                          |-/dev                         devtmpfs    devtmpfs    rw,relatime,size=1800056k,nr_inodes=84157,mode=755
                                          | |-/dev/shm                   tmpfs       tmpfs       rw,nosuid,nodev
                                          | |-/dev/pts                   devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                          | `-/dev/mqueue                mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                                          |-/proc                        proc        proc        rw,relatime
                                          | `-/proc/sys/fs/binfmt_misc   systemd-1   autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                          |   `-/proc/sys/fs/binfmt_misc binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                                          |-/sys                         sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/kernel/security       securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/fs/cgroup             cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                          | |-/sys/fs/bpf                none        bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                                          | |-/sys/kernel/debug          debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/kernel/tracing        tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/fs/fuse/connections   fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                                          | `-/sys/kernel/config         configfs    configfs    rw,nosuid,nodev,noexec,relatime
                                          |-/run                         tmpfs       tmpfs       rw,nosuid,nodev,size=785972k,nr_inodes=819200,mode=755
                                          | |-/run/lock                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                                          | |-/run/credentials/systemd-sysctl.service
                                          | |                            none        ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                          | |-/run/credentials/systemd-sysusers.service
                                          | |-/run/credentials/systemd-tmpfiles-setup-dev.service
                                          | |-/run/rpc_pipefs            sunrpc      rpc_pipefs  rw,relatime
                                          | |-/run/credentials/systemd-tmpfiles-setup.service
                                          | `-/run/user/1000             tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=392984k,nr_inodes=98246,mode=700,uid=1000,gid=1000
                                          |-/snap/certbot/3642           /dev/loop1  squashfs    ro,nodev,relatime
                                          |-/snap/core/16207             /dev/loop2  squashfs    ro,nodev,relatime
                                          |-/snap/certbot/3568           /dev/loop0  squashfs    ro,nodev,relatime
                                          |-/snap/core20/2106            /dev/loop4  squashfs    ro,nodev,relatime
                                          |-/snap/core/16575             /dev/loop3  squashfs    ro,nodev,relatime
                                          |-/snap/core20/2185            /dev/loop5  squashfs    ro,nodev,relatime
                                          `-/boot                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-r
                                          /var:
                                          3.6G	/var/
                                          2.1G	/var/log
                                          1.9G	/var/log/journal/a86ff8ac034a41cc8294fe68053416f8
                                          1.3G	/var/lib
                                          Archived and active journals take up 1.8G in the file system.
                                          /opt/iobroker/backups:
                                          178M	/opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          741M	/opt/iobroker/iobroker-data/
                                          523M	/opt/iobroker/iobroker-data/files
                                          89M	/opt/iobroker/iobroker-data/files/echarts.admin
                                          80M	/opt/iobroker/iobroker-data/backup-objects
                                          57M	/opt/iobroker/iobroker-data/files/javascript.admin
                                          du: cannot access '/opt/iobroker/iobroker-data/files/vis-2/c3ec73ec5450fb4cac984fc867dd54eb.js': No such file or directory
                                          du: cannot access '/opt/iobroker/iobroker-data/files/vis-2/c351437da7e800bc3d9409c431052f9c.js': No such file or directory
                                          109M	/opt/iobroker/iobroker-data/states.jsonl
                                          35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                          31M	/opt/iobroker/iobroker-data/objects.jsonl
                                          24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                          24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                          USB-Devices by-id:
                                          *** NodeJS-Installation ***
                                          /usr/bin/npm 		10.2.4
                                          /usr/bin/npx 		10.2.4
                                          nodejs:
                                            Installed: 18.19.1-1nodesource1
                                            Candidate: 18.19.1-1nodesource1
                                            Version table:
                                           *** 18.19.1-1nodesource1 600
                                                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                                  100 /var/lib/dpkg/status
                                               18.19.0+dfsg-6~deb12u1+rpi1 500
                                                  500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
                                               18.19.0-1nodesource1 600
                                               18.18.2-1nodesource1 600
                                               18.18.1-1nodesource1 600
                                               18.18.0-1nodesource1 600
                                               18.17.1-1nodesource1 600
                                               18.17.0-1nodesource1 600
                                               18.16.1-1nodesource1 600
                                               18.16.0-1nodesource1 600
                                               18.15.0-1nodesource1 600
                                               18.14.2-1nodesource1 600
                                               18.14.1-1nodesource1 600
                                               18.14.0-1nodesource1 600
                                               18.13.0-1nodesource1 600
                                               18.12.0-1nodesource1 600
                                               18.11.0-1nodesource1 600
                                               18.10.0-1nodesource1 600
                                               18.9.1-1nodesource1 600
                                               18.9.0-1nodesource1 600
                                               18.8.0-1nodesource1 600
                                               18.7.0-1nodesource1 600
                                               18.6.0-1nodesource1 600
                                               18.5.0-1nodesource1 600
                                               18.4.0-1nodesource1 600
                                               18.3.0-1nodesource1 600
                                               18.2.0-1nodesource1 600
                                               18.1.0-1nodesource1 600
                                               18.0.0-1nodesource1 600
                                          No problems detected
                                          Errors in npm tree:
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          js-controller: 	5.0.19
                                          admin: 		6.15.2
                                          javascript: 	7.8.0
                                          Adapters from github: 	1
                                          Adapter State
                                          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled, compact disabled
                                            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled, compact disabled
                                            system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                                          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled, compact disabled
                                            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled, compact disabled
                                            system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                                          + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, compact disabled, port: 80
                                            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled, compact disabled
                                            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
                                            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
                                            system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
                                            system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
                                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
                                          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, compact disabled, port: 1884
                                            system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, compact disabled, port: 1883, bind: 0.0.0.0
                                          + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, compact disabled, port: 1884, bind: 0.0.0.0
                                            system.adapter.netatmo-crawler.1        : netatmo-crawler       : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
                                          + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
                                          + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
                                          + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.vesync.0                 : vesync                : raspberrypi                              -  enabled, compact disabled
                                            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
                                          + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled, compact disabled
                                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
                                            system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled, compact disabled
                                            system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
                                            system.adapter.vis-homekittiles.0       : vis-homekittiles      : raspberrypi                              -  enabled
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                                            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled, compact disabled
                                            system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
                                            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
                                            system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
                                            system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
                                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                                            system.adapter.vis-owl.0                : vis-owl               : raspberrypi                              -  enabled
                                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                                            system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled, compact disabled
                                            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled, compact disabled
                                          + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
                                          + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled, compact disabled
                                          + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                          + instance is alive
                                          ioBroker-Repositories
                                          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                          Installed ioBroker-Instances
                                          Used repository: Beta (latest)
                                          Adapter    "admin"        : 6.15.2   , installed 6.15.2
                                          Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                                          Adapter    "awtrix-light" : 0.15.0   , installed 0.15.0
                                          Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                          Adapter    "bring"        : 1.8.4    , installed 1.8.4
                                          Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                          Adapter    "device-watcher": 2.10.5  , installed 2.10.5
                                          Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                                          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                          Adapter    "espresense"   : 0.4.4    , installed 0.4.4
                                          Adapter    "hmip"         : 1.22.0   , installed 1.22.0
                                          Adapter    "hue"          : 3.10.2   , installed 3.10.2
                                          Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                                          Adapter    "ical"         : 1.14.3   , installed 1.14.3
                                          Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                                          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                          Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
                                          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                          Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                                          Adapter    "snmp"         : 3.1.0    , installed 3.1.0
                                          Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                                          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                          Adapter    "telegram"     : 3.1.0    , installed 3.1.0
                                          Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                          Adapter    "trashschedule": 3.2.0    , installed 2.3.0  [Updatable]
                                          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                                          Adapter    "vesync"       : 0.0.7    , installed 0.0.7
                                          Adapter    "vis-2"        : 2.9.40   , installed 2.9.40
                                          Adapter    "vis-2-widgets-material": 1.3.25, installed 1.3.25
                                          Adapter    "vis-2-widgets-sweethome3d": 0.1.6, installed 0.1.6
                                          Adapter    "vis-homekittiles": 0.0.9 , installed 0.0.9
                                          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                                          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                          Adapter    "vis-map"      : 1.1.0    , installed 1.1.0
                                          Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                                          Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                                          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                                          Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                                          Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                          Adapter    "ws"           : 2.5.11   , installed 2.5.11
                                          Objects and States
                                          Objects: 	21668
                                          States: 	14569
                                          Hit:1 http://linux.teamviewer.com/deb stable InRelease
                                          Hit:2 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
                                          Hit:3 http://archive.raspberrypi.org/debian bookworm InRelease
                                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                          Hit:5 https://packages.sury.org/php buster InRelease
                                          Update rpimonitor Packages Status
                                          Reading package lists... Done
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          Netid          State           Recv-Q          Send-Q                                 Local Address:Port                    Peer Address:Port         Process
                                          udp            UNCONN          0               0                                            0.0.0.0:6666                         0.0.0.0:*             users:(("io.tuya.0",pid=1804,fd=37))
                                          udp            UNCONN          0               0                                            0.0.0.0:6667                         0.0.0.0:*             users:(("io.tuya.0",pid=1804,fd=38))
                                          udp            UNCONN          0               0                                            0.0.0.0:5683                         0.0.0.0:*             users:(("io.shelly.0",pid=1704,fd=32))
                                          udp            UNCONN          0               0                                          127.0.0.1:53                           0.0.0.0:*             users:(("connmand",pid=570,fd=11))
                                          udp            UNCONN          0               0                                            0.0.0.0:33903                        0.0.0.0:*             users:(("io.snmp.0",pid=2100,fd=29))
                                          udp            UNCONN          0               0                                            0.0.0.0:631                          0.0.0.0:*             users:(("cups-browsed",pid=1293,fd=7))
                                          udp            UNCONN          0               0                                    192.168.178.255:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=17))
                                          udp            UNCONN          0               0                                     192.168.178.51:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=16))
                                          udp            UNCONN          0               0                                            0.0.0.0:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=14))
                                          udp            UNCONN          0               0                                    192.168.178.255:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=19))
                                          udp            UNCONN          0               0                                     192.168.178.51:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=18))
                                          udp            UNCONN          0               0                                            0.0.0.0:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=15))
                                          udp            UNCONN          0               0                                            0.0.0.0:45212                        0.0.0.0:*             users:(("connmand",pid=570,fd=21))
                                          udp            UNCONN          0               0                                            0.0.0.0:5353                         0.0.0.0:*             users:(("io.wled.0",pid=2673,fd=21))
                                          udp            UNCONN          0               0                                     192.168.178.51:5353                         0.0.0.0:*             users:(("io.tr-064.1",pid=1762,fd=29))
                                          udp            UNCONN          0               0                                     192.168.178.51:5353                         0.0.0.0:*             users:(("io.tr-064.0",pid=1736,fd=30))
                                          udp            UNCONN          0               0                                            0.0.0.0:5353                         0.0.0.0:*             users:(("avahi-daemon",pid=456,fd=12))
                                          udp            UNCONN          0               0                                            0.0.0.0:47932                        0.0.0.0:*             users:(("avahi-daemon",pid=456,fd=14))
                                          udp            UNCONN          0               0                                                  *:50208                              *:*             users:(("avahi-daemon",pid=456,fd=15))
                                          udp            UNCONN          0               0                                                  *:546                                *:*             users:(("connmand",pid=570,fd=18))
                                          udp            UNCONN          23616           0                        [fe80::ac64:680b:efa1:4b03]:546                                *:*             users:(("NetworkManager",pid=569,fd=24))
                                          udp            UNCONN          0               0                                              [::1]:53                                 *:*             users:(("connmand",pid=570,fd=12))
                                          udp            UNCONN          0               0                                                  *:5353                               *:*             users:(("avahi-daemon",pid=456,fd=13))
                                          tcp            LISTEN          0               128                                        127.0.0.1:5939                         0.0.0.0:*             users:(("teamviewerd",pid=1322,fd=12))
                                          tcp            LISTEN          0               4096                                         0.0.0.0:8083                         0.0.0.0:*             users:(("motion",pid=866,fd=5))
                                          tcp            LISTEN          0               10                                      127.0.0.1%lo:53                           0.0.0.0:*             users:(("connmand",pid=570,fd=13))
                                          tcp            LISTEN          0               128                                          0.0.0.0:22                           0.0.0.0:*             users:(("sshd",pid=707,fd=3))
                                          tcp            LISTEN          0               128                                        127.0.0.1:631                          0.0.0.0:*             users:(("cupsd",pid=617,fd=7))
                                          tcp            LISTEN          0               5                                            0.0.0.0:8888                         0.0.0.0:*             users:(("rpimonitord",pid=754,fd=4))
                                          tcp            LISTEN          0               511                                          0.0.0.0:1883                         0.0.0.0:*             users:(("io.sonoff.0",pid=1711,fd=34))
                                          tcp            LISTEN          0               511                                          0.0.0.0:1884                         0.0.0.0:*             users:(("io.mqtt.1",pid=1666,fd=29))
                                          tcp            LISTEN          0               50                                           0.0.0.0:445                          0.0.0.0:*             users:(("smbd",pid=1348,fd=31))
                                          tcp            LISTEN          0               128                                          0.0.0.0:8765                         0.0.0.0:*             users:(("meyectl",pid=470,fd=12))
                                          tcp            LISTEN          0               4096                                         0.0.0.0:7999                         0.0.0.0:*             users:(("motion",pid=866,fd=7))
                                          tcp            LISTEN          0               511                                        127.0.0.1:9000                         0.0.0.0:*             users:(("iobroker.js-con",pid=1306,fd=27))
                                          tcp            LISTEN          0               511                                        127.0.0.1:9001                         0.0.0.0:*             users:(("iobroker.js-con",pid=1306,fd=21))
                                          tcp            LISTEN          0               80                                         127.0.0.1:3306                         0.0.0.0:*             users:(("mariadbd",pid=714,fd=27))
                                          tcp            LISTEN          0               50                                           0.0.0.0:139                          0.0.0.0:*             users:(("smbd",pid=1348,fd=32))
                                          tcp            LISTEN          0               511                                        127.0.0.1:6379                         0.0.0.0:*             users:(("redis-server",pid=620,fd=6))
                                          tcp            LISTEN          0               511                                                *:80                                 *:*             users:(("apache2",pid=799,fd=4),("apache2",pid=797,fd=4),("apache2",pid=796,fd=4),("apache2",pid=795,fd=4),("apache2",pid=794,fd=4),("apache2",pid=793,fd=4),("apache2",pid=739,fd=4))
                                          tcp            LISTEN          0               511                                                *:8081                               *:*             users:(("io.admin.0",pid=1419,fd=29))
                                          tcp            LISTEN          0               511                                                *:8082                               *:*             users:(("io.web.0",pid=2666,fd=29))
                                          tcp            LISTEN          0               511                                                *:8084                               *:*             users:(("io.ws.0",pid=2703,fd=28))
                                          tcp            LISTEN          0               10                                          [::1]%lo:53                              [::]:*             users:(("connmand",pid=570,fd=14))
                                          tcp            LISTEN          0               128                                             [::]:22                              [::]:*             users:(("sshd",pid=707,fd=4))
                                          tcp            LISTEN          0               511                                                *:8087                               *:*             users:(("io.simple-api.0",pid=2067,fd=28))
                                          tcp            LISTEN          0               128                                            [::1]:631                             [::]:*             users:(("cupsd",pid=617,fd=6))
                                          tcp            LISTEN          0               4096                                               *:3000                               *:*             users:(("grafana-server",pid=1295,fd=11))
                                          tcp            LISTEN          0               50                                              [::]:445                             [::]:*             users:(("smbd",pid=1348,fd=29))
                                          tcp            LISTEN          0               511                                            [::1]:6379                            [::]:*             users:(("redis-server",pid=620,fd=7))
                                          tcp            LISTEN          0               50                                              [::]:139                             [::]:*             users:(("smbd",pid=1348,fd=30))
                                          2024-03-08 11:46:19.657  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.humidity_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.humidity_value": Connection is closed.]
                                          2024-03-08 11:46:19.659  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value": Connection is closed.
                                          2024-03-08 11:46:19.660  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value": Connection is closed.]
                                          2024-03-08 11:46:19.662  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value": Connection is closed.
                                          2024-03-08 11:46:19.664  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value": Connection is closed.]
                                          2024-03-08 11:46:19.666  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value": Connection is closed.
                                          2024-03-08 11:46:19.667  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value": Connection is closed.]
                                          2024-03-08 11:46:19.669  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value": Connection is closed.
                                          2024-03-08 11:46:19.671  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value": Connection is closed.]
                                          2024-03-08 11:46:19.673  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value": Connection is closed.
                                          2024-03-08 11:46:19.675  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value": Connection is closed.]
                                          2024-03-08 11:46:19.677  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8": Connection is closed.
                                          2024-03-08 11:46:19.680  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8": Connection is closed.]
                                          2024-03-08 11:46:19.682  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value": Connection is closed.
                                          2024-03-08 11:46:19.684  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value": Connection is closed.]
                                          2024-03-08 11:46:20.212  - error: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                                          2024-03-08 11:46:21.158  - info: tuya.0 (1804) bf047f0676f4973f71uyin: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.59:6668
                                          2024-03-08 11:46:35.239  - info: tuya.0 (1804) bf7e8a579d18ba290elhqa: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.34:6668
                                          2024-03-08 11:46:40.760  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                                          2024-03-08 11:46:40.844  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                                          2024-03-08 11:47:01.160  - error: vesync.0 (2220) {"traceId":"1709894813723","code":-11302030,"msg":"device timeout","module":null,"stacktrace":null,"result":null}
                                          2024-03-08 11:47:42.466  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                                          2024-03-08 11:47:42.960  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                                          2024-03-08 11:48:40.996  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                                          2024-03-08 11:48:41.296  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                                          iob diag has finished.
                                          Press any key for a summary
                                          • Virus2K12
                                            zusammenfassung iob_diag
                                            			v.2023-10-25
                                                   Icon name: computer
                                                Architecture: arm
                                            Kernel: 		armv7l
                                            Userland: 		armhf
                                            User-ID: 		1000
                                            X-Server: 		false
                                            			/usr/bin/npm 		10.2.4
                                            			/usr/bin/npx 		10.2.4
                                            MEMORY:
                                            Mem:            4.0G        2.7G        223M        4.8M        1.3G        1.3G
                                            Swap:           104M          0B        104M
                                            Total:          4.1G        2.7G        328M
                                            			admin 			6.15.2
                                            Objects type: jsonl
                                            States  type: jsonl
                                            Objects: 		21668
                                            States: 		14569
                                            32M	/opt/iobroker/iobroker-data/objects.jsonl
                                            112M	/opt/iobroker/iobroker-data/states.jsonl
                                            adapter calendar ical kalender müll trash
                                            184
                                            1432
                                            428071
