    3. Einsteigerfragen
    4. [gelöst] frische IOB Installation - WebGUI nicht erreichbar
      Fierce @Thomas Braun last edited by Fierce
      @thomas-braun said in frische IOB Installation - WebGUI nicht erreichbar:
      @fierce
      Gib mal die Langfassung vom 'iob diag' zum Besten.
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: Fierce-Server
             Icon name: computer-desktop
               Chassis: desktop 🖥️
                Kernel: Linux 6.7.7-x64v4-xanmod1
          Architecture: x86-64
       Hardware Vendor: Intel_R_ Client Systems
        Hardware Model: NUC11PAHi5
      Firmware Version: PATGL357.0047.2022.0627.1120
      model name      : 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       19:34:26 up 20:31,  2 users,  load average: 2.21, 2.38, 2.46
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Wed 2024-03-06 19:34:26 CET
                 Universal time: Wed 2024-03-06 18:34:26 UTC
                       RTC time: Wed 2024-03-06 18:34:26
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      fierce
      /home/fierce
      fierce cdrom floppy sudo audio dip video plugdev users netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:             33G        1.0G         30G        1.8M        1.7G         32G
      Swap:           1.0G          0B        1.0G
      Total:           34G        1.0G         32G
              31752 M total memory
                995 M used memory
                527 M active memory
               1272 M inactive memory
              29560 M free memory
                275 M buffer memory
               1352 M swap cache
                976 M total swap
                  0 M used swap
                976 M free swap
      *** FAILED SERVICES ***
        UNIT           LOAD   ACTIVE SUB    DESCRIPTION
      * mnt-plex.mount loaded failed failed /mnt/plex
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs   16G     0   16G   0% /dev
      tmpfs          tmpfs     3.2G  1.2M  3.1G   1% /run
      /dev/nvme0n1p2 ext4      937G   11G  879G   2% /
      tmpfs          tmpfs      16G  4.0K   16G   1% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      efivarfs       efivarfs  192K  111K   77K  59% /sys/firmware/efi/efivars
      /dev/nvme0n1p1 vfat      511M  5.9M  506M   2% /boot/efi
      tmpfs          tmpfs     3.2G     0  3.2G   0% /run/user/1000
      TARGET      SOURCE         FSTYPE OPTIONS
      /           /dev/nvme0n1p2 ext4   rw,relatime,errors=remount-ro
      `-/boot/efi /dev/nvme0n1p1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
      /var:
      6.4G    /var/
      4.7G    /var/lib
      4.5G    /var/lib/plexmediaserver/Library/Application Support/Plex Media Server
      Archived and active journals take up 30.8M in the file system.
      /opt/iobroker/backups:
      2.9M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      111M    /opt/iobroker/iobroker-data/
      71M     /opt/iobroker/iobroker-data/files
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      37M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      8.5M    /opt/iobroker/iobroker-data/objects.jsonl
      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      6.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/344.2eef1017.chunk.js.map
      4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.1-1nodesource1
        Version table:
           18.19.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
       *** 18.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://ftp.de.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : Fierce-Server                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : Fierce-Server                            -  enabled
      + system.adapter.discovery.0              : discovery             : Fierce-Server                            -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Objects and States
      Objects:        147
      States:         105
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 https://downloads.plex.tv/repo/deb public InRelease
      Hit:3 http://ftp.de.debian.org/debian bookworm InRelease
      Hit:4 http://ftp.de.debian.org/debian bookworm-updates InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:6 http://deb.xanmod.org releases InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37714      20404/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       40620      20404/iobroker.js-c
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5228       1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4495       622/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      104        10743      599/mosquitto
      tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      999        4524       756/Plex Tuner Serv
      tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      999        7568       581/Plex Media Serv
      tcp        0      0 0.0.0.0:8883            0.0.0.0:*               LISTEN      104        10748      599/mosquitto
      tcp        0      0 127.0.0.1:37419         0.0.0.0:*               LISTEN      999        9653       703/Plex Plug-in [c
      tcp6       0      0 :::111                  :::*                    LISTEN      0          2094       1/init
      tcp6       0      0 :::80                   :::*                    LISTEN      0          7547       623/apache2
      tcp6       0      0 :::22                   :::*                    LISTEN      0          4497       622/sshd: /usr/sbin
      tcp6       0      0 :::1883                 :::*                    LISTEN      104        10744      599/mosquitto
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       40656      20423/io.admin.0
      tcp6       0      0 :::8883                 :::*                    LISTEN      104        10749      599/mosquitto
      tcp6       0      0 :::32400                :::*                    LISTEN      999        7566       581/Plex Media Serv
      udp        0      0 192.168.178.64:44371    0.0.0.0:*                           999        7622       581/Plex Media Serv
      udp        0      0 192.168.178.64:47242    0.0.0.0:*                           999        7626       581/Plex Media Serv
      udp        0      0 0.0.0.0:32410           0.0.0.0:*                           999        8523       581/Plex Media Serv
      udp        0      0 0.0.0.0:32412           0.0.0.0:*                           999        8524       581/Plex Media Serv
      udp        0      0 0.0.0.0:32413           0.0.0.0:*                           999        7620       581/Plex Media Serv
      udp        0      0 0.0.0.0:32414           0.0.0.0:*                           999        8522       581/Plex Media Serv
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2585       573/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5229       1/init
      udp        0      0 127.0.0.1:49402         0.0.0.0:*                           999        7621       581/Plex Media Serv
      udp        0      0 0.0.0.0:1901            0.0.0.0:*                           999        7625       581/Plex Media Serv
      udp        0      0 127.0.0.1:54911         0.0.0.0:*                           999        7623       581/Plex Media Serv
      udp        0      0 192.168.178.64:39558    0.0.0.0:*                           999        7624       581/Plex Media Serv
      udp6       0      0 :::111                  :::*                                0          8221       1/init
      2024-03-06 19:30:30.431  - info: host.Fierce-Server 3 instances found
      2024-03-06 19:30:30.433  - info: host.Fierce-Server starting 3 instances
      2024-03-06 19:30:30.482  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeNewest"
      2024-03-06 19:30:30.486  - info: host.Fierce-Server instance system.adapter.admin.0 started with pid 20423
      2024-03-06 19:30:30.527  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeNewestNext"
      2024-03-06 19:30:30.528  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmCurrent"
      2024-03-06 19:30:30.529  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmNewest"
      2024-03-06 19:30:30.530  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmNewestNext"
      2024-03-06 19:30:30.530  - info: host.Fierce-Server Some obsolete host states deleted.
      2024-03-06 19:30:30.870  - info: admin.0 (20423) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.19
      2024-03-06 19:30:30.877  - info: admin.0 (20423) requesting all objects
      2024-03-06 19:30:30.983  - info: admin.0 (20423) received all objects
      2024-03-06 19:30:31.042  - info: admin.0 (20423) socket.io server listening on port 8081
      2024-03-06 19:30:31.043  - info: admin.0 (20423) http server listening on port 8081
      2024-03-06 19:30:31.043  - info: admin.0 (20423) Use link "http://127.0.0.1:8081" to configure.
      2024-03-06 19:30:32.312  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
      2024-03-06 19:30:32.313  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
      2024-03-06 19:30:32.313  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.0
      2024-03-06 19:30:32.314  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
      2024-03-06 19:30:34.377  - error: host.Fierce-Server-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
      2024-03-06 19:30:34.439  - info: host.Fierce-Server instance system.adapter.backitup.0 started with pid 20450
      2024-03-06 19:30:34.755  - info: backitup.0 (20450) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.19
      2024-03-06 19:30:34.766  - info: backitup.0 (20450) [iobroker] backup will be activated at 02:48 every 1 day(s)
      2024-03-06 19:30:38.438  - info: host.Fierce-Server instance system.adapter.discovery.0 started with pid 20477
      2024-03-06 19:30:38.783  - info: discovery.0 (20477) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.19
      @fierce
      sudo systemctl set-default multi-user.target
      Und was versprichst du dir von dem Kernel?
      Der Kernel ist Empfehlung aus der Plex Comunity. Soll fürs Medienstreaming Vorteile habe 🤷‍♂️
      fierce@Fierce-Server:~$ sudo systemctl set-default multi-user.target
      Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
      Fehler im Log-File bleibt bestehen und WebGUI weiterhin nicht aufrufbar...
      fierce@Fierce-Server:/opt/iobroker$ iob restart
      fierce@Fierce-Server:/opt/iobroker$ node node_modules/iobroker.js-controller/controller.js --logs
        Thomas Braun Most Active @Fierce last edited by
        @fierce
        sudo usermod -a -G adm fierce
        sudo apt update
        iob stop
        sudo apt full-upgrade
        fierce einmal aus und wieder einloggen.
        Ansonsten schaut das eigentlich okay aus.
          fierce@Fierce-Server:/opt/iobroker$ sudo usermod -a -G adm fierce
          [sudo] Passwort für fierce:
          fierce@Fierce-Server:/opt/iobroker$ sudo apt update
          OK:1 http://security.debian.org/debian-security bookworm-security InRelease
          OK:2 https://downloads.plex.tv/repo/deb public InRelease
          OK:3 http://ftp.de.debian.org/debian bookworm InRelease
          OK:4 http://ftp.de.debian.org/debian bookworm-updates InRelease
          OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          OK:6 http://deb.xanmod.org releases InRelease
          Paketlisten werden gelesen… Fertig
          Abhängigkeitsbaum wird aufgebaut… Fertig
          Statusinformationen werden eingelesen… Fertig
          Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
          fierce@Fierce-Server:/opt/iobroker$ iob stop
          fierce@Fierce-Server:/opt/iobroker$ sudo apt full-upgrade
          Paketaktualisierung (Upgrade) wird berechnet… Fertig
          Die folgenden Pakete werden aktualisiert (Upgrade):
            nodejs
          1 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
          Es müssen noch 0 B von 29,8 MB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 54,3 kB Plattenplatz zusätzlich benutzt.
          Möchten Sie fortfahren? [J/n] j
          Changelogs werden gelesen... Fertig
          (Lese Datenbank ... 109430 Dateien und Verzeichnisse sind derzeit installiert.)
          Vorbereitung zum Entpacken von .../nodejs_18.19.1-1nodesource1_amd64.deb ...
          Detected old npm client, removing...
          Entpacken von nodejs (18.19.1-1nodesource1) über (18.19.0-1nodesource1) ...
          nodejs (18.19.1-1nodesource1) wird eingerichtet ...
          Trigger für man-db (2.11.2-2) werden verarbeitet ...
          fierce@Fierce-Server:/opt/iobroker$ sudo systemctl reboot
          Leider immernoch das gleiche Fehlerbild. Die WebGUI ist einfach nicht aufrufbar...
            Fierce @Fierce last edited by Fierce
            Noch irgendjemand eine Idee wo man schauen oder was man prüfen könnte ? Den einzigen Fehler den ich gefunden habe ist der folgende aber ich kann nicht einschätzen ob der wirklich dafür verantwortlich ist das die WebGUI nicht aufrufbar ist...
            2024-03-07 21:53:02.596  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
            2024-03-07 21:53:02.598  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
            2024-03-07 21:53:02.598  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.1
            2024-03-07 21:53:02.598  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
            2024-03-07 21:53:04.661  - error: host.Fierce-Server-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
            scheinbar wird aber auf den Ports gelauscht
            fierce@Fierce-Server:~$ sudo netstat -tulnp
            Aktive Internetverbindungen (Nur Server)
            Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      596/mosquitto
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      604/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      1/init
            tcp        0      0 127.0.0.1:39819         0.0.0.0:*               LISTEN      703/Plex Plug-in [c
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      555/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      555/iobroker.js-con
            tcp        0      0 0.0.0.0:8883            0.0.0.0:*               LISTEN      596/mosquitto
            tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      760/Plex Tuner Serv
            tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      576/Plex Media Serv
            tcp6       0      0 :::1883                 :::*                    LISTEN      596/mosquitto
            tcp6       0      0 :::22                   :::*                    LISTEN      604/sshd: /usr/sbin
            tcp6       0      0 :::80                   :::*                    LISTEN      623/apache2
            tcp6       0      0 :::111                  :::*                    LISTEN      1/init
            tcp6       0      0 :::8081                 :::*                    LISTEN      731/io.admin.0
            tcp6       0      0 :::8883                 :::*                    LISTEN      596/mosquitto
            tcp6       0      0 :::32400                :::*                    LISTEN      576/Plex Media Serv
            udp        0      0 192.168.178.64:43086    0.0.0.0:*                           576/Plex Media Serv
            udp        0      0 0.0.0.0:32410           0.0.0.0:*                           576/Plex Media Serv
            udp        0      0 0.0.0.0:32412           0.0.0.0:*                           576/Plex Media Serv
            udp        0      0 0.0.0.0:32413           0.0.0.0:*                           576/Plex Media Serv
            udp        0      0 0.0.0.0:32414           0.0.0.0:*                           576/Plex Media Serv
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           611/dhclient
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           1/init
            udp        0      0 127.0.0.1:34595         0.0.0.0:*                           576/Plex Media Serv
            udp        0      0 0.0.0.0:1901            0.0.0.0:*                           576/Plex Media Serv
            udp        0      0 192.168.178.64:34690    0.0.0.0:*                           576/Plex Media Serv
            udp        0      0 192.168.178.64:35225    0.0.0.0:*                           576/Plex Media Serv
            udp        0      0 127.0.0.1:56280         0.0.0.0:*                           576/Plex Media Serv
            udp6       0      0 :::111                  :::*                                1/init
            mcm1957 2 Replies Last reply Reply Quote 0
            • mcm1957
              mcm1957 @Fierce last edited by
              @apollon77
              Hast du da eine Idee?
                apollon77 last edited by
                Naja im ersten schritt ,al das echte Logfile ansehen und nicht während ein ioBroker läuft noch versuchen einen zweiten zu starten. Das KANN nur schieff gehen. 🙂
                Ein "iobroker restart" bewirkt das der iobroker systemd servcei restartet und damit läuft ein ioBroker doch schon. Dann nochmal einen Starten gibt erwartungsgemäss den DB Lock Fehler.
                Also ... was steht denn so im Logfile unter /opt/iobroker/log/... ?
                  Fierce @apollon77 last edited by
                  @apollon77
                  Hatte schon mehrfach gestoppt und gestartet bzw. den rechner neugestartet. Aufgrund meiner ratlosigkeit hatte ich mich auf den Fehler konzentriert.
                  fierce@Fierce-Server:/opt/iobroker/log$ ls -l
                  insgesamt 24
                  -rw-rwxr--+ 1 iobroker iobroker 1451  5. Mär 21:13 iobroker.2024-03-04.log.gz
                  -rw-rw-r--+ 1 iobroker iobroker 5056  6. Mär 19:30 iobroker.2024-03-05.log.gz
                  -rw-rw-r--+ 1 iobroker iobroker 1909  7. Mär 19:24 iobroker.2024-03-06.log.gz
                  -rw-rw-r--+ 1 iobroker iobroker 1661  7. Mär 21:53 iobroker.2024-03-07.log
                  -rw-rwxr--+ 1 iobroker iobroker 1001  7. Mär 19:24 iobroker-audit.json
                  lrwxrwxrwx  1 fierce   fierce     23  7. Mär 21:53 iobroker.current.log -> iobroker.2024-03-07.log
                  fierce@Fierce-Server:/opt/iobroker/log$ cat iobroker.2024-03-07.log
                  2024-03-07 19:24:34.759  - info: admin.0 (731) Request actual repository...
                  2024-03-07 19:24:34.832  - info: host.Fierce-Server Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                  2024-03-07 19:24:37.050  - info: admin.0 (731) Repository received successfully.
                  2024-03-07 21:52:54.004  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
                  2024-03-07 21:52:54.005  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                  2024-03-07 21:52:54.005  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.1
                  2024-03-07 21:52:54.006  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
                  2024-03-07 21:52:56.068  - error: host.Fierce-Server-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                  fierce@Fierce-Server:/opt/iobroker/log$ iob stop
                  fierce@Fierce-Server:/opt/iobroker/log$ iob start
                  insgesamt 32
                  -rw-rw-r--+ 1 iobroker iobroker  493  8. Mär 14:16 iobroker.2024-03-07.log.gz
                  -rw-rw-r--+ 1 iobroker iobroker 5738  8. Mär 14:16 iobroker.2024-03-08.log
                  -rw-rwxr--+ 1 iobroker iobroker 1001  8. Mär 14:16 iobroker-audit.json
                  lrwxrwxrwx  1 iobroker iobroker   23  8. Mär 14:16 iobroker.current.log -> iobroker.2024-03-08.log
                  fierce@Fierce-Server:/opt/iobroker/log$ cat iobroker.2024-03-08.log
                  2024-03-08 14:16:27.813  - info: host.Fierce-Server received SIGTERM
                  2024-03-08 14:16:27.815  - info: host.Fierce-Server stopInstance system.adapter.admin.0 (force=false, process=true)
                  2024-03-08 14:16:27.815  - info: host.Fierce-Server stopInstance system.adapter.backitup.0 (force=false, process=true)
                  2024-03-08 14:16:27.815  - info: host.Fierce-Server stopInstance system.adapter.discovery.0 (force=false, process=true)
                  2024-03-08 14:16:27.813  - info: admin.0 (731) terminating http server on port 8081
                  2024-03-08 14:16:27.813  - info: backitup.0 (838) cleaned everything up...
                  2024-03-08 14:16:27.817  - info: host.Fierce-Server stopInstance system.adapter.admin.0 send kill signal
                  2024-03-08 14:16:27.817  - info: admin.0 (731) Got terminate signal TERMINATE_YOURSELF
                  2024-03-08 14:16:27.818  - info: backitup.0 (838) Got terminate signal TERMINATE_YOURSELF
                  2024-03-08 14:16:27.818  - info: admin.0 (731) terminating
                  2024-03-08 14:16:27.818  - info: backitup.0 (838) terminating
                  2024-03-08 14:16:27.818  - info: backitup.0 (838) Terminated (NO_ERROR): Without reason
                  2024-03-08 14:16:27.818  - info: admin.0 (731) Terminated (NO_ERROR): Without reason
                  2024-03-08 14:16:27.818  - info: discovery.0 (900) Got terminate signal TERMINATE_YOURSELF
                  2024-03-08 14:16:27.821  - info: discovery.0 (900) terminating
                  2024-03-08 14:16:27.821  - info: discovery.0 (900) Terminated (NO_ERROR): Without reason
                  2024-03-08 14:16:27.859  - info: host.Fierce-Server stopInstance system.adapter.backitup.0 send kill signal
                  2024-03-08 14:16:27.859  - info: host.Fierce-Server stopInstance system.adapter.discovery.0 send kill signal
                  2024-03-08 14:16:28.315  - info: discovery.0 (900) terminating
                  2024-03-08 14:16:28.319  - info: admin.0 (731) terminating
                  2024-03-08 14:16:28.319  - info: backitup.0 (838) terminating
                  2024-03-08 14:16:28.332  - info: host.Fierce-Server instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                  2024-03-08 14:16:28.333  - info: host.Fierce-Server instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                  2024-03-08 14:16:28.377  - info: host.Fierce-Server instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                  2024-03-08 14:16:28.377  - info: host.Fierce-Server All instances are stopped.
                  2024-03-08 14:16:28.463  - info: host.Fierce-Server terminated
                  2024-03-08 14:16:45.183  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
                  2024-03-08 14:16:45.185  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                  2024-03-08 14:16:45.185  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.1
                  2024-03-08 14:16:45.185  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
                  2024-03-08 14:16:45.509  - info: host.Fierce-Server connected to Objects and States
                  2024-03-08 14:16:45.514  - info: host.Fierce-Server added notifications configuration of host
                  2024-03-08 14:16:45.660  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeCurrent"
                  2024-03-08 14:16:45.660  - info: host.Fierce-Server 3 instances found
                  2024-03-08 14:16:45.662  - info: host.Fierce-Server starting 3 instances
                  2024-03-08 14:16:45.710  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeNewest"
                  2024-03-08 14:16:45.714  - info: host.Fierce-Server instance system.adapter.admin.0 started with pid 7346
                  2024-03-08 14:16:45.755  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeNewestNext"
                  2024-03-08 14:16:45.756  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmCurrent"
                  2024-03-08 14:16:45.757  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmNewest"
                  2024-03-08 14:16:45.758  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmNewestNext"
                  2024-03-08 14:16:45.758  - info: host.Fierce-Server Some obsolete host states deleted.
                  2024-03-08 14:16:46.105  - info: admin.0 (7346) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.1, js-controller: 5.0.19
                  2024-03-08 14:16:46.112  - info: admin.0 (7346) requesting all objects
                  2024-03-08 14:16:46.215  - info: admin.0 (7346) received all objects
                  2024-03-08 14:16:46.257  - info: admin.0 (7346) Request actual repository...
                  2024-03-08 14:16:46.263  - info: admin.0 (7346) socket.io server listening on port 8081
                  2024-03-08 14:16:46.263  - info: admin.0 (7346) http server listening on port 8081
                  2024-03-08 14:16:46.264  - info: admin.0 (7346) Use link "http://127.0.0.1:8081" to configure.
                  2024-03-08 14:16:46.324  - info: host.Fierce-Server Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                  2024-03-08 14:16:48.765  - info: admin.0 (7346) Repository received successfully.
                  2024-03-08 14:16:49.670  - info: host.Fierce-Server instance system.adapter.backitup.0 started with pid 7373
                  2024-03-08 14:16:49.987  - info: backitup.0 (7373) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.1, js-controller: 5.0.19
                  2024-03-08 14:16:50.018  - info: backitup.0 (7373) [iobroker] backup will be activated at 02:48 every 1 day(s)
                  2024-03-08 14:16:53.669  - info: host.Fierce-Server instance system.adapter.discovery.0 started with pid 7389
                  2024-03-08 14:16:54.011  - info: discovery.0 (7389) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.1, js-controller: 5.0.19
                  in dem log zeigt er kein fehler mehr, beim "node" aber schon
                  2024-03-08 14:23:10.139  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
                  2024-03-08 14:23:10.141  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                  2024-03-08 14:23:10.141  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.1
                  2024-03-08 14:23:10.141  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
                  2024-03-08 14:23:12.204  - error: host.Fierce-Server-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                  WebGUI weiterhin nicht erreichbar (Zeitüberschreitung)
                  • mcm1957
                    @fierce
                    Na ja node node_modules/iobroker.js-controller/controller.js --logs startet ja eine neue, zweite Instanz des js-controllers. Da ist es eigentlich klar, dass ein Locking Fehler auftreten muss.
                    node ... ist KEIN Instrument um sich logs anzusehen falls das der Irrtum ist.
                    mcm1957 F 2 Replies Last reply Reply Quote 0
                    • mcm1957
                      mcm1957 @mcm1957 last edited by
                      Da du eine Zeitüberschreitung bekommst:
                      Bist du sicher, dass dein ioBroker Rechner von jenem Rechner auf dem der Browser läuft erreichbar ist?
                      Ich nehme mal an, der Browser läuft auf einem Windows PC.
                      • Funktioniert ein ping vom Windows PC auf den ioBroker NUC?
                      • Steigst du via ssh von deinem Windows PC auf die Commandline des NUC ein oder loggst du dich am NUC mittels lokalem Keyboard + Bildschirm ein?
                      • Hast du irgendwo im LAN ein Firewall die die Verbindung blockieren könnte?
                        Fierce @mcm1957 last edited by Fierce
                        @mcm57 sagte in frische IOB Installation - WebGUI nicht erreichbar:
                        @fierce
                        Danke für die Erläuterung das macht etwas klarer was ich da eigentlich gemacht habe 😌
                        Der Rechner ist ein Intel NUC 11, auf dem läuft auch mein Plex-Server (Medien-Server). Der Plex Server ist von mehreren Geräte im LAN aus erreichbar und ja ich gehe von dem gleichen Rechner mit ssh auf den NUC mit dem ich auch versuche den ioBroker im Browser (http://192.168.178.64:8081) aufzurufen. Ich hab verschiedene Browser und den Aufruf von diesem Rechner als auch vom Smartphone versucht. Ping ist erfolgreich, eine Firewall im LAN selber hab ich nicht.
                        C:\Users\Fierce>ping 192.168.178.64
                        Ping wird ausgeführt für 192.168.178.64 mit 32 Bytes Daten:
                        Antwort von 192.168.178.64: Bytes=32 Zeit=79ms TTL=64
                        Antwort von 192.168.178.64: Bytes=32 Zeit=94ms TTL=64
                        Antwort von 192.168.178.64: Bytes=32 Zeit=49ms TTL=64
                        Antwort von 192.168.178.64: Bytes=32 Zeit=16ms TTL=64
                        Ping-Statistik für 192.168.178.64:
                            Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
                            (0% Verlust),
                        Ca. Zeitangaben in Millisek.:
                            Minimum = 16ms, Maximum = 94ms, Mittelwert = 59ms
                        C:\Users\Fierce>
                        • mcm1957
                          mcm1957 @Fierce last edited by mcm1957
                          @fierce
                          Ein reiner "versuchs mas halt" Versuch 🙂
                          Am nuc hast du ja keinen Browser (mangel UI, ok soweit).
                          Versuch mal mit curl localhost:8081 abzurufen und schau ob / was passiert.
                          Und auch curl 192.168.178.64:8081 vom Windows PC aus sollte gehen.
                          Ich hab im Moment keine Idee ob der Webserver des Admin nicht mag oder du den Rechner doch nicht erreichst - warum auch immer.
                          • mcm1957
                            mcm1957 @mcm1957 last edited by mcm1957
                            Moment mal
                            Was mir grad auffällt:
                            Auf Port 8081 wird nur mittel :::8081 gelauscht. Bin nicht 100% sicher, aber das sieht nach nur IPv6 aus.
                            Hab aber keine Ahnung ob man dem Admin irgendwie sagen kann schau nur auf IPv6 ...
                            IPv4 hast du ja hoffentlich nicht urgendwie auf Linux Ebene beschränkt / deaktiviert.
                            • mcm1957
                              Kann es sein, dass du da ev. IPv6 ausgewählt hast?
                              Frag mich aber nicht wie man das ändern kann wenn man keine Zugriff via GUI mehr hat 😞
                              • mcm1957
                                Ev. versuch den Rechner mal auf seine IPv6 Addresse anzusprechen.
                                Oder richte testweise mal eine zweite Admin Instanz ein
                                  mach doch mal folgendes
                                  1.) iob stop
                                  2.) lösche mal das Logfile (nicht das "current" sondern das mit Datum von heute)
                                  3.) iob start
                                  Dann warten ... dann logfile bitte mal vollständig posten. ... und bitte keine parallelen Versuche an der CLI
                                  • mcm1957
                                    @fierce said in frische IOB Installation - WebGUI nicht erreichbar:
                                    @apollon77
                                    Das sieht für mich so aus als würe admin NUR auf IPv6 lauschen - warum auch immer.
                                    Daher die Bitte den Rechner durch mal mittels IPv6 anzurufen ...
                                      Homoran Global Moderator Administrators @mcm1957 last edited by
                                      ja, aber das würde das jsonl lock nicht erklären, oder?
                                      • mcm1957
                                        mcm1957 @Homoran last edited by
                                        @homoran said in frische IOB Installation - WebGUI nicht erreichbar:
                                        Das mit dem Lock hat sich schon geklärt.
                                        Er hat bei laiufender Instanz via node Befehl (!) den js-controller nochmals gestartet,
                                        Na klar, dass es da zu log Konflikt kommt.
                                        Schau dir die Zeile an wo das lock Konflikt als Output kommt. Hab ioch auch erst später gesehen. Das ist kein Befehl um ein Log auszugeben sondern der volle node Befahl den js-congtroller zu starten ....
                                        ABER
                                        Das mit IPv6 ists auch nicht. Bei meinem PI sieht netstat fast ident aus uns ich (glaub ich) benutze IPv4 Zugriff.
                                          Thomas Braun Most Active @mcm1957 last edited by Thomas Braun
                                          echad@chet:~ $ sudo netstat -tulpen
                                          Proto Recv-Q Send-Q Local Address           Foreign Address         State       Benutzer   Inode      PID/Program name
                                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        5103987    2786798/mosquitto
                                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       22466317   2081231/iobroker.js
                                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       22466322   2081231/iobroker.js
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12573929   2170053/sshd: /usr/
                                          tcp        0      0 0.0.0.0:45000           0.0.0.0:*               LISTEN      1001       22471121   2081781/io.sainlogi
                                          tcp        0      0 100.107.71.135:45714    0.0.0.0:*               LISTEN      0          14574724   3044818/tailscaled
                                          tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN      0          12180      805/upsd
                                          tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       22467445   2081437/adb
                                          tcp6       0      0 :::1883                 :::*                    LISTEN      107        5103988    2786798/mosquitto
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          12571486   2170053/sshd: /usr/
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22471766   2081611/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22881105   2126862/io.admin.0
                                          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22471421   2081916/io.ws.0
                                          tcp6       0      0 fd7a:115c:a1e0:ab:45714 :::*                    LISTEN      0          14574725   3044818/tailscaled
                                          tcp6       0      0 :::51989                :::*                    LISTEN      1001       22470703   2081502/io.nuki-ext
                                          Aber hier spielt es keine Rolle, weil hier auch alles per IPv6 unterwegs ist (was es kann, jedenfalls).
                                          • mcm1957
                                            mcm1957 @Thomas Braun last edited by
                                            Na ja,
                                            Er versucht das Admin Interface ja per IPv4 Addressangabe aufzurufen. (Siehe erstes Post)
                                            Schaltets das irgendwer intern dann auf IPv6 Kommunikation um? Ich dachte wenn ich im Webbrowser http://102.168.178.64:8081 eintippe dann benutzt das System zwingend IPv4.
                                            Aber offensichtlich interpretiere ich den IPv6 Wildcard falsch.
                                            Danke Thomas
                                            debian 12 webgui
                                            910
