    4. Zigbee Adapter Error Send Command failed with no error code
      Thomas Braun Most Active @Stefan 3 last edited by
      @stefan-3
      Da war noch ein Fehlerchen drin.
      echo "deb [signed-by=/usr/share/keyrings/debianfhemde-archive-keyring.gpg] https://debian.fhem.de/nightly/ /" | sudo tee /etc/apt/sources.list.d/fhem.list
      sudo apt update
      sudo apt install fhem
      sollte funktionieren.
        @thomas-braun Tippi toppi 👍 So funktioiniert nun die FHEM Installation. Vielen herzlichen Dank schonmal. Hast Du Kontakte zum FHEM Team um die Anleitung auf https://debian.fhem.de/ zu bereinigen? Ansonsten versuch ich da mein Glück.
        Danach hab ich die iob Installation versucht.
        pi@raspberrypi:~ $ curl -sSLf https://iobroker.net/install.sh | bash -
        library: loaded
        Library version=2024-01-04
            Welcome to the ioBroker installer!
            Installer version: 2024-01-04
            You might need to enter your password a couple of times.
            Installing prerequisites (1/4)
        Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
        Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://debian.fhem.de/nightly  InRelease
        Fetched 48.0 kB in 2s (22.4 kB/s)
        Reading package lists... Done
            Node.js not found. Installing...
        rm: cannot remove '/etc/apt/keyrings/nodesource.gpg': No such file or directory
        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
        Package: nodejs
        Pin: origin deb.nodesource.com
        Pin-Priority: 1001
         Processing triggers for man-db (2.11.2-2) ...ource1_arm64.deb ...led.)
        Installed nodejs
        Node.js Installed successfully!
        Changing npm registry to https://registry.npmjs.org
         Processing triggers for man-db (2.11.2-2) ...arm64.deb ... installed.)
        Installed acl
         Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-10) ...-10_arm64.deb ...
        Installed libavahi-compat-libdnssd-dev
         Processing triggers for man-db (2.11.2-2) ...1) ...1_arm64.deb ...ed.)
        Installed libudev-dev
         Processing triggers for man-db (2.11.2-2) ...eb12u1) ...1_arm64.deb ...
        Installed libpam0g-dev
         Processing triggers for man-db (2.11.2-2) ...m64.deb ......installed.)
        Installed git
        Extracting templates from packages: 100%
         Setting up libcairo2-dev:arm64 (1.16.0-7+rpt1) ....u4) ...t1) .........rm64.deb ...
        Installed libcairo2-dev
         Processing triggers for libc-bin (2.36-9+rpt2+deb12u4) ...m64.deb ... ....
        Installed libpango1.0-dev
         Setting up libjpeg-dev:arm64 (1:2.1.5-2) ...5-2) ...4.deb ....deb ...)
        Installed libjpeg-dev
         Processing triggers for libc-bin (2.36-9+rpt2+deb12u4) ... installed.)
        Installed libgif-dev
         Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.10+dfsg-1+b1) ..........
        Installed librsvg2-dev
         Processing triggers for libc-bin (2.36-9+rpt2+deb12u4) .....nstalled.)
        Installed cmake
            Creating ioBroker user and directory (2/4)
        User iobroker created
        Created /etc/sudoers.d/iobroker
        Directory /opt/iobroker created
            Installing ioBroker (3/4)
        (##################) ⠦ reify:iobroker.admin: http fetch GET 200 https://registry.npmjs.org/iobroker.admin/-/iobroker.admin-6.13.16.tgz 47759ms (cache miss)
        Dann war über 20 Min. keine Reaktion mehr zu verzeichnen, auch mit Strg+C.
        Ich schließe also einen Monitor am Raspi an. Zuerst steht nur Login da, dann:
        hwmon hwmon1: Undervoltage detected!
        Obwohl ich inzwischen ein Labornetzteil mit +5,5V/3A, dickes Kabel und 220µF Abblock-C dicht am Raspi einsetze. Über Putty komm ich auch nicht mehr drauf. Reboot durch alt+Druck über Tastatur am Raspi. Dann erneuter Versuch der iob Installation. Diesmal läuft es durch.
        library: loaded
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://debian.fhem.de/nightly  InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
        Fetched 48.0 kB in 3s (18.3 kB/s)
            Finalizing installation (4/4)
        Enabling autostart...
        Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
        Autostart enabled!
        Fixing directory permissions...
            ioBroker was installed successfully
            Open http://192.168.123.57:8081 in a browser and start configuring!
        You need to re-login before doing anything else on the console!
        Morgen spiel ich die Adapter drauf und dann sehen wir weiter bzgl. dem eigentlichen Zigbee Problem.
        Thomas Braun arteck 2 Replies Last reply Reply Quote 0
          @stefan-3
          Nein, mit FHEM hab ich nix am Hut.
            arteck Developer Most Active @Stefan 3 last edited by
            @stefan-3 ist ja nicht dein ernst...iobroker übernimmt FHEM support... geil...
              Stefan 3 @arteck last edited by
              @arteck So, System wie gesagt neu aufgesetzt, FHEM und IOB installiert. RAM war am Anschlag, so dass ich eine 2GB Swap-Datei eingerichtet hab. Der Zigbee-Fehler ist unverändert da
              Zusatzinfo: Jetziges Ergebnis von iob diag:
              Skript v.2023-10-10
              *** BASE SYSTEM ***
               Static hostname: raspberrypi
                     Icon name: computer
                        Kernel: Linux 6.1.0-rpi8-rpi-v8
                  Architecture: arm64
              Model           : Raspberry Pi 3 Model B Rev 1.2
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : arm64
              Systemuptime and Load:
               18:10:05 up 23 min,  2 users,  load average: 0.26, 0.21, 0.33
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              ~ Under-voltage has occurred
              *** Time and Time Zones ***
                             Local time: Fri 2024-03-08 18:10:05 CET
                         Universal time: Fri 2024-03-08 17:10:05 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            952M        747M        112M        188K        153M        205M
              Swap:           2.3G        252M        2.0G
              Total:          3.2G        1.0G        2.1G
                        908 M total memory
                        712 M used memory
                        455 M active memory
                        253 M inactive memory
                        107 M free memory
                         10 M buffer memory
                        135 M swap cache
                       2147 M total swap
                        241 M used swap
                       1906 M free swap
              Raspberry only:
              oom events: 0
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              udev           devtmpfs  319M     0  319M   0% /dev
              tmpfs          tmpfs      91M  1.1M   90M   2% /run
              /dev/mmcblk0p2 ext4       29G  5.9G   22G  22% /
              tmpfs          tmpfs     455M     0  455M   0% /dev/shm
              tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
              /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
              tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
              [Fri Mar  8 17:46:20 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=d46b09f2-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Fri Mar  8 17:46:26 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Fri Mar  8 17:46:30 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              TARGET           SOURCE         FSTYPE OPTIONS
              /                /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              753M    /var/
              285M    /var/log/journal/b97363623a9b4bc5bc8e5d0296596227
              285M    /var/log
              203M    /var/cache
              Archived and active journals take up 284.0M in the file system.
              /opt/iobroker/backups:
              8.4M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              199M    /opt/iobroker/iobroker-data/
              186M    /opt/iobroker/iobroker-data/files
              57M     /opt/iobroker/iobroker-data/files/javascript.admin
              43M     /opt/iobroker/iobroker-data/files/iot.admin
              42M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
              33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
              22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
              11M     /opt/iobroker/iobroker-data/objects.jsonl
              8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
              8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
              USB-Devices by-id:
              /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.19.1
              /usr/bin/node           v18.19.1
              /usr/bin/npm            10.2.4
              /usr/bin/npx            10.2.4
              /usr/bin/corepack       0.22.0
              nodejs:
                Installed: 18.19.1-1nodesource1
                Candidate: 18.19.1-1nodesource1
                Version table:
               *** 18.19.1-1nodesource1 1001
                      100 /var/lib/dpkg/status
                   18.19.0+dfsg-6~deb12u1 500
                   18.19.0-1nodesource1 1001
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0+dfsg1-1 500
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.19
              admin:          6.13.16
              javascript:     7.8.0
              Adapters from github:   0
              Adapter State
              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
              + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
              + system.adapter.fhem.0                   : fhem                  : raspberrypi                              -  enabled, port: 7072
                system.adapter.history.0                : history               : raspberrypi                              - disabled
              + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
              + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                system.adapter.solarmanpv.0             : solarmanpv            : raspberrypi                              -  enabled
              + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
              + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
              Adapter    "backitup"     : 2.10.11  , installed 2.10.11
              Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
              Adapter    "fhem"         : 2.0.5    , installed 2.0.5
              Adapter    "iot"          : 2.0.11   , installed 2.0.11
              Adapter    "javascript"   : 7.8.0    , installed 7.8.0
              Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
              Adapter    "sonos"        : 3.0.0    , installed 3.0.0
              Adapter    "web"          : 6.2.3    , installed 6.2.3
              Adapter    "ws"           : 2.5.10   , installed 2.5.10
              Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
              Objects and States
              Objects:        3724
              States:         2904
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12870      629/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13810      629/iobroker.js-con
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13768      686/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        12858      770/perl
              tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        15825      770/perl
              tcp6       0      0 :::22                   :::*                    LISTEN      0          13770      686/sshd: /usr/sbin
              tcp6       0      0 :::3500                 :::*                    LISTEN      1001       15988      857/io.sonos.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14048      931/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15899      788/io.admin.0
              udp        0      0 0.0.0.0:56381           0.0.0.0:*                           104        12601      491/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        12599      491/avahi-daemon: r
              udp6       0      0 fe80::2157:f17c:c3f:546 :::*                                0          15821      582/NetworkManager
              udp6       0      0 :::44614                :::*                                104        12602      491/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                104        12600      491/avahi-daemon: r
              2024-03-08 18:00:33.396  - error: zigbee.0 (880) Send command to 0x00124b0018d534f5 failed with no error code (undefined)
              2024-03-08 18:01:00.626  - debug: alexa2.0 (824) Alexa-Remote HTTP2-PUSH: Send Ping
              2024-03-08 18:02:55.680  - info: fhem.0 (840) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
              2024-03-08 18:04:00.626  - debug: alexa2.0 (824) Alexa-Remote HTTP2-PUSH: Send Ping
              2024-03-08 18:05:00.133  - info: javascript.0 (795) script.js.common.V1a_Beregnung: Nächste Beregnung Programm 1a aktualisiert auf: 03/09/2024 18:00
              2024-03-08 18:06:00.096  - info: host.raspberrypi instance system.adapter.solarmanpv.0 started with pid 1082
              2024-03-08 18:06:04.154  - info: solarmanpv.0 (1082) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v18.19.1, js-controller: 5.0.19
              2024-03-08 18:06:06.251  - info: solarmanpv.0 (1082) State value to set for "solarmanpv.0.3104772.221753192.DEV_TYP1" has to be type "number" but received type "string"
              2024-03-08 18:06:06.339  - info: solarmanpv.0 (1082) State value to set for "solarmanpv.0.3104772.221753192.COMM_PTC_v1" has to be type "string" but received type "number"
              2024-03-08 18:06:06.398  - info: solarmanpv.0 (1082) State value to set for "solarmanpv.0.3104772.221753192.HWv1" has to be type "string" but received type "number"
              2024-03-08 18:06:06.933  - info: solarmanpv.0 (1082) State value to set for "solarmanpv.0.3104772.221753192.NOP" has to be type "number" but received type "string"
              2024-03-08 18:06:07.622  - info: solarmanpv.0 (1082) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
              2024-03-08 18:06:08.190  - info: host.raspberrypi instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-03-08 18:07:00.626  - debug: alexa2.0 (824) Alexa-Remote HTTP2-PUSH: Send Ping
              2024-03-08 18:07:55.641  - info: fhem.0 (840) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
              2024-03-08 18:10:00.626  - debug: alexa2.0 (824) Alexa-Remote HTTP2-PUSH: Send Ping
              2024-03-08 18:12:00.092  - info: host.raspberrypi instance system.adapter.solarmanpv.0 started with pid 1908
              2024-03-08 18:12:04.893  - info: solarmanpv.0 (1908) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v18.19.1, js-controller: 5.0.19
              2024-03-08 18:12:14.391  - info: solarmanpv.0 (1908) State value to set for "solarmanpv.0.3104772.221753192.DEV_TYP1" has to be type "number" but received type "string"
              2024-03-08 18:12:14.500  - info: solarmanpv.0 (1908) State value to set for "solarmanpv.0.3104772.221753192.COMM_PTC_v1" has to be type "string" but received type "number"
              2024-03-08 18:12:14.572  - info: solarmanpv.0 (1908) State value to set for "solarmanpv.0.3104772.221753192.HWv1" has to be type "string" but received type "number"
              2024-03-08 18:12:15.297  - info: solarmanpv.0 (1908) State value to set for "solarmanpv.0.3104772.221753192.NOP" has to be type "number" but received type "string"
              2024-03-08 18:12:16.099  - info: solarmanpv.0 (1908) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
              2024-03-08 18:12:16.702  - info: host.raspberrypi instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                @stefan-3
                1GB RAM ist auch deutlich zu wenig.
                Unter 4 macht es eigentlich kaum Sinn.
                MartinP S 2 Replies Last reply Reply Quote 0
                • MartinP
                  MartinP @Thomas Braun last edited by
                  @thomas-braun Wie schaut es eigentlich mit möglichst abgemagerten ioBroker Slaves aus? Wo ist da die untere sinnvolle RAM-Grenze?
                  irgendein oller Pi, der über USB z. B. einen Smartmeter Lesekopf antreibt, und dieser wird in einen ioBroker Slave mit Smartmeter Adapter flugs an den Master ioBroker weitergeleitet?
                    Thomas Braun Most Active @MartinP last edited by
                    @martinp sagte in Zigbee Adapter Error Send Command failed with no error code:
                    Da könntest du mit 1GB hinkommen. Aber da muss ja auch außer des etsprechenden Adapters auch nix mehr laufen, nichtmal ein admin. Hier ist aber ja auch deutlich mehr am Start, inkl. FHEM.
                      Stefan 3 @Thomas Braun last edited by
                      @thomas-braun Das Swap-File hat 2GB. Ergebnis:
                      pi@raspberrypi:~ $ free -m
                      Mem:             908         576          83           0         310         332
                      Swap:           2147         467        1680
                      Gut, ist nicht (mehr) die performanteste HW, aber muss ich Deiner Meinung nach nun echt eine neue HW kaufen? Das kann doch nicht Dein Ernst sein. Mal abgesehen davon glaub ich nicht dran, dass daher die Zigbee-Probleme herkommen.
                        @stefan-3 sagte in Zigbee Adapter Error Send Command failed with no error code:
                        Dann schlag dich weiter mit komischen Problemen herum. Jedenfalls ist 1GB für einen sinnvollen Betrieb mit einer handvoll Adapter zu wenig.
                        S 1 Reply Last reply Reply Quote 2
                          @thomas-braun Sorry, wollte Dir nicht zu nahe treten. Zumindest testweise hab ich mal alle Adapter bis auf Zigbee deaktiviert > reboot > RAM Auslastung:
                          Mem:             908         458         258           1         249         449
                          Swap:           2147           0        2147
                          und dennoch, sobald ich die RGB brightness verändere, erhalte ich die Zigbee Fehlermeldung.
                          @arteck Hast Du (oder gerne auch jemand anderes) nicht noch eine Idee, wie ich den Fehler eingrenzen kann. Es sind ausschließlich alle (3 Stück bei mir) LED Dimmer vom Typ HOMA1001 betroffen, die bis ca. Jahreswechsel 2023/24 einwandfrei funktioniert hatten.
                          Zusatzinfo: Ein Original Netzteil hab ich inzwischen bestellt, da das frühere USB-Ladenetzteil tatsächlich eine gewisse Instabilität zur Folge hat, welche ich mit dem aktuellen Labornetzteil so nicht mehr sehe. Dass es aktuell also noch am Netzteil liegt schließe ich aus.
                            Stefan 3 @Stefan 3 last edited by
                            @arteck Hab inzwischen ein Original Raspi-Netzteil installiert. Das Verhalten bleibt jedoch unverändert (im Vergleich zu meinem Labornetzteil), d.h. Zigbee Fehler und einmalige undervoltage Meldung, sobald ich eine USB-Tastatur am Raspi anstecke, aber das schließe ich als Ursache für den Zigbee-Effekt aus.
                              mrjeschke @Stefan 3 last edited by
                              @stefan-3
                              Zum Thema zigbee hätte ich noch einen Schuß ins Blaue.
                              Ich hatte vor längerer Zeit (ca. 1Jahr) das Problem das bei meinen
                              Hue-Lampen an/aus und Helligkeit funkionierten, bei Änderungen
                              der Farbe kam es zum gleichen Fehler.
                              Ursache war bei mir der dp hue_calibration.
                              Nachdem ich den Inhalt des dp gelöscht habe, klappte es wieder.
                              Vieleicht hast du ja ein ähnliches Problem.
                                Stefan 3 @mrjeschke last edited by
                                @mrjeschke Ich gehe davon aus, dass du mit dp = Datenpunkt meinst. Der dp zum Setzen der Helligkeit nennt sich bei mir brightness_rgb.
                                Hiervon kann ich den Wert ändern. Der LED Stripe ändert dann seine Helligkeit nicht und ich bekomme eine Fehlermeldung im iob Log.
                                Zum Löschen des Inhalts des dp hab ich den dp brightness_rgb (und später auch alle anderen dp des Geräts) als JSON-Datei exportiert und dabei "Keine Zustandswerte exportieren" angewählt, dann den dp gelöscht und danach die JSON-Datei wieder importiert. Meinst du das mit "Inhalt des dp löschen"?
                                Dieses Löschen hat leider keinen Einfluss auf das HW-Verhalten.
                                  Ich hab nun Folgendes gemacht:
                                  • Pairing eines HOMA1001 Dimmers aufgehoben
                                  • State Cleanup durchgeführt
                                  • Restart Zigbee-Adapter
                                  • HOMA1001 Dimmer neu gepaired -> klappt fehlerfrei
                                  • Leider ist der Dimmer ohne jegliche Funktion. Einträge im Error Log:
                                  • Dann den Dimmer bei "Ausschliessen" ergänzt.
                                  • Leider gleiches Verhalten wie zuvor (keine Funktion und die gleichen Log Einträge).
                                  • In der Datei /opt/iobroker/iobroker-data/zigbee_0/shepherd.db wird der Dimmer ganz richtig aufgenommen:
                                  {"id":20,"type":"Router","ieeeAddr":"0x00124b0018d52b59","nwkAddr":40982,"manufId":0,"manufName":"ShenZhen_Homa","powerSource":"Mains (single phase)","modelId":"HOMA1001","epList":[10,11,13],"endpoints":{"10":{"profId":260,"epId":10,"devId":256,"inClusterList":[0,3,4,5,6,8],"outClusterList":[],"clusters":{"genOnOff":{"attributes":{"onOff":1}},"genBasic":{"attributes":{"zclVersion":1}}},"binds":[],"configuredReportings":[],"meta":{}},"11":{"profId":49246,"epId":11,"devId":528,"inClusterList":[0,3,4,5,6,8,768],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"13":{"profId":49246,"epId":13,"devId":57694,"inClusterList":[4096],"outClusterList":[4096],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20131206","swBuildId":"1.0.2","zclVersion":1,"interviewCompleted":true,"meta":{},"lastSeen":1711647347498}
                                  • In der Datei /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/shenzhen_homa.js wird der HOMA1001-Dimmer auch richtig beschrieben:
                                  const definitions = [
                                          fingerprint: [
                                              { modelID: 'HOMA1001', endpoints: [
                                                      { ID: 10, profileID: 49246, deviceID: 256, inputClusters: [0, 3, 4, 5, 6, 8], outputClusters: [] },
                                                      { ID: 11, profileID: 49246, deviceID: 528, inputClusters: [0, 3, 4, 5, 6, 8, 768], outputClusters: [] },
                                                      { ID: 13, profileID: 49246, deviceID: 57694, inputClusters: [4096], outputClusters: [4096] },
                                          model: 'HOMA1001_RGBW',
                                          vendor: 'Shenzhen Homa',
                                          description: 'Smart LED driver RGBW',
                                          extend: extend_1.default.light_onoff_brightness_color(),
                                          exposes: [e.light_brightness().withEndpoint('white'), e.light_brightness_colorxy().withEndpoint('rgb')],
                                          meta: { multiEndpoint: true },
                                          endpoint: (device) => {
                                              return { white: 10, rgb: 11 };
                                          fingerprint: [
                                          model: 'HOMA1001_RGB',
                                          description: 'Smart LED driver RGB',
                                          extend: [(0, modernExtend_1.light)({ color: true })],
                                          fingerprint: [
                                                      { ID: 11, profileID: 49246, deviceID: 544, inputClusters: [0, 3, 4, 5, 6, 8, 768], outputClusters: [] },
                                          model: 'HOMA1001_CT',
                                          description: 'Smart LED driver CT',
                                          extend: [(0, modernExtend_1.light)()],
                                          fingerprint: [
                                                      { ID: 11, profileID: 49246, deviceID: 256, inputClusters: [0, 3, 4, 5, 6, 8], outputClusters: [] },
                                          model: 'HOMA1001_SC',
                                          description: 'Smart LED driver SC',
                                  Aus mir nicht nachvollziehbaren Gründen hat er nun gänzlich verlernt wie der HOMA1001 Dimmer anzusteuern ist 😞
                                    arteck Developer Most Active @Stefan 3 last edited by arteck
                                    @stefan-3 zeigmal die angelegten Datenpunkte..die nach dem pairing entstanden sind
                                      @arteck Über Nacht hatte ich den Dimmer stromlos. Beim wieder anklemmen erhalte ich im Log eine "announced itself"-Meldung:
                                      Hier die zugehörigen Datenpunkte:
                                      Asgothian 2 Replies Last reply Reply Quote 0
                                      • Asgothian
                                        Asgothian Developer @Stefan 3 last edited by
                                        @stefan-3 das ist normal. Das Netz merkt sich das es sich da um ein bekanntes Gerät handelt.
                                        • Asgothian
                                          Die Tatsache das die datenpunkte die in deiner Fehlermeldung angeblich fehlen doch vorhanden sind deuten darauf hin das es einen Fehler im Zeitablauf des anlernen gibt - das anlernen und aufbauen der States dauert (bei deinem System) länger als der herdsman und das gerät erwarten - die 3 Fehlermeldungen beim Anlernen darfst du also ignorieren.
                                          Ansonsten stellt sich die Frage was an Meldungen kommt wenn du
                                          • 52b95 in den state zigbee.0.info.debugmessages einträgst
                                          • danach den device-query DP triggered
                                          • danach versuchst einzelne states zu ändern.
                                          Durch den Eintrag für die debug messages sollte jeder Versuch da was zu ändern bis zu 4 warn Meldungen mit dem Schlüsselwort Elevated im log erscheinen.
                                          A.
                                            Stefan 3 @Asgothian last edited by
                                            @asgothian Als Log-Antwort auf device-query erhält man:
                                            Und wenn man z.B. die Helligkeit der weißen LEDs ändert:
                                            Meines Erachtens alles ganz normal bis auf die Tatsache, dass er das states-mapping vergessen hat.
                                            Ich hab das Device daraufhin nochmal entkoppelt -> state cleanup -> restart Zigbee Adapter -> Pairing. Ergebnis unverändert das fehlende states-mapping:
                                            Auch danach ist das Verhalten bei state-Änderungen unverändert.
                                            3961
