    4. Test Adapter TrashSchedule
      Thomas Braun Most Active @Virus2K12 last edited by
      @virus2k12
      systemctl status iobroker.service
      sagt?
      Virus2K12 2 Replies Last reply Reply Quote 0
      • Virus2K12
        Virus2K12 @Thomas Braun last edited by
        @thomas-braun ich mach grade einen reboot, mal abwarten was er dann zeigt.
        • Virus2K12
          @thomas-braun sagt: das alles läuft
          • Virus2K12
            Virus2K12 @DJMarc75 last edited by
            @djmarc75 zeigt trotzdem nichts an.
            na egal ich muss jetzt bissl schlafen, hab dann noch Nachtschicht.
            Danke erstmal soweit für die Tipps. Es läuft ja soweit.
              Thomas Braun Most Active @Virus2K12 last edited by Thomas Braun
              @virus2k12 sagte in Test Adapter TrashSchedule:
              Zeigen, nix nacherzählen.
              Virus2K12 1 Reply Last reply Reply Quote 0
              • Virus2K12
                Virus2K12 @Thomas Braun last edited by Negalein
                pi@raspberrypi:~ $ systemctl status iobroker.service
                * iobroker.service - ioBroker Server
                     Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: ena>
                     Active: active (running) since Thu 2024-03-07 13:41:39 CET; 27min ago
                       Docs: http://iobroker.net
                   Main PID: 1239 (iobroker.js-con)
                      Tasks: 374 (limit: 4915)
                        CPU: 1h 6min 20.668s
                     CGroup: /system.slice/iobroker.service
                             |-1239 iobroker.js-controller
                             |-1454 io.admin.0
                             |-1466 io.history.0
                             |-1505 io.javascript.0
                             |-1525 io.telegram.0
                             |-1560 io.alexa2.0
                             |-1576 io.backitup.0
                             |-1614 io.hmip.0
                             |-1621 io.hue.0
                             |-1667 io.mqtt-client.0
                             |-1706 io.mqtt.1
                             |-1718 io.shelly.0
                             |-1759 io.sonoff.0
                             |-1773 io.tr-064.0
                             |-1801 io.tr-064.1
                             |-1812 io.tuya.0
                             |-1870 io.wifilight.0
                             |-1890 io.awtrix-light.0
                             |-1924 io.bring.0
                             |-1972 io.device-watcher.0
                             |-1983 io.discovery.0
                             |-2027 io.echarts.0
                             |-2068 io.hue-extended.0
                             |-2087 io.info.0
                             |-2160 io.simple-api.0
                             |-2171 io.snmp.0
                             |-2182 io.text2command.0
                             |-2211 io.trashschedule.0
                             |-2252 io.vesync.0
                             |-2263 io.vis-2.0
                             |-2305 io.vis-inventwo.0
                             |-2342 io.web.0
                             |-2349 io.wled.0
                             `-2372 io.ws.0
                Mar 07 13:42:13 raspberrypi bash[1239]: host.raspberrypi check instance "system>
                Mar 07 13:42:25 raspberrypi bash[1239]: ================================== > LO>
                Mar 07 13:42:28 raspberrypi bash[1239]: Send diag info: {"uuid":"a2e3c321-5dd7->
                pi@raspberrypi:~ $
                  @virus2k12
                  Ruf das mal auf:
                  curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                  Dürfte ein Netzwerk-Thema sein.
                  • haus-automatisierung
                    haus-automatisierung Developer Most Active @Codierknecht last edited by haus-automatisierung
                    @codierknecht sagte in Test Adapter TrashSchedule:
                    @virus2k12
                    Wie sieht denn Dein Schedule dazu aus?
                    Warum hast Du denn einen Neustart-Zeitplan für die Instanz hinterlegt? Ist nicht notwendig.
                    Wird das überhaupt gebraucht?
                    Nein. Das startet ja bei Dir die Instanz 2x jede Stunde neu. Warum sollte man das tun? Wäre das nötig, würde der Adapter das mitbringen. Ist halt auch eine Option für Experten und deswegen (aus Gründen) nur im Expertenmodus sichtbar.
                    • Codierknecht
                      Codierknecht Developer Most Active @haus-automatisierung last edited by
                      Wie gesagt: Keine Ahnung, warum das drin ist.
                      Vielleicht mal zu Testzwecken reingekommen und vergessen wieder zu entfernen.
                        Expertenmodus einfach immer auslassen (wozu braucht man den überhaupt?) 🙂
                        • Codierknecht
                          @haus-automatisierung sagte in Test Adapter TrashSchedule:
                          Ist er auch - in der Regel.
                          Und wenn ich ihn einschalte, dann nicht dauerhaft.
                          Um z.B. mal den Loglevel zu verändern.
                          Oder das Schedule für beispielsweise "iCal" oder "DasWetter", damit die ihre Daten nicht zu vollen Stunde holen.
                            Für Schedule-Adapter kann man den Zeitplan auch ohne Expertenmodus anpassen 🙂
                            • Codierknecht
                              Stimmt. Das mache ich halt so selten 😉
                              Für Loglevel braucht man den EM trotzdem. Aber eben auch nur sehr selten.
                              • Virus2K12
                                @djmarc75
                                Copy text starting here:
                                			v.2023-10-25
                                 Static hostname: raspberrypi
                                       Icon name: computer
                                Operating System: Raspbian GNU/Linux 12 (bookworm)
                                          Kernel: Linux 5.10.103-v7l+
                                    Architecture: arm
                                Installation: 		native
                                Kernel: 		armv7l
                                Userland: 		armhf
                                Timezone: 		Europe/Berlin (CET, +0100)
                                User-ID: 		1000
                                X-Server: 		true
                                Boot Target: 		graphical.target
                                Pending OS-Updates: 	0
                                Pending iob updates: 	1
                                Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
                                			/usr/bin/node 		v18.19.1
                                			/usr/bin/npm 		10.5.0
                                			/usr/bin/npx 		10.5.0
                                			/usr/bin/corepack 	0.22.0
                                Recommended versions are nodejs 18.19.1 and npm 10.2.4
                                MEMORY:
                                Mem:            4.0G        3.0G        487M         13M        705M        1.0G
                                Swap:           104M        104M        4.1K
                                Total:          4.1G        3.1G        487M
                                Active iob-Instances: 	34
                                Active repo(s): Beta (latest)
                                ioBroker Core: 		js-controller 		5.0.19
                                			admin 			6.15.2
                                ioBroker Status: 	iobroker is running on this host.
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                Objects: 		21621
                                States: 		14503
                                Size of iob-Database:
                                27M	/opt/iobroker/iobroker-data/objects.jsonl
                                115M	/opt/iobroker/iobroker-data/states.jsonl
                                === Mark text until here for copying ===
                                  @virus2k12
                                  Da stimmt was nicht mit npm.
                                  iob stop
                                  sudo apt install --reinstall nodejs
                                  iob restart
                                  Und dann nochmal die Langfassung von iob diag.
                                  Finger von npm lassen!
                                  • Codierknecht
                                    Codierknecht Developer Most Active @Thomas Braun last edited by
                                    @Virus2K12
                                    ... und den Desktop ausschalten.
                                      Thomas Braun Most Active @Codierknecht last edited by
                                      @Virus2K12
                                      Oh, ganz übersehen. Natürlich.
                                      Und auch mal prüfen, ob die Hardware nicht 64Bit verträgt.
                                      • Virus2K12
                                        Desktop aus und reinstall nodejs gemacht.
                                        Hier jetzt erst einmal die lange Fassung von iob diag
                                        Skript v.2023-10-25
                                        *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm
                                        Model		: Raspberry Pi 4 Model B Rev 1.1
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : armv7l
                                        Userland        : armhf
                                        Systemuptime and Load:
                                         11:46:10 up 4 min,  1 user,  load average: 4.35, 2.76, 1.17
                                        CPU threads: 4
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        *** Time and Time Zones ***
                                                       Local time: Fri 2024-03-08 11:46:10 CET
                                                   Universal time: Fri 2024-03-08 10:46:10 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** User and Groups ***
                                        pi
                                        /home/pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                        *** X-Server-Setup ***
                                        X-Server: 	false
                                        Desktop:
                                        Terminal: 	tty
                                        Boot Target: 	multi-user.target
                                        *** MEMORY ***
                                        Mem:            4.0G        2.4G        670M        4.8M        1.1G        1.6G
                                        Swap:           104M          0B        104M
                                        Total:          4.1G        2.4G        775M
                                                 3837 M total memory
                                                 2303 M used memory
                                                  235 M active memory
                                                 2842 M inactive memory
                                                  638 M free memory
                                                  244 M buffer memory
                                                  788 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FAILED SERVICES ***
                                          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                                        * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
                                        LOAD   = Reflects whether the unit definition was properly loaded.
                                        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                        SUB    = The low-level unit activation state, values depend on unit type.
                                        1 loaded units listed.
                                        *** FILESYSTEM ***
                                        /dev/root      ext4      219G   24G  185G  12% /
                                        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                                        tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
                                        tmpfs          tmpfs     768M  2.1M  766M   1% /run
                                        tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                                        /dev/loop1     squashfs   43M   43M     0 100% /snap/certbot/3642
                                        /dev/loop2     squashfs   91M   91M     0 100% /snap/core/16207
                                        /dev/loop0     squashfs   42M   42M     0 100% /snap/certbot/3568
                                        /dev/loop4     squashfs   54M   54M     0 100% /snap/core20/2106
                                        /dev/loop3     squashfs   91M   91M     0 100% /snap/core/16575
                                        /dev/loop5     squashfs   54M   54M     0 100% /snap/core20/2185
                                        /dev/sda1      vfat      253M   93M  160M  37% /boot
                                        tmpfs          tmpfs     384M   80K  384M   1% /run/user/1000
                                        [Fri Mar  8 11:41:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=DC:A6:32:4F:AC:15 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=048e52a3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles fsck.mode=force cfg80211.ieee80211_regdom=DE
                                        [Fri Mar  8 11:41:27 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                                        [Fri Mar  8 11:41:27 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                        [Fri Mar  8 11:42:02 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
                                        Show mounted filesystems:
                                        TARGET                         SOURCE      FSTYPE      OPTIONS
                                        /                              /dev/sda2   ext4        rw,noatime
                                        |-/dev                         devtmpfs    devtmpfs    rw,relatime,size=1800056k,nr_inodes=84157,mode=755
                                        | |-/dev/shm                   tmpfs       tmpfs       rw,nosuid,nodev
                                        | |-/dev/pts                   devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                        | `-/dev/mqueue                mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                                        |-/proc                        proc        proc        rw,relatime
                                        | `-/proc/sys/fs/binfmt_misc   systemd-1   autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                        |   `-/proc/sys/fs/binfmt_misc binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                                        |-/sys                         sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                                        | |-/sys/kernel/security       securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                                        | |-/sys/fs/cgroup             cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                        | |-/sys/fs/bpf                none        bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                                        | |-/sys/kernel/debug          debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                                        | |-/sys/kernel/tracing        tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                                        | |-/sys/fs/fuse/connections   fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                                        | `-/sys/kernel/config         configfs    configfs    rw,nosuid,nodev,noexec,relatime
                                        |-/run                         tmpfs       tmpfs       rw,nosuid,nodev,size=785972k,nr_inodes=819200,mode=755
                                        | |-/run/lock                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                                        | |-/run/credentials/systemd-sysctl.service
                                        | |                            none        ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                        | |-/run/credentials/systemd-sysusers.service
                                        | |-/run/credentials/systemd-tmpfiles-setup-dev.service
                                        | |-/run/rpc_pipefs            sunrpc      rpc_pipefs  rw,relatime
                                        | |-/run/credentials/systemd-tmpfiles-setup.service
                                        | `-/run/user/1000             tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=392984k,nr_inodes=98246,mode=700,uid=1000,gid=1000
                                        |-/snap/certbot/3642           /dev/loop1  squashfs    ro,nodev,relatime
                                        |-/snap/core/16207             /dev/loop2  squashfs    ro,nodev,relatime
                                        |-/snap/certbot/3568           /dev/loop0  squashfs    ro,nodev,relatime
                                        |-/snap/core20/2106            /dev/loop4  squashfs    ro,nodev,relatime
                                        |-/snap/core/16575             /dev/loop3  squashfs    ro,nodev,relatime
                                        |-/snap/core20/2185            /dev/loop5  squashfs    ro,nodev,relatime
                                        `-/boot                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-r
                                        /var:
                                        3.6G	/var/
                                        2.1G	/var/log
                                        1.9G	/var/log/journal/a86ff8ac034a41cc8294fe68053416f8
                                        1.3G	/var/lib
                                        Archived and active journals take up 1.8G in the file system.
                                        /opt/iobroker/backups:
                                        178M	/opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        741M	/opt/iobroker/iobroker-data/
                                        523M	/opt/iobroker/iobroker-data/files
                                        89M	/opt/iobroker/iobroker-data/files/echarts.admin
                                        80M	/opt/iobroker/iobroker-data/backup-objects
                                        57M	/opt/iobroker/iobroker-data/files/javascript.admin
                                        du: cannot access '/opt/iobroker/iobroker-data/files/vis-2/c3ec73ec5450fb4cac984fc867dd54eb.js': No such file or directory
                                        du: cannot access '/opt/iobroker/iobroker-data/files/vis-2/c351437da7e800bc3d9409c431052f9c.js': No such file or directory
                                        109M	/opt/iobroker/iobroker-data/states.jsonl
                                        35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                        31M	/opt/iobroker/iobroker-data/objects.jsonl
                                        24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                        24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                        USB-Devices by-id:
                                        *** NodeJS-Installation ***
                                        /usr/bin/npm 		10.2.4
                                        /usr/bin/npx 		10.2.4
                                        nodejs:
                                          Installed: 18.19.1-1nodesource1
                                          Candidate: 18.19.1-1nodesource1
                                          Version table:
                                         *** 18.19.1-1nodesource1 600
                                                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                                100 /var/lib/dpkg/status
                                             18.19.0+dfsg-6~deb12u1+rpi1 500
                                                500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
                                             18.19.0-1nodesource1 600
                                             18.18.2-1nodesource1 600
                                             18.18.1-1nodesource1 600
                                             18.18.0-1nodesource1 600
                                             18.17.1-1nodesource1 600
                                             18.17.0-1nodesource1 600
                                             18.16.1-1nodesource1 600
                                             18.16.0-1nodesource1 600
                                             18.15.0-1nodesource1 600
                                             18.14.2-1nodesource1 600
                                             18.14.1-1nodesource1 600
                                             18.14.0-1nodesource1 600
                                             18.13.0-1nodesource1 600
                                             18.12.0-1nodesource1 600
                                             18.11.0-1nodesource1 600
                                             18.10.0-1nodesource1 600
                                             18.9.1-1nodesource1 600
                                             18.9.0-1nodesource1 600
                                             18.8.0-1nodesource1 600
                                             18.7.0-1nodesource1 600
                                             18.6.0-1nodesource1 600
                                             18.5.0-1nodesource1 600
                                             18.4.0-1nodesource1 600
                                             18.3.0-1nodesource1 600
                                             18.2.0-1nodesource1 600
                                             18.1.0-1nodesource1 600
                                             18.0.0-1nodesource1 600
                                        No problems detected
                                        Errors in npm tree:
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Core adapters versions
                                        js-controller: 	5.0.19
                                        admin: 		6.15.2
                                        javascript: 	7.8.0
                                        Adapters from github: 	1
                                        Adapter State
                                        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled, compact disabled
                                          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled, compact disabled
                                          system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                                        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled, compact disabled
                                          system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled, compact disabled
                                          system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                                        + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, compact disabled, port: 80
                                          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled, compact disabled
                                          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
                                          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
                                          system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
                                          system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
                                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
                                        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, compact disabled, port: 1884
                                          system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, compact disabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, compact disabled, port: 1884, bind: 0.0.0.0
                                          system.adapter.netatmo-crawler.1        : netatmo-crawler       : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
                                        + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.vesync.0                 : vesync                : raspberrypi                              -  enabled, compact disabled
                                          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
                                        + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled, compact disabled
                                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
                                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled, compact disabled
                                          system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
                                          system.adapter.vis-homekittiles.0       : vis-homekittiles      : raspberrypi                              -  enabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                                          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled, compact disabled
                                          system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
                                          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
                                          system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
                                          system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
                                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                                          system.adapter.vis-owl.0                : vis-owl               : raspberrypi                              -  enabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                                          system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled, compact disabled
                                          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled, compact disabled
                                        + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
                                        + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled, compact disabled
                                        + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                        + instance is alive
                                        ioBroker-Repositories
                                        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                        Installed ioBroker-Instances
                                        Used repository: Beta (latest)
                                        Adapter    "admin"        : 6.15.2   , installed 6.15.2
                                        Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                                        Adapter    "awtrix-light" : 0.15.0   , installed 0.15.0
                                        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                        Adapter    "bring"        : 1.8.4    , installed 1.8.4
                                        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                        Adapter    "device-watcher": 2.10.5  , installed 2.10.5
                                        Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                                        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                        Adapter    "espresense"   : 0.4.4    , installed 0.4.4
                                        Adapter    "hmip"         : 1.22.0   , installed 1.22.0
                                        Adapter    "hue"          : 3.10.2   , installed 3.10.2
                                        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                                        Adapter    "ical"         : 1.14.3   , installed 1.14.3
                                        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                                        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                        Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
                                        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                        Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                                        Adapter    "snmp"         : 3.1.0    , installed 3.1.0
                                        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                                        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                        Adapter    "telegram"     : 3.1.0    , installed 3.1.0
                                        Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                        Adapter    "trashschedule": 3.2.0    , installed 2.3.0  [Updatable]
                                        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                                        Adapter    "vesync"       : 0.0.7    , installed 0.0.7
                                        Adapter    "vis-2"        : 2.9.40   , installed 2.9.40
                                        Adapter    "vis-2-widgets-material": 1.3.25, installed 1.3.25
                                        Adapter    "vis-2-widgets-sweethome3d": 0.1.6, installed 0.1.6
                                        Adapter    "vis-homekittiles": 0.0.9 , installed 0.0.9
                                        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                                        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                        Adapter    "vis-map"      : 1.1.0    , installed 1.1.0
                                        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                                        Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                                        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                                        Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                                        Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                        Adapter    "ws"           : 2.5.11   , installed 2.5.11
                                        Objects and States
                                        Objects: 	21668
                                        States: 	14569
                                        Hit:1 http://linux.teamviewer.com/deb stable InRelease
                                        Hit:2 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
                                        Hit:3 http://archive.raspberrypi.org/debian bookworm InRelease
                                        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Hit:5 https://packages.sury.org/php buster InRelease
                                        Update rpimonitor Packages Status
                                        Reading package lists... Done
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        Netid          State           Recv-Q          Send-Q                                 Local Address:Port                    Peer Address:Port         Process
                                        udp            UNCONN          0               0                                            0.0.0.0:6666                         0.0.0.0:*             users:(("io.tuya.0",pid=1804,fd=37))
                                        udp            UNCONN          0               0                                            0.0.0.0:6667                         0.0.0.0:*             users:(("io.tuya.0",pid=1804,fd=38))
                                        udp            UNCONN          0               0                                            0.0.0.0:5683                         0.0.0.0:*             users:(("io.shelly.0",pid=1704,fd=32))
                                        udp            UNCONN          0               0                                          127.0.0.1:53                           0.0.0.0:*             users:(("connmand",pid=570,fd=11))
                                        udp            UNCONN          0               0                                            0.0.0.0:33903                        0.0.0.0:*             users:(("io.snmp.0",pid=2100,fd=29))
                                        udp            UNCONN          0               0                                            0.0.0.0:631                          0.0.0.0:*             users:(("cups-browsed",pid=1293,fd=7))
                                        udp            UNCONN          0               0                                    192.168.178.255:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=17))
                                        udp            UNCONN          0               0                                     192.168.178.51:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=16))
                                        udp            UNCONN          0               0                                            0.0.0.0:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=14))
                                        udp            UNCONN          0               0                                    192.168.178.255:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=19))
                                        udp            UNCONN          0               0                                     192.168.178.51:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=18))
                                        udp            UNCONN          0               0                                            0.0.0.0:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=15))
                                        udp            UNCONN          0               0                                            0.0.0.0:45212                        0.0.0.0:*             users:(("connmand",pid=570,fd=21))
                                        udp            UNCONN          0               0                                            0.0.0.0:5353                         0.0.0.0:*             users:(("io.wled.0",pid=2673,fd=21))
                                        udp            UNCONN          0               0                                     192.168.178.51:5353                         0.0.0.0:*             users:(("io.tr-064.1",pid=1762,fd=29))
                                        udp            UNCONN          0               0                                     192.168.178.51:5353                         0.0.0.0:*             users:(("io.tr-064.0",pid=1736,fd=30))
                                        udp            UNCONN          0               0                                            0.0.0.0:5353                         0.0.0.0:*             users:(("avahi-daemon",pid=456,fd=12))
                                        udp            UNCONN          0               0                                            0.0.0.0:47932                        0.0.0.0:*             users:(("avahi-daemon",pid=456,fd=14))
                                        udp            UNCONN          0               0                                                  *:50208                              *:*             users:(("avahi-daemon",pid=456,fd=15))
                                        udp            UNCONN          0               0                                                  *:546                                *:*             users:(("connmand",pid=570,fd=18))
                                        udp            UNCONN          23616           0                        [fe80::ac64:680b:efa1:4b03]:546                                *:*             users:(("NetworkManager",pid=569,fd=24))
                                        udp            UNCONN          0               0                                              [::1]:53                                 *:*             users:(("connmand",pid=570,fd=12))
                                        udp            UNCONN          0               0                                                  *:5353                               *:*             users:(("avahi-daemon",pid=456,fd=13))
                                        tcp            LISTEN          0               128                                        127.0.0.1:5939                         0.0.0.0:*             users:(("teamviewerd",pid=1322,fd=12))
                                        tcp            LISTEN          0               4096                                         0.0.0.0:8083                         0.0.0.0:*             users:(("motion",pid=866,fd=5))
                                        tcp            LISTEN          0               10                                      127.0.0.1%lo:53                           0.0.0.0:*             users:(("connmand",pid=570,fd=13))
                                        tcp            LISTEN          0               128                                          0.0.0.0:22                           0.0.0.0:*             users:(("sshd",pid=707,fd=3))
                                        tcp            LISTEN          0               128                                        127.0.0.1:631                          0.0.0.0:*             users:(("cupsd",pid=617,fd=7))
                                        tcp            LISTEN          0               5                                            0.0.0.0:8888                         0.0.0.0:*             users:(("rpimonitord",pid=754,fd=4))
                                        tcp            LISTEN          0               511                                          0.0.0.0:1883                         0.0.0.0:*             users:(("io.sonoff.0",pid=1711,fd=34))
                                        tcp            LISTEN          0               511                                          0.0.0.0:1884                         0.0.0.0:*             users:(("io.mqtt.1",pid=1666,fd=29))
                                        tcp            LISTEN          0               50                                           0.0.0.0:445                          0.0.0.0:*             users:(("smbd",pid=1348,fd=31))
                                        tcp            LISTEN          0               128                                          0.0.0.0:8765                         0.0.0.0:*             users:(("meyectl",pid=470,fd=12))
                                        tcp            LISTEN          0               4096                                         0.0.0.0:7999                         0.0.0.0:*             users:(("motion",pid=866,fd=7))
                                        tcp            LISTEN          0               511                                        127.0.0.1:9000                         0.0.0.0:*             users:(("iobroker.js-con",pid=1306,fd=27))
                                        tcp            LISTEN          0               511                                        127.0.0.1:9001                         0.0.0.0:*             users:(("iobroker.js-con",pid=1306,fd=21))
                                        tcp            LISTEN          0               80                                         127.0.0.1:3306                         0.0.0.0:*             users:(("mariadbd",pid=714,fd=27))
                                        tcp            LISTEN          0               50                                           0.0.0.0:139                          0.0.0.0:*             users:(("smbd",pid=1348,fd=32))
                                        tcp            LISTEN          0               511                                        127.0.0.1:6379                         0.0.0.0:*             users:(("redis-server",pid=620,fd=6))
                                        tcp            LISTEN          0               511                                                *:80                                 *:*             users:(("apache2",pid=799,fd=4),("apache2",pid=797,fd=4),("apache2",pid=796,fd=4),("apache2",pid=795,fd=4),("apache2",pid=794,fd=4),("apache2",pid=793,fd=4),("apache2",pid=739,fd=4))
                                        tcp            LISTEN          0               511                                                *:8081                               *:*             users:(("io.admin.0",pid=1419,fd=29))
                                        tcp            LISTEN          0               511                                                *:8082                               *:*             users:(("io.web.0",pid=2666,fd=29))
                                        tcp            LISTEN          0               511                                                *:8084                               *:*             users:(("io.ws.0",pid=2703,fd=28))
                                        tcp            LISTEN          0               10                                          [::1]%lo:53                              [::]:*             users:(("connmand",pid=570,fd=14))
                                        tcp            LISTEN          0               128                                             [::]:22                              [::]:*             users:(("sshd",pid=707,fd=4))
                                        tcp            LISTEN          0               511                                                *:8087                               *:*             users:(("io.simple-api.0",pid=2067,fd=28))
                                        tcp            LISTEN          0               128                                            [::1]:631                             [::]:*             users:(("cupsd",pid=617,fd=6))
                                        tcp            LISTEN          0               4096                                               *:3000                               *:*             users:(("grafana-server",pid=1295,fd=11))
                                        tcp            LISTEN          0               50                                              [::]:445                             [::]:*             users:(("smbd",pid=1348,fd=29))
                                        tcp            LISTEN          0               511                                            [::1]:6379                            [::]:*             users:(("redis-server",pid=620,fd=7))
                                        tcp            LISTEN          0               50                                              [::]:139                             [::]:*             users:(("smbd",pid=1348,fd=30))
                                        2024-03-08 11:46:19.657  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.humidity_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.humidity_value": Connection is closed.]
                                        2024-03-08 11:46:19.659  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value": Connection is closed.
                                        2024-03-08 11:46:19.660  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value": Connection is closed.]
                                        2024-03-08 11:46:19.662  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value": Connection is closed.
                                        2024-03-08 11:46:19.664  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value": Connection is closed.]
                                        2024-03-08 11:46:19.666  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value": Connection is closed.
                                        2024-03-08 11:46:19.667  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value": Connection is closed.]
                                        2024-03-08 11:46:19.669  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value": Connection is closed.
                                        2024-03-08 11:46:19.671  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value": Connection is closed.]
                                        2024-03-08 11:46:19.673  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value": Connection is closed.
                                        2024-03-08 11:46:19.675  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value": Connection is closed.]
                                        2024-03-08 11:46:19.677  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8": Connection is closed.
                                        2024-03-08 11:46:19.680  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8": Connection is closed.]
                                        2024-03-08 11:46:19.682  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value": Connection is closed.
                                        2024-03-08 11:46:19.684  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value": Connection is closed.]
                                        2024-03-08 11:46:20.212  - error: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                                        2024-03-08 11:46:21.158  - info: tuya.0 (1804) bf047f0676f4973f71uyin: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.59:6668
                                        2024-03-08 11:46:35.239  - info: tuya.0 (1804) bf7e8a579d18ba290elhqa: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.34:6668
                                        2024-03-08 11:46:40.760  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                                        2024-03-08 11:46:40.844  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                                        2024-03-08 11:47:01.160  - error: vesync.0 (2220) {"traceId":"1709894813723","code":-11302030,"msg":"device timeout","module":null,"stacktrace":null,"result":null}
                                        2024-03-08 11:47:42.466  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                                        2024-03-08 11:47:42.960  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                                        2024-03-08 11:48:40.996  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                                        2024-03-08 11:48:41.296  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                                        iob diag has finished.
                                        Press any key for a summary
                                        • Virus2K12
                                          zusammenfassung iob_diag
                                          			v.2023-10-25
                                                 Icon name: computer
                                              Architecture: arm
                                          Kernel: 		armv7l
                                          Userland: 		armhf
                                          User-ID: 		1000
                                          X-Server: 		false
                                          			/usr/bin/npm 		10.2.4
                                          			/usr/bin/npx 		10.2.4
                                          MEMORY:
                                          Mem:            4.0G        2.7G        223M        4.8M        1.3G        1.3G
                                          Swap:           104M          0B        104M
                                          Total:          4.1G        2.7G        328M
                                          			admin 			6.15.2
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects: 		21668
                                          States: 		14569
                                          32M	/opt/iobroker/iobroker-data/objects.jsonl
                                          112M	/opt/iobroker/iobroker-data/states.jsonl
                                            @virus2k12
                                            Hast du das per Dist-Upgrade von einer Vorversion auf 'Debian 12 - Bookworm' gebracht (bzw. es versucht?).
                                            Das funktioniert nicht. Neuinstallation von Null an.
                                            adapter calendar ical kalender müll trash
                                            185
                                            1434
                                            454958
