    4. Login funktioniert nach Backup-Wiederherstellung nicht mehr
      Homoran Global Moderator Administrators @Pauli290787 last edited by
      @pauli290787
      bitte als Text in code-tags posten!
      Bei richtiger Behandlung sind die code-tags direkt im output integriert
        *** iob diag is starting up, please wait ***
        *** ioBroker Diagnosis ***
        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
        https://forum.iobroker.net
        Just copy and paste the Summary Page, including the ``` characters at start and end.
        It helps us to help you!
        Press any key to continue
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: rsp-automation
               Icon name: computer
                  Kernel: Linux 6.1.0-rpi8-rpi-v8
            Architecture: arm64
        Model		: Raspberry Pi 4 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         10:13:11 up 11:58,  2 users,  load average: 0.23, 0.33, 0.54
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sat 2024-03-09 10:13:11 CET
                   Universal time: Sat 2024-03-09 09:13:11 UTC
                         RTC time: n/a
                        Time zone: Europe/Vienna (CET, +0100)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        Boot Target: 	multi-user.target
        *** MEMORY ***
        Mem:            4.0G        742M        1.1G        1.2M        2.2G        3.2G
        Swap:           104M          0B        104M
        Total:          4.1G        742M        1.2G
                 3792 M total memory
                  708 M used memory
                  861 M active memory
                 1536 M inactive memory
                 1080 M free memory
                  154 M buffer memory
                 1925 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     380M  1.2M  379M   1% /run
        /dev/sda2      ext4       56G  5.5G   49G  11% /
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        /dev/sda1      vfat      510M   61M  450M  12% /boot/firmware
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Fri Mar  8 22:15:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:50:4B:F4 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=31733faa-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Fri Mar  8 22:15:04 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Fri Mar  8 22:15:06 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
        TARGET           SOURCE    FSTYPE OPTIONS
        /                /dev/sda2 ext4   rw,noatime
        `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        695M	/var/
        376M	/var/cache
        370M	/var/cache/apt
        258M	/var/cache/apt/archives
        169M	/var/lib
        Archived and active journals take up 49.2M in the file system.
        /opt/iobroker/backups:
        11M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        500M	/opt/iobroker/iobroker-data/
        451M	/opt/iobroker/iobroker-data/files
        89M	/opt/iobroker/iobroker-data/files/echarts.admin
        57M	/opt/iobroker/iobroker-data/files/javascript.admin
        57M	/opt/iobroker/iobroker-data/files/echarts
        35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.19.1
        /usr/bin/node 		v18.19.1
        /usr/bin/npm 		10.2.4
        /usr/bin/npx 		10.2.4
        /usr/bin/corepack 	0.22.0
        nodejs:
          Installed: 18.19.1-1nodesource1
          Candidate: 18.19.1-1nodesource1
          Version table:
         *** 18.19.1-1nodesource1 1001
                100 /var/lib/dpkg/status
             18.19.0+dfsg-6~deb12u1 500
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	5.0.19
        admin: 		6.13.16
        javascript: 	7.8.0
        Adapters from github: 	6
        Adapter State
        + system.adapter.admin.0                  : admin                 : rsp-automation                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                 : alexa2                : rsp-automation                           - disabled
          system.adapter.awtrix-light.0           : awtrix-light          : rsp-automation                           - disabled
        + system.adapter.backitup.0               : backitup              : rsp-automation                           -  enabled
          system.adapter.birthdays.0              : birthdays             : rsp-automation                           - disabled
          system.adapter.ble.0                    : ble                   : rsp-automation                           - disabled
          system.adapter.device-reminder.0        : device-reminder       : rsp-automation                           - disabled
          system.adapter.devices.0                : devices               : rsp-automation                           - disabled
          system.adapter.discovery.0              : discovery             : rsp-automation                           - disabled
          system.adapter.echarts.0                : echarts               : rsp-automation                           - disabled
          system.adapter.email.0                  : email                 : rsp-automation                           - disabled
          system.adapter.enigma2.0                : enigma2               : rsp-automation                           - disabled
          system.adapter.feiertage.0              : feiertage             : rsp-automation                           - disabled
          system.adapter.fhem.0                   : fhem                  : rsp-automation                           - disabled, port: 7072
          system.adapter.harmony.0                : harmony               : rsp-automation                           - disabled
          system.adapter.hm-rpc.0                 : hm-rpc                : rsp-automation                           - disabled, port: 0
          system.adapter.hm-rpc.1                 : hm-rpc                : rsp-automation                           - disabled, port: 0
          system.adapter.homeconnect.0            : homeconnect           : rsp-automation                           - disabled
          system.adapter.ical.0                   : ical                  : rsp-automation                           - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : rsp-automation                           - disabled
          system.adapter.influxdb.0               : influxdb              : rsp-automation                           - disabled, port: 3004
          system.adapter.info.0                   : info                  : rsp-automation                           - disabled
          system.adapter.iot.0                    : iot                   : rsp-automation                           - disabled
          system.adapter.jarvis.0                 : jarvis                : rsp-automation                           - disabled
          system.adapter.javascript.0             : javascript            : rsp-automation                           - disabled
          system.adapter.klipper-moonraker.0      : klipper-moonraker     : rsp-automation                           - disabled
          system.adapter.knx.0                    : knx                   : rsp-automation                           - disabled, bind: 10.0.0.37
          system.adapter.life360.0                : life360               : rsp-automation                           - disabled
          system.adapter.linux-control.0          : linux-control         : rsp-automation                           - disabled
          system.adapter.mihome-vacuum.0          : mihome-vacuum         : rsp-automation                           - disabled, port: 54321
          system.adapter.milight-smart-light.0    : milight-smart-light   : rsp-automation                           - disabled
          system.adapter.mqtt.0                   : mqtt                  : rsp-automation                           - disabled, port: 1883, bind: 0.0.0.0
          system.adapter.mytime.0                 : mytime                : rsp-automation                           - disabled
          system.adapter.netatmo.0                : netatmo               : rsp-automation                           - disabled
          system.adapter.notification-manager.0   : notification-manager  : rsp-automation                           - disabled
          system.adapter.nuki-extended.0          : nuki-extended         : rsp-automation                           - disabled
          system.adapter.openknx.0                : openknx               : rsp-automation                           - disabled
          system.adapter.owntracks.0              : owntracks             : rsp-automation                           - disabled, port: 1885, bind: 0.0.0.0
          system.adapter.pi-hole.0                : pi-hole               : rsp-automation                           - disabled
          system.adapter.ping.0                   : ping                  : rsp-automation                           - disabled
          system.adapter.pjlinkv2.0               : pjlinkv2              : rsp-automation                           - disabled, port: 3461
          system.adapter.pushover.0               : pushover              : rsp-automation                           - disabled
          system.adapter.rpi2.0                   : rpi2                  : rsp-automation                           - disabled
          system.adapter.sayit.0                  : sayit                 : rsp-automation                           - disabled, port: 0
          system.adapter.scenes.0                 : scenes                : rsp-automation                           - disabled
          system.adapter.shelly.0                 : shelly                : rsp-automation                           - disabled, port: 1889, bind: 10.0.0.37
          system.adapter.shelly.1                 : shelly                : rsp-automation                           - disabled, port: 1899, bind: 10.0.0.37
          system.adapter.shuttercontrol.0         : shuttercontrol        : rsp-automation                           - disabled
          system.adapter.signal-cmb.0             : signal-cmb            : rsp-automation                           - disabled
          system.adapter.simple-api.0             : simple-api            : rsp-automation                           - disabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.smartcontrol.0           : smartcontrol          : rsp-automation                           - disabled
          system.adapter.smartmeter.0             : smartmeter            : rsp-automation                           - disabled
          system.adapter.sonoff.0                 : sonoff                : rsp-automation                           - disabled, port: 1898, bind: 0.0.0.0
          system.adapter.sonos.0                  : sonos                 : rsp-automation                           - disabled
          system.adapter.synology.0               : synology              : rsp-automation                           - disabled, port: 5001
          system.adapter.tado.0                   : tado                  : rsp-automation                           - disabled
          system.adapter.telegram.0               : telegram              : rsp-automation                           - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.text2command.0           : text2command          : rsp-automation                           - disabled
          system.adapter.tr-064.0                 : tr-064                : rsp-automation                           - disabled
          system.adapter.trashschedule.0          : trashschedule         : rsp-automation                           - disabled
          system.adapter.unifi.0                  : unifi                 : rsp-automation                           - disabled
          system.adapter.vis-players.0            : vis                   : rsp-automation                           - disabled
          system.adapter.vis.0                    : vis                   : rsp-automation                           - disabled
          system.adapter.web-speedy.0             : web-speedy            : rsp-automation                           - disabled
          system.adapter.web.0                    : web                   : rsp-automation                           - disabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.wiobrowser.0             : wiobrowser            : rsp-automation                           - disabled, port: 5000
          system.adapter.wled.0                   : wled                  : rsp-automation                           - disabled
          system.adapter.worx.0                   : worx                  : rsp-automation                           - disabled
          system.adapter.zigbee.0                 : zigbee                : rsp-automation                           - disabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): Stable (default)
        Installed ioBroker-Instances
        Used repository: Stable (default)
        Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
        Adapter    "awtrix-light" : 0.13.1   , installed 0.15.0
        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
        Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
        Adapter    "ble"          : 0.14.0   , installed 0.14.0
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "email"        : 1.2.2    , installed 1.2.2
        Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "fhem"         : 2.0.5    , installed 2.0.5
        Adapter    "harmony"      : 1.3.0    , installed 1.3.0
        Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
        Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Adapter    "knx"          : 2.0.24   , installed 2.0.24
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
        Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "notification-manager": 1.0.0, installed 1.0.0
        Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
        Adapter    "openknx"      : 0.7.2    , installed 0.7.2
        Adapter    "owntracks"    : 1.0.5    , installed 1.0.5
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "pushover"     : 3.0.6    , installed 3.0.6
        Adapter    "sayit"        : 3.0.5    , installed 4.0.0
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
        Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "synology"     : 3.0.1    , installed 3.0.1
        Adapter    "tado"         : 0.5.3    , installed 0.5.3
        Adapter    "telegram"     : 3.1.0    , installed 3.1.0
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "trashschedule": 3.2.0    , installed 3.2.0
        Adapter    "unifi"        : 0.6.7    , installed 0.6.7
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
        Adapter    "wled"         : 0.7.2    , installed 0.7.2
        Adapter    "worx"         : 2.3.4    , installed 2.3.4
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
        Objects and States
        Objects: 	18459
        States: 	14746
        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:6 https://apt.debmatic.de/debmatic stable InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1999            0.0.0.0:*               LISTEN      0          30578      5870/lighttpd
        tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      0          30584      5870/lighttpd
        tcp        0      0 0.0.0.0:2000            0.0.0.0:*               LISTEN      0          30586      5870/lighttpd
        tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      0          30580      5870/lighttpd
        tcp        0      0 0.0.0.0:8181            0.0.0.0:*               LISTEN      0          30576      5870/lighttpd
        tcp        0      0 0.0.0.0:8183            0.0.0.0:*               LISTEN      0          34710      7410/ReGaHss.commun
        tcp        0      0 0.0.0.0:31999           0.0.0.0:*               LISTEN      0          35389      7410/ReGaHss.commun
        tcp        0      0 127.0.0.1:30080         0.0.0.0:*               LISTEN      0          34645      7287/lighttpd
        tcp        0      0 0.0.0.0:9292            0.0.0.0:*               LISTEN      0          30582      5870/lighttpd
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       53580      13989/iobroker.js-c
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53587      13989/iobroker.js-c
        tcp        0      0 0.0.0.0:88              0.0.0.0:*               LISTEN      0          30575      5870/lighttpd
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13285      767/sshd: /usr/sbin
        tcp6       0      0 :::1999                 :::*                    LISTEN      0          30579      5870/lighttpd
        tcp6       0      0 :::2001                 :::*                    LISTEN      0          30585      5870/lighttpd
        tcp6       0      0 :::2000                 :::*                    LISTEN      0          30587      5870/lighttpd
        tcp6       0      0 :::2010                 :::*                    LISTEN      0          30581      5870/lighttpd
        tcp6       0      0 :::8181                 :::*                    LISTEN      0          30577      5870/lighttpd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       56380      14014/io.admin.0
        tcp6       0      0 :::9292                 :::*                    LISTEN      0          30583      5870/lighttpd
        tcp6       0      0 :::39292                :::*                    LISTEN      0          37306      7331/java
        tcp6       0      0 :::88                   :::*                    LISTEN      0          30574      5870/lighttpd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13287      767/sshd: /usr/sbin
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          35249      7267/ssdpd
        udp        0      0 127.0.0.1:1998          0.0.0.0:*                           0          34711      7410/ReGaHss.commun
        udp        0      0 127.0.0.1:8182          0.0.0.0:*                           0          34644      7275/hss_led
        udp        0      0 0.0.0.0:43439           0.0.0.0:*                           0          34629      7252/eq3configd
        udp        0      0 0.0.0.0:55861           0.0.0.0:*                           104        12185      542/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        12183      542/avahi-daemon: r
        udp6       0      0 :::55181                :::*                                0          37299      7331/java
        udp6       0      0 :::33071                :::*                                104        12186      542/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        12184      542/avahi-daemon: r
        2024-03-09 09:37:53.785  - info: host.rsp-automation iobroker install mytime@0.7.12 using installedFrom
        2024-03-09 09:37:54.648  - info: host.rsp-automation instance system.adapter.backitup.0 started with pid 14038
        2024-03-09 09:37:55.457  - info: admin.0 (14014) received all objects
        2024-03-09 09:37:56.272  - info: admin.0 (14014) Request actual repository...
        2024-03-09 09:37:56.634  - info: admin.0 (14014) socket.io server listening on port 8081
        2024-03-09 09:37:56.640  - info: admin.0 (14014) http server listening on port 8081
        2024-03-09 09:37:56.640  - info: admin.0 (14014) Use link "http://127.0.0.1:8081" to configure.
        2024-03-09 09:37:56.968  - info: host.rsp-automation Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
        2024-03-09 09:37:58.321  - info: backitup.0 (14038) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2024-03-09 09:37:58.738  - error: host.rsp-automation iobroker npm-install: host.rsp-automation Unknown packetName mytime. Please install packages from outside the repository using npm!
        2024-03-09 09:37:59.339  - info: admin.0 (14014) Repository received successfully.
        2024-03-09 09:37:59.355  - info: backitup.0 (14038) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.1, js-controller: 5.0.19
        2024-03-09 09:37:59.447  - info: backitup.0 (14038) [iobroker] backup will be activated at 02:40 every 1 day(s)
        2024-03-09 09:38:00.175  - info: host.rsp-automation iobroker npm-install: exit 12
        2024-03-09 09:38:01.176  - warn: host.rsp-automation startInstance cannot find adapter "vis-players@1.5.4". Try to install it... 1 attempt
        2024-03-09 09:38:01.177  - info: host.rsp-automation iobroker install vis@1.5.4 using installedFrom
        2024-03-09 09:38:03.073  - info: host.rsp-automation iobroker npm-install: adapter "vis" already installed. Use "upgrade" to upgrade to a newer version.
        2024-03-09 09:38:04.099  - info: host.rsp-automation iobroker npm-install: exit 51
        2024-03-09 09:38:05.101  - warn: host.rsp-automation startInstance cannot find adapter "web-speedy@0.2.0". Try to install it... 1 attempt
        2024-03-09 09:38:05.101  - info: host.rsp-automation iobroker install web-speedy@0.2.0 using installedFrom
        2024-03-09 09:38:07.745  - error: host.rsp-automation iobroker npm-install: host.rsp-automation Unknown packetName web-speedy. Please install packages from outside the repository using npm!
        2024-03-09 09:38:08.795  - info: host.rsp-automation iobroker npm-install: exit 12
        2024-03-09 09:38:11.915  - error: backitup.0 (14038) Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //10.0.0.175/ioBroker-Backup /opt/iobroker/backups
        mount error(113): could not connect to 10.0.0.175Unable to find suitable address.
        iob diag has finished.
        Press any key for a summary
        Copy text starting here:
        			v.2023-10-10
               Icon name: computer
            Architecture: arm64
        Installation: 		native
        Kernel: 		aarch64
        Userland: 		arm64
        Timezone: 		Europe/Vienna (CET, +0100)
        User-ID: 		1000
        X-Server: 		false
        Pending OS-Updates: 	0
        Pending iob updates: 	0
        Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
        			/usr/bin/npm 		10.2.4
        			/usr/bin/npx 		10.2.4
        Recommended versions are nodejs 18.19.1 and npm 10.2.4
        MEMORY:
        Mem:            4.0G        752M        1.1G        1.2M        2.2G        3.2G
        Swap:           104M          0B        104M
        Total:          4.1G        752M        1.2G
        Active iob-Instances: 	3
        ioBroker Core: 		js-controller 		5.0.19
        			admin 			6.13.16
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects: 		18459
        States: 		14746
        Size of iob-Database:
        21M	/opt/iobroker/iobroker-data/objects.jsonl
        4.3M	/opt/iobroker/iobroker-data/states.jsonl
          @pauli290787
          benutzt du Windows Editoren?
          das darf man mit Linuxdaten nie machen (wenn man sie wieder in Linux verwenden will! )
          Der Admin läuft, und sollte auch erreichbar sein.
          Da wir es die Tage gerade erst hatten: läuft eine Firewall?
            Windows edition von was?
            Firewall läuft keine.
            Der Admin ist auch erreichbar aber der Login funktioniert nicht.
            P Homoran 2 Replies Last reply Reply Quote 0
              Pauli290787 @Pauli290787 last edited by
              Sorry hab mich verlesen... Editoren ... Ja
                @pauli290787 sagte in Login funktioniert nach Backup-Wiederherstellung nicht mehr:
                aber nicht per https, was imho für die Authentifizierung notwendig wäre.
                  Wieso brauche ich im selben Netz für die Authentifizierung HTTPS?
                  Hatte ich bis jetzt intern nie verwendet
                    Habe jetzt testweise iobroker noch einmal komplett gelöscht und neu installiert.
                    Unmittelbar nach der Installation alles bestens.
                    Dann bin ich die Ersteintrichtung durchlaufen und habe das Backup wieder eingespielt und zur Sicherheit per PuTTY noch ein passwd gemacht.
                    Dann den Admin wieder aufgerufen --> gleicher Fehler "Benutzername oder Passwort sind falsch" egal was ich eingebe 😞
                      @pauli290787 Das "unbekannte" Passwort kommt doch aus dem Restore.
                      Was ist denn in dem Backup drin gewesen?
                      Hostname gleich geblieben?
                        Ja das kommt aus dem Backup aber ich hätte es ja sogar versucht per passwd zu ändern.
                        Das mit dem Hostname kann ich jetzt gar nicht zu 100 % sagen. Könnte das die Ursache sein ?
                          Pauli290787 last edited by Pauli290787
                          Habe es gerade kontrolliert der Hostname ist gleich.
                            Thomas Braun Most Active @Pauli290787 last edited by
                            @pauli290787
                            passwd ist auf Betriebssystemebene, hat mit dem ioBroker/Admin nix zu tun.
                              ich meinte
                              iobroker passwd admin
                                Wildbill @Pauli290787 last edited by
                                @pauli290787 Hast Du nach dem restore auch lang genug gewartet, bis alle Adapter aus dem Backup installiert wurden? Wenn nach dem restore die Vollzugsmeldung kommt, dann startet erst der eigentliche Vorgang und dann wird erst nach und nach wieder alles installiert und die ganzen Objekte geschrieben. Nicht, dass Du da im laufenden Vorgang bereits versuchst das Passwort zu ändern oder so. Kann, je nach Hardware schon so 20min-1Stunde dauern.
                                Gruss, Jürgen
                                  Heute hat es geklappt, aber die Ursache ist mir bis jetzt unklar.
                                  Ich habe den iobroker noch einmal neu installiert und dann gleich per Konsole das Backup eingespielt.
                                  433
