    5. Bewegungserkennung mit Motioneye, Lösung komplett in Blockly
      A Former User @Virus2K12 last edited by
      @virus2k12
      logfile? Fehlermeldungen?
      Virus2K12 1 Reply Last reply Reply Quote 0
      • Virus2K12
        Virus2K12 @Guest last edited by
        @ilovegym nicht im log und keine Fehlermeldung.?
        • Virus2K12
          Virus2K12 last edited by Virus2K12
          im javasript haut er dieses log raus, wenn ich per Telegramm Foto schicke:
          3/6/2024, 11:03:26 AM.583 [info ]: javascript.0 (2028) Stop script script.js.yicam.bild_telegramm
          3/6/2024, 11:03:27 AM.656 [info ]: javascript.0 (2028) Start javascript script.js.yicam.bild_telegramm
          3/6/2024, 11:03:27 AM.695 [info ]: javascript.0 (2028) script.js.yicam.bild_telegramm: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          3/6/2024, 11:03:45 AM.966 [info ]: javascript.0 (2028) script.js.yicam.bild_telegramm: exec: curl 192.168.178.51:7999/1/action/snapshot
          3/6/2024, 11:05:56 AM.554 [info ]: javascript.0 (2028) Stop script script.js.yicam.bild_telegramm
          3/6/2024, 11:05:57 AM.241 [info ]: javascript.0 (2028) Start javascript script.js.yicam.bild_telegramm
          3/6/2024, 11:05:57 AM.267 [info ]: javascript.0 (2028) script.js.yicam.bild_telegramm: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          3/6/2024, 11:06:07 AM.386 [info ]: javascript.0 (2028) script.js.yicam.bild_telegramm: exec: curl 192.168.178.51:7999/1/action/snapshot
          3/6/2024, 11:06:41 AM.546 [info ]: javascript.0 (2028) Stop script script.js.yicam.bild_telegramm
          3/6/2024, 11:06:42 AM.353 [info ]: javascript.0 (2028) Start javascript script.js.yicam.bild_telegramm
          3/6/2024, 11:06:42 AM.385 [info ]: javascript.0 (2028) script.js.yicam.bild_telegramm: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          3/6/2024, 11:06:52 AM.330 [info ]: javascript.0 (2028) script.js.yicam.bild_telegramm: exec: curl 192.168.178.51:7999/1/action/snapshot
          3/6/2024, 11:07:07 AM.332 [info ]: javascript.0 (2028) Stop script script.js.yicam.bild_telegramm
          3/6/2024, 11:07:08 AM.057 [info ]: javascript.0 (2028) Start javascript script.js.yicam.bild_telegramm
          3/6/2024, 11:07:08 AM.064 [info ]: javascript.0 (2028) script.js.yicam.bild_telegramm: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          • Virus2K12
              crunchip Forum Testing Most Active @Virus2K12 last edited by
              @virus2k12 setz mal den Haken Mit Ergebnisse, im Blockly
              • Virus2K12
                keine Änderung, werder im Telegramm noch im log.
                  @virus2k12
                  laedt er das Bild denn auch runter, also funktioniert der exec curl befehl?
                  • Virus2K12
                    Virus2K12 @Guest last edited by Virus2K12
                    @ilovegym ja. liegt im angegeben pfad. siehe screen weiter oben
                    https://forum.iobroker.net/topic/40016/bewegungserkennung-mit-motioneye-lösung-komplett-in-blockly/47
                    • Virus2K12
                      und das sagt mein iob log:
                      • Virus2K12
                        was ich jetzt beobachtet habe, der Wert von takeSnapshot ändert sich nicht in true und lässt sich auch nicht per Hand auf true setzen. Bei getLastpic funktioniert das.?
                        Woran kann das liegen?
                          @virus2k12 sagte in Bewegungserkennung mit Motioneye, Lösung komplett in Blockly:
                          Zeig mal das Raw vom DP
                          • Virus2K12
                            @crunchip
                            "common": {
                            "name": "motioneye.takeSnapshot",
                            "role": "state",
                            "type": "boolean",
                            "custom": {
                            "telegram.0": {
                            "enabled": true,
                            "alias": "takeSnapshot",
                            "buttons": 3,
                            "writeOnly": false,
                            "offCommand": "",
                            "onCommand": "",
                            "offStatus": "",
                            "onStatus": "",
                            "onlyFalse": false,
                            "readOnly": false,
                            "report": true,
                            "onlyTrue": false,
                            "reportChanges": true
                            "native": {},
                            "type": "state",
                            "_id": "javascript.0.motioneye.takeSnapshot",
                            "acl": {
                            "object": 1636,
                            "state": 1636,
                            "owner": "system.user.admin",
                            "ownerGroup": "system.group.user"
                            "user": "system.user.admin",
                            "ts": 1710056777837
                              crunchip Forum Testing Most Active @Virus2K12 last edited by crunchip
                              @virus2k12 und den anderen zum Vergleich
                              Irgendwie fehlt da read/write true
                              • Virus2K12
                                Virus2K12 @crunchip last edited by
                                @crunchip
                                "common": {
                                "name": "motioneye.getLastPic",
                                "role": "state",
                                "type": "boolean",
                                "custom": {
                                "telegram.0": {
                                "enabled": true,
                                "alias": "getLastPic",
                                "buttons": 3,
                                "writeOnly": false,
                                "offCommand": "",
                                "onCommand": "",
                                "offStatus": "",
                                "onStatus": "",
                                "onlyFalse": false,
                                "readOnly": false,
                                "report": true,
                                "onlyTrue": false,
                                "native": {},
                                "type": "state",
                                "_id": "javascript.0.motioneye.getLastPic",
                                "acl": {
                                "object": 1636,
                                "state": 1636,
                                "ts": 1710056528080
                                • Virus2K12
                                  Virus2K12 @Virus2K12 last edited by Virus2K12
                                  wurden beide im Blockly so angelegt.
                                  Habe mal read + write mit rein genommen, ändert sich aber nichts.
                                    @virus2k12 ich sehe an den beiden keinen Unterschied, kannst mal den DP manuell selbst anlegen
                                    • Virus2K12
                                      @crunchip sagte in Bewegungserkennung mit Motioneye, Lösung komplett in Blockly:
                                      auch schon probiert, dann kann ich ihn ändern. Sofern ich aber im Telegram "foto" schicke lässt sich danach der DP wieder nicht ändern. Er schreibe zwar
                                      nur ändert er sich nicht sichtbar.
                                        @virus2k12 kein Plan was da bei dir falsch läuft. Ich hatte das ganze anders laufen
                                        https://forum.iobroker.net/post/373101
                                        Virus2K12 1 Reply Last reply Reply Quote 1
                                        • Virus2K12
                                          @crunchip hab das jetzt auch so umgesetzt und es funktioniert. Einige Anpassungen gemacht zwecks schalten über Telegramm etc, jetzt noch die Anwesenheit Erkennung einbauen und dann sollte es so funktionieren wie ich es will.
                                          Danke für den Tip.
                                          blockly communication monitoring security template
                                          12
                                          62
                                          15694
