    3. Einsteigerfragen
    4. [gelöst] frische IOB Installation - WebGUI nicht erreichbar
      Thomas Braun Most Active @Fierce last edited by
      @fierce
      sudo systemctl set-default multi-user.target
      Und was versprichst du dir von dem Kernel?
        Fierce @Thomas Braun last edited by Fierce
        @thomas-braun said in frische IOB Installation - WebGUI nicht erreichbar:
        @fierce
        Gib mal die Langfassung vom 'iob diag' zum Besten.
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: Fierce-Server
               Icon name: computer-desktop
                 Chassis: desktop 🖥️
                  Kernel: Linux 6.7.7-x64v4-xanmod1
            Architecture: x86-64
         Hardware Vendor: Intel_R_ Client Systems
          Hardware Model: NUC11PAHi5
        Firmware Version: PATGL357.0047.2022.0627.1120
        model name      : 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         19:34:26 up 20:31,  2 users,  load average: 2.21, 2.38, 2.46
        CPU threads: 8
        *** Time and Time Zones ***
                       Local time: Wed 2024-03-06 19:34:26 CET
                   Universal time: Wed 2024-03-06 18:34:26 UTC
                         RTC time: Wed 2024-03-06 18:34:26
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        fierce
        /home/fierce
        fierce cdrom floppy sudo audio dip video plugdev users netdev iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:             33G        1.0G         30G        1.8M        1.7G         32G
        Swap:           1.0G          0B        1.0G
        Total:           34G        1.0G         32G
                31752 M total memory
                  995 M used memory
                  527 M active memory
                 1272 M inactive memory
                29560 M free memory
                  275 M buffer memory
                 1352 M swap cache
                  976 M total swap
                    0 M used swap
                  976 M free swap
        *** FAILED SERVICES ***
          UNIT           LOAD   ACTIVE SUB    DESCRIPTION
        * mnt-plex.mount loaded failed failed /mnt/plex
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs   16G     0   16G   0% /dev
        tmpfs          tmpfs     3.2G  1.2M  3.1G   1% /run
        /dev/nvme0n1p2 ext4      937G   11G  879G   2% /
        tmpfs          tmpfs      16G  4.0K   16G   1% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        efivarfs       efivarfs  192K  111K   77K  59% /sys/firmware/efi/efivars
        /dev/nvme0n1p1 vfat      511M  5.9M  506M   2% /boot/efi
        tmpfs          tmpfs     3.2G     0  3.2G   0% /run/user/1000
        TARGET      SOURCE         FSTYPE OPTIONS
        /           /dev/nvme0n1p2 ext4   rw,relatime,errors=remount-ro
        `-/boot/efi /dev/nvme0n1p1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
        /var:
        6.4G    /var/
        4.7G    /var/lib
        4.5G    /var/lib/plexmediaserver/Library/Application Support/Plex Media Server
        Archived and active journals take up 30.8M in the file system.
        /opt/iobroker/backups:
        2.9M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        111M    /opt/iobroker/iobroker-data/
        71M     /opt/iobroker/iobroker-data/files
        57M     /opt/iobroker/iobroker-data/files/javascript.admin
        38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        37M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        8.5M    /opt/iobroker/iobroker-data/objects.jsonl
        7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        6.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/344.2eef1017.chunk.js.map
        4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.1-1nodesource1
          Version table:
             18.19.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
         *** 18.19.0-1nodesource1 1001
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
                500 http://ftp.de.debian.org/debian bookworm/main amd64 Packages
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.13.16
        javascript:     7.8.0
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : Fierce-Server                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : Fierce-Server                            -  enabled
        + system.adapter.discovery.0              : discovery             : Fierce-Server                            -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Objects and States
        Objects:        147
        States:         105
        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:2 https://downloads.plex.tv/repo/deb public InRelease
        Hit:3 http://ftp.de.debian.org/debian bookworm InRelease
        Hit:4 http://ftp.de.debian.org/debian bookworm-updates InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:6 http://deb.xanmod.org releases InRelease
        Reading package lists...
        Pending Updates: 1
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37714      20404/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       40620      20404/iobroker.js-c
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5228       1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4495       622/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      104        10743      599/mosquitto
        tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      999        4524       756/Plex Tuner Serv
        tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      999        7568       581/Plex Media Serv
        tcp        0      0 0.0.0.0:8883            0.0.0.0:*               LISTEN      104        10748      599/mosquitto
        tcp        0      0 127.0.0.1:37419         0.0.0.0:*               LISTEN      999        9653       703/Plex Plug-in [c
        tcp6       0      0 :::111                  :::*                    LISTEN      0          2094       1/init
        tcp6       0      0 :::80                   :::*                    LISTEN      0          7547       623/apache2
        tcp6       0      0 :::22                   :::*                    LISTEN      0          4497       622/sshd: /usr/sbin
        tcp6       0      0 :::1883                 :::*                    LISTEN      104        10744      599/mosquitto
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       40656      20423/io.admin.0
        tcp6       0      0 :::8883                 :::*                    LISTEN      104        10749      599/mosquitto
        tcp6       0      0 :::32400                :::*                    LISTEN      999        7566       581/Plex Media Serv
        udp        0      0 192.168.178.64:44371    0.0.0.0:*                           999        7622       581/Plex Media Serv
        udp        0      0 192.168.178.64:47242    0.0.0.0:*                           999        7626       581/Plex Media Serv
        udp        0      0 0.0.0.0:32410           0.0.0.0:*                           999        8523       581/Plex Media Serv
        udp        0      0 0.0.0.0:32412           0.0.0.0:*                           999        8524       581/Plex Media Serv
        udp        0      0 0.0.0.0:32413           0.0.0.0:*                           999        7620       581/Plex Media Serv
        udp        0      0 0.0.0.0:32414           0.0.0.0:*                           999        8522       581/Plex Media Serv
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2585       573/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5229       1/init
        udp        0      0 127.0.0.1:49402         0.0.0.0:*                           999        7621       581/Plex Media Serv
        udp        0      0 0.0.0.0:1901            0.0.0.0:*                           999        7625       581/Plex Media Serv
        udp        0      0 127.0.0.1:54911         0.0.0.0:*                           999        7623       581/Plex Media Serv
        udp        0      0 192.168.178.64:39558    0.0.0.0:*                           999        7624       581/Plex Media Serv
        udp6       0      0 :::111                  :::*                                0          8221       1/init
        2024-03-06 19:30:30.431  - info: host.Fierce-Server 3 instances found
        2024-03-06 19:30:30.433  - info: host.Fierce-Server starting 3 instances
        2024-03-06 19:30:30.482  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeNewest"
        2024-03-06 19:30:30.486  - info: host.Fierce-Server instance system.adapter.admin.0 started with pid 20423
        2024-03-06 19:30:30.527  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeNewestNext"
        2024-03-06 19:30:30.528  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmCurrent"
        2024-03-06 19:30:30.529  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmNewest"
        2024-03-06 19:30:30.530  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmNewestNext"
        2024-03-06 19:30:30.530  - info: host.Fierce-Server Some obsolete host states deleted.
        2024-03-06 19:30:30.870  - info: admin.0 (20423) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.19
        2024-03-06 19:30:30.877  - info: admin.0 (20423) requesting all objects
        2024-03-06 19:30:30.983  - info: admin.0 (20423) received all objects
        2024-03-06 19:30:31.042  - info: admin.0 (20423) socket.io server listening on port 8081
        2024-03-06 19:30:31.043  - info: admin.0 (20423) http server listening on port 8081
        2024-03-06 19:30:31.043  - info: admin.0 (20423) Use link "http://127.0.0.1:8081" to configure.
        2024-03-06 19:30:32.312  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
        2024-03-06 19:30:32.313  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
        2024-03-06 19:30:32.313  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.0
        2024-03-06 19:30:32.314  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
        2024-03-06 19:30:34.377  - error: host.Fierce-Server-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
        2024-03-06 19:30:34.439  - info: host.Fierce-Server instance system.adapter.backitup.0 started with pid 20450
        2024-03-06 19:30:34.755  - info: backitup.0 (20450) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.19
        2024-03-06 19:30:34.766  - info: backitup.0 (20450) [iobroker] backup will be activated at 02:48 every 1 day(s)
        2024-03-06 19:30:38.438  - info: host.Fierce-Server instance system.adapter.discovery.0 started with pid 20477
        2024-03-06 19:30:38.783  - info: discovery.0 (20477) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.19
        @fierce
        Der Kernel ist Empfehlung aus der Plex Comunity. Soll fürs Medienstreaming Vorteile habe 🤷‍♂️
        fierce@Fierce-Server:~$ sudo systemctl set-default multi-user.target
        Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
        Fehler im Log-File bleibt bestehen und WebGUI weiterhin nicht aufrufbar...
        fierce@Fierce-Server:/opt/iobroker$ iob restart
        fierce@Fierce-Server:/opt/iobroker$ node node_modules/iobroker.js-controller/controller.js --logs
          @fierce
          sudo usermod -a -G adm fierce
          sudo apt update
          iob stop
          sudo apt full-upgrade
          fierce einmal aus und wieder einloggen.
          Ansonsten schaut das eigentlich okay aus.
            fierce@Fierce-Server:/opt/iobroker$ sudo usermod -a -G adm fierce
            [sudo] Passwort für fierce:
            fierce@Fierce-Server:/opt/iobroker$ sudo apt update
            OK:1 http://security.debian.org/debian-security bookworm-security InRelease
            OK:2 https://downloads.plex.tv/repo/deb public InRelease
            OK:3 http://ftp.de.debian.org/debian bookworm InRelease
            OK:4 http://ftp.de.debian.org/debian bookworm-updates InRelease
            OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
            OK:6 http://deb.xanmod.org releases InRelease
            Paketlisten werden gelesen… Fertig
            Abhängigkeitsbaum wird aufgebaut… Fertig
            Statusinformationen werden eingelesen… Fertig
            Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
            fierce@Fierce-Server:/opt/iobroker$ iob stop
            fierce@Fierce-Server:/opt/iobroker$ sudo apt full-upgrade
            Paketaktualisierung (Upgrade) wird berechnet… Fertig
            Die folgenden Pakete werden aktualisiert (Upgrade):
              nodejs
            1 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
            Es müssen noch 0 B von 29,8 MB an Archiven heruntergeladen werden.
            Nach dieser Operation werden 54,3 kB Plattenplatz zusätzlich benutzt.
            Möchten Sie fortfahren? [J/n] j
            Changelogs werden gelesen... Fertig
            (Lese Datenbank ... 109430 Dateien und Verzeichnisse sind derzeit installiert.)
            Vorbereitung zum Entpacken von .../nodejs_18.19.1-1nodesource1_amd64.deb ...
            Detected old npm client, removing...
            Entpacken von nodejs (18.19.1-1nodesource1) über (18.19.0-1nodesource1) ...
            nodejs (18.19.1-1nodesource1) wird eingerichtet ...
            Trigger für man-db (2.11.2-2) werden verarbeitet ...
            fierce@Fierce-Server:/opt/iobroker$ sudo systemctl reboot
            Leider immernoch das gleiche Fehlerbild. Die WebGUI ist einfach nicht aufrufbar...
              Fierce @Fierce last edited by Fierce
              Noch irgendjemand eine Idee wo man schauen oder was man prüfen könnte ? Den einzigen Fehler den ich gefunden habe ist der folgende aber ich kann nicht einschätzen ob der wirklich dafür verantwortlich ist das die WebGUI nicht aufrufbar ist...
              2024-03-07 21:53:02.596  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
              2024-03-07 21:53:02.598  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
              2024-03-07 21:53:02.598  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.1
              2024-03-07 21:53:02.598  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
              2024-03-07 21:53:04.661  - error: host.Fierce-Server-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
              scheinbar wird aber auf den Ports gelauscht
              fierce@Fierce-Server:~$ sudo netstat -tulnp
              Aktive Internetverbindungen (Nur Server)
              Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      596/mosquitto
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      604/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      1/init
              tcp        0      0 127.0.0.1:39819         0.0.0.0:*               LISTEN      703/Plex Plug-in [c
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      555/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      555/iobroker.js-con
              tcp        0      0 0.0.0.0:8883            0.0.0.0:*               LISTEN      596/mosquitto
              tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      760/Plex Tuner Serv
              tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      576/Plex Media Serv
              tcp6       0      0 :::1883                 :::*                    LISTEN      596/mosquitto
              tcp6       0      0 :::22                   :::*                    LISTEN      604/sshd: /usr/sbin
              tcp6       0      0 :::80                   :::*                    LISTEN      623/apache2
              tcp6       0      0 :::111                  :::*                    LISTEN      1/init
              tcp6       0      0 :::8081                 :::*                    LISTEN      731/io.admin.0
              tcp6       0      0 :::8883                 :::*                    LISTEN      596/mosquitto
              tcp6       0      0 :::32400                :::*                    LISTEN      576/Plex Media Serv
              udp        0      0 192.168.178.64:43086    0.0.0.0:*                           576/Plex Media Serv
              udp        0      0 0.0.0.0:32410           0.0.0.0:*                           576/Plex Media Serv
              udp        0      0 0.0.0.0:32412           0.0.0.0:*                           576/Plex Media Serv
              udp        0      0 0.0.0.0:32413           0.0.0.0:*                           576/Plex Media Serv
              udp        0      0 0.0.0.0:32414           0.0.0.0:*                           576/Plex Media Serv
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           611/dhclient
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           1/init
              udp        0      0 127.0.0.1:34595         0.0.0.0:*                           576/Plex Media Serv
              udp        0      0 0.0.0.0:1901            0.0.0.0:*                           576/Plex Media Serv
              udp        0      0 192.168.178.64:34690    0.0.0.0:*                           576/Plex Media Serv
              udp        0      0 192.168.178.64:35225    0.0.0.0:*                           576/Plex Media Serv
              udp        0      0 127.0.0.1:56280         0.0.0.0:*                           576/Plex Media Serv
              udp6       0      0 :::111                  :::*                                1/init
              mcm1957 2 Replies Last reply Reply Quote 0
              • mcm1957
                mcm1957 @Fierce last edited by
                @apollon77
                Hast du da eine Idee?
                  apollon77 last edited by
                  Naja im ersten schritt ,al das echte Logfile ansehen und nicht während ein ioBroker läuft noch versuchen einen zweiten zu starten. Das KANN nur schieff gehen. 🙂
                  Ein "iobroker restart" bewirkt das der iobroker systemd servcei restartet und damit läuft ein ioBroker doch schon. Dann nochmal einen Starten gibt erwartungsgemäss den DB Lock Fehler.
                  Also ... was steht denn so im Logfile unter /opt/iobroker/log/... ?
                    Fierce @apollon77 last edited by
                    @apollon77
                    Hatte schon mehrfach gestoppt und gestartet bzw. den rechner neugestartet. Aufgrund meiner ratlosigkeit hatte ich mich auf den Fehler konzentriert.
                    fierce@Fierce-Server:/opt/iobroker/log$ ls -l
                    insgesamt 24
                    -rw-rwxr--+ 1 iobroker iobroker 1451  5. Mär 21:13 iobroker.2024-03-04.log.gz
                    -rw-rw-r--+ 1 iobroker iobroker 5056  6. Mär 19:30 iobroker.2024-03-05.log.gz
                    -rw-rw-r--+ 1 iobroker iobroker 1909  7. Mär 19:24 iobroker.2024-03-06.log.gz
                    -rw-rw-r--+ 1 iobroker iobroker 1661  7. Mär 21:53 iobroker.2024-03-07.log
                    -rw-rwxr--+ 1 iobroker iobroker 1001  7. Mär 19:24 iobroker-audit.json
                    lrwxrwxrwx  1 fierce   fierce     23  7. Mär 21:53 iobroker.current.log -> iobroker.2024-03-07.log
                    fierce@Fierce-Server:/opt/iobroker/log$ cat iobroker.2024-03-07.log
                    2024-03-07 19:24:34.759  - info: admin.0 (731) Request actual repository...
                    2024-03-07 19:24:34.832  - info: host.Fierce-Server Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                    2024-03-07 19:24:37.050  - info: admin.0 (731) Repository received successfully.
                    2024-03-07 21:52:54.004  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
                    2024-03-07 21:52:54.005  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                    2024-03-07 21:52:54.005  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.1
                    2024-03-07 21:52:54.006  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
                    2024-03-07 21:52:56.068  - error: host.Fierce-Server-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                    fierce@Fierce-Server:/opt/iobroker/log$ iob stop
                    fierce@Fierce-Server:/opt/iobroker/log$ iob start
                    insgesamt 32
                    -rw-rw-r--+ 1 iobroker iobroker  493  8. Mär 14:16 iobroker.2024-03-07.log.gz
                    -rw-rw-r--+ 1 iobroker iobroker 5738  8. Mär 14:16 iobroker.2024-03-08.log
                    -rw-rwxr--+ 1 iobroker iobroker 1001  8. Mär 14:16 iobroker-audit.json
                    lrwxrwxrwx  1 iobroker iobroker   23  8. Mär 14:16 iobroker.current.log -> iobroker.2024-03-08.log
                    fierce@Fierce-Server:/opt/iobroker/log$ cat iobroker.2024-03-08.log
                    2024-03-08 14:16:27.813  - info: host.Fierce-Server received SIGTERM
                    2024-03-08 14:16:27.815  - info: host.Fierce-Server stopInstance system.adapter.admin.0 (force=false, process=true)
                    2024-03-08 14:16:27.815  - info: host.Fierce-Server stopInstance system.adapter.backitup.0 (force=false, process=true)
                    2024-03-08 14:16:27.815  - info: host.Fierce-Server stopInstance system.adapter.discovery.0 (force=false, process=true)
                    2024-03-08 14:16:27.813  - info: admin.0 (731) terminating http server on port 8081
                    2024-03-08 14:16:27.813  - info: backitup.0 (838) cleaned everything up...
                    2024-03-08 14:16:27.817  - info: host.Fierce-Server stopInstance system.adapter.admin.0 send kill signal
                    2024-03-08 14:16:27.817  - info: admin.0 (731) Got terminate signal TERMINATE_YOURSELF
                    2024-03-08 14:16:27.818  - info: backitup.0 (838) Got terminate signal TERMINATE_YOURSELF
                    2024-03-08 14:16:27.818  - info: admin.0 (731) terminating
                    2024-03-08 14:16:27.818  - info: backitup.0 (838) terminating
                    2024-03-08 14:16:27.818  - info: backitup.0 (838) Terminated (NO_ERROR): Without reason
                    2024-03-08 14:16:27.818  - info: admin.0 (731) Terminated (NO_ERROR): Without reason
                    2024-03-08 14:16:27.818  - info: discovery.0 (900) Got terminate signal TERMINATE_YOURSELF
                    2024-03-08 14:16:27.821  - info: discovery.0 (900) terminating
                    2024-03-08 14:16:27.821  - info: discovery.0 (900) Terminated (NO_ERROR): Without reason
                    2024-03-08 14:16:27.859  - info: host.Fierce-Server stopInstance system.adapter.backitup.0 send kill signal
                    2024-03-08 14:16:27.859  - info: host.Fierce-Server stopInstance system.adapter.discovery.0 send kill signal
                    2024-03-08 14:16:28.315  - info: discovery.0 (900) terminating
                    2024-03-08 14:16:28.319  - info: admin.0 (731) terminating
                    2024-03-08 14:16:28.319  - info: backitup.0 (838) terminating
                    2024-03-08 14:16:28.332  - info: host.Fierce-Server instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                    2024-03-08 14:16:28.333  - info: host.Fierce-Server instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                    2024-03-08 14:16:28.377  - info: host.Fierce-Server instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                    2024-03-08 14:16:28.377  - info: host.Fierce-Server All instances are stopped.
                    2024-03-08 14:16:28.463  - info: host.Fierce-Server terminated
                    2024-03-08 14:16:45.183  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
                    2024-03-08 14:16:45.185  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                    2024-03-08 14:16:45.185  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.1
                    2024-03-08 14:16:45.185  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
                    2024-03-08 14:16:45.509  - info: host.Fierce-Server connected to Objects and States
                    2024-03-08 14:16:45.514  - info: host.Fierce-Server added notifications configuration of host
                    2024-03-08 14:16:45.660  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeCurrent"
                    2024-03-08 14:16:45.660  - info: host.Fierce-Server 3 instances found
                    2024-03-08 14:16:45.662  - info: host.Fierce-Server starting 3 instances
                    2024-03-08 14:16:45.710  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeNewest"
                    2024-03-08 14:16:45.714  - info: host.Fierce-Server instance system.adapter.admin.0 started with pid 7346
                    2024-03-08 14:16:45.755  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeNewestNext"
                    2024-03-08 14:16:45.756  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmCurrent"
                    2024-03-08 14:16:45.757  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmNewest"
                    2024-03-08 14:16:45.758  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmNewestNext"
                    2024-03-08 14:16:45.758  - info: host.Fierce-Server Some obsolete host states deleted.
                    2024-03-08 14:16:46.105  - info: admin.0 (7346) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.1, js-controller: 5.0.19
                    2024-03-08 14:16:46.112  - info: admin.0 (7346) requesting all objects
                    2024-03-08 14:16:46.215  - info: admin.0 (7346) received all objects
                    2024-03-08 14:16:46.257  - info: admin.0 (7346) Request actual repository...
                    2024-03-08 14:16:46.263  - info: admin.0 (7346) socket.io server listening on port 8081
                    2024-03-08 14:16:46.263  - info: admin.0 (7346) http server listening on port 8081
                    2024-03-08 14:16:46.264  - info: admin.0 (7346) Use link "http://127.0.0.1:8081" to configure.
                    2024-03-08 14:16:46.324  - info: host.Fierce-Server Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                    2024-03-08 14:16:48.765  - info: admin.0 (7346) Repository received successfully.
                    2024-03-08 14:16:49.670  - info: host.Fierce-Server instance system.adapter.backitup.0 started with pid 7373
                    2024-03-08 14:16:49.987  - info: backitup.0 (7373) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.1, js-controller: 5.0.19
                    2024-03-08 14:16:50.018  - info: backitup.0 (7373) [iobroker] backup will be activated at 02:48 every 1 day(s)
                    2024-03-08 14:16:53.669  - info: host.Fierce-Server instance system.adapter.discovery.0 started with pid 7389
                    2024-03-08 14:16:54.011  - info: discovery.0 (7389) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.1, js-controller: 5.0.19
                    in dem log zeigt er kein fehler mehr, beim "node" aber schon
                    2024-03-08 14:23:10.139  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
                    2024-03-08 14:23:10.141  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                    2024-03-08 14:23:10.141  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.1
                    2024-03-08 14:23:10.141  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
                    2024-03-08 14:23:12.204  - error: host.Fierce-Server-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                    WebGUI weiterhin nicht erreichbar (Zeitüberschreitung)
                    • mcm1957
                      @fierce
                      Na ja node node_modules/iobroker.js-controller/controller.js --logs startet ja eine neue, zweite Instanz des js-controllers. Da ist es eigentlich klar, dass ein Locking Fehler auftreten muss.
                      node ... ist KEIN Instrument um sich logs anzusehen falls das der Irrtum ist.
                      mcm1957 F 2 Replies Last reply Reply Quote 0
                      • mcm1957
                        mcm1957 @mcm1957 last edited by
                        Da du eine Zeitüberschreitung bekommst:
                        Bist du sicher, dass dein ioBroker Rechner von jenem Rechner auf dem der Browser läuft erreichbar ist?
                        Ich nehme mal an, der Browser läuft auf einem Windows PC.
                        • Funktioniert ein ping vom Windows PC auf den ioBroker NUC?
                        • Steigst du via ssh von deinem Windows PC auf die Commandline des NUC ein oder loggst du dich am NUC mittels lokalem Keyboard + Bildschirm ein?
                        • Hast du irgendwo im LAN ein Firewall die die Verbindung blockieren könnte?
                          Fierce @mcm1957 last edited by Fierce
                          @mcm57 sagte in frische IOB Installation - WebGUI nicht erreichbar:
                          @fierce
                          Danke für die Erläuterung das macht etwas klarer was ich da eigentlich gemacht habe 😌
                          Der Rechner ist ein Intel NUC 11, auf dem läuft auch mein Plex-Server (Medien-Server). Der Plex Server ist von mehreren Geräte im LAN aus erreichbar und ja ich gehe von dem gleichen Rechner mit ssh auf den NUC mit dem ich auch versuche den ioBroker im Browser (http://192.168.178.64:8081) aufzurufen. Ich hab verschiedene Browser und den Aufruf von diesem Rechner als auch vom Smartphone versucht. Ping ist erfolgreich, eine Firewall im LAN selber hab ich nicht.
                          C:\Users\Fierce>ping 192.168.178.64
                          Ping wird ausgeführt für 192.168.178.64 mit 32 Bytes Daten:
                          Antwort von 192.168.178.64: Bytes=32 Zeit=79ms TTL=64
                          Antwort von 192.168.178.64: Bytes=32 Zeit=94ms TTL=64
                          Antwort von 192.168.178.64: Bytes=32 Zeit=49ms TTL=64
                          Antwort von 192.168.178.64: Bytes=32 Zeit=16ms TTL=64
                          Ping-Statistik für 192.168.178.64:
                              Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
                              (0% Verlust),
                          Ca. Zeitangaben in Millisek.:
                              Minimum = 16ms, Maximum = 94ms, Mittelwert = 59ms
                          C:\Users\Fierce>
                          • mcm1957
                            mcm1957 @Fierce last edited by mcm1957
                            @fierce
                            Ein reiner "versuchs mas halt" Versuch 🙂
                            Am nuc hast du ja keinen Browser (mangel UI, ok soweit).
                            Versuch mal mit curl localhost:8081 abzurufen und schau ob / was passiert.
                            Und auch curl 192.168.178.64:8081 vom Windows PC aus sollte gehen.
                            Ich hab im Moment keine Idee ob der Webserver des Admin nicht mag oder du den Rechner doch nicht erreichst - warum auch immer.
                            • mcm1957
                              mcm1957 @mcm1957 last edited by mcm1957
                              Moment mal
                              Was mir grad auffällt:
                              Auf Port 8081 wird nur mittel :::8081 gelauscht. Bin nicht 100% sicher, aber das sieht nach nur IPv6 aus.
                              Hab aber keine Ahnung ob man dem Admin irgendwie sagen kann schau nur auf IPv6 ...
                              IPv4 hast du ja hoffentlich nicht urgendwie auf Linux Ebene beschränkt / deaktiviert.
                              • mcm1957
                                Kann es sein, dass du da ev. IPv6 ausgewählt hast?
                                Frag mich aber nicht wie man das ändern kann wenn man keine Zugriff via GUI mehr hat 😞
                                • mcm1957
                                  Ev. versuch den Rechner mal auf seine IPv6 Addresse anzusprechen.
                                  Oder richte testweise mal eine zweite Admin Instanz ein
                                    mach doch mal folgendes
                                    1.) iob stop
                                    2.) lösche mal das Logfile (nicht das "current" sondern das mit Datum von heute)
                                    3.) iob start
                                    Dann warten ... dann logfile bitte mal vollständig posten. ... und bitte keine parallelen Versuche an der CLI
                                    • mcm1957
                                      @fierce said in frische IOB Installation - WebGUI nicht erreichbar:
                                      @apollon77
                                      Das sieht für mich so aus als würe admin NUR auf IPv6 lauschen - warum auch immer.
                                      Daher die Bitte den Rechner durch mal mittels IPv6 anzurufen ...
                                        Homoran Global Moderator Administrators @mcm1957 last edited by
                                        ja, aber das würde das jsonl lock nicht erklären, oder?
                                        • mcm1957
                                          mcm1957 @Homoran last edited by
                                          @homoran said in frische IOB Installation - WebGUI nicht erreichbar:
                                          Das mit dem Lock hat sich schon geklärt.
                                          Er hat bei laiufender Instanz via node Befehl (!) den js-controller nochmals gestartet,
                                          Na klar, dass es da zu log Konflikt kommt.
                                          Schau dir die Zeile an wo das lock Konflikt als Output kommt. Hab ioch auch erst später gesehen. Das ist kein Befehl um ein Log auszugeben sondern der volle node Befahl den js-congtroller zu starten ....
                                          ABER
                                          Das mit IPv6 ists auch nicht. Bei meinem PI sieht netstat fast ident aus uns ich (glaub ich) benutze IPv4 Zugriff.
                                            Thomas Braun Most Active @mcm1957 last edited by Thomas Braun
                                            echad@chet:~ $ sudo netstat -tulpen
                                            Proto Recv-Q Send-Q Local Address           Foreign Address         State       Benutzer   Inode      PID/Program name
                                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        5103987    2786798/mosquitto
                                            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       22466317   2081231/iobroker.js
                                            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       22466322   2081231/iobroker.js
                                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12573929   2170053/sshd: /usr/
                                            tcp        0      0 0.0.0.0:45000           0.0.0.0:*               LISTEN      1001       22471121   2081781/io.sainlogi
                                            tcp        0      0 100.107.71.135:45714    0.0.0.0:*               LISTEN      0          14574724   3044818/tailscaled
                                            tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN      0          12180      805/upsd
                                            tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       22467445   2081437/adb
                                            tcp6       0      0 :::1883                 :::*                    LISTEN      107        5103988    2786798/mosquitto
                                            tcp6       0      0 :::22                   :::*                    LISTEN      0          12571486   2170053/sshd: /usr/
                                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22471766   2081611/io.web.0
                                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22881105   2126862/io.admin.0
                                            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22471421   2081916/io.ws.0
                                            tcp6       0      0 fd7a:115c:a1e0:ab:45714 :::*                    LISTEN      0          14574725   3044818/tailscaled
                                            tcp6       0      0 :::51989                :::*                    LISTEN      1001       22470703   2081502/io.nuki-ext
                                            Aber hier spielt es keine Rolle, weil hier auch alles per IPv6 unterwegs ist (was es kann, jedenfalls).
                                            debian 12 webgui
                                            910
