    4. Test Adapter TrashSchedule
    • Codierknecht
      Codierknecht Developer Most Active @haus-automatisierung last edited by
      Stimmt. Das mache ich halt so selten 😉
      Für Loglevel braucht man den EM trotzdem. Aber eben auch nur sehr selten.
      • Virus2K12
        Virus2K12 @DJMarc75 last edited by
        @djmarc75
        Copy text starting here:
        			v.2023-10-25
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 12 (bookworm)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
        Installation: 		native
        Kernel: 		armv7l
        Userland: 		armhf
        Timezone: 		Europe/Berlin (CET, +0100)
        User-ID: 		1000
        X-Server: 		true
        Boot Target: 		graphical.target
        Pending OS-Updates: 	0
        Pending iob updates: 	1
        Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
        			/usr/bin/node 		v18.19.1
        			/usr/bin/npm 		10.5.0
        			/usr/bin/npx 		10.5.0
        			/usr/bin/corepack 	0.22.0
        Recommended versions are nodejs 18.19.1 and npm 10.2.4
        MEMORY:
        Mem:            4.0G        3.0G        487M         13M        705M        1.0G
        Swap:           104M        104M        4.1K
        Total:          4.1G        3.1G        487M
        Active iob-Instances: 	34
        Active repo(s): Beta (latest)
        ioBroker Core: 		js-controller 		5.0.19
        			admin 			6.15.2
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects: 		21621
        States: 		14503
        Size of iob-Database:
        27M	/opt/iobroker/iobroker-data/objects.jsonl
        115M	/opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
          Thomas Braun Most Active @Virus2K12 last edited by Thomas Braun
          @virus2k12
          Da stimmt was nicht mit npm.
          iob stop
          sudo apt install --reinstall nodejs
          iob restart
          Und dann nochmal die Langfassung von iob diag.
          Finger von npm lassen!
          • Codierknecht
            Codierknecht Developer Most Active @Thomas Braun last edited by
            @Virus2K12
            ... und den Desktop ausschalten.
              Thomas Braun Most Active @Codierknecht last edited by
              @codierknecht sagte in Test Adapter TrashSchedule:
              @Virus2K12
              Oh, ganz übersehen. Natürlich.
              Und auch mal prüfen, ob die Hardware nicht 64Bit verträgt.
              • Virus2K12
                Desktop aus und reinstall nodejs gemacht.
                Hier jetzt erst einmal die lange Fassung von iob diag
                Skript v.2023-10-25
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm
                Model		: Raspberry Pi 4 Model B Rev 1.1
                Docker          : false
                Virtualization  : none
                Kernel          : armv7l
                Userland        : armhf
                Systemuptime and Load:
                 11:46:10 up 4 min,  1 user,  load average: 4.35, 2.76, 1.17
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Fri 2024-03-08 11:46:10 CET
                           Universal time: Fri 2024-03-08 10:46:10 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server: 	false
                Desktop:
                Terminal: 	tty
                Boot Target: 	multi-user.target
                *** MEMORY ***
                Mem:            4.0G        2.4G        670M        4.8M        1.1G        1.6G
                Swap:           104M          0B        104M
                Total:          4.1G        2.4G        775M
                         3837 M total memory
                         2303 M used memory
                          235 M active memory
                         2842 M inactive memory
                          638 M free memory
                          244 M buffer memory
                          788 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FAILED SERVICES ***
                  UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
                LOAD   = Reflects whether the unit definition was properly loaded.
                ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                SUB    = The low-level unit activation state, values depend on unit type.
                1 loaded units listed.
                *** FILESYSTEM ***
                /dev/root      ext4      219G   24G  185G  12% /
                devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
                tmpfs          tmpfs     768M  2.1M  766M   1% /run
                tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                /dev/loop1     squashfs   43M   43M     0 100% /snap/certbot/3642
                /dev/loop2     squashfs   91M   91M     0 100% /snap/core/16207
                /dev/loop0     squashfs   42M   42M     0 100% /snap/certbot/3568
                /dev/loop4     squashfs   54M   54M     0 100% /snap/core20/2106
                /dev/loop3     squashfs   91M   91M     0 100% /snap/core/16575
                /dev/loop5     squashfs   54M   54M     0 100% /snap/core20/2185
                /dev/sda1      vfat      253M   93M  160M  37% /boot
                tmpfs          tmpfs     384M   80K  384M   1% /run/user/1000
                [Fri Mar  8 11:41:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=DC:A6:32:4F:AC:15 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=048e52a3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles fsck.mode=force cfg80211.ieee80211_regdom=DE
                [Fri Mar  8 11:41:27 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                [Fri Mar  8 11:41:27 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                [Fri Mar  8 11:42:02 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
                Show mounted filesystems:
                TARGET                         SOURCE      FSTYPE      OPTIONS
                /                              /dev/sda2   ext4        rw,noatime
                |-/dev                         devtmpfs    devtmpfs    rw,relatime,size=1800056k,nr_inodes=84157,mode=755
                | |-/dev/shm                   tmpfs       tmpfs       rw,nosuid,nodev
                | |-/dev/pts                   devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                | `-/dev/mqueue                mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                |-/proc                        proc        proc        rw,relatime
                | `-/proc/sys/fs/binfmt_misc   systemd-1   autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                |   `-/proc/sys/fs/binfmt_misc binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                |-/sys                         sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/security       securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/cgroup             cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                | |-/sys/fs/bpf                none        bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                | |-/sys/kernel/debug          debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/tracing        tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/fuse/connections   fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                | `-/sys/kernel/config         configfs    configfs    rw,nosuid,nodev,noexec,relatime
                |-/run                         tmpfs       tmpfs       rw,nosuid,nodev,size=785972k,nr_inodes=819200,mode=755
                | |-/run/lock                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                | |-/run/credentials/systemd-sysctl.service
                | |                            none        ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                | |-/run/credentials/systemd-sysusers.service
                | |-/run/credentials/systemd-tmpfiles-setup-dev.service
                | |-/run/rpc_pipefs            sunrpc      rpc_pipefs  rw,relatime
                | |-/run/credentials/systemd-tmpfiles-setup.service
                | `-/run/user/1000             tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=392984k,nr_inodes=98246,mode=700,uid=1000,gid=1000
                |-/snap/certbot/3642           /dev/loop1  squashfs    ro,nodev,relatime
                |-/snap/core/16207             /dev/loop2  squashfs    ro,nodev,relatime
                |-/snap/certbot/3568           /dev/loop0  squashfs    ro,nodev,relatime
                |-/snap/core20/2106            /dev/loop4  squashfs    ro,nodev,relatime
                |-/snap/core/16575             /dev/loop3  squashfs    ro,nodev,relatime
                |-/snap/core20/2185            /dev/loop5  squashfs    ro,nodev,relatime
                `-/boot                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-r
                /var:
                3.6G	/var/
                2.1G	/var/log
                1.9G	/var/log/journal/a86ff8ac034a41cc8294fe68053416f8
                1.3G	/var/lib
                Archived and active journals take up 1.8G in the file system.
                /opt/iobroker/backups:
                178M	/opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                741M	/opt/iobroker/iobroker-data/
                523M	/opt/iobroker/iobroker-data/files
                89M	/opt/iobroker/iobroker-data/files/echarts.admin
                80M	/opt/iobroker/iobroker-data/backup-objects
                57M	/opt/iobroker/iobroker-data/files/javascript.admin
                du: cannot access '/opt/iobroker/iobroker-data/files/vis-2/c3ec73ec5450fb4cac984fc867dd54eb.js': No such file or directory
                du: cannot access '/opt/iobroker/iobroker-data/files/vis-2/c351437da7e800bc3d9409c431052f9c.js': No such file or directory
                109M	/opt/iobroker/iobroker-data/states.jsonl
                35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                31M	/opt/iobroker/iobroker-data/objects.jsonl
                24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                USB-Devices by-id:
                *** NodeJS-Installation ***
                /usr/bin/npm 		10.2.4
                /usr/bin/npx 		10.2.4
                nodejs:
                  Installed: 18.19.1-1nodesource1
                  Candidate: 18.19.1-1nodesource1
                  Version table:
                 *** 18.19.1-1nodesource1 600
                        500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                        100 /var/lib/dpkg/status
                     18.19.0+dfsg-6~deb12u1+rpi1 500
                        500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
                     18.19.0-1nodesource1 600
                     18.18.2-1nodesource1 600
                     18.18.1-1nodesource1 600
                     18.18.0-1nodesource1 600
                     18.17.1-1nodesource1 600
                     18.17.0-1nodesource1 600
                     18.16.1-1nodesource1 600
                     18.16.0-1nodesource1 600
                     18.15.0-1nodesource1 600
                     18.14.2-1nodesource1 600
                     18.14.1-1nodesource1 600
                     18.14.0-1nodesource1 600
                     18.13.0-1nodesource1 600
                     18.12.0-1nodesource1 600
                     18.11.0-1nodesource1 600
                     18.10.0-1nodesource1 600
                     18.9.1-1nodesource1 600
                     18.9.0-1nodesource1 600
                     18.8.0-1nodesource1 600
                     18.7.0-1nodesource1 600
                     18.6.0-1nodesource1 600
                     18.5.0-1nodesource1 600
                     18.4.0-1nodesource1 600
                     18.3.0-1nodesource1 600
                     18.2.0-1nodesource1 600
                     18.1.0-1nodesource1 600
                     18.0.0-1nodesource1 600
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller: 	5.0.19
                admin: 		6.15.2
                javascript: 	7.8.0
                Adapters from github: 	1
                Adapter State
                + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled, compact disabled
                + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled, compact disabled
                + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact disabled
                + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled, compact disabled
                  system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled, compact disabled
                + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled, compact disabled
                  system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled, compact disabled
                  system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled, compact disabled
                + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled, compact disabled
                  system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact disabled
                + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled, compact disabled
                + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled, compact disabled
                + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, compact disabled, port: 80
                  system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled, compact disabled
                  system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
                  system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
                  system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
                  system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
                + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled, compact disabled
                + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
                + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, compact disabled, port: 1884
                  system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, compact disabled, port: 1883, bind: 0.0.0.0
                + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, compact disabled, port: 1884, bind: 0.0.0.0
                  system.adapter.netatmo-crawler.1        : netatmo-crawler       : raspberrypi                              -  enabled, compact disabled
                + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
                + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
                + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled, compact disabled
                + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
                + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
                + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled, compact disabled
                + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled, compact disabled
                + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled, compact disabled
                + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled, compact disabled
                + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled, compact disabled
                + system.adapter.vesync.0                 : vesync                : raspberrypi                              -  enabled, compact disabled
                  system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
                + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled, compact disabled
                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
                  system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled, compact disabled
                  system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
                  system.adapter.vis-homekittiles.0       : vis-homekittiles      : raspberrypi                              -  enabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled, compact disabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled, compact disabled
                  system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
                  system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
                  system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
                  system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                  system.adapter.vis-owl.0                : vis-owl               : raspberrypi                              -  enabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                  system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled, compact disabled
                  system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled, compact disabled
                + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
                + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled, compact disabled
                + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin
                + instance is alive
                ioBroker-Repositories
                Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                Installed ioBroker-Instances
                Used repository: Beta (latest)
                Adapter    "admin"        : 6.15.2   , installed 6.15.2
                Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                Adapter    "awtrix-light" : 0.15.0   , installed 0.15.0
                Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                Adapter    "bring"        : 1.8.4    , installed 1.8.4
                Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                Adapter    "device-watcher": 2.10.5  , installed 2.10.5
                Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                Adapter    "espresense"   : 0.4.4    , installed 0.4.4
                Adapter    "hmip"         : 1.22.0   , installed 1.22.0
                Adapter    "hue"          : 3.10.2   , installed 3.10.2
                Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                Adapter    "ical"         : 1.14.3   , installed 1.14.3
                Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
                Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                Adapter    "snmp"         : 3.1.0    , installed 3.1.0
                Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                Adapter    "telegram"     : 3.1.0    , installed 3.1.0
                Adapter    "text2command" : 3.0.3    , installed 3.0.3
                Adapter    "trashschedule": 3.2.0    , installed 2.3.0  [Updatable]
                Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                Adapter    "vesync"       : 0.0.7    , installed 0.0.7
                Adapter    "vis-2"        : 2.9.40   , installed 2.9.40
                Adapter    "vis-2-widgets-material": 1.3.25, installed 1.3.25
                Adapter    "vis-2-widgets-sweethome3d": 0.1.6, installed 0.1.6
                Adapter    "vis-homekittiles": 0.0.9 , installed 0.0.9
                Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                Adapter    "vis-map"      : 1.1.0    , installed 1.1.0
                Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                Adapter    "wled"         : 0.7.2    , installed 0.7.2
                Adapter    "ws"           : 2.5.11   , installed 2.5.11
                Objects and States
                Objects: 	21668
                States: 	14569
                Hit:1 http://linux.teamviewer.com/deb stable InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
                Hit:3 http://archive.raspberrypi.org/debian bookworm InRelease
                Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                Hit:5 https://packages.sury.org/php buster InRelease
                Update rpimonitor Packages Status
                Reading package lists... Done
                Pending Updates: 0
                *** Listening Ports ***
                Netid          State           Recv-Q          Send-Q                                 Local Address:Port                    Peer Address:Port         Process
                udp            UNCONN          0               0                                            0.0.0.0:6666                         0.0.0.0:*             users:(("io.tuya.0",pid=1804,fd=37))
                udp            UNCONN          0               0                                            0.0.0.0:6667                         0.0.0.0:*             users:(("io.tuya.0",pid=1804,fd=38))
                udp            UNCONN          0               0                                            0.0.0.0:5683                         0.0.0.0:*             users:(("io.shelly.0",pid=1704,fd=32))
                udp            UNCONN          0               0                                          127.0.0.1:53                           0.0.0.0:*             users:(("connmand",pid=570,fd=11))
                udp            UNCONN          0               0                                            0.0.0.0:33903                        0.0.0.0:*             users:(("io.snmp.0",pid=2100,fd=29))
                udp            UNCONN          0               0                                            0.0.0.0:631                          0.0.0.0:*             users:(("cups-browsed",pid=1293,fd=7))
                udp            UNCONN          0               0                                    192.168.178.255:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=17))
                udp            UNCONN          0               0                                     192.168.178.51:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=16))
                udp            UNCONN          0               0                                            0.0.0.0:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=14))
                udp            UNCONN          0               0                                    192.168.178.255:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=19))
                udp            UNCONN          0               0                                     192.168.178.51:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=18))
                udp            UNCONN          0               0                                            0.0.0.0:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=15))
                udp            UNCONN          0               0                                            0.0.0.0:45212                        0.0.0.0:*             users:(("connmand",pid=570,fd=21))
                udp            UNCONN          0               0                                            0.0.0.0:5353                         0.0.0.0:*             users:(("io.wled.0",pid=2673,fd=21))
                udp            UNCONN          0               0                                     192.168.178.51:5353                         0.0.0.0:*             users:(("io.tr-064.1",pid=1762,fd=29))
                udp            UNCONN          0               0                                     192.168.178.51:5353                         0.0.0.0:*             users:(("io.tr-064.0",pid=1736,fd=30))
                udp            UNCONN          0               0                                            0.0.0.0:5353                         0.0.0.0:*             users:(("avahi-daemon",pid=456,fd=12))
                udp            UNCONN          0               0                                            0.0.0.0:47932                        0.0.0.0:*             users:(("avahi-daemon",pid=456,fd=14))
                udp            UNCONN          0               0                                                  *:50208                              *:*             users:(("avahi-daemon",pid=456,fd=15))
                udp            UNCONN          0               0                                                  *:546                                *:*             users:(("connmand",pid=570,fd=18))
                udp            UNCONN          23616           0                        [fe80::ac64:680b:efa1:4b03]:546                                *:*             users:(("NetworkManager",pid=569,fd=24))
                udp            UNCONN          0               0                                              [::1]:53                                 *:*             users:(("connmand",pid=570,fd=12))
                udp            UNCONN          0               0                                                  *:5353                               *:*             users:(("avahi-daemon",pid=456,fd=13))
                tcp            LISTEN          0               128                                        127.0.0.1:5939                         0.0.0.0:*             users:(("teamviewerd",pid=1322,fd=12))
                tcp            LISTEN          0               4096                                         0.0.0.0:8083                         0.0.0.0:*             users:(("motion",pid=866,fd=5))
                tcp            LISTEN          0               10                                      127.0.0.1%lo:53                           0.0.0.0:*             users:(("connmand",pid=570,fd=13))
                tcp            LISTEN          0               128                                          0.0.0.0:22                           0.0.0.0:*             users:(("sshd",pid=707,fd=3))
                tcp            LISTEN          0               128                                        127.0.0.1:631                          0.0.0.0:*             users:(("cupsd",pid=617,fd=7))
                tcp            LISTEN          0               5                                            0.0.0.0:8888                         0.0.0.0:*             users:(("rpimonitord",pid=754,fd=4))
                tcp            LISTEN          0               511                                          0.0.0.0:1883                         0.0.0.0:*             users:(("io.sonoff.0",pid=1711,fd=34))
                tcp            LISTEN          0               511                                          0.0.0.0:1884                         0.0.0.0:*             users:(("io.mqtt.1",pid=1666,fd=29))
                tcp            LISTEN          0               50                                           0.0.0.0:445                          0.0.0.0:*             users:(("smbd",pid=1348,fd=31))
                tcp            LISTEN          0               128                                          0.0.0.0:8765                         0.0.0.0:*             users:(("meyectl",pid=470,fd=12))
                tcp            LISTEN          0               4096                                         0.0.0.0:7999                         0.0.0.0:*             users:(("motion",pid=866,fd=7))
                tcp            LISTEN          0               511                                        127.0.0.1:9000                         0.0.0.0:*             users:(("iobroker.js-con",pid=1306,fd=27))
                tcp            LISTEN          0               511                                        127.0.0.1:9001                         0.0.0.0:*             users:(("iobroker.js-con",pid=1306,fd=21))
                tcp            LISTEN          0               80                                         127.0.0.1:3306                         0.0.0.0:*             users:(("mariadbd",pid=714,fd=27))
                tcp            LISTEN          0               50                                           0.0.0.0:139                          0.0.0.0:*             users:(("smbd",pid=1348,fd=32))
                tcp            LISTEN          0               511                                        127.0.0.1:6379                         0.0.0.0:*             users:(("redis-server",pid=620,fd=6))
                tcp            LISTEN          0               511                                                *:80                                 *:*             users:(("apache2",pid=799,fd=4),("apache2",pid=797,fd=4),("apache2",pid=796,fd=4),("apache2",pid=795,fd=4),("apache2",pid=794,fd=4),("apache2",pid=793,fd=4),("apache2",pid=739,fd=4))
                tcp            LISTEN          0               511                                                *:8081                               *:*             users:(("io.admin.0",pid=1419,fd=29))
                tcp            LISTEN          0               511                                                *:8082                               *:*             users:(("io.web.0",pid=2666,fd=29))
                tcp            LISTEN          0               511                                                *:8084                               *:*             users:(("io.ws.0",pid=2703,fd=28))
                tcp            LISTEN          0               10                                          [::1]%lo:53                              [::]:*             users:(("connmand",pid=570,fd=14))
                tcp            LISTEN          0               128                                             [::]:22                              [::]:*             users:(("sshd",pid=707,fd=4))
                tcp            LISTEN          0               511                                                *:8087                               *:*             users:(("io.simple-api.0",pid=2067,fd=28))
                tcp            LISTEN          0               128                                            [::1]:631                             [::]:*             users:(("cupsd",pid=617,fd=6))
                tcp            LISTEN          0               4096                                               *:3000                               *:*             users:(("grafana-server",pid=1295,fd=11))
                tcp            LISTEN          0               50                                              [::]:445                             [::]:*             users:(("smbd",pid=1348,fd=29))
                tcp            LISTEN          0               511                                            [::1]:6379                            [::]:*             users:(("redis-server",pid=620,fd=7))
                tcp            LISTEN          0               50                                              [::]:139                             [::]:*             users:(("smbd",pid=1348,fd=30))
                2024-03-08 11:46:19.657  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.humidity_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.humidity_value": Connection is closed.]
                2024-03-08 11:46:19.659  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value": Connection is closed.
                2024-03-08 11:46:19.660  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value": Connection is closed.]
                2024-03-08 11:46:19.662  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value": Connection is closed.
                2024-03-08 11:46:19.664  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value": Connection is closed.]
                2024-03-08 11:46:19.666  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value": Connection is closed.
                2024-03-08 11:46:19.667  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value": Connection is closed.]
                2024-03-08 11:46:19.669  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value": Connection is closed.
                2024-03-08 11:46:19.671  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value": Connection is closed.]
                2024-03-08 11:46:19.673  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value": Connection is closed.
                2024-03-08 11:46:19.675  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value": Connection is closed.]
                2024-03-08 11:46:19.677  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8": Connection is closed.
                2024-03-08 11:46:19.680  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8": Connection is closed.]
                2024-03-08 11:46:19.682  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value": Connection is closed.
                2024-03-08 11:46:19.684  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value": Connection is closed.]
                2024-03-08 11:46:20.212  - error: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                2024-03-08 11:46:21.158  - info: tuya.0 (1804) bf047f0676f4973f71uyin: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.59:6668
                2024-03-08 11:46:35.239  - info: tuya.0 (1804) bf7e8a579d18ba290elhqa: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.34:6668
                2024-03-08 11:46:40.760  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                2024-03-08 11:46:40.844  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                2024-03-08 11:47:01.160  - error: vesync.0 (2220) {"traceId":"1709894813723","code":-11302030,"msg":"device timeout","module":null,"stacktrace":null,"result":null}
                2024-03-08 11:47:42.466  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                2024-03-08 11:47:42.960  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                2024-03-08 11:48:40.996  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                2024-03-08 11:48:41.296  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                iob diag has finished.
                Press any key for a summary
                • Virus2K12
                  zusammenfassung iob_diag
                  			v.2023-10-25
                         Icon name: computer
                      Architecture: arm
                  Kernel: 		armv7l
                  Userland: 		armhf
                  User-ID: 		1000
                  X-Server: 		false
                  			/usr/bin/npm 		10.2.4
                  			/usr/bin/npx 		10.2.4
                  MEMORY:
                  Mem:            4.0G        2.7G        223M        4.8M        1.3G        1.3G
                  Swap:           104M          0B        104M
                  Total:          4.1G        2.7G        328M
                  			admin 			6.15.2
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		21668
                  States: 		14569
                  32M	/opt/iobroker/iobroker-data/objects.jsonl
                  112M	/opt/iobroker/iobroker-data/states.jsonl
                    @virus2k12
                    Hast du das per Dist-Upgrade von einer Vorversion auf 'Debian 12 - Bookworm' gebracht (bzw. es versucht?).
                    Das funktioniert nicht. Neuinstallation von Null an.
                    Virus2K12 1 Reply Last reply Reply Quote 0
                    • Virus2K12
                      Virus2K12 @Thomas Braun last edited by Virus2K12
                      @thomas-braun ja, von bullseye auf bookworm, aber schon vor ewigkeiten. Lief auch die ganze Zeit ohne Probleme.
                      Zuletzt habe ich eine smb Freigabe für verschieden Verzeichnisse gemacht, kann es daran liegen zwecks Zugriffsrechte etc. ?
                        @virus2k12
                        Aber nicht richtig.
                        Der Kernel ist z. B. noch aus Bullseye-Zeiten.
                        • Virus2K12
                          Problem gelöst. Node, npm und iob deinstalliert, Kernelupdate gemacht, node, npm und iob neu installiert und alles läuft.
                            @virus2k12
                            Du hockst aber immer noch auf einer 32Bit-Version.
                            • Virus2K12
                              @thomas-braun ja, kann ich das einfach von 32 auf 64 updaten?
                              da_Woody Thomas Braun 2 Replies Last reply Reply Quote 0
                              • da_Woody
                                da_Woody @Virus2K12 last edited by
                                @virus2k12 ja, wie schon der Vorschlag war. Neu installieren.
                                  @virus2k12 sagte in Test Adapter TrashSchedule:
                                  Nein. Wie bereits oben gesagt: Komplette NEUINSTALLATION ist erforderlich.
                                  • Virus2K12
                                    Virus2K12 @da_Woody last edited by
                                    @da_woody nee ich hab weder Zeit noch Lust alles neu aufzusetzen.
                                    • Virus2K12
                                      @thomas-braun nee, dann bleibt es so wie es ist.
                                        @virus2k12
                                        Dann viel Spaß in Zukunft. Das wird dir früher oder später wegkippen.
                                        Virus2K12 1 Reply Last reply Reply Quote 2
                                          Siggi0904 last edited by
                                          Ich hatte seit dem letzten Stable Update vergessen zu fragen,
                                          wie funktioniert denn das mit den Datenpunkten "Tätigwerden" und "erledigt"?
                                          Schreibt er das in den Kalender zurück?
                                          Was machen diese beiden neuen Datenpunkte?
                                          • Virus2K12
                                            @thomas-braun sagte in Test Adapter TrashSchedule:
                                            @virus2k12
                                            wenn es dann mal Not ist werde ich es neu aufsetzen, im Moment fehlt mir die Zeit da. Wird eher was für den Winter
                                            adapter calendar ical kalender müll trash
                                            184
                                            1432
                                            427303
