Login funktioniert nach Backup-Wiederherstellung nicht mehr
[H[2J[3J*** iob diag is starting up, please wait ***
[H[2J[3J
[34;107m*** ioBroker Diagnosis ***[0mPlease stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
Just copy and paste the Summary Page, including the ``` characters at start and end.
It helps us to help you!Press any key to continue
[H[2J[3J
[33m======== Start marking the full check here =========[0mSkript v.2023-10-10 [34;107m*** BASE SYSTEM ***[0m Static hostname: rsp-automation Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-rpi8-rpi-v8 Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.1 Docker : false Virtualization : none Kernel : aarch64 Userland : arm64 Systemuptime and Load: 10:13:11 up 11:58, 2 users, load average: 0.23, 0.33, 0.54 CPU threads: 4 [34;107m*** RASPBERRY THROTTLING ***[0m Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. [34;107m*** Time and Time Zones ***[0m Local time: Sat 2024-03-09 10:13:11 CET Universal time: Sat 2024-03-09 09:13:11 UTC RTC time: n/a Time zone: Europe/Vienna (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no [34;107m*** User and Groups ***[0m pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker [34;107m*** X-Server-Setup ***[0m X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target [34;107m*** MEMORY ***[0m total used free shared buff/cache available Mem: 4.0G 742M 1.1G 1.2M 2.2G 3.2G Swap: 104M 0B 104M Total: 4.1G 742M 1.2G 3792 M total memory 708 M used memory 861 M active memory 1536 M inactive memory 1080 M free memory 154 M buffer memory 1925 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms [34;107m*** FAILED SERVICES ***[0m UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. [34;107m*** FILESYSTEM ***[0m Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 1.6G 0 1.6G 0% /dev tmpfs tmpfs 380M 1.2M 379M 1% /run /dev/sda2 ext4 56G 5.5G 49G 11% / tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock /dev/sda1 vfat 510M 61M 450M 12% /boot/firmware tmpfs tmpfs 380M 0 380M 0% /run/user/1000 [32mMessages concerning ext4 filesystem in dmesg:[0m [Fri Mar 8 22:15:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:50:4B:F4 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=31733faa-02 rootfstype=ext4 fsck.repair=yes rootwait [Fri Mar 8 22:15:04 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none. [Fri Mar 8 22:15:06 2024] EXT4-fs (sda2): re-mounted. Quota mode: none. [32mShow mounted filesystems \(real ones only\):[0m TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot/firmware /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro [32mFiles in neuralgic directories:[0m [32m/var:[0m 695M /var/ 376M /var/cache 370M /var/cache/apt 258M /var/cache/apt/archives 169M /var/lib Archived and active journals take up 49.2M in the file system. [32m/opt/iobroker/backups:[0m 11M /opt/iobroker/backups/ [32m/opt/iobroker/iobroker-data:[0m 500M /opt/iobroker/iobroker-data/ 451M /opt/iobroker/iobroker-data/files 89M /opt/iobroker/iobroker-data/files/echarts.admin 57M /opt/iobroker/iobroker-data/files/javascript.admin 57M /opt/iobroker/iobroker-data/files/echarts [32mThe five largest files in iobroker-data are:[0m 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map 24M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map 23M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map [32mUSB-Devices by-id:[0m USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': [34;107m*** NodeJS-Installation ***[0m /usr/bin/nodejs v18.19.1 /usr/bin/node v18.19.1 /usr/bin/npm 10.2.4 /usr/bin/npx 10.2.4 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.1-1nodesource1 Candidate: 18.19.1-1nodesource1 Version table: *** 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 18.19.0+dfsg-6~deb12u1 500 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.13.0+dfsg1-1 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [32mTemp directories causing npm8 problem:[0m 0 No problems detected Errors in npm tree: [34;107m*** ioBroker-Installation ***[0m [32mioBroker Status[0m iobroker is running on this host. Objects type: jsonl States type: jsonl [32mCore adapters versions[0m js-controller: 5.0.19 admin: 6.13.16 javascript: 7.8.0 Adapters from github: 6 [32mAdapter State[0m + system.adapter.admin.0 : admin : rsp-automation - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alexa2.0 : alexa2 : rsp-automation - disabled system.adapter.awtrix-light.0 : awtrix-light : rsp-automation - disabled + system.adapter.backitup.0 : backitup : rsp-automation - enabled system.adapter.birthdays.0 : birthdays : rsp-automation - disabled system.adapter.ble.0 : ble : rsp-automation - disabled system.adapter.device-reminder.0 : device-reminder : rsp-automation - disabled system.adapter.devices.0 : devices : rsp-automation - disabled system.adapter.discovery.0 : discovery : rsp-automation - disabled system.adapter.echarts.0 : echarts : rsp-automation - disabled system.adapter.email.0 : email : rsp-automation - disabled system.adapter.enigma2.0 : enigma2 : rsp-automation - disabled system.adapter.feiertage.0 : feiertage : rsp-automation - disabled system.adapter.fhem.0 : fhem : rsp-automation - disabled, port: 7072 system.adapter.harmony.0 : harmony : rsp-automation - disabled system.adapter.hm-rpc.0 : hm-rpc : rsp-automation - disabled, port: 0 system.adapter.hm-rpc.1 : hm-rpc : rsp-automation - disabled, port: 0 system.adapter.homeconnect.0 : homeconnect : rsp-automation - disabled system.adapter.ical.0 : ical : rsp-automation - disabled system.adapter.icons-material-png.0 : icons-material-png : rsp-automation - disabled system.adapter.influxdb.0 : influxdb : rsp-automation - disabled, port: 3004 system.adapter.info.0 : info : rsp-automation - disabled system.adapter.iot.0 : iot : rsp-automation - disabled system.adapter.jarvis.0 : jarvis : rsp-automation - disabled system.adapter.javascript.0 : javascript : rsp-automation - disabled system.adapter.klipper-moonraker.0 : klipper-moonraker : rsp-automation - disabled system.adapter.knx.0 : knx : rsp-automation - disabled, bind: 10.0.0.37 system.adapter.life360.0 : life360 : rsp-automation - disabled system.adapter.linux-control.0 : linux-control : rsp-automation - disabled system.adapter.mihome-vacuum.0 : mihome-vacuum : rsp-automation - disabled, port: 54321 system.adapter.milight-smart-light.0 : milight-smart-light : rsp-automation - disabled system.adapter.mqtt.0 : mqtt : rsp-automation - disabled, port: 1883, bind: 0.0.0.0 system.adapter.mytime.0 : mytime : rsp-automation - disabled system.adapter.netatmo.0 : netatmo : rsp-automation - disabled system.adapter.notification-manager.0 : notification-manager : rsp-automation - disabled system.adapter.nuki-extended.0 : nuki-extended : rsp-automation - disabled system.adapter.openknx.0 : openknx : rsp-automation - disabled system.adapter.owntracks.0 : owntracks : rsp-automation - disabled, port: 1885, bind: 0.0.0.0 system.adapter.pi-hole.0 : pi-hole : rsp-automation - disabled system.adapter.ping.0 : ping : rsp-automation - disabled system.adapter.pjlinkv2.0 : pjlinkv2 : rsp-automation - disabled, port: 3461 system.adapter.pushover.0 : pushover : rsp-automation - disabled system.adapter.rpi2.0 : rpi2 : rsp-automation - disabled system.adapter.sayit.0 : sayit : rsp-automation - disabled, port: 0 system.adapter.scenes.0 : scenes : rsp-automation - disabled system.adapter.shelly.0 : shelly : rsp-automation - disabled, port: 1889, bind: 10.0.0.37 system.adapter.shelly.1 : shelly : rsp-automation - disabled, port: 1899, bind: 10.0.0.37 system.adapter.shuttercontrol.0 : shuttercontrol : rsp-automation - disabled system.adapter.signal-cmb.0 : signal-cmb : rsp-automation - disabled system.adapter.simple-api.0 : simple-api : rsp-automation - disabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.smartcontrol.0 : smartcontrol : rsp-automation - disabled system.adapter.smartmeter.0 : smartmeter : rsp-automation - disabled system.adapter.sonoff.0 : sonoff : rsp-automation - disabled, port: 1898, bind: 0.0.0.0 system.adapter.sonos.0 : sonos : rsp-automation - disabled system.adapter.synology.0 : synology : rsp-automation - disabled, port: 5001 system.adapter.tado.0 : tado : rsp-automation - disabled system.adapter.telegram.0 : telegram : rsp-automation - disabled, port: 8443, bind: 0.0.0.0 system.adapter.text2command.0 : text2command : rsp-automation - disabled system.adapter.tr-064.0 : tr-064 : rsp-automation - disabled system.adapter.trashschedule.0 : trashschedule : rsp-automation - disabled system.adapter.unifi.0 : unifi : rsp-automation - disabled system.adapter.vis-players.0 : vis : rsp-automation - disabled system.adapter.vis.0 : vis : rsp-automation - disabled system.adapter.web-speedy.0 : web-speedy : rsp-automation - disabled system.adapter.web.0 : web : rsp-automation - disabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.wiobrowser.0 : wiobrowser : rsp-automation - disabled, port: 5000 system.adapter.wled.0 : wled : rsp-automation - disabled system.adapter.worx.0 : worx : rsp-automation - disabled system.adapter.zigbee.0 : zigbee : rsp-automation - disabled, port: /dev/ttyACM0 + instance is alive [32mEnabled adapters with bindings[0m + system.adapter.admin.0 : admin : rsp-automation - enabled, port: 8081, bind: 0.0.0.0, run as: admin [32mioBroker-Repositories[0m Stable (default): http://download.iobroker.net/sources-dist.json Beta (latest) : http://download.iobroker.net/sources-dist-latest.json Active repo(s): Stable (default) [32mInstalled ioBroker-Instances[0m Used repository: Stable (default) Adapter "admin" : 6.13.16 , installed 6.13.16 Adapter "alexa2" : 3.26.4 , installed 3.26.4 Adapter "awtrix-light" : 0.13.1 , installed 0.15.0 Adapter "backitup" : 2.10.11 , installed 2.10.11 Adapter "birthdays" : 2.4.1 , installed 2.4.1 Adapter "ble" : 0.14.0 , installed 0.14.0 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "echarts" : 1.7.2 , installed 1.7.2 Adapter "email" : 1.2.2 , installed 1.2.2 Adapter "enigma2" : 2.0.5 , installed 2.0.5 Adapter "feiertage" : 1.1.4 , installed 1.1.4 Adapter "fhem" : 2.0.5 , installed 2.0.5 Adapter "harmony" : 1.3.0 , installed 1.3.0 Adapter "hm-rpc" : 1.16.0 , installed 1.16.0 Adapter "homeconnect" : 1.3.0 , installed 1.3.0 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 2.0.11 , installed 2.0.11 Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 7.8.0 , installed 7.8.0 Controller "js-controller": 5.0.19 , installed 5.0.19 Adapter "knx" : 2.0.24 , installed 2.0.24 Adapter "linux-control": 1.1.5 , installed 1.1.5 Adapter "mihome-vacuum": 4.1.1 , installed 4.1.1 Adapter "milight-smart-light": 1.2.2, installed 1.2.2 Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "netatmo" : 3.1.0 , installed 3.1.0 Adapter "notification-manager": 1.0.0, installed 1.0.0 Adapter "nuki-extended": 2.6.5 , installed 2.6.5 Adapter "openknx" : 0.7.2 , installed 0.7.2 Adapter "owntracks" : 1.0.5 , installed 1.0.5 Adapter "pi-hole" : 1.3.6 , installed 1.3.6 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pushover" : 3.0.6 , installed 3.0.6 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "sayit" : 3.0.5 , installed 4.0.0 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 6.6.1 , installed 6.6.1 Adapter "shuttercontrol": 1.7.0 , installed 1.7.0 Adapter "signal-cmb" : 0.3.0 , installed 0.3.0 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "smartmeter" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "sonos" : 3.0.0 , installed 3.0.0 Adapter "synology" : 3.0.1 , installed 3.0.1 Adapter "tado" : 0.5.3 , installed 0.5.3 Adapter "telegram" : 3.1.0 , installed 3.1.0 Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "trashschedule": 3.2.0 , installed 3.2.0 Adapter "unifi" : 0.6.7 , installed 0.6.7 Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "web" : 6.2.3 , installed 6.2.3 Adapter "wiobrowser" : 2.0.2 , installed 2.0.2 Adapter "wled" : 0.7.2 , installed 0.7.2 Adapter "worx" : 2.3.4 , installed 2.3.4 Adapter "ws" : 2.5.10 , installed 2.5.10 Adapter "zigbee" : 1.10.1 , installed 1.10.1 [32mObjects and States[0m Please stand by - This may take a while Objects: 18459 States: 14746 [34;107m*** OS-Repositories and Updates ***[0m Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease Hit:4 http://deb.debian.org/debian bookworm-updates InRelease Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease Hit:6 https://apt.debmatic.de/debmatic stable InRelease Reading package lists... Pending Updates: 0 [34;107m*** Listening Ports ***[0m Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:1999 0.0.0.0:* LISTEN 0 30578 5870/lighttpd tcp 0 0 0.0.0.0:2001 0.0.0.0:* LISTEN 0 30584 5870/lighttpd tcp 0 0 0.0.0.0:2000 0.0.0.0:* LISTEN 0 30586 5870/lighttpd tcp 0 0 0.0.0.0:2010 0.0.0.0:* LISTEN 0 30580 5870/lighttpd tcp 0 0 0.0.0.0:8181 0.0.0.0:* LISTEN 0 30576 5870/lighttpd tcp 0 0 0.0.0.0:8183 0.0.0.0:* LISTEN 0 34710 7410/ReGaHss.commun tcp 0 0 0.0.0.0:31999 0.0.0.0:* LISTEN 0 35389 7410/ReGaHss.commun tcp 0 0 127.0.0.1:30080 0.0.0.0:* LISTEN 0 34645 7287/lighttpd tcp 0 0 0.0.0.0:9292 0.0.0.0:* LISTEN 0 30582 5870/lighttpd tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 53580 13989/iobroker.js-c tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 53587 13989/iobroker.js-c tcp 0 0 0.0.0.0:88 0.0.0.0:* LISTEN 0 30575 5870/lighttpd tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 13285 767/sshd: /usr/sbin tcp6 0 0 :::1999 :::* LISTEN 0 30579 5870/lighttpd tcp6 0 0 :::2001 :::* LISTEN 0 30585 5870/lighttpd tcp6 0 0 :::2000 :::* LISTEN 0 30587 5870/lighttpd tcp6 0 0 :::2010 :::* LISTEN 0 30581 5870/lighttpd tcp6 0 0 :::8181 :::* LISTEN 0 30577 5870/lighttpd tcp6 0 0 :::8081 :::* LISTEN 1001 56380 14014/io.admin.0 tcp6 0 0 :::9292 :::* LISTEN 0 30583 5870/lighttpd tcp6 0 0 :::39292 :::* LISTEN 0 37306 7331/java tcp6 0 0 :::88 :::* LISTEN 0 30574 5870/lighttpd tcp6 0 0 :::22 :::* LISTEN 0 13287 767/sshd: /usr/sbin udp 0 0 0.0.0.0:1900 0.0.0.0:* 0 35249 7267/ssdpd udp 0 0 127.0.0.1:1998 0.0.0.0:* 0 34711 7410/ReGaHss.commun udp 0 0 127.0.0.1:8182 0.0.0.0:* 0 34644 7275/hss_led udp 0 0 0.0.0.0:43439 0.0.0.0:* 0 34629 7252/eq3configd udp 0 0 0.0.0.0:55861 0.0.0.0:* 104 12185 542/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 12183 542/avahi-daemon: r udp6 0 0 :::55181 :::* 0 37299 7331/java udp6 0 0 :::33071 :::* 104 12186 542/avahi-daemon: r udp6 0 0 :::5353 :::* 104 12184 542/avahi-daemon: r [34;107m*** Log File - Last 25 Lines ***[0m 2024-03-09 09:37:53.785 - [32minfo[39m: host.rsp-automation iobroker install mytime@0.7.12 using installedFrom 2024-03-09 09:37:54.648 - [32minfo[39m: host.rsp-automation instance system.adapter.backitup.0 started with pid 14038 2024-03-09 09:37:55.457 - [32minfo[39m: admin.0 (14014) received all objects 2024-03-09 09:37:56.272 - [32minfo[39m: admin.0 (14014) Request actual repository... 2024-03-09 09:37:56.634 - [32minfo[39m: admin.0 (14014) socket.io server listening on port 8081 2024-03-09 09:37:56.640 - [32minfo[39m: admin.0 (14014) http server listening on port 8081 2024-03-09 09:37:56.640 - [32minfo[39m: admin.0 (14014) Use link "http://127.0.0.1:8081" to configure. 2024-03-09 09:37:56.968 - [32minfo[39m: host.rsp-automation Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json" 2024-03-09 09:37:58.321 - [32minfo[39m: backitup.0 (14038) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system 2024-03-09 09:37:58.738 - [31merror[39m: host.rsp-automation iobroker npm-install: host.rsp-automation Unknown packetName mytime. Please install packages from outside the repository using npm! 2024-03-09 09:37:59.339 - [32minfo[39m: admin.0 (14014) Repository received successfully. 2024-03-09 09:37:59.355 - [32minfo[39m: backitup.0 (14038) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.1, js-controller: 5.0.19 2024-03-09 09:37:59.447 - [32minfo[39m: backitup.0 (14038) [iobroker] backup will be activated at 02:40 every 1 day(s) 2024-03-09 09:38:00.175 - [32minfo[39m: host.rsp-automation iobroker npm-install: exit 12 2024-03-09 09:38:01.176 - [33mwarn[39m: host.rsp-automation startInstance cannot find adapter "vis-players@1.5.4". Try to install it... 1 attempt 2024-03-09 09:38:01.177 - [32minfo[39m: host.rsp-automation iobroker install vis@1.5.4 using installedFrom 2024-03-09 09:38:03.073 - [32minfo[39m: host.rsp-automation iobroker npm-install: adapter "vis" already installed. Use "upgrade" to upgrade to a newer version. 2024-03-09 09:38:04.099 - [32minfo[39m: host.rsp-automation iobroker npm-install: exit 51 2024-03-09 09:38:05.101 - [33mwarn[39m: host.rsp-automation startInstance cannot find adapter "web-speedy@0.2.0". Try to install it... 1 attempt 2024-03-09 09:38:05.101 - [32minfo[39m: host.rsp-automation iobroker install web-speedy@0.2.0 using installedFrom 2024-03-09 09:38:07.745 - [31merror[39m: host.rsp-automation iobroker npm-install: host.rsp-automation Unknown packetName web-speedy. Please install packages from outside the repository using npm! 2024-03-09 09:38:08.795 - [32minfo[39m: host.rsp-automation iobroker npm-install: exit 12 2024-03-09 09:38:11.915 - [31merror[39m: backitup.0 (14038) Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //10.0.0.175/ioBroker-Backup /opt/iobroker/backups mount error(113): could not connect to 10.0.0.175Unable to find suitable address.
[33m============ Mark until here for C&P =============[0m
iob diag has finished.
Press any key for a summary
[H[2J[3JCopy text starting here:
======================= SUMMARY ======================= v.2023-10-10 Static hostname: rsp-automation Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-rpi8-rpi-v8 Architecture: arm64 Installation: native Kernel: aarch64 Userland: arm64 Timezone: Europe/Vienna (CET, +0100) User-ID: 1000 X-Server: false Boot Target: multi-user.target Pending OS-Updates: 0 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.19.1 /usr/bin/node v18.19.1 /usr/bin/npm 10.2.4 /usr/bin/npx 10.2.4 /usr/bin/corepack 0.22.0 Recommended versions are nodejs 18.19.1 and npm 10.2.4 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 4.0G 752M 1.1G 1.2M 2.2G 3.2G Swap: 104M 0B 104M Total: 4.1G 752M 1.2G Active iob-Instances: 3 Active repo(s): Stable (default) ioBroker Core: js-controller 5.0.19 admin 6.13.16 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : rsp-automation - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.web-speedy.0 : web-speedy : rsp-automation - disabled system.adapter.web.0 : web : rsp-automation - disabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 18459 States: 14746 Size of iob-Database: 21M /opt/iobroker/iobroker-data/objects.jsonl 4.3M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ====================
@pauli290787
benutzt du Windows Editoren?
das darf man mit Linuxdaten nie machen (wenn man sie wieder in Linux verwenden will! )Der Admin läuft, und sollte auch erreichbar sein.
Da wir es die Tage gerade erst hatten: läuft eine Firewall?
Windows edition von was?
Firewall läuft keine.
Der Admin ist auch erreichbar aber der Login funktioniert nicht. -
Sorry hab mich verlesen... Editoren ... Ja
@pauli290787 sagte in Login funktioniert nach Backup-Wiederherstellung nicht mehr:
aber nicht per https, was imho für die Authentifizierung notwendig wäre.
Wieso brauche ich im selben Netz für die Authentifizierung HTTPS?
Hatte ich bis jetzt intern nie verwendet -
Habe jetzt testweise iobroker noch einmal komplett gelöscht und neu installiert.
Unmittelbar nach der Installation alles bestens.
Dann bin ich die Ersteintrichtung durchlaufen und habe das Backup wieder eingespielt und zur Sicherheit per PuTTY noch ein passwd gemacht.
Dann den Admin wieder aufgerufen --> gleicher Fehler "Benutzername oder Passwort sind falsch" egal was ich eingebe -
@pauli290787 Das "unbekannte" Passwort kommt doch aus dem Restore.
Was ist denn in dem Backup drin gewesen?Hostname gleich geblieben?
Ja das kommt aus dem Backup aber ich hätte es ja sogar versucht per passwd zu ändern.
Das mit dem Hostname kann ich jetzt gar nicht zu 100 % sagen. Könnte das die Ursache sein ?
Habe es gerade kontrolliert der Hostname ist gleich.
passwd ist auf Betriebssystemebene, hat mit dem ioBroker/Admin nix zu tun.
ich meinte
iobroker passwd admin
@pauli290787 Hast Du nach dem restore auch lang genug gewartet, bis alle Adapter aus dem Backup installiert wurden? Wenn nach dem restore die Vollzugsmeldung kommt, dann startet erst der eigentliche Vorgang und dann wird erst nach und nach wieder alles installiert und die ganzen Objekte geschrieben. Nicht, dass Du da im laufenden Vorgang bereits versuchst das Passwort zu ändern oder so. Kann, je nach Hardware schon so 20min-1Stunde dauern.
Gruss, Jürgen
Heute hat es geklappt, aber die Ursache ist mir bis jetzt unklar.
Ich habe den iobroker noch einmal neu installiert und dann gleich per Konsole das Backup eingespielt.
